  4. ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert
esphomepythonwemos d1 miniplatformio
29 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
  • M mayokleckz
    ok, alles klar.
    Fix habe ich ausgeführt. Danach dann den find befehl
     $ iob stop
    flo@raspberrypi:~ $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Get:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Fetched 15.0 kB in 1s (12.9 kB/s)
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    flo@raspberrypi:~ $ iob start
    flo@raspberrypi:~ $ find "/usr/lib/" -iname "EXTERNALLY*"
    find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
    flo@raspberrypi:~ $
    Edit: Der auszug der Datei / home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log noch
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.5.1
    2 info using node@v18.16.0
    3 timing npm:load:whichnode Completed in 3ms
    4 timing config:load:defaults Completed in 6ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 14ms
    6 timing config:load:builtin Completed in 15ms
    7 timing config:load:cli Completed in 9ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
    10 timing config:load:project Completed in 22ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 4ms
    16 timing config:load Completed in 59ms
    17 timing npm:load:configload Completed in 59ms
    18 timing npm:load:mkdirpcache Completed in 1ms
    19 timing npm:load:mkdirplogs Completed in 1ms
    20 verbose title npm install iobroker.esphome@0.2.4
    21 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
    22 timing npm:load:setTitle Completed in 5ms
    23 timing config:load:flatten Completed in 11ms
    24 timing npm:load:display Completed in 14ms
    25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-
    26 verbose logfile /home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    27 timing npm:load:logFile Completed in 18ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 104ms
    31 timing arborist:ctor Completed in 3ms
    32 silly logfile start cleaning logs, removing 2 files
    33 silly logfile done cleaning log files
    34 timing idealTree:init Completed in 3379ms
    35 timing idealTree:userRequests Completed in 22ms
    36 silly idealTree buildDeps
    37 silly fetch manifest iobroker.esphome@0.2.4
    38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    39 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 94ms (cache hit)
    40 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
    41 silly fetch manifest @sentry/node@^5.30.0
    42 silly fetch manifest esphome-native-api@^1.0.9
    43 silly fetch manifest nopy@^0.2.7
    44 silly fetch manifest tree-kill@^1.2.2
    45 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 55ms (cache hit)
    46 http fetch GET 200 https://registry.npmjs.org/tree-kill 55ms (cache hit)
    47 http fetch GET 200 https://registry.npmjs.org/nopy 58ms (cache hit)
    48 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 97ms (cache hit)
    49 timing idealTree:#root Completed in 267ms
    50 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
    51 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
    52 silly placeDep ROOT nopy@0.2.9 OK for: iobroker.esphome@0.2.4 want: ^0.2.7
    53 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
    54 silly fetch manifest @sentry/core@5.30.0
    55 silly fetch manifest @sentry/hub@5.30.0
    56 silly fetch manifest @sentry/types@5.30.0
    57 silly fetch manifest @sentry/utils@5.30.0
    58 silly fetch manifest eslint@^7.13.0
    59 silly fetch manifest events@^3.2.0
    60 silly fetch manifest google-protobuf@^3.14.0
    61 silly fetch manifest multicast-dns@^7.2.2
    62 silly fetch manifest net@^1.0.2
    63 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 3521ms (cache hit)
    64 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 3542ms (cache hit)
    65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 3557ms (cache hit)
    66 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 3571ms (cache hit)
    67 http fetch GET 200 https://registry.npmjs.org/eslint 3590ms (cache hit)
    68 http fetch GET 200 https://registry.npmjs.org/events 3649ms (cache hit)
    69 http fetch GET 200 https://registry.npmjs.org/google-protobuf 3650ms (cache hit)
    70 http fetch GET 200 https://registry.npmjs.org/net 3651ms (cache hit)
    71 http fetch GET 200 https://registry.npmjs.org/multicast-dns 3655ms (cache hit)
    72 timing idealTree:node_modules/iobroker.esphome Completed in 3743ms
    73 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
    74 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
    75 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
    76 silly placeDep ROOT multicast-dns@7.2.5 OK for: esphome-native-api@1.0.9 want: ^7.2.2
    77 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
    78 silly fetch manifest @babel/code-frame@7.12.11
    79 silly fetch manifest @eslint/eslintrc@^0.4.3
    80 silly fetch manifest @humanwhocodes/config-array@^0.5.0
    81 silly fetch manifest debug@^4.0.1
    82 silly fetch manifest doctrine@^3.0.0
    83 silly fetch manifest enquirer@^2.3.5
    84 silly fetch manifest eslint-scope@^5.1.1
    85 silly fetch manifest eslint-utils@^2.1.0
    86 silly fetch manifest eslint-visitor-keys@^2.0.0
    87 silly fetch manifest espree@^7.3.1
    88 silly fetch manifest esquery@^1.4.0
    89 silly fetch manifest esutils@^2.0.2
    90 silly fetch manifest file-entry-cache@^6.0.1
    91 silly fetch manifest functional-red-black-tree@^1.0.1
    92 silly fetch manifest globals@^13.6.0
    93 silly fetch manifest ignore@^4.0.6
    94 silly fetch manifest js-yaml@^3.13.1
    95 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
    96 silly fetch manifest levn@^0.4.1
    97 silly fetch manifest lodash.merge@^4.6.2
    98 silly fetch manifest minimatch@^3.0.4
    99 silly fetch manifest natural-compare@^1.4.0
    100 silly fetch manifest optionator@^0.9.1
    101 silly fetch manifest progress@^2.0.0
    102 silly fetch manifest regexpp@^3.1.0
    103 silly fetch manifest strip-json-comments@^3.1.0
    104 silly fetch manifest table@^6.0.9
    105 silly fetch manifest text-table@^0.2.0
    106 silly fetch manifest v8-compile-cache@^2.0.3
    107 silly fetch manifest dns-packet@^5.2.2
    108 silly fetch manifest thunky@^1.0.2
    109 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 428ms (cache hit)
    110 http fetch GET 200 https://registry.npmjs.org/doctrine 426ms (cache hit)
    111 http fetch GET 200 https://registry.npmjs.org/eslint-scope 427ms (cache hit)
    112 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 437ms (cache hit)
    113 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 442ms (cache hit)
    114 http fetch GET 200 https://registry.npmjs.org/debug 445ms (cache hit)
    115 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 441ms (cache hit)
    116 http fetch GET 200 https://registry.npmjs.org/espree 445ms (cache hit)
    117 http fetch GET 200 https://registry.npmjs.org/esquery 452ms (cache hit)
    118 http fetch GET 200 https://registry.npmjs.org/esutils 451ms (cache hit)
    119 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 451ms (cache hit)
    120 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 451ms (cache hit)
    121 http fetch GET 200 https://registry.npmjs.org/globals 452ms (cache hit)
    122 http fetch GET 200 https://registry.npmjs.org/ignore 455ms (cache hit)
    123 http fetch GET 200 https://registry.npmjs.org/enquirer 485ms (cache hit)
    124 http fetch GET 200 https://registry.npmjs.org/levn 457ms (cache hit)
    125 http fetch GET 200 https://registry.npmjs.org/eslint-utils 488ms (cache hit)
    126 http fetch GET 200 https://registry.npmjs.org/js-yaml 468ms (cache hit)
    127 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 471ms (cache hit)
    128 http fetch GET 200 https://registry.npmjs.org/natural-compare 463ms (cache hit)
    129 http fetch GET 200 https://registry.npmjs.org/optionator 444ms (cache hit)
    130 http fetch GET 200 https://registry.npmjs.org/progress 444ms (cache hit)
    131 http fetch GET 200 https://registry.npmjs.org/regexpp 443ms (cache hit)
    132 http fetch GET 200 https://registry.npmjs.org/lodash.merge 476ms (cache hit)
    133 http fetch GET 200 https://registry.npmjs.org/text-table 440ms (cache hit)
    134 http fetch GET 200 https://registry.npmjs.org/dns-packet 437ms (cache hit)
    135 http fetch GET 200 https://registry.npmjs.org/minimatch 483ms (cache hit)
    136 http fetch GET 200 https://registry.npmjs.org/thunky 450ms (cache hit)
    137 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 465ms (cache hit)
    138 http fetch GET 200 https://registry.npmjs.org/table 468ms (cache hit)
    139 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 488ms (cache hit)
    140 timing idealTree:node_modules/esphome-native-api Completed in 614ms
    141 silly placeDep node_modules/eslint @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
    142 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
    143 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
    144 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
    145 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
    146 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
    147 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
    148 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
    149 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
    150 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
    151 silly placeDep ROOT esquery@1.5.0 OK for: eslint@7.32.0 want: ^1.4.0
    152 silly placeDep ROOT esutils@2.0.3 OK for: eslint@7.32.0 want: ^2.0.2
    153 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
    154 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
    155 silly placeDep ROOT globals@13.20.0 OK for: eslint@7.32.0 want: ^13.6.0
    156 silly placeDep node_modules/eslint ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
    157 silly placeDep ROOT js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
    158 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
    159 silly placeDep ROOT levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
    160 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
    161 silly placeDep node_modules/eslint minimatch@3.1.2 OK for: eslint@7.32.0 want: ^3.0.4
    162 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
    163 silly placeDep ROOT optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
    164 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
    165 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
    166 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
    167 silly placeDep ROOT table@6.8.1 OK for: eslint@7.32.0 want: ^6.0.9
    168 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
    169 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
    170 silly fetch manifest debug@^4.1.1
    171 silly fetch manifest strip-json-comments@^3.1.1
    172 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
    173 silly fetch manifest ms@2.1.2
    174 silly fetch manifest ansi-colors@^4.1.1
    175 silly fetch manifest esrecurse@^4.3.0
    176 silly fetch manifest estraverse@^4.1.1
    177 silly fetch manifest eslint-visitor-keys@^1.1.0
    178 silly fetch manifest acorn@^7.4.0
    179 silly fetch manifest acorn-jsx@^5.3.1
    180 silly fetch manifest eslint-visitor-keys@^1.3.0
    181 silly fetch manifest estraverse@^5.1.0
    182 silly fetch manifest flat-cache@^3.0.4
    183 silly fetch manifest type-fest@^0.20.2
    184 silly fetch manifest argparse@^1.0.7
    185 silly fetch manifest esprima@^4.0.0
    186 silly fetch manifest prelude-ls@^1.2.1
    187 silly fetch manifest type-check@~0.4.0
    188 silly fetch manifest brace-expansion@^1.1.7
    189 silly fetch manifest deep-is@^0.1.3
    190 silly fetch manifest word-wrap@^1.2.3
    191 silly fetch manifest type-check@^0.4.0
    192 silly fetch manifest fast-levenshtein@^2.0.6
    193 silly fetch manifest ajv@^8.0.1
    194 silly fetch manifest lodash.truncate@^4.4.2
    195 silly fetch manifest slice-ansi@^4.0.0
    196 http fetch GET 200 https://registry.npmjs.org/ms 221ms (cache hit)
    197 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 227ms (cache hit)
    198 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 211ms (cache hit)
    199 http fetch GET 200 https://registry.npmjs.org/estraverse 209ms (cache hit)
    200 http fetch GET 200 https://registry.npmjs.org/flat-cache 209ms (cache hit)
    201 http fetch GET 200 https://registry.npmjs.org/argparse 207ms (cache hit)
    202 http fetch GET 200 https://registry.npmjs.org/type-fest 215ms (cache hit)
    203 http fetch GET 200 https://registry.npmjs.org/estraverse 239ms (cache hit)
    204 http fetch GET 200 https://registry.npmjs.org/esrecurse 246ms (cache hit)
    205 http fetch GET 200 https://registry.npmjs.org/acorn 242ms (cache hit)
    206 http fetch GET 200 https://registry.npmjs.org/ansi-colors 260ms (cache hit)
    207 http fetch GET 200 https://registry.npmjs.org/prelude-ls 235ms (cache hit)
    208 http fetch GET 200 https://registry.npmjs.org/word-wrap 218ms (cache hit)
    209 http fetch GET 200 https://registry.npmjs.org/type-check 236ms (cache hit)
    210 http fetch GET 200 https://registry.npmjs.org/brace-expansion 236ms (cache hit)
    211 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 215ms (cache hit)
    212 http fetch GET 200 https://registry.npmjs.org/fast-levenshtein 222ms (cache hit)
    213 http fetch GET 200 https://registry.npmjs.org/ajv 226ms (cache hit)
    214 http fetch GET 200 https://registry.npmjs.org/slice-ansi 236ms (cache hit)
    215 http fetch GET 200 https://registry.npmjs.org/esprima 274ms (cache hit)
    216 http fetch GET 200 https://registry.npmjs.org/deep-is 259ms (cache hit)
    217 http fetch GET 200 https://registry.npmjs.org/type-check 255ms (cache hit)
    218 timing idealTree:node_modules/eslint Completed in 529ms
    219 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
    220 silly placeDep node_modules/@eslint/eslintrc ignore@4.0.6 OK for: @eslint/eslintrc@0.4.3 want: ^4.0.6
    221 silly placeDep node_modules/@eslint/eslintrc minimatch@3.1.2 OK for: @eslint/eslintrc@0.4.3 want: ^3.0.4
    222 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
    223 timing idealTree:node_modules/@eslint/eslintrc Completed in 15ms
    224 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
    225 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
    226 silly placeDep node_modules/@humanwhocodes/config-array minimatch@3.1.2 OK for: @humanwhocodes/config-array@0.5.0 want: ^3.0.4
    227 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 13ms
    228 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
    229 timing idealTree:node_modules/doctrine Completed in 0ms
    230 silly placeDep ROOT ansi-colors@4.1.3 OK for: enquirer@2.3.6 want: ^4.1.1
    231 timing idealTree:node_modules/enquirer Completed in 5ms
    232 timing idealTree:node_modules/ansi-colors Completed in 0ms
    233 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
    234 silly placeDep ROOT estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
    235 silly fetch manifest estraverse@^5.2.0
    236 timing idealTree:node_modules/eslint-scope Completed in 12ms
    237 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
    238 timing idealTree:node_modules/eslint-utils Completed in 3ms
    239 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
    240 silly placeDep ROOT acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
    241 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
    242 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
    243 timing idealTree:node_modules/espree Completed in 45ms
    244 timing idealTree:node_modules/acorn Completed in 1ms
    245 timing idealTree:node_modules/acorn-jsx Completed in 0ms
    246 silly placeDep node_modules/esquery estraverse@5.3.0 OK for: esquery@1.5.0 want: ^5.1.0
    247 timing idealTree:node_modules/esquery Completed in 5ms
    248 silly placeDep node_modules/esrecurse estraverse@5.3.0 OK for: esrecurse@4.3.0 want: ^5.2.0
    249 timing idealTree:node_modules/esrecurse Completed in 4ms
    250 timing idealTree:node_modules/estraverse Completed in 0ms
    251 timing idealTree:node_modules/esutils Completed in 0ms
    252 timing idealTree:node_modules/events Completed in 0ms
    253 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
    254 silly fetch manifest flatted@^3.1.0
    255 http fetch GET 200 https://registry.npmjs.org/flatted 17ms (cache hit)
    256 timing idealTree:node_modules/file-entry-cache Completed in 28ms
    257 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
    258 timing idealTree:node_modules/flat-cache Completed in 10ms
    259 timing idealTree:node_modules/flatted Completed in 0ms
    260 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
    261 silly placeDep node_modules/globals type-fest@0.20.2 OK for: globals@13.20.0 want: ^0.20.2
    262 timing idealTree:node_modules/globals Completed in 4ms
    263 timing idealTree:node_modules/google-protobuf Completed in 0ms
    264 silly placeDep ROOT argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
    265 silly placeDep ROOT esprima@4.0.1 OK for: js-yaml@3.14.1 want: ^4.0.0
    266 silly fetch manifest sprintf-js@~1.0.2
    267 http fetch GET 200 https://registry.npmjs.org/sprintf-js 9ms (cache hit)
    268 timing idealTree:node_modules/js-yaml Completed in 24ms
    269 silly placeDep node_modules/argparse sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
    270 timing idealTree:node_modules/argparse Completed in 3ms
    271 timing idealTree:node_modules/esprima Completed in 0ms
    272 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
    273 silly placeDep ROOT prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
    274 silly placeDep ROOT type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
    275 timing idealTree:node_modules/levn Completed in 13ms
    276 timing idealTree:node_modules/lodash.merge Completed in 0ms
    277 silly placeDep node_modules/multicast-dns dns-packet@5.6.0 OK for: multicast-dns@7.2.5 want: ^5.2.2
    278 silly placeDep ROOT thunky@1.1.0 OK for: multicast-dns@7.2.5 want: ^1.0.2
    279 silly fetch manifest @leichtgewicht/ip-codec@^2.0.1
    280 http fetch GET 200 https://registry.npmjs.org/@leichtgewicht%2fip-codec 9ms (cache hit)
    281 timing idealTree:node_modules/multicast-dns Completed in 23ms
    282 timing idealTree:node_modules/natural-compare Completed in 0ms
    283 timing idealTree:node_modules/net Completed in 0ms
    284 timing idealTree:node_modules/nopy Completed in 1ms
    285 silly placeDep ROOT deep-is@0.1.4 OK for: optionator@0.9.1 want: ^0.1.3
    286 silly placeDep ROOT fast-levenshtein@2.0.6 OK for: optionator@0.9.1 want: ^2.0.6
    287 silly placeDep ROOT word-wrap@1.2.3 OK for: optionator@0.9.1 want: ^1.2.3
    288 timing idealTree:node_modules/optionator Completed in 17ms
    289 timing idealTree:node_modules/deep-is Completed in 1ms
    290 timing idealTree:node_modules/fast-levenshtein Completed in 0ms
    291 timing idealTree:node_modules/prelude-ls Completed in 0ms
    292 timing idealTree:node_modules/progress Completed in 0ms
    293 timing idealTree:node_modules/regexpp Completed in 0ms
    294 silly placeDep node_modules/table ajv@8.12.0 OK for: table@6.8.1 want: ^8.0.1
    295 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.1 want: ^4.4.2
    296 silly placeDep node_modules/table slice-ansi@4.0.0 OK for: table@6.8.1 want: ^4.0.0
    297 silly fetch manifest json-schema-traverse@^1.0.0
    298 silly fetch manifest require-from-string@^2.0.2
    299 silly fetch manifest astral-regex@^2.0.0
    300 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 24ms (cache hit)
    301 http fetch GET 200 https://registry.npmjs.org/require-from-string 24ms (cache hit)
    302 http fetch GET 200 https://registry.npmjs.org/astral-regex 23ms (cache hit)
    303 timing idealTree:node_modules/table Completed in 46ms
    304 timing idealTree:node_modules/lodash.truncate Completed in 0ms
    305 timing idealTree:node_modules/text-table Completed in 0ms
    306 timing idealTree:node_modules/thunky Completed in 0ms
    307 timing idealTree:node_modules/tree-kill Completed in 0ms
    308 timing idealTree:node_modules/type-check Completed in 0ms
    309 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
    310 timing idealTree:node_modules/word-wrap Completed in 0ms
    311 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    312 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 5ms
    313 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 0ms
    314 silly placeDep node_modules/@eslint/eslintrc brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    315 timing idealTree:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 4ms
    316 timing idealTree:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 0ms
    317 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
    318 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
    319 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    320 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 4ms
    321 silly placeDep node_modules/@humanwhocodes/config-array brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    322 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 4ms
    323 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 0ms
    324 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
    325 timing idealTree:node_modules/argparse/node_modules/sprintf-js Completed in 0ms
    326 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1ms
    327 timing idealTree:node_modules/eslint/node_modules/@babel/code-frame Completed in 0ms
    328 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    329 timing idealTree:node_modules/eslint/node_modules/debug Completed in 4ms
    330 timing idealTree:node_modules/eslint/node_modules/ignore Completed in 0ms
    331 silly placeDep node_modules/eslint brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    332 timing idealTree:node_modules/eslint/node_modules/minimatch Completed in 5ms
    333 timing idealTree:node_modules/eslint/node_modules/brace-expansion Completed in 0ms
    334 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
    335 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
    336 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
    337 timing idealTree:node_modules/esquery/node_modules/estraverse Completed in 0ms
    338 timing idealTree:node_modules/esrecurse/node_modules/estraverse Completed in 0ms
    339 timing idealTree:node_modules/globals/node_modules/type-fest Completed in 1ms
    340 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    341 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    342 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    343 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    344 silly fetch manifest @sentry/minimal@5.30.0
    345 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 14ms (cache hit)
    346 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 52ms
    347 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
    348 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 5ms
    349 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
    350 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
    351 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
    352 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
    353 silly placeDep ROOT @leichtgewicht/ip-codec@2.0.4 OK for: dns-packet@5.6.0 want: ^2.0.1
    354 timing idealTree:node_modules/multicast-dns/node_modules/dns-packet Completed in 7ms
    355 timing idealTree:node_modules/@leichtgewicht/ip-codec Completed in 0ms
    356 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
    357 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.12.0 want: ^2.0.2
    358 timing idealTree:node_modules/table/node_modules/ajv Completed in 10ms
    359 timing idealTree:node_modules/require-from-string Completed in 0ms
    360 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
    361 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
    362 timing idealTree:node_modules/table/node_modules/slice-ansi Completed in 6ms
    363 timing idealTree:node_modules/astral-regex Completed in 0ms
    364 timing idealTree:buildDeps Completed in 5568ms
    365 timing idealTree:fixDepFlags Completed in 25ms
    366 timing idealTree Completed in 9036ms
    367 timing reify:loadTrees Completed in 9040ms
    368 timing reify:diffTrees Completed in 105ms
    369 silly reify moves {}
    370 timing reify:retireShallow Completed in 4ms
    371 timing reify:createSparse Completed in 22ms
    372 timing reify:loadBundles Completed in 0ms
    373 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
    374 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
    375 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
    376 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
    377 timing reifyNode:node_modules/osx-temperature-sensor Completed in 67ms
    378 timing reifyNode:node_modules/fsevents Completed in 67ms
    379 timing reifyNode:node_modules/natural-compare Completed in 1296ms
    380 timing reifyNode:node_modules/require-from-string Completed in 1322ms
    381 timing reifyNode:node_modules/fast-levenshtein Completed in 1322ms
    382 timing reifyNode:node_modules/table/node_modules/slice-ansi Completed in 1337ms
    383 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1336ms
    384 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1337ms
    385 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 1338ms
    386 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1338ms
    387 timing reifyNode:node_modules/eslint/node_modules/brace-expansion Completed in 1339ms
    388 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1340ms
    389 timing reifyNode:node_modules/astral-regex Completed in 1357ms
    390 timing reifyNode:node_modules/lodash.truncate Completed in 1357ms
    391 timing reifyNode:node_modules/word-wrap Completed in 1357ms
    392 timing reifyNode:node_modules/net Completed in 1360ms
    393 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1369ms
    394 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1369ms
    395 timing reifyNode:node_modules/eslint/node_modules/@babel/code-frame Completed in 1370ms
    396 timing reifyNode:node_modules/esrecurse Completed in 1386ms
    397 timing reifyNode:node_modules/tree-kill Completed in 1386ms
    398 timing reifyNode:node_modules/thunky Completed in 1409ms
    399 timing reifyNode:node_modules/v8-compile-cache Completed in 1408ms
    400 timing reifyNode:node_modules/file-entry-cache Completed in 1409ms
    401 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1410ms
    402 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 1417ms
    403 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 1417ms
    404 timing reifyNode:node_modules/eslint/node_modules/minimatch Completed in 1417ms
    405 timing reifyNode:node_modules/type-check Completed in 1432ms
    406 timing reifyNode:node_modules/acorn-jsx Completed in 1433ms
    407 timing reifyNode:node_modules/lodash.merge Completed in 1434ms
    408 timing reifyNode:node_modules/@leichtgewicht/ip-codec Completed in 1450ms
    409 timing reifyNode:node_modules/ansi-colors Completed in 1448ms
    410 timing reifyNode:node_modules/progress Completed in 1449ms
    411 timing reifyNode:node_modules/levn Completed in 1449ms
    412 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1449ms
    413 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1456ms
    414 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1456ms
    415 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1454ms
    416 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1454ms
    417 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1454ms
    418 timing reifyNode:node_modules/estraverse Completed in 1467ms
    419 timing reifyNode:node_modules/globals Completed in 1468ms
    420 timing reifyNode:node_modules/esrecurse/node_modules/estraverse Completed in 1475ms
    421 timing reifyNode:node_modules/esquery/node_modules/estraverse Completed in 1475ms
    422 timing reifyNode:node_modules/deep-is Completed in 1487ms
    423 timing reifyNode:node_modules/flat-cache Completed in 1487ms
    424 timing reifyNode:node_modules/optionator Completed in 1488ms
    425 timing reifyNode:node_modules/functional-red-black-tree Completed in 1488ms
    426 timing reifyNode:node_modules/multicast-dns Completed in 1487ms
    427 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 1492ms
    428 timing reifyNode:node_modules/eslint/node_modules/ignore Completed in 1491ms
    429 timing reifyNode:node_modules/esutils Completed in 1539ms
    430 timing reifyNode:node_modules/multicast-dns/node_modules/dns-packet Completed in 1543ms
    431 timing reifyNode:node_modules/prelude-ls Completed in 1556ms
    432 timing reifyNode:node_modules/text-table Completed in 1596ms
    433 timing reifyNode:node_modules/espree Completed in 1596ms
    434 timing reifyNode:node_modules/doctrine Completed in 1595ms
    435 timing reifyNode:node_modules/flatted Completed in 1608ms
    436 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 1607ms
    437 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 1620ms
    438 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 1626ms
    439 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 1640ms
    440 timing reifyNode:node_modules/eslint-scope Completed in 1648ms
    441 timing reifyNode:node_modules/argparse/node_modules/sprintf-js Completed in 1666ms
    442 timing reifyNode:node_modules/regexpp Completed in 1680ms
    443 timing reifyNode:node_modules/esprima Completed in 1703ms
    444 timing reifyNode:node_modules/eslint-utils Completed in 1708ms
    445 timing reifyNode:node_modules/events Completed in 1800ms
    446 timing reifyNode:node_modules/argparse Completed in 1836ms
    447 timing reifyNode:node_modules/@eslint/eslintrc Completed in 1842ms
    448 timing reifyNode:node_modules/iobroker.esphome Completed in 1863ms
    449 timing reifyNode:node_modules/globals/node_modules/type-fest Completed in 1887ms
    450 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 1982ms
    451 timing reifyNode:node_modules/esphome-native-api Completed in 1988ms
    452 timing reifyNode:node_modules/enquirer Completed in 2004ms
    453 timing reifyNode:node_modules/google-protobuf Completed in 2047ms
    454 timing reifyNode:node_modules/esquery Completed in 2061ms
    455 timing reifyNode:node_modules/js-yaml Completed in 2063ms
    456 timing reifyNode:node_modules/acorn Completed in 2124ms
    457 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2273ms
    458 timing reifyNode:node_modules/table Completed in 2347ms
    459 timing reifyNode:node_modules/nopy Completed in 2473ms
    460 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 2542ms
    461 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 2612ms
    462 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 2732ms
    463 timing reifyNode:node_modules/table/node_modules/ajv Completed in 3151ms
    464 timing reifyNode:node_modules/eslint Completed in 3171ms
    465 timing reify:unpack Completed in 3184ms
    466 timing reify:unretire Completed in 1ms
    467 timing build:queue Completed in 19ms
    468 timing build:link:node_modules/acorn Completed in 38ms
    469 timing build:link:node_modules/eslint Completed in 35ms
    470 timing build:link:node_modules/esprima Completed in 43ms
    471 timing build:link:node_modules/js-yaml Completed in 43ms
    472 timing build:link:node_modules/multicast-dns Completed in 32ms
    473 timing build:link:node_modules/nopy Completed in 31ms
    474 timing build:link:node_modules/tree-kill Completed in 28ms
    475 timing build:link Completed in 48ms
    476 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
    477 info run iobroker.esphome@0.2.4 install { code: 126, signal: null }
    478 timing reify:rollback:createSparse Completed in 411ms
    479 timing reify:rollback:retireShallow Completed in 0ms
    480 timing command:install Completed in 12950ms
    481 verbose stack Error: command failed
    481 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
    481 verbose stack     at ChildProcess.emit (node:events:513:28)
    481 verbose stack     at maybeClose (node:internal/child_process:1091:16)
    481 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
    481 verbose stack     at Socket.emit (node:events:513:28)
    481 verbose stack     at Pipe.<anonymous> (node:net:322:12)
    482 verbose pkgid iobroker.esphome@0.2.4
    483 verbose cwd /opt/iobroker
    484 verbose Linux 6.1.21-v8+
    485 verbose node v18.16.0
    486 verbose npm  v9.5.1
    487 error code 126
    488 error path /opt/iobroker/node_modules/iobroker.esphome
    489 error command failed
    490 error command sh -c npip install
    491 error sh: 1: npip: Permission denied
    492 verbose exit 126
    493 timing npm Completed in 13118ms
    494 verbose unfinished npm timer reify 1682355031569
    495 verbose unfinished npm timer reify:build 1682355043958
    496 verbose unfinished npm timer build 1682355043962
    497 verbose unfinished npm timer build:deps 1682355043963
    498 verbose unfinished npm timer build:run:install 1682355044031
    499 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1682355044033
    500 verbose code 126
    501 error A complete log of this run can be found in:
    501 error     /home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    @mayokleckz
    Was sagt:
    ls -la /opt/iobroker/node_modules/nopy/src/
      mayokleckz
      flo@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/nopy/src/
      ls: cannot access '/opt/iobroker/node_modules/nopy/src/': No such file or directory
      flo@raspberrypi:~ $
      • M mayokleckz
        flo@raspberrypi:~ $
        @mayokleckz
        cd /opt/iobroker
        npm i nopy
        sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
        Danach sollte es mit der Installation funktionieren.
          @mayokleckz
          cd /opt/iobroker
          npm i nopy
          mayokleckz
          @thomas-braun said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
          sudo -u iobroker chmod a+x /opt/iobroker/node_modules/nopy/src/n*
          Mit den Rechten kommt man ein Stück weiter. Jedoch rennt das System in den nächsten Fehler.
          Ist da bei meiner Installation gestern was schief gegangen? Mit so viel Problemen installiert sich ja sonst niemand einen Adapter.
          Würd mich freuen wenn du auch hier nochmal drüber schaust.
          Hier das Logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
          3 timing npm:load:whichnode Completed in 24ms
          4 timing config:load:defaults Completed in 17ms
          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 24ms
          6 timing config:load:builtin Completed in 24ms
          7 timing config:load:cli Completed in 11ms
          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
          10 timing config:load:project Completed in 12ms
          11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
          13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
          15 timing config:load:setEnvs Completed in 6ms
          16 timing config:load Completed in 77ms
          17 timing npm:load:configload Completed in 77ms
          23 timing config:load:flatten Completed in 13ms
          24 timing npm:load:display Completed in 17ms
          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-
          26 verbose logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
          27 timing npm:load:logFile Completed in 20ms
          30 timing npm:load Completed in 151ms
          34 timing idealTree:init Completed in 4111ms
          35 timing idealTree:userRequests Completed in 30ms
          39 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 181ms (cache hit)
          43 silly fetch manifest tree-kill@^1.2.2
          44 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 3381ms (cache hit)
          45 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 3396ms (cache hit)
          46 http fetch GET 200 https://registry.npmjs.org/tree-kill 3453ms (cache hit)
          47 timing idealTree:#root Completed in 3683ms
          48 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
          49 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
          50 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
          51 silly fetch manifest @sentry/core@5.30.0
          52 silly fetch manifest @sentry/hub@5.30.0
          53 silly fetch manifest @sentry/types@5.30.0
          54 silly fetch manifest @sentry/utils@5.30.0
          55 silly fetch manifest eslint@^7.13.0
          56 silly fetch manifest events@^3.2.0
          57 silly fetch manifest google-protobuf@^3.14.0
          58 silly fetch manifest multicast-dns@^7.2.2
          59 silly fetch manifest net@^1.0.2
          60 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 963ms (cache hit)
          61 http fetch GET 200 https://registry.npmjs.org/events 976ms (cache hit)
          62 http fetch GET 200 https://registry.npmjs.org/multicast-dns 986ms (cache hit)
          63 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 1010ms (cache hit)
          64 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 1037ms (cache hit)
          65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 1067ms (cache hit)
          66 http fetch GET 200 https://registry.npmjs.org/google-protobuf 1072ms (cache hit)
          67 http fetch GET 200 https://registry.npmjs.org/net 1075ms (cache hit)
          68 http fetch GET 200 https://registry.npmjs.org/eslint 1093ms (cache hit)
          69 timing idealTree:node_modules/iobroker.esphome Completed in 1226ms
          70 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
          71 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
          72 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
          73 silly placeDep ROOT multicast-dns@7.2.5 OK for: esphome-native-api@1.0.9 want: ^7.2.2
          74 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
          75 silly fetch manifest @babel/code-frame@7.12.11
          76 silly fetch manifest @eslint/eslintrc@^0.4.3
          77 silly fetch manifest @humanwhocodes/config-array@^0.5.0
          78 silly fetch manifest debug@^4.0.1
          79 silly fetch manifest doctrine@^3.0.0
          80 silly fetch manifest enquirer@^2.3.5
          81 silly fetch manifest eslint-scope@^5.1.1
          82 silly fetch manifest eslint-utils@^2.1.0
          83 silly fetch manifest eslint-visitor-keys@^2.0.0
          84 silly fetch manifest espree@^7.3.1
          85 silly fetch manifest esquery@^1.4.0
          86 silly fetch manifest esutils@^2.0.2
          87 silly fetch manifest file-entry-cache@^6.0.1
          88 silly fetch manifest functional-red-black-tree@^1.0.1
          89 silly fetch manifest globals@^13.6.0
          90 silly fetch manifest ignore@^4.0.6
          91 silly fetch manifest js-yaml@^3.13.1
          92 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
          93 silly fetch manifest levn@^0.4.1
          94 silly fetch manifest lodash.merge@^4.6.2
          95 silly fetch manifest minimatch@^3.0.4
          96 silly fetch manifest natural-compare@^1.4.0
          97 silly fetch manifest optionator@^0.9.1
          98 silly fetch manifest progress@^2.0.0
          99 silly fetch manifest regexpp@^3.1.0
          100 silly fetch manifest strip-json-comments@^3.1.0
          101 silly fetch manifest table@^6.0.9
          102 silly fetch manifest text-table@^0.2.0
          103 silly fetch manifest v8-compile-cache@^2.0.3
          104 silly fetch manifest dns-packet@^5.2.2
          105 silly fetch manifest thunky@^1.0.2
          106 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 325ms (cache hit)
          107 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 328ms (cache hit)
          108 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 332ms (cache hit)
          109 http fetch GET 200 https://registry.npmjs.org/debug 337ms (cache hit)
          110 http fetch GET 200 https://registry.npmjs.org/enquirer 357ms (cache hit)
          111 http fetch GET 200 https://registry.npmjs.org/eslint-scope 362ms (cache hit)
          112 http fetch GET 200 https://registry.npmjs.org/doctrine 368ms (cache hit)
          113 http fetch GET 200 https://registry.npmjs.org/eslint-utils 368ms (cache hit)
          114 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 371ms (cache hit)
          115 http fetch GET 200 https://registry.npmjs.org/espree 374ms (cache hit)
          116 http fetch GET 200 https://registry.npmjs.org/esquery 382ms (cache hit)
          117 http fetch GET 200 https://registry.npmjs.org/esutils 381ms (cache hit)
          118 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 381ms (cache hit)
          119 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 382ms (cache hit)
          120 http fetch GET 200 https://registry.npmjs.org/globals 382ms (cache hit)
          121 http fetch GET 200 https://registry.npmjs.org/ignore 386ms (cache hit)
          122 http fetch GET 200 https://registry.npmjs.org/js-yaml 391ms (cache hit)
          123 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 395ms (cache hit)
          124 http fetch GET 200 https://registry.npmjs.org/lodash.merge 393ms (cache hit)
          125 http fetch GET 200 https://registry.npmjs.org/levn 399ms (cache hit)
          126 http fetch GET 200 https://registry.npmjs.org/natural-compare 395ms (cache hit)
          127 http fetch GET 200 https://registry.npmjs.org/minimatch 402ms (cache hit)
          128 http fetch GET 200 https://registry.npmjs.org/progress 409ms (cache hit)
          129 http fetch GET 200 https://registry.npmjs.org/optionator 417ms (cache hit)
          130 http fetch GET 200 https://registry.npmjs.org/regexpp 417ms (cache hit)
          131 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 417ms (cache hit)
          132 http fetch GET 200 https://registry.npmjs.org/text-table 415ms (cache hit)
          133 http fetch GET 200 https://registry.npmjs.org/table 421ms (cache hit)
          134 http fetch GET 200 https://registry.npmjs.org/thunky 417ms (cache hit)
          135 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 425ms (cache hit)
          136 http fetch GET 200 https://registry.npmjs.org/dns-packet 425ms (cache hit)
          137 timing idealTree:node_modules/esphome-native-api Completed in 534ms
          138 silly placeDep node_modules/eslint @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
          139 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
          140 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
          141 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
          142 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
          143 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
          144 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
          145 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
          146 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
          147 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
          148 silly placeDep ROOT esquery@1.5.0 OK for: eslint@7.32.0 want: ^1.4.0
          149 silly placeDep ROOT esutils@2.0.3 OK for: eslint@7.32.0 want: ^2.0.2
          150 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
          151 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
          152 silly placeDep ROOT globals@13.20.0 OK for: eslint@7.32.0 want: ^13.6.0
          153 silly placeDep node_modules/eslint ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
          154 silly placeDep ROOT js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
          155 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
          156 silly placeDep ROOT levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
          157 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
          158 silly placeDep node_modules/eslint minimatch@3.1.2 OK for: eslint@7.32.0 want: ^3.0.4
          159 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
          160 silly placeDep ROOT optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
          161 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
          162 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
          163 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
          164 silly placeDep ROOT table@6.8.1 OK for: eslint@7.32.0 want: ^6.0.9
          165 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
          166 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
          167 silly fetch manifest debug@^4.1.1
          168 silly fetch manifest strip-json-comments@^3.1.1
          169 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
          170 silly fetch manifest ms@2.1.2
          171 silly fetch manifest ansi-colors@^4.1.1
          172 silly fetch manifest esrecurse@^4.3.0
          173 silly fetch manifest estraverse@^4.1.1
          174 silly fetch manifest eslint-visitor-keys@^1.1.0
          175 silly fetch manifest acorn@^7.4.0
          176 silly fetch manifest acorn-jsx@^5.3.1
          177 silly fetch manifest eslint-visitor-keys@^1.3.0
          178 silly fetch manifest estraverse@^5.1.0
          179 silly fetch manifest flat-cache@^3.0.4
          180 silly fetch manifest type-fest@^0.20.2
          181 silly fetch manifest argparse@^1.0.7
          182 silly fetch manifest esprima@^4.0.0
          183 silly fetch manifest prelude-ls@^1.2.1
          184 silly fetch manifest type-check@~0.4.0
          185 silly fetch manifest brace-expansion@^1.1.7
          186 silly fetch manifest deep-is@^0.1.3
          187 silly fetch manifest word-wrap@^1.2.3
          188 silly fetch manifest type-check@^0.4.0
          189 silly fetch manifest fast-levenshtein@^2.0.6
          190 silly fetch manifest ajv@^8.0.1
          191 silly fetch manifest lodash.truncate@^4.4.2
          192 silly fetch manifest slice-ansi@^4.0.0
          193 http fetch GET 200 https://registry.npmjs.org/esrecurse 315ms (cache hit)
          194 http fetch GET 200 https://registry.npmjs.org/estraverse 315ms (cache hit)
          195 http fetch GET 200 https://registry.npmjs.org/estraverse 308ms (cache hit)
          196 http fetch GET 200 https://registry.npmjs.org/flat-cache 308ms (cache hit)
          197 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 337ms (cache hit)
          198 http fetch GET 200 https://registry.npmjs.org/ms 336ms (cache hit)
          199 http fetch GET 200 https://registry.npmjs.org/acorn 327ms (cache hit)
          200 http fetch GET 200 https://registry.npmjs.org/type-fest 327ms (cache hit)
          201 http fetch GET 200 https://registry.npmjs.org/ansi-colors 358ms (cache hit)
          202 http fetch GET 200 https://registry.npmjs.org/prelude-ls 330ms (cache hit)
          203 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 350ms (cache hit)
          204 http fetch GET 200 https://registry.npmjs.org/esprima 338ms (cache hit)
          205 http fetch GET 200 https://registry.npmjs.org/type-check 336ms (cache hit)
          206 http fetch GET 200 https://registry.npmjs.org/brace-expansion 334ms (cache hit)
          207 http fetch GET 200 https://registry.npmjs.org/word-wrap 332ms (cache hit)
          208 http fetch GET 200 https://registry.npmjs.org/type-check 331ms (cache hit)
          209 http fetch GET 200 https://registry.npmjs.org/argparse 355ms (cache hit)
          210 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 305ms (cache hit)
          211 http fetch GET 200 https://registry.npmjs.org/slice-ansi 307ms (cache hit)
          212 http fetch GET 200 https://registry.npmjs.org/deep-is 351ms (cache hit)
          213 http fetch GET 200 https://registry.npmjs.org/fast-levenshtein 343ms (cache hit)
          214 http fetch GET 200 https://registry.npmjs.org/ajv 351ms (cache hit)
          215 timing idealTree:node_modules/eslint Completed in 668ms
          216 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
          217 silly placeDep node_modules/@eslint/eslintrc ignore@4.0.6 OK for: @eslint/eslintrc@0.4.3 want: ^4.0.6
          218 silly placeDep node_modules/@eslint/eslintrc minimatch@3.1.2 OK for: @eslint/eslintrc@0.4.3 want: ^3.0.4
          219 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
          220 timing idealTree:node_modules/@eslint/eslintrc Completed in 24ms
          221 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
          222 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
          223 silly placeDep node_modules/@humanwhocodes/config-array minimatch@3.1.2 OK for: @humanwhocodes/config-array@0.5.0 want: ^3.0.4
          224 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 18ms
          225 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
          226 timing idealTree:node_modules/doctrine Completed in 0ms
          227 silly placeDep ROOT ansi-colors@4.1.3 OK for: enquirer@2.3.6 want: ^4.1.1
          228 timing idealTree:node_modules/enquirer Completed in 6ms
          229 timing idealTree:node_modules/ansi-colors Completed in 0ms
          230 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
          231 silly placeDep ROOT estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
          232 silly fetch manifest estraverse@^5.2.0
          233 timing idealTree:node_modules/eslint-scope Completed in 15ms
          234 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
          235 timing idealTree:node_modules/eslint-utils Completed in 4ms
          236 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
          237 silly placeDep ROOT acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
          238 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
          239 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
          240 timing idealTree:node_modules/espree Completed in 26ms
          241 timing idealTree:node_modules/acorn Completed in 0ms
          242 timing idealTree:node_modules/acorn-jsx Completed in 0ms
          243 silly placeDep node_modules/esquery estraverse@5.3.0 OK for: esquery@1.5.0 want: ^5.1.0
          244 timing idealTree:node_modules/esquery Completed in 6ms
          245 silly placeDep node_modules/esrecurse estraverse@5.3.0 OK for: esrecurse@4.3.0 want: ^5.2.0
          246 timing idealTree:node_modules/esrecurse Completed in 4ms
          247 timing idealTree:node_modules/estraverse Completed in 0ms
          248 timing idealTree:node_modules/esutils Completed in 1ms
          249 timing idealTree:node_modules/events Completed in 0ms
          250 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
          251 silly fetch manifest flatted@^3.1.0
          252 http fetch GET 200 https://registry.npmjs.org/flatted 18ms (cache hit)
          253 timing idealTree:node_modules/file-entry-cache Completed in 31ms
          254 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
          255 timing idealTree:node_modules/flat-cache Completed in 7ms
          256 timing idealTree:node_modules/flatted Completed in 0ms
          257 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
          258 silly placeDep node_modules/globals type-fest@0.20.2 OK for: globals@13.20.0 want: ^0.20.2
          259 timing idealTree:node_modules/globals Completed in 5ms
          260 timing idealTree:node_modules/google-protobuf Completed in 0ms
          261 silly placeDep ROOT argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
          262 silly placeDep ROOT esprima@4.0.1 OK for: js-yaml@3.14.1 want: ^4.0.0
          263 silly fetch manifest sprintf-js@~1.0.2
          264 http fetch GET 200 https://registry.npmjs.org/sprintf-js 20ms (cache hit)
          265 timing idealTree:node_modules/js-yaml Completed in 38ms
          266 silly placeDep node_modules/argparse sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
          267 timing idealTree:node_modules/argparse Completed in 4ms
          268 timing idealTree:node_modules/esprima Completed in 0ms
          269 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
          270 silly placeDep ROOT prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
          271 silly placeDep ROOT type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
          272 timing idealTree:node_modules/levn Completed in 13ms
          273 timing idealTree:node_modules/lodash.merge Completed in 0ms
          274 silly placeDep node_modules/multicast-dns dns-packet@5.6.0 OK for: multicast-dns@7.2.5 want: ^5.2.2
          275 silly placeDep ROOT thunky@1.1.0 OK for: multicast-dns@7.2.5 want: ^1.0.2
          276 silly fetch manifest @leichtgewicht/ip-codec@^2.0.1
          277 http fetch GET 200 https://registry.npmjs.org/@leichtgewicht%2fip-codec 18ms (cache hit)
          278 timing idealTree:node_modules/multicast-dns Completed in 34ms
          279 timing idealTree:node_modules/natural-compare Completed in 0ms
          280 timing idealTree:node_modules/net Completed in 0ms
          281 silly placeDep ROOT deep-is@0.1.4 OK for: optionator@0.9.1 want: ^0.1.3
          282 silly placeDep ROOT fast-levenshtein@2.0.6 OK for: optionator@0.9.1 want: ^2.0.6
          283 silly placeDep ROOT word-wrap@1.2.3 OK for: optionator@0.9.1 want: ^1.2.3
          284 timing idealTree:node_modules/optionator Completed in 19ms
          285 timing idealTree:node_modules/deep-is Completed in 0ms
          286 timing idealTree:node_modules/fast-levenshtein Completed in 1ms
          287 timing idealTree:node_modules/prelude-ls Completed in 0ms
          288 timing idealTree:node_modules/progress Completed in 0ms
          289 timing idealTree:node_modules/regexpp Completed in 0ms
          290 silly placeDep node_modules/table ajv@8.12.0 OK for: table@6.8.1 want: ^8.0.1
          291 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.1 want: ^4.4.2
          292 silly placeDep node_modules/table slice-ansi@4.0.0 OK for: table@6.8.1 want: ^4.0.0
          293 silly fetch manifest json-schema-traverse@^1.0.0
          294 silly fetch manifest require-from-string@^2.0.2
          295 silly fetch manifest astral-regex@^2.0.0
          296 http fetch GET 200 https://registry.npmjs.org/require-from-string 48ms (cache hit)
          297 http fetch GET 200 https://registry.npmjs.org/astral-regex 47ms (cache hit)
          298 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 54ms (cache hit)
          299 timing idealTree:node_modules/table Completed in 78ms
          300 timing idealTree:node_modules/lodash.truncate Completed in 0ms
          301 timing idealTree:node_modules/text-table Completed in 0ms
          302 timing idealTree:node_modules/thunky Completed in 0ms
          303 timing idealTree:node_modules/tree-kill Completed in 1ms
          304 timing idealTree:node_modules/type-check Completed in 0ms
          305 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
          306 timing idealTree:node_modules/word-wrap Completed in 0ms
          307 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
          308 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 6ms
          309 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 0ms
          310 silly placeDep node_modules/@eslint/eslintrc brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
          311 timing idealTree:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 5ms
          312 timing idealTree:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 0ms
          313 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
          314 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
          315 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
          316 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 4ms
          317 silly placeDep node_modules/@humanwhocodes/config-array brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
          318 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 6ms
          319 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1ms
          320 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
          321 timing idealTree:node_modules/argparse/node_modules/sprintf-js Completed in 0ms
          322 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 0ms
          323 timing idealTree:node_modules/eslint/node_modules/@babel/code-frame Completed in 0ms
          324 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
          325 timing idealTree:node_modules/eslint/node_modules/debug Completed in 5ms
          326 timing idealTree:node_modules/eslint/node_modules/ignore Completed in 0ms
          327 silly placeDep node_modules/eslint brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
          328 timing idealTree:node_modules/eslint/node_modules/minimatch Completed in 6ms
          329 timing idealTree:node_modules/eslint/node_modules/brace-expansion Completed in 0ms
          330 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
          331 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
          332 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
          333 timing idealTree:node_modules/esquery/node_modules/estraverse Completed in 0ms
          334 timing idealTree:node_modules/esrecurse/node_modules/estraverse Completed in 0ms
          335 timing idealTree:node_modules/globals/node_modules/type-fest Completed in 1ms
          336 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
          337 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
          338 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
          339 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
          340 silly fetch manifest @sentry/minimal@5.30.0
          341 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 32ms (cache hit)
          342 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 79ms
          343 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
          344 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 6ms
          345 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
          346 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
          347 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
          348 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
          349 silly placeDep ROOT @leichtgewicht/ip-codec@2.0.4 OK for: dns-packet@5.6.0 want: ^2.0.1
          350 timing idealTree:node_modules/multicast-dns/node_modules/dns-packet Completed in 8ms
          351 timing idealTree:node_modules/@leichtgewicht/ip-codec Completed in 0ms
          352 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
          353 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.12.0 want: ^2.0.2
          354 timing idealTree:node_modules/table/node_modules/ajv Completed in 12ms
          355 timing idealTree:node_modules/require-from-string Completed in 0ms
          356 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
          357 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
          358 timing idealTree:node_modules/table/node_modules/slice-ansi Completed in 7ms
          359 timing idealTree:node_modules/astral-regex Completed in 0ms
          360 timing idealTree:buildDeps Completed in 6642ms
          361 timing idealTree:fixDepFlags Completed in 30ms
          362 timing idealTree Completed in 10857ms
          363 timing reify:loadTrees Completed in 10861ms
          364 timing reify:diffTrees Completed in 104ms
          365 silly reify mark retired [ '/opt/iobroker/node_modules/fsevents' ]
          366 silly reify mark retired [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
          367 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.vis' ]
          368 silly reify moves {
          368 silly reify   '/opt/iobroker/node_modules/fsevents': '/opt/iobroker/node_modules/.fsevents-yNYMVUiI',
          368 silly reify   '/opt/iobroker/node_modules/osx-temperature-sensor': '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv',
          368 silly reify   '/opt/iobroker/node_modules/iobroker.vis': '/opt/iobroker/node_modules/.iobroker.vis-A3mwBQZP'
          368 silly reify }
          369 timing reify:retireShallow Completed in 16ms
          370 timing reify:createSparse Completed in 41ms
          371 timing reify:loadBundles Completed in 0ms
          372 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
          373 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
          374 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
          375 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
          376 timing reifyNode:node_modules/osx-temperature-sensor Completed in 56ms
          377 timing reifyNode:node_modules/fsevents Completed in 57ms
          378 timing reifyNode:node_modules/natural-compare Completed in 1469ms
          379 timing reifyNode:node_modules/require-from-string Completed in 1511ms
          380 timing reifyNode:node_modules/fast-levenshtein Completed in 1513ms
          381 timing reifyNode:node_modules/table/node_modules/slice-ansi Completed in 1538ms
          382 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1540ms
          383 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 1540ms
          384 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1541ms
          385 timing reifyNode:node_modules/eslint/node_modules/brace-expansion Completed in 1540ms
          386 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1541ms
          387 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1545ms
          388 timing reifyNode:node_modules/astral-regex Completed in 1562ms
          389 timing reifyNode:node_modules/word-wrap Completed in 1561ms
          390 timing reifyNode:node_modules/lodash.truncate Completed in 1562ms
          391 timing reifyNode:node_modules/net Completed in 1576ms
          392 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1589ms
          393 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1592ms
          394 timing reifyNode:node_modules/eslint/node_modules/@babel/code-frame Completed in 1592ms
          395 timing reifyNode:node_modules/esrecurse Completed in 1628ms
          396 timing reifyNode:node_modules/tree-kill Completed in 1644ms
          397 timing reifyNode:node_modules/thunky Completed in 1674ms
          398 timing reifyNode:node_modules/v8-compile-cache Completed in 1687ms
          399 timing reifyNode:node_modules/file-entry-cache Completed in 1688ms
          400 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1698ms
          401 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 1716ms
          402 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 1716ms
          403 timing reifyNode:node_modules/eslint/node_modules/minimatch Completed in 1715ms
          404 timing reifyNode:node_modules/type-check Completed in 1738ms
          405 timing reifyNode:node_modules/acorn-jsx Completed in 1742ms
          406 timing reifyNode:node_modules/lodash.merge Completed in 1746ms
          407 timing reifyNode:node_modules/@leichtgewicht/ip-codec Completed in 1778ms
          408 timing reifyNode:node_modules/ansi-colors Completed in 1779ms
          409 timing reifyNode:node_modules/progress Completed in 1781ms
          410 timing reifyNode:node_modules/levn Completed in 1782ms
          411 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1784ms
          412 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1795ms
          413 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1796ms
          414 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1793ms
          415 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1793ms
          416 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1796ms
          417 timing reifyNode:node_modules/estraverse Completed in 1810ms
          418 timing reifyNode:node_modules/globals Completed in 1810ms
          419 timing reifyNode:node_modules/esrecurse/node_modules/estraverse Completed in 1821ms
          420 timing reifyNode:node_modules/esquery/node_modules/estraverse Completed in 1818ms
          421 timing reifyNode:node_modules/deep-is Completed in 1827ms
          422 timing reifyNode:node_modules/flat-cache Completed in 1828ms
          423 timing reifyNode:node_modules/optionator Completed in 1829ms
          424 timing reifyNode:node_modules/functional-red-black-tree Completed in 1830ms
          425 timing reifyNode:node_modules/multicast-dns Completed in 1832ms
          426 timing reifyNode:node_modules/eslint/node_modules/ignore Completed in 1835ms
          427 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 1838ms
          428 timing reifyNode:node_modules/esutils Completed in 1879ms
          429 timing reifyNode:node_modules/multicast-dns/node_modules/dns-packet Completed in 1885ms
          430 timing reifyNode:node_modules/prelude-ls Completed in 1896ms
          431 timing reifyNode:node_modules/text-table Completed in 1939ms
          432 timing reifyNode:node_modules/espree Completed in 1938ms
          433 timing reifyNode:node_modules/doctrine Completed in 1939ms
          434 timing reifyNode:node_modules/flatted Completed in 1950ms
          435 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 1953ms
          436 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 1967ms
          437 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 1977ms
          438 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 2000ms
          439 timing reifyNode:node_modules/eslint-scope Completed in 2019ms
          440 timing reifyNode:node_modules/argparse/node_modules/sprintf-js Completed in 2039ms
          441 timing reifyNode:node_modules/regexpp Completed in 2053ms
          442 timing reifyNode:node_modules/esprima Completed in 2076ms
          443 timing reifyNode:node_modules/eslint-utils Completed in 2084ms
          444 timing reifyNode:node_modules/events Completed in 2277ms
          445 timing reifyNode:node_modules/argparse Completed in 2319ms
          446 timing reifyNode:node_modules/@eslint/eslintrc Completed in 2330ms
          447 timing reifyNode:node_modules/iobroker.esphome Completed in 2359ms
          448 timing reifyNode:node_modules/globals/node_modules/type-fest Completed in 2398ms
          449 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 2525ms
          450 timing reifyNode:node_modules/esphome-native-api Completed in 2527ms
          451 timing reifyNode:node_modules/enquirer Completed in 2544ms
          452 timing reifyNode:node_modules/google-protobuf Completed in 2602ms
          453 timing reifyNode:node_modules/js-yaml Completed in 2616ms
          454 timing reifyNode:node_modules/esquery Completed in 2617ms
          455 timing reifyNode:node_modules/acorn Completed in 2683ms
          456 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2893ms
          457 timing reifyNode:node_modules/table Completed in 3019ms
          458 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 3240ms
          459 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 3279ms
          460 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 3411ms
          461 timing reifyNode:node_modules/table/node_modules/ajv Completed in 4089ms
          462 timing reifyNode:node_modules/eslint Completed in 4128ms
          463 timing reify:unpack Completed in 4140ms
          464 timing reify:unretire Completed in 1ms
          465 timing build:queue Completed in 18ms
          466 timing build:link:node_modules/eslint Completed in 5ms
          467 timing build:link:node_modules/acorn Completed in 9ms
          468 timing build:link:node_modules/esprima Completed in 5ms
          469 timing build:link:node_modules/js-yaml Completed in 5ms
          470 timing build:link:node_modules/multicast-dns Completed in 5ms
          471 timing build:link:node_modules/tree-kill Completed in 4ms
          472 timing build:link Completed in 10ms
          473 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
          474 info run iobroker.esphome@0.2.4 install { code: 1, signal: null }
          475 timing reify:rollback:createSparse Completed in 487ms
          476 timing reify:rollback:retireShallow Completed in 2ms
          477 timing command:install Completed in 107556ms
          478 verbose stack Error: command failed
          478 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
          478 verbose stack     at ChildProcess.emit (node:events:513:28)
          478 verbose stack     at maybeClose (node:internal/child_process:1091:16)
          478 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
          478 verbose stack     at Socket.emit (node:events:513:28)
          478 verbose stack     at Pipe.<anonymous> (node:net:322:12)
          479 verbose pkgid iobroker.esphome@0.2.4
          480 verbose cwd /opt/iobroker
          481 verbose Linux 6.1.21-v8+
          482 verbose node v18.16.0
          483 verbose npm  v9.5.1
          484 error code 1
          485 error path /opt/iobroker/node_modules/iobroker.esphome
          486 error command failed
          487 error command sh -c npip install
          488 error No python_modules directory; installing pip locally if needed.
          488 error Successfully completed pip check.
          488 error Collecting esphome>=2021.8
          488 error   Using cached esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
          488 error Collecting tornado>=3.2
          488 error   Using cached tornado-6.3.1.tar.gz (508 kB)
          488 error   Installing build dependencies: started
          488 error   Installing build dependencies: finished with status 'done'
          488 error   Getting requirements to build wheel: started
          488 error   Getting requirements to build wheel: finished with status 'done'
          488 error   Preparing metadata (pyproject.toml): started
          488 error   Preparing metadata (pyproject.toml): finished with status 'done'
          488 error Collecting voluptuous==0.13.1 (from esphome>=2021.8)
          488 error   Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
          488 error Collecting PyYAML==6.0 (from esphome>=2021.8)
          488 error   Using cached PyYAML-6.0.tar.gz (124 kB)
          488 error Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
          488 error   Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
          488 error   Preparing metadata (setup.py): started
          488 error   Preparing metadata (setup.py): finished with status 'done'
          488 error Collecting colorama==0.4.6 (from esphome>=2021.8)
          488 error   Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
          488 error   Using cached tornado-6.2.tar.gz (504 kB)
          488 error Collecting tzlocal==4.2 (from esphome>=2021.8)
          488 error   Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
          488 error Collecting tzdata>=2021.1 (from esphome>=2021.8)
          488 error   Using cached tzdata-2023.3-py2.py3-none-any.whl (341 kB)
          488 error Collecting pyserial==3.5 (from esphome>=2021.8)
          488 error   Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
          488 error Collecting platformio==6.1.6 (from esphome>=2021.8)
          488 error   Using cached platformio-6.1.6.tar.gz (236 kB)
          488 error Collecting esptool==4.5.1 (from esphome>=2021.8)
          488 error   Using cached esptool-4.5.1.tar.gz (252 kB)
          488 error Collecting click==8.1.3 (from esphome>=2021.8)
          488 error   Using cached click-8.1.3-py3-none-any.whl (96 kB)
          488 error Collecting esphome-dashboard==20230214.0 (from esphome>=2021.8)
          488 error   Using cached esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
          488 error Collecting aioesphomeapi==13.5.1 (from esphome>=2021.8)
          488 error   Using cached aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
          488 error Collecting zeroconf==0.56.0 (from esphome>=2021.8)
          488 error   Using cached zeroconf-0.56.0.tar.gz (140 kB)
          488 error Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
          488 error   Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
          488 error Collecting protobuf>=3.19.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
          488 error   Using cached protobuf-4.22.3-py3-none-any.whl (172 kB)
          488 error Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.5.1->esphome>=2021.8)
          488 error   Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
          488 error Collecting async-timeout>=4.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
          488 error   Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
          488 error Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
          488 error   Using cached bitstring-4.0.2-py3-none-any.whl (46 kB)
          488 error Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
          488 error   Using cached cryptography-40.0.2.tar.gz (625 kB)
          488 error   Installing build dependencies: finished with status 'error'
          489 error /usr/bin/python3: No module named pip
          489 error /usr/bin/python3: No module named ensurepip
          489 error ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/wheel-0.40.0.dist-info/INSTALLER4efqrkmn.tmp'
          489 error
          489 error   error: subprocess-exited-with-error
          489 error
          489 error   × pip subprocess to install build dependencies did not run successfully.
          489 error   │ exit code: 1
          489 error   ╰─> [81 lines of output]
          489 error       Collecting setuptools!=60.9.0,>=40.6.0
          489 error         Using cached setuptools-67.7.2-py3-none-any.whl (1.1 MB)
          489 error       Collecting wheel
          489 error         Using cached wheel-0.40.0-py3-none-any.whl (64 kB)
          489 error       Collecting cffi>=1.12
          489 error         Using cached cffi-1.15.1.tar.gz (508 kB)
          489 error         Preparing metadata (setup.py): started
          489 error         Preparing metadata (setup.py): finished with status 'done'
          489 error       Collecting setuptools-rust>=0.11.4
          489 error         Using cached setuptools_rust-1.5.2-py3-none-any.whl (23 kB)
          489 error       Collecting pycparser (from cffi>=1.12)
          489 error         Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
          489 error       Collecting semantic-version<3,>=2.8.2 (from setuptools-rust>=0.11.4)
          489 error         Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
          489 error       Collecting typing-extensions>=3.7.4.3 (from setuptools-rust>=0.11.4)
          489 error         Using cached typing_extensions-4.5.0-py3-none-any.whl (27 kB)
          489 error       Building wheels for collected packages: cffi
          489 error         Building wheel for cffi (setup.py): started
          489 error         Building wheel for cffi (setup.py): finished with status 'error'
          489 error
          489 error         × python setup.py bdist_wheel did not run successfully.
          489 error         ╰─> [50 lines of output]
          489 error             /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/config/setupcfg.py:293: _DeprecatedConfig: Deprecated config in `setup.cfg`
          489 error             !!
          489 error
          489 error                     ********************************************************************************
          489 error                     The license_file parameter is deprecated, use license_files instead.
          489 error
          489 error                     By 2023-Oct-30, you need to update your project and remove deprecated calls
          489 error                     or your builds will no longer be supported.
          489 error
          489 error                     See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
          489 error
          489 error             !!
          489 error               parsed = self.parsers.get(option_name, lambda x: x)(value)
          489 error             running bdist_wheel
          489 error             running build
          489 error             running build_py
          489 error             creating build
          489 error             creating build/lib.linux-aarch64-cpython-39
          489 error             creating build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/lock.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/cparser.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/verifier.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/vengine_gen.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/error.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/__init__.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/model.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/pkgconfig.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/recompiler.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/api.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/ffiplatform.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/commontypes.py -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/_cffi_include.h -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/parse_c_type.h -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/_embedding.h -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-cpython-39/cffi
          489 error             running build_ext
          489 error             building '_cffi_backend' extension
          489 error             creating build/temp.linux-aarch64-cpython-39
          489 error             creating build/temp.linux-aarch64-cpython-39/c
          489 error             arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-aarch64-cpython-39/c/_cffi_backend.o
          489 error             c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
          489 error                 2 | #include <Python.h>
          489 error                   |          ^~~~~~~~~~
          489 error             compilation terminated.
          489 error             error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
          489 error             [end of output]
          489 error
          489 error         note: This error originates from a subprocess, and is likely not a problem with pip.
          489 error         ERROR: Failed building wheel for cffi
          489 error         Running setup.py clean for cffi
          489 error       Failed to build cffi
          489 error       ERROR: Could not build wheels for cffi, which is required to install pyproject.toml-based projects
          489 error
          489 error
          489 error ╰─> See above for output.
          489 error
          490 verbose exit 1
          491 timing npm Completed in 107807ms
          492 verbose unfinished npm timer reify 1682367601160
          493 verbose unfinished npm timer reify:build 1682367616344
          494 verbose unfinished npm timer build 1682367616349
          495 verbose unfinished npm timer build:deps 1682367616350
          496 verbose unfinished npm timer build:run:install 1682367616381
          497 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1682367616382
          498 verbose code 1
          499 error A complete log of this run can be found in:
          499 error     /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
          • M mayokleckz
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@9.5.1
            2 info using node@v18.16.0
            8 timing config:load:env Completed in 1ms
            12 timing config:load:user Completed in 1ms
            14 timing config:load:global Completed in 1ms
            18 timing npm:load:mkdirpcache Completed in 1ms
            19 timing npm:load:mkdirplogs Completed in 1ms
            20 verbose title npm install iobroker.esphome@0.2.4
            21 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
            22 timing npm:load:setTitle Completed in 5ms
            28 timing npm:load:timers Completed in 0ms
            29 timing npm:load:configScope Completed in 0ms
            31 timing arborist:ctor Completed in 3ms
            32 silly logfile start cleaning logs, removing 2 files
            33 silly logfile done cleaning log files
            36 silly idealTree buildDeps
            37 silly fetch manifest iobroker.esphome@0.2.4
            38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
            40 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
            41 silly fetch manifest @sentry/node@^5.30.0
            42 silly fetch manifest esphome-native-api@^1.0.9
            368 silly reify }
            484 error code 1
            489 error
            489 error
            489 error
            489 error             !!
            489 error
            489 error
            489 error
            489 error
            489 error             !!
            489 error
            489 error
            489 error
            489 error
            490 verbose exit 1
            498 verbose code 1
            @mayokleckz
            apt policy python3-full python3-pip
              @mayokleckz
              mayokleckz
              flo@raspberrypi:~ $ apt policy python3-full python3-pip
              python3-full:
                Installed: (none)
                Candidate: 3.9.2-3
                Version table:
                   3.9.2-3 500
              python3-pip:
                Installed: 20.3.4-4+rpt1+deb11u1
                Candidate: 20.3.4-4+rpt1+deb11u1
                Version table:
               *** 20.3.4-4+rpt1+deb11u1 500
                      500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                   20.3.4-4+deb11u1 500
              flo@raspberrypi:~ $
              • M mayokleckz
                python3-full:
                  Installed: (none)
                  Candidate: 3.9.2-3
                  Version table:
                     3.9.2-3 500
                python3-pip:
                  Version table:
                flo@raspberrypi:~ $
                @mayokleckz sagte in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
                python3-full
                Installier das mal nach.
                sudo apt install python3-full python3.9-dev libpython3.9-dev
                  python3-full
                  mayokleckz
                  Die Installation funktioniert nun.
                  Es war also
                  cd /opt/iobroker
                  npm i nopy
                  und
                  notwendig.
                  Danke.
                  Beim Kompilieren komme ich in einen neuen Fehler. Nach erstem suchen ein 32-bit<>64-bit os Problem?!
                  INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-7a8069.yaml...
                  INFO Generating C++ source...
                  INFO Compiling app...
                  Processing esphome--brunnen-web-7a8069 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                  HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
                  Dependency Graph
                  |-- ESPAsyncTCP-esphome @ 1.2.3
                  |-- ESPAsyncWebServer-esphome @ 2.1.0
                  |   |-- Hash @ 1.0
                  |   |-- ESP8266WiFi @ 1.0
                  |-- DNSServer @ 1.1.1
                  |-- ESP8266mDNS @ 1.2
                  |-- noise-c @ 0.1.4
                  |   |-- libsodium @ 1.10018.1
                  Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o
                  sh: 1: xtensa-lx106-elf-g++: not found
                  Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o
                  Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o
                  *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o] Error 127
                  Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o
                  *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
                  *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o] Error 127
                  *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
                  ========================== [FAILED] Took 2.55 seconds ==========================
                  Der erste Lösungsversuch schlug schonmal fehl.
                  flo@raspberrypi:~ $ sudo apt-get install xtensa-lx106-elf
                  Reading package lists... Done
                  E: Unable to locate package xtensa-lx106-elf
                  flo@raspberrypi:~ $
                  • M mayokleckz
                    Es war also
                    cd /opt/iobroker
                    npm i nopy
                    und
                    notwendig.
                    Danke.
                    Dependency Graph
                    |   |-- Hash @ 1.0
                    |-- noise-c @ 0.1.4
                    flo@raspberrypi:~ $
                    Versuch es mit
                    sudo apt install gcc-xtensa-lx106
                      Versuch es mit
                      mayokleckz
                      Das ging durch.
                      Ich stolper trotzdem nur ahnungslos von Fehler zu Fehler.
                      INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp-home-brunnen.yaml...
                      Processing esphome-brunnen (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                      HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
                      Dependency Graph
                      |   |-- Hash @ 1.0
                      Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o
                      Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o
                      xtensa-lx106-elf-g++: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
                      Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o
                      *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o] Error 1
                      *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
                      *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o] Error 1
                      Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o
                      *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
                      ========================== [FAILED] Took 2.38 seconds ==========================
                      • M mayokleckz
                        Das ging durch.
                        Dependency Graph
                        |   |-- Hash @ 1.0
                        @mayokleckz
                        Da fehlt dir der Cross Compiler
                        https://packages.debian.org/search?searchon=contents&keywords=cc1plus&mode=exactfilename&suite=stable&arch=any
                        Musst Mal schauen welcher gcc und welche Architektur da bei dir am Start ist. Danach richtet sich das zu installierende Paket.
                        uname -m
                        gcc --version
                        sagt dir Näheres.
                        Edit:
                        Ich sehe gerade, das sollte eigentlich auch im Paket gcc-xtensa-lx106 drin sein. Dann weiß ich nicht was dem System noch fehlt.
                          @mayokleckz
                          uname -m
                          gcc --version
                          sagt dir Näheres.
                          Edit:
                          mayokleckz
                          ok schade. trotzdem danke.
                          Evtl. ließt hier noch jemand drüber und weiß weiter Rat.
                          Ich hab mal nachgeschaut, also vorhanden scheint es zu sein.
                          flo@raspberrypi:~ $ find /usr/ -name "*cc1*"
                          /usr/share/terminfo/x/xterm+pcc1
                          /usr/share/doc/libcc1-0
                          /usr/lib/debug/.build-id/97/fca3e5a4e23a7a9dc3429293fe5f810dcc1cd6.debug
                          /usr/lib/debug/.build-id/ac/24d09573ac4b8d5987190d274d9128cc1aeb38.debug
                          find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
                          /usr/lib/arm-linux-gnueabihf/libcc1.so.0.0.0
                          /usr/lib/gcc/arm-linux-gnueabihf/10/cc1
                          /usr/lib/gcc/arm-linux-gnueabihf/10/cc1plus
                          /usr/lib/gcc/arm-linux-gnueabihf/10/libcc1.so
                          /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so
                          /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so.0.0.0
                          /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1
                          /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus
                          /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so
                          /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so.0.0.0
                          /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.la
                          flo@raspberrypi:~ $ find /usr/ -name "*execvp*"
                          /usr/share/man/man3/execvpe.3.gz
                          /usr/share/man/man3/execvp.3.gz
                          flo@raspberrypi:~ $ ^C
                          da eine Rechtevergabe schon mal geklappt hat, hab ich mal verzweifelt chmod versucht.
                          flo@raspberrypi:~ $ sudo -u iobroker chmod a+x /usr/lib/gcc/xtensa-lx106-elf/10.2.1/c*
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/collect2': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtbegin.o': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtend.o': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crti.o': Operation not permitted
                          chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtn.o': Operation not permitted
                          flo@raspberrypi:~ $
                          Dann noch in die Umgebungsvariable
                          flo@raspberrypi:~ $ export PATH=$PATH:/usr/lib/gcc/xtensa-lx106-elf/10.2.1
                          flo@raspberrypi:~ $ $PATH
                          -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin/g++::/usr/lib/gcc/xtensa-lx106-elf/10.2.1:
                          flo@raspberrypi:~ $
                          Den Adapter auch noch mal neu installiert. Kompiliert einfach nicht.
                          Hänge also weiter bei
                          @mayokleckz said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
                          Das ging durch.
                          Dependency Graph
                          |   |-- Hash @ 1.0
                          • M mayokleckz
                            flo@raspberrypi:~ $
                            flo@raspberrypi:~ $
                            Das ging durch.
                            Dependency Graph
                            |   |-- Hash @ 1.0
                            Schlachte dich da nicht so durch das Rechtegefüge. Das die Rechte bei per Paketmanager installierten Softwarepaketen nicht stimmen kommt nur extrem selten vor, ich würde behaupten nie. Eher fehlen da Gruppenzugehörigkeiten für die User.
                            Gibt es da wo der Code herkommt keine Hinweise was für eine build chain benötigt wird?
                            Edith: Gerade noch was herumgeschaut. Hab ähnliche Probleme gefunden, wenn ältere Versionen von esphome verwendet wurden.
                            echad@chet:~ $ esphome version
                            Version: 2023.4.1
                            echad@chet:~ $
                            Was spuckt das bei dir aus?
                              Version: 2023.4.1
                              echad@chet:~ $
                              mayokleckz
                              schrieb am zuletzt editiert von mayokleckz
                              flo@raspberrypi:~ $ esphome version
                              -bash: esphome: command not found
                              flo@raspberrypi:~ $
                              Welchen Code meinst du? Falls der YAML Code zum kompilieren gemeint ist, das ist die initiale yaml Datei, die vom ESPHome Adapter beim hinzufügen eines Geräts automatisch erzeugt wird.
                              esphome:
                              esp8266:
                                board: d1_mini
                              # Enable logging
                              logger:
                              # Enable Home Assistant API
                              api:
                                  password: 'MyPassword'
                              ota:
                                password: "d960f666ab261cb6fbcd4e21b4cd9a59"
                              wifi:
                                ssid: !secret wifi_ssid
                                password: !secret wifi_password
                                # Enable fallback hotspot (captive portal) in case wifi connection fails
                                ap:
                                  ssid: "Esphome-Brunnen Fallback Hotspot"
                                  password: "15dOCTm1PxgU"
                              captive_portal:
                              • M mayokleckz
                                flo@raspberrypi:~ $
                                esphome:
                                esp8266:
                                  board: d1_mini
                                # Enable logging
                                logger:
                                api:
                                ota:
                                wifi:
                                  ap:
                                captive_portal:
                                @mayokleckz
                                Keine Ahnung, hab mit esphome eigentlich nix am Hut.
                                  @mayokleckz
                                  mayokleckz
                                  Das esphome version keine Antwort gab, hab ich folgendes versucht. Brachte aber auch keine Änderung am Ergebnis. Und im falschen Verzeichnis hab ichs wohl auch noch installiert.
                                  flo@raspberrypi:~ $ pip3 install esphome
                                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                  Collecting esphome
                                    Downloading https://www.piwheels.org/simple/esphome/esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                                       |████████████████████████████████| 2.6 MB 1.2 MB/s
                                    Downloading https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                                       |████████████████████████████████| 341 kB 7.1 MB/s
                                    Downloading https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                                    Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-4.2-py3-none-any.whl (19 kB)
                                    Downloading https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp39-cp39-linux_armv7l.whl (45 kB)
                                       |████████████████████████████████| 45 kB 1.5 MB/s
                                    Downloading https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                                       |████████████████████████████████| 145 kB 1.2 MB/s
                                    Downloading https://www.piwheels.org/simple/platformio/platformio-6.1.6-py3-none-any.whl (416 kB)
                                       |████████████████████████████████| 416 kB 6.9 MB/s
                                    Downloading https://www.piwheels.org/simple/esptool/esptool-4.5.1-py3-none-any.whl (320 kB)
                                       |████████████████████████████████| 320 kB 3.8 MB/s
                                  Collecting tornado==6.2
                                    Downloading https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                                       |████████████████████████████████| 422 kB 2.9 MB/s
                                    Downloading https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                                       |████████████████████████████████| 90 kB 2.9 MB/s
                                    Downloading https://www.piwheels.org/simple/zeroconf/zeroconf-0.56.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.1 MB)
                                       |████████████████████████████████| 2.1 MB 1.2 MB/s
                                    Downloading https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
                                    Downloading https://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
                                       |████████████████████████████████| 96 kB 1.6 MB/s
                                    Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
                                       |████████████████████████████████| 1.6 MB 6.8 MB/s
                                    Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                                       |████████████████████████████████| 75 kB 1.6 MB/s
                                    Downloading https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
                                       |████████████████████████████████| 54 kB 802 kB/s
                                    Downloading https://www.piwheels.org/simple/protobuf/protobuf-4.22.3-cp39-cp39-linux_armv7l.whl (924 kB)
                                       |████████████████████████████████| 924 kB 1.2 MB/s
                                    Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                                    Downloading https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                                    Downloading https://www.piwheels.org/simple/cryptography/cryptography-40.0.2-cp39-cp39-linux_armv7l.whl (1.5 MB)
                                       |████████████████████████████████| 1.5 MB 1.2 MB/s
                                  Collecting reedsolo<=1.6.0,>=1.5.3
                                    Downloading https://www.piwheels.org/simple/reedsolo/reedsolo-1.6.0-cp39-cp39-linux_armv7l.whl (897 kB)
                                       |████████████████████████████████| 897 kB 6.9 MB/s
                                  Collecting ecdsa>=0.16.0
                                    Downloading https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                                       |████████████████████████████████| 142 kB 7.0 MB/s
                                    Downloading https://www.piwheels.org/simple/bitstring/bitstring-4.0.2-py3-none-any.whl (46 kB)
                                       |████████████████████████████████| 46 kB 1.6 MB/s
                                  Collecting semantic-version==2.10.*
                                    Downloading https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
                                  Collecting tabulate==0.9.*
                                    Downloading https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
                                  Collecting starlette==0.23.*
                                    Downloading https://www.piwheels.org/simple/starlette/starlette-0.23.1-py3-none-any.whl (64 kB)
                                       |████████████████████████████████| 64 kB 1.4 MB/s
                                  Collecting pyelftools<1,>=0.27
                                    Downloading https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                                       |████████████████████████████████| 174 kB 6.9 MB/s
                                  Collecting ajsonrpc==1.*
                                    Downloading https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                                  Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.6->esphome) (2.25.1)
                                  Collecting aiofiles==22.1.*
                                    Downloading https://www.piwheels.org/simple/aiofiles/aiofiles-22.1.0-py3-none-any.whl (14 kB)
                                  Collecting wsproto==1.2.*
                                    Downloading https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
                                  Collecting bottle==0.12.*
                                    Downloading https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                                       |████████████████████████████████| 90 kB 2.8 MB/s
                                  Collecting marshmallow==3.*
                                    Downloading marshmallow-3.19.0-py3-none-any.whl (49 kB)
                                       |████████████████████████████████| 49 kB 1.6 MB/s
                                  Collecting uvicorn==0.20.*
                                    Downloading https://www.piwheels.org/simple/uvicorn/uvicorn-0.20.0-py3-none-any.whl (56 kB)
                                       |████████████████████████████████| 56 kB 787 kB/s
                                  Collecting packaging>=17.0
                                    Downloading https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                                       |████████████████████████████████| 48 kB 992 kB/s
                                  Collecting typing-extensions>=3.10.0
                                    Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.5.0-py3-none-any.whl (27 kB)
                                  Collecting anyio<5,>=3.4.0
                                    Downloading https://www.piwheels.org/simple/anyio/anyio-3.6.2-py3-none-any.whl (80 kB)
                                       |████████████████████████████████| 80 kB 937 kB/s
                                  Collecting pytz-deprecation-shim
                                    Downloading https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                                  Collecting h11>=0.8
                                    Downloading https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                                       |████████████████████████████████| 58 kB 2.0 MB/s
                                  Collecting ifaddr>=0.1.7
                                    Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                                  Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.23.*->platformio==6.1.6->esphome) (2.10)
                                  Collecting sniffio>=1.1
                                    Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                                    Downloading https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
                                       |████████████████████████████████| 364 kB 1.2 MB/s
                                    Downloading https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                                       |████████████████████████████████| 119 kB 6.9 MB/s
                                  Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.5.1->esphome) (1.16.0)
                                  Installing collected packages: pycparser, sniffio, cffi, tzdata, typing-extensions, packaging, ifaddr, h11, cryptography, click, async-timeout, anyio, zeroconf, wsproto, uvicorn, tabulate, starlette, semantic-version, reedsolo, pytz-deprecation-shim, pyserial, pyelftools, protobuf, noiseprotocol, marshmallow, ecdsa, colorama, bottle, bitstring, ajsonrpc, aiofiles, voluptuous, tzlocal, tornado, PyYAML, platformio, paho-mqtt, kconfiglib, esptool, esphome-dashboard, aioesphomeapi, esphome
                                    WARNING: The script uvicorn is installed in '/home/flo/.local/bin' which is not on PATH.
                                    Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
                                    WARNING: The script tabulate is installed in '/home/flo/.local/bin' which is not on PATH.
                                    WARNING: The scripts pyserial-miniterm and pyserial-ports are installed in '/home/flo/.local/bin' which is not on PATH.
                                    WARNING: The script async-json-rpc-server is installed in '/home/flo/.local/bin' which is not on PATH.
                                    WARNING: The scripts pio, piodebuggdb and platformio are installed in '/home/flo/.local/bin' which is not on PATH.
                                    WARNING: The scripts alldefconfig, allmodconfig, allnoconfig, allyesconfig, defconfig, genconfig, guiconfig, listnewconfig, menuconfig, oldconfig, olddefconfig, savedefconfig and setconfig are installed in '/home/flo/.local/bin' which is not on PATH.
                                    WARNING: The script esphome is installed in '/home/flo/.local/bin' which is not on PATH.
                                  Successfully installed PyYAML-6.0 aioesphomeapi-13.5.1 aiofiles-22.1.0 ajsonrpc-1.2.0 anyio-3.6.2 async-timeout-4.0.2 bitstring-4.0.2 bottle-0.12.25 cffi-1.15.1 click-8.1.3 colorama-0.4.6 cryptography-40.0.2 ecdsa-0.18.0 esphome-2023.4.1 esphome-dashboard-20230214.0 esptool-4.5.1 h11-0.14.0 ifaddr-0.2.0 kconfiglib-13.7.1 marshmallow-3.19.0 noiseprotocol-0.3.1 packaging-23.1 paho-mqtt-1.6.1 platformio-6.1.6 protobuf-4.22.3 pycparser-2.21 pyelftools-0.29 pyserial-3.5 pytz-deprecation-shim-0.1.0.post0 reedsolo-1.6.0 semantic-version-2.10.0 sniffio-1.3.0 starlette-0.23.1 tabulate-0.9.0 tornado-6.2 typing-extensions-4.5.0 tzdata-2023.3 tzlocal-4.2 uvicorn-0.20.0 voluptuous-0.13.1 wsproto-1.2.0 zeroconf-0.56.0
                                  flo@raspberrypi:~ $ export PATH=$PATH:/home/flo/.local/bin
                                  Version: 2023.4.1
                                  flo@raspberrypi:~ $
                                  Ich glaub den ESPHome Adapter lass ich dann mal bleiben, oder versuchs mal bei HA.
                                  • M mayokleckz
                                    Collecting esphome
                                    Collecting h11>=0.8
                                    Version: 2023.4.1
                                    flo@raspberrypi:~ $
                                    @mayokleckz
                                    pipx install esphome
                                    ist aber möglich das des Adapter das anders braucht/selber mitbringt.
                                      @mayokleckz
                                      mayokleckz
                                      Ich weiß ja, dass es kein iobroker Thema mehr ist, würde es aber trotzdem hier Dokumentieren, falls ich zu einer Lösung komme. Kann ja nicht sein, dass es nicht geht. . .
                                      Im Abhängigkeitsbaum zu Beginn der Kompilierung, habe ich festgestellt, dass im Vergleich zu anderen noise-c und libsodium fehlen. Kann es daran liegen?
                                      Falls ja, wie kann ich das installieren? Wenn ich google, bekomm ich nur noise canceling und audio Ergebnisse.
                                      Mein "Error"Log auf dem Raspi
                                      Dependency Graph
                                      |   |-- Hash @ 1.0
                                      Hier aus dem log einer funktionierenden Kompilierung
                                      Dependency Graph
                                      |   |-- Hash @ 1.0
                                      |-- noise-c @ 0.1.4
                                      Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_connection.cpp.o
                                      Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_frame_helper.cpp.o
                                      Compiling .pioenvs\esp-home-brunnen-defsettings\src\esphome\components\api\api_pb2.cpp.o
                                      • M mayokleckz
                                        Dependency Graph
                                        |   |-- Hash @ 1.0
                                        Dependency Graph
                                        |   |-- Hash @ 1.0
                                        |-- noise-c @ 0.1.4
                                        mayokleckz
                                        @mayokleckz
                                        SD Karte formatieren und RaspOS 64 bit drauf. Alles installieren und es läuft.
                                        Ich brech zam.
                                        Danke @Thomas-Braun für den support und sorry, war offensichtlich unnötig.
