  4. ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert
esphomepythonwemos d1 miniplatformio
29 Beiträge 3 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    mayokleckz
    gerade noch einmal ausgeführt. Hier das Logfile
     $ sudo iobroker add esphome auto --host raspberrypi --debug
    NPM version: 9.5.1
    Installing iobroker.esphome@0.2.4... (System call)
    npm ERR! code 126
    npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
    npm ERR! command failed
    npm ERR! command sh -c npip install
    npm ERR! sh: 1: npip: Permission denied
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    host.raspberrypi Cannot install iobroker.esphome@0.2.4: 126
    // home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.5.1
    2 info using node@v18.16.0
    3 timing npm:load:whichnode Completed in 3ms
    4 timing config:load:defaults Completed in 6ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 14ms
    6 timing config:load:builtin Completed in 15ms
    7 timing config:load:cli Completed in 9ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
    10 timing config:load:project Completed in 22ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 4ms
    16 timing config:load Completed in 59ms
    17 timing npm:load:configload Completed in 59ms
    18 timing npm:load:mkdirpcache Completed in 1ms
    19 timing npm:load:mkdirplogs Completed in 1ms
    20 verbose title npm install iobroker.esphome@0.2.4
    21 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
    22 timing npm:load:setTitle Completed in 5ms
    23 timing config:load:flatten Completed in 11ms
    24 timing npm:load:display Completed in 14ms
    25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-
    26 verbose logfile /home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    27 timing npm:load:logFile Completed in 18ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 104ms
    31 timing arborist:ctor Completed in 3ms
    32 silly logfile start cleaning logs, removing 2 files
    33 silly logfile done cleaning log files
    34 timing idealTree:init Completed in 3379ms
    35 timing idealTree:userRequests Completed in 22ms
    36 silly idealTree buildDeps
    37 silly fetch manifest iobroker.esphome@0.2.4
    38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    39 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 94ms (cache hit)
    40 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
    41 silly fetch manifest @sentry/node@^5.30.0
    42 silly fetch manifest esphome-native-api@^1.0.9
    43 silly fetch manifest nopy@^0.2.7
    44 silly fetch manifest tree-kill@^1.2.2
    45 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 55ms (cache hit)
    46 http fetch GET 200 https://registry.npmjs.org/tree-kill 55ms (cache hit)
    47 http fetch GET 200 https://registry.npmjs.org/nopy 58ms (cache hit)
    48 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 97ms (cache hit)
    49 timing idealTree:#root Completed in 267ms
    50 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
    51 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
    52 silly placeDep ROOT nopy@0.2.9 OK for: iobroker.esphome@0.2.4 want: ^0.2.7
    53 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
    54 silly fetch manifest @sentry/core@5.30.0
    55 silly fetch manifest @sentry/hub@5.30.0
    56 silly fetch manifest @sentry/types@5.30.0
    57 silly fetch manifest @sentry/utils@5.30.0
    58 silly fetch manifest eslint@^7.13.0
    59 silly fetch manifest events@^3.2.0
    60 silly fetch manifest google-protobuf@^3.14.0
    61 silly fetch manifest multicast-dns@^7.2.2
    62 silly fetch manifest net@^1.0.2
    63 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 3521ms (cache hit)
    64 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 3542ms (cache hit)
    65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 3557ms (cache hit)
    66 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 3571ms (cache hit)
    67 http fetch GET 200 https://registry.npmjs.org/eslint 3590ms (cache hit)
    68 http fetch GET 200 https://registry.npmjs.org/events 3649ms (cache hit)
    69 http fetch GET 200 https://registry.npmjs.org/google-protobuf 3650ms (cache hit)
    70 http fetch GET 200 https://registry.npmjs.org/net 3651ms (cache hit)
    71 http fetch GET 200 https://registry.npmjs.org/multicast-dns 3655ms (cache hit)
    72 timing idealTree:node_modules/iobroker.esphome Completed in 3743ms
    73 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
    74 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
    75 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
    76 silly placeDep ROOT multicast-dns@7.2.5 OK for: esphome-native-api@1.0.9 want: ^7.2.2
    77 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
    78 silly fetch manifest @babel/code-frame@7.12.11
    79 silly fetch manifest @eslint/eslintrc@^0.4.3
    80 silly fetch manifest @humanwhocodes/config-array@^0.5.0
    81 silly fetch manifest debug@^4.0.1
    82 silly fetch manifest doctrine@^3.0.0
    83 silly fetch manifest enquirer@^2.3.5
    84 silly fetch manifest eslint-scope@^5.1.1
    85 silly fetch manifest eslint-utils@^2.1.0
    86 silly fetch manifest eslint-visitor-keys@^2.0.0
    87 silly fetch manifest espree@^7.3.1
    88 silly fetch manifest esquery@^1.4.0
    89 silly fetch manifest esutils@^2.0.2
    90 silly fetch manifest file-entry-cache@^6.0.1
    91 silly fetch manifest functional-red-black-tree@^1.0.1
    92 silly fetch manifest globals@^13.6.0
    93 silly fetch manifest ignore@^4.0.6
    94 silly fetch manifest js-yaml@^3.13.1
    95 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
    96 silly fetch manifest levn@^0.4.1
    97 silly fetch manifest lodash.merge@^4.6.2
    98 silly fetch manifest minimatch@^3.0.4
    99 silly fetch manifest natural-compare@^1.4.0
    100 silly fetch manifest optionator@^0.9.1
    101 silly fetch manifest progress@^2.0.0
    102 silly fetch manifest regexpp@^3.1.0
    103 silly fetch manifest strip-json-comments@^3.1.0
    104 silly fetch manifest table@^6.0.9
    105 silly fetch manifest text-table@^0.2.0
    106 silly fetch manifest v8-compile-cache@^2.0.3
    107 silly fetch manifest dns-packet@^5.2.2
    108 silly fetch manifest thunky@^1.0.2
    109 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 428ms (cache hit)
    110 http fetch GET 200 https://registry.npmjs.org/doctrine 426ms (cache hit)
    111 http fetch GET 200 https://registry.npmjs.org/eslint-scope 427ms (cache hit)
    112 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 437ms (cache hit)
    113 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 442ms (cache hit)
    114 http fetch GET 200 https://registry.npmjs.org/debug 445ms (cache hit)
    115 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 441ms (cache hit)
    116 http fetch GET 200 https://registry.npmjs.org/espree 445ms (cache hit)
    117 http fetch GET 200 https://registry.npmjs.org/esquery 452ms (cache hit)
    118 http fetch GET 200 https://registry.npmjs.org/esutils 451ms (cache hit)
    119 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 451ms (cache hit)
    120 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 451ms (cache hit)
    121 http fetch GET 200 https://registry.npmjs.org/globals 452ms (cache hit)
    122 http fetch GET 200 https://registry.npmjs.org/ignore 455ms (cache hit)
    123 http fetch GET 200 https://registry.npmjs.org/enquirer 485ms (cache hit)
    124 http fetch GET 200 https://registry.npmjs.org/levn 457ms (cache hit)
    125 http fetch GET 200 https://registry.npmjs.org/eslint-utils 488ms (cache hit)
    126 http fetch GET 200 https://registry.npmjs.org/js-yaml 468ms (cache hit)
    127 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 471ms (cache hit)
    128 http fetch GET 200 https://registry.npmjs.org/natural-compare 463ms (cache hit)
    129 http fetch GET 200 https://registry.npmjs.org/optionator 444ms (cache hit)
    130 http fetch GET 200 https://registry.npmjs.org/progress 444ms (cache hit)
    131 http fetch GET 200 https://registry.npmjs.org/regexpp 443ms (cache hit)
    132 http fetch GET 200 https://registry.npmjs.org/lodash.merge 476ms (cache hit)
    133 http fetch GET 200 https://registry.npmjs.org/text-table 440ms (cache hit)
    134 http fetch GET 200 https://registry.npmjs.org/dns-packet 437ms (cache hit)
    135 http fetch GET 200 https://registry.npmjs.org/minimatch 483ms (cache hit)
    136 http fetch GET 200 https://registry.npmjs.org/thunky 450ms (cache hit)
    137 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 465ms (cache hit)
    138 http fetch GET 200 https://registry.npmjs.org/table 468ms (cache hit)
    139 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 488ms (cache hit)
    140 timing idealTree:node_modules/esphome-native-api Completed in 614ms
    141 silly placeDep node_modules/eslint @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
    142 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
    143 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
    144 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
    145 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
    146 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
    147 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
    148 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
    149 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
    150 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
    151 silly placeDep ROOT esquery@1.5.0 OK for: eslint@7.32.0 want: ^1.4.0
    152 silly placeDep ROOT esutils@2.0.3 OK for: eslint@7.32.0 want: ^2.0.2
    153 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
    154 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
    155 silly placeDep ROOT globals@13.20.0 OK for: eslint@7.32.0 want: ^13.6.0
    156 silly placeDep node_modules/eslint ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
    157 silly placeDep ROOT js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
    158 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
    159 silly placeDep ROOT levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
    160 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
    161 silly placeDep node_modules/eslint minimatch@3.1.2 OK for: eslint@7.32.0 want: ^3.0.4
    162 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
    163 silly placeDep ROOT optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
    164 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
    165 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
    166 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
    167 silly placeDep ROOT table@6.8.1 OK for: eslint@7.32.0 want: ^6.0.9
    168 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
    169 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
    170 silly fetch manifest debug@^4.1.1
    171 silly fetch manifest strip-json-comments@^3.1.1
    172 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
    173 silly fetch manifest ms@2.1.2
    174 silly fetch manifest ansi-colors@^4.1.1
    175 silly fetch manifest esrecurse@^4.3.0
    176 silly fetch manifest estraverse@^4.1.1
    177 silly fetch manifest eslint-visitor-keys@^1.1.0
    178 silly fetch manifest acorn@^7.4.0
    179 silly fetch manifest acorn-jsx@^5.3.1
    180 silly fetch manifest eslint-visitor-keys@^1.3.0
    181 silly fetch manifest estraverse@^5.1.0
    182 silly fetch manifest flat-cache@^3.0.4
    183 silly fetch manifest type-fest@^0.20.2
    184 silly fetch manifest argparse@^1.0.7
    185 silly fetch manifest esprima@^4.0.0
    186 silly fetch manifest prelude-ls@^1.2.1
    187 silly fetch manifest type-check@~0.4.0
    188 silly fetch manifest brace-expansion@^1.1.7
    189 silly fetch manifest deep-is@^0.1.3
    190 silly fetch manifest word-wrap@^1.2.3
    191 silly fetch manifest type-check@^0.4.0
    192 silly fetch manifest fast-levenshtein@^2.0.6
    193 silly fetch manifest ajv@^8.0.1
    194 silly fetch manifest lodash.truncate@^4.4.2
    195 silly fetch manifest slice-ansi@^4.0.0
    196 http fetch GET 200 https://registry.npmjs.org/ms 221ms (cache hit)
    197 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 227ms (cache hit)
    198 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 211ms (cache hit)
    199 http fetch GET 200 https://registry.npmjs.org/estraverse 209ms (cache hit)
    200 http fetch GET 200 https://registry.npmjs.org/flat-cache 209ms (cache hit)
    201 http fetch GET 200 https://registry.npmjs.org/argparse 207ms (cache hit)
    202 http fetch GET 200 https://registry.npmjs.org/type-fest 215ms (cache hit)
    203 http fetch GET 200 https://registry.npmjs.org/estraverse 239ms (cache hit)
    204 http fetch GET 200 https://registry.npmjs.org/esrecurse 246ms (cache hit)
    205 http fetch GET 200 https://registry.npmjs.org/acorn 242ms (cache hit)
    206 http fetch GET 200 https://registry.npmjs.org/ansi-colors 260ms (cache hit)
    207 http fetch GET 200 https://registry.npmjs.org/prelude-ls 235ms (cache hit)
    208 http fetch GET 200 https://registry.npmjs.org/word-wrap 218ms (cache hit)
    209 http fetch GET 200 https://registry.npmjs.org/type-check 236ms (cache hit)
    210 http fetch GET 200 https://registry.npmjs.org/brace-expansion 236ms (cache hit)
    211 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 215ms (cache hit)
    212 http fetch GET 200 https://registry.npmjs.org/fast-levenshtein 222ms (cache hit)
    213 http fetch GET 200 https://registry.npmjs.org/ajv 226ms (cache hit)
    214 http fetch GET 200 https://registry.npmjs.org/slice-ansi 236ms (cache hit)
    215 http fetch GET 200 https://registry.npmjs.org/esprima 274ms (cache hit)
    216 http fetch GET 200 https://registry.npmjs.org/deep-is 259ms (cache hit)
    217 http fetch GET 200 https://registry.npmjs.org/type-check 255ms (cache hit)
    218 timing idealTree:node_modules/eslint Completed in 529ms
    219 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
    220 silly placeDep node_modules/@eslint/eslintrc ignore@4.0.6 OK for: @eslint/eslintrc@0.4.3 want: ^4.0.6
    221 silly placeDep node_modules/@eslint/eslintrc minimatch@3.1.2 OK for: @eslint/eslintrc@0.4.3 want: ^3.0.4
    222 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
    223 timing idealTree:node_modules/@eslint/eslintrc Completed in 15ms
    224 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
    225 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
    226 silly placeDep node_modules/@humanwhocodes/config-array minimatch@3.1.2 OK for: @humanwhocodes/config-array@0.5.0 want: ^3.0.4
    227 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 13ms
    228 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
    229 timing idealTree:node_modules/doctrine Completed in 0ms
    230 silly placeDep ROOT ansi-colors@4.1.3 OK for: enquirer@2.3.6 want: ^4.1.1
    231 timing idealTree:node_modules/enquirer Completed in 5ms
    232 timing idealTree:node_modules/ansi-colors Completed in 0ms
    233 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
    234 silly placeDep ROOT estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
    235 silly fetch manifest estraverse@^5.2.0
    236 timing idealTree:node_modules/eslint-scope Completed in 12ms
    237 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
    238 timing idealTree:node_modules/eslint-utils Completed in 3ms
    239 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
    240 silly placeDep ROOT acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
    241 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
    242 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
    243 timing idealTree:node_modules/espree Completed in 45ms
    244 timing idealTree:node_modules/acorn Completed in 1ms
    245 timing idealTree:node_modules/acorn-jsx Completed in 0ms
    246 silly placeDep node_modules/esquery estraverse@5.3.0 OK for: esquery@1.5.0 want: ^5.1.0
    247 timing idealTree:node_modules/esquery Completed in 5ms
    248 silly placeDep node_modules/esrecurse estraverse@5.3.0 OK for: esrecurse@4.3.0 want: ^5.2.0
    249 timing idealTree:node_modules/esrecurse Completed in 4ms
    250 timing idealTree:node_modules/estraverse Completed in 0ms
    251 timing idealTree:node_modules/esutils Completed in 0ms
    252 timing idealTree:node_modules/events Completed in 0ms
    253 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
    254 silly fetch manifest flatted@^3.1.0
    255 http fetch GET 200 https://registry.npmjs.org/flatted 17ms (cache hit)
    256 timing idealTree:node_modules/file-entry-cache Completed in 28ms
    257 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
    258 timing idealTree:node_modules/flat-cache Completed in 10ms
    259 timing idealTree:node_modules/flatted Completed in 0ms
    260 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
    261 silly placeDep node_modules/globals type-fest@0.20.2 OK for: globals@13.20.0 want: ^0.20.2
    262 timing idealTree:node_modules/globals Completed in 4ms
    263 timing idealTree:node_modules/google-protobuf Completed in 0ms
    264 silly placeDep ROOT argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
    265 silly placeDep ROOT esprima@4.0.1 OK for: js-yaml@3.14.1 want: ^4.0.0
    266 silly fetch manifest sprintf-js@~1.0.2
    267 http fetch GET 200 https://registry.npmjs.org/sprintf-js 9ms (cache hit)
    268 timing idealTree:node_modules/js-yaml Completed in 24ms
    269 silly placeDep node_modules/argparse sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
    270 timing idealTree:node_modules/argparse Completed in 3ms
    271 timing idealTree:node_modules/esprima Completed in 0ms
    272 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
    273 silly placeDep ROOT prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
    274 silly placeDep ROOT type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
    275 timing idealTree:node_modules/levn Completed in 13ms
    276 timing idealTree:node_modules/lodash.merge Completed in 0ms
    277 silly placeDep node_modules/multicast-dns dns-packet@5.6.0 OK for: multicast-dns@7.2.5 want: ^5.2.2
    278 silly placeDep ROOT thunky@1.1.0 OK for: multicast-dns@7.2.5 want: ^1.0.2
    279 silly fetch manifest @leichtgewicht/ip-codec@^2.0.1
    280 http fetch GET 200 https://registry.npmjs.org/@leichtgewicht%2fip-codec 9ms (cache hit)
    281 timing idealTree:node_modules/multicast-dns Completed in 23ms
    282 timing idealTree:node_modules/natural-compare Completed in 0ms
    283 timing idealTree:node_modules/net Completed in 0ms
    284 timing idealTree:node_modules/nopy Completed in 1ms
    285 silly placeDep ROOT deep-is@0.1.4 OK for: optionator@0.9.1 want: ^0.1.3
    286 silly placeDep ROOT fast-levenshtein@2.0.6 OK for: optionator@0.9.1 want: ^2.0.6
    287 silly placeDep ROOT word-wrap@1.2.3 OK for: optionator@0.9.1 want: ^1.2.3
    288 timing idealTree:node_modules/optionator Completed in 17ms
    289 timing idealTree:node_modules/deep-is Completed in 1ms
    290 timing idealTree:node_modules/fast-levenshtein Completed in 0ms
    291 timing idealTree:node_modules/prelude-ls Completed in 0ms
    292 timing idealTree:node_modules/progress Completed in 0ms
    293 timing idealTree:node_modules/regexpp Completed in 0ms
    294 silly placeDep node_modules/table ajv@8.12.0 OK for: table@6.8.1 want: ^8.0.1
    295 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.1 want: ^4.4.2
    296 silly placeDep node_modules/table slice-ansi@4.0.0 OK for: table@6.8.1 want: ^4.0.0
    297 silly fetch manifest json-schema-traverse@^1.0.0
    298 silly fetch manifest require-from-string@^2.0.2
    299 silly fetch manifest astral-regex@^2.0.0
    300 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 24ms (cache hit)
    301 http fetch GET 200 https://registry.npmjs.org/require-from-string 24ms (cache hit)
    302 http fetch GET 200 https://registry.npmjs.org/astral-regex 23ms (cache hit)
    303 timing idealTree:node_modules/table Completed in 46ms
    304 timing idealTree:node_modules/lodash.truncate Completed in 0ms
    305 timing idealTree:node_modules/text-table Completed in 0ms
    306 timing idealTree:node_modules/thunky Completed in 0ms
    307 timing idealTree:node_modules/tree-kill Completed in 0ms
    308 timing idealTree:node_modules/type-check Completed in 0ms
    309 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
    310 timing idealTree:node_modules/word-wrap Completed in 0ms
    311 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    312 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 5ms
    313 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 0ms
    314 silly placeDep node_modules/@eslint/eslintrc brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    315 timing idealTree:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 4ms
    316 timing idealTree:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 0ms
    317 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
    318 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
    319 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    320 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 4ms
    321 silly placeDep node_modules/@humanwhocodes/config-array brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    322 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 4ms
    323 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 0ms
    324 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
    325 timing idealTree:node_modules/argparse/node_modules/sprintf-js Completed in 0ms
    326 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1ms
    327 timing idealTree:node_modules/eslint/node_modules/@babel/code-frame Completed in 0ms
    328 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    329 timing idealTree:node_modules/eslint/node_modules/debug Completed in 4ms
    330 timing idealTree:node_modules/eslint/node_modules/ignore Completed in 0ms
    331 silly placeDep node_modules/eslint brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
    332 timing idealTree:node_modules/eslint/node_modules/minimatch Completed in 5ms
    333 timing idealTree:node_modules/eslint/node_modules/brace-expansion Completed in 0ms
    334 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
    335 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
    336 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
    337 timing idealTree:node_modules/esquery/node_modules/estraverse Completed in 0ms
    338 timing idealTree:node_modules/esrecurse/node_modules/estraverse Completed in 0ms
    339 timing idealTree:node_modules/globals/node_modules/type-fest Completed in 1ms
    340 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    341 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    342 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    343 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
    344 silly fetch manifest @sentry/minimal@5.30.0
    345 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 14ms (cache hit)
    346 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 52ms
    347 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
    348 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 5ms
    349 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
    350 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
    351 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
    352 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
    353 silly placeDep ROOT @leichtgewicht/ip-codec@2.0.4 OK for: dns-packet@5.6.0 want: ^2.0.1
    354 timing idealTree:node_modules/multicast-dns/node_modules/dns-packet Completed in 7ms
    355 timing idealTree:node_modules/@leichtgewicht/ip-codec Completed in 0ms
    356 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
    357 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.12.0 want: ^2.0.2
    358 timing idealTree:node_modules/table/node_modules/ajv Completed in 10ms
    359 timing idealTree:node_modules/require-from-string Completed in 0ms
    360 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
    361 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
    362 timing idealTree:node_modules/table/node_modules/slice-ansi Completed in 6ms
    363 timing idealTree:node_modules/astral-regex Completed in 0ms
    364 timing idealTree:buildDeps Completed in 5568ms
    365 timing idealTree:fixDepFlags Completed in 25ms
    366 timing idealTree Completed in 9036ms
    367 timing reify:loadTrees Completed in 9040ms
    368 timing reify:diffTrees Completed in 105ms
    369 silly reify moves {}
    370 timing reify:retireShallow Completed in 4ms
    371 timing reify:createSparse Completed in 22ms
    372 timing reify:loadBundles Completed in 0ms
    373 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
    374 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
    375 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
    376 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
    377 timing reifyNode:node_modules/osx-temperature-sensor Completed in 67ms
    378 timing reifyNode:node_modules/fsevents Completed in 67ms
    379 timing reifyNode:node_modules/natural-compare Completed in 1296ms
    380 timing reifyNode:node_modules/require-from-string Completed in 1322ms
    381 timing reifyNode:node_modules/fast-levenshtein Completed in 1322ms
    382 timing reifyNode:node_modules/table/node_modules/slice-ansi Completed in 1337ms
    383 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1336ms
    384 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1337ms
    385 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 1338ms
    386 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1338ms
    387 timing reifyNode:node_modules/eslint/node_modules/brace-expansion Completed in 1339ms
    388 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1340ms
    389 timing reifyNode:node_modules/astral-regex Completed in 1357ms
    390 timing reifyNode:node_modules/lodash.truncate Completed in 1357ms
    391 timing reifyNode:node_modules/word-wrap Completed in 1357ms
    392 timing reifyNode:node_modules/net Completed in 1360ms
    393 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1369ms
    394 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1369ms
    395 timing reifyNode:node_modules/eslint/node_modules/@babel/code-frame Completed in 1370ms
    396 timing reifyNode:node_modules/esrecurse Completed in 1386ms
    397 timing reifyNode:node_modules/tree-kill Completed in 1386ms
    398 timing reifyNode:node_modules/thunky Completed in 1409ms
    399 timing reifyNode:node_modules/v8-compile-cache Completed in 1408ms
    400 timing reifyNode:node_modules/file-entry-cache Completed in 1409ms
    401 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1410ms
    402 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 1417ms
    403 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 1417ms
    404 timing reifyNode:node_modules/eslint/node_modules/minimatch Completed in 1417ms
    405 timing reifyNode:node_modules/type-check Completed in 1432ms
    406 timing reifyNode:node_modules/acorn-jsx Completed in 1433ms
    407 timing reifyNode:node_modules/lodash.merge Completed in 1434ms
    408 timing reifyNode:node_modules/@leichtgewicht/ip-codec Completed in 1450ms
    409 timing reifyNode:node_modules/ansi-colors Completed in 1448ms
    410 timing reifyNode:node_modules/progress Completed in 1449ms
    411 timing reifyNode:node_modules/levn Completed in 1449ms
    412 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1449ms
    413 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1456ms
    414 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1456ms
    415 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1454ms
    416 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1454ms
    417 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1454ms
    418 timing reifyNode:node_modules/estraverse Completed in 1467ms
    419 timing reifyNode:node_modules/globals Completed in 1468ms
    420 timing reifyNode:node_modules/esrecurse/node_modules/estraverse Completed in 1475ms
    421 timing reifyNode:node_modules/esquery/node_modules/estraverse Completed in 1475ms
    422 timing reifyNode:node_modules/deep-is Completed in 1487ms
    423 timing reifyNode:node_modules/flat-cache Completed in 1487ms
    424 timing reifyNode:node_modules/optionator Completed in 1488ms
    425 timing reifyNode:node_modules/functional-red-black-tree Completed in 1488ms
    426 timing reifyNode:node_modules/multicast-dns Completed in 1487ms
    427 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 1492ms
    428 timing reifyNode:node_modules/eslint/node_modules/ignore Completed in 1491ms
    429 timing reifyNode:node_modules/esutils Completed in 1539ms
    430 timing reifyNode:node_modules/multicast-dns/node_modules/dns-packet Completed in 1543ms
    431 timing reifyNode:node_modules/prelude-ls Completed in 1556ms
    432 timing reifyNode:node_modules/text-table Completed in 1596ms
    433 timing reifyNode:node_modules/espree Completed in 1596ms
    434 timing reifyNode:node_modules/doctrine Completed in 1595ms
    435 timing reifyNode:node_modules/flatted Completed in 1608ms
    436 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 1607ms
    437 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 1620ms
    438 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 1626ms
    439 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 1640ms
    440 timing reifyNode:node_modules/eslint-scope Completed in 1648ms
    441 timing reifyNode:node_modules/argparse/node_modules/sprintf-js Completed in 1666ms
    442 timing reifyNode:node_modules/regexpp Completed in 1680ms
    443 timing reifyNode:node_modules/esprima Completed in 1703ms
    444 timing reifyNode:node_modules/eslint-utils Completed in 1708ms
    445 timing reifyNode:node_modules/events Completed in 1800ms
    446 timing reifyNode:node_modules/argparse Completed in 1836ms
    447 timing reifyNode:node_modules/@eslint/eslintrc Completed in 1842ms
    448 timing reifyNode:node_modules/iobroker.esphome Completed in 1863ms
    449 timing reifyNode:node_modules/globals/node_modules/type-fest Completed in 1887ms
    450 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 1982ms
    451 timing reifyNode:node_modules/esphome-native-api Completed in 1988ms
    452 timing reifyNode:node_modules/enquirer Completed in 2004ms
    453 timing reifyNode:node_modules/google-protobuf Completed in 2047ms
    454 timing reifyNode:node_modules/esquery Completed in 2061ms
    455 timing reifyNode:node_modules/js-yaml Completed in 2063ms
    456 timing reifyNode:node_modules/acorn Completed in 2124ms
    457 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2273ms
    458 timing reifyNode:node_modules/table Completed in 2347ms
    459 timing reifyNode:node_modules/nopy Completed in 2473ms
    460 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 2542ms
    461 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 2612ms
    462 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 2732ms
    463 timing reifyNode:node_modules/table/node_modules/ajv Completed in 3151ms
    464 timing reifyNode:node_modules/eslint Completed in 3171ms
    465 timing reify:unpack Completed in 3184ms
    466 timing reify:unretire Completed in 1ms
    467 timing build:queue Completed in 19ms
    468 timing build:link:node_modules/acorn Completed in 38ms
    469 timing build:link:node_modules/eslint Completed in 35ms
    470 timing build:link:node_modules/esprima Completed in 43ms
    471 timing build:link:node_modules/js-yaml Completed in 43ms
    472 timing build:link:node_modules/multicast-dns Completed in 32ms
    473 timing build:link:node_modules/nopy Completed in 31ms
    474 timing build:link:node_modules/tree-kill Completed in 28ms
    475 timing build:link Completed in 48ms
    476 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
    477 info run iobroker.esphome@0.2.4 install { code: 126, signal: null }
    478 timing reify:rollback:createSparse Completed in 411ms
    479 timing reify:rollback:retireShallow Completed in 0ms
    480 timing command:install Completed in 12950ms
    481 verbose stack Error: command failed
    481 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
    481 verbose stack     at ChildProcess.emit (node:events:513:28)
    481 verbose stack     at maybeClose (node:internal/child_process:1091:16)
    481 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
    481 verbose stack     at Socket.emit (node:events:513:28)
    481 verbose stack     at Pipe.<anonymous> (node:net:322:12)
    482 verbose pkgid iobroker.esphome@0.2.4
    483 verbose cwd /opt/iobroker
    484 verbose Linux 6.1.21-v8+
    485 verbose node v18.16.0
    486 verbose npm  v9.5.1
    487 error code 126
    488 error path /opt/iobroker/node_modules/iobroker.esphome
    489 error command failed
    490 error command sh -c npip install
    491 error sh: 1: npip: Permission denied
    492 verbose exit 126
    493 timing npm Completed in 13118ms
    494 verbose unfinished npm timer reify 1682355031569
    495 verbose unfinished npm timer reify:build 1682355043958
    496 verbose unfinished npm timer build 1682355043962
    497 verbose unfinished npm timer build:deps 1682355043963
    498 verbose unfinished npm timer build:run:install 1682355044031
    499 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1682355044033
    500 verbose code 126
    501 error A complete log of this run can be found in:
    501 error     /home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log
    • M mayokleckz
      NPM version: 9.5.1
      npm ERR! code 126
      487 error code 126
      @mayokleckz sagte in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
      sudo iobroker
      iobroker wird niemals mit sudo ausgeführt.
      iob stop
      iob fix
      iob start
      • M mayokleckz
        NPM version: 9.5.1
        npm ERR! code 126
        487 error code 126
        @mayokleckz
        find "/usr/lib/" -iname "EXTERNALLY*"
        sagt?
          @mayokleckz
          sagt?
          mayokleckz
          sudo in der Console war der laienhafte Versuch den Permission denied fehler zu umgehen. In der Applikation wird er ohne ausgeführt.
          find: ‘/usr/lib/mysql/plugin/auth_pam_tool_dir’: Permission denied
          • M mayokleckz
            iobroker NIE mit sudo in Verbindung bringen.
            Hast du den Fix jetzt ausgeführt?
            Auszüge aus der Konsole immer vollständig, inkl. LogInPrompt und der neuen, leeren Eingabezeile, damit man sieht ob das komplett durch ist oder da Dinge nicht kopiert wurden.
            Was steht da drin?
              Was steht da drin?
              mayokleckz
              schrieb am zuletzt editiert von mayokleckz
              ok, alles klar.
              Fix habe ich ausgeführt. Danach dann den find befehl
               $ iob stop
              flo@raspberrypi:~ $ iob fix
              library: loaded
              Library version=2022-12-09
                  Welcome to the ioBroker installation fixer!
                  Script version: 2023-04-02
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
              Get:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
              Fetched 15.0 kB in 1s (12.9 kB/s)
              Reading package lists... Done
              Installed gcc-c++
                  Checking ioBroker user and directory permissions (2/5)
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Compressed 2 JSONL files. Done
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              flo@raspberrypi:~ $ iob start
              flo@raspberrypi:~ $ find "/usr/lib/" -iname "EXTERNALLY*"
              flo@raspberrypi:~ $
              Edit: Der auszug der Datei / home/iobroker/.npm/_logs/2023-04-24T16_50_31_412Z-debug-0.log noch
              487 error code 126
              • M mayokleckz
                ok, alles klar.
                 $ iob stop
                library: loaded
                Installed gcc-c++
                Done.
                Autostart enabled!
                flo@raspberrypi:~ $
                487 error code 126
                @mayokleckz
                Was sagt:
                ls -la /opt/iobroker/node_modules/nopy/src/
                  mayokleckz
                  flo@raspberrypi:~ $ ls -la /opt/iobroker/node_modules/nopy/src/
                  ls: cannot access '/opt/iobroker/node_modules/nopy/src/': No such file or directory
                  flo@raspberrypi:~ $
                  • M mayokleckz
                    flo@raspberrypi:~ $
                    @mayokleckz
                    cd /opt/iobroker
                    npm i nopy
                    sudo -u iobroker chmod ug+x /opt/iobroker/node_modules/nopy/src/n*
                    Danach sollte es mit der Installation funktionieren.
                      @mayokleckz
                      cd /opt/iobroker
                      npm i nopy
                      mayokleckz
                      @thomas-braun said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
                      sudo -u iobroker chmod a+x /opt/iobroker/node_modules/nopy/src/n*
                      Mit den Rechten kommt man ein Stück weiter. Jedoch rennt das System in den nächsten Fehler.
                      Ist da bei meiner Installation gestern was schief gegangen? Mit so viel Problemen installiert sich ja sonst niemand einen Adapter.
                      Würd mich freuen wenn du auch hier nochmal drüber schaust.
                      Hier das Logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
                      3 timing npm:load:whichnode Completed in 24ms
                      4 timing config:load:defaults Completed in 17ms
                      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 24ms
                      6 timing config:load:builtin Completed in 24ms
                      7 timing config:load:cli Completed in 11ms
                      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 8ms
                      10 timing config:load:project Completed in 12ms
                      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                      13 timing config:load:file:/usr/etc/npmrc Completed in 1ms
                      15 timing config:load:setEnvs Completed in 6ms
                      16 timing config:load Completed in 77ms
                      17 timing npm:load:configload Completed in 77ms
                      23 timing config:load:flatten Completed in 13ms
                      24 timing npm:load:display Completed in 17ms
                      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-
                      26 verbose logfile /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
                      27 timing npm:load:logFile Completed in 20ms
                      30 timing npm:load Completed in 151ms
                      34 timing idealTree:init Completed in 4111ms
                      35 timing idealTree:userRequests Completed in 30ms
                      39 http fetch GET 200 https://registry.npmjs.org/iobroker.esphome 181ms (cache hit)
                      43 silly fetch manifest tree-kill@^1.2.2
                      44 http fetch GET 200 https://registry.npmjs.org/esphome-native-api 3381ms (cache hit)
                      45 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 3396ms (cache hit)
                      46 http fetch GET 200 https://registry.npmjs.org/tree-kill 3453ms (cache hit)
                      47 timing idealTree:#root Completed in 3683ms
                      48 silly placeDep node_modules/iobroker.esphome @sentry/node@5.30.0 OK for: iobroker.esphome@0.2.4 want: ^5.30.0
                      49 silly placeDep ROOT esphome-native-api@1.0.9 OK for: iobroker.esphome@0.2.4 want: ^1.0.9
                      50 silly placeDep ROOT tree-kill@1.2.2 OK for: iobroker.esphome@0.2.4 want: ^1.2.2
                      51 silly fetch manifest @sentry/core@5.30.0
                      52 silly fetch manifest @sentry/hub@5.30.0
                      53 silly fetch manifest @sentry/types@5.30.0
                      54 silly fetch manifest @sentry/utils@5.30.0
                      55 silly fetch manifest eslint@^7.13.0
                      56 silly fetch manifest events@^3.2.0
                      57 silly fetch manifest google-protobuf@^3.14.0
                      58 silly fetch manifest multicast-dns@^7.2.2
                      59 silly fetch manifest net@^1.0.2
                      60 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 963ms (cache hit)
                      61 http fetch GET 200 https://registry.npmjs.org/events 976ms (cache hit)
                      62 http fetch GET 200 https://registry.npmjs.org/multicast-dns 986ms (cache hit)
                      63 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 1010ms (cache hit)
                      64 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 1037ms (cache hit)
                      65 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 1067ms (cache hit)
                      66 http fetch GET 200 https://registry.npmjs.org/google-protobuf 1072ms (cache hit)
                      67 http fetch GET 200 https://registry.npmjs.org/net 1075ms (cache hit)
                      68 http fetch GET 200 https://registry.npmjs.org/eslint 1093ms (cache hit)
                      69 timing idealTree:node_modules/iobroker.esphome Completed in 1226ms
                      70 silly placeDep ROOT eslint@7.32.0 OK for: esphome-native-api@1.0.9 want: ^7.13.0
                      71 silly placeDep ROOT events@3.3.0 OK for: esphome-native-api@1.0.9 want: ^3.2.0
                      72 silly placeDep ROOT google-protobuf@3.21.2 OK for: esphome-native-api@1.0.9 want: ^3.14.0
                      73 silly placeDep ROOT multicast-dns@7.2.5 OK for: esphome-native-api@1.0.9 want: ^7.2.2
                      74 silly placeDep ROOT net@1.0.2 OK for: esphome-native-api@1.0.9 want: ^1.0.2
                      75 silly fetch manifest @babel/code-frame@7.12.11
                      76 silly fetch manifest @eslint/eslintrc@^0.4.3
                      77 silly fetch manifest @humanwhocodes/config-array@^0.5.0
                      78 silly fetch manifest debug@^4.0.1
                      79 silly fetch manifest doctrine@^3.0.0
                      80 silly fetch manifest enquirer@^2.3.5
                      81 silly fetch manifest eslint-scope@^5.1.1
                      82 silly fetch manifest eslint-utils@^2.1.0
                      83 silly fetch manifest eslint-visitor-keys@^2.0.0
                      84 silly fetch manifest espree@^7.3.1
                      85 silly fetch manifest esquery@^1.4.0
                      86 silly fetch manifest esutils@^2.0.2
                      87 silly fetch manifest file-entry-cache@^6.0.1
                      88 silly fetch manifest functional-red-black-tree@^1.0.1
                      89 silly fetch manifest globals@^13.6.0
                      90 silly fetch manifest ignore@^4.0.6
                      91 silly fetch manifest js-yaml@^3.13.1
                      92 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
                      93 silly fetch manifest levn@^0.4.1
                      94 silly fetch manifest lodash.merge@^4.6.2
                      95 silly fetch manifest minimatch@^3.0.4
                      96 silly fetch manifest natural-compare@^1.4.0
                      97 silly fetch manifest optionator@^0.9.1
                      98 silly fetch manifest progress@^2.0.0
                      99 silly fetch manifest regexpp@^3.1.0
                      100 silly fetch manifest strip-json-comments@^3.1.0
                      101 silly fetch manifest table@^6.0.9
                      102 silly fetch manifest text-table@^0.2.0
                      103 silly fetch manifest v8-compile-cache@^2.0.3
                      104 silly fetch manifest dns-packet@^5.2.2
                      105 silly fetch manifest thunky@^1.0.2
                      106 http fetch GET 200 https://registry.npmjs.org/@babel%2fcode-frame 325ms (cache hit)
                      107 http fetch GET 200 https://registry.npmjs.org/@eslint%2feslintrc 328ms (cache hit)
                      108 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fconfig-array 332ms (cache hit)
                      109 http fetch GET 200 https://registry.npmjs.org/debug 337ms (cache hit)
                      110 http fetch GET 200 https://registry.npmjs.org/enquirer 357ms (cache hit)
                      111 http fetch GET 200 https://registry.npmjs.org/eslint-scope 362ms (cache hit)
                      112 http fetch GET 200 https://registry.npmjs.org/doctrine 368ms (cache hit)
                      113 http fetch GET 200 https://registry.npmjs.org/eslint-utils 368ms (cache hit)
                      114 http fetch GET 200 https://registry.npmjs.org/eslint-visitor-keys 371ms (cache hit)
                      115 http fetch GET 200 https://registry.npmjs.org/espree 374ms (cache hit)
                      116 http fetch GET 200 https://registry.npmjs.org/esquery 382ms (cache hit)
                      117 http fetch GET 200 https://registry.npmjs.org/esutils 381ms (cache hit)
                      118 http fetch GET 200 https://registry.npmjs.org/file-entry-cache 381ms (cache hit)
                      119 http fetch GET 200 https://registry.npmjs.org/functional-red-black-tree 382ms (cache hit)
                      120 http fetch GET 200 https://registry.npmjs.org/globals 382ms (cache hit)
                      121 http fetch GET 200 https://registry.npmjs.org/ignore 386ms (cache hit)
                      122 http fetch GET 200 https://registry.npmjs.org/js-yaml 391ms (cache hit)
                      123 http fetch GET 200 https://registry.npmjs.org/json-stable-stringify-without-jsonify 395ms (cache hit)
                      124 http fetch GET 200 https://registry.npmjs.org/lodash.merge 393ms (cache hit)
                      125 http fetch GET 200 https://registry.npmjs.org/levn 399ms (cache hit)
                      126 http fetch GET 200 https://registry.npmjs.org/natural-compare 395ms (cache hit)
                      127 http fetch GET 200 https://registry.npmjs.org/minimatch 402ms (cache hit)
                      128 http fetch GET 200 https://registry.npmjs.org/progress 409ms (cache hit)
                      129 http fetch GET 200 https://registry.npmjs.org/optionator 417ms (cache hit)
                      130 http fetch GET 200 https://registry.npmjs.org/regexpp 417ms (cache hit)
                      131 http fetch GET 200 https://registry.npmjs.org/strip-json-comments 417ms (cache hit)
                      132 http fetch GET 200 https://registry.npmjs.org/text-table 415ms (cache hit)
                      133 http fetch GET 200 https://registry.npmjs.org/table 421ms (cache hit)
                      134 http fetch GET 200 https://registry.npmjs.org/thunky 417ms (cache hit)
                      135 http fetch GET 200 https://registry.npmjs.org/v8-compile-cache 425ms (cache hit)
                      136 http fetch GET 200 https://registry.npmjs.org/dns-packet 425ms (cache hit)
                      137 timing idealTree:node_modules/esphome-native-api Completed in 534ms
                      138 silly placeDep node_modules/eslint @babel/code-frame@7.12.11 OK for: eslint@7.32.0 want: 7.12.11
                      139 silly placeDep ROOT @eslint/eslintrc@0.4.3 OK for: eslint@7.32.0 want: ^0.4.3
                      140 silly placeDep ROOT @humanwhocodes/config-array@0.5.0 OK for: eslint@7.32.0 want: ^0.5.0
                      141 silly placeDep node_modules/eslint debug@4.3.4 OK for: eslint@7.32.0 want: ^4.0.1
                      142 silly placeDep ROOT doctrine@3.0.0 OK for: eslint@7.32.0 want: ^3.0.0
                      143 silly placeDep ROOT enquirer@2.3.6 OK for: eslint@7.32.0 want: ^2.3.5
                      144 silly placeDep ROOT eslint-scope@5.1.1 OK for: eslint@7.32.0 want: ^5.1.1
                      145 silly placeDep ROOT eslint-utils@2.1.0 OK for: eslint@7.32.0 want: ^2.1.0
                      146 silly placeDep ROOT eslint-visitor-keys@2.1.0 OK for: eslint@7.32.0 want: ^2.0.0
                      147 silly placeDep ROOT espree@7.3.1 OK for: eslint@7.32.0 want: ^7.3.1
                      148 silly placeDep ROOT esquery@1.5.0 OK for: eslint@7.32.0 want: ^1.4.0
                      149 silly placeDep ROOT esutils@2.0.3 OK for: eslint@7.32.0 want: ^2.0.2
                      150 silly placeDep ROOT file-entry-cache@6.0.1 OK for: eslint@7.32.0 want: ^6.0.1
                      151 silly placeDep ROOT functional-red-black-tree@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
                      152 silly placeDep ROOT globals@13.20.0 OK for: eslint@7.32.0 want: ^13.6.0
                      153 silly placeDep node_modules/eslint ignore@4.0.6 OK for: eslint@7.32.0 want: ^4.0.6
                      154 silly placeDep ROOT js-yaml@3.14.1 OK for: eslint@7.32.0 want: ^3.13.1
                      155 silly placeDep ROOT json-stable-stringify-without-jsonify@1.0.1 OK for: eslint@7.32.0 want: ^1.0.1
                      156 silly placeDep ROOT levn@0.4.1 OK for: eslint@7.32.0 want: ^0.4.1
                      157 silly placeDep ROOT lodash.merge@4.6.2 OK for: eslint@7.32.0 want: ^4.6.2
                      158 silly placeDep node_modules/eslint minimatch@3.1.2 OK for: eslint@7.32.0 want: ^3.0.4
                      159 silly placeDep ROOT natural-compare@1.4.0 OK for: eslint@7.32.0 want: ^1.4.0
                      160 silly placeDep ROOT optionator@0.9.1 OK for: eslint@7.32.0 want: ^0.9.1
                      161 silly placeDep ROOT progress@2.0.3 OK for: eslint@7.32.0 want: ^2.0.0
                      162 silly placeDep ROOT regexpp@3.2.0 OK for: eslint@7.32.0 want: ^3.1.0
                      163 silly placeDep node_modules/eslint strip-json-comments@3.1.1 OK for: eslint@7.32.0 want: ^3.1.0
                      164 silly placeDep ROOT table@6.8.1 OK for: eslint@7.32.0 want: ^6.0.9
                      165 silly placeDep ROOT text-table@0.2.0 OK for: eslint@7.32.0 want: ^0.2.0
                      166 silly placeDep ROOT v8-compile-cache@2.3.0 OK for: eslint@7.32.0 want: ^2.0.3
                      167 silly fetch manifest debug@^4.1.1
                      168 silly fetch manifest strip-json-comments@^3.1.1
                      169 silly fetch manifest @humanwhocodes/object-schema@^1.2.0
                      170 silly fetch manifest ms@2.1.2
                      171 silly fetch manifest ansi-colors@^4.1.1
                      172 silly fetch manifest esrecurse@^4.3.0
                      173 silly fetch manifest estraverse@^4.1.1
                      174 silly fetch manifest eslint-visitor-keys@^1.1.0
                      175 silly fetch manifest acorn@^7.4.0
                      176 silly fetch manifest acorn-jsx@^5.3.1
                      177 silly fetch manifest eslint-visitor-keys@^1.3.0
                      178 silly fetch manifest estraverse@^5.1.0
                      179 silly fetch manifest flat-cache@^3.0.4
                      180 silly fetch manifest type-fest@^0.20.2
                      181 silly fetch manifest argparse@^1.0.7
                      182 silly fetch manifest esprima@^4.0.0
                      183 silly fetch manifest prelude-ls@^1.2.1
                      184 silly fetch manifest type-check@~0.4.0
                      185 silly fetch manifest brace-expansion@^1.1.7
                      186 silly fetch manifest deep-is@^0.1.3
                      187 silly fetch manifest word-wrap@^1.2.3
                      188 silly fetch manifest type-check@^0.4.0
                      189 silly fetch manifest fast-levenshtein@^2.0.6
                      190 silly fetch manifest ajv@^8.0.1
                      191 silly fetch manifest lodash.truncate@^4.4.2
                      192 silly fetch manifest slice-ansi@^4.0.0
                      193 http fetch GET 200 https://registry.npmjs.org/esrecurse 315ms (cache hit)
                      194 http fetch GET 200 https://registry.npmjs.org/estraverse 315ms (cache hit)
                      195 http fetch GET 200 https://registry.npmjs.org/estraverse 308ms (cache hit)
                      196 http fetch GET 200 https://registry.npmjs.org/flat-cache 308ms (cache hit)
                      197 http fetch GET 200 https://registry.npmjs.org/@humanwhocodes%2fobject-schema 337ms (cache hit)
                      198 http fetch GET 200 https://registry.npmjs.org/ms 336ms (cache hit)
                      199 http fetch GET 200 https://registry.npmjs.org/acorn 327ms (cache hit)
                      200 http fetch GET 200 https://registry.npmjs.org/type-fest 327ms (cache hit)
                      201 http fetch GET 200 https://registry.npmjs.org/ansi-colors 358ms (cache hit)
                      202 http fetch GET 200 https://registry.npmjs.org/prelude-ls 330ms (cache hit)
                      203 http fetch GET 200 https://registry.npmjs.org/acorn-jsx 350ms (cache hit)
                      204 http fetch GET 200 https://registry.npmjs.org/esprima 338ms (cache hit)
                      205 http fetch GET 200 https://registry.npmjs.org/type-check 336ms (cache hit)
                      206 http fetch GET 200 https://registry.npmjs.org/brace-expansion 334ms (cache hit)
                      207 http fetch GET 200 https://registry.npmjs.org/word-wrap 332ms (cache hit)
                      208 http fetch GET 200 https://registry.npmjs.org/type-check 331ms (cache hit)
                      209 http fetch GET 200 https://registry.npmjs.org/argparse 355ms (cache hit)
                      210 http fetch GET 200 https://registry.npmjs.org/lodash.truncate 305ms (cache hit)
                      211 http fetch GET 200 https://registry.npmjs.org/slice-ansi 307ms (cache hit)
                      212 http fetch GET 200 https://registry.npmjs.org/deep-is 351ms (cache hit)
                      213 http fetch GET 200 https://registry.npmjs.org/fast-levenshtein 343ms (cache hit)
                      214 http fetch GET 200 https://registry.npmjs.org/ajv 351ms (cache hit)
                      215 timing idealTree:node_modules/eslint Completed in 668ms
                      216 silly placeDep node_modules/@eslint/eslintrc debug@4.3.4 OK for: @eslint/eslintrc@0.4.3 want: ^4.1.1
                      217 silly placeDep node_modules/@eslint/eslintrc ignore@4.0.6 OK for: @eslint/eslintrc@0.4.3 want: ^4.0.6
                      218 silly placeDep node_modules/@eslint/eslintrc minimatch@3.1.2 OK for: @eslint/eslintrc@0.4.3 want: ^3.0.4
                      219 silly placeDep node_modules/@eslint/eslintrc strip-json-comments@3.1.1 OK for: @eslint/eslintrc@0.4.3 want: ^3.1.1
                      220 timing idealTree:node_modules/@eslint/eslintrc Completed in 24ms
                      221 silly placeDep ROOT @humanwhocodes/object-schema@1.2.1 OK for: @humanwhocodes/config-array@0.5.0 want: ^1.2.0
                      222 silly placeDep node_modules/@humanwhocodes/config-array debug@4.3.4 OK for: @humanwhocodes/config-array@0.5.0 want: ^4.1.1
                      223 silly placeDep node_modules/@humanwhocodes/config-array minimatch@3.1.2 OK for: @humanwhocodes/config-array@0.5.0 want: ^3.0.4
                      224 timing idealTree:node_modules/@humanwhocodes/config-array Completed in 18ms
                      225 timing idealTree:node_modules/@humanwhocodes/object-schema Completed in 0ms
                      226 timing idealTree:node_modules/doctrine Completed in 0ms
                      227 silly placeDep ROOT ansi-colors@4.1.3 OK for: enquirer@2.3.6 want: ^4.1.1
                      228 timing idealTree:node_modules/enquirer Completed in 6ms
                      229 timing idealTree:node_modules/ansi-colors Completed in 0ms
                      230 silly placeDep ROOT esrecurse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.3.0
                      231 silly placeDep ROOT estraverse@4.3.0 OK for: eslint-scope@5.1.1 want: ^4.1.1
                      232 silly fetch manifest estraverse@^5.2.0
                      233 timing idealTree:node_modules/eslint-scope Completed in 15ms
                      234 silly placeDep node_modules/eslint-utils eslint-visitor-keys@1.3.0 OK for: eslint-utils@2.1.0 want: ^1.1.0
                      235 timing idealTree:node_modules/eslint-utils Completed in 4ms
                      236 timing idealTree:node_modules/eslint-visitor-keys Completed in 0ms
                      237 silly placeDep ROOT acorn@7.4.1 OK for: espree@7.3.1 want: ^7.4.0
                      238 silly placeDep ROOT acorn-jsx@5.3.2 OK for: espree@7.3.1 want: ^5.3.1
                      239 silly placeDep node_modules/espree eslint-visitor-keys@1.3.0 OK for: espree@7.3.1 want: ^1.3.0
                      240 timing idealTree:node_modules/espree Completed in 26ms
                      241 timing idealTree:node_modules/acorn Completed in 0ms
                      242 timing idealTree:node_modules/acorn-jsx Completed in 0ms
                      243 silly placeDep node_modules/esquery estraverse@5.3.0 OK for: esquery@1.5.0 want: ^5.1.0
                      244 timing idealTree:node_modules/esquery Completed in 6ms
                      245 silly placeDep node_modules/esrecurse estraverse@5.3.0 OK for: esrecurse@4.3.0 want: ^5.2.0
                      246 timing idealTree:node_modules/esrecurse Completed in 4ms
                      247 timing idealTree:node_modules/estraverse Completed in 0ms
                      248 timing idealTree:node_modules/esutils Completed in 1ms
                      249 timing idealTree:node_modules/events Completed in 0ms
                      250 silly placeDep ROOT flat-cache@3.0.4 OK for: file-entry-cache@6.0.1 want: ^3.0.4
                      251 silly fetch manifest flatted@^3.1.0
                      252 http fetch GET 200 https://registry.npmjs.org/flatted 18ms (cache hit)
                      253 timing idealTree:node_modules/file-entry-cache Completed in 31ms
                      254 silly placeDep ROOT flatted@3.2.7 OK for: flat-cache@3.0.4 want: ^3.1.0
                      255 timing idealTree:node_modules/flat-cache Completed in 7ms
                      256 timing idealTree:node_modules/flatted Completed in 0ms
                      257 timing idealTree:node_modules/functional-red-black-tree Completed in 0ms
                      258 silly placeDep node_modules/globals type-fest@0.20.2 OK for: globals@13.20.0 want: ^0.20.2
                      259 timing idealTree:node_modules/globals Completed in 5ms
                      260 timing idealTree:node_modules/google-protobuf Completed in 0ms
                      261 silly placeDep ROOT argparse@1.0.10 OK for: js-yaml@3.14.1 want: ^1.0.7
                      262 silly placeDep ROOT esprima@4.0.1 OK for: js-yaml@3.14.1 want: ^4.0.0
                      263 silly fetch manifest sprintf-js@~1.0.2
                      264 http fetch GET 200 https://registry.npmjs.org/sprintf-js 20ms (cache hit)
                      265 timing idealTree:node_modules/js-yaml Completed in 38ms
                      266 silly placeDep node_modules/argparse sprintf-js@1.0.3 OK for: argparse@1.0.10 want: ~1.0.2
                      267 timing idealTree:node_modules/argparse Completed in 4ms
                      268 timing idealTree:node_modules/esprima Completed in 0ms
                      269 timing idealTree:node_modules/json-stable-stringify-without-jsonify Completed in 0ms
                      270 silly placeDep ROOT prelude-ls@1.2.1 OK for: levn@0.4.1 want: ^1.2.1
                      271 silly placeDep ROOT type-check@0.4.0 OK for: levn@0.4.1 want: ~0.4.0
                      272 timing idealTree:node_modules/levn Completed in 13ms
                      273 timing idealTree:node_modules/lodash.merge Completed in 0ms
                      274 silly placeDep node_modules/multicast-dns dns-packet@5.6.0 OK for: multicast-dns@7.2.5 want: ^5.2.2
                      275 silly placeDep ROOT thunky@1.1.0 OK for: multicast-dns@7.2.5 want: ^1.0.2
                      276 silly fetch manifest @leichtgewicht/ip-codec@^2.0.1
                      277 http fetch GET 200 https://registry.npmjs.org/@leichtgewicht%2fip-codec 18ms (cache hit)
                      278 timing idealTree:node_modules/multicast-dns Completed in 34ms
                      279 timing idealTree:node_modules/natural-compare Completed in 0ms
                      280 timing idealTree:node_modules/net Completed in 0ms
                      281 silly placeDep ROOT deep-is@0.1.4 OK for: optionator@0.9.1 want: ^0.1.3
                      282 silly placeDep ROOT fast-levenshtein@2.0.6 OK for: optionator@0.9.1 want: ^2.0.6
                      283 silly placeDep ROOT word-wrap@1.2.3 OK for: optionator@0.9.1 want: ^1.2.3
                      284 timing idealTree:node_modules/optionator Completed in 19ms
                      285 timing idealTree:node_modules/deep-is Completed in 0ms
                      286 timing idealTree:node_modules/fast-levenshtein Completed in 1ms
                      287 timing idealTree:node_modules/prelude-ls Completed in 0ms
                      288 timing idealTree:node_modules/progress Completed in 0ms
                      289 timing idealTree:node_modules/regexpp Completed in 0ms
                      290 silly placeDep node_modules/table ajv@8.12.0 OK for: table@6.8.1 want: ^8.0.1
                      291 silly placeDep ROOT lodash.truncate@4.4.2 OK for: table@6.8.1 want: ^4.4.2
                      292 silly placeDep node_modules/table slice-ansi@4.0.0 OK for: table@6.8.1 want: ^4.0.0
                      293 silly fetch manifest json-schema-traverse@^1.0.0
                      294 silly fetch manifest require-from-string@^2.0.2
                      295 silly fetch manifest astral-regex@^2.0.0
                      296 http fetch GET 200 https://registry.npmjs.org/require-from-string 48ms (cache hit)
                      297 http fetch GET 200 https://registry.npmjs.org/astral-regex 47ms (cache hit)
                      298 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 54ms (cache hit)
                      299 timing idealTree:node_modules/table Completed in 78ms
                      300 timing idealTree:node_modules/lodash.truncate Completed in 0ms
                      301 timing idealTree:node_modules/text-table Completed in 0ms
                      302 timing idealTree:node_modules/thunky Completed in 0ms
                      303 timing idealTree:node_modules/tree-kill Completed in 1ms
                      304 timing idealTree:node_modules/type-check Completed in 0ms
                      305 timing idealTree:node_modules/v8-compile-cache Completed in 0ms
                      306 timing idealTree:node_modules/word-wrap Completed in 0ms
                      307 silly placeDep node_modules/@eslint/eslintrc ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                      308 timing idealTree:node_modules/@eslint/eslintrc/node_modules/debug Completed in 6ms
                      309 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 0ms
                      310 silly placeDep node_modules/@eslint/eslintrc brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
                      311 timing idealTree:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 5ms
                      312 timing idealTree:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 0ms
                      313 timing idealTree:node_modules/@eslint/eslintrc/node_modules/ms Completed in 0ms
                      314 timing idealTree:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 0ms
                      315 silly placeDep node_modules/@humanwhocodes/config-array ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                      316 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 4ms
                      317 silly placeDep node_modules/@humanwhocodes/config-array brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
                      318 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 6ms
                      319 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1ms
                      320 timing idealTree:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 0ms
                      321 timing idealTree:node_modules/argparse/node_modules/sprintf-js Completed in 0ms
                      322 timing idealTree:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 0ms
                      323 timing idealTree:node_modules/eslint/node_modules/@babel/code-frame Completed in 0ms
                      324 silly placeDep node_modules/eslint ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
                      325 timing idealTree:node_modules/eslint/node_modules/debug Completed in 5ms
                      326 timing idealTree:node_modules/eslint/node_modules/ignore Completed in 0ms
                      327 silly placeDep node_modules/eslint brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
                      328 timing idealTree:node_modules/eslint/node_modules/minimatch Completed in 6ms
                      329 timing idealTree:node_modules/eslint/node_modules/brace-expansion Completed in 0ms
                      330 timing idealTree:node_modules/eslint/node_modules/ms Completed in 0ms
                      331 timing idealTree:node_modules/eslint/node_modules/strip-json-comments Completed in 0ms
                      332 timing idealTree:node_modules/espree/node_modules/eslint-visitor-keys Completed in 0ms
                      333 timing idealTree:node_modules/esquery/node_modules/estraverse Completed in 0ms
                      334 timing idealTree:node_modules/esrecurse/node_modules/estraverse Completed in 0ms
                      335 timing idealTree:node_modules/globals/node_modules/type-fest Completed in 1ms
                      336 silly placeDep node_modules/iobroker.esphome @sentry/core@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
                      337 silly placeDep node_modules/iobroker.esphome @sentry/hub@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
                      338 silly placeDep node_modules/iobroker.esphome @sentry/types@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
                      339 silly placeDep node_modules/iobroker.esphome @sentry/utils@5.30.0 OK for: @sentry/node@5.30.0 want: 5.30.0
                      340 silly fetch manifest @sentry/minimal@5.30.0
                      341 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 32ms (cache hit)
                      342 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 79ms
                      343 silly placeDep node_modules/iobroker.esphome @sentry/minimal@5.30.0 OK for: @sentry/core@5.30.0 want: 5.30.0
                      344 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 6ms
                      345 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 0ms
                      346 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 0ms
                      347 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 0ms
                      348 timing idealTree:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 0ms
                      349 silly placeDep ROOT @leichtgewicht/ip-codec@2.0.4 OK for: dns-packet@5.6.0 want: ^2.0.1
                      350 timing idealTree:node_modules/multicast-dns/node_modules/dns-packet Completed in 8ms
                      351 timing idealTree:node_modules/@leichtgewicht/ip-codec Completed in 0ms
                      352 silly placeDep node_modules/table json-schema-traverse@1.0.0 OK for: ajv@8.12.0 want: ^1.0.0
                      353 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.12.0 want: ^2.0.2
                      354 timing idealTree:node_modules/table/node_modules/ajv Completed in 12ms
                      355 timing idealTree:node_modules/require-from-string Completed in 0ms
                      356 timing idealTree:node_modules/table/node_modules/json-schema-traverse Completed in 0ms
                      357 silly placeDep ROOT astral-regex@2.0.0 OK for: slice-ansi@4.0.0 want: ^2.0.0
                      358 timing idealTree:node_modules/table/node_modules/slice-ansi Completed in 7ms
                      359 timing idealTree:node_modules/astral-regex Completed in 0ms
                      360 timing idealTree:buildDeps Completed in 6642ms
                      361 timing idealTree:fixDepFlags Completed in 30ms
                      362 timing idealTree Completed in 10857ms
                      363 timing reify:loadTrees Completed in 10861ms
                      364 timing reify:diffTrees Completed in 104ms
                      365 silly reify mark retired [ '/opt/iobroker/node_modules/fsevents' ]
                      366 silly reify mark retired [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                      367 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.vis' ]
                      368 silly reify moves {
                      368 silly reify   '/opt/iobroker/node_modules/fsevents': '/opt/iobroker/node_modules/.fsevents-yNYMVUiI',
                      368 silly reify   '/opt/iobroker/node_modules/osx-temperature-sensor': '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv',
                      368 silly reify   '/opt/iobroker/node_modules/iobroker.vis': '/opt/iobroker/node_modules/.iobroker.vis-A3mwBQZP'
                      368 silly reify }
                      369 timing reify:retireShallow Completed in 16ms
                      370 timing reify:createSparse Completed in 41ms
                      371 timing reify:loadBundles Completed in 0ms
                      372 verbose reify failed optional dependency /opt/iobroker/node_modules/osx-temperature-sensor
                      373 silly reify mark deleted [ '/opt/iobroker/node_modules/osx-temperature-sensor' ]
                      374 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
                      375 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
                      376 timing reifyNode:node_modules/osx-temperature-sensor Completed in 56ms
                      377 timing reifyNode:node_modules/fsevents Completed in 57ms
                      378 timing reifyNode:node_modules/natural-compare Completed in 1469ms
                      379 timing reifyNode:node_modules/require-from-string Completed in 1511ms
                      380 timing reifyNode:node_modules/fast-levenshtein Completed in 1513ms
                      381 timing reifyNode:node_modules/table/node_modules/slice-ansi Completed in 1538ms
                      382 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/brace-expansion Completed in 1540ms
                      383 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/brace-expansion Completed in 1540ms
                      384 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ms Completed in 1541ms
                      385 timing reifyNode:node_modules/eslint/node_modules/brace-expansion Completed in 1540ms
                      386 timing reifyNode:node_modules/eslint/node_modules/ms Completed in 1541ms
                      387 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/ms Completed in 1545ms
                      388 timing reifyNode:node_modules/astral-regex Completed in 1562ms
                      389 timing reifyNode:node_modules/word-wrap Completed in 1561ms
                      390 timing reifyNode:node_modules/lodash.truncate Completed in 1562ms
                      391 timing reifyNode:node_modules/net Completed in 1576ms
                      392 timing reifyNode:node_modules/eslint/node_modules/strip-json-comments Completed in 1589ms
                      393 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/strip-json-comments Completed in 1592ms
                      394 timing reifyNode:node_modules/eslint/node_modules/@babel/code-frame Completed in 1592ms
                      395 timing reifyNode:node_modules/esrecurse Completed in 1628ms
                      396 timing reifyNode:node_modules/tree-kill Completed in 1644ms
                      397 timing reifyNode:node_modules/thunky Completed in 1674ms
                      398 timing reifyNode:node_modules/v8-compile-cache Completed in 1687ms
                      399 timing reifyNode:node_modules/file-entry-cache Completed in 1688ms
                      400 timing reifyNode:node_modules/@humanwhocodes/config-array Completed in 1698ms
                      401 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/minimatch Completed in 1716ms
                      402 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/minimatch Completed in 1716ms
                      403 timing reifyNode:node_modules/eslint/node_modules/minimatch Completed in 1715ms
                      404 timing reifyNode:node_modules/type-check Completed in 1738ms
                      405 timing reifyNode:node_modules/acorn-jsx Completed in 1742ms
                      406 timing reifyNode:node_modules/lodash.merge Completed in 1746ms
                      407 timing reifyNode:node_modules/@leichtgewicht/ip-codec Completed in 1778ms
                      408 timing reifyNode:node_modules/ansi-colors Completed in 1779ms
                      409 timing reifyNode:node_modules/progress Completed in 1781ms
                      410 timing reifyNode:node_modules/levn Completed in 1782ms
                      411 timing reifyNode:node_modules/eslint-visitor-keys Completed in 1784ms
                      412 timing reifyNode:node_modules/eslint-utils/node_modules/eslint-visitor-keys Completed in 1795ms
                      413 timing reifyNode:node_modules/espree/node_modules/eslint-visitor-keys Completed in 1796ms
                      414 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/debug Completed in 1793ms
                      415 timing reifyNode:node_modules/eslint/node_modules/debug Completed in 1793ms
                      416 timing reifyNode:node_modules/@humanwhocodes/config-array/node_modules/debug Completed in 1796ms
                      417 timing reifyNode:node_modules/estraverse Completed in 1810ms
                      418 timing reifyNode:node_modules/globals Completed in 1810ms
                      419 timing reifyNode:node_modules/esrecurse/node_modules/estraverse Completed in 1821ms
                      420 timing reifyNode:node_modules/esquery/node_modules/estraverse Completed in 1818ms
                      421 timing reifyNode:node_modules/deep-is Completed in 1827ms
                      422 timing reifyNode:node_modules/flat-cache Completed in 1828ms
                      423 timing reifyNode:node_modules/optionator Completed in 1829ms
                      424 timing reifyNode:node_modules/functional-red-black-tree Completed in 1830ms
                      425 timing reifyNode:node_modules/multicast-dns Completed in 1832ms
                      426 timing reifyNode:node_modules/eslint/node_modules/ignore Completed in 1835ms
                      427 timing reifyNode:node_modules/@eslint/eslintrc/node_modules/ignore Completed in 1838ms
                      428 timing reifyNode:node_modules/esutils Completed in 1879ms
                      429 timing reifyNode:node_modules/multicast-dns/node_modules/dns-packet Completed in 1885ms
                      430 timing reifyNode:node_modules/prelude-ls Completed in 1896ms
                      431 timing reifyNode:node_modules/text-table Completed in 1939ms
                      432 timing reifyNode:node_modules/espree Completed in 1938ms
                      433 timing reifyNode:node_modules/doctrine Completed in 1939ms
                      434 timing reifyNode:node_modules/flatted Completed in 1950ms
                      435 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/minimal Completed in 1953ms
                      436 timing reifyNode:node_modules/json-stable-stringify-without-jsonify Completed in 1967ms
                      437 timing reifyNode:node_modules/table/node_modules/json-schema-traverse Completed in 1977ms
                      438 timing reifyNode:node_modules/@humanwhocodes/object-schema Completed in 2000ms
                      439 timing reifyNode:node_modules/eslint-scope Completed in 2019ms
                      440 timing reifyNode:node_modules/argparse/node_modules/sprintf-js Completed in 2039ms
                      441 timing reifyNode:node_modules/regexpp Completed in 2053ms
                      442 timing reifyNode:node_modules/esprima Completed in 2076ms
                      443 timing reifyNode:node_modules/eslint-utils Completed in 2084ms
                      444 timing reifyNode:node_modules/events Completed in 2277ms
                      445 timing reifyNode:node_modules/argparse Completed in 2319ms
                      446 timing reifyNode:node_modules/@eslint/eslintrc Completed in 2330ms
                      447 timing reifyNode:node_modules/iobroker.esphome Completed in 2359ms
                      448 timing reifyNode:node_modules/globals/node_modules/type-fest Completed in 2398ms
                      449 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/hub Completed in 2525ms
                      450 timing reifyNode:node_modules/esphome-native-api Completed in 2527ms
                      451 timing reifyNode:node_modules/enquirer Completed in 2544ms
                      452 timing reifyNode:node_modules/google-protobuf Completed in 2602ms
                      453 timing reifyNode:node_modules/js-yaml Completed in 2616ms
                      454 timing reifyNode:node_modules/esquery Completed in 2617ms
                      455 timing reifyNode:node_modules/acorn Completed in 2683ms
                      456 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/core Completed in 2893ms
                      457 timing reifyNode:node_modules/table Completed in 3019ms
                      458 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/utils Completed in 3240ms
                      459 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/node Completed in 3279ms
                      460 timing reifyNode:node_modules/iobroker.esphome/node_modules/@sentry/types Completed in 3411ms
                      461 timing reifyNode:node_modules/table/node_modules/ajv Completed in 4089ms
                      462 timing reifyNode:node_modules/eslint Completed in 4128ms
                      463 timing reify:unpack Completed in 4140ms
                      464 timing reify:unretire Completed in 1ms
                      465 timing build:queue Completed in 18ms
                      466 timing build:link:node_modules/eslint Completed in 5ms
                      467 timing build:link:node_modules/acorn Completed in 9ms
                      468 timing build:link:node_modules/esprima Completed in 5ms
                      469 timing build:link:node_modules/js-yaml Completed in 5ms
                      470 timing build:link:node_modules/multicast-dns Completed in 5ms
                      471 timing build:link:node_modules/tree-kill Completed in 4ms
                      472 timing build:link Completed in 10ms
                      473 info run iobroker.esphome@0.2.4 install node_modules/iobroker.esphome npip install
                      474 info run iobroker.esphome@0.2.4 install { code: 1, signal: null }
                      475 timing reify:rollback:createSparse Completed in 487ms
                      476 timing reify:rollback:retireShallow Completed in 2ms
                      477 timing command:install Completed in 107556ms
                      478 verbose stack Error: command failed
                      478 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:53:27)
                      478 verbose stack     at ChildProcess.emit (node:events:513:28)
                      478 verbose stack     at maybeClose (node:internal/child_process:1091:16)
                      478 verbose stack     at Socket.<anonymous> (node:internal/child_process:449:11)
                      478 verbose stack     at Socket.emit (node:events:513:28)
                      478 verbose stack     at Pipe.<anonymous> (node:net:322:12)
                      479 verbose pkgid iobroker.esphome@0.2.4
                      480 verbose cwd /opt/iobroker
                      481 verbose Linux 6.1.21-v8+
                      482 verbose node v18.16.0
                      483 verbose npm  v9.5.1
                      484 error code 1
                      485 error path /opt/iobroker/node_modules/iobroker.esphome
                      486 error command failed
                      487 error command sh -c npip install
                      488 error No python_modules directory; installing pip locally if needed.
                      488 error Successfully completed pip check.
                      488 error Collecting esphome>=2021.8
                      488 error   Using cached esphome-2023.4.1-py2.py3-none-any.whl (2.6 MB)
                      488 error Collecting tornado>=3.2
                      488 error   Using cached tornado-6.3.1.tar.gz (508 kB)
                      488 error   Installing build dependencies: started
                      488 error   Installing build dependencies: finished with status 'done'
                      488 error   Getting requirements to build wheel: started
                      488 error   Getting requirements to build wheel: finished with status 'done'
                      488 error   Preparing metadata (pyproject.toml): started
                      488 error   Preparing metadata (pyproject.toml): finished with status 'done'
                      488 error Collecting voluptuous==0.13.1 (from esphome>=2021.8)
                      488 error   Using cached voluptuous-0.13.1-py3-none-any.whl (29 kB)
                      488 error Collecting PyYAML==6.0 (from esphome>=2021.8)
                      488 error   Using cached PyYAML-6.0.tar.gz (124 kB)
                      488 error Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                      488 error   Using cached paho-mqtt-1.6.1.tar.gz (99 kB)
                      488 error   Preparing metadata (setup.py): started
                      488 error   Preparing metadata (setup.py): finished with status 'done'
                      488 error Collecting colorama==0.4.6 (from esphome>=2021.8)
                      488 error   Using cached colorama-0.4.6-py2.py3-none-any.whl (25 kB)
                      488 error   Using cached tornado-6.2.tar.gz (504 kB)
                      488 error Collecting tzlocal==4.2 (from esphome>=2021.8)
                      488 error   Using cached tzlocal-4.2-py3-none-any.whl (19 kB)
                      488 error Collecting tzdata>=2021.1 (from esphome>=2021.8)
                      488 error   Using cached tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                      488 error Collecting pyserial==3.5 (from esphome>=2021.8)
                      488 error   Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
                      488 error Collecting platformio==6.1.6 (from esphome>=2021.8)
                      488 error   Using cached platformio-6.1.6.tar.gz (236 kB)
                      488 error Collecting esptool==4.5.1 (from esphome>=2021.8)
                      488 error   Using cached esptool-4.5.1.tar.gz (252 kB)
                      488 error Collecting click==8.1.3 (from esphome>=2021.8)
                      488 error   Using cached click-8.1.3-py3-none-any.whl (96 kB)
                      488 error Collecting esphome-dashboard==20230214.0 (from esphome>=2021.8)
                      488 error   Using cached esphome_dashboard-20230214.0-py3-none-any.whl (1.6 MB)
                      488 error Collecting aioesphomeapi==13.5.1 (from esphome>=2021.8)
                      488 error   Using cached aioesphomeapi-13.5.1-py2.py3-none-any.whl (54 kB)
                      488 error Collecting zeroconf==0.56.0 (from esphome>=2021.8)
                      488 error   Using cached zeroconf-0.56.0.tar.gz (140 kB)
                      488 error Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                      488 error   Using cached kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                      488 error Collecting protobuf>=3.19.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
                      488 error   Using cached protobuf-4.22.3-py3-none-any.whl (172 kB)
                      488 error Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==13.5.1->esphome>=2021.8)
                      488 error   Using cached noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                      488 error Collecting async-timeout>=4.0 (from aioesphomeapi==13.5.1->esphome>=2021.8)
                      488 error   Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                      488 error Collecting bitstring>=3.1.6 (from esptool==4.5.1->esphome>=2021.8)
                      488 error   Using cached bitstring-4.0.2-py3-none-any.whl (46 kB)
                      488 error Collecting cryptography>=2.1.4 (from esptool==4.5.1->esphome>=2021.8)
                      488 error   Using cached cryptography-40.0.2.tar.gz (625 kB)
                      488 error   Installing build dependencies: finished with status 'error'
                      489 error /usr/bin/python3: No module named pip
                      489 error /usr/bin/python3: No module named ensurepip
                      489 error ERROR: Could not install packages due to an OSError: [Errno 2] No such file or directory: '/opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/wheel-0.40.0.dist-info/INSTALLER4efqrkmn.tmp'
                      489 error
                      489 error   error: subprocess-exited-with-error
                      489 error
                      489 error   × pip subprocess to install build dependencies did not run successfully.
                      489 error   │ exit code: 1
                      489 error   ╰─> [81 lines of output]
                      489 error       Collecting setuptools!=60.9.0,>=40.6.0
                      489 error         Using cached setuptools-67.7.2-py3-none-any.whl (1.1 MB)
                      489 error       Collecting wheel
                      489 error         Using cached wheel-0.40.0-py3-none-any.whl (64 kB)
                      489 error       Collecting cffi>=1.12
                      489 error         Using cached cffi-1.15.1.tar.gz (508 kB)
                      489 error         Preparing metadata (setup.py): started
                      489 error         Preparing metadata (setup.py): finished with status 'done'
                      489 error       Collecting setuptools-rust>=0.11.4
                      489 error         Using cached setuptools_rust-1.5.2-py3-none-any.whl (23 kB)
                      489 error       Collecting pycparser (from cffi>=1.12)
                      489 error         Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
                      489 error       Collecting semantic-version<3,>=2.8.2 (from setuptools-rust>=0.11.4)
                      489 error         Using cached semantic_version-2.10.0-py2.py3-none-any.whl (15 kB)
                      489 error       Collecting typing-extensions>=3.7.4.3 (from setuptools-rust>=0.11.4)
                      489 error         Using cached typing_extensions-4.5.0-py3-none-any.whl (27 kB)
                      489 error       Building wheels for collected packages: cffi
                      489 error         Building wheel for cffi (setup.py): started
                      489 error         Building wheel for cffi (setup.py): finished with status 'error'
                      489 error
                      489 error         × python setup.py bdist_wheel did not run successfully.
                      489 error         ╰─> [50 lines of output]
                      489 error             /opt/iobroker/node_modules/iobroker.esphome/python_modules/lib/python3.9/site-packages/setuptools/config/setupcfg.py:293: _DeprecatedConfig: Deprecated config in `setup.cfg`
                      489 error             !!
                      489 error
                      489 error                     ********************************************************************************
                      489 error                     The license_file parameter is deprecated, use license_files instead.
                      489 error
                      489 error                     By 2023-Oct-30, you need to update your project and remove deprecated calls
                      489 error                     or your builds will no longer be supported.
                      489 error
                      489 error                     See https://setuptools.pypa.io/en/latest/userguide/declarative_config.html for details.
                      489 error
                      489 error             !!
                      489 error               parsed = self.parsers.get(option_name, lambda x: x)(value)
                      489 error             running bdist_wheel
                      489 error             running build
                      489 error             running build_py
                      489 error             creating build
                      489 error             creating build/lib.linux-aarch64-cpython-39
                      489 error             creating build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/lock.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/cparser.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/verifier.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/vengine_gen.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/error.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/__init__.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/model.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/pkgconfig.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/recompiler.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/api.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/ffiplatform.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/commontypes.py -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/_cffi_include.h -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/parse_c_type.h -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/_embedding.h -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-cpython-39/cffi
                      489 error             running build_ext
                      489 error             building '_cffi_backend' extension
                      489 error             creating build/temp.linux-aarch64-cpython-39
                      489 error             creating build/temp.linux-aarch64-cpython-39/c
                      489 error             arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-aarch64-cpython-39/c/_cffi_backend.o
                      489 error             c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
                      489 error                 2 | #include <Python.h>
                      489 error                   |          ^~~~~~~~~~
                      489 error             compilation terminated.
                      489 error             error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
                      489 error             [end of output]
                      489 error
                      489 error         note: This error originates from a subprocess, and is likely not a problem with pip.
                      489 error         ERROR: Failed building wheel for cffi
                      489 error         Running setup.py clean for cffi
                      489 error       Failed to build cffi
                      489 error       ERROR: Could not build wheels for cffi, which is required to install pyproject.toml-based projects
                      489 error
                      489 error
                      489 error ╰─> See above for output.
                      489 error
                      490 verbose exit 1
                      491 timing npm Completed in 107807ms
                      492 verbose unfinished npm timer reify 1682367601160
                      493 verbose unfinished npm timer reify:build 1682367616344
                      494 verbose unfinished npm timer build 1682367616349
                      495 verbose unfinished npm timer build:deps 1682367616350
                      496 verbose unfinished npm timer build:run:install 1682367616381
                      497 verbose unfinished npm timer build:run:install:node_modules/iobroker.esphome 1682367616382
                      498 verbose code 1
                      499 error A complete log of this run can be found in:
                      499 error     /home/iobroker/.npm/_logs/2023-04-24T20_20_00_942Z-debug-0.log
                      • M mayokleckz
                        0 verbose cli /usr/bin/node /usr/bin/npm
                        1 info using npm@9.5.1
                        2 info using node@v18.16.0
                        8 timing config:load:env Completed in 1ms
                        12 timing config:load:user Completed in 1ms
                        14 timing config:load:global Completed in 1ms
                        18 timing npm:load:mkdirpcache Completed in 1ms
                        19 timing npm:load:mkdirplogs Completed in 1ms
                        20 verbose title npm install iobroker.esphome@0.2.4
                        21 verbose argv "install" "--save-exact" "iobroker.esphome@0.2.4"
                        22 timing npm:load:setTitle Completed in 5ms
                        28 timing npm:load:timers Completed in 0ms
                        29 timing npm:load:configScope Completed in 0ms
                        31 timing arborist:ctor Completed in 3ms
                        32 silly logfile start cleaning logs, removing 2 files
                        33 silly logfile done cleaning log files
                        36 silly idealTree buildDeps
                        37 silly fetch manifest iobroker.esphome@0.2.4
                        38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                        40 silly placeDep ROOT iobroker.esphome@0.2.4 OK for: iobroker.inst@3.0.0 want: 0.2.4
                        41 silly fetch manifest @sentry/node@^5.30.0
                        42 silly fetch manifest esphome-native-api@^1.0.9
                        368 silly reify }
                        484 error code 1
                        489 error
                        489 error
                        489 error
                        489 error             !!
                        489 error
                        489 error
                        489 error
                        489 error
                        489 error             !!
                        489 error
                        489 error
                        489 error
                        489 error
                        490 verbose exit 1
                        498 verbose code 1
                        @mayokleckz
                        apt policy python3-full python3-pip
                          @mayokleckz
                          mayokleckz
                          flo@raspberrypi:~ $ apt policy python3-full python3-pip
                          python3-full:
                            Installed: (none)
                            Candidate: 3.9.2-3
                            Version table:
                               3.9.2-3 500
                          python3-pip:
                            Installed: 20.3.4-4+rpt1+deb11u1
                            Candidate: 20.3.4-4+rpt1+deb11u1
                            Version table:
                           *** 20.3.4-4+rpt1+deb11u1 500
                                  500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                               20.3.4-4+deb11u1 500
                          flo@raspberrypi:~ $
                          • M mayokleckz
                            python3-full:
                              Installed: (none)
                              Candidate: 3.9.2-3
                              Version table:
                                 3.9.2-3 500
                            python3-pip:
                              Version table:
                            flo@raspberrypi:~ $
                            python3-full
                            Installier das mal nach.
                            sudo apt install python3-full python3.9-dev libpython3.9-dev
                              python3-full
                              mayokleckz
                              Die Installation funktioniert nun.
                              Es war also
                              cd /opt/iobroker
                              npm i nopy
                              und
                              notwendig.
                              Danke.
                              Beim Kompilieren komme ich in einen neuen Fehler. Nach erstem suchen ein 32-bit<>64-bit os Problem?!
                              INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esphome-web-7a8069.yaml...
                              INFO Generating C++ source...
                              INFO Compiling app...
                              Processing esphome--brunnen-web-7a8069 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                              HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
                              Dependency Graph
                              |-- ESPAsyncTCP-esphome @ 1.2.3
                              |-- ESPAsyncWebServer-esphome @ 2.1.0
                              |   |-- Hash @ 1.0
                              |   |-- ESP8266WiFi @ 1.0
                              |-- DNSServer @ 1.1.1
                              |-- ESP8266mDNS @ 1.2
                              |-- noise-c @ 0.1.4
                              |   |-- libsodium @ 1.10018.1
                              Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o
                              sh: 1: xtensa-lx106-elf-g++: not found
                              Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o
                              Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o
                              *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_connection.cpp.o] Error 127
                              Compiling .pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o
                              *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
                              *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2.cpp.o] Error 127
                              *** [.pioenvs/esphome--brunnen-web-7a8069/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
                              ========================== [FAILED] Took 2.55 seconds ==========================
                              Der erste Lösungsversuch schlug schonmal fehl.
                              flo@raspberrypi:~ $ sudo apt-get install xtensa-lx106-elf
                              E: Unable to locate package xtensa-lx106-elf
                              flo@raspberrypi:~ $
                              • M mayokleckz
                                Es war also
                                cd /opt/iobroker
                                npm i nopy
                                und
                                notwendig.
                                Danke.
                                Dependency Graph
                                |   |-- Hash @ 1.0
                                |-- noise-c @ 0.1.4
                                flo@raspberrypi:~ $
                                Versuch es mit
                                sudo apt install gcc-xtensa-lx106
                                  Versuch es mit
                                  mayokleckz
                                  Das ging durch.
                                  Ich stolper trotzdem nur ahnungslos von Fehler zu Fehler.
                                  INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/esp-home-brunnen.yaml...
                                  Processing esphome-brunnen (board: d1_mini; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
                                  HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
                                  Dependency Graph
                                  |   |-- Hash @ 1.0
                                  Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o
                                  Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o
                                  xtensa-lx106-elf-g++: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
                                  Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o
                                  *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_connection.cpp.o] Error 1
                                  *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
                                  *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2.cpp.o] Error 1
                                  Compiling .pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o
                                  *** [.pioenvs/esphome-brunnen/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
                                  ========================== [FAILED] Took 2.38 seconds ==========================
                                  • M mayokleckz
                                    Das ging durch.
                                    Dependency Graph
                                    |   |-- Hash @ 1.0
                                    @mayokleckz
                                    Da fehlt dir der Cross Compiler
                                    https://packages.debian.org/search?searchon=contents&keywords=cc1plus&mode=exactfilename&suite=stable&arch=any
                                    Musst Mal schauen welcher gcc und welche Architektur da bei dir am Start ist. Danach richtet sich das zu installierende Paket.
                                    uname -m
                                    gcc --version
                                    sagt dir Näheres.
                                    Edit:
                                    Ich sehe gerade, das sollte eigentlich auch im Paket gcc-xtensa-lx106 drin sein. Dann weiß ich nicht was dem System noch fehlt.
                                      @mayokleckz
                                      uname -m
                                      gcc --version
                                      sagt dir Näheres.
                                      Edit:
                                      mayokleckz
                                      ok schade. trotzdem danke.
                                      Evtl. ließt hier noch jemand drüber und weiß weiter Rat.
                                      Ich hab mal nachgeschaut, also vorhanden scheint es zu sein.
                                      flo@raspberrypi:~ $ find /usr/ -name "*cc1*"
                                      /usr/share/terminfo/x/xterm+pcc1
                                      /usr/share/doc/libcc1-0
                                      /usr/lib/debug/.build-id/97/fca3e5a4e23a7a9dc3429293fe5f810dcc1cd6.debug
                                      /usr/lib/debug/.build-id/ac/24d09573ac4b8d5987190d274d9128cc1aeb38.debug
                                      /usr/lib/arm-linux-gnueabihf/libcc1.so.0.0.0
                                      /usr/lib/gcc/arm-linux-gnueabihf/10/cc1
                                      /usr/lib/gcc/arm-linux-gnueabihf/10/cc1plus
                                      /usr/lib/gcc/arm-linux-gnueabihf/10/libcc1.so
                                      /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so
                                      /usr/lib/gcc/arm-linux-gnueabihf/10/plugin/libcc1plugin.so.0.0.0
                                      /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1
                                      /usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus
                                      /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so
                                      /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.so.0.0.0
                                      /usr/lib/gcc/xtensa-lx106-elf/10.2.1/plugin/libcc1plugin.la
                                      flo@raspberrypi:~ $ find /usr/ -name "*execvp*"
                                      /usr/share/man/man3/execvpe.3.gz
                                      /usr/share/man/man3/execvp.3.gz
                                      flo@raspberrypi:~ $ ^C
                                      da eine Rechtevergabe schon mal geklappt hat, hab ich mal verzweifelt chmod versucht.
                                      flo@raspberrypi:~ $ sudo -u iobroker chmod a+x /usr/lib/gcc/xtensa-lx106-elf/10.2.1/c*
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/cc1plus': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/collect2': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtbegin.o': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtend.o': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crti.o': Operation not permitted
                                      chmod: changing permissions of '/usr/lib/gcc/xtensa-lx106-elf/10.2.1/crtn.o': Operation not permitted
                                      flo@raspberrypi:~ $
                                      Dann noch in die Umgebungsvariable
                                      flo@raspberrypi:~ $ export PATH=$PATH:/usr/lib/gcc/xtensa-lx106-elf/10.2.1
                                      flo@raspberrypi:~ $ $PATH
                                      -bash: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/bin/g++::/usr/lib/gcc/xtensa-lx106-elf/10.2.1:
                                      flo@raspberrypi:~ $
                                      Den Adapter auch noch mal neu installiert. Kompiliert einfach nicht.
                                      Hänge also weiter bei
                                      @mayokleckz said in ESPHome pls upgr to pio Core 6 obwohl v6.1.6 installiert:
                                      Das ging durch.
                                      Dependency Graph
                                      |   |-- Hash @ 1.0
                                      • M mayokleckz
                                        flo@raspberrypi:~ $
                                        flo@raspberrypi:~ $
                                        Das ging durch.
                                        Dependency Graph
                                        |   |-- Hash @ 1.0
                                        Schlachte dich da nicht so durch das Rechtegefüge. Das die Rechte bei per Paketmanager installierten Softwarepaketen nicht stimmen kommt nur extrem selten vor, ich würde behaupten nie. Eher fehlen da Gruppenzugehörigkeiten für die User.
                                        Gibt es da wo der Code herkommt keine Hinweise was für eine build chain benötigt wird?
                                        Edith: Gerade noch was herumgeschaut. Hab ähnliche Probleme gefunden, wenn ältere Versionen von esphome verwendet wurden.
                                        echad@chet:~ $ esphome version
                                        Version: 2023.4.1
                                        echad@chet:~ $
                                        Was spuckt das bei dir aus?
                                          Version: 2023.4.1
                                          echad@chet:~ $
                                          mayokleckz
                                          flo@raspberrypi:~ $ esphome version
                                          -bash: esphome: command not found
                                          flo@raspberrypi:~ $
                                          Welchen Code meinst du? Falls der YAML Code zum kompilieren gemeint ist, das ist die initiale yaml Datei, die vom ESPHome Adapter beim hinzufügen eines Geräts automatisch erzeugt wird.
                                          esphome:
                                          esp8266:
                                            board: d1_mini
                                          # Enable logging
                                          logger:
                                          # Enable Home Assistant API
                                          api:
                                              password: 'MyPassword'
                                          ota:
                                            password: "d960f666ab261cb6fbcd4e21b4cd9a59"
                                          wifi:
                                            ssid: !secret wifi_ssid
                                            password: !secret wifi_password
                                            # Enable fallback hotspot (captive portal) in case wifi connection fails
                                            ap:
                                              ssid: "Esphome-Brunnen Fallback Hotspot"
                                              password: "15dOCTm1PxgU"
                                          captive_portal:
