  4. Backitup und Grafana
62 Beiträge 7 Kommentatoren 10.8k Aufrufe 6 Beobachtet
  • simatecS simatec
    @thomas-braun sieht mir auch so aus. Da sind teilweise ganz alte Versionen
    @simatec
    Ja, npm>7 sollte auch eigentlich für eine andere Ausgabe bei npm ls sorgen.
      kratan75
      @simatec Meinst du den js-controller ?
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "countdown"    : 1.2.5    , installed 1.2.5
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "fronius"      : 1.1.3    , installed 1.1.3
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "kecontact"    : 1.5.2    , installed 1.5.2
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      • K kratan75
        kratan75
        @kratan75 Hier nochmal die ganze Ausgabe.
        Skript v.2023-04-02
        *** BASE SYSTEM ***
        Model : Raspberry Pi 4 Model B Rev 1.5
        Architecture : armv7l
        Docker : false
        Virtualization : none
        Distributor ID: Raspbian
        Description: Raspbian GNU/Linux 10 (buster)
        Release: 10
        Codename: buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
        15:36:22 up 19:59, 1 user, load average: 0.54, 0.64, 0.79
        CPU threads: 4
        *** Time and Time Zones ***
        Local time: Sat 2023-04-08 15:36:22 CEST
        Universal time: Sat 2023-04-08 13:36:22 UTC
        RTC time: n/a
        NTP service: active
        RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
        *** X-Server-Setup ***
        X-Server: false
        Desktop:
        Terminal: tty
        Boot Target: graphical.target
        *** MEMORY ***
        total used free shared buff/cache available
        Mem: 3.8G 1.1G 1.5G 48M 1.2G 2.9G
        Swap: 99M 0B 99M
        Total: 3.9G 1.1G 1.6G
             3838 M total memory
             1141 M used memory
              401 M active memory
             1774 M inactive memory
             1478 M free memory
              130 M buffer memory
             1088 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
        *** FILESYSTEM ***
        Filesystem Type Size Used Avail Use% Mounted on
        /dev/root ext4 30G 4.8G 24G 18% /
        devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev
        tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
        tmpfs tmpfs 1.9G 49M 1.9G 3% /run
        tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
        tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
        /dev/loop1 squashfs 99M 99M 0 100% /snap/core/14788
        /dev/loop0 squashfs 384K 384K 0 100% /snap/minicom/1
        /dev/loop2 squashfs 99M 99M 0 100% /snap/core/14950
        /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot
        tmpfs tmpfs 384M 0 384M 0% /run/user/1000
        [Fri Apr 7 19:36:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4 :5F:01:A9:73:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=t tyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=y es rootwait
        [Fri Apr 7 19:36:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Fri Apr 7 19:36:27 2023] VFS: Mounted root (ext4 filesystem) readonly on devic e 179:2.
        [Fri Apr 7 19:36:29 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET SOURCE FSTYPE OPTIONS
        / /dev/mmcblk0p2 ext4 rw,noatime
        |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode= 700
        |-/snap/core/14788 /dev/loop1 squashfs ro,nodev,relatime
        |-/snap/minicom/1 /dev/loop0 squashfs ro,nodev,relatime
        |-/snap/core/14950 /dev/loop2 squashfs ro,nodev,relatime
        `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,cod epage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.2G /var/
        510M /var/lib
        325M /var/log
        294M /var/lib/snapd
        197M /var/lib/snapd/snaps
        /opt/iobroker/backups:
        461M /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        302M /opt/iobroker/iobroker-data/
        252M /opt/iobroker/iobroker-data/files
        78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        51M /opt/iobroker/iobroker-data/files/javascript.admin
        35M /opt/iobroker/iobroker-data/backup-objects
        11M /opt/iobroker/iobroker-data/objects.jsonl
        6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c 9.chunk.js.map
        6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.j s.map
        6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js.map
        5.3M /opt/iobroker/iobroker-data/states.jsonl
        *** NodeJS-Installation ***
        /usr/bin/nodejs v14.19.3
        /usr/bin/node v14.19.3
        /usr/bin/npm 6.14.17
        /usr/bin/npx 6.14.17
        nodejs:
        Installed: 14.19.3-deb-1nodesource1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
        14.21.3-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
        *** 14.19.3-deb-1nodesource1 100
        10.24.0~dfsg-1~deb10u3 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States type: jsonl
        Core adapters versions
        js-controller: 4.0.23
        admin: 6.3.5
        javascript: 6.1.4
        npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
        Adapters from github: 5
        Adapter State
        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admi n
        • system.adapter.backitup.0 : backitup : iobroker - enabled
        • system.adapter.countdown.0 : countdown : iobroker - enabled
        • system.adapter.discovery.0 : discovery : iobroker - enabled
        • system.adapter.email.0 : email : iobroker - enabled
        • system.adapter.fronius.0 : fronius : iobroker - enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob roker - enabled
          system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled
          system.adapter.icons-material-png.0 : icons-material-png : iobroker - enabled
          system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - enabled
          system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob roker - enabled
          system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled
        • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
        • system.adapter.javascript.0 : javascript : iobroker - enabled
        • system.adapter.kecontact.0 : kecontact : iobroker - enabled
        • system.adapter.modbus.0 : modbus : iobroker - enabled
        • system.adapter.modbus.1 : modbus : iobroker - enabled
        • system.adapter.modbus.2 : modbus : iobroker - enabled
        • system.adapter.modbus.3 : modbus : iobroker - enabled
          system.adapter.openweathermap.0 : openweathermap : iobroker - enabled
        • system.adapter.ping.0 : ping : iobroker - enabled
        • system.adapter.pvforecast.0 : pvforecast : iobroker - enabled
        • system.adapter.rpi2.0 : rpi2 : iobroker - enabled
        • system.adapter.smartmeter.0 : smartmeter : iobroker - enabled
          system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled
        • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
          system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
          system.adapter.vis.0 : vis : iobroker - enabled
          system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled
        • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admi n
        • instance is alive
        ioBroker-Repositories
        stable : http://download.iobroker.net/sources-dist.json
        beta : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): stable
        Adapter "simple-api" : 2.7.2 , installed 2.7.2
        Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
        Objects and States
        Objects: 3680
        States: 3190
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 http://archive.raspbian.org/raspbian buster InRelease
        Get:4 https://repos.influxdata.com/debian buster InRelease [7029 B]
        Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
        Err:4 https://repos.influxdata.com/debian buster InRelease
        Fetched 7029 B in 2s (4352 B/s)
        Reading package lists...
        Pending Updates: 107
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
        tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18055 659/sshd
        tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 15205 652/influxd
        tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1140135 19291/iobroker.js-c
        tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1140128 19291/iobroker.js-c
        tcp6 0 0 :::8081 :::* LISTEN 1001 1141192 19309/io.admin.0
        tcp6 0 0 :::8082 :::* LISTEN 1001 1140639 19686/io.web.0
        tcp6 0 0 :::8086 :::* LISTEN 999 18118 652/influxd
        tcp6 0 0 :::22 :::* LISTEN 0 18057 659/sshd
        tcp6 0 0 :::3000 :::* LISTEN 109 16125 643/grafana-server
        udp 0 0 0.0.0.0:60833 0.0.0.0:* 108 16868 396/avahi-daemon: r
        udp 0 0 0.0.0.0:7090 0.0.0.0:* 1001 1141592 19670/io.kecontact.
        udp 0 0 0.0.0.0:7092 0.0.0.0:* 1001 1141593 19670/io.kecontact.
        udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15891 633/dhcpcd
        udp 0 0 0.0.0.0:47717 0.0.0.0:* 1001 1141594 19670/io.kecontact.
        udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 16866 396/avahi-daemon: r
        udp6 0 0 :::49312 :::* 108 16869 396/avahi-daemon: r
        udp6 0 0 :::5353 :::* 108 16867 396/avahi-daemon: r
        2023-04-08 15:34:52.440 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:34:58.571 - info: smartmeter.0 (19375) Received 13 values, 5 updated
        2023-04-08 15:35:04.644 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:10.874 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:17.246 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:23.619 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:30.126 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:36.534 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:42.060 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:47.670 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:35:53.339 - info: smartmeter.0 (19375) Received 13 values, 5 updated
        2023-04-08 15:35:59.067 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:04.617 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:10.358 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:16.341 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:22.283 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:28.263 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:34.442 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:40.609 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:47.138 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:36:54.256 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:37:00.904 - info: smartmeter.0 (19375) Received 13 values, 5 updated
        2023-04-08 15:37:07.485 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:37:16.405 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        2023-04-08 15:37:23.365 - info: smartmeter.0 (19375) Received 13 values, 6 updated
        iob diag has finished.
        • K kratan75
          Skript v.2023-04-02
          *** BASE SYSTEM ***
          Docker : false
          Release: 10
          Codename: buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          RTC time: n/a
          NTP service: active
          RTC in local TZ: no
          pi
          /home/pi
          X-Server: false
          Desktop:
          Terminal: tty
          *** MEMORY ***
          Swap: 99M 0B 99M
               3838 M total memory
               1141 M used memory
                401 M active memory
               1478 M free memory
                130 M buffer memory
               1088 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
          *** FILESYSTEM ***
          /var:
          1.2G /var/
          510M /var/lib
          325M /var/log
          294M /var/lib/snapd
          nodejs:
          Version table:
          ioBroker Status
          Objects type: jsonl
          States type: jsonl
          admin: 6.3.5
          javascript: 6.1.4
          Adapter State
          • instance is alive
          Objects and States
          Objects: 3680
          States: 3190
          kratan75
          @kratan75 Hier die NodeJS Installation. Denke die wolltet Ihr sehen.
          nodejs:
            Version table:
          K Thomas BraunT 2 Antworten Letzte Antwort
          • K kratan75
            nodejs:
              Version table:
            kratan75
            schrieb am zuletzt editiert von kratan75
            @kratan75 ```
                                 v.2023-04-02
            Operatingsystem:        Raspbian GNU/Linux 10 (buster)
            Kernel:                 5.10.103-v7l+
            Installation:           Native
            User-ID:                1000
            X-Server:               false
            Pending OS-Updates:     107
            Pending iob updates:    2
            Nodejs-Installation:    /usr/bin/nodejs         v14.19.3
            Recommended versions are nodejs 18.x.y and npm 9.x.y
            MEMORY:
            Mem:           3.8G        1.2G        1.5G         48M        1.2G        2.9G
            Swap:           99M          0B         99M
            Total:         3.9G        1.2G        1.6G
            Active iob-Instances:   20
            ioBroker Core:          js-controller           4.0.23
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                3680
            States:                 3190
            Size of iob-Database:
            6.9M    /opt/iobroker/iobroker-data/states.jsonl
            ext
            • K kratan75
              nodejs:
                Version table:
              @kratan75
              Die influxdb-Quelle muss angepackt werden.
              Dann funktionieren auch Upgrades wieder und du kannst die 107 geschluderten Upgrades einspielen.
              Und was haste da mit snapd gemacht? Vollkommen unüblich für Server.
              Dann das Ganze auf nodejs 18 bringen.
              Und zu guter Letzt den abgekündigten Buster beerdigen und Bullseye installieren.
              Das wiederum würde ich in der 64bit-Version gleich neu installieren.
                @kratan75
                kratan75
                @thomas-braun Kannst mir das bitte etwas näher erklären ?
                Vor dem Update hat ja alles noch wunderbar funktioniert.
                Wie passe ich die influxdb-Quelle an ?Die Upgrades denke ich bekomme ich mit
                sudo apt-get update
                sudo apt-get upgrade
                noch hin, aber wo passe ich zum Henker die InfluxDB Quelle an.
                Sorry, ich arbeite eigentlich fast nur mit IObroker selbst, nicht mit dem Linuxsystem dahinter.
                Gruß Andi
                • K kratan75
                  sudo apt-get update
                  Gruß Andi
                  @kratan75
                  Steht hier mit drin:
                  https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                  Der Grund für die notwendigen Anpassungen bei influxdb und grafana ist der gleiche.
                    @kratan75
                    kratan75
                    Ok Danke, ich lese mich da mal ein und probiere es aus. Ich berichte dann wieder wie es gelaufen ist.
                    Frohe Ostern
                    Gruß Andi
                    • K kratan75
                      sudo apt-get update
                      Gruß Andi
                      @kratan75 sagte in Backitup und Grafana:
                      Dann musst du das ändern. Ein wenig Systempflege ist durchaus abgebracht.
                      V 1 Antwort Letzte Antwort
                        V Offline
                        V Offline
                        vstrasser
                        @thomas-braun @simatec
                        ich häng' mich mal hier rein. Seit dem 25.3. lässt sich kein erfolgreiches Grafana Backup mehr durchführen. Ich kann leider nicht nachvollziehen, was sich zu diesem Zeitpunkt hin verändert hat. Ich tippe aber auf Adapter Updates oder System Updates.
                        Hier der (denke ich) relevante Auszug aus dem BackItUp Log im iobroker:
                        [DEBUG] [grafana] - Start Grafana Backup ...
                        [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                        [DEBUG] [grafana] - Created dashboard directory
                        [DEBUG] [grafana] - Created dashboards_manually_restore directory
                        [DEBUG] [grafana] - Created datasource directory
                        [DEBUG] [grafana] - start Grafana request ...
                        [ERROR] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http
                        [ERROR] [grafana] - Grafana is not available!
                        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                        [ERROR] [grafana] - Grafana Backup cannot created ...
                        [DEBUG] [grafana] - done
                        Hier der Output von "iob diag"
                        		     v.2023-04-02
                        Timezone: 		Europe/London (BST, +0100)
                        User-ID: 		1000
                        X-Server: 		false
                        Boot Target: 		multi-user.target
                        Pending OS-Updates: 	0
                        Pending iob updates: 	0
                        Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.1
                        			/usr/bin/node 		v16.19.1
                        			/usr/bin/npm 		8.19.3
                        			/usr/bin/npx 		8.19.3
                        MEMORY:
                        Mem:           3.8G        1.8G        577M         24M        1.5G        2.5G
                        Swap:           99M        2.0M         97M
                        Total:         3.9G        1.8G        675M
                        Active iob-Instances: 	24
                        ioBroker Core: 		js-controller 		4.0.24
                        			admin 			6.3.5
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : raspberrypiIOB                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : raspberrypiIOB                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects: 		23901
                        States: 		21127
                        26M	/opt/iobroker/iobroker-data/objects.jsonl
                        12M	/opt/iobroker/iobroker-data/objects.json.migrated
                        12M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                        27M	/opt/iobroker/iobroker-data/states.jsonl
                        3.8M	/opt/iobroker/iobroker-data/states.json.migrated
                        3.8M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                        iobroker, influxdb, grafana laufen alle auf dem gleichen Raspi. Systemupdates alle durchgeführt. Infos und Anweisungen aus diesem Thread angeschaut und durchgeführt. Ergebnis ist nach wie vor das gleiche.
                        Was kann/soll ich noch tun um das Problem zu beheben?
                        Danke und viele Grüße, Volker
                        Thomas BraunT simatecS 2 Antworten Letzte Antwort
                        • V vstrasser
                          		     v.2023-04-02
                          User-ID: 		1000
                          X-Server: 		false
                          			/usr/bin/npm 		8.19.3
                          			/usr/bin/npx 		8.19.3
                          MEMORY:
                          Swap:           99M        2.0M         97M
                          			admin 			6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		23901
                          States: 		21127
                          @vstrasser sagte in Backitup und Grafana:
                          buster
                          Muss durch 'Bullseye' ersetzt werden.
                          Mutmaßlich wohnt der ioBroker nicht in dieser Zeitzone
                          nodejs v16.19.1
                          nodejs 18 ist die derzeitige Empfehlung.
                          Zum Thema:
                          Ich würde sagen, da fehlt entweder im log was oder der Grafana-Server ist nicht richtig eingetragen.
                          • V vstrasser
                            		     v.2023-04-02
                            User-ID: 		1000
                            X-Server: 		false
                            			/usr/bin/npm 		8.19.3
                            			/usr/bin/npx 		8.19.3
                            MEMORY:
                            Swap:           99M        2.0M         97M
                            			admin 			6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		23901
                            States: 		21127
                            simatecS Online
                            simatecS Online
                            simatec
                            @vstrasser Zeige doch mal den vollständigen Debuglog vom Backup und deine Config von Backitup.
                            Mit welchem Protokoll ist Grafana erreichbar? http oder https?
                            • Besuche meine Github Seite
                            • HowTo Restore ioBroker
                            • simatecS simatec
                              V Offline
                              V Offline
                              vstrasser
                              @simatec DANKE - dein Hinweis (http / https) hat mir die Lösung gezeigt. Ich hatte im "host-feld" ein "http" vorgestellt. Frag' mich bitte nicht, warum. Nun steht wieder "nur" die IP Adresse drin und das Backup läuft erfolgreich durch.
                              viele Grüße, Volker
                                buster
                                nodejs v16.19.1
                                Zum Thema:
                                V Offline
                                V Offline
                                vstrasser
                                @thomas-braun das mit buster --> bullseye hab' ich bereits gesehen und es steht auf dem Plan. Bin noch nicht dazu gekommen. TimeZone-settings korrigiere ich. Danke. Den Update von nodejs hab' ich ebenfalls auf dem Radar. Hab's nur noch nicht hingekriegt.
                                viele Grüße, Volker
                                • V vstrasser
                                  viele Grüße, Volker
                                  simatecS Online
                                  simatecS Online
                                  simatec
                                  viele Grüße, Volker
                                  Hmmm wie kommt das da von alleine hin?
                                  Nun verstehe ich deine Frage noch weniger... Das kannst nur du eingetragen haben.
                                  • simatecS simatec
                                    viele Grüße, Volker
                                    V Offline
                                    V Offline
                                    vstrasser
                                    @simatec wie gesagt - ich weiß nicht, warum ich das http da vorgestellt hatte. War aber sicherlich mein eigener Fehler. Nun funktioniert es ja wieder. Nochmal "Danke"
                                      kratan75
                                      @thomas-braun Hallo Thomas
                                      Jetzt habe ich mal das System auf den neuesten Stand gebracht, allerdings habe ich noch Buster drauf. Das möchte ich vorerst auch nicht ändern. Nun bekomme ich aber folgende Fehlermeldung wenn ich npm list ausführe.
                                      pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ npm list
                                      npm ERR! code ELSPROBLEMS
                                      npm ERR! missing: @alcalzone/release-script-plugin-iobroker@^3.5.9, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: @alcalzone/release-script-plugin-license@^3.5.9, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: @alcalzone/release-script@^3.5.9, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: @iobroker/adapter-core@^2.6.7, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: @iobroker/testing@^4.1.0, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: chai@^4.3.7, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: express@^4.18.2, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: gulp@^4.0.2, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: mocha@^10.2.0, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: request@^2.88.2, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
                                      npm ERR! missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
                                      iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                                      ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-iobroker@^3.5.9
                                      ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-license@^3.5.9
                                      ├── UNMET DEPENDENCY @alcalzone/release-script@^3.5.9
                                      ├── UNMET DEPENDENCY @googleapis/drive@^4.0.2
                                      ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.6.7
                                      ├── UNMET DEPENDENCY @iobroker/testing@^4.1.0
                                      ├── axios@1.3.5
                                      ├── UNMET DEPENDENCY chai@^4.3.7
                                      ├── UNMET DEPENDENCY dropbox-v2-api@^2.5.10
                                      ├── UNMET DEPENDENCY express@^4.18.2
                                      ├── fs-extra@11.1.1
                                      ├── UNMET DEPENDENCY ftp@^0.3.10
                                      ├── UNMET DEPENDENCY google-auth-library@^8.7.0
                                      ├── UNMET DEPENDENCY gulp@^4.0.2
                                      ├── UNMET DEPENDENCY mocha@^10.2.0
                                      ├── node-schedule@2.1.1
                                      ├── UNMET DEPENDENCY node-wol@^0.1.1
                                      ├── UNMET DEPENDENCY onedrive-api@^1.0.7
                                      ├── UNMET DEPENDENCY request@^2.88.2
                                      ├── UNMET DEPENDENCY tar-fs@^2.1.1
                                      └── UNMET DEPENDENCY webdav@^4.11.2
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-04-14T15_06_19_781Z-debug-0.log
                                      apt update:
                                      pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ sudo apt update
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                      Hit:4 https://repos.influxdata.com/debian stable InRelease
                                      Hit:5 https://apt.grafana.com stable InRelease
                                      Hit:6 https://deb.nodesource.com/node_19.x buster InRelease
                                      Reading package lists... Done
                                      Building dependency tree
                                      All packages are up to date.
                                      pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ npm -v
                                      9.6.3
                                      pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ nodejs -v
                                      v19.9.0
                                      iob diag Ausgabe:
                                      Skript v.2023-04-02
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        10
                                      Codename:       buster
                                      VERSION_ID="10"
                                      ID=raspbian
                                      ID_LIKE=debian
                                       17:16:51 up  2:17,  1 user,  load average: 0.75, 0.43, 0.34
                                      CPU threads: 4
                                                     Local time: Fri 2023-04-14 17:16:51 CEST
                                                 Universal time: Fri 2023-04-14 15:16:51 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:           3.8G        801M        1.6G         16M        1.4G        3.0G
                                      Swap:           99M          0B         99M
                                      Total:         3.9G        801M        1.7G
                                               3838 M total memory
                                                801 M used memory
                                                494 M active memory
                                               1569 M inactive memory
                                               1588 M free memory
                                                152 M buffer memory
                                               1296 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       30G  5.2G   23G  19% /
                                      tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
                                      /dev/loop0     squashfs   99M   99M     0 100% /snap/core/14950
                                      /dev/loop2     squashfs  384K  384K     0 100% /snap/minicom/1
                                      [Fri Apr 14 14:59:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:BC:F7:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                      [Fri Apr 14 14:59:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                      [Fri Apr 14 14:59:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Fri Apr 14 14:59:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                      |-/sys/fs/bpf      none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
                                      |-/snap/core/14950 /dev/loop0     squashfs ro,nodev,relatime
                                      |-/snap/minicom/1  /dev/loop2     squashfs ro,nodev,relatime
                                      `-/boot            /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      1.1G    /var/
                                      506M    /var/lib
                                      294M    /var/lib/snapd
                                      253M    /var/log
                                      491M    /opt/iobroker/backups/
                                      298M    /opt/iobroker/iobroker-data/
                                      6.9M    /opt/iobroker/iobroker-data/objects.jsonl
                                      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                      6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                      5.1M    /opt/iobroker/iobroker-data/states.jsonl
                                      /usr/bin/nodejs         v19.9.0
                                      /usr/bin/node           v19.9.0
                                      /usr/bin/npm            9.6.3
                                      /usr/bin/npx            9.6.3
                                      nodejs:
                                        Installed: 19.9.0-deb-1nodesource1
                                        Candidate: 19.9.0-deb-1nodesource1
                                        Version table:
                                       *** 19.9.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_19.x buster/main armhf Packages
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapters from github:   0
                                      Adapter State
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                        system.adapter.fronius.0                : fronius               : iobroker                                 - disabled
                                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                                      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        system.adapter.kecontact.0              : kecontact             : iobroker                                 - disabled
                                        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
                                        system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
                                        system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
                                        system.adapter.modbus.3                 : modbus                : iobroker                                 - disabled
                                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                        system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
                                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      + instance is alive
                                      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                                      Objects and States
                                      Objects:        3685
                                      States:         3195
                                      Hit:1 http://archive.raspbian.org/raspbian buster InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18691      633/sshd
                                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16738      626/influxd
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87197      10363/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87190      10363/iobroker.js-c
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87273      10384/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       85926      10666/io.web.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16177      626/influxd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          18693      633/sshd
                                      tcp6       0      0 :::3000                 :::*                    LISTEN      109        16764      620/grafana
                                      udp        0      0 0.0.0.0:51197           0.0.0.0:*                           108        16508      372/avahi-daemon: r
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16663      618/dhcpcd
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16506      372/avahi-daemon: r
                                      udp6       0      0 :::37553                :::*                                108        16509      372/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                108        16507      372/avahi-daemon: r
                                      2023-04-14 17:15:45.097  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:15:50.051  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:15:55.104  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:00.119  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:05.074  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:10.119  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:15.097  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:20.099  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:25.091  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:30.122  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:35.068  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:40.118  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:45.093  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:50.090  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:16:55.085  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:00.099  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:05.054  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:10.084  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:15.089  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:20.088  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:27.049  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:31.218  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:35.063  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:40.090  - error: rpi2.0 (10894) GPIO is not initialized!
                                      2023-04-14 17:17:45.078  - error: rpi2.0 (10894) GPIO is not initialized!
                                      Nun gibt es die Meldung GPIO is not initialized.
                                      Die GPIO brauche ich aber dringend.
                                      Wenn ich das Backitup ausführe selbe Fehlermeldung:
                                      BackItUp:
                                      Your backup was not completely created. Please check the errors!!
                                      grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (node:events:525:35)\n at endReadableNT (node:internal/streams/readable:1359:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://localhost:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":false,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
                                      Oder ist jetzt "nodejs19" wieder zu neu ?
                                      Was zum Henker mach ich falsch ???
                                      Gruß Andi
                                      DJMarc75D Thomas BraunT 3 Antworten Letzte Antwort
                                      • K kratan75
                                        ├── axios@1.3.5
                                        ├── fs-extra@11.1.1
                                        apt update:
                                        9.6.3
                                        v19.9.0
                                        iob diag Ausgabe:
                                        Skript v.2023-04-02
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        10
                                        Codename:       buster
                                        VERSION_ID="10"
                                        ID=raspbian
                                        ID_LIKE=debian
                                        CPU threads: 4
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           99M          0B         99M
                                                 3838 M total memory
                                                  801 M used memory
                                                  494 M active memory
                                                 1588 M free memory
                                                  152 M buffer memory
                                                 1296 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        1.1G    /var/
                                        506M    /var/lib
                                        294M    /var/lib/snapd
                                        253M    /var/log
                                        /usr/bin/npm            9.6.3
                                        /usr/bin/npx            9.6.3
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        javascript:     6.1.4
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        3685
                                        States:         3195
                                        Pending Updates: 0
                                        BackItUp:
                                        Gruß Andi
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        Grund ?
                                        Lehrling seit 1975 !!!
                                        • K kratan75
                                          ├── axios@1.3.5
                                          ├── fs-extra@11.1.1
                                          apt update:
                                          9.6.3
                                          v19.9.0
                                          iob diag Ausgabe:
                                          Skript v.2023-04-02
                                          *** BASE SYSTEM ***
                                          Docker          : false
                                          Release:        10
                                          Codename:       buster
                                          VERSION_ID="10"
                                          ID=raspbian
                                          ID_LIKE=debian
                                          CPU threads: 4
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           99M          0B         99M
                                                   3838 M total memory
                                                    801 M used memory
                                                    494 M active memory
                                                   1588 M free memory
                                                    152 M buffer memory
                                                   1296 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.1G    /var/
                                          506M    /var/lib
                                          294M    /var/lib/snapd
                                          253M    /var/log
                                          /usr/bin/npm            9.6.3
                                          /usr/bin/npx            9.6.3
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        3685
                                          States:         3195
                                          Pending Updates: 0
                                          BackItUp:
                                          Gruß Andi
                                          Das wirst du ändern müssen, weil Buster das EndOfLife erreicht hat. Vor Monaten bereits.
