  4. Backitup und Grafana
62 Beiträge 7 Kommentatoren 10.8k Aufrufe 6 Beobachtet
  • K kratan75
    @kratan75 Hier nochmal die ganze Ausgabe.
    Skript v.2023-04-02
    *** BASE SYSTEM ***
    Model : Raspberry Pi 4 Model B Rev 1.5
    Architecture : armv7l
    Docker : false
    Virtualization : none
    Distributor ID: Raspbian
    Description: Raspbian GNU/Linux 10 (buster)
    Release: 10
    Codename: buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
    15:36:22 up 19:59, 1 user, load average: 0.54, 0.64, 0.79
    CPU threads: 4
    *** Time and Time Zones ***
    Local time: Sat 2023-04-08 15:36:22 CEST
    Universal time: Sat 2023-04-08 13:36:22 UTC
    RTC time: n/a
    NTP service: active
    RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Terminal: tty
    Boot Target: graphical.target
    *** MEMORY ***
    total used free shared buff/cache available
    Mem: 3.8G 1.1G 1.5G 48M 1.2G 2.9G
    Swap: 99M 0B 99M
    Total: 3.9G 1.1G 1.6G
         3838 M total memory
         1141 M used memory
          401 M active memory
         1774 M inactive memory
         1478 M free memory
          130 M buffer memory
         1088 M swap cache
           99 M total swap
            0 M used swap
           99 M free swap
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 30G 4.8G 24G 18% /
    devtmpfs devtmpfs 1.8G 0 1.8G 0% /dev
    tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
    tmpfs tmpfs 1.9G 49M 1.9G 3% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
    /dev/loop1 squashfs 99M 99M 0 100% /snap/core/14788
    /dev/loop0 squashfs 384K 384K 0 100% /snap/minicom/1
    /dev/loop2 squashfs 99M 99M 0 100% /snap/core/14950
    /dev/mmcblk0p1 vfat 253M 49M 204M 20% /boot
    tmpfs tmpfs 384M 0 384M 0% /run/user/1000
    [Fri Apr 7 19:36:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4 :5F:01:A9:73:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=t tyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=y es rootwait
    [Fri Apr 7 19:36:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Apr 7 19:36:27 2023] VFS: Mounted root (ext4 filesystem) readonly on devic e 179:2.
    [Fri Apr 7 19:36:29 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime
    |-/sys/fs/bpf none bpf rw,nosuid,nodev,noexec,relatime,mode= 700
    |-/snap/core/14788 /dev/loop1 squashfs ro,nodev,relatime
    |-/snap/minicom/1 /dev/loop0 squashfs ro,nodev,relatime
    |-/snap/core/14950 /dev/loop2 squashfs ro,nodev,relatime
    `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,cod epage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G /var/
    510M /var/lib
    325M /var/log
    294M /var/lib/snapd
    197M /var/lib/snapd/snaps
    /opt/iobroker/backups:
    461M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    302M /opt/iobroker/iobroker-data/
    252M /opt/iobroker/iobroker-data/files
    78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    51M /opt/iobroker/iobroker-data/files/javascript.admin
    35M /opt/iobroker/iobroker-data/backup-objects
    11M /opt/iobroker/iobroker-data/objects.jsonl
    6.9M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c 9.chunk.js.map
    6.6M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.j s.map
    6.3M /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_ iobr-99c23e.847b8ad9.chunk.js.map
    5.3M /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs v14.19.3
    /usr/bin/node v14.19.3
    /usr/bin/npm 6.14.17
    /usr/bin/npx 6.14.17
    nodejs:
    Installed: 14.19.3-deb-1nodesource1
    Candidate: 14.21.3-deb-1nodesource1
    Version table:
    14.21.3-deb-1nodesource1 500
    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
    *** 14.19.3-deb-1nodesource1 100
    10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Core adapters versions
    js-controller: 4.0.23
    admin: 6.3.5
    javascript: 6.1.4
    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
    Adapters from github: 5
    Adapter State
    • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admi n
    • system.adapter.backitup.0 : backitup : iobroker - enabled
    • system.adapter.countdown.0 : countdown : iobroker - enabled
    • system.adapter.discovery.0 : discovery : iobroker - enabled
    • system.adapter.email.0 : email : iobroker - enabled
    • system.adapter.fronius.0 : fronius : iobroker - enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob roker - enabled
      system.adapter.icons-icons8.0 : icons-icons8 : iobroker - enabled
      system.adapter.icons-material-png.0 : icons-material-png : iobroker - enabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - enabled
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob roker - enabled
      system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - enabled
    • system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086
    • system.adapter.javascript.0 : javascript : iobroker - enabled
    • system.adapter.kecontact.0 : kecontact : iobroker - enabled
    • system.adapter.modbus.0 : modbus : iobroker - enabled
    • system.adapter.modbus.1 : modbus : iobroker - enabled
    • system.adapter.modbus.2 : modbus : iobroker - enabled
    • system.adapter.modbus.3 : modbus : iobroker - enabled
      system.adapter.openweathermap.0 : openweathermap : iobroker - enabled
    • system.adapter.ping.0 : ping : iobroker - enabled
    • system.adapter.pvforecast.0 : pvforecast : iobroker - enabled
    • system.adapter.rpi2.0 : rpi2 : iobroker - enabled
    • system.adapter.smartmeter.0 : smartmeter : iobroker - enabled
      system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - enabled
    • system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - enabled
      system.adapter.vis.0 : vis : iobroker - enabled
      system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled
    • system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admi n
    • instance is alive
    ioBroker-Repositories
    stable : http://download.iobroker.net/sources-dist.json
    beta : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter "admin" : 6.3.5 , installed 6.3.5
    Adapter "backitup" : 2.6.16 , installed 2.6.16
    Adapter "countdown" : 1.2.5 , installed 1.2.5
    Adapter "discovery" : 3.1.0 , installed 3.1.0
    Adapter "email" : 1.1.4 , installed 1.1.4
    Adapter "fronius" : 1.1.3 , installed 1.1.3
    Adapter "i2c" : 1.2.1 , installed 1.2.1
    Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
    Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
    Adapter "icons-material-png": 0.1.0, installed 0.1.0
    Adapter "icons-mfd-png": 1.1.0 , installed 1.1.0
    Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "influxdb" : 3.2.0 , installed 3.2.0
    Adapter "javascript" : 6.1.4 , installed 6.1.4
    Controller "js-controller": 4.0.24 , installed 4.0.23 [Updatable]
    Adapter "kecontact" : 1.5.2 , installed 1.5.2
    Adapter "modbus" : 5.0.11 , installed 5.0.11
    Adapter "openweathermap": 0.3.3 , installed 0.3.3
    Adapter "ping" : 1.5.3 , installed 1.5.3
    Adapter "pvforecast" : 2.3.0 , installed 2.3.0
    Adapter "rpi2" : 1.3.2 , installed 1.3.2
    Adapter "simple-api" : 2.7.2 , installed 2.7.2
    Adapter "smartmeter" : 3.3.4 , installed 3.3.4
    Adapter "socketio" : 4.2.0 , installed 4.2.0
    Adapter "vis" : 1.4.16 , installed 1.4.15 [Updatable]
    Adapter "vis-icontwo" : 0.90.0 , installed 0.90.0
    Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "weatherunderground": 3.4.2, installed 3.4.2
    Adapter "web" : 4.3.0 , installed 4.3.0
    Adapter "ws" : 1.3.0 , installed 1.3.0
    Objects and States
    Objects: 3680
    States: 3190
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspbian.org/raspbian buster InRelease
    Get:4 https://repos.influxdata.com/debian buster InRelease [7029 B]
    Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
    Err:4 https://repos.influxdata.com/debian buster InRelease
    Fetched 7029 B in 2s (4352 B/s)
    Reading package lists...
    Pending Updates: 107
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 18055 659/sshd
    tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 15205 652/influxd
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1140135 19291/iobroker.js-c
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1140128 19291/iobroker.js-c
    tcp6 0 0 :::8081 :::* LISTEN 1001 1141192 19309/io.admin.0
    tcp6 0 0 :::8082 :::* LISTEN 1001 1140639 19686/io.web.0
    tcp6 0 0 :::8086 :::* LISTEN 999 18118 652/influxd
    tcp6 0 0 :::22 :::* LISTEN 0 18057 659/sshd
    tcp6 0 0 :::3000 :::* LISTEN 109 16125 643/grafana-server
    udp 0 0 0.0.0.0:60833 0.0.0.0:* 108 16868 396/avahi-daemon: r
    udp 0 0 0.0.0.0:7090 0.0.0.0:* 1001 1141592 19670/io.kecontact.
    udp 0 0 0.0.0.0:7092 0.0.0.0:* 1001 1141593 19670/io.kecontact.
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15891 633/dhcpcd
    udp 0 0 0.0.0.0:47717 0.0.0.0:* 1001 1141594 19670/io.kecontact.
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 16866 396/avahi-daemon: r
    udp6 0 0 :::49312 :::* 108 16869 396/avahi-daemon: r
    udp6 0 0 :::5353 :::* 108 16867 396/avahi-daemon: r
    2023-04-08 15:34:52.440 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:34:58.571 - info: smartmeter.0 (19375) Received 13 values, 5 updated
    2023-04-08 15:35:04.644 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:10.874 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:17.246 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:23.619 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:30.126 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:36.534 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:42.060 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:47.670 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:35:53.339 - info: smartmeter.0 (19375) Received 13 values, 5 updated
    2023-04-08 15:35:59.067 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:04.617 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:10.358 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:16.341 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:22.283 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:28.263 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:34.442 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:40.609 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:47.138 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:36:54.256 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:37:00.904 - info: smartmeter.0 (19375) Received 13 values, 5 updated
    2023-04-08 15:37:07.485 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:37:16.405 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    2023-04-08 15:37:23.365 - info: smartmeter.0 (19375) Received 13 values, 6 updated
    iob diag has finished.
    kratan75
    @kratan75 Hier die NodeJS Installation. Denke die wolltet Ihr sehen.
    nodejs:
      Version table:
    K Thomas BraunT 2 Antworten Letzte Antwort
    • K kratan75
      nodejs:
        Version table:
      kratan75
      schrieb am zuletzt editiert von kratan75
      @kratan75 ```
                           v.2023-04-02
      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
      Kernel:                 5.10.103-v7l+
      Installation:           Native
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     107
      Pending iob updates:    2
      Nodejs-Installation:    /usr/bin/nodejs         v14.19.3
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:           3.8G        1.2G        1.5G         48M        1.2G        2.9G
      Swap:           99M          0B         99M
      Total:         3.9G        1.2G        1.6G
      Active iob-Instances:   20
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                3680
      States:                 3190
      Size of iob-Database:
      6.9M    /opt/iobroker/iobroker-data/states.jsonl
      ext
      • K kratan75
        nodejs:
          Version table:
        @kratan75
        Die influxdb-Quelle muss angepackt werden.
        Dann funktionieren auch Upgrades wieder und du kannst die 107 geschluderten Upgrades einspielen.
        Und was haste da mit snapd gemacht? Vollkommen unüblich für Server.
        Dann das Ganze auf nodejs 18 bringen.
        Und zu guter Letzt den abgekündigten Buster beerdigen und Bullseye installieren.
        Das wiederum würde ich in der 64bit-Version gleich neu installieren.
          @kratan75
          kratan75
          @thomas-braun Kannst mir das bitte etwas näher erklären ?
          Vor dem Update hat ja alles noch wunderbar funktioniert.
          Wie passe ich die influxdb-Quelle an ?Die Upgrades denke ich bekomme ich mit
          sudo apt-get update
          sudo apt-get upgrade
          noch hin, aber wo passe ich zum Henker die InfluxDB Quelle an.
          Sorry, ich arbeite eigentlich fast nur mit IObroker selbst, nicht mit dem Linuxsystem dahinter.
          Gruß Andi
          • K kratan75
            sudo apt-get update
            Gruß Andi
            @kratan75
            Steht hier mit drin:
            https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
            Der Grund für die notwendigen Anpassungen bei influxdb und grafana ist der gleiche.
              @kratan75
              kratan75
              Ok Danke, ich lese mich da mal ein und probiere es aus. Ich berichte dann wieder wie es gelaufen ist.
              Frohe Ostern
              Gruß Andi
              • K kratan75
                sudo apt-get update
                Gruß Andi
                @kratan75 sagte in Backitup und Grafana:
                Dann musst du das ändern. Ein wenig Systempflege ist durchaus abgebracht.
                V 1 Antwort Letzte Antwort
                  V Offline
                  V Offline
                  vstrasser
                  @thomas-braun @simatec
                  ich häng' mich mal hier rein. Seit dem 25.3. lässt sich kein erfolgreiches Grafana Backup mehr durchführen. Ich kann leider nicht nachvollziehen, was sich zu diesem Zeitpunkt hin verändert hat. Ich tippe aber auf Adapter Updates oder System Updates.
                  Hier der (denke ich) relevante Auszug aus dem BackItUp Log im iobroker:
                  [DEBUG] [grafana] - Start Grafana Backup ...
                  [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                  [DEBUG] [grafana] - Created dashboard directory
                  [DEBUG] [grafana] - Created dashboards_manually_restore directory
                  [DEBUG] [grafana] - Created datasource directory
                  [DEBUG] [grafana] - start Grafana request ...
                  [ERROR] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http
                  [ERROR] [grafana] - Grafana is not available!
                  [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                  [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                  [ERROR] [grafana] - Grafana Backup cannot created ...
                  [DEBUG] [grafana] - done
                  Hier der Output von "iob diag"
                  		     v.2023-04-02
                  Timezone: 		Europe/London (BST, +0100)
                  User-ID: 		1000
                  X-Server: 		false
                  Boot Target: 		multi-user.target
                  Pending OS-Updates: 	0
                  Pending iob updates: 	0
                  Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.1
                  			/usr/bin/node 		v16.19.1
                  			/usr/bin/npm 		8.19.3
                  			/usr/bin/npx 		8.19.3
                  MEMORY:
                  Mem:           3.8G        1.8G        577M         24M        1.5G        2.5G
                  Swap:           99M        2.0M         97M
                  Total:         3.9G        1.8G        675M
                  Active iob-Instances: 	24
                  ioBroker Core: 		js-controller 		4.0.24
                  			admin 			6.3.5
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : raspberrypiIOB                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.0                    : web                   : raspberrypiIOB                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects: 		23901
                  States: 		21127
                  26M	/opt/iobroker/iobroker-data/objects.jsonl
                  12M	/opt/iobroker/iobroker-data/objects.json.migrated
                  12M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                  27M	/opt/iobroker/iobroker-data/states.jsonl
                  3.8M	/opt/iobroker/iobroker-data/states.json.migrated
                  3.8M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                  iobroker, influxdb, grafana laufen alle auf dem gleichen Raspi. Systemupdates alle durchgeführt. Infos und Anweisungen aus diesem Thread angeschaut und durchgeführt. Ergebnis ist nach wie vor das gleiche.
                  Was kann/soll ich noch tun um das Problem zu beheben?
                  Danke und viele Grüße, Volker
                  Thomas BraunT simatecS 2 Antworten Letzte Antwort
                  • V vstrasser
                    		     v.2023-04-02
                    User-ID: 		1000
                    X-Server: 		false
                    			/usr/bin/npm 		8.19.3
                    			/usr/bin/npx 		8.19.3
                    MEMORY:
                    Swap:           99M        2.0M         97M
                    			admin 			6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		23901
                    States: 		21127
                    @vstrasser sagte in Backitup und Grafana:
                    buster
                    Muss durch 'Bullseye' ersetzt werden.
                    Mutmaßlich wohnt der ioBroker nicht in dieser Zeitzone
                    nodejs v16.19.1
                    nodejs 18 ist die derzeitige Empfehlung.
                    Zum Thema:
                    Ich würde sagen, da fehlt entweder im log was oder der Grafana-Server ist nicht richtig eingetragen.
                    • V vstrasser
                      		     v.2023-04-02
                      User-ID: 		1000
                      X-Server: 		false
                      			/usr/bin/npm 		8.19.3
                      			/usr/bin/npx 		8.19.3
                      MEMORY:
                      Swap:           99M        2.0M         97M
                      			admin 			6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		23901
                      States: 		21127
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @vstrasser Zeige doch mal den vollständigen Debuglog vom Backup und deine Config von Backitup.
                      Mit welchem Protokoll ist Grafana erreichbar? http oder https?
                      • Besuche meine Github Seite
                      • HowTo Restore ioBroker
                      • simatecS simatec
                        V Offline
                        V Offline
                        vstrasser
                        @simatec DANKE - dein Hinweis (http / https) hat mir die Lösung gezeigt. Ich hatte im "host-feld" ein "http" vorgestellt. Frag' mich bitte nicht, warum. Nun steht wieder "nur" die IP Adresse drin und das Backup läuft erfolgreich durch.
                        viele Grüße, Volker
                          buster
                          nodejs v16.19.1
                          Zum Thema:
                          V Offline
                          V Offline
                          vstrasser
                          @thomas-braun das mit buster --> bullseye hab' ich bereits gesehen und es steht auf dem Plan. Bin noch nicht dazu gekommen. TimeZone-settings korrigiere ich. Danke. Den Update von nodejs hab' ich ebenfalls auf dem Radar. Hab's nur noch nicht hingekriegt.
                          viele Grüße, Volker
                          • V vstrasser
                            viele Grüße, Volker
                            simatecS Offline
                            simatecS Offline
                            simatec
                            viele Grüße, Volker
                            Hmmm wie kommt das da von alleine hin?
                            Nun verstehe ich deine Frage noch weniger... Das kannst nur du eingetragen haben.
                            • simatecS simatec
                              viele Grüße, Volker
                              V Offline
                              V Offline
                              vstrasser
                              @simatec wie gesagt - ich weiß nicht, warum ich das http da vorgestellt hatte. War aber sicherlich mein eigener Fehler. Nun funktioniert es ja wieder. Nochmal "Danke"
                                kratan75
                                @thomas-braun Hallo Thomas
                                Jetzt habe ich mal das System auf den neuesten Stand gebracht, allerdings habe ich noch Buster drauf. Das möchte ich vorerst auch nicht ändern. Nun bekomme ich aber folgende Fehlermeldung wenn ich npm list ausführe.
                                pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ npm list
                                npm ERR! code ELSPROBLEMS
                                npm ERR! missing: @alcalzone/release-script-plugin-iobroker@^3.5.9, required by iobroker.backitup@2.6.16
                                npm ERR! missing: @alcalzone/release-script-plugin-license@^3.5.9, required by iobroker.backitup@2.6.16
                                npm ERR! missing: @alcalzone/release-script@^3.5.9, required by iobroker.backitup@2.6.16
                                npm ERR! missing: @googleapis/drive@^4.0.2, required by iobroker.backitup@2.6.16
                                npm ERR! missing: @iobroker/adapter-core@^2.6.7, required by iobroker.backitup@2.6.16
                                npm ERR! missing: @iobroker/testing@^4.1.0, required by iobroker.backitup@2.6.16
                                npm ERR! missing: chai@^4.3.7, required by iobroker.backitup@2.6.16
                                npm ERR! missing: dropbox-v2-api@^2.5.10, required by iobroker.backitup@2.6.16
                                npm ERR! missing: express@^4.18.2, required by iobroker.backitup@2.6.16
                                npm ERR! missing: ftp@^0.3.10, required by iobroker.backitup@2.6.16
                                npm ERR! missing: google-auth-library@^8.7.0, required by iobroker.backitup@2.6.16
                                npm ERR! missing: gulp@^4.0.2, required by iobroker.backitup@2.6.16
                                npm ERR! missing: mocha@^10.2.0, required by iobroker.backitup@2.6.16
                                npm ERR! missing: node-wol@^0.1.1, required by iobroker.backitup@2.6.16
                                npm ERR! missing: onedrive-api@^1.0.7, required by iobroker.backitup@2.6.16
                                npm ERR! missing: request@^2.88.2, required by iobroker.backitup@2.6.16
                                npm ERR! missing: tar-fs@^2.1.1, required by iobroker.backitup@2.6.16
                                npm ERR! missing: webdav@^4.11.2, required by iobroker.backitup@2.6.16
                                iobroker.backitup@2.6.16 /opt/iobroker/node_modules/iobroker.backitup
                                ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-iobroker@^3.5.9
                                ├── UNMET DEPENDENCY @alcalzone/release-script-plugin-license@^3.5.9
                                ├── UNMET DEPENDENCY @alcalzone/release-script@^3.5.9
                                ├── UNMET DEPENDENCY @googleapis/drive@^4.0.2
                                ├── UNMET DEPENDENCY @iobroker/adapter-core@^2.6.7
                                ├── UNMET DEPENDENCY @iobroker/testing@^4.1.0
                                ├── axios@1.3.5
                                ├── UNMET DEPENDENCY chai@^4.3.7
                                ├── UNMET DEPENDENCY dropbox-v2-api@^2.5.10
                                ├── UNMET DEPENDENCY express@^4.18.2
                                ├── fs-extra@11.1.1
                                ├── UNMET DEPENDENCY ftp@^0.3.10
                                ├── UNMET DEPENDENCY google-auth-library@^8.7.0
                                ├── UNMET DEPENDENCY gulp@^4.0.2
                                ├── UNMET DEPENDENCY mocha@^10.2.0
                                ├── node-schedule@2.1.1
                                ├── UNMET DEPENDENCY node-wol@^0.1.1
                                ├── UNMET DEPENDENCY onedrive-api@^1.0.7
                                ├── UNMET DEPENDENCY request@^2.88.2
                                ├── UNMET DEPENDENCY tar-fs@^2.1.1
                                └── UNMET DEPENDENCY webdav@^4.11.2
                                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-04-14T15_06_19_781Z-debug-0.log
                                apt update:
                                pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ sudo apt update
                                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:4 https://repos.influxdata.com/debian stable InRelease
                                Hit:5 https://apt.grafana.com stable InRelease
                                Hit:6 https://deb.nodesource.com/node_19.x buster InRelease
                                Reading package lists... Done
                                Building dependency tree
                                All packages are up to date.
                                pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ npm -v
                                9.6.3
                                pi@iobroker:/opt/iobroker/node_modules/iobroker.backitup $ nodejs -v
                                v19.9.0
                                iob diag Ausgabe:
                                Skript v.2023-04-02
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        10
                                Codename:       buster
                                VERSION_ID="10"
                                ID=raspbian
                                ID_LIKE=debian
                                 17:16:51 up  2:17,  1 user,  load average: 0.75, 0.43, 0.34
                                CPU threads: 4
                                               Local time: Fri 2023-04-14 17:16:51 CEST
                                           Universal time: Fri 2023-04-14 15:16:51 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:           3.8G        801M        1.6G         16M        1.4G        3.0G
                                Swap:           99M          0B         99M
                                Total:         3.9G        801M        1.7G
                                         3838 M total memory
                                          801 M used memory
                                          494 M active memory
                                         1569 M inactive memory
                                         1588 M free memory
                                          152 M buffer memory
                                         1296 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                /dev/root      ext4       30G  5.2G   23G  19% /
                                tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
                                /dev/loop0     squashfs   99M   99M     0 100% /snap/core/14950
                                /dev/loop2     squashfs  384K  384K     0 100% /snap/minicom/1
                                [Fri Apr 14 14:59:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:BC:F7:27 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a62f624d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Fri Apr 14 14:59:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                [Fri Apr 14 14:59:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Fri Apr 14 14:59:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                |-/sys/fs/bpf      none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
                                |-/snap/core/14950 /dev/loop0     squashfs ro,nodev,relatime
                                |-/snap/minicom/1  /dev/loop2     squashfs ro,nodev,relatime
                                `-/boot            /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                1.1G    /var/
                                506M    /var/lib
                                294M    /var/lib/snapd
                                253M    /var/log
                                491M    /opt/iobroker/backups/
                                298M    /opt/iobroker/iobroker-data/
                                6.9M    /opt/iobroker/iobroker-data/objects.jsonl
                                6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
                                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                5.1M    /opt/iobroker/iobroker-data/states.jsonl
                                /usr/bin/nodejs         v19.9.0
                                /usr/bin/node           v19.9.0
                                /usr/bin/npm            9.6.3
                                /usr/bin/npx            9.6.3
                                nodejs:
                                  Installed: 19.9.0-deb-1nodesource1
                                  Candidate: 19.9.0-deb-1nodesource1
                                  Version table:
                                 *** 19.9.0-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_19.x buster/main armhf Packages
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     6.1.4
                                Adapters from github:   0
                                Adapter State
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                  system.adapter.fronius.0                : fronius               : iobroker                                 - disabled
                                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                                + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  system.adapter.kecontact.0              : kecontact             : iobroker                                 - disabled
                                  system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
                                  system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
                                  system.adapter.modbus.2                 : modbus                : iobroker                                 - disabled
                                  system.adapter.modbus.3                 : modbus                : iobroker                                 - disabled
                                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                  system.adapter.smartmeter.0             : smartmeter            : iobroker                                 - disabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                + instance is alive
                                Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
                                Objects and States
                                Objects:        3685
                                States:         3195
                                Hit:1 http://archive.raspbian.org/raspbian buster InRelease
                                Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18691      633/sshd
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        16738      626/influxd
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87197      10363/iobroker.js-c
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87190      10363/iobroker.js-c
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87273      10384/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       85926      10666/io.web.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        16177      626/influxd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          18693      633/sshd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      109        16764      620/grafana
                                udp        0      0 0.0.0.0:51197           0.0.0.0:*                           108        16508      372/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16663      618/dhcpcd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16506      372/avahi-daemon: r
                                udp6       0      0 :::37553                :::*                                108        16509      372/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        16507      372/avahi-daemon: r
                                2023-04-14 17:15:45.097  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:15:50.051  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:15:55.104  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:00.119  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:05.074  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:10.119  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:15.097  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:20.099  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:25.091  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:30.122  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:35.068  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:40.118  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:45.093  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:50.090  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:16:55.085  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:00.099  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:05.054  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:10.084  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:15.089  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:20.088  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:27.049  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:31.218  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:35.063  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:40.090  - error: rpi2.0 (10894) GPIO is not initialized!
                                2023-04-14 17:17:45.078  - error: rpi2.0 (10894) GPIO is not initialized!
                                Nun gibt es die Meldung GPIO is not initialized.
                                Die GPIO brauche ich aber dringend.
                                Wenn ich das Backitup ausführe selbe Fehlermeldung:
                                BackItUp:
                                Your backup was not completely created. Please check the errors!!
                                grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (node:events:525:35)\n at endReadableNT (node:internal/streams/readable:1359:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://localhost:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":false,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
                                Oder ist jetzt "nodejs19" wieder zu neu ?
                                Was zum Henker mach ich falsch ???
                                Gruß Andi
                                DJMarc75D Thomas BraunT 3 Antworten Letzte Antwort
                                • K kratan75
                                  ├── axios@1.3.5
                                  ├── fs-extra@11.1.1
                                  apt update:
                                  9.6.3
                                  v19.9.0
                                  iob diag Ausgabe:
                                  Skript v.2023-04-02
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        10
                                  Codename:       buster
                                  VERSION_ID="10"
                                  ID=raspbian
                                  ID_LIKE=debian
                                  CPU threads: 4
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           99M          0B         99M
                                           3838 M total memory
                                            801 M used memory
                                            494 M active memory
                                           1588 M free memory
                                            152 M buffer memory
                                           1296 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.1G    /var/
                                  506M    /var/lib
                                  294M    /var/lib/snapd
                                  253M    /var/log
                                  /usr/bin/npm            9.6.3
                                  /usr/bin/npx            9.6.3
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     6.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        3685
                                  States:         3195
                                  Pending Updates: 0
                                  BackItUp:
                                  Gruß Andi
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Grund ?
                                  Lehrling seit 1975 !!!
                                  • K kratan75
                                    ├── axios@1.3.5
                                    ├── fs-extra@11.1.1
                                    apt update:
                                    9.6.3
                                    v19.9.0
                                    iob diag Ausgabe:
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        10
                                    Codename:       buster
                                    VERSION_ID="10"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           99M          0B         99M
                                             3838 M total memory
                                              801 M used memory
                                              494 M active memory
                                             1588 M free memory
                                              152 M buffer memory
                                             1296 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.1G    /var/
                                    506M    /var/lib
                                    294M    /var/lib/snapd
                                    253M    /var/log
                                    /usr/bin/npm            9.6.3
                                    /usr/bin/npx            9.6.3
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    javascript:     6.1.4
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        3685
                                    States:         3195
                                    Pending Updates: 0
                                    BackItUp:
                                    Gruß Andi
                                    Das wirst du ändern müssen, weil Buster das EndOfLife erreicht hat. Vor Monaten bereits.
                                    • K kratan75
                                      ├── axios@1.3.5
                                      ├── fs-extra@11.1.1
                                      apt update:
                                      9.6.3
                                      v19.9.0
                                      iob diag Ausgabe:
                                      Skript v.2023-04-02
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        10
                                      Codename:       buster
                                      VERSION_ID="10"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           99M          0B         99M
                                               3838 M total memory
                                                801 M used memory
                                                494 M active memory
                                               1588 M free memory
                                                152 M buffer memory
                                               1296 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      1.1G    /var/
                                      506M    /var/lib
                                      294M    /var/lib/snapd
                                      253M    /var/log
                                      /usr/bin/npm            9.6.3
                                      /usr/bin/npx            9.6.3
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        3685
                                      States:         3195
                                      Pending Updates: 0
                                      BackItUp:
                                      Gruß Andi
                                      Ja, die derzeitige Empfehlung ist nodejs@18.
                                        kratan75
                                        @thomas-braun Geht trotzdem nicht.
                                        Hier die Ausgabe:
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v18.16.0
                                        v18.16.0
                                        9.5.1
                                        npm ERR! could not determine executable to run
                                        npm ERR!     /home/pi/.npm/_logs/2023-04-14T16_44_18_966Z-debug-0.log
                                        Copy text starting here:
                                                             v.2023-04-02
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending iob updates:    1
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
        /usr/bin/node           v18.16.0
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
                                        MEMORY:
                                        Mem:           3.8G        668M        1.7G         16M        1.5G        3.1G
                                        Swap:           99M          0B         99M
                                        Total:         3.9G        668M        1.8G
                                        Active iob-Instances:   13
        admin                   6.3.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                3685
                                        States:                 3269
                                        6.7M    /opt/iobroker/iobroker-data/objects.jsonl
                                        1.3M    /opt/iobroker/iobroker-data/states.jsonl
                                        Selbes Ergebnis:
                                        BackItUp:
                                        grafana: {"message":"Request failed with status code 401","name":"AxiosError","stack":"AxiosError: Request failed with status code 401\n at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:1898:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2950:11)\n at IncomingMessage.emit (node:events:525:35)\n at endReadableNT (node:internal/streams/readable:1359:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, /","Authorization":"Bearer ****","User-Agent":"axios/1.3.5","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.3.162:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":false,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_REQUEST","status":401}
                                        Irgendwie treibt mich das Teil noch zum Wahnsinn 👿
                                        Noch eine Idee ?
                                        Gruß Andi
                                        • K kratan75
                                          Hier die Ausgabe:
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.16.0
                                          v18.16.0
                                          9.5.1
                                                               v.2023-04-02
                                          User-ID:                1000
                                          X-Server:               false
        /usr/bin/npm            9.5.1
        /usr/bin/npx            9.5.1
                                          MEMORY:
                                          Swap:           99M          0B         99M
        admin                   6.3.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                3685
                                          States:                 3269
                                          Selbes Ergebnis:
                                          BackItUp:
                                          Noch eine Idee ?
                                          Gruß Andi
                                          Da ist nodejs auch bestimmt 'krumm' installiert, denn npx wird natülich in einer gesunden Installation gefunden.
                                          iob diag
                                          sagt? Ist natürlich nur sinnvoll in einem aktuellen System, also nicht 'buster'.
