  5. [ Gelöst ] Kamerabild aufnehmen (speichern)
19 Beiträge 5 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • I ioBrokerMike
    @emil70
    mit sudo
    pi@iobroker-pi:~ $ sudo wget –output-document /opt/iobroker/tmp/CamBild.jpeg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
    --2023-01-04 11:27:33--  http://xn--output-document-du9h/
    Resolving xn--output-document-du9h (xn--output-document-du9h)... failed: Name or service not known.
    wget: unable to resolve host address ‘xn--output-document-du9h’
    /opt/iobroker/tmp/CamBild.jpeg: Scheme missing.
    --2023-01-04 11:27:34--  http://192.168.178.200/snapshot.cgi?user=abc&pwd=
    Connecting to 192.168.178.200:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 28860 (28K) [image/jpeg]
    Saving to: ‘snapshot.cgi?user=admin&pwd=.4’
    snapshot.cgi?user=admin&pwd=.4      100%[==================================================================>]  28.18K  --.-KB/s    in 0.01s
    2023-01-04 11:27:34 (1.91 MB/s) - ‘snapshot.cgi?user=admin&pwd=.4’ saved [28860/28860]
    FINISHED --2023-01-04 11:27:34--
    Total wall clock time: 0.4s
    Downloaded: 1 files, 28K in 0.01s (1.91 MB/s)
    ohne sudo
    pi@iobroker-pi:~ $  wget –output-document /opt/iobroker/tmp/CamBild.jpeg 'http://192.168.178.200:80/snapshot.cgi?user=admin&pwd='
    --2023-01-04 11:41:03--  http://xn--output-document-du9h/
    --2023-01-04 11:41:03--  http://192.168.178.200/snapshot.cgi?user=admin&pwd=
    Length: 29192 (29K) [image/jpeg]
    Saving to: ‘snapshot.cgi?user=abc&pwd=.6’
    snapshot.cgi?user=admin&pwd=.6      100%[==================================================================>]  28.51K  --.-KB/s    in 0.01s
    2023-01-04 11:41:03 (2.00 MB/s) - ‘snapshot.cgi?user=abc&pwd=.6’ saved [29192/29192]
    FINISHED --2023-01-04 11:41:03--
    Total wall clock time: 0.1s
    Downloaded: 1 files, 29K in 0.01s (2.00 MB/s)
    @glasfaser
    Es wird kein Bild gespeichert.
    Ob es geholt wird weiß ich nicht?
    @Codierknecht
    OK, hast recht werde sie stehen lassen.
    System ist von außen ja nicht Zugänglich.
    GlasfaserG Offline
    GlasfaserG Offline
    @iobrokermike sagte in Kamerabild aufnehmen (speichern):
    Das ist auch merkwürdig ..
    geht ein :
    ping google.com
    I 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      geht ein :
      ping google.com
      I Offline
      I Offline
      ioBrokerMike
      @glasfaser sagte in Kamerabild aufnehmen (speichern):
      t auch merkwürdig
      pi@iobroker-pi:~ $ ping google.com
      PING google.com(fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e)) 56 data bytes
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=1 ttl=119 time=20.7 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=2 ttl=119 time=9.99 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=3 ttl=119 time=10.0 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=4 ttl=119 time=9.55 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=5 ttl=119 time=9.66 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=6 ttl=119 time=9.63 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=7 ttl=119 time=9.98 ms
      64 bytes from fra24s12-in-x0e.1e100.net (2a00:1450:4001:831::200e): icmp_seq=8 ttl=119 time=9.82 ms
      Mfg
      IOBrokerMike
      Achtung ! Sehkraft 25% | 60% , kein scherz
      Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
      • GlasfaserG Offline
        GlasfaserG Offline
        das ist falsch , der Bindestrich vor output !!!!
        deshalb die Meldung
        so :
        wget --output-document
        • I Offline
          I Offline
          ioBrokerMike
          @glasfaser
          deshalb die Meldung
          Leider ohne Erfolg.
          pi@iobroker-pi:~ $ sudo wget -–output-document /opt/iobroker/tmp/CamBild.jpg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
          wget: invalid option -- '▒'
          Usage: wget [OPTION]... [URL]...
          Try `wget --help' for more options.
          pi@iobroker-pi:~ $ wget -–output-document /opt/iobroker/tmp/CamBild.jpg 'http://192.168.178.200:80/snapshot.cgi?user=abc&pwd='
          Bin schon ein schwerer Fall 😊
          Mfg
          IOBrokerMike
          E GlasfaserG 2 Antworten Letzte Antwort
          • I ioBrokerMike
            @glasfaser
            deshalb die Meldung
            Leider ohne Erfolg.
            emil70
            @iobrokermike setzt mal den http teil in
            gruss emil70
            iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
            • E emil70
              I Offline
              I Offline
              ioBrokerMike
              @emil70
              Leider nichts geändert.
              pi@iobroker-pi:~ $  wget -–output-document /opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
              Mfg
              IOBrokerMike
              CodierknechtC OliverIOO 2 Antworten Letzte Antwort
              • I ioBrokerMike
                @emil70
                CodierknechtC Offline
                Codierknecht
                @iobrokermike
                Hast Du im Passwort evtl. Sonderzeichen? Könnte ein mögliches Problem sein.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • I ioBrokerMike
                  @emil70
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  ein Blick in die Doku von wget hätte hier schnell weitergeholfen.
                  die kann man in linux einfach mit
                  man wget
                  aufrufen. das in google eintippen hilft genauso weiter
                  https://linux.die.net/man/1/wget
                  unter dem Parameter -–output-document ist ersichtlich, das die Definitiopn der Datei mit einem Gleichheitszeichen angegeben wird.
                  In Linux wird jeder seperate Parameter immer mit einem Leerzeichen getrennt.
                  Wenn zu einem Parameter ein Wert gehört, dann wird meist dieser mit = zugewiesen, allerdings habe ich auch schon gesehen, das direkt ohne Leerzeichen dahinter weitergeschrieben wird.
                  wget -–output-document=/opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                  mit man <befehl> kann man sich eigentlich zu jedem shell kommando die hilfe aufrufen.
                  Meine Adapter und Widgets
                  Links im Profil
                  • OliverIOO OliverIO
                    man wget
                    I Offline
                    I Offline
                    ioBrokerMike
                    @oliverio sagte in Kamerabild aufnehmen (speichern):
                    Auch mit dem = bekomme ich kein Bild.
                    pi@iobroker-pi:~ $ wget -–output-document=/opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                    Mfg
                    IOBrokerMike
                    • I ioBrokerMike
                      @glasfaser
                      deshalb die Meldung
                      Leider ohne Erfolg.
                      GlasfaserG Offline
                      GlasfaserG Offline
                      da stimmt immer noch der -- !!!
                      der ist bei dir kurz und lang !!!!
                      siehe hier bei der Meldung die Bindestriche
                      edit :
                      so sieht der bei dir aus
                      • I ioBrokerMike
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @iobrokermike
                        ??? was ist denn jetzt [gelöst]
                        • I Offline
                          I Offline
                          ioBrokerMike
                          schrieb am zuletzt editiert von ioBrokerMike
                          Vielen Dank an euch!
                          Ihr hatte es nicht einfach mit mir.
                          Hier die Lösung : wget --output-document /opt/iobroker/tmp/CamBild.jpg "http://192.168.178.200:80/snapshot.cgi?user=abc&pwd="
                          Mfg
                          IOBrokerMike
                          • I ioBrokerMike
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @iobrokermike sagte in [ Gelöst ] Kamerabild aufnehmen (speichern):
                            Hier die Lösung
                            Der Postbote hat geklingelt ...
