  4. Test lovelace 5.x
Test lovelace 5.x
1.1k Beiträge 96 Kommentatoren 579.7k Aufrufe 78 Beobachtet
  • XBiTX Online
    XBiTX Online
    XBiT
    schrieb am zuletzt editiert von XBiT
    @Garfonso
    Bei Nutzung vom Popup (Browser_Mod) mit dem Inhalt aus einen Datenpunkt (als markdown) verabschiedet sich das Lovelace UI
    Code vom Popup
    tap_action:
     action: fire-dom-event
     browser_mod:
       service: browser_mod.popup
       data:
         title: offene Türen und Fenster
         content:
           type: markdown
           content: {0_userdata.0.Home.Status.TuerFensterKontakt.Text}
    Die Log dazu
    lovelace.0
    2022-12-04 14:04:38.005	info	http server listening on port 8091
    lovelace.0
    2022-12-04 14:04:37.971	info	starting. Version 3.0.1 (non-npm: ioBroker/ioBroker.lovelace#0113381e74ea152d1753cabcc1926ca0f6103153) in /opt/iobroker/node_modules/iobroker.lovelace, node: v16.17.0, js-controller: 4.0.23
    host.IoBroker
    2022-12-04 14:04:36.928	info	instance system.adapter.lovelace.0 started with pid 18232
    host.IoBroker
    2022-12-04 14:04:06.871	info	Restart adapter system.adapter.lovelace.0 because enabled
    host.IoBroker
    2022-12-04 14:04:06.871	error	instance system.adapter.lovelace.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.IoBroker
    2022-12-04 14:04:06.871	error	Caught by controller[0]: Unknown request: {"type":"config/area_registry/list","id":14}
    host.IoBroker
    2022-12-04 14:04:06.871	error	Caught by controller[0]: Unknown request: {"type":"config/device_registry/list","id":13}
    host.IoBroker
    2022-12-04 14:04:06.871	error	Caught by controller[0]: Unknown request: {"type":"config/entity_registry/list","id":12}
    lovelace.0
    2022-12-04 14:04:06.322	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    lovelace.0
    2022-12-04 14:04:06.322	info	terminating
    lovelace.0
    2022-12-04 14:04:06.321	info	cleaned everything up...
    lovelace.0
    2022-12-04 14:04:06.316	error	format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.316	error	TypeError: format.match is not a function at Object.extractBinding (/opt/iobroker/node_modules/iobroker.lovelace/lib/bindings.js:288:24) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2512:39) at WebSocket.emit (node:events:513:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:1178:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:528:14) at Receiver.getData (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:446:17) at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:148:22) at Receiver._write (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:83:10) at writeOrBuffer (node:internal/streams/writable:391:12)
    lovelace.0
    2022-12-04 14:04:06.316	error	unhandled promise rejection: format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.316	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0
    2022-12-04 14:04:06.315	error	format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.315	error	TypeError: format.match is not a function at Object.extractBinding (/opt/iobroker/node_modules/iobroker.lovelace/lib/bindings.js:288:24) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2512:39) at WebSocket.emit (node:events:513:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:1178:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:528:14) at Receiver.getData (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:446:17) at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:148:22) at Receiver._write (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:83:10) at writeOrBuffer (node:internal/streams/writable:391:12)
    lovelace.0
    2022-12-04 14:04:06.315	error	unhandled promise rejection: format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.315	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0
    lovelace.0
    2022-12-04 14:04:06.314	error	TypeError: format.match is not a function at Object.extractBinding (/opt/iobroker/node_modules/iobroker.lovelace/lib/bindings.js:288:24) at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2512:39) at WebSocket.emit (node:events:513:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/websocket.js:1178:20) at Receiver.emit (node:events:513:28) at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:528:14) at Receiver.getData (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:446:17) at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:148:22) at Receiver._write (/opt/iobroker/node_modules/iobroker.lovelace/node_modules/ws/lib/receiver.js:83:10) at writeOrBuffer (node:internal/streams/writable:391:12)
    lovelace.0
    2022-12-04 14:04:06.314	error	unhandled promise rejection: format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.314	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0
    2022-12-04 14:04:06.314	error	format.match is not a function
    lovelace.0
    lovelace.0
    2022-12-04 14:04:06.313	error	unhandled promise rejection: format.match is not a function
    lovelace.0
    2022-12-04 14:04:06.312	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    lovelace.0
    2022-12-04 14:03:46.266	warn	Got duplicate for entity light.LED_Arbeitsplatte_Kueche. Overwriting old value. Was for hm-rpc.0.KEQ0554490.1 and new one is for alias.0.LED Band Kueche.Switch
    lovelace.0
    2022-12-04 14:03:46.176	warn	Got duplicate for entity switch.Kamera_und_Repeater. Overwriting old value. Was for shelly.0.SHPLG-S#6EE621#1 and new one is for alias.0.Kamera_und_Repeater.Switch
    lovelace.0
    2022-12-04 14:03:43.763	info	http server listening on port 8091
    lovelace.0
    2022-12-04 14:03:43.734	info	starting. Version 3.0.1 (non-npm: ioBroker/ioBroker.lovelace#0113381e74ea152d1753cabcc1926ca0f6103153) in /opt/iobroker/node_modules/iobroker.lovelace, node: v16.17.0, js-controller: 4.0.23
    host.IoBroker
    2022-12-04 14:03:42.827	info	instance system.adapter.lovelace.0 started with pid 18212
    host.IoBroker
    2022-12-04 14:03:12.763	info	Restart adapter system.adapter.lovelace.0 because enabled
    GarfonsoG 1 Antwort Letzte Antwort
    • GarfonsoG Garfonso
      @fantasticmaxpower
      lovelace läuft aber und lokal klappt der Zugriff?
      Starte nochmal sauber bei iobroker.pro mit einem neuem Tab (oder so). Die Umleitungen (wenn ausgeloggt oder mal was nicht gehen) gehen leider manchmal schief für lovelace.
      fantasticmaxpowerF Offline
      fantasticmaxpower
      @garfonso hatte ich alles schon probiert. Es geht wieder. Habe mir heute ne Remote Jahreslizenz gegönnt und den App Key neu generiert, Nu geht's wieda.
      Habe heute auch Mal auf Version 3. stabile geupdatet. Wahnsinn was sich in der letzten Zeit alles am Adapter getan hat! Die Frontendkonfiguration funktioniert erste Sahne, auch im Code Editor.
      1000 Dank an Dich und alle Mitwirkenden!
      • fantasticmaxpowerF fantasticmaxpower
        Banis
        ich leider Probleme mit der ApexChart Card und im Offiziellen Forum konnte mir niemand weiterhelfen. Vielleicht werden die Probleme ja von der iobroker Variante von Lovelace verursacht. Deshalb probiere ich es jetzt hier.
        Bei untenstehende Balkendiagramm werden unterschiedliche Werte angezeigt abhängig davon ob ich im normal Modus oder im "Konfigurations Modus" (also "Benutzeroberfläche konfigurieren") bin. Die korrekten Werte werden leider nur im Konfigurtions Modus angezeigt. Hier mal ein aktuelles Beispiel: links passt alles, rechts sind die Werte oben und die Balken falsch.
        Hab zwischenzeitliche festgestellt, dass wenn ich den Browser-Catche die Werte bis zum nächsten Tag wieder passen. Gleiches auch wenn ich einen anderen Brwoser verwende.
        Hat jemand eine Idee wie ich das Problem beheben kann?
          M1R0O
          ich bekomme seit kurzer Zeit alle 10 Sekunden folgende Fehlermeldung:
          ![46b5efad-72d2-4db8-9087-3488848ee302-image.png](/assets/uploads/files/1671653052487-46b5efad-72d2-4db8-9087-3488848ee302-image.png) code_text
          ```No device ID in browser_mod request: {"type":"browser_mod/update","deviceID":"0cde9593-54af69fa","data":{"browser":{"path":"/lovelace/home","visibility":"visible","userAgent":"Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/86.0.4240.197 Safari/537.36","currentUser":"admin","fullyKiosk":false,"width":1920,"height":1080,"battery_level":100,"charging":true,"darkMode":false,"userData":{"id":"system.user.admin","name":"admin","is_owner":true,"is_admin":true,"credentials":[{"auth_provider_type":"iobroker","auth_provider_id":null}],"mfa_modules":[{"id":"totp","name":"Authenticator app","enabled":false}]}}},"id":45923}
          Eine Browser_mod habe ich nicht installiert.
          Was muss ich tun?
          Danke!
          • L Offline
            lessthanmore
            Hat jemand lovelace 3.x zufällig mit fully browser im Einsatz?
            Seit dem lovelace upgrade wird fully mit der Zeit extrem langsam und reagiert irgendwann gar nicht mehr. Die App geht dann am Tablet aus (Fire HD).
            Unter Objekten laufen die Einträge unter „instances“ schon nach kurzer Zeit über (250+ nach kurzer Zeit).
            • L lessthanmore
              lobomauL Offline
              lobomauL Offline
              lobomau
              @lessthanmore ich habe das so im Einsatz.
              Ich bin aber ganz neu mit lovelace dabei und es ist noch sehr simpel aufgebaut.
              Da läuft es noch super flüssig und wird auch nicht langsamer nach der Zeit.
              Mit Vis hatte ich die Probleme, dass es träge wurde nach kurzer Zeit.
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
              nukleuzN 1 Antwort Letzte Antwort
              • JB1985J Offline
                JB1985J Offline
                JB1985
                ich nutze die Tesla-solar Card. Weiß jemand, wie man die Richtung des Flusses beeinflussen kann?
                Die Flussrichtung zum Netz ist bei mir falsch.
                Minus ist bei mir der Verkauf, dass bedeutet der blaue Punkt müsste Richtung Netz fliesen. Wenn ich Strom vom Netz bekomme, + und der Ball sollte in Richtig Haus gehen.
                Bei mir ist es momentan genau andersrum.
                Weiß jemand wie man das ändern kann?
                C 1 Antwort Letzte Antwort
                • JB1985J JB1985
                  Carsten1210
                  @jb1985
                  Schau dir doch mal die Power Flow Card an: https://github.com/ulic75/power-flow-card.
                  Die sieht ähnlich aus und kann bei der Werten auch invertieren.
                  Gruss, Carsten
                  JB1985J 1 Antwort Letzte Antwort
                  • C Carsten1210
                    @jb1985
                    Gruss, Carsten
                    JB1985J Offline
                    JB1985J Offline
                    JB1985
                    @carsten1210 Danke! Die Card scheint echt besser zu sein.
                    • David G.D Online
                      David G.D Online
                      David G.
                      Hey,
                      hat jmd von euch die dual-gauge Card erfolgreich am laufen?
                      Bei mit wird sie fehlerhaft dargestellt.
                      Würde gerne 2 Werte zusammen darstellen.
                      2 Wagerechte Linien über- oder untereinander würden auch gehen.
                      Die custom Bar chart sieht auch ganz gut aus.
                      Glaube aber, da kann man keine 2 entities in einen "Balken" machen.
                      2x untereinander sieht mit einem Abstand sieht mir nicht zusammenhängend genug aus.
                      • David G.D David G.
                        Hey,
                        nukleuzN Offline
                        nukleuzN Offline
                        nukleuz
                        @david-g
                        Jupp, läuft bei mir… Schicke dir später den Code - hier liegt gerade ein Wurm auf mir 👶
                        Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                        • lobomauL lobomau
                          nukleuzN Offline
                          nukleuzN Offline
                          nukleuz
                          @lobomau
                          Bei Lovelace UI konnte ich das bisher nur beim Einsatz von der custom apexchart card feststellen… Das Rendern dauert bei teilweise mehreren tausenden Werten etwas länger… Du hast also noch Luft 😎
                          • nukleuzN nukleuz
                            @david-g
                            David G.D Online
                            David G.D Online
                            David G.
                            @nukleuz
                            Danke,
                            so siehts bei mir aus.
                            Ist noch ein Test. Beschriftungen etc stimmen nicht.
                            type: custom:dual-gauge-card
                            title: Download
                            min: 0
                            max: 100
                            outer:
                              entity: input_number.Netzwerk_Internet_Speedtest_Download_MBit
                              attribute: current_temperature
                              label: Current
                              unit: °C
                            inner:
                              entity: input_number.Netzwerk_Internet_Modem_Download_aktuell
                              label: Target
                              attribute: temperature
                              unit: °C
                            colors:
                              - color: var(--label-badge-red)
                                value: 27.5
                              - color: var(--label-badge-green)
                                value: 25
                              - color: var(--label-badge-yellow)
                                value: 18
                              - color: var(--label-badge-blue)
                                value: 0
                              - color: var(--paper-blue-400)
                                value: -40
                            Edit:
                            Mein Wurm wird jetzt geweckt. Lang genug geschlafen ^^.
                            nukleuzN 2 Antworten Letzte Antwort
                              @nukleuz
                              Danke,
                              title: Download
                              min: 0
                              max: 100
                              outer:
                                label: Current
                                unit: °C
                              inner:
                                label: Target
                                unit: °C
                              colors:
                                  value: 27.5
                                  value: 25
                                  value: 18
                                  value: 0
                                  value: -40
                              Edit:
                              nukleuzN Offline
                              nukleuzN Offline
                              nukleuz
                              @david-g
                              title: Luftfeuchte
                              min: 0
                              max: 100
                              outer:
                                entity: sensor.Kellereingang_ESPHome_SHT31_D_Humidity
                                label: Aussen
                                unit: '%'
                              inner:
                                entity: sensor.Terrasse_Klima_Humidity
                                label: Keller
                                unit: '%'
                              colors:
                                - color: var(--label-badge-pink)
                                  value: 90
                                  value: 70
                                  value: 30
                                  value: 0
                              Ich kann dir aktuell nicht sagen, welche Version der Card im Einsatz ist - das war eine der ersten und nie aktualisiert...
                                @nukleuz
                                Danke,
                                title: Download
                                min: 0
                                max: 100
                                outer:
                                  label: Current
                                  unit: °C
                                inner:
                                  label: Target
                                  unit: °C
                                colors:
                                    value: 27.5
                                    value: 25
                                    value: 18
                                    value: 0
                                    value: -40
                                Edit:
                                nukleuzN Offline
                                nukleuzN Offline
                                nukleuz
                                @david-g
                                lediglich die unit ist in Anführungszeichen und ich habe kein attribute...
                                • nukleuzN nukleuz
                                  @david-g
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @nukleuz
                                  Danke,
                                  probiere ich nachher auch mal aus.
                                  Wobei mir grad in den Kopf kommt, dass ich die Farben zumindest nie absichtlich im Theme angegeben habe. Evtl sind die als Standart nicht drinnen....
                                  EDIT
                                  Funzt jetzt.
                                  Durfte keine input_number sein (hatte ich noch zum testen, da ich die Zahlen noch manchmal in der Visu zum probieren geändert habe). Jetzt als sensor geht es. Die anderen Karten hatten alle den input_number genommen.
                                  • nukleuzN nukleuz
                                    @david-g
                                    title: Luftfeuchte
                                    min: 0
                                    max: 100
                                    outer:
                                      label: Aussen
                                      unit: '%'
                                    inner:
                                      label: Keller
                                      unit: '%'
                                    colors:
                                        value: 90
                                        value: 70
                                        value: 30
                                        value: 0
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    @nukleuz
                                    So siehts jetzt aus (Farben muss ich noch anpassen).
                                    Ganz zufrieden bin ich noch nicht.
                                    Falls jemand also noch eine Idee hat für die dual-gauge,bitte her damit 🤣.
                                    Sollte eben nebeneinander mit 2 Karten noch gut aussehen.
                                    EDIT
                                    Oben ist der Vorgänger der Karte. Da gab es noch keine Werte für die aktuelle Auslastung der Leitung.
                                    • XBiTX Online
                                      XBiTX Online
                                      XBiT
                                      #66
                                      etwas OT....
                                      ob was mit @Garfonso passiert ist? er ist schon 1 Monat nicht online gewesen im Forum... sonst meldet er sich ja immer zu den aufkommenden Fragen.
                                      • XBiTX XBiT
                                        etwas OT....
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #67
                                        @xbit
                                        Ob du es glaubst oder nicht.
                                        Genau das habe ich mich heute auch gefragt......
                                          @xbit
                                          #68
                                          @david-g in telegram ist er aktiv also denke ich ihn geht gut 🤠
