  4. Anfrage Tahoma/Somfy IO Adapter
611 Beiträge 103 Kommentatoren 306.3k Aufrufe 86 Beobachtet
  • W Willi-Wunder
    @memme
    Hast du deine Tahoma auch mal komplett stromlos gemacht? Daran lag es das letzte mal bei mir......Reboot hat nicht ausgereicht. Entwicklermodus ist in der Box auch aktiviert?
    Meine Einstellungen sind anders:
    Hab die V0.8.0
    Verzögerung zwischen den Anmeldeversuchen 60 sek.
    Verzögerung nach fehlgeschlagener Anmeldung 200 sek.
    Verzögerung vor dem erneuten Versuch der Apply-Warteschlange (Millisekunden) 500000
    Abrufintervall 500000
    Meine Fehlermeldung im Log ist:
    tahoma.0
    	2022-12-11 13:19:37.326	warn	Body: {"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"}
    tahoma.0
    	2022-12-11 13:19:37.325	warn	Response: {"statusCode":400,"body":{"error":"\"No registered event listener.\"","errorCode":"UNSPECIFIED_ERROR"},"headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"77","connection":"close","date":"Sun, 11 Dec 2022 12:19:37 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-xxxx-xxxx-xxxx:8443","port":"8443","hostname":"gateway-xxxx-xxxx-xxxx","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch","path":"/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch","href":"https://gateway-xxxx-xxxx-xxxx:8443/enduser-mobile-web/1/enduserAPI/events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 6263c4b71f21561a9245","Content-type":"application/json","accept":"application/json","content-length":2}}}
    tahoma.0
    	2022-12-11 13:19:37.325	warn	error during request: null, request path: events/f8338c7f-113b-4707-9f0d-c5e7c76f9533/fetch with payload:{}
    Läuft aber alles :-)
    memme
    #410
    @willi-wunder
    Stromlos gerade erst gestern gemacht.
    Entwicklermodus muss ja an sein, da ich sonst ja keinen key hätte und dann würde ja gar nichts funktionieren.
    Apply Warteschlange von 500s macht doch null sinn, wenn er nach knapp 10 minuten nen retry macht......
      mrniceguy
      #411
      Am 6.12 wurde meine Tahoma Switch Box upgedated. Seit dem konnte sich der Adapter nicht mehr über dielokale Api verbinden. Ess wurde immer versucht, die Verbindung mit dem alten Bearer Token aufzubauen, dieser war aber nicht mehr gültig. Erst nachdem ich den kompletten Adapter gelöscht und wieder neu installiert hatte, wurde ein neuer Token generiert und der Zugriff war wieder möglich.
      • M mrniceguy
        memme
        #412
        @mrniceguy es funktioniert ja ein paar mal und dann arbeitet der adapter die queue nicht mehr ab.
        habe nun die lokale api raus gelöscht. seit dem ist ein kleiner delay, aber zumindest kommen die befehle stabil an
        • M memme
          memme
          #413
          @memme
          Nach einem Tag kommen auch hier Fehler und mein Somfy account wird temp. gesperrt: Too many asynchronous jobs, try again later (job was Full refresh all states
          tahoma.0
          	16628	2022-12-14 08:01:54.608	info	eventRegisterID = 0f70bdb7-98e4-e192-5738-df83b686cc19
          tahoma.0
          	16628	2022-12-14 08:01:45.273	warn	refresh device state failed: Error - true data: {"statusCode":400,"body":"{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}","headers":{"date":"Wed, 14 Dec 2022 07:01:55 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains, max-age=31536000 ; includeSubDomains","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","x-xss-protection":"1; mode=block","x-frame-options":"DENY","x-content-type-options":"nosniff","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","cookie":"JSESSIONID=A655650992623BF926730CD5836CDBD5","content-length":0}}}
          tahoma.0
          	16628	2022-12-14 08:01:45.273	warn	Body: "{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}"
          tahoma.0
          	16628	2022-12-14 08:01:45.272	warn	Response: {"statusCode":400,"body":"{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}","headers":{"date":"Wed, 14 Dec 2022 07:01:55 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains, max-age=31536000 ; includeSubDomains","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","x-xss-protection":"1; mode=block","x-frame-options":"DENY","x-content-type-options":"nosniff","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","cookie":"JSESSIONID=A655650992623BF926730CD5836CDBD5","content-length":0}}}
          tahoma.0
          	16628	2022-12-14 08:01:45.272	warn	error during request: null, request path: setup/devices/states/refresh with payload:null
          tahoma.0
          	16628	2022-12-14 08:00:54.617	warn	refresh device state failed: Error - true data: {"statusCode":400,"body":"{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}","headers":{"date":"Wed, 14 Dec 2022 07:01:04 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains, max-age=31536000 ; includeSubDomains","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","x-xss-protection":"1; mode=block","x-frame-options":"DENY","x-content-type-options":"nosniff","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","cookie":"JSESSIONID=1745203EB914CDDD897B722C7E410073","content-length":0}}}
          tahoma.0
          	16628	2022-12-14 08:00:54.616	warn	Body: "{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}"
          tahoma.0
          	16628	2022-12-14 08:00:54.616	warn	Response: {"statusCode":400,"body":"{\"errorCode\":\"TOO_MANY_OPERATIONS_IN_PROGRESS\",\"error\":\"Too many asynchronous jobs, try again later (job was Full refresh all states)\"}","headers":{"date":"Wed, 14 Dec 2022 07:01:04 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains, max-age=31536000 ; includeSubDomains","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","x-xss-protection":"1; mode=block","x-frame-options":"DENY","x-content-type-options":"nosniff","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI/setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI/setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","cookie":"JSESSIONID=1745203EB914CDDD897B722C7E410073","content-length":0}}}
          tahoma.0
          	16628	2022-12-14 08:00:54.601	warn	error during request: null, request path: setup/devices/states/refresh with payload:null
            Murphys234d
            #414
            @mrniceguy War bei mir das gleiche. Instanz löschen und Neuanlegen hat dann geholfen.
            Hatte testweise eine zweite Instanz angelegt und da er sich dort verbinden konnte, war die Sache klar.
            • O Offline
              O Offline
              oxident
              #415
              Interessanter Adapter!
              Wisst ihr, ob er prinzipiell auch mit einem "gebrandeten" Account, also einer Somfy-Box von Atlantic funktionieren könnte?
              Soweit ich weiß würde es da eventuell über die REST-API bei https://ha110-1.overkiz.com/enduser-mobile-web/enduserAPI/ laufen...
              • M Murphys234d
                slobo
                #416
                @murphys234d
                Hallo hab das selbe Problem mit dem Tahoma Adapter, die Temperatur lässt sich nicht Steuern die selben Fehler wie der @memme gepostet hat.
                Hab schon Instanz gelöscht und neue angelegt aber hilft nicht gibts vielleicht noch andere Lösungen?
                • S slobo
                  @murphys234d
                  Murphys234d
                  #417
                  @slobo kann ich dir leider nicht helfen. Den Fehler kenne ich nicht.
                  • D Dakusk
                    @dakusk
                    Okay Problem selber gelöst bekommen. Tatsächlich hat mein System die etc/hosts nach jedem reboot überschrieben.
                    Jetzt tauchen wieder die Fehler wie vor der Neuinstallation auf.
                    2022-05-23 21:57:01.002 - warn: tahoma.1 (464) error during request: null, request path: history/executions/82cdf30b-51e7-497b-9116-03438574b3a2 with payload:{}
                    2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:00 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1208-2847-9785.local:8443","port":"8443","hostname":"gateway-1208-2847-9785.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2","path":"/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/82cdf30b-51e7-497b-9116-03438574b3a2"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                    2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                    2022-05-23 21:57:01.003 - warn: tahoma.1 (464) Failed getting execution state for 82cdf30b-51e7-497b-9116-03438574b3a2
                    2022-05-23 21:57:01.016 - warn: tahoma.1 (464) error during request: null, request path: history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38 with payload:{}
                    2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:00 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38","path":"/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/65fba7f7-33a6-4d47-9704-b353af2fed38"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                    2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                    2022-05-23 21:57:01.016 - warn: tahoma.1 (464) Failed getting execution state for 65fba7f7-33a6-4d47-9704-b353af2fed38
                    2022-05-23 21:57:01.031 - warn: tahoma.1 (464) error during request: null, request path: history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3 with payload:{}
                    2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:01 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3","path":"/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                    2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                    2022-05-23 21:57:01.032 - warn: tahoma.1 (464) Failed getting execution state for b41a285c-0a9b-4a6d-8b66-c7f0c1420fc3
                    2022-05-23 21:57:15.963 - warn: tahoma.1 (464) error during request: null, request path: history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15 with payload:{}
                    2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Response: {"statusCode":400,"body":"{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}","headers":{"content-type":"application/json","access-control-allow-origin":"*","access-control-allow-headers":"Authorization","content-length":"59","connection":"close","date":"Mon, 23 May 2022 21:57:15 GMT","server":"KizOs"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"gateway-1XXX-2XXX-9XXX.local:8443","port":"8443","hostname":"gateway-1XXX-2XXX-9XXX.local","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15","path":"/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15","href":"https://gateway-1XXX-2XXX-9XXX.local:8443/enduser-mobile-web/1/enduserAPI/history/executions/5787ffbb-1245-408b-b093-e962a0dd9d15"},"method":"GET","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0","Authorization":"Bearer 627788a7e67b661cc13a","Content-type":"application/json"}}}
                    2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Body: "{\"error\":\"Unknown object.\",\"errorCode\":\"UNSPECIFIED_ERROR\"}"
                    2022-05-23 21:57:15.963 - warn: tahoma.1 (464) Failed getting execution state for 5787ffbb-1245-408b-b093-e962a0dd9d15
                    slobo
                    #418
                    @dakusk Wie hast du das Problem gelöst ? danke
                    • K kassmann
                      @memme wir haben 5 Jalousien/Rollläden, vier Velux Fenster, eine Markise und diverse Sensoren im Einsatz. Diese fahren täglich durch unsere „Beschattungs-Blockly“ rauf und runter, auf und zu, je nachdem was der Tag und das Licht so bringen. Direkt hintereinander auf, zu, auf, usw. habe ich nicht getestet, aber eben täglich diverse Stellungen und die laufen ohne Probleme seit lokaler API.
                      Wir haben die v0.9.0 im Einsatz.
                      psimon
                      schrieb am zuletzt editiert von psimon
                      #419
                      @kassmann said in Anfrage Tahoma/Somfy IO Adapter:
                      @memme wir haben ... vier Velux Fenster ... im Einsatz.
                      kannst du die Velux Fenster über den Tahoma Switch und ioBroker auch öffnen? Das geht ja in ioBroker mit dem Velux Adapter nicht da man ja den Code braucht den man nirgends hinterlegen kann. Mit dem KLF-200 soll es zwar gehen aber irgendwie nur mit alter Firmware usw. Das ist mir aber dann doch zu unsicher ob das wirklich so noch klappt.
                      Jetzt bin ich auf 2 Lösungsansätze gestoßen.
                      1. Variante - Apple Homekit irgendwie per Python mit ioBroker und Velux verknüpfen, wäre prinzipiell möglich da ich einen Apple TV habe der als Homekit Zentrale dienen könnte, da blicke ich mich aber bei der Installation überhaupt nicht durch. Außerdem schein die Anleitung ziemlich alt zu sein, also keine Ahnung ob das mit den aktuellen Versionen und der Vaktuellen Firmware noch klappt.
                      2. Variante - Velux Schalter (KLI 310) im Tahoma Switch einbinden und diesen dann in ioBroker einbinden. Und da stellt sich jetzt die Frage ob man hier beim öffnen der Fenster dann auch den Velux Code braucht, denn dann macht es für mich keinen Sinn. Will nur nicht umsonst 200 Euro raushauen.
                      Vielleicht hast du ja ein paar Infos für mich.
                      Danke und LG
                      Patrick
                      • W Offline
                        W Offline
                        Willi-Wunder
                        #420
                        habe nun meine Somfy Premium Box durch meine Switch Box ablösen wollen.
                        Entwicklermodus ist auch hier aktiviert, mit der normalen Anmeldung läuft sie auch ohne Fehler. Wollte nun auch wie in der Premium Box die Lokale API einstellen. Sobald ich die PIN eintrage kommt im Log folgendes:
                        tahoma.0
                        2022-12-30 11:56:57.361 warn error during request: Unauthorized ->401 retry setup
                        Habe die Box bereits stromlos gemacht, paar Stunden vom Netzt getrennt, Lokale API geht aber nicht.
                        Bearer Token wird aber laut Log benutzt:
                        Using stored bearer token 6263c4b71f21561xxxxx
                        Bei der Premium Box hat es noch geklappt. Jemand noch eine Idee?
                        Gruß Willi
                        • W Willi-Wunder
                          tahoma.0
                          Gruß Willi
                          Murphys234d
                          schrieb am zuletzt editiert von Murphys234d
                          #421
                          @willi-wunder instanz löschen und neu anlegen schon einmal probiert? Eventuell ist es noch das Token der premium.
                          Alternativ, kannst du auch schnell zum Prüfen eine zweite Instanz anlegen.
                          Nach dem Löschen werden - soweit meine Erfahrung damit - die Datenpunkte genau so wiederhergestellt, ein vorheriges Backup schadet aber nie.
                          W 1 Antwort Letzte Antwort
                          • M Murphys234d
                            W Offline
                            W Offline
                            Willi-Wunder
                            schrieb am zuletzt editiert von Willi-Wunder
                            #422
                            @murphys234d
                            Vielen Dank für deinen Tipp. 👍 Er verwendet tatsächlich noch den Bearer Token von der ersten Box, hatte ich jetzt mal verglichen.
                            Adapter hatte ich zuvor bereits gelöscht gehabt, er legt zwar die neue PIN an, nimmt aber den alten Token. Erst bei einer neuen Instanz nimmt er einen neuen Token. Bei der zweiten Insztanz passen dann meine Befehle für Telegram nicht mehr, daher wollte ich die erste Instanz behalten. Kann man irgendwie den Token aus der Instanz 1 löschen?
                            Ansonsten muss ich die Befehle für Telegram auf die zweite Instanz anpassen.
                            • W Willi-Wunder
                              @murphys234d
                              blackeagle998
                              schrieb am zuletzt editiert von blackeagle998
                              #423
                              @willi-wunder
                              Ich mache das per Skript:
                              function resetBearerToken(){
                                  if (getState('system.adapter.tahoma.0.alive').val == true){setState('system.adapter.tahoma.0.alive', false);}
                                  extendObject('system.adapter.tahoma.0', {native: {bearer_token: ''}});
                                  setTimeout(function(){
                                      setState('system.adapter.tahoma.0.alive', true);
                                  },5000);
                              Jedes Mal wenn ich die LAN Netzwerkverbindung der BOX kappe und neu verbinde, muss ich den Token löschen, damit die Box wieder sauber arbeitet. Wenn man weiß wie und eine Funktion dafür hat, ist es nur ein Knopfdruck, das war's.
                              • B blackeagle998
                                @willi-wunder
                                    },5000);
                                W Offline
                                W Offline
                                Willi-Wunder
                                #424
                                @blackeagle998
                                Hi, vielen Dank für das Skript. Habe es angelegt und ausgeführt und danach den Tahoma Adapter gestartet. Anmeldung klappt Lokal aber immer noch nicht, gleiche Fehlermeldung.
                                Muss ich nochmal die alte Box anstecken um diesen Token zu löschen? Oder habe ich da etwas falsch verstanden?
                                Gruß Willi
                                • W Willi-Wunder
                                  @blackeagle998
                                  Gruß Willi
                                  blackeagle998
                                  #425
                                  @willi-wunder
                                  Was dafür der korrekte Lösungsweg ist, weiß ich nicht.
                                  Den Fehler hatte ich aber auch und folgendes führte zum Erfolg.
                                  1. Instanz ausschalten (ruhig für ein paar Minuten / Stunden)
                                  2. in der ioBroker Objektansicht den Expertenmodus aktivieren und folgenden Datenpunkt editieren:
                                  3. in dem Datenpunkt auf den Reiter Objektdaten gehen und unter "native" den Bearer Token manuell auf '' (leer) setzen.
                                  4. die Tahoma Switch komplett zurücksetzen (Reset) und neu anmelden
                                  5. Instanz wieder starten
                                  Wie gesagt, das führte bei mir zum Erfolg beim Umstieg von einer anderen Box (Connexoon).
                                  Ob das der Weisheit letzter Schluss ist, weiß ich nicht, drücke aber die Daumen.
                                  • B blackeagle998
                                    @willi-wunder
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    #426
                                    @blackeagle998
                                    In Objekte in der Ansicht Expertenmodus erscheint bei mir keine Möglichkeit zum editieren....
                                    Nachtrag:
                                    Sorry, jetzt erst gelesen, das ganze unter System.....
                                    • W Willi-Wunder
                                      @blackeagle998
                                      Nachtrag:
                                      blackeagle998
                                      #427
                                      @willi-wunder
                                      Dann probiere es per Skript mit nur diesem Statement:
                                      • B blackeagle998
                                        @willi-wunder
                                        W Offline
                                        W Offline
                                        Willi-Wunder
                                        #428
                                        @blackeagle998
                                        Hab jetzt bei system.adapter.tahoma.0 den alten Token mit dem aktuellen Token einfach überschrieben, dann Adapter neu gestartet, läuft jetzt ohne Fehleranmeldung.
                                        Vielen Dank. 👍
                                        B M 2 Antworten Letzte Antwort
                                        • W Willi-Wunder
                                          @blackeagle998
                                          Vielen Dank. 👍
                                          blackeagle998
                                          #429
                                          @willi-wunder
                                          Gute Idee, schön dass es wieder läuft!
