Skript mit WLED und Online Status
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable type="interval" id="Intervall">Intervall</variable> </variables> <block type="on" id="`@mfc^ejQ8QyU{c0S(D$" x="-507" y="-400"> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="?cCW{!d#-r@hsdJ,pG7Y"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="$35V6)M`{NM=?HnZImC!"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Wm0gvk]I|A5b2p?][%#P"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> </block> </value> <value name="B"> <block type="logic_boolean" id="}wj3)OcuSWu7^bw.w*%I"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="$SIc7unZ4arb;@`{hGy)"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5{Fc8oKr~Aqng#tT.?x7"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="At{$N?TW1)4nS9.R;*aN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="84=[T3P}6FG(9,FuN2,u"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Z5H6{IzIKyB%QqXDOgB="> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="o`SG8diE+/$h#7~Nq.6y"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Hy4FeT,v$k[Tm]*NhGkE"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="S4wSkQm`(4-okM;h{034"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="XWIMS7^!3e-l!hM6cHh("> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="{xdgup=@F*=-eMfCfmIr"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="vra|W$o~z^+]T-.UkRoC"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="=7AiE,Hf70uJ~u9bxjq="> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="update" id="cT|[4=[+^]@cK.n-P;sY"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.DIMMER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="Al2Mwu6X;8qogs1bTO/~"> <field name="NUM">50</field> </block> </value> <next> <block type="control" id="s7m`k-V]*+:*|DwXT}`g"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.RGB</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="SoJkA:3Ki@7q~Ko3Z+*D"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="=lTu?8{DU!9F0beM~1#i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd610703f.ps</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="nG:E{CY6)%Ty]pZQ3a.k"> <field name="NUM">4</field> </block> </value> <next> <block type="timeouts_setinterval" id="o:t^ngdZC`t:/1)CSjGF"> <field name="NAME">Intervall</field> <field name="INTERVAL">8</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="controls_if" id="Jn@q3)XzR0LOQpm70+E$"> <value name="IF0"> <block type="logic_compare" id="@tVQ*.*$X:Wx(`tr2K;1"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="imF8_f%I/TJJLL%,wTE@"> <field name="ATTR">val</field> <field name="OID">wled.0.0cb815b8b20c._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="Crypq(B4/,=4Mg77vmzA"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="4S3/h07BCaIo)[U=)ywr"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="g@c-oHB+c,WBAb0#jR(*"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="8%?|2:[_u-D0!m%fV9?F"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="5LAQ?7Qj[J])u,lT1vkM"> <field name="NUM">5</field> </block> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id="L-8Lr90%Z6OqSW9iMD(X"> <value name="IF0"> <block type="logic_compare" id="tN-V;j|~-q$o:sI9!1uK"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="#*SWesgg]ns-_~rT):Pt"> <field name="ATTR">val</field> <field name="OID">wled.0.bcff4d3da988._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="N*IdiuiS}hjLNF;:XDS}"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="ui9*kHGT.L^T;.JAe+@_"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3debe0.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="E;-XPa2P1U)!_Or6rRy]"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="=;Bu{Utut2YpYT[4[NXi"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3e23a9.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="iqUjeqzVch:ZwVi8YUxZ"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="$ZQjjd$,dZ6.|)_0$UyW"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="KBxK4H-GnhCvKE^.;}$$"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id=".?2B`BI8?*vU=WwzS~f+"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="O#t#t1;CZW95e:I,n%nX"> <field name="NUM">10</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> <next> <block type="controls_if" id="?:x_mfRx|7$~TUc8#vX-"> <value name="IF0"> <block type="logic_compare" id="Jn8DIjQ:nlep?+/cm?Rb"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="~J6,2]v86_$9r#3OpYXk"> <field name="ATTR">val</field> <field name="OID">wled.0.4cebd60c2e6f._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="]pz_c)2Q0=RJi)OQJ%Cz"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=")$=5_(CM$j6sW.o+L;xh"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="6|h8v+-x2D#^g`I#wn:h"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="O0F7OVis1W%W1PxswbLT"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="i;si@bS5_DQ*iewPRx|:"> <field name="NUM">20</field> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id=",NDdTx4,Pg:cVK*Djk4q"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pf#=EQkMS{i@E`.xM-S:"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="^XVW4ui#5Bml~oO0Z*x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="lePA[LhUG0}+3Zj9!L@I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id=".cjNj|yPqcZx=0XyhMWu"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="QL4vK.)#o4LQHV2Y)_Po"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="1jUQMBKe#E)p8FGDFOw%"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="50t]!o1sBlO/PROv;=9/"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="8/J4`hQ~:2g=Db.S12R!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id=":,T{bu]Fq)T5r^H![0]e"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </xml> -
@maik5066 Danke!
fehlen da Zeilen/Blöcke?
Ausschnitte helfen nicht wirklich um ein Skript nachzuvollziehen und einen Fehler zu finden. -
Entschuldige der blöden Nachfrage aber wie kann ich das Skript als jpg exportieren und nicht als screenshot
@maik5066 Screenshot ist doch ok!
jpg nutzt mir am Handy auch nix.ggf paarmal auf (-) klicken zum verkleinern. Aber nicht zu oft ;-)
ich vermisse die Verzögerung/ Pause nach dem anschalten
@maik5066 Danke! das h7lft!
da ist keine Verzögerung, statt dessen ein Intervall.
außerden aktualisierst du beteits vorher den Dimmer statt ihn zu steuern.
auch die anderen Steuerbefehle können nicht wirken, da sie zeitgleich mit on gesendet wrden (vorausgesetzt on ist power on der controller -
@maik5066 sagte in Skript mit WLED und Online Status:
ich habe jetzte eine Pause davor geschalten
und was ist mit den Befehlen zum dimmen und RGB und preset?
die bekommt der Controller doch auch nicht mit -
es werden mehre Controller geschalten, die Dimmer und RGB vor der Prüfung der Online Status sind dauerhaft Online.
die 2 Steuerung ON/OFF sind für 2 Segmente die ich abschalte, diese werden nicht mit RGB und Dimmer geschalten
dann aber den Dimmer steuern, nicht aktualisieren!
wie läuft es denn jetzt?
Danke dir, das habe ich jetzt angepasst. Ich habe mir mehrere Signale eingefügt um zu prüfen wo das Skript hängt er kommt nur bis WLED1 dann hängt er
@maik5066 Du solltest Namen in den Objekten vergeben!
Solange die IDs alle gleich heißen kann man ichts nachvollziehen!was ist der Unterschied zum zweiten falls?
@homoran sagte in Skript mit WLED und Online Status:
wenn man es importiert sieht man es
aber ich weiß....handy
Ich habe das Skript jetzt angepasst , wie lange so ich den Timeout einstellen.<xml xmlns="https://developers.google.com/blockly/xml"> <block type="on" id="`@mfc^ejQ8QyU{c0S(D$" x="-507" y="-400"> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="?cCW{!d#-r@hsdJ,pG7Y"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="$35V6)M`{NM=?HnZImC!"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Wm0gvk]I|A5b2p?][%#P"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> </block> </value> <value name="B"> <block type="logic_boolean" id="}wj3)OcuSWu7^bw.w*%I"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="$SIc7unZ4arb;@`{hGy)"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5{Fc8oKr~Aqng#tT.?x7"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="At{$N?TW1)4nS9.R;*aN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="84=[T3P}6FG(9,FuN2,u"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Z5H6{IzIKyB%QqXDOgB="> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="o`SG8diE+/$h#7~Nq.6y"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Hy4FeT,v$k[Tm]*NhGkE"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="S4wSkQm`(4-okM;h{034"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="XWIMS7^!3e-l!hM6cHh("> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="{xdgup=@F*=-eMfCfmIr"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="vra|W$o~z^+]T-.UkRoC"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="=7AiE,Hf70uJ~u9bxjq="> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="0U4@*d.%::wY-lv2[.5$"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.DIMMER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="@WDH{@kC@X#1:)/Hig+l"> <field name="NUM">50</field> </block> </value> <next> <block type="control" id="s7m`k-V]*+:*|DwXT}`g"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.RGB</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="SoJkA:3Ki@7q~Ko3Z+*D"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="=lTu?8{DU!9F0beM~1#i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd610703f.ps</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="nG:E{CY6)%Ty]pZQ3a.k"> <field name="NUM">4</field> </block> </value> <next> <block type="timeouts_wait" id="}pMyyYTEae#(`hY^8Hva"> <field name="DELAY">8</field> <field name="UNIT">sec</field> <next> <block type="controls_if" id="Jn@q3)XzR0LOQpm70+E$"> <value name="IF0"> <block type="logic_compare" id="@tVQ*.*$X:Wx(`tr2K;1"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="imF8_f%I/TJJLL%,wTE@"> <field name="ATTR">val</field> <field name="OID">wled.0.0cb815b8b20c._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="Crypq(B4/,=4Mg77vmzA"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="4S3/h07BCaIo)[U=)ywr"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="g@c-oHB+c,WBAb0#jR(*"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="8%?|2:[_u-D0!m%fV9?F"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="5LAQ?7Qj[J])u,lT1vkM"> <field name="NUM">5</field> </block> </value> <next> <block type="debug" id="/LYg*c48dCYjz?9,yglV"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="M?*~+Z4=XJIh!8N@c4k_"> <field name="TEXT">WLED1</field> </shadow> </value> </block> </next> </block> </next> </block> </statement> <next> <block type="controls_if" id="L-8Lr90%Z6OqSW9iMD(X"> <value name="IF0"> <block type="logic_compare" id="tN-V;j|~-q$o:sI9!1uK"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="#*SWesgg]ns-_~rT):Pt"> <field name="ATTR">val</field> <field name="OID">wled.0.bcff4d3da988._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="N*IdiuiS}hjLNF;:XDS}"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="ui9*kHGT.L^T;.JAe+@_"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3debe0.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="E;-XPa2P1U)!_Or6rRy]"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="=;Bu{Utut2YpYT[4[NXi"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3e23a9.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="iqUjeqzVch:ZwVi8YUxZ"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="$ZQjjd$,dZ6.|)_0$UyW"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="KBxK4H-GnhCvKE^.;}$$"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id=".?2B`BI8?*vU=WwzS~f+"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="O#t#t1;CZW95e:I,n%nX"> <field name="NUM">10</field> </block> </value> <next> <block type="debug" id="{p(x}3L]KdH!~mXh,j[!"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="_Pxkw~EFKjqGD1g]pvY_"> <field name="TEXT">WLED2</field> </shadow> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <next> <block type="controls_if" id="?:x_mfRx|7$~TUc8#vX-"> <value name="IF0"> <block type="logic_compare" id="Jn8DIjQ:nlep?+/cm?Rb"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="~J6,2]v86_$9r#3OpYXk"> <field name="ATTR">val</field> <field name="OID">wled.0.4cebd60c2e6f._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="]pz_c)2Q0=RJi)OQJ%Cz"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=")$=5_(CM$j6sW.o+L;xh"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="6|h8v+-x2D#^g`I#wn:h"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="O0F7OVis1W%W1PxswbLT"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="i;si@bS5_DQ*iewPRx|:"> <field name="NUM">20</field> </block> </value> <next> <block type="debug" id="@mU`czKce{u)hv;pXB%W"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="yRyN1=_GBK#5OB1$N+Bq"> <field name="TEXT">WLED3</field> </shadow> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id=",NDdTx4,Pg:cVK*Djk4q"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pf#=EQkMS{i@E`.xM-S:"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="^XVW4ui#5Bml~oO0Z*x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="lePA[LhUG0}+3Zj9!L@I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id=".cjNj|yPqcZx=0XyhMWu"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="QL4vK.)#o4LQHV2Y)_Po"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="1jUQMBKe#E)p8FGDFOw%"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="50t]!o1sBlO/PROv;=9/"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="8/J4`hQ~:2g=Db.S12R!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id=":,T{bu]Fq)T5r^H![0]e"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </xml> -
Ich habe das Skript jetzt angepasst , wie lange so ich den Timeout einstellen.<xml xmlns="https://developers.google.com/blockly/xml"> <block type="on" id="`@mfc^ejQ8QyU{c0S(D$" x="-507" y="-400"> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="?cCW{!d#-r@hsdJ,pG7Y"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="$35V6)M`{NM=?HnZImC!"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Wm0gvk]I|A5b2p?][%#P"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.Datenpunkte.Licht.Erdgeschoss_Ambiente.Erdgeschoss_Ambiente</field> </block> </value> <value name="B"> <block type="logic_boolean" id="}wj3)OcuSWu7^bw.w*%I"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="$SIc7unZ4arb;@`{hGy)"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="5{Fc8oKr~Aqng#tT.?x7"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="At{$N?TW1)4nS9.R;*aN"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="84=[T3P}6FG(9,FuN2,u"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Z5H6{IzIKyB%QqXDOgB="> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="o`SG8diE+/$h#7~Nq.6y"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="Hy4FeT,v$k[Tm]*NhGkE"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="S4wSkQm`(4-okM;h{034"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="XWIMS7^!3e-l!hM6cHh("> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="{xdgup=@F*=-eMfCfmIr"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="vra|W$o~z^+]T-.UkRoC"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="=7AiE,Hf70uJ~u9bxjq="> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="0U4@*d.%::wY-lv2[.5$"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.DIMMER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="@WDH{@kC@X#1:)/Hig+l"> <field name="NUM">50</field> </block> </value> <next> <block type="control" id="s7m`k-V]*+:*|DwXT}`g"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.RGB</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="SoJkA:3Ki@7q~Ko3Z+*D"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="=lTu?8{DU!9F0beM~1#i"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd610703f.ps</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="nG:E{CY6)%Ty]pZQ3a.k"> <field name="NUM">4</field> </block> </value> <next> <block type="timeouts_wait" id="}pMyyYTEae#(`hY^8Hva"> <field name="DELAY">8</field> <field name="UNIT">sec</field> <next> <block type="controls_if" id="Jn@q3)XzR0LOQpm70+E$"> <value name="IF0"> <block type="logic_compare" id="@tVQ*.*$X:Wx(`tr2K;1"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="imF8_f%I/TJJLL%,wTE@"> <field name="ATTR">val</field> <field name="OID">wled.0.0cb815b8b20c._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="Crypq(B4/,=4Mg77vmzA"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="4S3/h07BCaIo)[U=)ywr"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="g@c-oHB+c,WBAb0#jR(*"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="8%?|2:[_u-D0!m%fV9?F"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.0cb815b8b20c.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="5LAQ?7Qj[J])u,lT1vkM"> <field name="NUM">5</field> </block> </value> <next> <block type="debug" id="/LYg*c48dCYjz?9,yglV"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="M?*~+Z4=XJIh!8N@c4k_"> <field name="TEXT">WLED1</field> </shadow> </value> </block> </next> </block> </next> </block> </statement> <next> <block type="controls_if" id="L-8Lr90%Z6OqSW9iMD(X"> <value name="IF0"> <block type="logic_compare" id="tN-V;j|~-q$o:sI9!1uK"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="#*SWesgg]ns-_~rT):Pt"> <field name="ATTR">val</field> <field name="OID">wled.0.bcff4d3da988._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="N*IdiuiS}hjLNF;:XDS}"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="ui9*kHGT.L^T;.JAe+@_"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3debe0.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="E;-XPa2P1U)!_Or6rRy]"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="=;Bu{Utut2YpYT[4[NXi"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3e23a9.seg.0.on</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="iqUjeqzVch:ZwVi8YUxZ"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="$ZQjjd$,dZ6.|)_0$UyW"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="KBxK4H-GnhCvKE^.;}$$"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id=".?2B`BI8?*vU=WwzS~f+"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.bcff4d3da988.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="O#t#t1;CZW95e:I,n%nX"> <field name="NUM">10</field> </block> </value> <next> <block type="debug" id="{p(x}3L]KdH!~mXh,j[!"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="_Pxkw~EFKjqGD1g]pvY_"> <field name="TEXT">WLED2</field> </shadow> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <next> <block type="controls_if" id="?:x_mfRx|7$~TUc8#vX-"> <value name="IF0"> <block type="logic_compare" id="Jn8DIjQ:nlep?+/cm?Rb"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="~J6,2]v86_$9r#3OpYXk"> <field name="ATTR">val</field> <field name="OID">wled.0.4cebd60c2e6f._info._online</field> </block> </value> <value name="B"> <block type="logic_boolean" id="]pz_c)2Q0=RJi)OQJ%Cz"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id=")$=5_(CM$j6sW.o+L;xh"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.seg.0.col.0_HEX</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="text" id="6|h8v+-x2D#^g`I#wn:h"> <field name="TEXT">#7883ff</field> </block> </value> <next> <block type="control" id="O0F7OVis1W%W1PxswbLT"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">wled.0.4cebd60c2e6f.bri</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="i;si@bS5_DQ*iewPRx|:"> <field name="NUM">20</field> </block> </value> <next> <block type="debug" id="@mU`czKce{u)hv;pXB%W"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="yRyN1=_GBK#5OB1$N+Bq"> <field name="TEXT">WLED3</field> </shadow> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <statement name="ELSE"> <block type="control" id=",NDdTx4,Pg:cVK*Djk4q"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Kueche_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="pf#=EQkMS{i@E`.xM-S:"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="^XVW4ui#5Bml~oO0Z*x3"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Kueche.Licht_herd.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="lePA[LhUG0}+3Zj9!L@I"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id=".cjNj|yPqcZx=0XyhMWu"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_Lampe.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="QL4vK.)#o4LQHV2Y)_Po"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="1jUQMBKe#E)p8FGDFOw%"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Wohnzimmer.Wohnzimmer_LED.ON_SET</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="50t]!o1sBlO/PROv;=9/"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="8/J4`hQ~:2g=Db.S12R!"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.Erdgeschoss.Esszimmer.Esszimmer_LED.ON</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id=":,T{bu]Fq)T5r^H![0]e"> <field name="BOOL">FALSE</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </xml>@maik5066 sagte in Skript mit WLED und Online Status:
erst mal richtig hoch um zu sehen ob es daran liegt dass evtl noch nicht alle Controller erreichbar sind.
Klappt es dann reproduzierbar musst du dich an den kürzest möglichen sicheren Zeitraum rantasten.klappt es aber auch mit z.B. 30-45 Sekunden nicht, müssen wir die Ursache woanders vermuten.
@homoran Danke dir.
Ich habe jetzt die Pause auf 15s eingestellt , jetzt geht alles.
Ich dachte immer, wenn ein Skript ein "wenn" nicht erfüllt springt er nicht in die nächste Codezeile.
Naja jetzt passt es, nochmal vielen Dank für deine Hilfe.
