  4. Kann Zigbee-Adapter nicht upgraden
77 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • M Mistaluna
    @arteck sagte in Kann Zigbee-Adapter nicht upgraden:
    @mistaluna dann wurde der Ordner nicht gelöscht
    wenn der iobroker.zigbee ordner weg ist dann kommt der Fehler nicht..
    also nochmal
    löschen
    rm -R /opt/iobroker/node_modules/iobroker.zigbee
    Ergebniss posten:
    pi@raspberrypiiobroker:/ $ ls
    bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
    pi@raspberrypiiobroker:/ $ rm -R /opt/iobroker/node_modules/iobroker.zigbee
    rm: cannot remove '/opt/iobroker/node_modules/iobroker.zigbee': No such file or directory
    pi@raspberrypiiobroker:/ $ cd opt/iobroker/node_modules/
    pi@raspberrypiiobroker:/opt/iobroker/node_modules $ ls
    @abandonware                has-property-descriptors       one-time
    abbrev                      has-symbols                    onetime
    accepts                     has-tostringtag                on-finished
    acme-http-01-standalone     has-unicode                    on-headers
    acorn                       has-yarn                       open
    acorn-walk                  he                             options
    addressparser               help-me                        org-regex
    after                       homematic-xmlrpc               os-tmpdir
    agent-base                  hosted-git-info                oui
    agentkeepalive              hot-patcher                    ow
    aggregate-error             hpagent                        package-json
    ajv                         htmlparser2                    pako
    @alcalzone                  http2-wrapper                  parent-module
    ansi-align                  http-cache-semantics           parse5
    ansi-colors                 http-errors                    parse5-htmlparser2-tree-adapter
    ansi-escapes                http-parser-js                 parse-json
    ansi-regex                  http-proxy-agent               parsejson
    ansi-styles                 http-signature                 parseqs
    anymatch                    https-proxy-agent              parseuri
    any-observable              humanize-ms                    parseurl
    append-field                human-signals                  passport
    aproba                      i18next                        passport-http-bearer
    argparse                    iconv-lite                     passport-local
    arraybuffer.slice           ieee754                        passport-oauth2-client-password
    array-flatten               ignore                         passport-strategy
    array-indexofobject         ignore-walk                    path-exists
    array.prototype.findindex   immediate                      path-is-absolute
    array-union                 import-fresh                   path-key
    arrify                      import-lazy                    path-parse
    asn1                        import-local                   path-posix
    assert-plus                 imurmurhash                    path-to-regexp
    async                       indent-string                  path-type
    async-exit-hook             indexof                        pause
    asynckit                    inflight                       pause-stream
    async-mutex                 inherits                       p-cancelable
    at-least-node               ini                            p-defer
    aws4                        inquirer                       performance-now
    @aws-crypto                 inquirer-autosubmit-prompt     p-event
    @aws-sdk                    internal-slot                  p-finally
    aws-sign2                   @iobroker                      picocolors
    axios                       iobroker.admin                 picomatch
    @babel                      iobroker.backitup              pidusage
    backo2                      iobroker.bosesoundtouch        ping
    balanced-match              iobroker.controme              pkg-dir
    base-64                     iobroker.daswetter             pkginfo
    base64-arraybuffer          iobroker.devices               p-limit
    base64id                    iobroker.discovery             p-locate
    base64-js                   iobroker.history               p-map
    basic-auth                  iobroker.hm-rega               p-memoize
    bcrypt                      iobroker.hm-rpc                p-queue
    bcryptjs                    iobroker.homekit-controller    p-reflect
    bcrypt-pbkdf                iobroker.icons-ultimate-png    prepend-http
    better-assert               iobroker.info                  process-nextick-args
    bignumber.js                iobroker.javascript            promise-timeout
    binary                      iobroker.js-controller         promisify-child-process
    binary-extensions           iobroker.klf200                prompt
    bindings                    iobroker.linkeddevices         proxy-addr
    binrpc                      iobroker.net-tools             proxy-from-env
    bl                          iobroker.node-red              p-settle
    blob                        iobroker.panasonic-viera       pseudomap
    bluebird                    iobroker.simple-api            psl
    body-parser                 iobroker.socketio              p-timeout
    boolbase                    iobroker.statistics            p-try
    bowser                      iobroker.telegram              pump
    boxen                       iobroker.text2command          punycode
    brace-expansion             iobroker.vis                   pupa
    braces                      iobroker.vis-canvas-gauges     put
    bson                        iobroker.vis-fancyswitch       q
    buffer                      iobroker.vis-hqwidgets         qjobs
    buffer-equal-constant-time  iobroker.vis-icontwo           qs
    buffer-from                 iobroker.vis-justgage          querystringify
    buffers                     iobroker.vis-timeandweather    queue-microtask
    builtins                    iobroker.web                   quick-lru
    busboy                      iobroker.ws                    random-bytes
    byte-length                 iobroker.ws.server             range-parser
    bytes                       ioredis                        rasha
    cacheable-lookup            ip                             raw-body
    cacheable-request           ipaddr.js                      rc
    call-bind                   is                             read
    callsite                    isarray                        readable-stream
    callsites                   is-arrayish                    readdirp
    camelcase                   is-bigint                      readline
    camelcase-keys              is-binary-path                 readline-sync
    caseless                    is-boolean-object              read-pkg
    cert-info                   is-buffer                      read-pkg-up
    chainsaw                    is-callable                    redent
    chalk                       is-ci                          redirect-https
    chardet                     is-core-module                 redis-commands
    charenc                     is-date-object                 redis-errors
    char-spinner                is-docker                      redis-parser
    cheerio                     isexe                          regenerator-runtime
    cheerio-select              is-extglob                     regexp.prototype.flags
    chokidar                    is-fullwidth-code-point        registry-auth-token
    chownr                      is-glob                        registry-url
    ci-info                     is-installed-globally          reinterval
    clean-stack                 is-interactive                 request
    cli                         is-nan                         request-promise
    cli-boxes                   is-negative-zero               request-promise-core
    cli-cursor                  is-npm                         require-directory
    cliff                       is-number                      require-from-string
    cli-table                   is-number-object               requires-port
    cli-truncate                is-obj                         resolve
    cli-width                   is-observable                  resolve-alpn
    clone                       is-path-cwd                    resolve-cwd
    clone-response              is-path-inside                 resolve-from
    cluster-key-slot            is-plain-obj                   respjs
    code-point-at               is-promise                     responselike
    coffeescript                is-regex                       restore-cursor
    color                       is-scoped                      retry
    color-convert               is-shared-array-buffer         reusify
    color-name                  is-stream                      revalidator
    @colors                     isstream                       rfdc
    colorspace                  is-string                      rimraf
    color-string                issue-regex                    @root
    color-support               is-symbol                      rsa-compat
    combined-stream             is-typedarray                  run-async
    commist                     is-unicode-supported           run-parallel
    complex.js                  is-url-superb                  rxjs
    component-bind              is-utf8                        safe-buffer
    component-emitter           is-weakref                     safer-buffer
    component-inherit           is-wsl                         safe-regex-test
    compressible                is-yarn-global                 safe-replace
    compression                 javascript-natural-sort        safe-stable-stringify
    concat-map                  jquery                         @samverschueren
    concat-stream               js2xmlparser                   saslprep
    configstore                 jsbn                           sax
    connect-flash               jshashes                       scoped-regex
    console-control-strings     json3                          seed-random
    content-disposition         jsonata                        seedrandom
    content-type                json-bigint                    @selderee
    cookie                      json-buffer                    semver
    cookie-parser               jsonc-parser                   semver-diff
    cookie-signature            jsonfile                       send
    core-util-is                jsonify                        sentiment
    cors                        json-parse-even-better-errors  @sentry
    cosmiconfig                 json-schema                    seq-logging
    country-data                json-schema-traverse           @serialport
    cron                        json-stable-stringify          serialport
    cronosjs                    json-stringify-safe            serve-static
    cron-parser                 jsonwebtoken                   set-blocking
    cross-spawn                 jsprim                         setimmediate
    crypt                       js-sdsl                        setprototypeof
    crypto-random-string        js-tokens                      shebang-command
    css-select                  jszip                          shebang-regex
    css-what                    jwa                            side-channel
    currency-symbol-map         jws                            signal-exit
    cycle                       keypairs                       simple-statistics
    @dabh                       keyv                           simple-swizzle
    daemonize2                  kind-of                        @sindresorhus
    dashdash                    klf-200-api                    @sinonjs
    @datalust                   kuler                          slash
    date-fns                    latest-version                 slice-ansi
    debug                       layerr                         smart-buffer
    decache                     le-acme-core                   @socket.io
    decamelize                  le-challenge-fs                socket.io
    decamelize-keys             le-sni-auto                    socket.io-adapter
    decimal.js                  leven                          socket.io-client
    deep-clone                  libsodium                      socket.io-parser
    deep-extend                 libsodium-wrappers             socks
    defer-to-connect            lie                            socksv5
    define-properties           lines-and-columns              sorted-array-functions
    del                         listr                          source-map
    delayed-stream              listr-input                    source-map-support
    delegates                   listr-silent-renderer          sparse-bitfield
    denque                      listr-update-renderer          spdx-correct
    depd                        listr-verbose-renderer         spdx-exceptions
    destroy                     loadavg-windows                spdx-expression-parse
    dgram                       localforage                    spdx-license-ids
    dir-glob                    locate-path                    split
    diskusage                   lodash                         split2
    dns-packet                  lodash.assign                  sshpk
    dnssd                       lodash.clonedeep               stack-trace
    domelementtype              lodash.defaults                standard-as-callback
    domhandler                  lodash.flatten                 statuses
    dom-serializer              lodash.get                     stealthy-require
    domutils                    lodash.has                     stream-combiner
    dot-prop                    lodash.includes                stream-shift
    dropbox-v2-api              lodash.isarguments             string_decoder
    duplexer                    lodash.isboolean               string-format
    duplexer3                   lodash.isequal                 string.prototype.trimend
    duplexify                   lodash.isinteger               string.prototype.trimstart
    ecc-jsbn                    lodash.isnumber                string-width
    ecdsa-sig-formatter         lodash.isplainobject           strip-ansi
    eckles                      lodash.isstring                strip-final-newline
    ee-first                    lodash.once                    strip-indent
    elegant-spinner             lodash.uniq                    strip-json-comments
    emoji-regex                 lodash.zip                     strnum
    enabled                     logform                        suncalc2
    encodeurl                   log-symbols                    supports-color
    end-of-stream               log-update                     supports-hyperlinks
    engine.io                   long-timeout                   supports-preserve-symlinks-flag
    engine.io-client            lowercase-keys                 symbol-observable
    engine.io-parser            lru-cache                      systeminformation
    enquirer                    lru_map                        @szmarczak
    entities                    luxon                          tar
    error-ex                    make-dir                       tar-fs
    es6-promise                 map-age-cleaner                tar-stream
    es-abstract                 @mapbox                        terminal-link
    esbuild                     map-obj                        text-hex
    escalade                    map-stream                     text-table
    escape-goat                 mathjs                         through
    escape-html                 md5                            tiny-emitter
    escape-latex                mdns-discovery                 tmp
    escape-string-regexp        media-typer                    to-array
    es-shim-unscopables         memory-pager                   toidentifier
    es-to-primitive             memorystore                    @tootallnate
    etag                        meow                           to-readable-stream
    eventemitter3               merge2                         to-regex-range
    event-stream                merge-descriptors              tough-cookie
    evilscan                    merge-stream                   tr46
    execa                       methods                        traverse
    express                     micromatch                     trim-newlines
    express-fileupload          mime                           triple-beam
    express-session             mime-db                        tslib
    extend                      mime-types                     tunnel-agent
    external-editor             mimic-fn                       tweetnacl
    extsprintf                  mimic-response                 twitter-ng
    eyes                        minimatch                      typedarray
    fast-deep-equal             minimist                       typedarray-to-buffer
    fast-glob                   minimist-options               typed-function
    fast-json-stable-stringify  min-indent                     type-fest
    fastq                       minipass                       type-is
    fast-srp-hap                minizlib                       @types
    fast-text-encoding          mkdirp                         typescript
    fast-xml-parser             mkdirp-classic                 uglify-js
    fecha                       moment                         uid2
    feedparser                  moment-duration-format         uid-safe
    fetch-enhanced              moment-timezone                ultron
    figures                     mongodb                        unbox-primitive
    file-stream-rotator         mongodb-connection-string-url  underscore
    file-type                   mqtt                           @ungap
    file-uri-to-path            mqtt-packet                    unique-string
    fill-range                  mri                            universalify
    finalhandler                ms                             unix-dgram
    find-up                     multer                         unpipe
    fn.name                     mustache                       update-notifier
    follow-redirects            mute-stream                    uri-js
    forever-agent               nan                            url-join
    form-data                   negotiator                     url-parse
    forwarded                   nested-property                url-parse-lax
    fraction.js                 netmask                        url-template
    fresh                       new-github-release-url         ursa-optional
    from                        node-addon-api                 usb
    fs-constants                node-arp                       util-deprecate
    fs-extra                    node-disk-info                 utils-merge
    fs-minipass                 node.extend                    uuid
    fs.notify                   node-fetch                     vali-date
    fs.realpath                 node-forge                     validate-npm-package-license
    ftp                         node-gyp-build                 validate-npm-package-name
    function-bind               node-hkdf-sync                 vary
    function.prototype.name     node-inspect                   verror
    functions-have-names        @nodelib                       virtual-tsc
    gaxios                      node-mndp                      vows
    gcp-metadata                node-panasonic-viera           weak-daemon
    get-caller-file             @node-red                      webdav
    get-intrinsic               node-red                       webidl-conversions
    getpass                     node-red-admin                 whatwg-url
    get-stream                  node-red-contrib-aggregator    which
    get-symbol-description      node-red-contrib-os            which-boxed-primitive
    github-url-from-git         node-red-contrib-polymer       wide-align
    glob                        node-red-dashboard             widest-line
    global-dirs                 node-red-node-email            winston
    globby                      node-red-node-feedparser       winston-daily-rotate-file
    glob-parent                 node-red-node-sentiment        winston-seq-updated
    glossy                      node-red-node-twitter          winston-syslog
    @googleapis                 node-schedule                  winston-transport
    googleapis-common           node-ssdp                      wol
    google-auth-library         node-telegram-bot-api          wrap-ansi
    google-p12-pem              node-watch                     wrappy
    got                         node-wol                       write-file-atomic
    graceful-fs                 nopt                           ws
    @greenlock                  normalize-package-data         wtf-8
    greenlock                   normalize-path                 xdg-basedir
    greenlock-express           normalize-url                  xml2js
    greenlock-manager-fs        np                             xml2json-light
    greenlock-store-fs          npm-name                       xmlbuilder
    gridstack                   npm-run-path                   xmlcreate
    gtoken                      nth-check                      xmlhttprequest-ssl
    hap-controller              number-allocator               xregexp
    hard-rejection              number-is-nan                  xtend
    har-schema                  oauth                          y18n
    har-validator               oauth2orize                    yallist
    has                         oauth-sign                     yaml
    has-ansi                    object-assign                  yargs-parser
    has-bigints                 object.assign                  yeast
    has-binary                  object-component               yocto-queue
    has-binary2                 object-hash                    zigbee-herdsman
    has-cors                    object-inspect                 zigbee-herdsman-converters
    has-flag                    object-keys
    hash-sum                    once
    dann
    cd  /opt/iobroker/node_modules/iobroker.zigbee
    Ergebniss posten
    pi@raspberrypiiobroker:/opt/iobroker/node_modules $ cd iobroker.zigbee
    -bash: cd: iobroker.zigbee: No such file or directory
    arteckA Offline
    arteckA Offline
    arteck
    @mistaluna und jetzt von git installieren
    so wie ich es gepostet habe
      Mistaluna
      Übrigens wird der Adapter in Instanzen noch angezeigt:
      • arteckA arteck
        Mistaluna
        schrieb am zuletzt editiert von Mistaluna
        #vom Author gelöscht da irrelevant#
          Mistaluna
          @arteck
          Fehler bleibt gleich:
          $ iobroker url https://github.com/ioBroker/ioBroker.zigbee --host raspberrypiiobroker --debug
          install ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d
          NPM version: 8.19.2Installing ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d... (System call)
          npm ERR! Invalid Version: 1.6.0o
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-12-05T13_07_26_405Z-debug-0.log
          host.raspberrypiiobroker Cannot install ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d: 1
          ERROR: Process exited with code 25
          • M Mistaluna
            arteckA Offline
            arteckA Offline
            arteck
            @mistaluna ja die instanz bleibt...
            das ist auch richtig ..sonst sind die Geräte wg wenn du die löscht..
            mach bitte ein
            sudo rm -R /opt/iobroker/node_modules/iobroker.zigbee
            so wie es aussieht ist der Ordner noch da..
            • M Mistaluna
              @crunchip sagte in Kann Zigbee-Adapter nicht upgraden:
              @mistaluna du kannst mal testhalber folgendes prüfen, ob anderweitig auch noch Probleme bestehen oder wirklich nur an dem zigbee liegt.
              Was zeigt
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
              Zeigt bei mir gar nichts:
              pi@raspberrypiiobroker:/ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
              dann noch ein
              sudo -u iobroker npm cache clean --force
              Ergibt nur das hier:
              pi@raspberrypiiobroker:/ $ sudo -u iobroker npm cache clean --force
              npm WARN using --force Recommended protections disabled.
              (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠦ : WARN using --force Recommended protections disabled.
              und nochmal probieren zigbee zu installieren
              ansonsten hab ich auf die schnelle nur das gefunden
              https://forum.iobroker.net/topic/51817/gelöst-zigbee-update-von-1-6-0o-auf-1-6-x
              Probiere ich gleich.
              crunchipC Offline
              crunchipC Offline
              @mistaluna sagte in Kann Zigbee-Adapter nicht upgraden:
              dann gibts diesbezüglich auch nix, alles ok
              auch ok
              du hast ja auch nicht den Adapter an sich gelöscht, was du auch nicht tun sollst
              • M Mistaluna
                @arteck
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                könnte das hier sein:
                https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                Lehrling seit 1975 !!!
                • DJMarc75D DJMarc75
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @djmarc75 NEIN es liegt an der
                  • arteckA arteck
                    mach bitte ein
                    Mistaluna
                    mach bitte ein
                    pi@raspberrypiiobroker:/ $ sudo rm -R /opt/iobroker/node_modules/iobroker.zigbee
                    ESP8266E AsgothianA 2 Antworten Letzte Antwort
                    • M Mistaluna
                      mach bitte ein
                      ESP8266E Offline
                      ESP8266E Offline
                      ESP8266
                      schrieb am zuletzt editiert von ESP8266
                      @mistaluna , das sagt aber was anderes.
                      weil er weg ist.
                      ESP8266E 1 Antwort Letzte Antwort
                      • arteckA arteck
                        Mistaluna
                        Ich frage mich wo diese Info herkommt. Auch da ich zwischendurch die 1.7.6. schon am laufen hatte. Ich habe das Gefühl er führt die Installation und vorher das Upgrade nicht durch, da diese version installiert war. Vielleicht weil etwas inkompatibel ist. Das o in 1.6.0o steht für oldherdsman und war nötig weil der Stick die gebraucht hatte, wenn ich mich recht erinnere.
                        • M Mistaluna
                          mach bitte ein
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @mistaluna
                          Ich fürchte Du wirst nicht umhin zu kommen zumindest die Instanz des Adapters zu löschen. Solange diese existiert gibt es innerhalb des Systems einen Eintrag der besagt welche Version des Adapters mit dieser Instanz installiert wurde.
                          Bitte im Vorfeld:
                          • Die Dateien im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 sichern.
                          • Aufnehmen welche Datenpunkte Du direkt per History weg sicherst (Diese Konfiguration hängt an den Datenpunkten und wird dadurch leider verloren gehen)
                          • Sämtliche Skripte die auf Zigbee Geräte zugreifen anhalten.
                          Dann die Instanz löschen, den Adapter neu von Github installieren, aber NICHT starten.
                          Vor dem Start die Dateien aus dem Verzeichnis /opt/iobroker/iobroker-data-zigbee_0 restaurieren
                          Dann den adapter starten. Das meiste sollte erhalten bleiben.
                          Was du bei dieser Methode verlierst:
                          • die Zuordnung der Geräte zu Enums
                          • angepasste Benennungen der Geräte.
                          In Zukunft werden zumindest die Benennungen auch ein Löschen und Deinstallieren der Instanz überleben (können)
                          A.
                          M 3 Antworten Letzte Antwort
                          • AsgothianA Asgothian
                            @mistaluna
                            Bitte im Vorfeld:
                            A.
                            Mistaluna
                            @asgothian
                            Danke für deinen Tip. Das da eine neuinstallation nötig wird, habe ich schon befürchtet.
                            Sind die Enums die Einträge hier:
                            Also alles, worauf Skripte zugreifen?
                            AsgothianA crunchipC 2 Antworten Letzte Antwort
                              @mistaluna
                              Bitte im Vorfeld:
                              A.
                              Mistaluna
                              @asgothian sagte in Kann Zigbee-Adapter nicht upgraden:
                              @mistaluna
                              Bevor ich das mache, ziehe ich mir ein Image der SD-Karte. Nur für den Fall dass der Fehler auch nach löschen des Adapters bestehen bleibt.
                              • M Mistaluna
                                @asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @asgothian
                                Nein. Das sind die Device ID's, diese bleiben alle gleich, da sie von der Hardware abgeleitet sind.
                                Enums sind Zuordnungen zu Funktionen oder Räumen.
                                A.
                                • M Mistaluna
                                  @asgothian
                                  crunchipC Offline
                                  crunchipC Offline
                                  nein, das sind deine Geräte, mit enums ist dies gemeint, Funktion und Räume
                                    Mistaluna
                                    Also alle direkten Zuordnungen, in Skripten oder Alias?
                                    • M Mistaluna
                                      ESP8266E Offline
                                      ESP8266E Offline
                                      ESP8266
                                      @mistaluna , ja und deshalb sollst du alle Scripte die was mit Zigbee zutun haben stoppen.
                                      Die Enums sind zum Beispiel verknüpft als Wohnzimmer Licht.
                                      • M Mistaluna
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        Ich kann die Frage nicht wirklich deuten - es fehlt die Referenz.
                                        Soweit ich das beurteilen kann sollten weder alias noch Skriptreferenzen von dem Entfernen / Neu installieren des Zigbee Adapters betroffen sein. Bei Skripten bin ich da 100% sicher - weswegen ich in meiner Mini-Anleitung darum gebeten hab die Skripte anzuhalten. Bei den Alias bin ich unsicher in wie die sich verhalten wenn das "original" entfernt wird. ggf. auch hier den Alias-Adapter pausieren.
                                        A.
                                          A.
                                          Mistaluna
                                          @asgothian
                                          OK, also welche konkreten Auswirkungen hat die Neuzuordnung der Enums zu den Geräten?
