  4. Kann Zigbee-Adapter nicht upgraden
77 Beiträge 8 Kommentatoren 10.2k Aufrufe 7 Beobachtet
  • arteckA arteck
    @mistaluna hast du ein Multihost ?
    ich dachte du denkst mit
    also nochmal
    rm -R /opt/iobroker/node_modules/iobroker.zigbee
    auf ALLEN maschienen die du hast.. und die GIT nur auf dem Host wo auch der adapter läuft
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    @arteck , ich habe neuerdings nach dem Upgrade das im Log:
    zigbee.0
    	2022-12-05 13:43:02.161	error	Error 225 on send command to 0x00178801081d33a1. Error: Error: Command 0x00178801081d33a1/11 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:41:13.318	error	Error 225 on send command to 0x84fd27fffe9b3baf. Error: Error: Command 0x84fd27fffe9b3baf/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:41:04.817	error	Error 225 on send command to 0x84fd27fffe9b3baf. Error: Error: Command 0x84fd27fffe9b3baf/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:40:53.856	error	Error 225 on send command to 0x84fd27fffe93d9f2. Error: Error: Command 0x84fd27fffe93d9f2/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    aber es funktioniert alles.
    • arteckA arteck
      also nochmal
      Mistaluna
      @arteck Nein, habe kein Multihost.
      • ESP8266E ESP8266
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        arteckA Offline
        arteckA Offline
        arteck
        @esp8266 sagte in Kann Zigbee-Adapter nicht upgraden:
        mach ein eigenen thread für auf
        ESP8266E 1 Antwort Letzte Antwort
        • arteckA arteck
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          @arteck ok
          • M Mistaluna
            arteckA Offline
            arteckA Offline
            arteck
            @mistaluna dann wurde der Ordner nicht gelöscht
            wenn der iobroker.zigbee ordner weg ist dann kommt der Fehler nicht..
            also nochmal
            löschen
            Ergebniss posten
            dann
            cd  /opt/iobroker/node_modules/iobroker.zigbee
            Ergebniss posten
              @mistaluna du kannst mal testhalber folgendes prüfen, ob anderweitig auch noch Probleme bestehen oder wirklich nur an dem zigbee liegt.
              Was zeigt
              for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
              dann noch ein
              sudo -u iobroker npm cache clean --force
              und nochmal probieren zigbee zu installieren
              ansonsten hab ich auf die schnelle nur das gefunden
              https://forum.iobroker.net/topic/51817/gelöst-zigbee-update-von-1-6-0o-auf-1-6-x
              Mistaluna
              @crunchip sagte in Kann Zigbee-Adapter nicht upgraden:
              Was zeigt
              Zeigt bei mir gar nichts:
              pi@raspberrypiiobroker:/ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%}; done
              dann noch ein
              Ergibt nur das hier:
              pi@raspberrypiiobroker:/ $ sudo -u iobroker npm cache clean --force
              npm WARN using --force Recommended protections disabled.
              (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠦ : WARN using --force Recommended protections disabled.
              Probiere ich gleich.
              • arteckA arteck
                also nochmal
                löschen
                Ergebniss posten
                dann
                Ergebniss posten
                Mistaluna
                @arteck sagte in Kann Zigbee-Adapter nicht upgraden:
                also nochmal
                löschen
                Ergebniss posten:
                pi@raspberrypiiobroker:/ $ ls
                bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
                pi@raspberrypiiobroker:/ $ rm -R /opt/iobroker/node_modules/iobroker.zigbee
                rm: cannot remove '/opt/iobroker/node_modules/iobroker.zigbee': No such file or directory
                pi@raspberrypiiobroker:/ $ cd opt/iobroker/node_modules/
                pi@raspberrypiiobroker:/opt/iobroker/node_modules $ ls
                @abandonware                has-property-descriptors       one-time
                abbrev                      has-symbols                    onetime
                accepts                     has-tostringtag                on-finished
                acme-http-01-standalone     has-unicode                    on-headers
                acorn                       has-yarn                       open
                acorn-walk                  he                             options
                addressparser               help-me                        org-regex
                after                       homematic-xmlrpc               os-tmpdir
                agent-base                  hosted-git-info                oui
                agentkeepalive              hot-patcher                    ow
                aggregate-error             hpagent                        package-json
                ajv                         htmlparser2                    pako
                @alcalzone                  http2-wrapper                  parent-module
                ansi-align                  http-cache-semantics           parse5
                ansi-colors                 http-errors                    parse5-htmlparser2-tree-adapter
                ansi-escapes                http-parser-js                 parse-json
                ansi-regex                  http-proxy-agent               parsejson
                ansi-styles                 http-signature                 parseqs
                anymatch                    https-proxy-agent              parseuri
                any-observable              humanize-ms                    parseurl
                append-field                human-signals                  passport
                aproba                      i18next                        passport-http-bearer
                argparse                    iconv-lite                     passport-local
                arraybuffer.slice           ieee754                        passport-oauth2-client-password
                array-flatten               ignore                         passport-strategy
                array-indexofobject         ignore-walk                    path-exists
                array.prototype.findindex   immediate                      path-is-absolute
                array-union                 import-fresh                   path-key
                arrify                      import-lazy                    path-parse
                asn1                        import-local                   path-posix
                assert-plus                 imurmurhash                    path-to-regexp
                async                       indent-string                  path-type
                async-exit-hook             indexof                        pause
                asynckit                    inflight                       pause-stream
                async-mutex                 inherits                       p-cancelable
                at-least-node               ini                            p-defer
                aws4                        inquirer                       performance-now
                @aws-crypto                 inquirer-autosubmit-prompt     p-event
                @aws-sdk                    internal-slot                  p-finally
                aws-sign2                   @iobroker                      picocolors
                axios                       iobroker.admin                 picomatch
                @babel                      iobroker.backitup              pidusage
                backo2                      iobroker.bosesoundtouch        ping
                balanced-match              iobroker.controme              pkg-dir
                base-64                     iobroker.daswetter             pkginfo
                base64-arraybuffer          iobroker.devices               p-limit
                base64id                    iobroker.discovery             p-locate
                base64-js                   iobroker.history               p-map
                basic-auth                  iobroker.hm-rega               p-memoize
                bcrypt                      iobroker.hm-rpc                p-queue
                bcryptjs                    iobroker.homekit-controller    p-reflect
                bcrypt-pbkdf                iobroker.icons-ultimate-png    prepend-http
                better-assert               iobroker.info                  process-nextick-args
                bignumber.js                iobroker.javascript            promise-timeout
                binary                      iobroker.js-controller         promisify-child-process
                binary-extensions           iobroker.klf200                prompt
                bindings                    iobroker.linkeddevices         proxy-addr
                binrpc                      iobroker.net-tools             proxy-from-env
                bl                          iobroker.node-red              p-settle
                blob                        iobroker.panasonic-viera       pseudomap
                bluebird                    iobroker.simple-api            psl
                body-parser                 iobroker.socketio              p-timeout
                boolbase                    iobroker.statistics            p-try
                bowser                      iobroker.telegram              pump
                boxen                       iobroker.text2command          punycode
                brace-expansion             iobroker.vis                   pupa
                braces                      iobroker.vis-canvas-gauges     put
                bson                        iobroker.vis-fancyswitch       q
                buffer                      iobroker.vis-hqwidgets         qjobs
                buffer-equal-constant-time  iobroker.vis-icontwo           qs
                buffer-from                 iobroker.vis-justgage          querystringify
                buffers                     iobroker.vis-timeandweather    queue-microtask
                builtins                    iobroker.web                   quick-lru
                busboy                      iobroker.ws                    random-bytes
                byte-length                 iobroker.ws.server             range-parser
                bytes                       ioredis                        rasha
                cacheable-lookup            ip                             raw-body
                cacheable-request           ipaddr.js                      rc
                call-bind                   is                             read
                callsite                    isarray                        readable-stream
                callsites                   is-arrayish                    readdirp
                camelcase                   is-bigint                      readline
                camelcase-keys              is-binary-path                 readline-sync
                caseless                    is-boolean-object              read-pkg
                cert-info                   is-buffer                      read-pkg-up
                chainsaw                    is-callable                    redent
                chalk                       is-ci                          redirect-https
                chardet                     is-core-module                 redis-commands
                charenc                     is-date-object                 redis-errors
                char-spinner                is-docker                      redis-parser
                cheerio                     isexe                          regenerator-runtime
                cheerio-select              is-extglob                     regexp.prototype.flags
                chokidar                    is-fullwidth-code-point        registry-auth-token
                chownr                      is-glob                        registry-url
                ci-info                     is-installed-globally          reinterval
                clean-stack                 is-interactive                 request
                cli                         is-nan                         request-promise
                cli-boxes                   is-negative-zero               request-promise-core
                cli-cursor                  is-npm                         require-directory
                cliff                       is-number                      require-from-string
                cli-table                   is-number-object               requires-port
                cli-truncate                is-obj                         resolve
                cli-width                   is-observable                  resolve-alpn
                clone                       is-path-cwd                    resolve-cwd
                clone-response              is-path-inside                 resolve-from
                cluster-key-slot            is-plain-obj                   respjs
                code-point-at               is-promise                     responselike
                coffeescript                is-regex                       restore-cursor
                color                       is-scoped                      retry
                color-convert               is-shared-array-buffer         reusify
                color-name                  is-stream                      revalidator
                @colors                     isstream                       rfdc
                colorspace                  is-string                      rimraf
                color-string                issue-regex                    @root
                color-support               is-symbol                      rsa-compat
                combined-stream             is-typedarray                  run-async
                commist                     is-unicode-supported           run-parallel
                complex.js                  is-url-superb                  rxjs
                component-bind              is-utf8                        safe-buffer
                component-emitter           is-weakref                     safer-buffer
                component-inherit           is-wsl                         safe-regex-test
                compressible                is-yarn-global                 safe-replace
                compression                 javascript-natural-sort        safe-stable-stringify
                concat-map                  jquery                         @samverschueren
                concat-stream               js2xmlparser                   saslprep
                configstore                 jsbn                           sax
                connect-flash               jshashes                       scoped-regex
                console-control-strings     json3                          seed-random
                content-disposition         jsonata                        seedrandom
                content-type                json-bigint                    @selderee
                cookie                      json-buffer                    semver
                cookie-parser               jsonc-parser                   semver-diff
                cookie-signature            jsonfile                       send
                core-util-is                jsonify                        sentiment
                cors                        json-parse-even-better-errors  @sentry
                cosmiconfig                 json-schema                    seq-logging
                country-data                json-schema-traverse           @serialport
                cron                        json-stable-stringify          serialport
                cronosjs                    json-stringify-safe            serve-static
                cron-parser                 jsonwebtoken                   set-blocking
                cross-spawn                 jsprim                         setimmediate
                crypt                       js-sdsl                        setprototypeof
                crypto-random-string        js-tokens                      shebang-command
                css-select                  jszip                          shebang-regex
                css-what                    jwa                            side-channel
                currency-symbol-map         jws                            signal-exit
                cycle                       keypairs                       simple-statistics
                @dabh                       keyv                           simple-swizzle
                daemonize2                  kind-of                        @sindresorhus
                dashdash                    klf-200-api                    @sinonjs
                @datalust                   kuler                          slash
                date-fns                    latest-version                 slice-ansi
                debug                       layerr                         smart-buffer
                decache                     le-acme-core                   @socket.io
                decamelize                  le-challenge-fs                socket.io
                decamelize-keys             le-sni-auto                    socket.io-adapter
                decimal.js                  leven                          socket.io-client
                deep-clone                  libsodium                      socket.io-parser
                deep-extend                 libsodium-wrappers             socks
                defer-to-connect            lie                            socksv5
                define-properties           lines-and-columns              sorted-array-functions
                del                         listr                          source-map
                delayed-stream              listr-input                    source-map-support
                delegates                   listr-silent-renderer          sparse-bitfield
                denque                      listr-update-renderer          spdx-correct
                depd                        listr-verbose-renderer         spdx-exceptions
                destroy                     loadavg-windows                spdx-expression-parse
                dgram                       localforage                    spdx-license-ids
                dir-glob                    locate-path                    split
                diskusage                   lodash                         split2
                dns-packet                  lodash.assign                  sshpk
                dnssd                       lodash.clonedeep               stack-trace
                domelementtype              lodash.defaults                standard-as-callback
                domhandler                  lodash.flatten                 statuses
                dom-serializer              lodash.get                     stealthy-require
                domutils                    lodash.has                     stream-combiner
                dot-prop                    lodash.includes                stream-shift
                dropbox-v2-api              lodash.isarguments             string_decoder
                duplexer                    lodash.isboolean               string-format
                duplexer3                   lodash.isequal                 string.prototype.trimend
                duplexify                   lodash.isinteger               string.prototype.trimstart
                ecc-jsbn                    lodash.isnumber                string-width
                ecdsa-sig-formatter         lodash.isplainobject           strip-ansi
                eckles                      lodash.isstring                strip-final-newline
                ee-first                    lodash.once                    strip-indent
                elegant-spinner             lodash.uniq                    strip-json-comments
                emoji-regex                 lodash.zip                     strnum
                enabled                     logform                        suncalc2
                encodeurl                   log-symbols                    supports-color
                end-of-stream               log-update                     supports-hyperlinks
                engine.io                   long-timeout                   supports-preserve-symlinks-flag
                engine.io-client            lowercase-keys                 symbol-observable
                engine.io-parser            lru-cache                      systeminformation
                enquirer                    lru_map                        @szmarczak
                entities                    luxon                          tar
                error-ex                    make-dir                       tar-fs
                es6-promise                 map-age-cleaner                tar-stream
                es-abstract                 @mapbox                        terminal-link
                esbuild                     map-obj                        text-hex
                escalade                    map-stream                     text-table
                escape-goat                 mathjs                         through
                escape-html                 md5                            tiny-emitter
                escape-latex                mdns-discovery                 tmp
                escape-string-regexp        media-typer                    to-array
                es-shim-unscopables         memory-pager                   toidentifier
                es-to-primitive             memorystore                    @tootallnate
                etag                        meow                           to-readable-stream
                eventemitter3               merge2                         to-regex-range
                event-stream                merge-descriptors              tough-cookie
                evilscan                    merge-stream                   tr46
                execa                       methods                        traverse
                express                     micromatch                     trim-newlines
                express-fileupload          mime                           triple-beam
                express-session             mime-db                        tslib
                extend                      mime-types                     tunnel-agent
                external-editor             mimic-fn                       tweetnacl
                extsprintf                  mimic-response                 twitter-ng
                eyes                        minimatch                      typedarray
                fast-deep-equal             minimist                       typedarray-to-buffer
                fast-glob                   minimist-options               typed-function
                fast-json-stable-stringify  min-indent                     type-fest
                fastq                       minipass                       type-is
                fast-srp-hap                minizlib                       @types
                fast-text-encoding          mkdirp                         typescript
                fast-xml-parser             mkdirp-classic                 uglify-js
                fecha                       moment                         uid2
                feedparser                  moment-duration-format         uid-safe
                fetch-enhanced              moment-timezone                ultron
                figures                     mongodb                        unbox-primitive
                file-stream-rotator         mongodb-connection-string-url  underscore
                file-type                   mqtt                           @ungap
                file-uri-to-path            mqtt-packet                    unique-string
                fill-range                  mri                            universalify
                finalhandler                ms                             unix-dgram
                find-up                     multer                         unpipe
                fn.name                     mustache                       update-notifier
                follow-redirects            mute-stream                    uri-js
                forever-agent               nan                            url-join
                form-data                   negotiator                     url-parse
                forwarded                   nested-property                url-parse-lax
                fraction.js                 netmask                        url-template
                fresh                       new-github-release-url         ursa-optional
                from                        node-addon-api                 usb
                fs-constants                node-arp                       util-deprecate
                fs-extra                    node-disk-info                 utils-merge
                fs-minipass                 node.extend                    uuid
                fs.notify                   node-fetch                     vali-date
                fs.realpath                 node-forge                     validate-npm-package-license
                ftp                         node-gyp-build                 validate-npm-package-name
                function-bind               node-hkdf-sync                 vary
                function.prototype.name     node-inspect                   verror
                functions-have-names        @nodelib                       virtual-tsc
                gaxios                      node-mndp                      vows
                gcp-metadata                node-panasonic-viera           weak-daemon
                get-caller-file             @node-red                      webdav
                get-intrinsic               node-red                       webidl-conversions
                getpass                     node-red-admin                 whatwg-url
                get-stream                  node-red-contrib-aggregator    which
                get-symbol-description      node-red-contrib-os            which-boxed-primitive
                github-url-from-git         node-red-contrib-polymer       wide-align
                glob                        node-red-dashboard             widest-line
                global-dirs                 node-red-node-email            winston
                globby                      node-red-node-feedparser       winston-daily-rotate-file
                glob-parent                 node-red-node-sentiment        winston-seq-updated
                glossy                      node-red-node-twitter          winston-syslog
                @googleapis                 node-schedule                  winston-transport
                googleapis-common           node-ssdp                      wol
                google-auth-library         node-telegram-bot-api          wrap-ansi
                google-p12-pem              node-watch                     wrappy
                got                         node-wol                       write-file-atomic
                graceful-fs                 nopt                           ws
                @greenlock                  normalize-package-data         wtf-8
                greenlock                   normalize-path                 xdg-basedir
                greenlock-express           normalize-url                  xml2js
                greenlock-manager-fs        np                             xml2json-light
                greenlock-store-fs          npm-name                       xmlbuilder
                gridstack                   npm-run-path                   xmlcreate
                gtoken                      nth-check                      xmlhttprequest-ssl
                hap-controller              number-allocator               xregexp
                hard-rejection              number-is-nan                  xtend
                har-schema                  oauth                          y18n
                har-validator               oauth2orize                    yallist
                has                         oauth-sign                     yaml
                has-ansi                    object-assign                  yargs-parser
                has-bigints                 object.assign                  yeast
                has-binary                  object-component               yocto-queue
                has-binary2                 object-hash                    zigbee-herdsman
                has-cors                    object-inspect                 zigbee-herdsman-converters
                has-flag                    object-keys
                hash-sum                    once
                dann
                Ergebniss posten
                pi@raspberrypiiobroker:/opt/iobroker/node_modules $ cd iobroker.zigbee
                -bash: cd: iobroker.zigbee: No such file or directory
                • M Mistaluna
                  also nochmal
                  löschen
                  Ergebniss posten:
                  acorn                       has-yarn                       open
                  bytes                       ioredis                        rasha
                  call-bind                   is                             read
                  entities                    luxon                          tar
                  fecha                       moment                         uid2
                  graceful-fs                 nopt                           ws
                  has                         oauth-sign                     yaml
                  hash-sum                    once
                  dann
                  Ergebniss posten
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @mistaluna und jetzt von git installieren
                  so wie ich es gepostet habe
                    Mistaluna
                    Übrigens wird der Adapter in Instanzen noch angezeigt:
                    • arteckA arteck
                      Mistaluna
                      schrieb am zuletzt editiert von Mistaluna
                      #vom Author gelöscht da irrelevant#
                        Mistaluna
                        @arteck
                        Fehler bleibt gleich:
                        $ iobroker url https://github.com/ioBroker/ioBroker.zigbee --host raspberrypiiobroker --debug
                        install ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d
                        NPM version: 8.19.2Installing ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d... (System call)
                        npm ERR! Invalid Version: 1.6.0o
                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-12-05T13_07_26_405Z-debug-0.log
                        host.raspberrypiiobroker Cannot install ioBroker/ioBroker.zigbee#51f9fd0067c1686617eb316ca011ee074213112d: 1
                        ERROR: Process exited with code 25
                        • M Mistaluna
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @mistaluna ja die instanz bleibt...
                          das ist auch richtig ..sonst sind die Geräte wg wenn du die löscht..
                          mach bitte ein
                          sudo rm -R /opt/iobroker/node_modules/iobroker.zigbee
                          so wie es aussieht ist der Ordner noch da..
                          • M Mistaluna
                            Was zeigt
                            dann noch ein
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @mistaluna sagte in Kann Zigbee-Adapter nicht upgraden:
                            dann gibts diesbezüglich auch nix, alles ok
                            auch ok
                            du hast ja auch nicht den Adapter an sich gelöscht, was du auch nicht tun sollst
                            • M Mistaluna
                              @arteck
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              könnte das hier sein:
                              https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                              Lehrling seit 1975 !!!
                              • DJMarc75D DJMarc75
                                arteckA Offline
                                arteckA Offline
                                arteck
                                @djmarc75 NEIN es liegt an der
                                • arteckA arteck
                                  mach bitte ein
                                  Mistaluna
                                  mach bitte ein
                                  pi@raspberrypiiobroker:/ $ sudo rm -R /opt/iobroker/node_modules/iobroker.zigbee
                                  ESP8266E AsgothianA 2 Antworten Letzte Antwort
                                  • M Mistaluna
                                    mach bitte ein
                                    ESP8266E Offline
                                    ESP8266E Offline
                                    ESP8266
                                    @mistaluna , das sagt aber was anderes.
                                    weil er weg ist.
                                    • arteckA arteck
                                      Mistaluna
                                      Ich frage mich wo diese Info herkommt. Auch da ich zwischendurch die 1.7.6. schon am laufen hatte. Ich habe das Gefühl er führt die Installation und vorher das Upgrade nicht durch, da diese version installiert war. Vielleicht weil etwas inkompatibel ist. Das o in 1.6.0o steht für oldherdsman und war nötig weil der Stick die gebraucht hatte, wenn ich mich recht erinnere.
                                      • M Mistaluna
                                        mach bitte ein
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @mistaluna
                                        Ich fürchte Du wirst nicht umhin zu kommen zumindest die Instanz des Adapters zu löschen. Solange diese existiert gibt es innerhalb des Systems einen Eintrag der besagt welche Version des Adapters mit dieser Instanz installiert wurde.
                                        Bitte im Vorfeld:
                                        • Die Dateien im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 sichern.
                                        • Aufnehmen welche Datenpunkte Du direkt per History weg sicherst (Diese Konfiguration hängt an den Datenpunkten und wird dadurch leider verloren gehen)
                                        • Sämtliche Skripte die auf Zigbee Geräte zugreifen anhalten.
                                        Dann die Instanz löschen, den Adapter neu von Github installieren, aber NICHT starten.
                                        Vor dem Start die Dateien aus dem Verzeichnis /opt/iobroker/iobroker-data-zigbee_0 restaurieren
                                        Dann den adapter starten. Das meiste sollte erhalten bleiben.
                                        Was du bei dieser Methode verlierst:
                                        • die Zuordnung der Geräte zu Enums
                                        • angepasste Benennungen der Geräte.
                                        In Zukunft werden zumindest die Benennungen auch ein Löschen und Deinstallieren der Instanz überleben (können)
                                        A.
                                        M 3 Antworten Letzte Antwort
                                        • AsgothianA Asgothian
                                          @mistaluna
                                          Bitte im Vorfeld:
                                          A.
                                          Mistaluna
                                          @asgothian
                                          Danke für deinen Tip. Das da eine neuinstallation nötig wird, habe ich schon befürchtet.
                                          Sind die Enums die Einträge hier:
                                          Also alles, worauf Skripte zugreifen?
                                          AsgothianA crunchipC 2 Antworten Letzte Antwort
