  4. Test Adapter mihome-cloud
    apollon77A
235 Beiträge 48 Kommentatoren 77.3k Aufrufe 46 Beobachtet
    @tombox
    dazu muss erwähnt werden, dass ich gerade AdGuard mit vielen neuen blacklisten ausgestattet habe.
    ![94938bc2-5ed7-4085-8aa5-87326685dca7-image.png](/assets/uploads/files/1668719436239-94938bc2-5ed7-4085-8aa5-87326685dca7-image-resized.png)
    ```2022-11-17 19:06:58.327 - error: host.HomeServer01 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    2022-11-17 19:06:59.243 - error: info.0 (3798) info.0 already running
    2022-11-17 19:07:01.830 - error: host.HomeServer01 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-17 19:07:02.773 - info: javascript.0 (3744) received all states
    2022-11-17 19:07:04.202 - error: trashschedule.0 (3862) trashschedule.0 already running
    2022-11-17 19:07:04.209 - warn: trashschedule.0 (3862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-17 19:07:05.361 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript_test: ReferenceError: Init is not defined
    2022-11-17 19:07:05.364 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:37:1
    2022-11-17 19:07:05.366 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:484:3
    2022-11-17 19:07:05.367 - error: javascript.0 (3744) at Script.runInContext (node:vm:141:12)
    2022-11-17 19:07:08.717 - error: trashschedule.1 (3889) trashschedule.1 already running
    2022-11-17 19:07:09.598 - info: host.HomeServer01 instance system.adapter.mihome-cloud.0 started with pid 3941
    2022-11-17 19:07:10.109 - error: host.HomeServer01 instance system.adapter.trashschedule.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-17 19:07:10.309 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: You are already logged in, login canceled
    2022-11-17 19:07:10.311 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Retrieving your in de registered MiHome Devices
    2022-11-17 19:07:10.329 - error: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Error: Pls login before make any request
    2022-11-17 19:07:10.330 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
    2022-11-17 19:07:10.332 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
    2022-11-17 19:07:10.336 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2:874:50)
    2022-11-17 19:07:10.338 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-11-17 19:07:10.382 - error: web.0 (3923) web.0 already running
    2022-11-17 19:07:10.377 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: You are already logged in, login canceled
    2022-11-17 19:07:10.378 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Retrieving your in de registered MiHome Devices
    2022-11-17 19:07:10.385 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Error: Pls login before make any request
    2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
    2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
    2022-11-17 19:07:10.387 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.Xiaomi-Skript:874:50)
    2022-11-17 19:07:10.393 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
    2022-11-17 19:07:11.834 - error: host.HomeServer01 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-17 19:07:11.835 - info: host.HomeServer01 Restart adapter system.adapter.web.0 because enabled
    2022-11-17 19:07:15.632 - error: mihome-cloud.0 (3941) mihome-cloud.0 already running
    2022-11-17 19:07:15.663 - warn: mihome-cloud.0 (3941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-11-17 19:07:16.385 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-11-17 19:07:16.386 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
    2022-11-17 19:07:54.479 - info: mihome-cloud.0 (4337) Login to MiHome Cloud
    2022-11-17 19:07:59.792 - error: mihome-cloud.0 (4337) Error: getaddrinfo EAI_AGAIN account.xiaomi.com
    2022-11-17 19:07:59.804 - error: mihome-cloud.0 (4337) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-11-17 19:07:59.810 - error: mihome-cloud.0 (4337) unhandled promise rejection: Cannot read properties of undefined (reading '_sign')
    2022-11-17 19:07:59.817 - error: mihome-cloud.0 (4337) TypeError: Cannot read properties of undefined (reading '_sign')
    at MihomeCloud.login (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:133:20)
    at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:91:5)
    2022-11-17 19:07:59.818 - error: mihome-cloud.0 (4337) Cannot read properties of undefined (reading '_sign')
    2022-11-17 19:07:59.844 - info: mihome-cloud.0 (4337) terminating
    2022-11-17 19:07:59.847 - warn: mihome-cloud.0 (4337) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-11-17 19:08:00.491 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-11-17 19:08:00.492 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
    T
    T
    tombox
    @hannnes Ok das Problem ist abgefangen
    • T tombox
      @tombox
      ich hab ne Verständnisfrage: Wie fängst Du das Problem ab ohne dass ich neu installieren muss? Oder soll ich neu installieren?
        @tombox
        T
        T
        tombox
        @hannnes Ich habe es in der GitHub version abgefangen. Wenn du die Änderung haben möchtest musst du neuinstallierten
        • T tombox
          @tombox
          Ah, ok. Du verbesserst, ohne die Version hochzuziehen. Jetzt löst sich ein Rätsel 😜
          • M
            M
            michael 1975
            @tombox ich habe heute den xiaomi Futterautomat hinzugefügt hier diesen kann ich leider auch nicht drüber steuern, kannst du mir hier auch helfen was bräuchtest du von mir?
            Gruß Michael
            • M michael 1975
              Gruß Michael
              T
              T
              tombox
              @michael-1975 wenn du das gerät sharen kannst dann mit mir sharen tombox2020@gmail.com oder wenigsten die Modell Nummer des Geräts
              M 2 Antworten Letzte Antwort
              • T tombox
                M
                M
                michael 1975
                @tombox habe ich gerade gemacht sollte bei dir sein wenn ich noch was machen kann sage es bitte.
                • T tombox
                  @thoml Ja Zugriff hilft immer beim debuggen
                  T
                  T
                  thoml
                  schrieb am zuletzt editiert von thoml
                  hat sich erledigt..
                  • dontobiD
                    dontobiD
                    dontobi
                    Hallo zusammen
                    Ich habe den Adapter nun auch Mal installiert. Ich nutze lediglich einen Air Purifier 2H. Bei den ersten Tests sind mir ein paar Kleinigkeiten aufgefallen. Dazu werde ich auf GitHub ein Issue erstellen, wenn ich alles getestet habe.
                    Ich möchte an dieser Stelle ein großes Dankeschön an den Entwickler schicken.
                    Gruß aus dem Rheinland
                    Tobi
                    Smart Home Zentrale: Raspberry Pi 4 4GB
                    Meine Homepage: https://www.myHome.zone
                    • T tombox
                      M
                      M
                      michael 1975
                      @tombox hat das mit dem Teilen geklappt, bin noch am überlegen den Trinkbrunnen zu holen da wäre sicher das selbe.
                      Danke für deine Mühe
                      • M michael 1975
                        T
                        T
                        tombox
                        @michael-1975 Jap komme aber später erst dazu mir das anzuschauen
                        • T
                          T
                          tequila74
                          ich wollte den Adapter nun auch mal testen, um meinen Dreame D9 in ioBroker zu bekommen.
                          Nur leider scheitert es bei mir schon mit der Anmeldung am Server.
                          Bekomme immer einen error mit "No sign in first step"
                          Server in der App & Adapter ist Deutschland.
                          Stefan
                          • T tequila74
                            Stefan
                            S
                            S
                            SaiBot1981
                            #66
                            @tequila74 sagte in Test Adapter mihome-cloud:
                            Stefan
                            Wollte den Adapter auch testen und bekomme den gleichen Fehler
                            • T
                              T
                              tombox
                              #67
                              @saibot1981 Kann eigentlich nicht passieren
                              Könnt ihr diese URL aufrufen
                              https://account.xiaomi.com/pass/serviceLogin?sid=xiaomiio&_json=true
                              und wenn ja was kommt da zurück
                              S B 2 Antworten Letzte Antwort
                              • T tombox
                                S
                                S
                                SaiBot1981
                                #68
                                @tombox sagte in Test Adapter mihome-cloud:
                                das kommt zurück:
                                &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"child":0,"desc":"登录验证失败"}
                                • T
                                  T
                                  tequila74
                                  #69
                                  SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
                                  • T
                                    T
                                    tombox
                                    #70
                                    @saibot1981 Kann dann eigentlich nicht sein .. größer log oder debug log wäre hilfreich
                                    • T tombox
                                      S
                                      S
                                      SaiBot1981
                                      schrieb am zuletzt editiert von SaiBot1981
                                      #71
                                      also wenn ich auf den link klicke den du gepostet hast kommt genau das zurück.
                                      Ich gehe davon aus du meinst auch ganz normal am pc öffnen, denn über den broker eine url öffnen hab ich noch nie gemacht.
                                      EDIT: man sollte dann auch nicht google chrome verwenden.
                                      Mit Firefox hab ich das:
                                      • T tombox
                                        B
                                        B
                                        bob der 1.
                                        schrieb am zuletzt editiert von bob der 1.
                                        #72
                                        @tombox
                                        Hänge mich mal da rein.
                                        Adapter rennt!
                                        auf FF kommt dass retour
                                        Mit dem edge
                                        bin halt mit dem Land in China.
                                        deswegen habe ich auch paar Log einträge mehr, denke die fehlermeldung kommen wegen China
                                        • S
                                          S
                                          SaiBot1981
                                          #73
                                          Jetzt gehts auf einmal mit dem einloggen... aber es fehlen leider noch ein paar werte bei meinem Air Purifier 3H
                                          zB Keine Temperatur, das wäre sehr cool um meine Heuzungen im Wohnzimmer wesentlich genauer zu steuern
                                          84.1k
