  4. Test Adapter mihome-cloud
    6.7k
235 Beiträge 48 Kommentatoren 67.2k Aufrufe 46 Beobachtet
  • ? Offline
    Gerade im log entdeckt:
    mihome-cloud.0
    2022-11-15 16:39:54.478	error	Error: Client network socket disconnected before secure TLS connection was established at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/dist/node/axios.cjs:725:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/dist/node/axios.cjs:2467:25) at RedirectableRequest.emit (node:events:513:28) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:513:28) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:109:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28) at emitErrorNT (node:internal/streams/destroy:157:8) at emitErrorCloseNT (node:internal/streams/destroy:122:3)
    mihome-cloud.0
    2022-11-15 16:39:54.477	error	Error: Client network socket disconnected before secure TLS connection was established
    mihome-cloud.0
    2022-11-15 16:39:54.477	error	/miotspec/action
    • JackDanielJ Online
      JackDanielJ Online
      JackDaniel
      hier kommt das im log
      mihome-cloud.0
      2022-11-15 18:48:33.791	error	TypeError: service.properties is not iterable
      mihome-cloud.0
      2022-11-15 18:48:31.119	warn	Please report this url to the developer: https://cdn.alsgp0.fds.api.mi-img.com/rn-plugins/2020-12-08/signed_10047_1000570_39_IOS_bundle_e6776fdd671602f308b9be25d889bb0c.zip
      mihome-cloud.0
      2022-11-15 18:48:31.118	warn	Remote commmands too long for roborock.vacuum.s5
      mihome-cloud.0
      2022-11-15 18:47:50.056	error	Please set username and password in the instance settings
      Carpe diem
        thoml
        @tombox Mein Dreame L10S Ultra wird auch erkannt, nur werden sehr wenige Datenpunkte befüllt. Die befüllten Datenpunkte lassen sich aber auch steuern und werden auch sofort in der App aktualisiert.
        Es ist auch noch ein Wasserkocher hinterlegt.
        Falls du Zugriff auf die Geräte brauchst, gib eben bescheid.
        • T thoml
          tombox
          @thoml Ja Zugriff hilft immer beim debuggen
          tombox2020@gmail.com
          • ? Offline
            Mein Netzwerk ist mehrmals zusammengebrochen. Ich habe dann den Schuldigen gefunden. Es ist ioBroker mit der Abfrage nach de.api.io.mi.com
            Da kommt doch der Verdacht auf, dass das mit dem Abtauchen des Adapters zusammenhängt.
            Der meldet:
              tombox
              @hannnes Was sagt der log gibt es da ein fehler
              • T tombox
                @tombox
                dazu muss erwähnt werden, dass ich gerade AdGuard mit vielen neuen blacklisten ausgestattet habe.
                ![94938bc2-5ed7-4085-8aa5-87326685dca7-image.png](/assets/uploads/files/1668719436239-94938bc2-5ed7-4085-8aa5-87326685dca7-image-resized.png)
                ```2022-11-17 19:06:58.327 - error: host.HomeServer01 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                2022-11-17 19:06:59.243 - error: info.0 (3798) info.0 already running
                2022-11-17 19:07:01.830 - error: host.HomeServer01 instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-11-17 19:07:02.773 - info: javascript.0 (3744) received all states
                2022-11-17 19:07:04.202 - error: trashschedule.0 (3862) trashschedule.0 already running
                2022-11-17 19:07:04.209 - warn: trashschedule.0 (3862) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-11-17 19:07:05.361 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript_test: ReferenceError: Init is not defined
                2022-11-17 19:07:05.364 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:37:1
                2022-11-17 19:07:05.366 - error: javascript.0 (3744) at script.js.Geraete-Skripts.Xiaomi-Skript_test:484:3
                2022-11-17 19:07:05.367 - error: javascript.0 (3744) at Script.runInContext (node:vm:141:12)
                2022-11-17 19:07:08.717 - error: trashschedule.1 (3889) trashschedule.1 already running
                2022-11-17 19:07:09.598 - info: host.HomeServer01 instance system.adapter.mihome-cloud.0 started with pid 3941
                2022-11-17 19:07:10.109 - error: host.HomeServer01 instance system.adapter.trashschedule.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-11-17 19:07:10.309 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: You are already logged in, login canceled
                2022-11-17 19:07:10.311 - info: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Retrieving your in de registered MiHome Devices
                2022-11-17 19:07:10.329 - error: javascript.0 (3744) script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2: Error: Pls login before make any request
                2022-11-17 19:07:10.330 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
                2022-11-17 19:07:10.332 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
                2022-11-17 19:07:10.336 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.XIAOMI-SKRIPT-Versuch2:874:50)
                2022-11-17 19:07:10.338 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
                2022-11-17 19:07:10.382 - error: web.0 (3923) web.0 already running
                2022-11-17 19:07:10.377 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: You are already logged in, login canceled
                2022-11-17 19:07:10.378 - info: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Retrieving your in de registered MiHome Devices
                2022-11-17 19:07:10.385 - error: javascript.0 (3744) script.js.Geraete-Skripts.Xiaomi-Skript: Error: Pls login before make any request
                2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:67:13)
                2022-11-17 19:07:10.386 - error: javascript.0 (3744) at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:29)
                2022-11-17 19:07:10.387 - error: javascript.0 (3744) at Init (script.js.Geraete-Skripts.Xiaomi-Skript:874:50)
                2022-11-17 19:07:10.393 - error: javascript.0 (3744) at processTicksAndRejections (node:internal/process/task_queues:96:5)
                2022-11-17 19:07:11.834 - error: host.HomeServer01 instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-11-17 19:07:11.835 - info: host.HomeServer01 Restart adapter system.adapter.web.0 because enabled
                2022-11-17 19:07:15.632 - error: mihome-cloud.0 (3941) mihome-cloud.0 already running
                2022-11-17 19:07:15.663 - warn: mihome-cloud.0 (3941) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2022-11-17 19:07:16.385 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2022-11-17 19:07:16.386 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
                2022-11-17 19:07:54.479 - info: mihome-cloud.0 (4337) Login to MiHome Cloud
                2022-11-17 19:07:59.792 - error: mihome-cloud.0 (4337) Error: getaddrinfo EAI_AGAIN account.xiaomi.com
                2022-11-17 19:07:59.804 - error: mihome-cloud.0 (4337) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2022-11-17 19:07:59.810 - error: mihome-cloud.0 (4337) unhandled promise rejection: Cannot read properties of undefined (reading '_sign')
                2022-11-17 19:07:59.817 - error: mihome-cloud.0 (4337) TypeError: Cannot read properties of undefined (reading '_sign')
                at MihomeCloud.login (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:133:20)
                at async MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:91:5)
                2022-11-17 19:07:59.818 - error: mihome-cloud.0 (4337) Cannot read properties of undefined (reading '_sign')
                2022-11-17 19:07:59.844 - info: mihome-cloud.0 (4337) terminating
                2022-11-17 19:07:59.847 - warn: mihome-cloud.0 (4337) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2022-11-17 19:08:00.491 - error: host.HomeServer01 instance system.adapter.mihome-cloud.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2022-11-17 19:08:00.492 - info: host.HomeServer01 Restart adapter system.adapter.mihome-cloud.0 because enabled
                  @tombox
                  tombox
                  @hannnes Ok das Problem ist abgefangen
                  • T tombox
                    @tombox
                    ich hab ne Verständnisfrage: Wie fängst Du das Problem ab ohne dass ich neu installieren muss? Oder soll ich neu installieren?
                      @tombox
                      tombox
                      @hannnes Ich habe es in der GitHub version abgefangen. Wenn du die Änderung haben möchtest musst du neuinstallierten
                      • T tombox
                        @tombox
                        Ah, ok. Du verbesserst, ohne die Version hochzuziehen. Jetzt löst sich ein Rätsel 😜
                          michael 1975
                          @tombox ich habe heute den xiaomi Futterautomat hinzugefügt hier diesen kann ich leider auch nicht drüber steuern, kannst du mir hier auch helfen was bräuchtest du von mir?
                          Gruß Michael
                          • M michael 1975
                            Gruß Michael
                            tombox
                            @michael-1975 wenn du das gerät sharen kannst dann mit mir sharen tombox2020@gmail.com oder wenigsten die Modell Nummer des Geräts
                            M 2 Antworten Letzte Antwort
                            • T tombox
                              michael 1975
                              @tombox habe ich gerade gemacht sollte bei dir sein wenn ich noch was machen kann sage es bitte.
                              • T tombox
                                thoml
                                schrieb am zuletzt editiert von thoml
                                hat sich erledigt..
                                • dontobiD Offline
                                  dontobiD Offline
                                  dontobi
                                  Hallo zusammen
                                  Ich habe den Adapter nun auch Mal installiert. Ich nutze lediglich einen Air Purifier 2H. Bei den ersten Tests sind mir ein paar Kleinigkeiten aufgefallen. Dazu werde ich auf GitHub ein Issue erstellen, wenn ich alles getestet habe.
                                  Ich möchte an dieser Stelle ein großes Dankeschön an den Entwickler schicken.
                                  Gruß aus dem Rheinland
                                  Tobi
                                  Smart Home Zentrale: Raspberry Pi 4 4GB
                                  Meine Homepage: https://www.myHome.zone
                                  • T tombox
                                    michael 1975
                                    @tombox hat das mit dem Teilen geklappt, bin noch am überlegen den Trinkbrunnen zu holen da wäre sicher das selbe.
                                    Danke für deine Mühe
                                    • M michael 1975
                                      tombox
                                      @michael-1975 Jap komme aber später erst dazu mir das anzuschauen
                                        tequila74
                                        ich wollte den Adapter nun auch mal testen, um meinen Dreame D9 in ioBroker zu bekommen.
                                        Nur leider scheitert es bei mir schon mit der Anmeldung am Server.
                                        Bekomme immer einen error mit "No sign in first step"
                                        Server in der App & Adapter ist Deutschland.
                                        Stefan
                                        • T tequila74
                                          Stefan
                                          SaiBot1981
                                          #66
                                          @tequila74 sagte in Test Adapter mihome-cloud:
                                          Stefan
                                          Wollte den Adapter auch testen und bekomme den gleichen Fehler
