  3. Einsteigerfragen
  4. *gelöst* Zigbee Adapter läuft nicht mehr nach
    5.6k
132 Beiträge 4 Kommentatoren 9.1k Aufrufe 3 Beobachtet
  • G Offline
    gluecksmann
    schrieb am zuletzt editiert von gluecksmann
    pi@raspberrypi:~ $ iobroker status
    Objects type: jsonl
    States  type: jsonl
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
      system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
      system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    pi@raspberrypi:~ $
    • G gluecksmann
      Objects type: jsonl
      States  type: jsonl
      pi@raspberrypi:~ $
      + instance is alive
      pi@raspberrypi:~ $
      @gluecksmann
      Wie stellt sich der Adapter bei einem (Neu)-Start im log file dar?
      Mit
      iobroker logs --watch | uniq
      kann man das beobachten.
      G 1 Antwort Letzte Antwort
        @gluecksmann
        Mit
        gluecksmann
        warum auch imer...ist er jetzt grün geworden...
        Jetzt muß ich nur noch meine alte VIS wiederherstellen... oder ich versuche mal die von Sigi aus... wie würde es ablaufen wenn ich meine wiederherstellen möchte? war ja was mit extrahieren?!
        • G gluecksmann
          @gluecksmann
          Vermutlich hat sich der zigbee-Adapter in der Zwischenzeit selber 'neugebaut'.
          Zu vis kann ich dir nix sagen, hier läuft keine.
          • crunchipC Abwesend
            crunchipC Abwesend
            @gluecksmann dein backup entpacken und die vis-view-json wieder reinladen
              gluecksmann
              @crunchip
              Und jetzt noch mal für DAUs ... ich gehe in den Backup Adapter.. da kann ich die entsprechende Backupdatei runterladen? Und dann weiter?
              • G gluecksmann
                @crunchip
                crunchipC Abwesend
                crunchipC Abwesend
                @gluecksmann du holst dir deine tar.gz auf deinen Rechner, entpackst diese mit einem zip Programm, darin enthalten sind dann deine einzelnen Dateien, die vis-view-json musst du dann in deinen iobroker wieder hochladen per Dateimanager
                  gluecksmann
                  @crunchip
                  Scheitere am entpacken...hab 7 Zip runtergeladen...
                  • G gluecksmann
                    @crunchip
                    @gluecksmann sagte in *gelöst* Zigbee Adapter läuft nicht mehr nach:
                    7zip kann prinzipiell mit tar.gz umgehen.
                    Obacht, das sind ggf. zwei Dateien, das gz entpackt zu einem tar, das muss dann nochmal entpackt werden.
                    Einfacher ist die Konsole:
                    tar xzvf dein_backup.tar.gz
                    • G gluecksmann
                      @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @gluecksmann geht doch, habs grad probiert, die Datei entpacken, dann wird ein Ordner erstellt, darin diese Datei nochmal entpacken, danach sind in dem Ordner alle Dateien, danach im Ordner files findest du den Ordner vis.0
                        gluecksmann
                        @crunchip
                        Die DAtei habe ich inzwischen... aber wie/wo ist der DAteimanager?
                        • G gluecksmann
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          https://forum.iobroker.net/post/888878
                          dein vis editor
                            dein vis editor
                            gluecksmann
                            @crunchip
                            er sagt ich kann nur in vis.0 hochladen... mache ich dieses, sehe ich aber die Datei nicht...
                            • G gluecksmann
                              @crunchip
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @gluecksmann hast du ein vorhandenes Projekt? (in der Regel main)
                                gluecksmann
                                @crunchip
                                Ja, aber das kann weg..bzw überschrieben werden...was auch immer
                                • G gluecksmann
                                  @crunchip
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @gluecksmann du kannst auch dein komplettes Projekt aus der Datei importieren
                                    gluecksmann
                                    @crunchip
                                    meinst alle views? wäre schön
                                    • G gluecksmann
                                      @crunchip
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @gluecksmann na freilich, dafür machen wir das doch gerade
                                      in deinem Ordner xyz\backup\files\vis.0 liegen doch alle Dateien, dort auch dein komplettes Projekt, dies kannst du importieren
                                      G 2 Antworten Letzte Antwort
                                        gluecksmann
                                        @crunchip
                                        bleibt immer noch die Frage, wie.... die von mir ins Mainverzeichnis geladene DAtei taucht nicht auf...
                                        • G gluecksmann
                                          @crunchip
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @gluecksmann d6d726df-4a06-4dae-b25b-6d1aa19feadd-image.png 52c755ce-b74d-462d-9287-864bc6c5f0e1-image.png
