  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 307.8k Aufrufe 40 Beobachtet
  • T tritor
    Testposting: v 0.0.5
    *** BASE SYSTEM ***
    CPU-Architecture: x86_64
    Docker: false
    Virtualization: kvm
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 10 (buster)
    Release:	10
    Codename:	buster
    PRETTY_NAME="Debian GNU/Linux 10 (buster)"
    NAME="Debian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     11:26:15 up 106 days, 11:30,  2 users,  load average: 0.71, 0.60, 0.53
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Nov  7 10:26:15 UTC 2022
    Mon Nov  7 11:26:15 CET 2022
    CET +0100
    Europe/Vienna
    *** User and Groups ***
    gxxxxx
    /home/gxxxxx
    gxxxxx cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server: false
    Desktop:
    Konsole: tty
    *** MEMORY ***
    Mem:           8.0G        4.2G        1.2G         65M        2.6G        3.5G
    Swap:          8.2G         13M        8.2G
    Total:          16G        4.2G        9.4G
             7978 M total memory
             4160 M used memory
             4661 M active memory
             1557 M inactive memory
             1199 M free memory
              340 M buffer memory
             2278 M swap cache
             8189 M total swap
               13 M used swap
             8176 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     798M   79M  720M  10% /run
    /dev/sda1      ext4       55G  8.3G   44G  16% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    tmpfs          tmpfs     798M     0  798M   0% /run/user/1001
    tmpfs          tmpfs     798M     0  798M   0% /run/user/1000
    /var:
    [sudo] password for gxxxxx:
    628M	/var/
    318M	/var/cache
    311M	/var/cache/apt
    278M	/var/lib
    250M	/var/cache/apt/archives
    /opt/iobroker/backups:
    143M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    740M	/opt/iobroker/iobroker-data/
    502M	/opt/iobroker/iobroker-data/files
    156M	/opt/iobroker/iobroker-data/backup-objects
    146M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js
    The five biggest files in iobroker-data:
     25M objects.jsonl
     22M states.jsonl
     14M objects.json.migrated
     14M objects.json.bak.migrated
    3.6M states.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.18.0
    /usr/bin/node 		v16.18.0
    /usr/bin/npm 		8.19.2
    nodejs:
      Installed: 16.18.0-deb-1nodesource1
      Candidate: 16.18.0-deb-1nodesource1
      Version table:
     *** 16.18.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
         10.24.0~dfsg-1~deb10u2 500
            500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
         10.24.0~dfsg-1~deb10u1 500
            500 http://deb.debian.org/debian buster/main amd64 Packages
    *** ioBroker-Installation ***
    Core adapters versions
    js-controller: 	4.0.23
    admin: 		6.2.23
    + system.adapter.admin.0                  : admin                 : ioBroker-prox                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.cul.0                    : cul                   : ioBroker-prox                            -  enabled, port: 23
    + system.adapter.hue.0                    : hue                   : ioBroker-prox                            -  enabled, port: 80
    + system.adapter.influxdb.0               : influxdb              : ioBroker-prox                            -  enabled, port: 8086
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-prox                            -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-prox                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.proxmox.0                : proxmox               : ioBroker-prox                            -  enabled, port: 8006
    + system.adapter.rest-api.0               : rest-api              : ioBroker-prox                            -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.shelly.0                 : shelly                : ioBroker-prox                            -  enabled, port: 1888, bind: 0.0.0.0
    + system.adapter.sia.0                    : sia                   : ioBroker-prox                            -  enabled, port: 50001, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : ioBroker-prox                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : ioBroker-prox                            -  enabled, port: 3306
    + system.adapter.synology.0               : synology              : ioBroker-prox                            -  enabled, port: 5001
    + system.adapter.web.0                    : web                   : ioBroker-prox                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker-prox                            -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2483232-if00
    ioBroker-Repositories
    Active repo(s): beta
    ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "asuswrt"      : 1.0.1    , installed 1.0.1
    Adapter    "backitup"     : 2.5.4    , installed 2.5.4
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cul"          : 2.0.2    , installed 2.0.2
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "devices"      : 1.1.1    , installed 1.1.1
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "epson_ecotank_et_2750": 0.0.12, installed 0.0.12
    Adapter    "fuelpricemonitor": 0.3.1 , installed 0.3.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "info"         : 1.9.21   , installed 1.9.21
    Adapter    "iot"          : 1.12.4   , installed 1.12.4
    Adapter    "javascript"   : 6.1.3    , installed 6.1.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "material"     : 1.2.5    , installed 1.2.5
    Adapter    "mercedesme"   : 0.0.59   , installed 0.0.59
    Adapter    "mihome-vacuum": 3.8.3    , installed 3.8.3
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "nut"          : 1.5.1    , installed 1.5.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
    Adapter    "shelly"       : 6.2.4    , installed 6.2.4
    Adapter    "sia"          : 1.0.4    , installed 1.0.4
    Adapter    "snmp"         : 2.2.1    , installed 2.2.1
    Adapter    "socketio"     : 6.1.10   , installed 6.1.10
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "vaillant"     : 0.0.17   , installed 0.0.17
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 5.2.10   , installed 5.2.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wlanthermo-nano": 0.2.1  , installed 0.2.1
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 2.1.5    , installed 2.1.5
    Adapter    "yahka"        : 0.17.0   , installed 0.17.0
    Adapter    "zigbee"       : 1.7.6    , installed 1.7.6
    Objects and States
    Objects: 	18466
    States: 	15762
    Hit:1 http://deb.debian.org/debian buster InRelease
    Hit:2 http://deb.debian.org/debian-security buster/updates InRelease
    Hit:3 http://deb.debian.org/debian buster-updates InRelease
    Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists... Done
    Pending Updates: 16
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          14295      405/vsftpd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          117154238  9639/sshd
    tcp        0      0 127.0.0.1:36343         0.0.0.0:*               LISTEN      1001       292293130  6556/io.yahka.0
    tcp        0      0 0.0.0.0:9080            0.0.0.0:*               LISTEN      1001       292362104  6223/nc
    tcp        0      0 127.0.0.1:38073         0.0.0.0:*               LISTEN      1001       288402685  6556/io.yahka.0
    tcp        0      0 0.0.0.0:45661           0.0.0.0:*               LISTEN      1001       246826580  6556/io.yahka.0
    tcp        0      0 127.0.0.1:43455         0.0.0.0:*               LISTEN      1001       287534097  6556/io.yahka.0
    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       285459326  27893/io.shelly.0
    tcp        0      0 127.0.0.1:45857         0.0.0.0:*               LISTEN      1001       287272939  6556/io.yahka.0
    tcp        0      0 127.0.0.1:39651         0.0.0.0:*               LISTEN      1001       291413111  6556/io.yahka.0
    tcp        0      0 127.0.0.1:34407         0.0.0.0:*               LISTEN      1001       289318830  6556/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       117177033  18016/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       117177026  18016/iobroker.js-c
    tcp        0      0 127.0.0.1:40459         0.0.0.0:*               LISTEN      1001       289269183  6556/io.yahka.0
    tcp        0      0 127.0.0.1:38703         0.0.0.0:*               LISTEN      1001       291811979  6556/io.yahka.0
    tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       117184279  20652/io.sia.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          117154249  9639/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       246837050  10026/io.simple-api
    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       117224023  1952/io.rest-api.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       252054002  647/io.harmony.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       246837870  10233/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       246834847  9211/io.web.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       285459017  27537/io.mihome-vac
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       252054003  647/io.harmony.0
    udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       117184280  20652/io.sia.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       246826577  6556/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       117184431  20687/io.wled.0
    #234
    @tritor
    Danke. Aber könntest du auch noch die SUMMARY hinzufügen?
    Die ermittelten Werte sind soweit stimmig?
      @tritor
      T Nicht stören
      T Nicht stören
      tritor
      #235
      gere we go:
      ========================= SUMMARY ======================
      v.0.0.5
      Operatingsystem: 	Debian GNU/Linux 10 (buster)
      Installation: 		kvm
      Timezone: 		Europe/Vienna
      User-ID: 		1000
      X-Server: 		false
      Nodejs-Installation: 	/usr/bin/nodejs 	v16.18.0
      			/usr/bin/npm 		8.19.2
      ioBroker Core: 		js-controller 		4.0.23
      					admin: 	6.2.23
      Objects: 		18466
      States: 		15762
      Size of iob-Database:
       12K backup-objects
         0 objects.json.broken
      4.0K objects.json.old
       33M objects.jsonl
      4.0K objects.jsonl.lock
      3.6M states.json.bak.migrated
         0 states.json.broken
      2.7M states.json.old
       22M states.jsonl
      4.0K states.jsonl.lock
      Gernot
      Host: i9 server Proxmox , Debian 13.4 for ioBroker
      ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
      Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
      Grafana 13.0.1 / InfluxDB 2.8.0
      • T tritor
        gere we go:
        v.0.0.5
        Installation: 		kvm
        User-ID: 		1000
        X-Server: 		false
        			/usr/bin/npm 		8.19.2
        					admin: 	6.2.23
        Objects: 		18466
        States: 		15762
         12K backup-objects
         33M objects.jsonl
         22M states.jsonl
        #236
        @tritor sagte in iob diag - Skript:
        An der Stelle muss ich aus optischen Gründen noch ran.
        Das soll natürlich fluchten.
        					admin: 	6.2.23
        @all
        Sonst noch Adapter, die man als 'Core' bezeichnen könnte? javaskript z. B.?
        OstfrieseUnterwegsO 1 Antwort Letzte Antwort
          					admin: 	6.2.23
          @all
          OstfrieseUnterwegsO Offline
          OstfrieseUnterwegs
          #237
          @thomas-braun sagte in iob diag - Skript:
          Wenn ich das richtig verstehe soll die Diagnose ja den Helfern Hinweise geben, was möglicherweise ein Grund für unerwartetes Verhalten von ioBroker sein kann.
          Das Ganze läuft dann quasi in zwei Stufen ab:
          • 1: Lass mal die Diagnose laufen und poste die Zusammenfassung.
            Daran sollte dann erkennbar sein, ob da was grundsätzliches falsch läuft wie unendlich viele Updates die in der Schlange warten, altes oder nicht unterstütztes OS oder eine vermurkste node Installation. Und auch ob Docker etc.
          • 2: Schick mal die Ausgabe der vollen Diagnose
          Ich glaube, was für die jeweiligen Stufen wichtig ist, wird die Zeit zeigen.
          • OstfrieseUnterwegsO OstfrieseUnterwegs
            HomoranH Offline
            HomoranH Offline
            #238
            @ostfrieseunterwegs wobei ich eigentlich das full diag gerne schon im Eröffnungsposts haben würde und dies auch entsprechend hier
            anfordern werde
              v0.0.5 ist raus, jetzt in Änglisch! 🇬🇧
              E Online
              E Online
              emil70
              #239
              Bleibt das jetzt nur in Englisch oder gibt es dann auch in deutsch?
              Abhängig welche Sprache mal gewählt hat
              gruss emil70
              iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
              apollon77A Thomas BraunT HomoranH 3 Antworten Letzte Antwort
              • E emil70
                #240
                @emil70 Ich bin dafür es auf Englisch zu belassen ...
                • E emil70
                  #241
                  @emil70 sagte in iob diag - Skript:
                  Das multilingual zu skripten ist (mir) zu aufwändig.
                  Deswegen erstmal nur Englisch.
                  Um das mehrsprachig zu haben müsstest du entweder jeden String als Variable anlegen und den eigentlichen Text in einer Sprachdatei haben oder je nach Sprache ein eigenes Skript pflegen. Ist beides recht aufwändig.
                  • E Online
                    E Online
                    emil70
                    #242
                    In meinen Augen gehört da auch deutsch mit rein. Soviel muss da dann auch nicht angepasst werden
                    gruss emil70
                    Thomas BraunT andreA 2 Antworten Letzte Antwort
                    • E emil70
                      #243
                      Dann forke es...
                      Ich hab es gerade von Deutsch auf Englisch umgestellt...
                      Das Layout muss dann auch angepasst werden, weil die Ausdrücke in den Sprachen ja länger oder kürzer sein können.
                      • E emil70
                        HomoranH Offline
                        HomoranH Offline
                        #244
                        @emil70 um die Ergebnisse richtig aus dem Kontext einer Datei/Rückgabe eines Befehls auszulesen muss ja z.B. die Anzahl Zeichen an die Worte der gewählten Sprache angepasst werden. Oder auch die "Ankerworte" für ein RegEx müssten sprachspezifisch angewandt werden.
                        Das ist ein Heidenaufwand.
                        • E emil70
                          andreA Offline
                          andreA Offline
                          andre
                          schrieb am zuletzt editiert von andre
                          #245
                          Die komplette Entwicklung und der Großteil der Issues bei ioBroker findet in englisch statt... Da ist es nur logisch, dass der Diagnosetext auch in englisch ist. Die Ausgabe ist ja nicht für den User, sondern für den Support gedacht...
                          Aufgrund der Anzahl deutsprachiger User wäre es aber m. E. durchaus denkbar, zumindest die Info und Anweisungen in zweisprachig auszugeben... Obwohl sich mir auch nicht erschließt, warum man für "press enter" eine übersetzung benötigt...
                          MfG,
                          André
                          ? E 2 Antworten Letzte Antwort
                            #246
                            @thomas-braun lass es bloss auf Englisch.. das gibt sonst nur ein Kauderwelsch... die meisten Fehlermeldungen selbst vom auf Deutsch eingestellten Linux System sind in Englisch..
                              #247
                              @homoran sagte in iob diag - Skript:
                              Oder such die "Ankerworte" für ein RegEx müssten sprachspezifisch angewandt werden.
                              Nee, das nicht. Die skript-interne Verarbeitung läuft immer auf Englisch ab, da passen dann die RegExes immer.
                              Aber das Layout der Ausgabe ist tricky.
                              • andreA andre
                                MfG,
                                André
                                #248
                                @andre sagte in iob diag - Skript:
                                ....Anweisungen in zweisprachig auszugeben... Obwohl sich mir auch nicht erschließt, warum man für "press enter" eine übersetzung benötigt...
                                Drueck en Knopp, Alter! oder so?
                                Nee net SHIFT - Drueck die Ausfuehren oder Eintritts Taste.. oder wie wuerde man ENTER uebersetzen..?
                                Was steht denn auf m deutschen Keyboard? (sorry hab keins.. :-) arbeite immer mit US...
                                andreA 1 Antwort Letzte Antwort
                                  andreA Offline
                                  andreA Offline
                                  andre
                                  #249
                                  @ilovegym sagte in iob diag - Skript:
                                  Wie wäre es mit der "Betreten Taste"??? 😁
                                  https://de.langenscheidt.com/englisch-deutsch/enter
                                  • andreA andre
                                    #250
                                    @andre
                                    'Pressen Sie die Betreten-Taste'
                                    • HomoranH Offline
                                      HomoranH Offline
                                      #251
                                      und wo finde i h den "any-Key" 🔑 ?
                                        #252
                                        und wo finde i h den "any-Key" ?
                                        On any keyboard, natürlich!
                                        • andreA andre
                                          MfG,
                                          André
                                          E Online
                                          E Online
                                          emil70
                                          #253
                                          MfG,
                                          André
                                          Genau das meine ich.
                                          gruss emil70
