  4. Zeigt her eure Views zum Thema Mähroboter
vis
780 Beiträge 70 Kommentatoren 302.5k Aufrufe 74 Beobachtet
  • H Hausbaer
    @hsteinme
    Die Zeitpläne in den Objekten sind immer vorhanden gewesen.
    Nur: Wenn ich in die App gehe, sind die Zeitpläne regelmäßig verschwunden, die Felder ausgegraut.
    Und komisch: Verhalten bei beiden Mähern gleich.
    Allerdings ist ein Landi derzeit wohl offline, das werde ich heute abend prüfen.
    Beim anderen Worx lief der Start - nachdem ich heute morgen händisch über die App wieder Zeiten zugewiesen haben - problemlos.
    Hier das Log in der betroffenen Zeit:
    worx.0
    2022-06-14 09:03:57.129
    debug
    Onlinecheck: couldnt get data StatusCodeError: 401 - {"message":"Unauthorized","code":"401.000"}
    worx.0
    2022-06-14 09:02:59.230
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.raw_messages_out" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.228
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.raw_messages_in" has to be stringified but received type "number"
    worx.0
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.messages_out" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.226
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.messages_in" has to be stringified but received type "number"
    worx.0
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.battery_charge_cycles_reset" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.225
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.battery_charge_cycles" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.224
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.blade_work_time_reset" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.223
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.blade_work_time" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.221
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.mower_work_time" has to be stringified but received type "number"
    worx.0
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.distance_covered" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.208
    info
    State value to set for "worx.0.222222222222222222CV.rawMqtt.raw.lawn_perimeter" has to be stringified but received type "number"
    worx.0
    2022-06-14 09:02:59.164
    info
    undefined is not a valid state value for id "worx.0.222222222222222222CV.rawMqtt.weatherdata"
    worx.0
    2022-06-14 09:02:59.089
    debug
    Test Status: 1
    worx.0
    2022-06-14 09:02:59.088
    debug
    GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"09:02:58","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"222222222222222222CV","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"A8032A562A94","fw":3.26,"fwb":1,"bt":{"t":14,"v":19.01,"p":100,"nr":82,"c":0,"m":1},"dmp":[-1.4,-2.1,297.8],"st":{"b":7272,"d":118797,"wt":7917,"bl":98},"ls":1,"le":0,"lz":0,"rsi":-45,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}
    worx.0
    2022-06-14 09:02:59.087
    debug
    Worxcloud MQTT get Message for mower Bärbel (222222222222222222CV)
    worx.0
    2022-06-14 09:02:57.141
    debug
    worx.0
    2022-06-14 09:02:18.212
    info
    worx.0
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.211
    info
    worx.0
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.210
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.209
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.206
    info
    worx.0
    2022-06-14 09:02:18.199
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.198
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.197
    info
    worx.0
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.196
    info
    worx.0
    info
    worx.0
    2022-06-14 09:02:18.195
    info
    worx.0
    2022-06-14 09:02:18.193
    info
    worx.0
    2022-06-14 09:02:15.173
    info
    worx.0
    2022-06-14 09:02:15.172
    info
    worx.0
    2022-06-14 09:02:15.171
    info
    worx.0
    2022-06-14 09:02:15.170
    info
    worx.0
    2022-06-14 09:02:15.169
    info
    worx.0
    2022-06-14 09:02:15.168
    info
    worx.0
    2022-06-14 09:02:15.167
    info
    worx.0
    2022-06-14 09:02:15.166
    info
    worx.0
    2022-06-14 09:02:15.165
    info
    worx.0
    2022-06-14 09:02:15.164
    info
    worx.0
    2022-06-14 09:02:15.159
    info
    worx.0
    2022-06-14 09:02:14.979
    info
    worx.0
    2022-06-14 09:02:14.955
    info
    worx.0
    2022-06-14 09:02:14.746
    info
    worx.0
    2022-06-14 09:02:14.664
    debug
    Test Status: 1
    worx.0
    2022-06-14 09:02:14.663
    debug
    GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"09:01:59","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"222222222222222222CV","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"A8032A562A94","fw":3.26,"fwb":1,"bt":{"t":13.9,"v":19,"p":100,"nr":82,"c":0,"m":1},"dmp":[-1.4,-2.1,297.8],"st":{"b":7272,"d":118797,"wt":7917,"bl":98},"ls":1,"le":0,"lz":0,"rsi":-45,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}
    worx.0
    2022-06-14 09:02:14.662
    debug
    worx.0
    2022-06-14 09:02:14.592
    debug
    Test Status: 1
    worx.0
    2022-06-14 09:02:14.591
    debug
    worx.0
    2022-06-14 09:02:14.590
    debug
    worx.0
    2022-06-14 09:02:14.005
    debug
    Test Status: 1
    worx.0
    2022-06-14 09:02:14.004
    debug
    worx.0
    2022-06-14 09:02:14.003
    debug
    worx.0
    2022-06-14 09:01:57.099
    debug
    worx.0
    2022-06-14 09:00:57.144
    debug
    worx.0
    2022-06-14 09:00:32.405
    info
    undefined is not a valid state value for id "worx.0.1111111111111111111XY.rawMqtt.weatherdata"
    worx.0
    2022-06-14 09:00:32.342
    debug
    Test Status: 7
    worx.0
    debug
    GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"09:00:32","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":12.4,"v":19.76,"p":100,"nr":298,"c":0,"m":1},"dmp":[-2.2,-4.1,357.4],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":7,"le":0,"lz":0,"rsi":-81,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":132,"l":132}}}
    worx.0
    2022-06-14 09:00:32.340
    debug
    Worxcloud MQTT get Message for mower Egon (1111111111111111111XY)
    worx.0
    2022-06-14 09:00:29.739
    info
    worx.0
    2022-06-14 09:00:29.556
    debug
    Test Status: 7
    worx.0
    2022-06-14 09:00:29.555
    debug
    GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"09:00:30","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":12.4,"v":19.24,"p":100,"nr":298,"c":0,"m":1},"dmp":[3.7,-4.8,4.9],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":7,"le":0,"lz":0,"rsi":-81,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":132,"l":132}}}
    worx.0
    debug
    worx.0
    2022-06-14 08:59:57.085
    debug
    worx.0
    2022-06-14 08:58:57.032
    debug
    worx.0
    2022-06-14 08:57:57.004
    debug
    worx.0
    2022-06-14 08:57:08.579
    info
    worx.0
    2022-06-14 08:57:08.507
    debug
    Test Status: 1
    worx.0
    2022-06-14 08:57:08.506
    debug
    GET MQTT DATA from API: {"cfg":{"id":1,"lg":"it","tm":"08:57:09","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.6,"v":19.76,"p":100,"nr":298,"c":1,"m":1},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-80,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}
    worx.0
    2022-06-14 08:57:08.505
    debug
    worx.0
    2022-06-14 08:57:08.036
    debug
    test cfg: 2 valID: 1 val: 210 sval: 210
    worx.0
    2022-06-14 08:57:08.035
    debug
    Worxcloud MQTT sendMessage to 222222222222222222CV Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    2022-06-14 08:57:08.034
    debug
    state change: id_____ worx.0.222222222222222222CV.calendar.tuesday.workTime Mower 222222222222222222CV_____workTime______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"222222222222222222CV","online":true,"raw":{"id":516160,"product_id":49,"user_id":400137,"serial_number":"222222222222222222CV","mac_address":"A8032A562A94","name":"Bärbel","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":false,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":null,"registered_at":"2022-04-22 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"tube","input_type":"keyboard_tube","lock":true,"pin":true,"rain_delay":true,"chassis":"m_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_tube_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/A8032A562A94/commandIn","command_out":"PRM100/A8032A562A94/commandOut"},"warranty_registered":false,"purchased_at":null,"warranty_expires_at":null,"setup_location":{"latitude":49.85492329,"longitude":12.44519892},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":250,"lawn_perimeter":98,"auto_schedule_settings":{"boost":1,"irrigation":null,"soil_type":"silt","grass_type":null,"exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]}]},"nutrition":null},"auto_schedule":false,"distance_covered":118797,"mower_work_time":7917,"blade_work_time":7272,"blade_work_time_reset":0,"blade_work_time_reset_at":null,"battery_charge_cycles":82,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":190,"messages_out":7335,"raw_messages_in":1596,"raw_messages_out":7335,"created_at":"2020-11-17 01:35:01","updated_at":"2022-05-06 01:26:32"},"edgeCut":false,"mqtt_command_in":"PRM100/A8032A562A94/commandIn","mqtt_command_out":"PRM100/A8032A562A94/commandOut","message":{"cfg":{"id":0,"lg":"it","tm":"08:51:22","dt":"14/06/2022","sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"222222222222222222CV","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"A8032A562A94","fw":3.26,"fwb":1,"bt":{"t":13.4,"v":19.03,"p":100,"nr":82,"c":0,"m":1},"dmp":[-1.4,-2.2,297.8],"st":{"b":7272,"d":118797,"wt":7917,"bl":98},"ls":1,"le":0,"lz":0,"rsi":-45,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    worx.0
    2022-06-14 08:57:08.017
    debug
    worx.0
    debug
    Worxcloud MQTT sendMessage to 1111111111111111111XY Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    2022-06-14 08:57:08.016
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",210,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    2022-06-14 08:57:08.015
    debug
    state change: id_____ worx.0.1111111111111111111XY.calendar.tuesday.workTime Mower 1111111111111111111XY_____workTime______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"1111111111111111111XY","online":true,"raw":{"id":541690,"product_id":52,"user_id":400137,"serial_number":"1111111111111111111XY","mac_address":"F4CFA2A0F738","name":"Egon","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":true,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":"AAAA","registered_at":"2021-04-12 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"lcd","input_type":"keyboard_arrow_keys","lock":true,"pin":true,"rain_delay":true,"chassis":"l_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/F4CFA2A0F738/commandIn","command_out":"PRM100/F4CFA2A0F738/commandOut"},"warranty_registered":true,"purchased_at":"2021-04-06 00:00:00","warranty_expires_at":"2024-04-06 00:00:00","setup_location":{"latitude":49.8549685,"longitude":12.44541026},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":1200,"lawn_perimeter":211,"auto_schedule_settings":{"boost":0,"irrigation":false,"soil_type":"silt","grass_type":"mixed_species","exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]}]},"nutrition":null},"auto_schedule":false,"distance_covered":704555,"mower_work_time":39049,"blade_work_time":35341,"blade_work_time_reset":7946,"blade_work_time_reset_at":"2021-06-07 06:21:07","battery_charge_cycles":298,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":473,"messages_out":29970,"raw_messages_in":9399,"raw_messages_out":29970,"created_at":"2020-12-21 00:59:57","updated_at":"2022-06-03 01:31:33"},"edgeCut":false,"mqtt_command_in":"PRM100/F4CFA2A0F738/commandIn","mqtt_command_out":"PRM100/F4CFA2A0F738/commandOut","message":{"cfg":{"id":1,"lg":"it","tm":"08:57:06","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.7,"v":19.55,"p":100,"nr":298,"c":0,"m":0},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-80,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    worx.0
    2022-06-14 08:57:05.619
    info
    worx.0
    2022-06-14 08:57:05.509
    debug
    Test Status: 1
    worx.0
    2022-06-14 08:57:05.508
    debug
    GET MQTT DATA from API: {"cfg":{"id":1,"lg":"it","tm":"08:57:06","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.7,"v":19.55,"p":100,"nr":298,"c":0,"m":0},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-80,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}
    worx.0
    2022-06-14 08:57:05.506
    debug
    worx.0
    2022-06-14 08:57:05.034
    debug
    test cfg: 2 valID: 0 val: 09:00 sval: 09:00
    worx.0
    debug
    Worxcloud MQTT sendMessage to 222222222222222222CV Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    2022-06-14 08:57:05.033
    debug
    h: 09 m: 00
    worx.0
    2022-06-14 08:57:05.032
    debug
    state change: id_____ worx.0.222222222222222222CV.calendar.tuesday.startTime Mower 222222222222222222CV_____startTime______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"222222222222222222CV","online":true,"raw":{"id":516160,"product_id":49,"user_id":400137,"serial_number":"222222222222222222CV","mac_address":"A8032A562A94","name":"Bärbel","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":false,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":null,"registered_at":"2022-04-22 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"tube","input_type":"keyboard_tube","lock":true,"pin":true,"rain_delay":true,"chassis":"m_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_tube_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/A8032A562A94/commandIn","command_out":"PRM100/A8032A562A94/commandOut"},"warranty_registered":false,"purchased_at":null,"warranty_expires_at":null,"setup_location":{"latitude":49.85492329,"longitude":12.44519892},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":250,"lawn_perimeter":98,"auto_schedule_settings":{"boost":1,"irrigation":null,"soil_type":"silt","grass_type":null,"exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]}]},"nutrition":null},"auto_schedule":false,"distance_covered":118797,"mower_work_time":7917,"blade_work_time":7272,"blade_work_time_reset":0,"blade_work_time_reset_at":null,"battery_charge_cycles":82,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":190,"messages_out":7335,"raw_messages_in":1596,"raw_messages_out":7335,"created_at":"2020-11-17 01:35:01","updated_at":"2022-05-06 01:26:32"},"edgeCut":false,"mqtt_command_in":"PRM100/A8032A562A94/commandIn","mqtt_command_out":"PRM100/A8032A562A94/commandOut","message":{"cfg":{"id":0,"lg":"it","tm":"08:51:22","dt":"14/06/2022","sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"222222222222222222CV","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"A8032A562A94","fw":3.26,"fwb":1,"bt":{"t":13.4,"v":19.03,"p":100,"nr":82,"c":0,"m":1},"dmp":[-1.4,-2.2,297.8],"st":{"b":7272,"d":118797,"wt":7917,"bl":98},"ls":1,"le":0,"lz":0,"rsi":-45,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    worx.0
    2022-06-14 08:57:05.018
    debug
    worx.0
    debug
    Worxcloud MQTT sendMessage to 1111111111111111111XY Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    2022-06-14 08:57:05.017
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["09:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    debug
    h: 09 m: 00
    worx.0
    2022-06-14 08:57:05.016
    debug
    state change: id_____ worx.0.1111111111111111111XY.calendar.tuesday.startTime Mower 1111111111111111111XY_____startTime______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"1111111111111111111XY","online":true,"raw":{"id":541690,"product_id":52,"user_id":400137,"serial_number":"1111111111111111111XY","mac_address":"F4CFA2A0F738","name":"Egon","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":true,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":"AAAA","registered_at":"2021-04-12 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"lcd","input_type":"keyboard_arrow_keys","lock":true,"pin":true,"rain_delay":true,"chassis":"l_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/F4CFA2A0F738/commandIn","command_out":"PRM100/F4CFA2A0F738/commandOut"},"warranty_registered":true,"purchased_at":"2021-04-06 00:00:00","warranty_expires_at":"2024-04-06 00:00:00","setup_location":{"latitude":49.8549685,"longitude":12.44541026},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":1200,"lawn_perimeter":211,"auto_schedule_settings":{"boost":0,"irrigation":false,"soil_type":"silt","grass_type":"mixed_species","exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]}]},"nutrition":null},"auto_schedule":false,"distance_covered":704555,"mower_work_time":39049,"blade_work_time":35341,"blade_work_time_reset":7946,"blade_work_time_reset_at":"2021-06-07 06:21:07","battery_charge_cycles":298,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":473,"messages_out":29970,"raw_messages_in":9399,"raw_messages_out":29970,"created_at":"2020-12-21 00:59:57","updated_at":"2022-06-03 01:31:33"},"edgeCut":false,"mqtt_command_in":"PRM100/F4CFA2A0F738/commandIn","mqtt_command_out":"PRM100/F4CFA2A0F738/commandOut","message":{"cfg":{"id":1,"lg":"it","tm":"08:57:03","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["10:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.7,"v":19.55,"p":100,"nr":298,"c":0,"m":0},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-80,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    worx.0
    2022-06-14 08:57:02.586
    info
    worx.0
    2022-06-14 08:57:02.507
    debug
    Test Status: 1
    worx.0
    2022-06-14 08:57:02.506
    debug
    GET MQTT DATA from API: {"cfg":{"id":1,"lg":"it","tm":"08:57:03","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["10:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.7,"v":19.55,"p":100,"nr":298,"c":0,"m":0},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-80,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}
    worx.0
    debug
    worx.0
    2022-06-14 08:57:02.040
    debug
    test cfg: 2 valID: 2 val: false sval: 0
    worx.0
    2022-06-14 08:57:02.039
    debug
    Worxcloud MQTT sendMessage to 222222222222222222CV Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    2022-06-14 08:57:02.038
    debug
    state change: id_____ worx.0.222222222222222222CV.calendar.tuesday.borderCut Mower 222222222222222222CV_____borderCut______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"222222222222222222CV","online":true,"raw":{"id":516160,"product_id":49,"user_id":400137,"serial_number":"222222222222222222CV","mac_address":"A8032A562A94","name":"Bärbel","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":false,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":null,"registered_at":"2022-04-22 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"tube","input_type":"keyboard_tube","lock":true,"pin":true,"rain_delay":true,"chassis":"m_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_tube_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/A8032A562A94/commandIn","command_out":"PRM100/A8032A562A94/commandOut"},"warranty_registered":false,"purchased_at":null,"warranty_expires_at":null,"setup_location":{"latitude":49.85492329,"longitude":12.44519892},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":250,"lawn_perimeter":98,"auto_schedule_settings":{"boost":1,"irrigation":null,"soil_type":"silt","grass_type":null,"exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]},{"exclude_day":false,"slots":[{"start_time":1260,"duration":180,"reason":"generic"},{"start_time":0,"duration":420,"reason":"generic"}]}]},"nutrition":null},"auto_schedule":false,"distance_covered":118797,"mower_work_time":7917,"blade_work_time":7272,"blade_work_time_reset":0,"blade_work_time_reset_at":null,"battery_charge_cycles":82,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":190,"messages_out":7335,"raw_messages_in":1596,"raw_messages_out":7335,"created_at":"2020-11-17 01:35:01","updated_at":"2022-05-06 01:26:32"},"edgeCut":false,"mqtt_command_in":"PRM100/A8032A562A94/commandIn","mqtt_command_out":"PRM100/A8032A562A94/commandOut","message":{"cfg":{"id":0,"lg":"it","tm":"08:51:22","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":0,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["10:00",150,0],["09:30",105,0],["00:00",0,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"222222222222222222CV","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"A8032A562A94","fw":3.26,"fwb":1,"bt":{"t":13.4,"v":19.03,"p":100,"nr":82,"c":0,"m":1},"dmp":[-1.4,-2.2,297.8],"st":{"b":7272,"d":118797,"wt":7917,"bl":98},"ls":1,"le":0,"lz":0,"rsi":-45,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    worx.0
    2022-06-14 08:57:02.026
    debug
    worx.0
    2022-06-14 08:57:02.024
    debug
    Worxcloud MQTT sendMessage to 1111111111111111111XY Message: {"sc":{"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["10:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}}
    worx.0
    debug
    Mowing time change at d to: {"m":1,"distm":0,"p":0,"d":[["00:00",0,0],["00:00",0,0],["10:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]}
    worx.0
    2022-06-14 08:57:02.022
    debug
    state change: id_____ worx.0.1111111111111111111XY.calendar.tuesday.borderCut Mower 1111111111111111111XY_____borderCut______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"1111111111111111111XY","online":true,"raw":{"id":541690,"product_id":52,"user_id":400137,"serial_number":"1111111111111111111XY","mac_address":"F4CFA2A0F738","name":"Egon","locked":false,"firmware_version":3.26,"firmware_auto_upgrade":true,"push_notifications":true,"sim":null,"push_notifications_level":"warning","test":0,"iot_registered":true,"mqtt_registered":true,"pin_code":"AAAA","registered_at":"2021-04-12 00:00:00","online":true,"app_settings":null,"accessories":null,"features":{"provisionable":true,"wifi_pairing":"smartconfig","tracking_firmware":true,"provisioning_replaceable":true,"rain_delay_start":3.08,"mac_address":true,"safe_go_home":3.25,"unrestricted_mowing_time":true,"multi_zone":true,"multi_zone_percentage":true,"multi_zone_zones":4,"mqtt":true,"display_type":"lcd","input_type":"keyboard_arrow_keys","lock":true,"pin":true,"rain_delay":true,"chassis":"l_2019","one_time_scheduler":3.15,"scheduler_two_slots":3.15,"auto_lock":3.25,"digital_fence_settings":3.25,"wifi_connection":"smartlink_display","bluetooth_pairing":true},"pending_radio_link_validation":null,"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"PRM100/F4CFA2A0F738/commandIn","command_out":"PRM100/F4CFA2A0F738/commandOut"},"warranty_registered":true,"purchased_at":"2021-04-06 00:00:00","warranty_expires_at":"2024-04-06 00:00:00","setup_location":{"latitude":49.8549685,"longitude":12.44541026},"city":{"id":2905971,"country_id":276,"name":"Hermannsreuth","latitude":49.832111,"longitude":12.47017,"created_at":"2018-02-15 22:24:59","updated_at":"2018-02-15 22:24:59"},"time_zone":"Europe/Berlin","lawn_size":1200,"lawn_perimeter":211,"auto_schedule_settings":{"boost":0,"irrigation":false,"soil_type":"silt","grass_type":"mixed_species","exclusion_scheduler":{"exclude_nights":true,"days":[{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]},{"exclude_day":false,"slots":[]}]},"nutrition":null},"auto_schedule":false,"distance_covered":704555,"mower_work_time":39049,"blade_work_time":35341,"blade_work_time_reset":7946,"blade_work_time_reset_at":"2021-06-07 06:21:07","battery_charge_cycles":298,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":null,"messages_in":473,"messages_out":29970,"raw_messages_in":9399,"raw_messages_out":29970,"created_at":"2020-12-21 00:59:57","updated_at":"2022-06-03 01:31:33"},"edgeCut":false,"mqtt_command_in":"PRM100/F4CFA2A0F738/commandIn","mqtt_command_out":"PRM100/F4CFA2A0F738/commandOut","message":{"cfg":{"id":0,"lg":"it","tm":"08:51:16","dt":"14/06/2022","sc":{"m":1,"distm":0,"ots":{"bc":1,"wtm":0},"p":0,"d":[["00:00",0,0],["00:00",0,0],["10:00",75,0],["00:00",0,0],["10:00",75,0],["10:00",75,0],["10:00",75,0]],"dd":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"1111111111111111111XY","al":{"lvl":0,"t":60},"tq":0},"dat":{"mac":"F4CFA2A0F738","fw":3.26,"fwb":1,"bt":{"t":11.7,"v":19.55,"p":100,"nr":298,"c":0,"m":0},"dmp":[1.7,-5.1,27.6],"st":{"b":35341,"d":704561,"wt":39049,"bl":211},"ls":1,"le":0,"lz":0,"rsi":-84,"lk":0,"act":1,"tr":0,"conn":"wifi","rain":{"s":0,"cnt":0},"time":{"r":0,"l":0}}}}
    hsteinmeH
    hsteinmeH
    hsteinme
    #503
    @hausbaer Bitte Logs künftig in gezippten Dateien als Anhang posten.
    Das Log zeigt ja noch nicht mal 10 Minuten an. Da kann ich nur sehen, dass Du am 2022-06-14 08:57:02.024 über ioBroker Mähzeiten gesetzt hast, diese um 2022-06-14 08:57:02.039 korrigiert hast, um 2022-06-14 08:57:05.018 erneut korrigiert hast und das anschließend noch dreimal tust. Der Zeitplan ist um 2022-06-14 09:02:59.088 noch vorhanden.
    Wer "fummelt" da minutenlang an den Zeitplänen rum? Ein Skript von Dir? Oder die VIS?
    H 1 Antwort Letzte Antwort
    • hsteinmeH hsteinme
      H
      H
      Hausbaer
      #504
      @hsteinme Hmm, eigentlich sollte da niemand (oder nichts) so lange drum rumwurschteln....
      hsteinmeH 1 Antwort Letzte Antwort
      • H Hausbaer
        hsteinmeH
        hsteinmeH
        hsteinme
        #505
        @hausbaer sagte in Zeigt her eure Views zum Thema Mähroboter:
        Läuft ein Skript von Dir zu diesem Zeitpunkt? Hast Du zu diesem Zeitpunkt Knöpfchen in einer Mäher-View gedrückt?
          H
          H
          Hausbaer
          #506
          @hsteinme
          Es läuft halt mein Mäher Script. Die Startzeit ist auf 9:00 eingestellt, die Übertragung (einmal) in Ordnung.
          Mehr kann ich erst Montag prüfen, da ich nicht am Rechner bin
          • H
            H
            Hausbaer
            #507
            Anscheinend ist wohl wirklich das Skript die Ursache.
            Ich bin dabei, dieses zu vereinfachen und werde dann erneut testen.
            • H
              H
              Hausbaer
              #508
              Der "Fehler" liegt wohl an der Übertragung.
              Wenn die Startzeit und die Arbeitsdauer zusammen übertragen werden (also ohne Zeitversatz), tritt der Fehler häufig auf.
              Ich habe nun die Übertragung 3 min vor dem eigentlichen Start herausgenommen.
              Das Übertragen wird nun nur noch durch die Vis gesteuert, in dem man entweder die Zeiten ändert oder eine Zeit deaktiviert.
              Übertragen wird mit einem Zeitversatz, die Startzeit mit 1 Sek, die Arbeitsdauer mit 2 Sek., Kantenschnitt ebenfalls mit 1 Sek.
              Scheint zu funktionieren.
              • H Hausbaer
                hsteinmeH
                hsteinmeH
                hsteinme
                #509
                Das ist genau die Situation, die ich vermutet hatte - und über die ich vor zwei Jahren auch gestolpert war. Ich atte mich damals auch für den Ansatz entschieden, Pausen zwischen den Sendevorgängen einzubauen. Siehe https://forum.iobroker.net/topic/31506/worx-adapter-kalender-änderungen-per-javascript-unwirksam/4
                Mittlerweile gibt es aber noch eine andere Möglichkeit, um die Übernahme geänderter Zeiten abzusichern: Unter calendar gibt es die Datenpunkte calJson bzw. calJson2, mit denen Du alle ersten bzw. alle zweiten Zeiten einer Woche auf einen Schlag zum Mäher senden kannst.
                Noch ein Hinweis am Rande: Es wäre gut, Du könntest geänderte Zeitpläne spätestens eine halbe Stunde vor vorgesehenem Mähbeginn abschicken. Dann nutzt nämlich der Mäher die halbe Stunde noch, um seinen Akku wieder auf 100% zu laden, sodass Dir dann eine maximale Mähdauer zur Verfügung steht.
                  H
                  H
                  hertob81
                  #510
                  @hsteinme & @Hausbaer
                  Ich bin zwar kein blutiger Anfänger mehr, aber besteht die Möglichkeit, dass ihr ne Screenshot postet, wo bzw wie ihr das im Blockly abgeändert habt.
                  Ich habe auch das Problem, das das VIS
                  über die Mähzeiten "bügelt" und am Ende alles leer bleibt.
                  Alternativ könnte ich auch damit leben, dass die Zeiten nur "lesend" in der VIS angezeigt werden, allerdings habe ich mich nicht herausgefunden wie ich das realisieren kann.
                  Mfg Tobias
                  hsteinmeH H 2 Antworten Letzte Antwort
                  • H hertob81
                    Mfg Tobias
                    hsteinmeH
                    hsteinmeH
                    hsteinme
                    #511
                    @hertob81 Sorry, hier kann ich Dir leider nicht weiterhelfen, da ich mich weder mit Blockly noch mit der VIS auskenne
                    • H hertob81
                      Mfg Tobias
                      H
                      H
                      Hausbaer
                      #512
                      @hertob81 sagte in Zeigt her eure Views zum Thema Mähroboter:
                      Mfg Tobias
                      Servus Tobias,
                      sorry für die späte Antwort. Ich hatte hier längere Zeit kein Auge mehr drauf. Ich werde mir die Sache "calJson" noch ansehen bzw. die Zeiten wieder eine Stunde vor Mähzeitbeginn übertragen lassen.
                      Ich stell das aktuelle Skript dann zur Verfügung.
                      • H
                        H
                        Hausbaer
                        #513
                        Hier das Skript.
                        Skript_Maehroboter.zip
                        Zeiten werden nach Änderung UND jeden Tag am Morgen übertragen.
                        • A
                          A
                          AKuehnemann73
                          schrieb am zuletzt editiert von AKuehnemann73
                          #514
                          @hausbaer
                          Hi, habe Dein Skript mal installiert und mit meinen Datenpunkten angepasst. Jedoch wird mir kein einziger Datenpunkt gefüllt. Könntest du mal über Dein Skript drüber schauen?
                          Außerdem müssen alle neu angelegten Datenpunkte überarbeitet werden. Hier haben sich wohl ein paar Fehler eingeschlichen.
                          z.b. 0.userdata.Mahroboter.Ahornberg...
                          • A AKuehnemann73
                            @hausbaer
                            A
                            A
                            AKuehnemann73
                            #515
                            @saeft_2003
                            Habe Dein Skript jetzt soweit am laufen mit der dazugehörigen vis.
                            Hätte kurz noch ein paar Fragen.
                            1. In der vis Klingenlaufzeit, Mähzeit und Distanz wie hast Du die Werte umgerechnet?
                              Bei mir sind die Werte in Minuten und Meter hinterlegt.
                            2. Im Skript "Wechsel 3min oder 40min" wo wird das in der vis eingeschaltet? Oder geht
                              die Einstellung nur selber in den Objekten?
                            3. Wenn ich in der vis die Einschaltzeit und Dauer eintrage werden mir diese Werte
                              nicht unter dem Mäher in den Kalender geschrieben. Eine Idee warum?
                            Danke schon mal für die Mühe
                            • A AKuehnemann73
                              @saeft_2003
                              S
                              S
                              saeft_2003
                              #516
                              @akuehnemann73
                              1. Die Werte habe ich einfach mit blockly umgerechnet
                              2. wenn du das in der vis umstellen möchtest dann leg dir einfach einen schalter mit dem DP in die vis. So habe ich es aber seit ich ein 4ah Akku habe nutze ich das nicht mehr.
                              3. das ist richtig so, in der App ist dein Kalender leer. Der Eintrag wird immer erst 3 min oder eben 40 min vor der eigentlichen Startzeit gemacht.
                              • S saeft_2003
                                @akuehnemann73
                                A
                                A
                                AKuehnemann73
                                #517
                                @saeft_2003
                                Danke für die schnelle Antwort. Punkt 1 und 2 somit erledigt.
                                Zu Punkt 3: Dann werden die Werte also auch in den Objekten im iobroker erst 3 oder 40min vor Start gesetzt? Weil irgendwie kommt da nix an.
                                • A AKuehnemann73
                                  @saeft_2003
                                  S
                                  S
                                  saeft_2003
                                  #518
                                  @akuehnemann73
                                  Nein die Zeiten wo hier stehen
                                  Werden 3min vor der Startzeit dort geschrieben
                                  Und das funktioniert nicht?
                                  A K 2 Antworten Letzte Antwort
                                  • S saeft_2003
                                    @akuehnemann73
                                    A
                                    A
                                    AKuehnemann73
                                    #519
                                    @saeft_2003
                                    ja genau das meine ich.
                                    Die Werte werden in meinen angelegten Datenpunkten angezeigt, jedoch nicht in die Objekte vom Robby übertragen.
                                    • A AKuehnemann73
                                      @saeft_2003
                                      S
                                      S
                                      saeft_2003
                                      #520
                                      @akuehnemann73
                                      Jetzt muss ich nochmal blöd fragen, hast du auch bis 3min vor der Startzeit gewartet?
                                      Noch dazu müssen die Wochentage aktiv sein und natürlich 3min vorher Zeitensetzen.
                                      • S saeft_2003
                                        @akuehnemann73
                                        A
                                        A
                                        AKuehnemann73
                                        #521
                                        @saeft_2003
                                        hab es gerade selber auch schon rausgefunden.
                                        Ich Idiot hatte vergessen die Wochentage zu aktivieren!!!
                                        "3x mit dem Kopf auf den Tisch hauen"
                                        • A AKuehnemann73
                                          @saeft_2003
                                          A
                                          A
                                          AKuehnemann73
                                          #522
                                          @akuehnemann73
                                          so geht aber immer noch nicht. Hab jetzt 2x getestet.
                                          Ich werde morgen weiter rum testen!!!
                                          Danke schon mal für die Hilfe
                                          84.1k
