  4. Backitup probleme
Backitup probleme
187 Beiträge 22 Kommentatoren 42.2k Aufrufe 13 Beobachtet
    @Amnesia1211
    Bitte Konsolenoutput unverändert in </> CodeTags hier reinkopieren. Das scheint mir immer noch kein gültiger Pfad zu sein.
    Amnesia1211A Offline
    Amnesia1211
    #134
    @Thomas-Braun
    Der name iobrokerBeta kommt weil ich eine neue Version von André's Docker Container getestet habe läuft aber alles.
    Die Probleme mit dem Backitup Adapter habe ich auch beim Aktiv System. (Nur als Info)
    backitup.0	2020-06-08 08:09:49.050	error	(1269) Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.241/BackupServer /opt/iobroker/backups mount: /opt/iobroker/backups: c
    backitup.0	2020-06-08 08:09:48.930	info	(1269) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-06-08 08:09:48.872	info	(1269) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.5
    host.iobrokerBETA	2020-06-08 08:09:44.770	info	instance system.adapter.backitup.0 started with pid 1269
    host.iobrokerBETA	2020-06-08 08:09:42.310	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    backitup.0	2020-06-08 08:09:41.738	info	(1248) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2020-06-08 08:09:41.736	info	(1248) terminating
    backitup.0	2020-06-08 08:09:41.735	info	(1248) cleaned everything up...
    backitup.0	2020-06-08 08:09:41.734	info	(1248) Got terminate signal TERMINATE_YOURSELF
    host.iobrokerBETA	2020-06-08 08:09:41.729	info	stopInstance system.adapter.backitup.0 send kill signal
    host.iobrokerBETA	2020-06-08 08:09:41.722	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    backitup.0	2020-06-08 08:06:24.266	error	(1248) Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.241/BackupServer /opt/iobroker/backups mount: /opt/iobroker/backups: c
    backitup.0	2020-06-08 08:06:24.161	info	(1248) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-06-08 08:06:24.104	info	(1248) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.5
    host.iobrokerBETA	2020-06-08 08:06:19.693	info	instance system.adapter.backitup.0 started with pid 1248
    host.iobrokerBETA	2020-06-08 08:06:17.244	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    backitup.0	2020-06-08 08:06:16.670	info	(1212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2020-06-08 08:06:16.669	info	(1212) terminating
    backitup.0	2020-06-08 08:06:16.668	info	(1212) cleaned everything up...
    backitup.0	2020-06-08 08:06:16.666	info	(1212) Got terminate signal TERMINATE_YOURSELF
    host.iobrokerBETA	2020-06-08 08:06:16.660	info	stopInstance system.adapter.backitup.0 send kill signal
    host.iobrokerBETA	2020-06-08 08:06:16.659	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    host.iobrokerBETA	2020-06-08 08:06:08.421	info	instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
    yr.0	2020-06-08 08:06:03.352	info	(1233) got weather data from yr.no
    yr.0	2020-06-08 08:06:03.061	info	(1233) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.18.0, js-controller: 3.1.5
    host.iobrokerBETA	2020-06-08 08:06:00.039	info	instance system.adapter.yr.0 started with pid 1233
    backitup.0	2020-06-08 08:05:56.788	error	(1212) Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.241/volume3/BackupServer /opt/iobroker/backups mount: /opt/iobroker/ba
    backitup.0	2020-06-08 08:05:56.656	info	(1212) [iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0	2020-06-08 08:05:56.613	info	(1212) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.0, js-controller: 3.1.5
    host.iobrokerBETA	2020-06-08 08:05:52.050	info	instance system.adapter.backitup.0 started with pid 1212
    host.iobrokerBETA	2020-06-08 08:05:49.619	info	instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    backitup.0	2020-06-08 08:05:49.020	info	(1192) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2020-06-08 08:05:49.019	info	(1192) terminating
    backitup.0	2020-06-08 08:05:49.018	info	(1192) cleaned everything up...
    backitup.0	2020-06-08 08:05:49.017	info	(1192) Got terminate signal TERMINATE_YOURSELF
    host.iobrokerBETA	2020-06-08 08:05:49.012	info	stopInstance system.adapter.backitup.0 send kill signal
    host.iobrokerBETA	2020-06-08 08:05:49.004	info	stopInstance system.adapter.backitup.0 (force=false, process=true)
    backitup.0	2020-06-08 08:05:41.197	error	(1192) Error: Command failed: mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.241/volume3/BackupServer /opt/iobroker/backups mount: only root can use "--
    backitup.0	2020-06-08 08:05:41.084	info	(1192) [iobroker] backup was activated at 02:00 every 1 day(s)
    Man muss nicht alles wissen, nur wissen wo es steht.
    Fragen schadet aber auch nicht :spock-hand:
    • Amnesia1211A Amnesia1211
      @Thomas-Braun
      #135
      @Amnesia1211
      Das ist ein Docker? Dann bin ich raus.
      Amnesia1211A 1 Antwort Letzte Antwort
        @Amnesia1211
        Amnesia1211
        #136
        @Thomas-Braun
        Ja ist Docker. Ok trotzdem danke
          @Thomas-Braun
          simatecS Online
          simatecS Online
          simatec
          #137
          @Amnesia1211
          Ist der User "iobroker" auf deinem NAS eingerichtet und hat dementsprechend auch die Zugriffsrechte?
          Hast du die cifs-utils installiert?
          https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md
          Wie lang ist dein Passwort? User haben in der Vergangenheit Probleme mit zu langen Passwörtern gehabt
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS simatec
            @Amnesia1211
            Amnesia1211
            #138
            @simatec
            Ja der Benutzer ist angelegt. Das Passwort ist 8 stellig.
            cifs hatte ist installiert aber der Fehler kommt da immer.....
            HomoranH simatecS Thomas BraunT 3 Antworten Letzte Antwort
              @simatec
              #139
              @Amnesia1211 sagte in Backitup probleme:
              Code bitte nie als Screenshot sondern als Text in code-tags!
              dem Fehler nach könnte es tatsächlich am Docker OS-Liegen, aber nfs ist nicht das Problem bei cifs
                @simatec
                simatecS Online
                simatecS Online
                simatec
                #140
                Ohne cifs-utils geht kein mount.
                Aber da müssten die Docker Spezis ran ...
                  @simatec
                  #141
                  @Amnesia1211
                  cifs-utils ist nicht installiert. Du bzw der Docker hat ja nicht mal einen Installationskandidaten dafür.
                  Eigentlich sollte da sowas bei herum kommen:
                  pi@raspberrypi:~ $ apt policy cifs-utils
                  cifs-utils:
                    Installiert:           2:6.8-2
                    Installationskandidat: 2:6.8-2
                    Versionstabelle:
                   *** 2:6.8-2 500
                  • Amnesia1211A Offline
                    Amnesia1211
                    #142
                    @Homoran Ok wird gemacht.
                    @simatec
                    Dank dir trotzdem, ich kenne mich da leider auch nicht mit aus.
                    @Thomas-Braun
                    Mhh ich hab keinen plan :-D also wird das nix wie es aus sieht. Danke dir natürlich trotzdem für deine Zeit.
                    • W Offline
                      W Offline
                      waterchill
                      #143
                      moin, ich scheiter auch gerade an dem Backitup Adapter. Ich möchte die Backups auf der Synology NAS speichern und folgender Fehler kommt:
                      Error: Command failed: mount -t cifs -o username=iobroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.171.40/Software/Backup/Raspi /opt/iobroker/backups mount.cifs: permission denied: no match for /opt/iobroker/backups found in /etc/fstab
                      Jemand eine Idee?
                      • W waterchill
                        Jemand eine Idee?
                        #144
                        @waterchill
                        Wie sehen die Einstellungen aus?
                        In die fstab kann man, aber man muss die Freigabe nicht unbedingt einstellen.
                        Hängt davon ab wie gemountet wird.
                        Mit Eintrag in der fstab kann u. U. von einem user gemountet werden, ohne Eintrag muss es mit root-Rechten gemacht werden.
                        W 1 Antwort Letzte Antwort
                          @waterchill
                          W Offline
                          W Offline
                          waterchill
                          #145
                          Sieht so aus:
                          • W waterchill
                            Sieht so aus:
                            #146
                            @waterchill
                            Als root mouten (sudo)
                            und das Protokoll würde ich wenn möglich auch auf SMB3.1.1 drehen.
                              @waterchill
                              W Offline
                              W Offline
                              waterchill
                              #147
                              Mit den SMB habe ich schon rumgespielt. Aber die Option als root mounten war die Lösung. Danke!
                              • W waterchill
                                #148
                                @waterchill sagte in Backitup probleme:
                                Und steht das jetzt auf der höchstmöglichen Version?
                                  W Offline
                                  W Offline
                                  waterchill
                                  #149
                                  Jo geht einwandfrei :)
                                  • W waterchill
                                    Diamand2k22
                                    #150
                                    @Thomas-Braun
                                    [DEBUG] [iobroker] - done
                                    [DEBUG] [influxDB] - InfluxDB-Backup started ...
                                    [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                    [ERROR] [influxDB] - Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2022_11_02-21_26_37_backupiobroker"
                                    Error: unknown shorthand flag: 'p' in -portable
                                    See 'influxd -h' for help
                                    hast du ne Idee warum er die Influx DB nicht sichert.
                                    Das Backup vom iobroker läuft ganz normal durch, bei der influx db bricht er immer mit error ab.
                                    Gemountet wird über cifs, smb 3.1.1, mount as root ist auch aktiv.
                                    • D Diamand2k22
                                      @Thomas-Braun
                                      #151
                                      @diamand2k22
                                      Ich hab influxdb nicht laufen.
                                      Keine Ahnung welche Optionen da gesetzt sein müssen.
                                      I.d.R. würde ich aber Paramter solcher Art erwarten: --portable
                                        @diamand2k22
                                        Diamand2k22
                                        #152
                                        danke für die schnelle Rückmeldung. Evtl. ist das ein Bug im Backitup Script.
                                        gibts hier noch Leute die evtl. die selbe Konstellation am laufen haben?
                                        • D Diamand2k22
                                          #153
                                          @diamand2k22
                                          Was ist denn da alles von influx installiert? Die cli-Programme auch?
                                          apt policy influxdb*
