  4. Adapter "smartmeter"
    6.7k
3.6k Beiträge 281 Kommentatoren 3.0m Aufrufe 162 Beobachtet
  • W wusa
    Ich habe leider das Problem, dass bei mir der Adapter leider nicht mehr funktioniert.
    Hier die Daten aus dem Log.
    martmeter.0
    2022-08-18 19:21:04.609	debug	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2022-08-18 19:21:04.597	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2022-08-18 19:19:04.626	debug	connected set to false
    smartmeter.0
    2022-08-18 19:19:04.506	debug	SmartmeterObis options: {"debug":0,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"0","anotherQueryDelay":"1000","transportSerialPort":"/dev/ttyAMA0","transportSerialBaudrate":9600,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false}
    smartmeter.0
    2022-08-18 19:19:04.389	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.17.0, js-controller: 4.0.23
    smartmeter.0
    2022-08-18 19:19:03.291	debug	Plugin sentry Initialize Plugin (enabled=true)
    smartmeter.0
    2022-08-18 19:19:03.219	debug	States connected to redis: 192.168.111.10:9000
    smartmeter.0
    2022-08-18 19:19:03.190	debug	States create User PubSub Client
    smartmeter.0
    2022-08-18 19:19:03.186	debug	States create System PubSub Client
    smartmeter.0
    2022-08-18 19:19:03.166	debug	Redis States: Use Redis connection: 192.168.111.10:9000
    smartmeter.0
    2022-08-18 19:19:03.082	debug	Objects connected to redis: 192.168.111.10:9001
    smartmeter.0
    2022-08-18 19:19:03.051	debug	Objects client initialize lua scripts
    smartmeter.0
    2022-08-18 19:19:02.969	debug	Objects create User PubSub Client
    smartmeter.0
    2022-08-18 19:19:02.964	debug	Objects create System PubSub Client
    smartmeter.0
    2022-08-18 19:19:02.951	debug	Objects client ready ... initialize now
    smartmeter.0
    2022-08-18 19:19:02.812	debug	Redis Objects: Use Redis connection: 192.168.111.10:9001
    host.iob-slave
    2022-08-18 19:18:56.399	info	instance system.adapter.smartmeter.0 started with pid 4205
    host.iob-slave
    2022-08-18 19:18:56.210	info	"system.adapter.smartmeter.0" enabled
    Ich habe den Smartmeter Adapter auf einem Rasperry Pi installiert, als Slave.
    Seitdem funktioniert der Adapter nicht mehr.
    An was könnte es liegen?
    GlasfaserG Offline
    GlasfaserG Offline
    #2780
    @wusa sagte in Adapter "smartmeter":
    Du schreibst das oben ..
    Was war hiermit !?
    Ich habe keine abenteuerliches Konstrukt.
    Es ist einfach nur ein Fototransistor mit 2 Pins.
    So ist meine jetzige Konfiguration.
    Die Frage ist nur, ob die GPIO auf dem Slave auch wieder gleich angesteuert werden. Oder ob auf dem Slave nur der Prozess ausgelagert wird aber GPIO eigentlich vom Master verwendet wird?
    Antwort :
    @homoran sagte in Adapter "smartmeter":
    Der Adapter ist für serielle Schnittstelle (USB/TTL) und einen Lesekopf ausgelegt.
    Da musdt du nur die richtige serielle Schnittstelle auf dem Gerät auswählen und es läuft.
    W 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Was war hiermit !?
      Antwort :
      W Offline
      W Offline
      wusa
      #2781
      @glasfaser
      Da war der Adapter noch auf dem Master.
      Ich habe den Pi komplett neu aufgesetzt und ihn zum Slave gemacht.
      Jetzt scheint es nicht mehr zu funktionieren.
      Eingestellt ist alles gleich wie auf dem Screenshot.
      • W wusa
        @glasfaser
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #2782
        @wusa
        Hast du die Instanz dann auch auf dem slave bearbeitet.
        Und nicht ! die Instanz auf dem master.
        (falls die noch vorhanden ist; war bei mir mal so)
        Danke.
        • bahnuhrB bahnuhr
          @wusa
          W Offline
          W Offline
          wusa
          #2783
          @bahnuhr
          Ja alles auf dem Slave gemacht. Auf dem Master ist die Instanz nicht mehr vorhanden.
          • W Offline
            W Offline
            wusa
            #2784
            Jetzt funktioniert es.
            Ich habe folgendes auf dem Pi ausgeführt:
            sudo nano /boot/config.txt
            und folgendes eingefügt:
            dtoverlay=pi3-disable-bt
            Nachdem noch folgendes ausgeführt:
            sudo systemctl disable hciuart
            Pi neu gestartet. Jetzt läuft der Adapter
            • Thomas WT Offline
              Thomas WT Offline
              Thomas W
              #2785
              Ich habe einen Q3MA1060 V 6.03.
              Welche passenden IR Adapter könnt ihr mot empfehlen?
              Iobroker läuft auf einer Synology und ist unter 5 m vom Stromzähler entfernt
              HomoranH K 2 Antworten Letzte Antwort
              • Thomas WT Thomas W
                #2786
                @thomas-w
                Anleitung?
                Bild?
                was passt denn bei dem überhaupt?
                  klassisch
                  #2787
                  @thomas-w
                  • Synology hat irgendwann USB dicht gemacht. Ob man ihn wieder / noch öffnen kann weiß ich nicht. Ansonsten über einen LAN Konverter gehen und über tcp
                  • In https://www.easymeter.com/products/zaehler/q3m-edl12 wird von D0 Schnittstelle und von der Info Schnittstelle gesprochen. Wie ist Dein Zähler konfiguriert? "moderne Meßeinrichtung" vom Versorger wie ab 2032 Pflicht oder mit D0, z.B. für interne Zwecke oder als "intelligentes Meßsystem"?
                  GlasfaserG Thomas WT 2 Antworten Letzte Antwort
                  • K klassisch
                    @thomas-w
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #2788
                    @klassisch sagte in Adapter "smartmeter":
                    stimmt , kann man aber (noch) umgehen .
                    Funktioniert über die Synology , auch über das aktuelle DSM 7.1-42661 Update 4 noch.
                    Beispiel :
                    https://forum.iobroker.net/topic/57106/synology-und-ir-lesekopf-für-stromzähler?_=1661088802931
                    • K klassisch
                      @thomas-w
                      Thomas WT Offline
                      Thomas WT Offline
                      Thomas W
                      #2789
                      @klassisch said in Adapter "smartmeter":
                      @thomas-w
                      Wo kann ich denn sehen wie mein Zähler konfiguriert ist? Ist ein Neubau von 2019 (evtl ist ab da ja eine bestimmte Konfig. Pflicht)
                      Meine Synology hat momentan ein deconz Stick für Zigbee Geräte im Einsatz, sodass ich sagen kann, dass USB auch in einem Docker Image möglich ist.
                      Gibt es denn einen "Standard IR" Leser den viele nehmen? Oder gibt es hier zig Auswahlmöglichkeiten?
                      K HomoranH 2 Antworten Letzte Antwort
                        @thomas-w
                        klassisch
                        #2790
                        @thomas-w sagte in Adapter "smartmeter":
                        Den fragen, der ihn eingebaut hat. Also wenn es der Meßstellenbetreiber war, dann dort nachfragen mit der Zählernummer. Fragen, ob das Gerät als "moderne Meßeinrichtung" konfiguriert ist.
                        Wenn USB geht, wird hier allgemein der Weidmann Kopf empfohlen (Weidmann USB).
                        Mittlerweile gibt es auch bei ebay ähnliche Geräte, von denen man hier ab und an liest. Ich kann dazu aber nichts sagen, weil ich nicht über USB gehe.
                        Thomas WT 1 Antwort Letzte Antwort
                          @thomas-w
                          #2791
                          in der Anleiting vom Netzbetreiber, die spätestens nach Anfoderung der PIN mit dieser geliefert wird.
                          • K klassisch
                            Thomas WT Offline
                            Thomas WT Offline
                            Thomas W
                            schrieb am zuletzt editiert von Thomas W
                            #2792
                            @klassisch Danke für deine Antwort. Wie machst du es denn? Via Funk oder via LAN?
                            Welche IR-Sensor hast du denn?
                            Ich habe die Pin beantragt -> kommt die Tage via Post. Hoffe dass da dann auch drin steht, wie mein Zähler konfiguriert ist. In der Anleitung des Zählers habe ich folgende INfos gefunden:
                            https://www.easymeter.com/products/zaehler/q3m-edl12#!#docs
                            Bidirektionale MSB-Schnittstelle (D0)
                            Protokoll nach SML V1.04
                            Funktionalität nach Lastenheft EDL V1.2
                            Sendediode, jede Sekunde Datenübertragung der ID.Nr., Zählerstände, Phasen- und Summenleistung
                            Empfangsdiode für bidirektionalen Betrieb
                              klassisch
                              schrieb am zuletzt editiert von klassisch
                              #2793
                              @thomas-w In der Anleitung steht unter 6.1.2 "Info-Schnittslelle für den Endkunden" und PIN. Und nur zu dieser Schnittstelle kann ich was sagen. Der Adapter unterstützt zwar auch D0 aber mein Zähler nicht und deshalb habe ich mich nicht damit beschäftigt. Die Info-Schnittstelle für den Endkunden ist unidirektional und relativ einfach auszulesen. Es wird mindestens der Energiewert ausgegeben und die Momentanleistung. So der Meßstellenbetreiber will auch mehr.
                              Allerdings muß man zuerst die PIN eingeben und meist auch die Info-Schnittstelle aktivieren. Das geschieht in einem Blinkcode-Dialog.
                              Die Eingabe der PIN kann man mit der Android App "mME Stromzähler" erleichtern.
                              Verschiedene Möglichkeiten die Info Schnittstelle einzulesen habe ich ein einem ausführlichen Guide beschrieben. Ich verwende einen komerziellen Kopf EHZ001K, der eigentlich für den Inneneinbau gedacht ist. Der hat RS232 und RS485 Ausgänge, die ich mit einem Konverter in LAN konvertiere. WLAN ist auch möglich, was ich an anderer Stelle im Haus mache. Aber Draht ist halt zuverlässiger als Funk. Ich mache derzeit recht viel und zeitkritische Applikationen mit den Zählerwerten, deshalb LAN. Wenn man nur ab und an den Verbrauchswert speichert ist WLAN gut genug.
                              Solche Konverter auf LAN oder WLAN gibt es als Fertiggeräte oder Bastelmodule. Läuft bei mir sehr stabil.
                              Wenn ein ioBroker Raspi in der Nähe ist, liegt ein Lesekopf mit USB nahe. Die Herausforderung hierbei ist es, das Linux dazu zu überreden, den USB Anschluß zum ioBroker durchzuleiten - und zwar so, daß die Zuordnung auch noch nach einem reboot zuverlässig erhalten bleibt. Das beherrschen viele User, ich muß aber immer nach den passenden Lösungen und den passenden Befehlen suchen. Man sucht per linux-befehl nach der Id Nummer des Kopfes, bastelt einen Befehl zusammen und trägt das in eine spezielle Datei des Linux ein - je nachdem wie das Linux initialisiert wird.
                              • K klassisch
                                #2794
                                @klassisch ich habe nicht so viele negative Punkte :-)
                                da hab ich noch nie Probleme mit gehabt. Einfach angesteckt und die angebotenen Möglichkeiten probiert.
                                ordentlich, und damit
                                kann man das mit einem Linuxbefehl an die Hardware-ID des Kopfes binden. Den muss ich mir auch immer im Forum raussuchen.
                                auch hier muss ich relativieren
                                die PIN dient dazu weitere Informationen freizuschalten.
                                die einstellung INF -> ON dient IMHO nur dazu diese Zusatzinfo auch an die Schnittstelle zu geben (bin jetzt aber nicht mehr sicher!)
                                unter 6.1.2 habe ich keine spezifizierten Daten fürcdie optische Schnittstelle gefunden.
                                im Header unter 6.1 stehen Parameter, u.a. SML die wahrscheinlich für beide Schnittstellen gelten.
                                Ich denke aber, dass mit der PIN noch eine bebilderte Anleitung mitkommt.
                                das müsste ggf. mit einer einfachen USB-Verlängerung klappen, vorausgesetzt es scheitert nicht an Syno und/oder Docker
                                H 1 Antwort Letzte Antwort
                                  hafo
                                  #2795
                                  Ich versuche seit einiger Zeit meinen neuen Stromzähler auszulesen. Dazu habe ich einen D1 mini direkt an den Zähler angeschlossen, bis jetzt haben ihm die 5V hoffentlich nicht geschadet.10.jpg
                                  Im EspEasy versuchte ich es zuerst mit dem P1 Wifi Gateway, leider ohne Erfolg. Auch der ESPEasy P2P Networking Controller hat da nicht weitergeholfen.
                                  Das habe ich über Putty herausbekommen
                                  Keine Ahnung ob das gut ist oder nicht, aber da kommt regelmässig was.
                                  Allerdings wird nichts über MQTT weitergesendet. Deshalb habe ich noch den Smartmeter Adapter ausprobiert auf Iobroker. Dieser zeigt aber keine Verbindung mit Gerät oder Dienst an.
                                  Was könnte ich noch versuchen, und ist die Ausgabe über Putty so richtig oder besteht bereits hier der Fehler?
                                  Danke für eure Inputs und Gruss
                                  Hansjürg
                                  • H hafo
                                    Hansjürg
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #2796
                                    @hafo sagte in Adapter "smartmeter":
                                    und wie ist dann die Verbindung hergestellt ...
                                    du schreibst :
                                    das geht mit dem Adapter nicht .
                                      du schreibst :
                                      hafo
                                      #2797
                                      @glasfaser ich bin davon ausgegangen dass die Zähler über die optische Schnittstelle dasselbe senden wie über die P1 (Rj12) Schnittstelle. Es wird dieses Protokoll verwendet
                                      Wie könnte ich dann die Daten auf Iobroker übertragen?
                                      • H hafo
                                        klassisch
                                        #2798
                                        Einige Möglichkeiten findest Du in meinem Guide , der sich aber NUR mit der Ausprägung "Moderne Messeinrichtung" beschäftigt.
                                        Du brauchst einen IR Lesekopf.
                                        Die ESP Lösung ist anders und geht über MQTT, aber dann auch in den ioBroker. Die Daten landen wohl im ioBroker, aber eben woanders im Datenbereich.
                                        Hat mit diesem Adapter nichts zu tun. Ich kenne mich mit der ESP Lösung nicht aus, es gibt hier im Forum auch Threads dazu. Kenne mich mit der ESP Lösung aber nicht aus.
                                        • K klassisch
                                          hafo
                                          #2799
                                          @klassisch Danke, dann suche ich noch etwas weiter. Mein Zähler hat beide Ausgabemöglichkeiten, ich finde die Kabellösung mit ESP eigentlich einiges besser und ich hatte dazu auch bereits alles im Haus.
