[How-to] Node.js ioBroker richtig updaten-2021/22 Edition
@glasfaser unverändert!
2022-08-20 21:33:26.813 - info: host.e-server iobroker rebuild 2022-08-20 21:33:28.415 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ... 2022-08-20 21:34:55.322 - info: host.e-server iobroker npm-rebuild: rebuilt dependencies successfully 2022-08-20 21:34:55.369 - info: host.e-server iobroker npm-rebuild: 2022-08-20 21:34:55.371 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules done 2022-08-20 21:34:56.385 - info: host.e-server iobroker npm-rebuild: exit 0 2022-08-20 21:34:56.750 - info: host.e-server instance system.adapter.klf200.0 started with pid 1450 2022-08-20 21:34:58.288 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959 2022-08-20 21:34:58.289 - error: host.e-server Caught by controller[0]: throw err; 2022-08-20 21:34:58.289 - error: host.e-server Caught by controller[0]: ^ 2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule' 2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: Require stack: 2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js 2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) 2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27) 2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19) 2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25) 2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14) 2022-08-20 21:34:58.293 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) 2022-08-20 21:34:58.293 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) 2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12) 2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { 2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND', 2022-08-20 21:34:58.295 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ] 2022-08-20 21:34:58.295 - error: host.e-server Caught by controller[0]: } 2022-08-20 21:34:58.295 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-08-20 21:34:58.296 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards. 2022-08-20 21:34:58.296 - info: host.e-server system.adapter.klf200.0 will be rebuilt 2022-08-20 21:34:58.297 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt 2022-08-20 21:34:58.297 - info: host.e-server iobroker rebuild 2022-08-20 21:34:59.706 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ... -
@glasfaser das selbe wie vorhin
Last login: Sat Aug 20 19:50:11 2022 from 192.168.178.57 e-server@e-server:~$ cd /opt/iobroker/node_modules/iobroker.klf200/ e-server@e-server:/opt/iobroker/node_modules/iobroker.klf200$ npm install --omit=dev [sudo] password for e-server: npm ERR! code ERESOLVE npm ERR! ERESOLVE unable to resolve dependency tree npm ERR! npm ERR! While resolving: iobroker.klf200@1.0.1 npm ERR! Found: eslint@7.32.0 npm ERR! node_modules/eslint npm ERR! dev eslint@"^7.1.0" from the root project npm ERR! npm ERR! Could not resolve dependency: npm ERR! peer eslint@"^5.0.0 || ^6.0.0" from @typescript-eslint/parser@2.34.0 npm ERR! node_modules/@typescript-eslint/parser npm ERR! dev @typescript-eslint/parser@"^2.34.0" from the root project npm ERR! peer @typescript-eslint/parser@"^2.0.0" from @typescript-eslint/eslint-plugin@2.34.0 npm ERR! node_modules/@typescript-eslint/eslint-plugin npm ERR! dev @typescript-eslint/eslint-plugin@"^2.34.0" from the root project npm ERR! npm ERR! Fix the upstream dependency conflict, or retry npm ERR! this command with --force, or --legacy-peer-deps npm ERR! to accept an incorrect (and potentially broken) dependency resolution. npm ERR! npm ERR! See /home/iobroker/.npm/eresolve-report.txt for a full report. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-08-20T21_38_39_538Z-debug-0.log e-server@e-server:/opt/iobroker/node_modules/iobroker.klf200$ -
@glasfaser sehe jetzt unter Instanzen den Adapter nicht mehr!!
e-server@e-server:~$ iobroker del klf200 Delete adapter "klf200" host.e-server Counted 1 meta of klf200 host.e-server Counted 1 adapter for klf200 host.e-server Counted 1 states (system.adapter.klf200.*) from states host.e-server file klf200.admin deleted host.e-server object klf200 deleted host.e-server object klf200.admin deleted host.e-server Deleting 2 object(s). host.e-server Deleting 1 state(s). removed 4 packages in 10s 90 packages are looking for funding run `npm fund` for details e-server@e-server:~$ iobroker install klf200@1.0.1 NPM version: 8.15.0 Installing iobroker.klf200@1.0.1... (System call) added 4 packages in 10s 90 packages are looking for funding run `npm fund` for details host.e-server install adapter klf200@1.0.1 upload [4] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/admin.d.ts admin.d.ts video/mp2t upload [3] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/index_m.html index_m.html text/html upload [2] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/klf200.png klf200.png image/png upload [1] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/style.css style.css text/css upload [0] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/words.js words.js application/javascript host.e-server object system.adapter.klf200 created/updated e-server@e-server:~$ -
@chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
iobroker add klf200@glasfaser hat leider auch nicht geklappt
2022-08-20 21:53:06.714 - info: host.e-server instance system.adapter.klf200.0 started with pid 2473 2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err; 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^ 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule' 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack: 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12) 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND', 2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ] 2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: } 2022-08-20 21:53:08.275 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-08-20 21:53:08.276 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards. 2022-08-20 21:53:08.276 - info: host.e-server system.adapter.klf200.0 will be rebuilt 2022-08-20 21:53:08.278 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt 2022-08-20 21:53:08.278 - info: host.e-server iobroker rebuild 2022-08-20 21:53:09.677 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ... -
@glasfaser ok, aber danke für deine Bemühungen!
2022-08-20 21:53:06.714 - info: host.e-server instance system.adapter.klf200.0 started with pid 2473 2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err; 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^ 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule' 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack: 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19) 2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) 2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32) 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12) 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) { 2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND', 2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ] 2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: } 2022-08-20 21:53:08.275 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-08-20 21:53:08.276 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards. 2022-08-20 21:53:08.276 - info: host.e-server system.adapter.klf200.0 will be rebuilt 2022-08-20 21:53:08.278 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt 2022-08-20 21:53:08.278 - info: host.e-server iobroker rebuild 2022-08-20 21:53:09.677 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...@chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err; 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^ 2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule' 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack: 2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.jsWas liefert denn ein
npm list|grep node?
Taucht da node-schedule auf? Sonst versuche mal einnpm install node-schedule
npm list|grep node?
@sborg das wars jetzt funktioniert es! Danke, Danke!!!
e-server@e-server:/opt/iobroker$ npm list|grep node [sudo] password for e-server: ├── node-inspect@2.0.0 extraneous e-server@e-server:/opt/iobroker$ npm install node-schedule added 1 package, removed 645 packages, and changed 1 package in 17s 90 packages are looking for funding run `npm fund` for details e-server@e-server:/opt/iobroker$ npm list|grep node └── node-schedule@2.1.0 e-server@e-server:/opt/iobroker$Hab jetzt noch einen Master und einen zweiten Slave, da kommt node-schedule auch nicht vor. Aber alle installierten Adapter laufen problemlos bzw. Iobroker selbst auch! Sollt ich das auch nach installieren?
Last login: Sat Aug 20 18:48:31 2022 from 192.168.178.57 c-server@c-server:~$ cd /opt/iobroker c-server@c-server:/opt/iobroker$ npm list|grep node [sudo] password for c-server: c-server@c-server:/opt/iobroker$ npm list|grep node c-server@c-server:/opt/iobroker$Last login: Sun Aug 21 13:44:13 2022 from 192.168.178.57 d-server@d-server:~$ cd /opt/iobroker d-server@d-server:/opt/iobroker$ npm list|grep node [sudo] password for d-server: ├── node-inspect@2.0.0 extraneous d-server@d-server:/opt/iobroker$ -
Last login: Sat Aug 20 18:48:31 2022 from 192.168.178.57 c-server@c-server:~$ cd /opt/iobroker c-server@c-server:/opt/iobroker$ npm list|grep node [sudo] password for c-server: c-server@c-server:/opt/iobroker$ npm list|grep node c-server@c-server:/opt/iobroker$Last login: Sun Aug 21 13:44:13 2022 from 192.168.178.57 d-server@d-server:~$ cd /opt/iobroker d-server@d-server:/opt/iobroker$ npm list|grep node [sudo] password for d-server: ├── node-inspect@2.0.0 extraneous d-server@d-server:/opt/iobroker$@chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Nein, das wäre nur Ressourcenverschwendung. Falls mal ein Adapter auf einem System den braucht, meldet er sich schon (siehe "error" in deinen Logs von oben). Normalerweise werden die Dependencies aber auch vom Adapter aufgelöst und nachinstalliert.
Fährst ja auch nicht das ganze Jahr mit angehängtem Wohnwagen rum, nur weil du ihn vielleicht mal 2 Wochen im Jahr brauchst ;) -
Fährst ja auch nicht das ganze Jahr mit angehängtem Wohnwagen rum, nur weil du ihn vielleicht mal 2 Wochen im Jahr brauchst ;)@sborg sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Ok, verstehe!! Danke nochmal.
Da hast du natürlich recht!! :
ich habe auf die empfohlene Version Node.js 16.x ein Update gemacht.
Jetzt wird folgendes in der Übersicht angezeigt:
Ist das so richtig?
Welche NPM Version wird empfohlen?
Muss ich mich um die NPM-Version kümmern? ... oder kommt die automatisch durch Node.js?
Wo finde ich die verfügbaren Updates (siehe Screeshot)?Viele Grüße
Frank -
Ist das so richtig?
Frank@frank06347 Das passt so. NPM nicht manuell updaten, kommt passend mit und zur nodejs Ver.
Ist das so richtig?
Frank@frank06347 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Ist das so richtig?
Ist das so richtig?
@homoran sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Ist das so richtig?
Alles klar ... Fehler im Admin .... vielen Dank für schnelle Antwort!
Viele Grüße
Frank -
Ist das so richtig?
Viele Grüße
Nur zur Klärung , das ist kein Fehler vom ADMIN !
Deshalb habe ich hier :
... es soll nur verhindert werden : "verleitet nur zu unnötigen Installations/Upgrade-Versuchen."
Schönen guten Morgen,
wollte euch mein Erfolgserlebnis in Bezug auf Node.js mitteilen.
kurz zur Vorgeschichte. Mein iobroker lief jetzt mehr als ein Jahr unter Windows auf einem Surface 1. Bisher habe ich immer alles hinbekommen und er lief 24 / 7 ohne Probleme, egal welches Update, es lief einfach super.
Jetzt bin ich auf proxmox gewechselt und einem Surface Pro 7 mit mit Displayschaden umgezogen. Als OS habe ich ubuntu server gewählt, 4 Cores und 4 GB RAM.
Im ioBroker unter Windows Backup gezogen und im Ubuntu Server eingespielt. Hat erst mal länger gedauert, hatte da am Anfang etwas Probleme mit, läuft aber jetzt und das sehr performant.
Dann Conbee ii usb durchgereicht, alles installiert und Backup eingespielt. Lief auf anhieb.
Bis hierher alles gut gelaufen und es läuft auch alles.
Dann habe ich gesehen das meine Node.js Version noch auf v12.22.9 ist.
Ich hab glaub ich alles durch was man so machen kann. Snapshots sei dank, so kam ich immer wieder zurück. :-) Aber nichts hatte geholfen. Stichwort "Broken-Pipe".
Nur das folgende konnte mir helfen:
iobroker stop cd /opt/iobroker sudo npm cache verify sudo chown -R iobroker /opt/iobroker sudo apt update -y && sudo apt upgrade -y sudo apt-get purge nodejs -y && sudo apt-get autoremove -y && sudo apt-get autoclean -y sudo curl -sL https://deb.nodesource.com/setup_16.x | sudo bash - sudo apt-get install -y nodejs sudo chown -R iobroker /opt/iobroker iobroker stop npm install -y iobroker.js-controller --unsafe-perm --production --save --prefix curl -sL https://iobroker.net/fix.sh | bash - npm rebuild iobroker update iobroker upgrade self iobroker upgrade -y iobroker startVielleicht hilft das dem ein oder anderen noch. :)
LG
Torsten
LG
Torsten
Ehrlich gesagt: Recht wirr.
Mag sein, läuft aber jetzt.
