  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.8k
812 Beiträge 97 Kommentatoren 458.1k Aufrufe 83 Beobachtet
  • GlasfaserG Glasfaser
    @chrisdor
    Die komplette Ein/Ausgabe posten ... da fehlt der Anfang !
    Chrisdor
    #707
    @glasfaser meinst du das?
    e-server@e-server:/opt/iobroker/node_modules/iobroker.klf200$ npm install --omit=dev
    (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠋ idealTree:iobroker.klf200: sill idealTree buildDeps
    npm ERR! code ERESOLVE
    npm ERR! ERESOLVE unable to resolve dependency tree
    npm ERR!
    npm ERR! While resolving: iobroker.klf200@1.0.1
    npm ERR! Found: eslint@7.32.0
    npm ERR! node_modules/eslint
    npm ERR!   dev eslint@"^7.1.0" from the root project
    npm ERR!
    npm ERR! Could not resolve dependency:
    npm ERR! peer eslint@"^5.0.0 || ^6.0.0" from @typescript-eslint/parser@2.34.0
    npm ERR! node_modules/@typescript-eslint/parser
    npm ERR!   dev @typescript-eslint/parser@"^2.34.0" from the root project
    npm ERR!   peer @typescript-eslint/parser@"^2.0.0" from @typescript-eslint/eslint-plugin@2.34.0
    npm ERR!   node_modules/@typescript-eslint/eslint-plugin
    npm ERR!     dev @typescript-eslint/eslint-plugin@"^2.34.0" from the root project
    npm ERR!
    npm ERR! Fix the upstream dependency conflict, or retry
    npm ERR! this command with --force, or --legacy-peer-deps
    npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
    npm ERR!
    npm ERR! See /home/iobroker/.npm/eresolve-report.txt for a full report.
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-20T21_02_24_597Z-debug-0.log
    • C Chrisdor
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      GlasfaserG Offline
      GlasfaserG Offline
      #708
      @chrisdor
      Zeigen
      cd /opt/iobroker
      npm ls | grep -E 'github.com|ERR'
      iobroker update -i
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      C 1 Antwort Letzte Antwort
        @chrisdor
        Zeigen
        cd /opt/iobroker
        iobroker update -i
        Chrisdor
        #709
        @glasfaser
        e-server@e-server:~$ cd /opt/iobroker
        e-server@e-server:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
        [sudo] password for e-server:
        e-server@e-server:/opt/iobroker$ iobroker update -i
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "backitup"     : 2.4.10   , installed 2.4.10
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "klf200"       : 1.0.1    , installed 1.0.1
        Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
        Adapter    "ph803w"       : 1.1.1    , installed 1.1.1
        Adapter    "ring"         : 3.0.4    , installed 3.0.4
        Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        e-server@e-server:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        e-server@e-server:/opt/iobroker$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        e-server
        /opt/iobroker
        Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
        Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
        Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
        Hit:4 http://at.archive.ubuntu.com/ubuntu jammy-security InRelease
        Hit:5 https://deb.nodesource.com/node_14.x jammy InRelease
        Reading package lists... Done
        All packages are up to date.
        nodejs:
          Installed: 16.17.0-deb-1nodesource1
          Candidate: 16.17.0-deb-1nodesource1
          Version table:
         *** 16.17.0-deb-1nodesource1 100
             14.20.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages
             12.22.9~dfsg-1ubuntu3 500
                500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        • C Chrisdor
          @glasfaser
          x86_64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.0
          v16.17.0
          8.15.0
          e-server
          /opt/iobroker
          nodejs:
            Version table:
          GlasfaserG Offline
          GlasfaserG Offline
          #710
          @chrisdor
          Lösche den Adapter und installiere ihn neu !
            @chrisdor
            Chrisdor
            #711
            @glasfaser Habe ich auch schon drei mal versucht, funktioniert leider auch nicht?
            • C Chrisdor
              GlasfaserG Offline
              GlasfaserG Offline
              #712
              @chrisdor
              Danke für die Info , hast du nicht geschrieben !!
                @chrisdor
                Chrisdor
                #713
                @glasfaser sorry hatte ich vergessen
                • C Chrisdor
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #714
                  @chrisdor
                  sudo -H -u iobroker npm cache clear --force
                  Neustart ... was ist dann
                    @chrisdor
                    Chrisdor
                    #715
                    @glasfaser unverändert!
                    2022-08-20 21:33:26.813 - info: host.e-server iobroker rebuild
                    2022-08-20 21:33:28.415 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                    2022-08-20 21:34:55.322 - info: host.e-server iobroker npm-rebuild: rebuilt dependencies successfully
                    2022-08-20 21:34:55.369 - info: host.e-server iobroker npm-rebuild:
                    2022-08-20 21:34:55.371 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules done
                    2022-08-20 21:34:56.385 - info: host.e-server iobroker npm-rebuild: exit 0
                    2022-08-20 21:34:56.750 - info: host.e-server instance system.adapter.klf200.0 started with pid 1450
                    2022-08-20 21:34:58.288 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                    2022-08-20 21:34:58.289 - error: host.e-server Caught by controller[0]: throw err;
                    2022-08-20 21:34:58.289 - error: host.e-server Caught by controller[0]: ^
                    2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                    2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: Require stack:
                    2022-08-20 21:34:58.290 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                    2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                    2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                    2022-08-20 21:34:58.291 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                    2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                    2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                    2022-08-20 21:34:58.292 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                    2022-08-20 21:34:58.293 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                    2022-08-20 21:34:58.293 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                    2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                    2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                    2022-08-20 21:34:58.294 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                    2022-08-20 21:34:58.295 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                    2022-08-20 21:34:58.295 - error: host.e-server Caught by controller[0]: }
                    2022-08-20 21:34:58.295 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2022-08-20 21:34:58.296 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
                    2022-08-20 21:34:58.296 - info: host.e-server system.adapter.klf200.0 will be rebuilt
                    2022-08-20 21:34:58.297 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                    2022-08-20 21:34:58.297 - info: host.e-server iobroker rebuild
                    2022-08-20 21:34:59.706 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                    • C Chrisdor
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #716
                      @chrisdor
                      jetzt nochmal
                      cd /opt/iobroker/node_modules/iobroker.klf200/
                        @chrisdor
                        jetzt nochmal
                        Chrisdor
                        #717
                        @glasfaser das selbe wie vorhin
                        Last login: Sat Aug 20 19:50:11 2022 from 192.168.178.57
                        e-server@e-server:~$ cd /opt/iobroker/node_modules/iobroker.klf200/
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-20T21_38_39_538Z-debug-0.log
                        • C Chrisdor
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #718
                          @chrisdor
                          iobroker del klf200
                          iobroker install klf200@1.0.1
                            @chrisdor
                            iobroker del klf200
                            Chrisdor
                            #719
                            @glasfaser sehe jetzt unter Instanzen den Adapter nicht mehr!!
                            e-server@e-server:~$ iobroker del klf200
                            Delete adapter "klf200"
                            host.e-server Counted 1 meta of klf200
                            host.e-server Counted 1 adapter for klf200
                            host.e-server Counted 1 states (system.adapter.klf200.*) from states
                            host.e-server file klf200.admin deleted
                            host.e-server object klf200 deleted
                            host.e-server object klf200.admin deleted
                            host.e-server Deleting 2 object(s).
                            host.e-server Deleting 1 state(s).
                            removed 4 packages in 10s
                            90 packages are looking for funding
                              run `npm fund` for details
                            e-server@e-server:~$ iobroker install klf200@1.0.1
                            NPM version: 8.15.0
                            Installing iobroker.klf200@1.0.1... (System call)
                            added 4 packages in 10s
                            host.e-server install adapter klf200@1.0.1
                            upload [4] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/admin.d.ts admin.d.ts video/mp2t
                            upload [3] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/index_m.html index_m.html text/html
                            upload [2] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/klf200.png klf200.png image/png
                            upload [1] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/style.css style.css text/css
                            upload [0] klf200.admin /opt/iobroker/node_modules/iobroker.klf200/admin/words.js words.js application/javascript
                            host.e-server object system.adapter.klf200 created/updated
                            • C Chrisdor
                              NPM version: 8.15.0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              #720
                              @chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                              iobroker add klf200
                                iobroker add klf200
                                Chrisdor
                                #721
                                @glasfaser hat leider auch nicht geklappt
                                2022-08-20 21:53:06.714 - info: host.e-server instance system.adapter.klf200.0 started with pid 2473
                                2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
                                2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err;
                                2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^
                                2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
                                2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack:
                                2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
                                2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
                                2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
                                2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
                                2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
                                2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
                                2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
                                2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
                                2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
                                2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
                                2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
                                2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: }
                                2022-08-20 21:53:08.275 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2022-08-20 21:53:08.276 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
                                2022-08-20 21:53:08.276 - info: host.e-server system.adapter.klf200.0 will be rebuilt
                                2022-08-20 21:53:08.278 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2022-08-20 21:53:08.278 - info: host.e-server iobroker rebuild
                                2022-08-20 21:53:09.677 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
                                • GlasfaserG Offline
                                  GlasfaserG Offline
                                  #722
                                  @chrisdor
                                  Sorry keine Idee mehr .. warum dieser Adapter zickt .
                                    @chrisdor
                                    Chrisdor
                                    #723
                                    @glasfaser ok, aber danke für deine Bemühungen!
                                    • C Chrisdor
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      #724
                                      Was liefert denn ein npm list|grep node ?
                                      Taucht da node-schedule auf? Sonst versuche mal ein npm install node-schedule
                                      LG SBorg ( SBorg auf GitHub)
                                      • SBorgS SBorg
                                        Chrisdor
                                        #725
                                        @sborg das wars jetzt funktioniert es! Danke, Danke!!!
                                        e-server@e-server:/opt/iobroker$ npm list|grep node
                                        ├── node-inspect@2.0.0 extraneous
                                        e-server@e-server:/opt/iobroker$ npm install node-schedule
                                        added 1 package, removed 645 packages, and changed 1 package in 17s
                                        └── node-schedule@2.1.0
                                        Hab jetzt noch einen Master und einen zweiten Slave, da kommt node-schedule auch nicht vor. Aber alle installierten Adapter laufen problemlos bzw. Iobroker selbst auch! Sollt ich das auch nach installieren?
                                        Last login: Sat Aug 20 18:48:31 2022 from 192.168.178.57
                                        c-server@c-server:~$ cd /opt/iobroker
                                        c-server@c-server:/opt/iobroker$ npm list|grep node
                                        [sudo] password for c-server:
                                        Last login: Sun Aug 21 13:44:13 2022 from 192.168.178.57
                                        d-server@d-server:~$ cd /opt/iobroker
                                        d-server@d-server:/opt/iobroker$ npm list|grep node
                                        [sudo] password for d-server:
                                        • C Chrisdor
                                          SBorgS Offline
                                          SBorgS Offline
                                          SBorg
                                          #726
                                          Nein, das wäre nur Ressourcenverschwendung. Falls mal ein Adapter auf einem System den braucht, meldet er sich schon (siehe "error" in deinen Logs von oben). Normalerweise werden die Dependencies aber auch vom Adapter aufgelöst und nachinstalliert.
                                          Fährst ja auch nicht das ganze Jahr mit angehängtem Wohnwagen rum, nur weil du ihn vielleicht mal 2 Wochen im Jahr brauchst ;)
