  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.8k
812 Beiträge 97 Kommentatoren 458.1k Aufrufe 83 Beobachtet
  • GlasfaserG Offline
    GlasfaserG Offline
    #722
    @chrisdor
    Sorry keine Idee mehr .. warum dieser Adapter zickt .
    C 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @chrisdor
      Chrisdor
      #723
      @glasfaser ok, aber danke für deine Bemühungen!
      • C Chrisdor
        @glasfaser hat leider auch nicht geklappt
        2022-08-20 21:53:06.714 - info: host.e-server instance system.adapter.klf200.0 started with pid 2473
        2022-08-20 21:53:08.269 - error: host.e-server Caught by controller[0]: node:internal/modules/cjs/loader:959
        2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: throw err;
        2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: ^
        2022-08-20 21:53:08.270 - error: host.e-server Caught by controller[0]: Error: Cannot find module 'node-schedule'
        2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: Require stack:
        2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
        2022-08-20 21:53:08.271 - error: host.e-server Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
        2022-08-20 21:53:08.272 - error: host.e-server Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
        2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
        2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1126:14)
        2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
        2022-08-20 21:53:08.273 - error: host.e-server Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1004:32)
        2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
        2022-08-20 21:53:08.274 - error: host.e-server Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
        2022-08-20 21:53:08.275 - error: host.e-server Caught by controller[0]: }
        2022-08-20 21:53:08.275 - error: host.e-server instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-08-20 21:53:08.276 - info: host.e-server Adapter system.adapter.klf200.0 needs rebuild and will be restarted afterwards.
        2022-08-20 21:53:08.276 - info: host.e-server system.adapter.klf200.0 will be rebuilt
        2022-08-20 21:53:08.278 - warn: host.e-server adapter "klf200" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        2022-08-20 21:53:08.278 - info: host.e-server iobroker rebuild
        2022-08-20 21:53:09.677 - info: host.e-server iobroker npm-rebuild: Rebuilding native modules ...
        SBorgS Offline
        SBorgS Offline
        SBorg
        #724
        @chrisdor sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
        Was liefert denn ein npm list|grep node ?
        Taucht da node-schedule auf? Sonst versuche mal ein npm install node-schedule
        LG SBorg ( SBorg auf GitHub)
        • SBorgS SBorg
          Chrisdor
          #725
          @sborg das wars jetzt funktioniert es! Danke, Danke!!!
          e-server@e-server:/opt/iobroker$ npm list|grep node
          [sudo] password for e-server:
          ├── node-inspect@2.0.0 extraneous
          e-server@e-server:/opt/iobroker$ npm install node-schedule
          added 1 package, removed 645 packages, and changed 1 package in 17s
          90 packages are looking for funding
            run `npm fund` for details
          └── node-schedule@2.1.0
          Hab jetzt noch einen Master und einen zweiten Slave, da kommt node-schedule auch nicht vor. Aber alle installierten Adapter laufen problemlos bzw. Iobroker selbst auch! Sollt ich das auch nach installieren?
          Last login: Sat Aug 20 18:48:31 2022 from 192.168.178.57
          c-server@c-server:~$ cd /opt/iobroker
          c-server@c-server:/opt/iobroker$ npm list|grep node
          [sudo] password for c-server:
          Last login: Sun Aug 21 13:44:13 2022 from 192.168.178.57
          d-server@d-server:~$ cd /opt/iobroker
          d-server@d-server:/opt/iobroker$ npm list|grep node
          [sudo] password for d-server:
          • C Chrisdor
            SBorgS Offline
            SBorgS Offline
            SBorg
            #726
            Nein, das wäre nur Ressourcenverschwendung. Falls mal ein Adapter auf einem System den braucht, meldet er sich schon (siehe "error" in deinen Logs von oben). Normalerweise werden die Dependencies aber auch vom Adapter aufgelöst und nachinstalliert.
            Fährst ja auch nicht das ganze Jahr mit angehängtem Wohnwagen rum, nur weil du ihn vielleicht mal 2 Wochen im Jahr brauchst ;)
            • SBorgS SBorg
              Chrisdor
              #727
              @sborg sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
              Ok, verstehe!! Danke nochmal.
              Da hast du natürlich recht!! :😁
              • F Offline
                Frank06347
                #728
                ich habe auf die empfohlene Version Node.js 16.x ein Update gemacht.
                Jetzt wird folgendes in der Übersicht angezeigt:
                Ist das so richtig?
                Welche NPM Version wird empfohlen?
                Muss ich mich um die NPM-Version kümmern? ... oder kommt die automatisch durch Node.js?
                Wo finde ich die verfügbaren Updates (siehe Screeshot)?
                Viele Grüße
                Frank
                DiginixD HomoranH 2 Antworten Letzte Antwort
                • F Frank06347
                  Ist das so richtig?
                  Viele Grüße
                  Frank
                  DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #729
                  @frank06347 Das passt so. NPM nicht manuell updaten, kommt passend mit und zur nodejs Ver.
                  ..:: So long! Tom ::..
                  • F Frank06347
                    Ist das so richtig?
                    Viele Grüße
                    Frank
                    #730
                    @frank06347 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                    Ist das so richtig?
                    ja!
                    https://forum.iobroker.net/post/848055
                    F 1 Antwort Letzte Antwort
                      Ist das so richtig?
                      ja!
                      Frank06347
                      #731
                      @homoran sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                      Ist das so richtig?
                      ja!
                      Alles klar ... Fehler im Admin .... vielen Dank für schnelle Antwort!
                      Viele Grüße
                      Frank
                      • F Frank06347
                        Ist das so richtig?
                        ja!
                        Viele Grüße
                        Frank
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #732
                        Nur zur Klärung , das ist kein Fehler vom ADMIN !
                        Deshalb habe ich hier :
                        ... es soll nur verhindert werden : "verleitet nur zu unnötigen Installations/Upgrade-Versuchen."
                        https://github.com/ioBroker/ioBroker.admin/issues/1663
                          torstenhe
                          schrieb am zuletzt editiert von torstenhe
                          #733
                          Schönen guten Morgen,
                          wollte euch mein Erfolgserlebnis in Bezug auf Node.js mitteilen.
                          kurz zur Vorgeschichte. Mein iobroker lief jetzt mehr als ein Jahr unter Windows auf einem Surface 1. Bisher habe ich immer alles hinbekommen und er lief 24 / 7 ohne Probleme, egal welches Update, es lief einfach super.
                          Jetzt bin ich auf proxmox gewechselt und einem Surface Pro 7 mit mit Displayschaden umgezogen. Als OS habe ich ubuntu server gewählt, 4 Cores und 4 GB RAM.
                          Im ioBroker unter Windows Backup gezogen und im Ubuntu Server eingespielt. Hat erst mal länger gedauert, hatte da am Anfang etwas Probleme mit, läuft aber jetzt und das sehr performant.
                          Dann Conbee ii usb durchgereicht, alles installiert und Backup eingespielt. Lief auf anhieb.
                          Bis hierher alles gut gelaufen und es läuft auch alles.
                          Dann habe ich gesehen das meine Node.js Version noch auf v12.22.9 ist.
                          Ich hab glaub ich alles durch was man so machen kann. Snapshots sei dank, so kam ich immer wieder zurück. :-) Aber nichts hatte geholfen. Stichwort "Broken-Pipe".
                          Nur das folgende konnte mir helfen:
                          iobroker stop
                          cd /opt/iobroker
                          sudo npm cache verify
                          sudo chown -R iobroker /opt/iobroker
                          sudo apt update -y && sudo apt upgrade -y
                          sudo apt-get purge nodejs -y && sudo apt-get autoremove -y && sudo apt-get autoclean -y
                          sudo curl -sL https://deb.nodesource.com/setup_16.x | sudo bash -
                          sudo apt-get install -y nodejs
                          iobroker stop
                          npm install -y iobroker.js-controller --unsafe-perm --production --save --prefix
                          curl -sL https://iobroker.net/fix.sh | bash -
                          npm rebuild
                          iobroker update
                          iobroker upgrade self
                          iobroker upgrade -y
                          iobroker start
                          Vielleicht hilft das dem ein oder anderen noch. :)
                          LG
                          Torsten
                          • T torstenhe
                            iobroker stop
                            cd /opt/iobroker
                            iobroker stop
                            npm rebuild
                            iobroker update
                            iobroker upgrade -y
                            iobroker start
                            LG
                            Torsten
                            #734
                            @torstenhe
                            Ehrlich gesagt: Recht wirr.
                              @torstenhe
                              torstenhe
                              #735
                              Mag sein, läuft aber jetzt. 🙄
                                Andre105
                                schrieb am zuletzt editiert von Andre105
                                #736
                                Moin,
                                Ist es jetzt ratsam auf Node.js 16 zu wechseln?
                                Wenn ja, wie war das noch mit den Befehlen?
                                • A Andre105
                                  Moin,
                                  #737
                                  @andre105
                                  Ja.
                                  HowTo in meiner Signatur.
                                    @andre105
                                    Ja.
                                    Andre105
                                    #738
                                    Muss ich das auch beachten?
                                    HINWEIS: ACHTUNG BEIM UPGRADE AUF NODE.js 16!!!
                                    Ein Upgrade auf die Version 16 / npm 8 erfordert im Vorfeld einen sauberen 'npm tree'!!!.
                                    Bei mir steht das:
                                    andre105@iobroker:~$ cd /opt/iobroker
                                    npm ls | grep -E 'github|ERR'
                                    [sudo] Passwort für andre105:
                                    │ │ │ ├── github-from-package@0.0.0
                                    npm ERR! peer dep missing: buffer@>=6.0.3, required by crc@4.1.1
                                    npm ERR! extraneous: libmime@5.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/libmime
                                      │ │ │   ├── github-from-package@0.0.0 deduped
                                    andre105@iobroker:/opt/iobroker$
                                    • A Andre105
                                      Bei mir steht das:
                                      #739
                                      @andre105
                                      Nein, sollte kein Problem sein.
                                        @andre105
                                        Andre105
                                        #740
                                        Hat geklappt 👍
                                        • A Andre105
                                          Hat geklappt 👍
                                          #741
                                          @andre105
                                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          sagt?
