  3. Off Topic
  4. InfluxDB
  5. Benötige Hilfe bei Influx DB
Geplant Angeheftet Gesperrt Verschoben InfluxDB
109 Beiträge 7 Kommentatoren 27.5k Aufrufe 5 Beobachtet
  • A Altersrentner
    Danke für Deine Hilfe.
    pi@raspberrypiioBroker:~ $ wget -q https://repos.influxdata.com/influxdb.key
    pi@raspberrypiioBroker:~ $ echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    influxdb.key: OK
    pi@raspberrypiioBroker:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    pi@raspberrypiioBroker:~ $ sudo apt update && sudo apt install influxdb2
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [4,645 B]
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://packages.grafana.com/oss/deb stable InRelease
    Get:8 https://repos.influxdata.com/debian stable/main armhf Packages [779 B]
    Get:9 https://repos.influxdata.com/debian stable/main arm64 Packages [1,260 B]
    Fetched 50.8 kB in 2s (26.0 kB/s)
    Reading package lists... Done
    All packages are up to date.
    The following additional packages will be installed:
      influxdb2-cli
    The following NEW packages will be installed:
      influxdb2 influxdb2-cli
    0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 94.3 MB of archives.
    After this operation, 160 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2 arm64 2.3.0-1 [89.4 MB]
    Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.3.0 [4,953 kB]
    Fetched 94.3 MB in 17s (5,603 kB/s)
    Selecting previously unselected package influxdb2.
    (Reading database ... 45845 files and directories currently installed.)
    Preparing to unpack .../influxdb2_2.3.0-1_arm64.deb ...
    Unpacking influxdb2 (2.3.0-1) ...
    Selecting previously unselected package influxdb2-cli.
    Preparing to unpack .../influxdb2-cli_2.3.0_arm64.deb ...
    Unpacking influxdb2-cli (2.3.0) ...
    Setting up influxdb2 (2.3.0-1) ...
    Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
    Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
    Setting up influxdb2-cli (2.3.0) ...
    pi@raspberrypiioBroker:~ $ sudo service influxdb2 start
    Failed to start influxdb2.service: Unit influxdb2.service not found.
    pi@raspberrypiioBroker:~ $ sudo service influxdb start
    pi@raspberrypiioBroker:~ $ sudo influx
    NAME:
       influx - Influx Client
    USAGE:
       influx [command]
    COMMANDS:
       version              Print the influx CLI version
       write                Write points to InfluxDB
       bucket               Bucket management commands
       completion           Generates completion scripts
       query                Execute a Flux query
       config               Config management commands
       org, organization    Organization management commands
       delete               Delete points from InfluxDB
       user                 User management commands
       task                 Task management commands
       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
       dashboards           List Dashboard(s).
       export               Export existing resources as a template
       secret               Secret management commands
       v1                   InfluxDB v1 management commands
       auth, authorization  Authorization management commands
       apply                Apply a template to manage resources
       stacks               List stack(s) and associated templates. Subcommands manage stacks.
       template             Summarize the provided template
       bucket-schema        Bucket schema management commands
       ping                 Check the InfluxDB /health endpoint
       setup                Setup instance with initial user, org, bucket
       backup               Backup database
       restore              Restores a backup directory to InfluxDB
       remote               Remote connection management commands
       replication          Replication stream management commands
       server-config        Display server config
       help, h              Shows a list of commands or help for one command
    GLOBAL OPTIONS:
       --help, -h  show help
    Muss ich jetzt noch Rechte einfügen? Etwa so?
    CREATE USER "admin" WITH PASSWORD '<adminpassword>' WITH ALL PRIVILEGES
    CREATE USER "user" WITH PASSWORD '<userpassword>'
    CREATE DATABASE "iobroker"
    GRANT ALL ON "iobroker" TO "user"
    R
    R
    Rosi8818
    schrieb am zuletzt editiert von Rosi8818
    hat sich erledigt, war hier schon geschrieben und hab ich zu spät gesehen
    • DJMarc75D DJMarc75
      @altersrentner sagte in Benötige Hilfe bei Influx DB:
      nur so
      passt!
      Kann man die Passwörter irgendwo sehen?
      Natürlich nicht.
      User jetzt nochmal nach meiner Vorlage angelegt ?
      A
      A
      Altersrentner
      @djmarc75 sagte in Benötige Hilfe bei Influx DB:
      Ist gemacht,
      jetzt
      sudo reboot
      • A Altersrentner
        Ist gemacht,
        jetzt
        sudo reboot
        DJMarc75D
        DJMarc75D
        DJMarc75
        sudo reboot
        brauch es nicht aber den Service neu starten.
        Und falls das nix gebracht hat probiere es so aus
        https://forum.iobroker.net/post/667113
        Lehrling seit 1975 !!!
        A 2 Antworten Letzte Antwort
          sudo reboot
          A
          A
          Altersrentner
          @djmarc75
          So Grafana ist gespeichert - Datenquelle aktualisiert.
          Werde dann mal heute Abend sehen ob ich ein paar Daten
          eingearbeitet bekomme.
          Danke euch.
          Melde mich wieder
          MfG Michael
            sudo reboot
            A
            A
            Altersrentner
            @djmarc75
            Doch nicht alles gut.
            Habe jetzt in Grafana das erste Bord angelegt.
            Kann es aber nicht in die VIS laden.
            Habe gesehen, das es Verbinungsprobleme ( Bild ) gibt.
            Hast Du eine Idee?
            Mir ist noch aufgefallen, das ioBroker auf zwei unterschiedlichen IPs läuft.
            120 und 41, das ist doch auch nicht normal, oder?
            Gruß MIchael
            DJMarc75D HomoranH Thomas BraunT 3 Antworten Letzte Antwort
            • A Altersrentner
              @djmarc75
              Hast Du eine Idee?
              Gruß MIchael
              DJMarc75D
              DJMarc75D
              DJMarc75
              Na klar ist das normal. Einmal per LAN und einmal per WLAN.
              Bitte aber nicht das LANKabel ziehen weil der ioBroker per LAN arbeiten sollte.
              Thema Verbindungsfehler --> Suchfunktion ergibt etliche Ergebnisse mit Lösungen
              z.B. https://forum.iobroker.net/topic/56618/vis-editor-meldet-immer-verbindungsfehler?_=1659436666712
              oder auch https://forum.iobroker.net/topic/56596/gelöst-vis-edit-meldet-verbindungsfehler?_=1659436666714
              Das nochmal hier durchzukauen macht wenig Sinn.
              • A Altersrentner
                @djmarc75
                Hast Du eine Idee?
                Gruß MIchael
                nein, ist es nicht.
                wie ist es dir aufgefallen?
                hast du LAN und WLAN am RasPi aktiviert?
                • A Altersrentner
                  @djmarc75
                  Hast Du eine Idee?
                  Gruß MIchael
                  Thomas BraunT
                  Thomas BraunT
                  ip a
                  sagt dir welches Netzwerk-Interface da mit welchen IPs versehen wurde.
                    nein, ist es nicht.
                    A
                    A
                    Altersrentner
                    @homoran sagte in Benötige Hilfe bei Influx DB:
                    Im Moment habe ich das LAN angesteckt
                    @thomas-braun sagte in Benötige Hilfe bei Influx DB:
                    pi@raspberrypiioBroker:~ $ ip a
                    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
                        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
                        inet 127.0.0.1/8 scope host lo
                           valid_lft forever preferred_lft forever
                        inet6 ::1/128 scope host
                    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
                        link/ether dc:a6:32:1b:bd:83 brd ff:ff:ff:ff:ff:ff
                        inet 192.168.178.41/24 brd 192.168.178.255 scope global dynamic noprefixroute eth0
                           valid_lft 848809sec preferred_lft 740809sec
                        inet6 2003:dc:9f19:4a00:5d01:c0bf:b13b:f74d/64 scope global dynamic mngtmpaddr noprefixroute
                           valid_lft 6942sec preferred_lft 1542sec
                        inet6 fe80::75a5:b9b4:6580:a932/64 scope link
                    3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                        link/ether dc:a6:32:1b:bd:85 brd ff:ff:ff:ff:ff:ff
                        inet 192.168.178.120/24 brd 192.168.178.255 scope global dynamic noprefixroute wlan0
                           valid_lft 848811sec preferred_lft 740811sec
                        inet6 2003:dc:9f19:4a00:d056:5ceb:f82:19e1/64 scope global dynamic mngtmpaddr noprefixroute
                        inet6 fe80::8424:c480:f6e8:d77a/64 scope link
                    • A Altersrentner
                      Thomas BraunT
                      Thomas BraunT
                      @altersrentner
                      41 - LAN
                      120 - WLAN
                      Also alles i.O.
                        @altersrentner
                        41 - LAN
                        120 - WLAN
                        Also alles i.O.
                        A
                        A
                        Altersrentner
                        Also alles i.O.
                        • A Altersrentner
                          Zusätzlich zum WLAN! 😊
                            A
                            A
                            Altersrentner
                            schrieb am zuletzt editiert von Altersrentner
                            Das Problem ist behoben.
                            Leider bekomme ich kein Deshboard von Grafana in die VIS integriert
                            Das habe ich eingestellt:
                            sudo nano /etc/grafana/grafana.ini
                            		[security]
                            		allow_embedding = true
                            		[auth.anonymous]
                            		enabled = true
                            		org_name = Main Org.
                            		org_role = Viewer
                            		[user]
                            		allow_sign_up = false
                            	sudo service grafana-server stop
                            	sudo service grafana-server start
                            Normal sollte der Link dann unter VIS Allgemein Quelle eingefügt werden.
                            Was ich auch gemacht habe
                            Aber das I Frame bleibt weiß
                            • A Altersrentner
                              		[security]
                              		[auth.anonymous]
                              		enabled = true
                              		org_role = Viewer
                              		[user]
                              DJMarc75D
                              DJMarc75D
                              DJMarc75
                              @altersrentner sieht der Eintrag in der grafana.ini bei Dir tatsächlich so aus ?
                              # set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
                              nicht dass da noch ein ";" davor steht.
                              Ansonsten mal einfach die Kiste neu starten und dann nochmal testen.
                                A
                                A
                                Altersrentner
                                Das stand davor
                                Habe ich entfernt
                                Bei den anderen Eintragungen steht ";" auch vor
                                • A Altersrentner
                                  Das stand davor
                                  Habe ich entfernt
                                  DJMarc75D
                                  DJMarc75D
                                  DJMarc75
                                  Das muss da natürlich auch weg
                                  [auth.anonymous]
                                  enabled = true
                                  org_role = Viewer
                                  [users]
                                  abspeichern und danach nochmal den service stoppen und starten
                                    [auth.anonymous]
                                    enabled = true
                                    org_role = Viewer
                                    [users]
                                    A
                                    A
                                    Altersrentner
                                    Ist gemacht!
                                    Jetzt alles prima.
                                    Zumindest habe ich nichts weiter festgestellt.
                                    Ich bedanke mich für eure Unterstützung und Hilfe.
                                    Mit freundlichen Grüßen
                                    Michael
                                    • A Altersrentner
                                      Ist gemacht!
                                      Jetzt alles prima.
                                      Michael
                                      A
                                      A
                                      Altersrentner
                                      @altersrentner
                                      Ich habe hier jetzt viele Beiträge hinsichtlich Aktualisierung Grafana gelesen.
                                      Alle Unterschiede wurden probiert. Leider ohne Erfolg.
                                      In der vorherigen Installation gab es diese Probleme nicht
                                      Bei dieser Version wird nicht aktualisiert.
                                      Erst wenn ich auf Dashboard aktualisieren klicke tut sich etwas.
                                      Ist das normal?
                                      • A Altersrentner
                                        @altersrentner
                                        Ist das normal?
                                        DJMarc75D
                                        DJMarc75D
                                        DJMarc75
                                        @altersrentner
                                        Tag,
                                        wenn Du das Dashboard meinst dann muss Du hier eine Zeit einstellen:
                                        danach das Dashboard natürlich speichern.
                                          @altersrentner
                                          Tag,
                                          A
                                          A
                                          Altersrentner
                                          Bei mir geht nur das
                                          83.9k
