  3. Off Topic
  4. InfluxDB
  5. Benötige Hilfe bei Influx DB
Geplant Angeheftet Gesperrt Verschoben InfluxDB
109 Beiträge 7 Kommentatoren 27.5k Aufrufe 5 Beobachtet
  • A Altersrentner
    @homoran Danke
    Thomas BraunT
    Thomas BraunT
    @altersrentner
    wget -q https://repos.influxdata.com/influxdb.key
    echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
    echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
    sudo apt update && sudo apt install influxdb2
      @altersrentner
      A
      A
      Altersrentner
      Danke für Deine Hilfe.
      pi@raspberrypiioBroker:~ $ wget -q https://repos.influxdata.com/influxdb.key
      pi@raspberrypiioBroker:~ $ echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
      influxdb.key: OK
      pi@raspberrypiioBroker:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      pi@raspberrypiioBroker:~ $ sudo apt update && sudo apt install influxdb2
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 https://repos.influxdata.com/debian stable InRelease [4,645 B]
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://packages.grafana.com/oss/deb stable InRelease
      Get:8 https://repos.influxdata.com/debian stable/main armhf Packages [779 B]
      Get:9 https://repos.influxdata.com/debian stable/main arm64 Packages [1,260 B]
      Fetched 50.8 kB in 2s (26.0 kB/s)
      Reading package lists... Done
      All packages are up to date.
      The following additional packages will be installed:
        influxdb2-cli
      The following NEW packages will be installed:
        influxdb2 influxdb2-cli
      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
      Need to get 94.3 MB of archives.
      After this operation, 160 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2 arm64 2.3.0-1 [89.4 MB]
      Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.3.0 [4,953 kB]
      Fetched 94.3 MB in 17s (5,603 kB/s)
      Selecting previously unselected package influxdb2.
      (Reading database ... 45845 files and directories currently installed.)
      Preparing to unpack .../influxdb2_2.3.0-1_arm64.deb ...
      Unpacking influxdb2 (2.3.0-1) ...
      Selecting previously unselected package influxdb2-cli.
      Preparing to unpack .../influxdb2-cli_2.3.0_arm64.deb ...
      Unpacking influxdb2-cli (2.3.0) ...
      Setting up influxdb2 (2.3.0-1) ...
      Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
      Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
      Setting up influxdb2-cli (2.3.0) ...
      pi@raspberrypiioBroker:~ $ sudo service influxdb2 start
      Failed to start influxdb2.service: Unit influxdb2.service not found.
      pi@raspberrypiioBroker:~ $ sudo service influxdb start
      pi@raspberrypiioBroker:~ $ sudo influx
      NAME:
         influx - Influx Client
      USAGE:
         influx [command]
      COMMANDS:
         version              Print the influx CLI version
         write                Write points to InfluxDB
         bucket               Bucket management commands
         completion           Generates completion scripts
         query                Execute a Flux query
         config               Config management commands
         org, organization    Organization management commands
         delete               Delete points from InfluxDB
         user                 User management commands
         task                 Task management commands
         telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
         dashboards           List Dashboard(s).
         export               Export existing resources as a template
         secret               Secret management commands
         v1                   InfluxDB v1 management commands
         auth, authorization  Authorization management commands
         apply                Apply a template to manage resources
         stacks               List stack(s) and associated templates. Subcommands manage stacks.
         template             Summarize the provided template
         bucket-schema        Bucket schema management commands
         ping                 Check the InfluxDB /health endpoint
         setup                Setup instance with initial user, org, bucket
         backup               Backup database
         restore              Restores a backup directory to InfluxDB
         remote               Remote connection management commands
         replication          Replication stream management commands
         server-config        Display server config
         help, h              Shows a list of commands or help for one command
      GLOBAL OPTIONS:
         --help, -h  show help
      Muss ich jetzt noch Rechte einfügen? Etwa so?
      CREATE USER "admin" WITH PASSWORD '<adminpassword>' WITH ALL PRIVILEGES
      CREATE USER "user" WITH PASSWORD '<userpassword>'
      CREATE DATABASE "iobroker"
      GRANT ALL ON "iobroker" TO "user"
      Thomas BraunT R 2 Antworten Letzte Antwort
      • A Altersrentner
        influxdb.key: OK
          influxdb2-cli
        NAME:
        USAGE:
           influx [command]
        COMMANDS:
        GLOBAL OPTIONS:
        Thomas BraunT
        Thomas BraunT
        @altersrentner
        Ich setzte kein influx ein. Wie das zu konfigurieren ist kann ich dir nicht sagen.
          ich habe das mal nach OffTopic verschoben. InfluxDB und Grafana sind keine Bestandteile von ioBroker sonder "Fremdprogramme" die "nur" mit Daten von ioBroker gefüttert werden.
          @altersrentner sagte in Benötige Hilfe bei Influx DB:
          Eigentlich sollte es von Grafana auch eine Sicherung geben
          wie hast du denn Grafana gesichert?
          DJMarc75D
          DJMarc75D
          DJMarc75
          @homoran sagte in Benötige Hilfe bei Influx DB:
          Leider garnicht !
          Mach langsam damit.
          Welche Anleitung hast Du genutzt ??
          EDIT:
          Du hast hoffentlich jetzt nicht influxdb2 installiert ???????????????????
          Lehrling seit 1975 !!!
          • DJMarc75D DJMarc75
            Leider garnicht !
            Mach langsam damit.
            EDIT:
            Thomas BraunT
            Thomas BraunT
            @djmarc75
            haut influxdb2 auf die Kiste.
            HomoranH DJMarc75D 2 Antworten Letzte Antwort
              @djmarc75
              @thomas-braun sagte in Benötige Hilfe bei Influx DB:
              @djmarc75
              aber nur mit 64bit
                @djmarc75
                aber nur mit 64bit
                Thomas BraunT
                Thomas BraunT
                Mit 32bit kann der nicht installiert werden, weil der dann gar nicht in der Auslage liegt.
                  @djmarc75
                  DJMarc75D
                  DJMarc75D
                  DJMarc75
                  Das wollen wir eigentlich vermeiden weil ... siehe gestern 😉
                    Thomas BraunT
                    Thomas BraunT
                    @djmarc75
                    Altersrentner kam mit influxdb2 an. Ich hab nur das Repo gerade gerückt. Aus der Quelle kann man ja beides schöpfen. Was dann da installiert und benötigt wird muss jeder selber wissen.
                    • A Altersrentner
                      Nachdem mein System neu installiert wurde und anschließend mittels Backup
                      in den Betriebszustand versetzt ist hänge ich an der Influx7 Grafana Installation.
                      Eigentlich sollte es von Grafana auch eine Sicherung geben, aber es ist nun mal nicht so.
                      Mit meinen alten Installationsaufzeichnungen komme ich nicht weiter. Es hängt immer an einem veralteten Code.
                      Jetzt habe ich hier im Forum eine neue Anleitung gefunden, Mit der ich aber auch nicht weiter komme.
                      Hier der Code der besagten Anleitung.
                      Zum Installieren von InfluxDB genügen zwei Befehle im Terminal.
                      1. wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor |
                      sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null export
                      DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -
                      sc) echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg]
                      https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME}
                      stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                      2. sudo apt-get update && sudo apt-get install influxdb2
                      Dass InfluxDB beim Booten ebenfalls als Service gestartet wird, bewirkt folgender Befehl .
                      Und hier das Ergebnis bei mir:
                      pi@raspberrypiioBroker:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor |
                      Usage: lsb_release [options]
                      lsb_release: error: No arguments are permitted
                      -bash: sc: command not found
                      -bash: export: `deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg]
                      stable': not a valid identifier
                      pi@raspberrypiioBroker:~ $ sudo apt-get update && sudo apt-get install influxdb2
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                      Get:5 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
                      Get:7 https://packages.grafana.com/oss/deb stable/main armhf Packages [36.0 kB]
                      Get:8 https://packages.grafana.com/oss/deb stable/main arm64 Packages [26.5 kB]
                      Fetched 119 kB in 2s (65.8 kB/s)
                      E: Unable to locate package influxdb2
                      Failed to start influxdb.service: Unit influxdb.service not found.
                      pi@raspberrypiioBroker:~ $ iob start
                      Wo liegt mein Problem bzw. wie kann ich weiter kommen.
                      Gruß Michael
                      etwa so?
                        @djmarc75
                        DJMarc75D
                        DJMarc75D
                        DJMarc75
                        Jetzt hab ichs auch gesehen.... dann wird das hier wieder ein langer Thread 😩
                          etwa so?
                          Thomas BraunT
                          Thomas BraunT
                          etwa so?
                          Nein, nicht so. Das lag ja am nicht korrekt eingebundenen Repo. Da hätte man auch kein influx1 drüber bekommen.
                            A
                            A
                            Altersrentner
                            schrieb am zuletzt editiert von Altersrentner
                            @djmarc75 sagte in Benötige Hilfe bei Influx DB:
                            Da hast Du aber eine schlechte Meinung von mir😧
                            Stand der Dinge aktuell:
                            IoBroker läuft
                            InfluxDB läuft
                            Grafana läuft
                            Soweit so gut
                            Es fehlt nur noch die Verbindung von Grafana mit der InfluxDB
                            • A Altersrentner
                              IoBroker läuft
                              InfluxDB läuft
                              Grafana läuft
                              Soweit so gut
                              DJMarc75D
                              DJMarc75D
                              DJMarc75
                              Quatsch.
                              Aber jetzt zum Thema. Welche influxdb hast Du denn nun installiert ? DIe 1er oder 2er?
                              Und welche hattest Du vorher ?
                              A 2 Antworten Letzte Antwort
                                Quatsch.
                                A
                                A
                                Altersrentner
                                Ich denke 1
                                • A Altersrentner
                                  Ich denke 1
                                  DJMarc75D
                                  DJMarc75D
                                  DJMarc75
                                  Ich denke 1
                                  influxd version
                                    Quatsch.
                                    A
                                    A
                                    Altersrentner
                                    @djmarc75
                                    In der influxDB muss unter Settings Benutzer und Passwort eingestellt werden.
                                    Dort stehen jetzt noch durch das eingespielte Backup die alten Daten drin.
                                    Das Passwort habe ich aber vergessen.
                                    Da es keine Sicherung von Grafana gibt, muss ich dort unter Datenquellen/Einstellungen/influxDB
                                    ganz unten:
                                    Datenbannk: iobroker
                                    Benutzer: admin
                                    Passwort:?
                                    eingeben.
                                    Das ist doch das Passwort aus der influxDB, oder?
                                    Wenn ja, kann ich ein neues Passwort vergeben?
                                      Ich denke 1
                                      influxd version
                                      A
                                      A
                                      Altersrentner
                                      influxd version
                                      pi@raspberrypiioBroker:~ $ influxd version
                                      InfluxDB v1.8.10 (git: 1.8 688e697c51fd)
                                      • A Altersrentner
                                        @djmarc75
                                        ganz unten:
                                        Benutzer: admin
                                        Passwort:?
                                        eingeben.
                                        DJMarc75D
                                        DJMarc75D
                                        DJMarc75
                                        Hast Du denn gestern oder heute einen Benutzer admin angelegt ?
                                          A
                                          A
                                          Altersrentner
                                          Das ist noch der Benutzer aus der alten Installation.
                                          Benutzer von Grafana jetzt ist auch admin
                                          83.9k
