  4. Kann keine Adapter aktualisieren
75 Beiträge 14 Kommentatoren 17.0k Aufrufe 10 Beobachtet
  • F Frank_y
    @grrfield sagte in Kann keine Adapter aktualisieren:
    Bei mir lassen sich auch keine Adapter mehr aktualisieren - weder über die Weboberfläche noch über die Kommandozeile:
    rock64@rock64:/opt/iobroker$ iobroker update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.1.7    , installed 1.11.1 [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 3.3.1    , installed 3.3.1
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "rest-api"     : 1.0.0    , installed 1.0.0
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "samsung"      : 0.5.8    , installed 0.5.8
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    rock64@rock64:/opt/iobroker$ iobroker upgrade
    This upgrade of "synology" will introduce the following changes:
    -> 2.1.9:
    Try to prevent account locks when using 2FA on restarts of the NAS
    -> 2.1.8:
    slow down reconnects to the DSM
    Would you like to upgrade synology from @2.1.7 to @2.1.9 now? [(y)es, (n)o]: y
    Update synology from @2.1.7 to @2.1.9
    NPM version: 8.11.0
    Installing iobroker.synology@2.1.9... (System call)
    host.rock64 Cannot install iobroker.synology@2.1.9: 128
    Bisher hatte ich nie Probleme beim Aktualisieren. Ich habe schon den iobroker-Fixer laufen lassen. Was kann ich noch tun?
    js-controller 4.0.23
    nodejs v16.16.0
    npm 8.11.0
    Bei mir das selbe Problem mit den stabel-Updates folgender Adapter:
    -discovery devices 3.0.3 ->3.0.5
    -History 1.11.1 ->2.1.7
    -iCal 1.12.1 ->1.13.1
    -influxDB 2.6.3 ->3.1.7
    -IoT assistants 1.11.4 ->1.11.8
    Der Worx-Adapter 1.5.5 -> 1.6.6 ließ sich ohne Fehler updaten
    nodejs sowohl bei v16.15.1 und v16.16.0
    node v16.15.1 bzw. v16.16.0
    npm 8.11.0
    habe auch iob fix noch einmal laufen lassen.
    Beispielhaft hier für History-Update:
    XXXXX@iobrokerVM:~$ iobroker upgrade history  --debug
    This upgrade of "history" will at least introduce the following changes:
    -> 2.1.7:
    Allow to remove a configuration value for "round" in config again
    -> 2.1.6:
    When not count is provided for aggregate "none" or "onchange" then the limit (de                                                fault 2000) is used as count to define the number of data to return.
    -> 2.1.5:
    Ignore errors from forked process after response was sent for GetHistory
    -> 2.1.4:
    Make sure debug log is active according to the settings
    -> 2.1.3:
    Huge performance optimizations for GetHistory calls
    -> 2.1.2:
    Fix crash case reported by Sentry
    -> 2.1.1:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C                                                HANGES!
    Would you like to upgrade history from @1.11.1 to @2.1.7 now? [(y)es, (n)o]: y
    Update history from @1.11.1 to @2.1.7
    NPM version: 8.11.0
    Installing iobroker.history@2.1.7... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/abab
    npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_56_29_851Z-debug-0.log
    host.iobrokerVM Cannot install iobroker.history@2.1.7: 217
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @frank_y sagte in Kann keine Adapter aktualisieren:
    Alle Verzeichnisse die so ausgespuckt werden löschen.
    Beispiel:
    rm -rf /opt/iobroker/node_modules/.abab-bvmibCm3
    Solange bis alle angemeckerten Verzeichnisse weg sind.
    F 1 Antwort Letzte Antwort
      ioBroker.radar-trap
      Deinstallier den mal temporär für die Upgrades.
      Hattest du die git-basierten Adapter vor dem nodejs16 Update nicht rausgeworfen?
      grrfieldG
      grrfieldG
      grrfield
      @thomas-braun sagte in Kann keine Adapter aktualisieren:
      ioBroker.radar-trap
      Vielen Dank für die schnelle Antwort!
      Ich habe den Adapter über die Weboberfläche deinstalliert, er ist da auch nicht mehr zu sehen. Nach
      iob update
      iobroker upgrade synology --debug
      bekomme ich wieder dieselbe Debug-Ausgabe wie vorher, d. h. es wird immer noch versucht, auf ssh://git@github.com/Steiger04/ioBroker.radar-trap.git zuzugreifen.
      Nein, ich bin eigentlich genau nach der Anleitung [How-to] Node.js ioBroker richtig updaten-2021/22 Edition](https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition?page=1) vorgegangen, und da habe ich nichts gelesen, daß die Git-Adapter vorher entfernt werden müssen. Hätte ich das tun müssen?
      • grrfieldG grrfield
        ioBroker.radar-trap
        iob update
        Thomas BraunT
        Thomas BraunT
        @grrfield
        Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
        Das ist die Passage, die für dich relevant gewesen wäre.
        grrfieldG 1 Antwort Letzte Antwort
          @grrfield
          grrfieldG
          grrfieldG
          grrfield
          Oh, das hatte ich nicht so aufgefaßt, da einige Adapter (radar-trap) noch nicht auf npm sind. Das nächste Mal bin ich dann klüger.
          Wie kann ich denn den Fehler, daß immer bei der Installation neuer Adapter immer noch nach den git-Adaptern gesucht wird, loswerden?
            Thomas BraunT
            Thomas BraunT
            @grrfield
            Schau wo der im tree liegt:
            cd /opt/iobroker
            npm ls iobroker.radar-trap
            • nbrgitN
              nbrgitN
              nbrgit
              ich versuche gerade diverse Adapter zu aktualisieren, leider ohne Erfolg.
              Kurzer Ausschnitt was bei der "Update-Kachel" erscheint :
              Dependencies:
              js-controller (>=3.3.22): 4.0.23
              node (>=12.0.0): 16.16.0
              Der Button "Aktualisieren" ist ausgeblendet.
              Ich weiß nicht so richtig weiter, denn wenn ich das richtig lese, sind alle Voraussetzungen erfüllt aber ein Update ist nicht möglich.
              Kann mir jemand helfen?
              LG
              haselchenH Thomas BraunT 2 Antworten Letzte Antwort
              • nbrgitN nbrgit
                Dependencies:
                LG
                haselchenH
                haselchenH
                haselchen
                @nbrgit
                6 Zeilen unter Dir ist das gleiche Problem.
                Warum nutzt du nicht den Thread?
                @Negalein
                @Homoran
                Bitte zusammenführen
                https://forum.iobroker.net/topic/55518/kann-keine-adapter-aktualisieren
                • nbrgitN nbrgit
                  Dependencies:
                  LG
                  Thomas BraunT
                  Thomas BraunT
                  @nbrgit
                  Was kommt vom System auf diese Befehle in der Kommandozeile zurück?
                  iobroker update -i
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  cd /opt/iobroker
                  npm ls | grep -E 'github|ERR'
                    @grrfield
                    cd /opt/iobroker
                    grrfieldG
                    grrfieldG
                    grrfield
                    Vielen Dank! Ich hatte in der Zwischenzeit weiter nach einem Eintrag mit "radar-trap" gesucht und habe dann in der Datei /opt/iobroker/package.json eine Zeile
                     "iobroker.radar-trap": "github:Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5",
                    gefunden und diese gelöscht (vorher eine Kopie der Datei erstellt).
                    Jetzt bekomme ich diese Fehlermeldung nicht mehr, sondern bin einen Schritt weiter und bekomme die Meldungen, die auch frank_y hat. Ich bin nun dabei, die Verzeichnisse, die als Meldungen ausgegeben werden, zu löschen. Könnte man auch einfach alle versteckten Verzeichnisse unter /opt/iobroker/node_modules löschen, also
                    rm -rf /opt/iobroker/node_modules/.*
                    Für mich das so aus, als ob das nur Sicherheitskopien sind, die vor einer Installation neu erstellt werden.
                      Thomas BraunT
                      Thomas BraunT
                      @grrfield
                      Vorsicht! Da liegt auch ein Verzeichnis .bin drin, das würde ich nicht unbedingt löschen.
                        @grrfield
                        grrfieldG
                        grrfieldG
                        grrfield
                        @thomas-braun Und der Rest?
                          Thomas BraunT
                          Thomas BraunT
                          @grrfield
                          Probier es aus...
                          Ich kann/konnte es bei mir nicht nachstellen, ich hab keine Meldungen zu solchen Verzeichnissen bekommen, in meinem Dateipfad sind auch keine zu finden.
                            Beispiel:
                            F
                            F
                            Frank_y
                            Beispiel:
                            Ich musste ca. 20 Verzeichnisse händisch löschen!
                            Jetzt wird folgender Fehler ausgeworfen:
                            XXXXXXX@iobrokerVM:/opt$ iobroker upgrade history  --debug
                            node:internal/modules/cjs/loader:936
                              throw err;
                            Error: Cannot find module 'at-least-node'
                            Require stack:
                            - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/m        ake-dir.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/i        ndex.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/copy-sync.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/index.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/ind        ex.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                            - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                            - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.j        s
                            - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                            - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                            - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:        15)
                                at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                at Module.require (node:internal/modules/cjs/loader:1005:19)
                                at require (node:internal/modules/cjs/helpers:102:18)
                                at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modu        les/fs-extra/lib/mkdirs/make-dir.js:9:21)
                                at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10        )
                                at Module.load (node:internal/modules/cjs/loader:981:32)
                                at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                at Module.require (node:internal/modules/cjs/loader:1005:19) {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: [
                                '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/make-dir.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/index.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/copy-sync.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/index.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index        .js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/        index.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tool        s.js',
                                '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            Sieht nicht gut aus, oder?
                            • F Frank_y
                              Beispiel:
                                throw err;
                              Require stack:
                                requireStack: [
                              Thomas BraunT
                              Thomas BraunT
                              @frank_y
                              iobroker stop
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                                @frank_y
                                iobroker stop
                                cd /opt/iobroker
                                F
                                F
                                Frank_y
                                jetzt werden wieder Verzeichnisse angemeckert:
                                npm ERR! path /opt/iobroker/node_modules/aws4
                                npm ERR! dest /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                npm ERR! errno -39
                                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws4' -> '/opt/iobroker/node_modules/.aws4-3BmHzpIi'
                                npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T14_18_20_594Z-debug-0.log
                                ich lösche mal weiter: rm -rf /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                • F Frank_y
                                  npm ERR! errno -39
                                  F
                                  F
                                  Frank_y
                                  @frank_y
                                  es sind wieder mehrere Verzeichnisse....bisher 6...sehr mühsam
                                  Woran liegt das denn. Es lief ja alles?
                                  • F Frank_y
                                    @frank_y
                                    Thomas BraunT
                                    Thomas BraunT
                                    Ich weiß es nicht. Wenn man sich im Netz umschaut passiert das überwiegend bei Aktionen im npm tree die mit root-Rechten und/oder global durchgeführt wurden. Kann auch geraume Zeit her sein, da schlummern dann halt immer Zeitbomben.
                                    Als ich auf npm8 gewechselt bin hatte ich solche Probleme jedenfalls nicht.
                                      F
                                      F
                                      Frank_y
                                      wenn ich den iobroker neu/frisch aufsetzte und dann per Backitup wiederherstelle, sollten die Probleme auch weg sein, oder?
                                      • F Frank_y
                                        Thomas BraunT
                                        Thomas BraunT
                                        @frank_y
                                        Ich weiß es nicht genau. Die package-lock wird soweit ich weiß mit gesichert.
                                        grrfieldG F 2 Antworten Letzte Antwort
                                          @frank_y
                                          grrfieldG
                                          grrfieldG
                                          grrfield
                                          Ich habe bei mir mit
                                          cd /opt/iobroker/node_modules
                                          mkdir bak
                                          mv ./.* bak
                                          mv bak/.bin .
                                          mv  @*/.??* bak
                                          alle beanstandeten Verzeichnisse entfernt. Danach lief das Update los, es kamen einige "normale" Updatemeldungen und dann eine Unmenge an Fehlermeldungen; größtenteils npm ERR! Ich habe mal das Logfile angehängt; es lohnt sich aber nicht, das weiter zu verfolgen: putty.log Da muß wohl noch etwas anderes kaputt sein :-( Ich werde das System neu aufsetzen und dann den letzten Backup einspielen.
                                          Trotzdem herzlichen Dank für Deine Hilfe!!!
                                          84.2k
