  4. Kann keine Adapter aktualisieren
    6.8k
75 Beiträge 14 Kommentatoren 15.9k Aufrufe 10 Beobachtet
  • F Frank_y
    @grrfield sagte in Kann keine Adapter aktualisieren:
    Bei mir lassen sich auch keine Adapter mehr aktualisieren - weder über die Weboberfläche noch über die Kommandozeile:
    rock64@rock64:/opt/iobroker$ iobroker update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.1.7    , installed 1.11.1 [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 3.3.1    , installed 3.3.1
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "rest-api"     : 1.0.0    , installed 1.0.0
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "samsung"      : 0.5.8    , installed 0.5.8
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    rock64@rock64:/opt/iobroker$ iobroker upgrade
    This upgrade of "synology" will introduce the following changes:
    -> 2.1.9:
    Try to prevent account locks when using 2FA on restarts of the NAS
    -> 2.1.8:
    slow down reconnects to the DSM
    Would you like to upgrade synology from @2.1.7 to @2.1.9 now? [(y)es, (n)o]: y
    Update synology from @2.1.7 to @2.1.9
    NPM version: 8.11.0
    Installing iobroker.synology@2.1.9... (System call)
    host.rock64 Cannot install iobroker.synology@2.1.9: 128
    Bisher hatte ich nie Probleme beim Aktualisieren. Ich habe schon den iobroker-Fixer laufen lassen. Was kann ich noch tun?
    js-controller 4.0.23
    nodejs v16.16.0
    npm 8.11.0
    Bei mir das selbe Problem mit den stabel-Updates folgender Adapter:
    -discovery devices 3.0.3 ->3.0.5
    -History 1.11.1 ->2.1.7
    -iCal 1.12.1 ->1.13.1
    -influxDB 2.6.3 ->3.1.7
    -IoT assistants 1.11.4 ->1.11.8
    Der Worx-Adapter 1.5.5 -> 1.6.6 ließ sich ohne Fehler updaten
    nodejs sowohl bei v16.15.1 und v16.16.0
    node v16.15.1 bzw. v16.16.0
    npm 8.11.0
    habe auch iob fix noch einmal laufen lassen.
    Beispielhaft hier für History-Update:
    XXXXX@iobrokerVM:~$ iobroker upgrade history  --debug
    This upgrade of "history" will at least introduce the following changes:
    -> 2.1.7:
    Allow to remove a configuration value for "round" in config again
    -> 2.1.6:
    When not count is provided for aggregate "none" or "onchange" then the limit (de                                                fault 2000) is used as count to define the number of data to return.
    -> 2.1.5:
    Ignore errors from forked process after response was sent for GetHistory
    -> 2.1.4:
    Make sure debug log is active according to the settings
    -> 2.1.3:
    Huge performance optimizations for GetHistory calls
    -> 2.1.2:
    Fix crash case reported by Sentry
    -> 2.1.1:
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C                                                HANGES!
    Would you like to upgrade history from @1.11.1 to @2.1.7 now? [(y)es, (n)o]: y
    Update history from @1.11.1 to @2.1.7
    NPM version: 8.11.0
    Installing iobroker.history@2.1.7... (System call)
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/abab
    npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
    npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_56_29_851Z-debug-0.log
    host.iobrokerVM Cannot install iobroker.history@2.1.7: 217
    @frank_y sagte in Kann keine Adapter aktualisieren:
    Dann das gleiche auch für dich:
    Upgrade mit --debug Option laufen lassen.
    F 1 Antwort Letzte Antwort
      Frank_y
      hier für iot-Update:
      XXXXX@iobrokerVM:~$ iobroker upgrade iot --debug
      This upgrade of "iot" will introduce the following changes:
      -> 1.11.8:
      Update dependencies to allow better automatic rebuild
      -> 1.11.7:
      Tried to correct URL key creation for Google home
      -> 1.11.5:
      Alisa: update for binary-sensor "motion" and "contact"
      Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
      Update iot from @1.11.4 to @1.11.8
      NPM version: 8.11.0
      Installing iobroker.iot@1.11.8... (System call)
      npm ERR! path /opt/iobroker/node_modules/abbrev
      npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T09_00_22_561Z-debug-0.log
      host.iobrokerVM Cannot install iobroker.iot@1.11.8: 217
      • F Frank_y
        -> 2.1.9:
        -> 2.1.8:
        NPM version: 8.11.0
        nodejs v16.16.0
        npm 8.11.0
        npm 8.11.0
        -> 2.1.7:
        -> 2.1.6:
        -> 2.1.5:
        -> 2.1.4:
        -> 2.1.3:
        -> 2.1.2:
        -> 2.1.1:
        NPM version: 8.11.0
        npm ERR! errno -39
        Alle Verzeichnisse die so ausgespuckt werden löschen.
        Beispiel:
        rm -rf /opt/iobroker/node_modules/.abab-bvmibCm3
        Solange bis alle angemeckerten Verzeichnisse weg sind.
          ioBroker.radar-trap
          Deinstallier den mal temporär für die Upgrades.
          Hattest du die git-basierten Adapter vor dem nodejs16 Update nicht rausgeworfen?
          grrfieldG Offline
          grrfieldG Offline
          grrfield
          @thomas-braun sagte in Kann keine Adapter aktualisieren:
          ioBroker.radar-trap
          Vielen Dank für die schnelle Antwort!
          Ich habe den Adapter über die Weboberfläche deinstalliert, er ist da auch nicht mehr zu sehen. Nach
          iob update
          iobroker upgrade synology --debug
          bekomme ich wieder dieselbe Debug-Ausgabe wie vorher, d. h. es wird immer noch versucht, auf ssh://git@github.com/Steiger04/ioBroker.radar-trap.git zuzugreifen.
          Nein, ich bin eigentlich genau nach der Anleitung [How-to] Node.js ioBroker richtig updaten-2021/22 Edition](https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition?page=1) vorgegangen, und da habe ich nichts gelesen, daß die Git-Adapter vorher entfernt werden müssen. Hätte ich das tun müssen?
          • grrfieldG grrfield
            ioBroker.radar-trap
            iob update
            @grrfield
            Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
            Das ist die Passage, die für dich relevant gewesen wäre.
            grrfieldG 1 Antwort Letzte Antwort
              @grrfield
              grrfieldG Offline
              grrfieldG Offline
              grrfield
              Oh, das hatte ich nicht so aufgefaßt, da einige Adapter (radar-trap) noch nicht auf npm sind. Das nächste Mal bin ich dann klüger.
              Wie kann ich denn den Fehler, daß immer bei der Installation neuer Adapter immer noch nach den git-Adaptern gesucht wird, loswerden?
                @grrfield
                Schau wo der im tree liegt:
                cd /opt/iobroker
                npm ls iobroker.radar-trap
                • nbrgitN Offline
                  nbrgitN Offline
                  nbrgit
                  ich versuche gerade diverse Adapter zu aktualisieren, leider ohne Erfolg.
                  Kurzer Ausschnitt was bei der "Update-Kachel" erscheint :
                  Dependencies:
                  js-controller (>=3.3.22): 4.0.23
                  node (>=12.0.0): 16.16.0
                  Der Button "Aktualisieren" ist ausgeblendet.
                  Ich weiß nicht so richtig weiter, denn wenn ich das richtig lese, sind alle Voraussetzungen erfüllt aber ein Update ist nicht möglich.
                  Kann mir jemand helfen?
                  LG
                  haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                  • nbrgitN nbrgit
                    Dependencies:
                    LG
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @nbrgit
                    6 Zeilen unter Dir ist das gleiche Problem.
                    Warum nutzt du nicht den Thread?
                    @Negalein
                    @Homoran
                    Bitte zusammenführen
                    https://forum.iobroker.net/topic/55518/kann-keine-adapter-aktualisieren
                    • nbrgitN nbrgit
                      Dependencies:
                      LG
                      @nbrgit
                      Was kommt vom System auf diese Befehle in der Kommandozeile zurück?
                      iobroker update -i
                      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                      cd /opt/iobroker
                      npm ls | grep -E 'github|ERR'
                        @grrfield
                        cd /opt/iobroker
                        grrfieldG Offline
                        grrfieldG Offline
                        grrfield
                        Vielen Dank! Ich hatte in der Zwischenzeit weiter nach einem Eintrag mit "radar-trap" gesucht und habe dann in der Datei /opt/iobroker/package.json eine Zeile
                         "iobroker.radar-trap": "github:Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5",
                        gefunden und diese gelöscht (vorher eine Kopie der Datei erstellt).
                        Jetzt bekomme ich diese Fehlermeldung nicht mehr, sondern bin einen Schritt weiter und bekomme die Meldungen, die auch frank_y hat. Ich bin nun dabei, die Verzeichnisse, die als Meldungen ausgegeben werden, zu löschen. Könnte man auch einfach alle versteckten Verzeichnisse unter /opt/iobroker/node_modules löschen, also
                        rm -rf /opt/iobroker/node_modules/.*
                        Für mich das so aus, als ob das nur Sicherheitskopien sind, die vor einer Installation neu erstellt werden.
                          @grrfield
                          Vorsicht! Da liegt auch ein Verzeichnis .bin drin, das würde ich nicht unbedingt löschen.
                            @grrfield
                            grrfieldG Offline
                            grrfieldG Offline
                            grrfield
                            @thomas-braun Und der Rest?
                              @grrfield
                              Probier es aus...
                              Ich kann/konnte es bei mir nicht nachstellen, ich hab keine Meldungen zu solchen Verzeichnissen bekommen, in meinem Dateipfad sind auch keine zu finden.
                                Beispiel:
                                Frank_y
                                Beispiel:
                                Ich musste ca. 20 Verzeichnisse händisch löschen!
                                Jetzt wird folgender Fehler ausgeworfen:
                                XXXXXXX@iobrokerVM:/opt$ iobroker upgrade history  --debug
                                node:internal/modules/cjs/loader:936
                                  throw err;
                                Error: Cannot find module 'at-least-node'
                                Require stack:
                                - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/m        ake-dir.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/i        ndex.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/copy-sync.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/index.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/ind        ex.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                                - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                                - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.j        s
                                - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:        15)
                                    at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                    at Module.require (node:internal/modules/cjs/loader:1005:19)
                                    at require (node:internal/modules/cjs/helpers:102:18)
                                    at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modu        les/fs-extra/lib/mkdirs/make-dir.js:9:21)
                                    at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10        )
                                    at Module.load (node:internal/modules/cjs/loader:981:32)
                                    at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                    at Module.require (node:internal/modules/cjs/loader:1005:19) {
                                  code: 'MODULE_NOT_FOUND',
                                  requireStack: [
                                    '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/make-dir.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/index.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/copy-sync.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/index.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index        .js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/        index.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                    '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                    '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tool        s.js',
                                    '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                Sieht nicht gut aus, oder?
                                • F Frank_y
                                  Beispiel:
                                    throw err;
                                  Require stack:
                                    requireStack: [
                                  @frank_y
                                  iobroker stop
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                    @frank_y
                                    iobroker stop
                                    cd /opt/iobroker
                                    Frank_y
                                    jetzt werden wieder Verzeichnisse angemeckert:
                                    npm ERR! path /opt/iobroker/node_modules/aws4
                                    npm ERR! dest /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aws4' -> '/opt/iobroker/node_modules/.aws4-3BmHzpIi'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T14_18_20_594Z-debug-0.log
                                    ich lösche mal weiter: rm -rf /opt/iobroker/node_modules/.aws4-3BmHzpIi
                                    • F Frank_y
                                      npm ERR! errno -39
                                      Frank_y
                                      @frank_y
                                      es sind wieder mehrere Verzeichnisse....bisher 6...sehr mühsam
                                      Woran liegt das denn. Es lief ja alles?
                                      • F Frank_y
                                        @frank_y
                                        Ich weiß es nicht. Wenn man sich im Netz umschaut passiert das überwiegend bei Aktionen im npm tree die mit root-Rechten und/oder global durchgeführt wurden. Kann auch geraume Zeit her sein, da schlummern dann halt immer Zeitbomben.
                                        Als ich auf npm8 gewechselt bin hatte ich solche Probleme jedenfalls nicht.
                                          Frank_y
                                          wenn ich den iobroker neu/frisch aufsetzte und dann per Backitup wiederherstelle, sollten die Probleme auch weg sein, oder?
