  4. Kann keine Adapter aktualisieren
    6.8k
75 Beiträge 14 Kommentatoren 15.9k Aufrufe 10 Beobachtet
  • grrfieldG grrfield
    Bei mir lassen sich auch keine Adapter mehr aktualisieren - weder über die Weboberfläche noch über die Kommandozeile:
    rock64@rock64:/opt/iobroker$ iobroker update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.1.7    , installed 1.11.1 [Updatable]
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 3.3.1    , installed 3.3.1
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "rest-api"     : 1.0.0    , installed 1.0.0
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "samsung"      : 0.5.8    , installed 0.5.8
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "unifi"        : 0.5.10   , installed 0.5.10
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    rock64@rock64:/opt/iobroker$ iobroker upgrade
    This upgrade of "synology" will introduce the following changes:
    -> 2.1.9:
    Try to prevent account locks when using 2FA on restarts of the NAS
    -> 2.1.8:
    slow down reconnects to the DSM
    Would you like to upgrade synology from @2.1.7 to @2.1.9 now? [(y)es, (n)o]: y
    Update synology from @2.1.7 to @2.1.9
    NPM version: 8.11.0
    Installing iobroker.synology@2.1.9... (System call)
    host.rock64 Cannot install iobroker.synology@2.1.9: 128
    Bisher hatte ich nie Probleme beim Aktualisieren. Ich habe schon den iobroker-Fixer laufen lassen. Was kann ich noch tun?
    js-controller 4.0.23
    nodejs v16.16.0
    npm 8.11.0
    @grrfield sagte in Kann keine Adapter aktualisieren:
    Bitte mit --debug Option upgraden.
    Z. B. so:
    iobroker upgrade synology --debug
    grrfieldG 1 Antwort Letzte Antwort
      Z. B. so:
      grrfieldG Offline
      grrfieldG Offline
      grrfield
      @thomas-braun sagte in Kann keine Adapter aktualisieren:
      Hier der Output:
      rock64@rock64:/opt/iobroker$ iobroker upgrade synology --debug
      -> 2.1.9:
      -> 2.1.8:
      NPM version: 8.11.0
      npm ERR! code 128
      npm ERR! An unknown git error occurred
      npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/Steiger04/ioBroker.radar-trap.git
      npm ERR! git@github.com: Permission denied (publickey).
      npm ERR! fatal: Could not read from remote repository.
      npm ERR!
      npm ERR! Please make sure you have the correct access rights
      npm ERR! and the repository exists.
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_44_58_233Z-debug-0.log
        Hier der Output:
        -> 2.1.9:
        -> 2.1.8:
        NPM version: 8.11.0
        npm ERR! code 128
        npm ERR!
        ioBroker.radar-trap
        Deinstallier den mal temporär für die Upgrades.
        Hattest du die git-basierten Adapter vor dem nodejs16 Update nicht rausgeworfen?
          -> 2.1.9:
          -> 2.1.8:
          NPM version: 8.11.0
          nodejs v16.16.0
          npm 8.11.0
          Frank_y
          schrieb am zuletzt editiert von Frank_y
          -> 2.1.9:
          -> 2.1.8:
          NPM version: 8.11.0
          nodejs v16.16.0
          npm 8.11.0
          Bei mir das selbe Problem mit den stabel-Updates folgender Adapter:
          -discovery devices 3.0.3 ->3.0.5
          -History 1.11.1 ->2.1.7
          -iCal 1.12.1 ->1.13.1
          -influxDB 2.6.3 ->3.1.7
          -IoT assistants 1.11.4 ->1.11.8
          Der Worx-Adapter 1.5.5 -> 1.6.6 ließ sich ohne Fehler updaten
          nodejs sowohl bei v16.15.1 und v16.16.0
          node v16.15.1 bzw. v16.16.0
          npm 8.11.0
          habe auch iob fix noch einmal laufen lassen.
          Beispielhaft hier für History-Update:
          XXXXX@iobrokerVM:~$ iobroker upgrade history  --debug
          This upgrade of "history" will at least introduce the following changes:
          -> 2.1.7:
          Allow to remove a configuration value for "round" in config again
          -> 2.1.6:
          When not count is provided for aggregate "none" or "onchange" then the limit (de                                                fault 2000) is used as count to define the number of data to return.
          -> 2.1.5:
          Ignore errors from forked process after response was sent for GetHistory
          -> 2.1.4:
          Make sure debug log is active according to the settings
          -> 2.1.3:
          Huge performance optimizations for GetHistory calls
          -> 2.1.2:
          Fix crash case reported by Sentry
          -> 2.1.1:
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING C                                                HANGES!
          Would you like to upgrade history from @1.11.1 to @2.1.7 now? [(y)es, (n)o]: y
          Update history from @1.11.1 to @2.1.7
          NPM version: 8.11.0
          Installing iobroker.history@2.1.7... (System call)
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /opt/iobroker/node_modules/abab
          npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
          npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T08_56_29_851Z-debug-0.log
          host.iobrokerVM Cannot install iobroker.history@2.1.7: 217
          • F Frank_y
            -> 2.1.9:
            -> 2.1.8:
            NPM version: 8.11.0
            nodejs v16.16.0
            npm 8.11.0
            npm 8.11.0
            -> 2.1.7:
            -> 2.1.6:
            -> 2.1.5:
            -> 2.1.4:
            -> 2.1.3:
            -> 2.1.2:
            -> 2.1.1:
            NPM version: 8.11.0
            npm ERR! errno -39
            @frank_y sagte in Kann keine Adapter aktualisieren:
            Dann das gleiche auch für dich:
            Upgrade mit --debug Option laufen lassen.
            F 1 Antwort Letzte Antwort
              Frank_y
              hier für iot-Update:
              XXXXX@iobrokerVM:~$ iobroker upgrade iot --debug
              This upgrade of "iot" will introduce the following changes:
              -> 1.11.8:
              Update dependencies to allow better automatic rebuild
              -> 1.11.7:
              Tried to correct URL key creation for Google home
              -> 1.11.5:
              Alisa: update for binary-sensor "motion" and "contact"
              Would you like to upgrade iot from @1.11.4 to @1.11.8 now? [(y)es, (n)o]: y
              Update iot from @1.11.4 to @1.11.8
              NPM version: 8.11.0
              Installing iobroker.iot@1.11.8... (System call)
              npm ERR! path /opt/iobroker/node_modules/abbrev
              npm ERR! dest /opt/iobroker/node_modules/.abbrev-5eNud0FY
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abbrev' -> '/opt/iobroker/node_modules/.abbrev-5eNud0FY'
              npm ERR!     /home/iobroker/.npm/_logs/2022-07-22T09_00_22_561Z-debug-0.log
              host.iobrokerVM Cannot install iobroker.iot@1.11.8: 217
              • F Frank_y
                -> 2.1.9:
                -> 2.1.8:
                NPM version: 8.11.0
                nodejs v16.16.0
                npm 8.11.0
                npm 8.11.0
                -> 2.1.7:
                -> 2.1.6:
                -> 2.1.5:
                -> 2.1.4:
                -> 2.1.3:
                -> 2.1.2:
                -> 2.1.1:
                NPM version: 8.11.0
                npm ERR! errno -39
                Alle Verzeichnisse die so ausgespuckt werden löschen.
                Beispiel:
                rm -rf /opt/iobroker/node_modules/.abab-bvmibCm3
                Solange bis alle angemeckerten Verzeichnisse weg sind.
                  ioBroker.radar-trap
                  grrfieldG Offline
                  grrfieldG Offline
                  grrfield
                  ioBroker.radar-trap
                  Vielen Dank für die schnelle Antwort!
                  Ich habe den Adapter über die Weboberfläche deinstalliert, er ist da auch nicht mehr zu sehen. Nach
                  iob update
                  bekomme ich wieder dieselbe Debug-Ausgabe wie vorher, d. h. es wird immer noch versucht, auf ssh://git@github.com/Steiger04/ioBroker.radar-trap.git zuzugreifen.
                  Nein, ich bin eigentlich genau nach der Anleitung [How-to] Node.js ioBroker richtig updaten-2021/22 Edition](https://forum.iobroker.net/topic/44566/how-to-node-js-iobroker-richtig-updaten-2021-22-edition?page=1) vorgegangen, und da habe ich nichts gelesen, daß die Git-Adapter vorher entfernt werden müssen. Hätte ich das tun müssen?
                    ioBroker.radar-trap
                    iob update
                    @grrfield
                    Bei Updates wo es größere Versionssprünge bei npm gibt (zb Node.js 14->16 updated npm von 6.x auf 8.x) kann es sehr hilfreich sein wenn man schaut ob Adapter die von GitHub installiert wurden inzwischen in der gleichen version auf auf npm liegen und dann ggf von dort nochmals installieren oder updaten. Im Admin werden Adapter die per GitHub installiert wurden gesondert mit einem GitHub Symbol angezeigt. Das hilft auch im Vorfeld Probleme zu vermeiden.
                    Das ist die Passage, die für dich relevant gewesen wäre.
                      @grrfield
                      grrfieldG Offline
                      grrfieldG Offline
                      grrfield
                      Oh, das hatte ich nicht so aufgefaßt, da einige Adapter (radar-trap) noch nicht auf npm sind. Das nächste Mal bin ich dann klüger.
                      Wie kann ich denn den Fehler, daß immer bei der Installation neuer Adapter immer noch nach den git-Adaptern gesucht wird, loswerden?
                        @grrfield
                        Schau wo der im tree liegt:
                        cd /opt/iobroker
                        npm ls iobroker.radar-trap
                        • nbrgitN Offline
                          nbrgitN Offline
                          nbrgit
                          ich versuche gerade diverse Adapter zu aktualisieren, leider ohne Erfolg.
                          Kurzer Ausschnitt was bei der "Update-Kachel" erscheint :
                          Dependencies:
                          js-controller (>=3.3.22): 4.0.23
                          node (>=12.0.0): 16.16.0
                          Der Button "Aktualisieren" ist ausgeblendet.
                          Ich weiß nicht so richtig weiter, denn wenn ich das richtig lese, sind alle Voraussetzungen erfüllt aber ein Update ist nicht möglich.
                          Kann mir jemand helfen?
                          LG
                          haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                          • nbrgitN nbrgit
                            Dependencies:
                            LG
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @nbrgit
                            6 Zeilen unter Dir ist das gleiche Problem.
                            Warum nutzt du nicht den Thread?
                            @Negalein
                            @Homoran
                            Bitte zusammenführen
                            https://forum.iobroker.net/topic/55518/kann-keine-adapter-aktualisieren
                            • nbrgitN nbrgit
                              Dependencies:
                              LG
                              @nbrgit
                              Was kommt vom System auf diese Befehle in der Kommandozeile zurück?
                              iobroker update -i
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              cd /opt/iobroker
                              npm ls | grep -E 'github|ERR'
                                @grrfield
                                cd /opt/iobroker
                                grrfieldG Offline
                                grrfieldG Offline
                                grrfield
                                Vielen Dank! Ich hatte in der Zwischenzeit weiter nach einem Eintrag mit "radar-trap" gesucht und habe dann in der Datei /opt/iobroker/package.json eine Zeile
                                 "iobroker.radar-trap": "github:Steiger04/ioBroker.radar-trap#59772746bcfedabc4482b47115ca8584a1381bd5",
                                gefunden und diese gelöscht (vorher eine Kopie der Datei erstellt).
                                Jetzt bekomme ich diese Fehlermeldung nicht mehr, sondern bin einen Schritt weiter und bekomme die Meldungen, die auch frank_y hat. Ich bin nun dabei, die Verzeichnisse, die als Meldungen ausgegeben werden, zu löschen. Könnte man auch einfach alle versteckten Verzeichnisse unter /opt/iobroker/node_modules löschen, also
                                rm -rf /opt/iobroker/node_modules/.*
                                Für mich das so aus, als ob das nur Sicherheitskopien sind, die vor einer Installation neu erstellt werden.
                                  @grrfield
                                  Vorsicht! Da liegt auch ein Verzeichnis .bin drin, das würde ich nicht unbedingt löschen.
                                    @grrfield
                                    grrfieldG Offline
                                    grrfieldG Offline
                                    grrfield
                                    @thomas-braun Und der Rest?
                                      @grrfield
                                      Probier es aus...
                                      Ich kann/konnte es bei mir nicht nachstellen, ich hab keine Meldungen zu solchen Verzeichnissen bekommen, in meinem Dateipfad sind auch keine zu finden.
                                        Beispiel:
                                        Frank_y
                                        Beispiel:
                                        Ich musste ca. 20 Verzeichnisse händisch löschen!
                                        Jetzt wird folgender Fehler ausgeworfen:
                                        XXXXXXX@iobrokerVM:/opt$ iobroker upgrade history  --debug
                                        node:internal/modules/cjs/loader:936
                                          throw err;
                                        Error: Cannot find module 'at-least-node'
                                        Require stack:
                                        - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/m        ake-dir.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdirs/i        ndex.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/copy-sync.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-syn        c/index.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/ind        ex.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                                        - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                                        - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.j        s
                                        - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                        - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:        15)
                                            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                            at Module.require (node:internal/modules/cjs/loader:1005:19)
                                            at require (node:internal/modules/cjs/helpers:102:18)
                                            at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modu        les/fs-extra/lib/mkdirs/make-dir.js:9:21)
                                            at Module._compile (node:internal/modules/cjs/loader:1105:14)
                                            at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10        )
                                            at Module.load (node:internal/modules/cjs/loader:981:32)
                                            at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                                            at Module.require (node:internal/modules/cjs/loader:1005:19) {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: [
                                            '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/make-dir.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/mkdir        s/index.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/copy-sync.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/copy-        sync/index.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/fs-extra/lib/index        .js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/        index.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                            '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                            '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tool        s.js',
                                            '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                            '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                            '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        Sieht nicht gut aus, oder?
                                        • F Frank_y
                                          Beispiel:
                                            throw err;
                                          Require stack:
                                            requireStack: [
                                          @frank_y
                                          iobroker stop
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.js-controller
