  4. Backup Wiederherstellung nicht möglich
    5.4k
172 Beiträge 6 Kommentatoren 25.9k Aufrufe 4 Beobachtet
  • I IceD112
    @glasfaser said in Backup Wiederherstellung nicht möglich:
    cifs-utils installiert?
    Was ist das, Sorry für die vielleicht dumme Frage
    GlasfaserG Offline
    GlasfaserG Offline
    @iced112 sagte in Backup Wiederherstellung nicht möglich:
    https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
    I 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      I Offline
      I Offline
      IceD112
      @glasfaser
      2022-07-21 16:08:50.155 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-21 16:08:50.161 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-21 16:08:50.162 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
      2022-07-21 16:08:50.163 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
      2022-07-21 16:08:50.472 - info: host.ioBroker connected to Objects and States
      2022-07-21 16:08:50.516 - info: host.ioBroker Node.js version has changed from unknown to 16.16.0
      2022-07-21 16:08:50.561 - info: host.ioBroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-07-21 16:08:50.579 - info: host.ioBroker added notifications configuration of host
      2022-07-21 16:08:50.867 - info: host.ioBroker 3 instances found
      2022-07-21 16:08:50.877 - info: host.ioBroker starting 3 instances
      2022-07-21 16:08:50.936 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7050
      2022-07-21 16:08:52.820 - info: admin.0 (7050) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:08:52.867 - info: admin.0 (7050) requesting all states
      2022-07-21 16:08:52.868 - info: admin.0 (7050) requesting all objects
      2022-07-21 16:08:52.961 - info: admin.0 (7050) received all objects
      2022-07-21 16:08:53.061 - info: admin.0 (7050) http server listening on port 8081
      2022-07-21 16:08:53.062 - info: admin.0 (7050) Use link "http://localhost:8081" to configure.
      2022-07-21 16:08:53.128 - warn: admin.0 (7050) Repository cannot be read: Active repo - stable
      2022-07-21 16:08:53.129 - warn: admin.0 (7050) Active repository "stable cannot be read
      2022-07-21 16:08:54.934 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7065
      2022-07-21 16:08:56.581 - info: discovery.0 (7065) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:08:58.929 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7080
      2022-07-21 16:09:00.650 - info: backitup.0 (7080) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:09:00.714 - info: backitup.0 (7080) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:09:49.819 - info: host.ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-07-21 16:18:29.975 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:18:29.995 - info: backitup.0 (7080) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:18:30.005 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:18:29.998 - info: backitup.0 (7080) cleaned everything up...
      2022-07-21 16:18:30.001 - info: backitup.0 (7080) terminating
      2022-07-21 16:18:30.005 - info: backitup.0 (7080) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:18:30.554 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:18:33.087 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7187
      2022-07-21 16:18:34.750 - info: backitup.0 (7187) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:18:34.820 - info: backitup.0 (7187) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:21:18.496 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:21:18.508 - info: backitup.0 (7187) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:21:18.512 - info: backitup.0 (7187) cleaned everything up...
      2022-07-21 16:21:18.515 - info: backitup.0 (7187) terminating
      2022-07-21 16:21:18.518 - info: backitup.0 (7187) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:21:18.553 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:21:19.090 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:21:21.598 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7231
      2022-07-21 16:21:23.337 - info: backitup.0 (7231) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:21:23.437 - info: backitup.0 (7231) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:21:24.008 - error: backitup.0 (7231) Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backups
      mount.nfs: Failed to resolve server : Name or service not known
      2022-07-21 16:39:36.896 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:39:36.915 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:39:36.916 - info: backitup.0 (7231) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:39:36.921 - info: backitup.0 (7231) cleaned everything up...
      2022-07-21 16:39:36.924 - info: backitup.0 (7231) terminating
      2022-07-21 16:39:36.928 - info: backitup.0 (7231) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:39:37.463 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:39:39.971 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7354
      2022-07-21 16:39:41.649 - info: backitup.0 (7354) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:39:41.720 - info: backitup.0 (7354) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:39:42.375 - error: backitup.0 (7354) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER /opt/iobroker/backups
      mount error(2): No such file or directory
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      2022-07-21 16:39:48.275 - error: backitup.0 (7354) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER /opt/iobroker/backups
      2022-07-21 16:40:48.795 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:40:48.804 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:40:48.805 - info: backitup.0 (7354) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:40:48.809 - info: backitup.0 (7354) cleaned everything up...
      2022-07-21 16:40:48.811 - info: backitup.0 (7354) terminating
      2022-07-21 16:40:48.815 - info: backitup.0 (7354) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:40:49.392 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:40:51.853 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7416
      2022-07-21 16:40:53.563 - info: backitup.0 (7416) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:40:53.629 - info: backitup.0 (7416) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:40:54.210 - error: backitup.0 (7416) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
      2022-07-21 16:40:59.247 - error: backitup.0 (7416) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
      2022-07-21 16:41:36.174 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:41:36.181 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:41:36.181 - info: backitup.0 (7416) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:41:36.185 - info: backitup.0 (7416) cleaned everything up...
      2022-07-21 16:41:36.187 - info: backitup.0 (7416) terminating
      2022-07-21 16:41:36.189 - info: backitup.0 (7416) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:41:36.767 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:41:39.227 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7456
      2022-07-21 16:41:40.919 - info: backitup.0 (7456) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:41:40.985 - info: backitup.0 (7456) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:41:41.624 - error: backitup.0 (7456) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
      2022-07-21 16:42:34.476 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:42:34.482 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:42:34.482 - info: backitup.0 (7456) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:42:34.486 - info: backitup.0 (7456) cleaned everything up...
      2022-07-21 16:42:34.487 - info: backitup.0 (7456) terminating
      2022-07-21 16:42:34.490 - info: backitup.0 (7456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:42:35.070 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:42:37.537 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7484
      2022-07-21 16:42:39.213 - info: backitup.0 (7484) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:42:39.279 - info: backitup.0 (7484) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:42:43.889 - error: backitup.0 (7484) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
      mount error(16): Device or resource busy
      2022-07-21 16:44:43.858 - error: backitup.0 (7484) umount: /opt/iobroker/backups: not mounted.
      2022-07-21 16:54:32.398 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 16:54:32.410 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 16:54:32.410 - info: backitup.0 (7484) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 16:54:32.414 - info: backitup.0 (7484) cleaned everything up...
      2022-07-21 16:54:32.416 - info: backitup.0 (7484) terminating
      2022-07-21 16:54:32.421 - info: backitup.0 (7484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 16:54:32.997 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 16:54:35.467 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7608
      2022-07-21 16:54:37.146 - info: backitup.0 (7608) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 16:54:37.237 - info: backitup.0 (7608) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 16:54:37.887 - error: backitup.0 (7608) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
      2022-07-21 16:56:37.953 - error: backitup.0 (7608) umount: /opt/iobroker/backups: not mounted.
      2022-07-21 17:06:48.664 - info: backitup.0 (7608) cleaned everything up...
      2022-07-21 17:06:48.662 - info: host.ioBroker received SIGTERM
      2022-07-21 17:06:48.666 - info: admin.0 (7050) terminating http server on port 8081
      2022-07-21 17:06:48.667 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-07-21 17:06:48.668 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-07-21 17:06:48.669 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 17:06:48.683 - info: admin.0 (7050) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:06:48.685 - info: discovery.0 (7065) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:06:48.687 - info: backitup.0 (7608) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:06:48.691 - info: discovery.0 (7065) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:06:48.691 - info: backitup.0 (7608) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:06:48.692 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
      2022-07-21 17:06:48.694 - info: admin.0 (7050) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:06:48.696 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
      2022-07-21 17:06:48.696 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 17:06:49.267 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:06:49.271 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:06:49.272 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:06:49.273 - info: host.ioBroker All instances are stopped.
      2022-07-21 17:06:49.326 - info: host.ioBroker terminated
      2022-07-21 17:07:18.998 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-21 17:07:19.004 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-21 17:07:19.005 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
      2022-07-21 17:07:19.006 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
      2022-07-21 17:07:19.493 - info: host.ioBroker connected to Objects and States
      2022-07-21 17:07:19.516 - info: host.ioBroker added notifications configuration of host
      2022-07-21 17:07:19.788 - info: host.ioBroker 3 instances found
      2022-07-21 17:07:19.796 - info: host.ioBroker starting 3 instances
      2022-07-21 17:07:19.838 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7796
      2022-07-21 17:07:21.688 - info: admin.0 (7796) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:07:21.739 - info: admin.0 (7796) requesting all states
      2022-07-21 17:07:21.739 - info: admin.0 (7796) requesting all objects
      2022-07-21 17:07:22.198 - info: admin.0 (7796) received all objects
      2022-07-21 17:07:22.402 - info: admin.0 (7796) http server listening on port 8081
      2022-07-21 17:07:22.403 - info: admin.0 (7796) Use link "http://localhost:8081" to configure.
      2022-07-21 17:07:24.066 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7812
      2022-07-21 17:07:26.124 - info: discovery.0 (7812) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:07:27.858 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7839
      2022-07-21 17:07:29.593 - info: backitup.0 (7839) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:07:29.710 - warn: backitup.0 (7839) Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
      2022-07-21 17:07:29.734 - info: backitup.0 (7839) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 17:07:30.380 - error: backitup.0 (7839) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
      2022-07-21 17:08:04.860 - info: host.ioBroker received SIGTERM
      2022-07-21 17:08:04.866 - info: backitup.0 (7839) cleaned everything up...
      2022-07-21 17:08:04.864 - info: admin.0 (7796) terminating http server on port 8081
      2022-07-21 17:08:04.866 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-07-21 17:08:04.867 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-07-21 17:08:04.868 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 17:08:04.885 - info: admin.0 (7796) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:08:04.887 - info: discovery.0 (7812) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:08:04.887 - info: backitup.0 (7839) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:08:04.894 - info: backitup.0 (7839) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:08:04.894 - info: discovery.0 (7812) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:08:04.897 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
      2022-07-21 17:08:04.898 - info: admin.0 (7796) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:08:04.903 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
      2022-07-21 17:08:04.903 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 17:08:05.476 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:08:05.477 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:08:05.495 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:08:05.496 - info: host.ioBroker All instances are stopped.
      2022-07-21 17:08:05.724 - info: host.ioBroker terminated
      2022-07-21 17:08:35.623 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-21 17:08:35.629 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-21 17:08:35.630 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
      2022-07-21 17:08:35.631 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
      2022-07-21 17:08:36.089 - info: host.ioBroker connected to Objects and States
      2022-07-21 17:08:36.111 - info: host.ioBroker added notifications configuration of host
      2022-07-21 17:08:36.425 - info: host.ioBroker 3 instances found
      2022-07-21 17:08:36.433 - info: host.ioBroker starting 3 instances
      2022-07-21 17:08:36.484 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7947
      2022-07-21 17:08:38.350 - info: admin.0 (7947) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:08:38.401 - info: admin.0 (7947) requesting all states
      2022-07-21 17:08:38.401 - info: admin.0 (7947) requesting all objects
      2022-07-21 17:08:38.905 - info: admin.0 (7947) received all objects
      2022-07-21 17:08:39.110 - info: admin.0 (7947) http server listening on port 8081
      2022-07-21 17:08:39.111 - info: admin.0 (7947) Use link "http://localhost:8081" to configure.
      2022-07-21 17:08:40.507 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7962
      2022-07-21 17:08:42.112 - info: discovery.0 (7962) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:08:44.497 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7977
      2022-07-21 17:08:46.217 - info: backitup.0 (7977) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:08:46.322 - warn: backitup.0 (7977) Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
      2022-07-21 17:08:46.348 - info: backitup.0 (7977) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 17:08:46.952 - error: backitup.0 (7977) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
      2022-07-21 17:10:47.004 - error: backitup.0 (7977) umount: /opt/iobroker/backups: not mounted.
      2022-07-21 17:11:48.247 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 17:11:48.265 - info: backitup.0 (7977) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:11:48.267 - info: backitup.0 (7977) cleaned everything up...
      2022-07-21 17:11:48.267 - info: backitup.0 (7977) terminating
      2022-07-21 17:11:48.269 - info: backitup.0 (7977) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-21 17:11:48.271 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 17:11:48.813 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-21 17:11:51.322 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8023
      2022-07-21 17:11:53.101 - info: backitup.0 (8023) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:11:53.175 - info: backitup.0 (8023) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-21 17:12:03.423 - error: backitup.0 (8023) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
      2022-07-21 17:12:17.772 - info: host.ioBroker received SIGTERM
      2022-07-21 17:12:17.774 - info: admin.0 (7947) terminating http server on port 8081
      2022-07-21 17:12:17.777 - info: backitup.0 (8023) cleaned everything up...
      2022-07-21 17:12:17.774 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-07-21 17:12:17.775 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-07-21 17:12:17.776 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-21 17:12:17.791 - info: admin.0 (7947) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:12:17.793 - info: discovery.0 (7962) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:12:17.793 - info: backitup.0 (8023) Got terminate signal TERMINATE_YOURSELF
      2022-07-21 17:12:17.797 - info: discovery.0 (7962) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:12:17.799 - info: admin.0 (7947) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:12:17.800 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
      2022-07-21 17:12:17.802 - info: backitup.0 (8023) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2022-07-21 17:12:17.804 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
      2022-07-21 17:12:17.804 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
      2022-07-21 17:12:18.350 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:12:18.367 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:12:18.415 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2022-07-21 17:12:18.417 - info: host.ioBroker All instances are stopped.
      2022-07-21 17:12:18.634 - info: host.ioBroker terminated
      2022-07-21 17:12:48.139 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-21 17:12:48.145 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-21 17:12:48.146 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
      2022-07-21 17:12:48.147 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
      2022-07-21 17:12:48.645 - info: host.ioBroker connected to Objects and States
      2022-07-21 17:12:48.668 - info: host.ioBroker added notifications configuration of host
      2022-07-21 17:12:48.984 - info: host.ioBroker 3 instances found
      2022-07-21 17:12:48.992 - info: host.ioBroker starting 3 instances
      2022-07-21 17:12:49.043 - info: host.ioBroker instance system.adapter.admin.0 started with pid 8135
      2022-07-21 17:12:50.836 - info: admin.0 (8135) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:12:50.884 - info: admin.0 (8135) requesting all states
      2022-07-21 17:12:50.885 - info: admin.0 (8135) requesting all objects
      2022-07-21 17:12:51.384 - info: admin.0 (8135) received all objects
      2022-07-21 17:12:51.614 - info: admin.0 (8135) http server listening on port 8081
      2022-07-21 17:12:51.615 - info: admin.0 (8135) Use link "http://localhost:8081" to configure.
      2022-07-21 17:12:53.065 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 8150
      2022-07-21 17:12:54.686 - info: discovery.0 (8150) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:12:57.057 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8166
      2022-07-21 17:12:58.768 - info: backitup.0 (8166) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-07-21 17:12:58.823 - error: backitup.0 (8166) [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2022_05_26-02_40_20_backupiobroker.tar.gz": TAR_BAD_ARCHIVE: Unrecognized archive format
      2022-07-21 17:12:58.849 - info: backitup.0 (8166) [iobroker] backup was activated at 02:40 every 1 day(s)
      haselchenH HomoranH 4 Antworten Letzte Antwort
      • I IceD112
        @glasfaser
        haselchenH Offline
        haselchenH Offline
        haselchen
        @iced112
        Vermutlich hat dein Rechner keine Rechte um auf das Backup zuzugreifen.
        Warum kopierst du es nicht in den backups Ordner auf dem Gerät wo Iobroker installiert ist?
        • I IceD112
          @glasfaser
          wattn das?
          • I IceD112
            @glasfaser
            und da scheint noch ein alter mount zu stehen
              GlasfaserG Offline
              GlasfaserG Offline
              @IceD112
              @homoran sagte in Backup Wiederherstellung nicht möglich:
              Den dann mit :
              sudo umount /opt/iobroker/backups
              • haselchenH haselchen
                @iced112
                I Offline
                I Offline
                IceD112
                @haselchen
                Das hatte ich schonmal. Dann hatte wir hier stromausfall und der PI war nicht mehr erreichbar und ich kam nicht mehr an die Daten ran. Danach hatte ich den ioB inkl VIS komplett neu aufgesetzt und habe die Backups auf die FritzBox auf einen angeschlossenen USB Stick gesichert.
                Jetzt hatten wir erneut vor kurzem einen Stromausfall... das selbe erneut. Allerdings stehen mir die Backups zur verfügung. Zumiondest sehen ich sie im BackitUp Adapter aber...
                  wattn das?
                  GlasfaserG Offline
                  GlasfaserG Offline
                  wattn das?
                  Das kommt daher :
                  ist 0 .
                    wenn die alle so aussehen wird das nix mit Restore
                      wattn das?
                      Das kommt daher :
                      ist 0 .
                      I Offline
                      I Offline
                      IceD112
                      @glasfaser ja, das verstehe ich auch nicht. ABer das obere hat ja scheinbar Inhalt mit 13.1 MB
                      HomoranH GlasfaserG 2 Antworten Letzte Antwort
                      • I IceD112
                        dann mach den umount und versuchs mit dem
                        • I IceD112
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @iced112
                          Ich sehe aber im beigestellte Log nichts davon das du es auch ausgewählt hast ...
                          oder habe ich es nicht gesehn
                            I Offline
                            I Offline
                            IceD112
                            schrieb am zuletzt editiert von IceD112
                            Kannst du mir bitte erklären wie ich das mache? 😲
                            Und was passiert da, damit ich das verstehe
                            • I IceD112
                              @glasfaser sagte in Backup Wiederherstellung nicht möglich:
                              @IceD112
                              Den dann mit :
                                @IceD112
                                Den dann mit :
                                I Offline
                                I Offline
                                IceD112
                                @homoran said in Backup Wiederherstellung nicht möglich:
                                Den Befehl in der ssh Console eingeben und Enter?
                                • I IceD112
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @iced112
                                  Ja
                                    @iced112
                                    Ja
                                    I Offline
                                    I Offline
                                    IceD112
                                    @glasfaser
                                    Ging immer noch nicht
                                    2022-07-21 17:45:22.360 - info: host.ioBroker received SIGTERM
                                    2022-07-21 17:45:22.362 - info: admin.0 (8135) terminating http server on port 8081
                                    2022-07-21 17:45:22.366 - info: backitup.0 (8166) cleaned everything up...
                                    2022-07-21 17:45:22.367 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2022-07-21 17:45:22.368 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2022-07-21 17:45:22.369 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2022-07-21 17:45:22.380 - info: admin.0 (8135) Got terminate signal TERMINATE_YOURSELF
                                    2022-07-21 17:45:22.382 - info: backitup.0 (8166) Got terminate signal TERMINATE_YOURSELF
                                    2022-07-21 17:45:22.382 - info: discovery.0 (8150) Got terminate signal TERMINATE_YOURSELF
                                    2022-07-21 17:45:22.387 - info: discovery.0 (8150) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-07-21 17:45:22.388 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
                                    2022-07-21 17:45:22.387 - info: admin.0 (8135) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-07-21 17:45:22.389 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
                                    2022-07-21 17:45:22.389 - info: backitup.0 (8166) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-07-21 17:45:22.390 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
                                    2022-07-21 17:45:22.955 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2022-07-21 17:45:22.978 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2022-07-21 17:45:23.023 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2022-07-21 17:45:23.024 - info: host.ioBroker All instances are stopped.
                                    2022-07-21 17:45:23.215 - info: host.ioBroker terminated
                                    2022-07-21 17:45:52.738 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-07-21 17:45:52.745 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-07-21 17:45:52.745 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
                                    2022-07-21 17:45:52.746 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
                                    2022-07-21 17:45:53.265 - info: host.ioBroker connected to Objects and States
                                    2022-07-21 17:45:53.287 - info: host.ioBroker added notifications configuration of host
                                    2022-07-21 17:45:53.561 - info: host.ioBroker 3 instances found
                                    2022-07-21 17:45:53.569 - info: host.ioBroker starting 3 instances
                                    2022-07-21 17:45:53.666 - info: host.ioBroker instance system.adapter.admin.0 started with pid 8571
                                    2022-07-21 17:45:55.460 - info: admin.0 (8571) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                                    2022-07-21 17:45:55.510 - info: admin.0 (8571) requesting all states
                                    2022-07-21 17:45:55.511 - info: admin.0 (8571) requesting all objects
                                    2022-07-21 17:45:56.052 - info: admin.0 (8571) received all objects
                                    2022-07-21 17:45:56.279 - info: admin.0 (8571) http server listening on port 8081
                                    2022-07-21 17:45:56.280 - info: admin.0 (8571) Use link "http://localhost:8081" to configure.
                                    2022-07-21 17:45:57.632 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 8586
                                    2022-07-21 17:45:59.262 - info: discovery.0 (8586) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
                                    2022-07-21 17:46:01.626 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8601
                                    2022-07-21 17:46:03.337 - info: backitup.0 (8601) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
                                    2022-07-21 17:46:03.391 - error: backitup.0 (8601) [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2022_06_27-02_40_20_backupiobroker.tar.gz": TAR_BAD_ARCHIVE: Unrecognized archive format
                                    2022-07-21 17:46:03.426 - info: backitup.0 (8601) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                    • I IceD112
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      kannst du mal diese Datei öffnen
                                      ich vermute mal deine ganzen Backups sind SCHROTT
                                        I Offline
                                        I Offline
                                        IceD112
                                        auch über putty?
                                        • I IceD112
                                          Hallo
                                          Ich musste meinen ioB neu installieren und wollte ihn nach Neuinstallation auf dem PI wiederherstellen.
                                          Den BackitUp Adapter habe ich entsprechend Konfiguriert (NAS / Kopieren). Die Backups wurden täglich auf einen USB-Stick an ander FritzBox gesichert
                                          Beim Versuch der Wiederherstellung kann ich auch ein entsprechendes Backup auswählen
                                          aber beim Versuch es wiederherzustellen, kommt die Meldung
                                          im Protokoll wird das geschrieben:
                                          Kann mir wer behilflich sein?
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Du kannst doch direkt darauf zugreifen !!
                                          I 2 Antworten Letzte Antwort
