  4. Backup Wiederherstellung nicht möglich
    5.4k
172 Beiträge 6 Kommentatoren 25.9k Aufrufe 4 Beobachtet
  • I IceD112
    @glasfaser
    2022-07-21 16:08:50.155 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-21 16:08:50.161 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-21 16:08:50.162 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
    2022-07-21 16:08:50.163 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
    2022-07-21 16:08:50.472 - info: host.ioBroker connected to Objects and States
    2022-07-21 16:08:50.516 - info: host.ioBroker Node.js version has changed from unknown to 16.16.0
    2022-07-21 16:08:50.561 - info: host.ioBroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-07-21 16:08:50.579 - info: host.ioBroker added notifications configuration of host
    2022-07-21 16:08:50.867 - info: host.ioBroker 3 instances found
    2022-07-21 16:08:50.877 - info: host.ioBroker starting 3 instances
    2022-07-21 16:08:50.936 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7050
    2022-07-21 16:08:52.820 - info: admin.0 (7050) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:08:52.867 - info: admin.0 (7050) requesting all states
    2022-07-21 16:08:52.868 - info: admin.0 (7050) requesting all objects
    2022-07-21 16:08:52.961 - info: admin.0 (7050) received all objects
    2022-07-21 16:08:53.061 - info: admin.0 (7050) http server listening on port 8081
    2022-07-21 16:08:53.062 - info: admin.0 (7050) Use link "http://localhost:8081" to configure.
    2022-07-21 16:08:53.128 - warn: admin.0 (7050) Repository cannot be read: Active repo - stable
    2022-07-21 16:08:53.129 - warn: admin.0 (7050) Active repository "stable cannot be read
    2022-07-21 16:08:54.934 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7065
    2022-07-21 16:08:56.581 - info: discovery.0 (7065) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:08:58.929 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7080
    2022-07-21 16:09:00.650 - info: backitup.0 (7080) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:09:00.714 - info: backitup.0 (7080) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:09:49.819 - info: host.ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-07-21 16:18:29.975 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:18:29.995 - info: backitup.0 (7080) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:18:30.005 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:18:29.998 - info: backitup.0 (7080) cleaned everything up...
    2022-07-21 16:18:30.001 - info: backitup.0 (7080) terminating
    2022-07-21 16:18:30.005 - info: backitup.0 (7080) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:18:30.554 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:18:33.087 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7187
    2022-07-21 16:18:34.750 - info: backitup.0 (7187) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:18:34.820 - info: backitup.0 (7187) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:21:18.496 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:21:18.508 - info: backitup.0 (7187) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:21:18.512 - info: backitup.0 (7187) cleaned everything up...
    2022-07-21 16:21:18.515 - info: backitup.0 (7187) terminating
    2022-07-21 16:21:18.518 - info: backitup.0 (7187) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:21:18.553 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:21:19.090 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:21:21.598 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7231
    2022-07-21 16:21:23.337 - info: backitup.0 (7231) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:21:23.437 - info: backitup.0 (7231) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:21:24.008 - error: backitup.0 (7231) Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backups
    mount.nfs: Failed to resolve server : Name or service not known
    2022-07-21 16:39:36.896 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:39:36.915 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:39:36.916 - info: backitup.0 (7231) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:39:36.921 - info: backitup.0 (7231) cleaned everything up...
    2022-07-21 16:39:36.924 - info: backitup.0 (7231) terminating
    2022-07-21 16:39:36.928 - info: backitup.0 (7231) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:39:37.463 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:39:39.971 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7354
    2022-07-21 16:39:41.649 - info: backitup.0 (7354) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:39:41.720 - info: backitup.0 (7354) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:39:42.375 - error: backitup.0 (7354) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    2022-07-21 16:39:48.275 - error: backitup.0 (7354) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER /opt/iobroker/backups
    2022-07-21 16:40:48.795 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:40:48.804 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:40:48.805 - info: backitup.0 (7354) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:40:48.809 - info: backitup.0 (7354) cleaned everything up...
    2022-07-21 16:40:48.811 - info: backitup.0 (7354) terminating
    2022-07-21 16:40:48.815 - info: backitup.0 (7354) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:40:49.392 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:40:51.853 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7416
    2022-07-21 16:40:53.563 - info: backitup.0 (7416) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:40:53.629 - info: backitup.0 (7416) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:40:54.210 - error: backitup.0 (7416) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
    2022-07-21 16:40:59.247 - error: backitup.0 (7416) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
    2022-07-21 16:41:36.174 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:41:36.181 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:41:36.181 - info: backitup.0 (7416) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:41:36.185 - info: backitup.0 (7416) cleaned everything up...
    2022-07-21 16:41:36.187 - info: backitup.0 (7416) terminating
    2022-07-21 16:41:36.189 - info: backitup.0 (7416) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:41:36.767 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:41:39.227 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7456
    2022-07-21 16:41:40.919 - info: backitup.0 (7456) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:41:40.985 - info: backitup.0 (7456) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:41:41.624 - error: backitup.0 (7456) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROCKER/ioBroker /opt/iobroker/backups
    2022-07-21 16:42:34.476 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:42:34.482 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:42:34.482 - info: backitup.0 (7456) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:42:34.486 - info: backitup.0 (7456) cleaned everything up...
    2022-07-21 16:42:34.487 - info: backitup.0 (7456) terminating
    2022-07-21 16:42:34.490 - info: backitup.0 (7456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:42:35.070 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:42:37.537 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7484
    2022-07-21 16:42:39.213 - info: backitup.0 (7484) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:42:39.279 - info: backitup.0 (7484) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:42:43.889 - error: backitup.0 (7484) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
    mount error(16): Device or resource busy
    2022-07-21 16:44:43.858 - error: backitup.0 (7484) umount: /opt/iobroker/backups: not mounted.
    2022-07-21 16:54:32.398 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 16:54:32.410 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 16:54:32.410 - info: backitup.0 (7484) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 16:54:32.414 - info: backitup.0 (7484) cleaned everything up...
    2022-07-21 16:54:32.416 - info: backitup.0 (7484) terminating
    2022-07-21 16:54:32.421 - info: backitup.0 (7484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 16:54:32.997 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 16:54:35.467 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7608
    2022-07-21 16:54:37.146 - info: backitup.0 (7608) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 16:54:37.237 - info: backitup.0 (7608) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 16:54:37.887 - error: backitup.0 (7608) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
    2022-07-21 16:56:37.953 - error: backitup.0 (7608) umount: /opt/iobroker/backups: not mounted.
    2022-07-21 17:06:48.664 - info: backitup.0 (7608) cleaned everything up...
    2022-07-21 17:06:48.662 - info: host.ioBroker received SIGTERM
    2022-07-21 17:06:48.666 - info: admin.0 (7050) terminating http server on port 8081
    2022-07-21 17:06:48.667 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-07-21 17:06:48.668 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-07-21 17:06:48.669 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 17:06:48.683 - info: admin.0 (7050) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:06:48.685 - info: discovery.0 (7065) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:06:48.687 - info: backitup.0 (7608) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:06:48.691 - info: discovery.0 (7065) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:06:48.691 - info: backitup.0 (7608) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:06:48.692 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
    2022-07-21 17:06:48.694 - info: admin.0 (7050) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:06:48.696 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
    2022-07-21 17:06:48.696 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 17:06:49.267 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:06:49.271 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:06:49.272 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:06:49.273 - info: host.ioBroker All instances are stopped.
    2022-07-21 17:06:49.326 - info: host.ioBroker terminated
    2022-07-21 17:07:18.998 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-21 17:07:19.004 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-21 17:07:19.005 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
    2022-07-21 17:07:19.006 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
    2022-07-21 17:07:19.493 - info: host.ioBroker connected to Objects and States
    2022-07-21 17:07:19.516 - info: host.ioBroker added notifications configuration of host
    2022-07-21 17:07:19.788 - info: host.ioBroker 3 instances found
    2022-07-21 17:07:19.796 - info: host.ioBroker starting 3 instances
    2022-07-21 17:07:19.838 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7796
    2022-07-21 17:07:21.688 - info: admin.0 (7796) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:07:21.739 - info: admin.0 (7796) requesting all states
    2022-07-21 17:07:21.739 - info: admin.0 (7796) requesting all objects
    2022-07-21 17:07:22.198 - info: admin.0 (7796) received all objects
    2022-07-21 17:07:22.402 - info: admin.0 (7796) http server listening on port 8081
    2022-07-21 17:07:22.403 - info: admin.0 (7796) Use link "http://localhost:8081" to configure.
    2022-07-21 17:07:24.066 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7812
    2022-07-21 17:07:26.124 - info: discovery.0 (7812) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:07:27.858 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7839
    2022-07-21 17:07:29.593 - info: backitup.0 (7839) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:07:29.710 - warn: backitup.0 (7839) Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
    2022-07-21 17:07:29.734 - info: backitup.0 (7839) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 17:07:30.380 - error: backitup.0 (7839) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
    2022-07-21 17:08:04.860 - info: host.ioBroker received SIGTERM
    2022-07-21 17:08:04.866 - info: backitup.0 (7839) cleaned everything up...
    2022-07-21 17:08:04.864 - info: admin.0 (7796) terminating http server on port 8081
    2022-07-21 17:08:04.866 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-07-21 17:08:04.867 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-07-21 17:08:04.868 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 17:08:04.885 - info: admin.0 (7796) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:08:04.887 - info: discovery.0 (7812) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:08:04.887 - info: backitup.0 (7839) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:08:04.894 - info: backitup.0 (7839) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:08:04.894 - info: discovery.0 (7812) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:08:04.897 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
    2022-07-21 17:08:04.898 - info: admin.0 (7796) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:08:04.903 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
    2022-07-21 17:08:04.903 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 17:08:05.476 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:08:05.477 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:08:05.495 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:08:05.496 - info: host.ioBroker All instances are stopped.
    2022-07-21 17:08:05.724 - info: host.ioBroker terminated
    2022-07-21 17:08:35.623 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-21 17:08:35.629 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-21 17:08:35.630 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
    2022-07-21 17:08:35.631 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
    2022-07-21 17:08:36.089 - info: host.ioBroker connected to Objects and States
    2022-07-21 17:08:36.111 - info: host.ioBroker added notifications configuration of host
    2022-07-21 17:08:36.425 - info: host.ioBroker 3 instances found
    2022-07-21 17:08:36.433 - info: host.ioBroker starting 3 instances
    2022-07-21 17:08:36.484 - info: host.ioBroker instance system.adapter.admin.0 started with pid 7947
    2022-07-21 17:08:38.350 - info: admin.0 (7947) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:08:38.401 - info: admin.0 (7947) requesting all states
    2022-07-21 17:08:38.401 - info: admin.0 (7947) requesting all objects
    2022-07-21 17:08:38.905 - info: admin.0 (7947) received all objects
    2022-07-21 17:08:39.110 - info: admin.0 (7947) http server listening on port 8081
    2022-07-21 17:08:39.111 - info: admin.0 (7947) Use link "http://localhost:8081" to configure.
    2022-07-21 17:08:40.507 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 7962
    2022-07-21 17:08:42.112 - info: discovery.0 (7962) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:08:44.497 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 7977
    2022-07-21 17:08:46.217 - info: backitup.0 (7977) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:08:46.322 - warn: backitup.0 (7977) Cannot read log file: Error: UNKNOWN: unknown error, open '/opt/iobroker/backups/logs.txt'
    2022-07-21 17:08:46.348 - info: backitup.0 (7977) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 17:08:46.952 - error: backitup.0 (7977) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
    2022-07-21 17:10:47.004 - error: backitup.0 (7977) umount: /opt/iobroker/backups: not mounted.
    2022-07-21 17:11:48.247 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 17:11:48.265 - info: backitup.0 (7977) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:11:48.267 - info: backitup.0 (7977) cleaned everything up...
    2022-07-21 17:11:48.267 - info: backitup.0 (7977) terminating
    2022-07-21 17:11:48.269 - info: backitup.0 (7977) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-07-21 17:11:48.271 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 17:11:48.813 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-07-21 17:11:51.322 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8023
    2022-07-21 17:11:53.101 - info: backitup.0 (8023) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:11:53.175 - info: backitup.0 (8023) [iobroker] backup was activated at 02:40 every 1 day(s)
    2022-07-21 17:12:03.423 - error: backitup.0 (8023) Error: Command failed: sudo mount -t cifs -o username=ioB_Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.1/IceDBox/IOBROKER/ioBroker /opt/iobroker/backups
    2022-07-21 17:12:17.772 - info: host.ioBroker received SIGTERM
    2022-07-21 17:12:17.774 - info: admin.0 (7947) terminating http server on port 8081
    2022-07-21 17:12:17.777 - info: backitup.0 (8023) cleaned everything up...
    2022-07-21 17:12:17.774 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2022-07-21 17:12:17.775 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
    2022-07-21 17:12:17.776 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2022-07-21 17:12:17.791 - info: admin.0 (7947) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:12:17.793 - info: discovery.0 (7962) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:12:17.793 - info: backitup.0 (8023) Got terminate signal TERMINATE_YOURSELF
    2022-07-21 17:12:17.797 - info: discovery.0 (7962) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:12:17.799 - info: admin.0 (7947) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:12:17.800 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
    2022-07-21 17:12:17.802 - info: backitup.0 (8023) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-07-21 17:12:17.804 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
    2022-07-21 17:12:17.804 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    2022-07-21 17:12:18.350 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:12:18.367 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:12:18.415 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2022-07-21 17:12:18.417 - info: host.ioBroker All instances are stopped.
    2022-07-21 17:12:18.634 - info: host.ioBroker terminated
    2022-07-21 17:12:48.139 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-07-21 17:12:48.145 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-07-21 17:12:48.146 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
    2022-07-21 17:12:48.147 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
    2022-07-21 17:12:48.645 - info: host.ioBroker connected to Objects and States
    2022-07-21 17:12:48.668 - info: host.ioBroker added notifications configuration of host
    2022-07-21 17:12:48.984 - info: host.ioBroker 3 instances found
    2022-07-21 17:12:48.992 - info: host.ioBroker starting 3 instances
    2022-07-21 17:12:49.043 - info: host.ioBroker instance system.adapter.admin.0 started with pid 8135
    2022-07-21 17:12:50.836 - info: admin.0 (8135) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:12:50.884 - info: admin.0 (8135) requesting all states
    2022-07-21 17:12:50.885 - info: admin.0 (8135) requesting all objects
    2022-07-21 17:12:51.384 - info: admin.0 (8135) received all objects
    2022-07-21 17:12:51.614 - info: admin.0 (8135) http server listening on port 8081
    2022-07-21 17:12:51.615 - info: admin.0 (8135) Use link "http://localhost:8081" to configure.
    2022-07-21 17:12:53.065 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 8150
    2022-07-21 17:12:54.686 - info: discovery.0 (8150) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:12:57.057 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8166
    2022-07-21 17:12:58.768 - info: backitup.0 (8166) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
    2022-07-21 17:12:58.823 - error: backitup.0 (8166) [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2022_05_26-02_40_20_backupiobroker.tar.gz": TAR_BAD_ARCHIVE: Unrecognized archive format
    2022-07-21 17:12:58.849 - info: backitup.0 (8166) [iobroker] backup was activated at 02:40 every 1 day(s)
    haselchenH Offline
    haselchenH Offline
    haselchen
    @iced112
    Vermutlich hat dein Rechner keine Rechte um auf das Backup zuzugreifen.
    Warum kopierst du es nicht in den backups Ordner auf dem Gerät wo Iobroker installiert ist?
    I 1 Antwort Letzte Antwort
    • I IceD112
      @glasfaser
      @iced112 sagte in Backup Wiederherstellung nicht möglich:
      wattn das?
      • I IceD112
        @glasfaser
        und da scheint noch ein alter mount zu stehen
          GlasfaserG Offline
          GlasfaserG Offline
          @IceD112
          @homoran sagte in Backup Wiederherstellung nicht möglich:
          Den dann mit :
          sudo umount /opt/iobroker/backups
          • haselchenH haselchen
            @iced112
            I Offline
            I Offline
            IceD112
            @haselchen
            Das hatte ich schonmal. Dann hatte wir hier stromausfall und der PI war nicht mehr erreichbar und ich kam nicht mehr an die Daten ran. Danach hatte ich den ioB inkl VIS komplett neu aufgesetzt und habe die Backups auf die FritzBox auf einen angeschlossenen USB Stick gesichert.
            Jetzt hatten wir erneut vor kurzem einen Stromausfall... das selbe erneut. Allerdings stehen mir die Backups zur verfügung. Zumiondest sehen ich sie im BackitUp Adapter aber...
              wattn das?
              GlasfaserG Offline
              GlasfaserG Offline
              wattn das?
              Das kommt daher :
              ist 0 .
                wenn die alle so aussehen wird das nix mit Restore
                • GlasfaserG Glasfaser
                  wattn das?
                  Das kommt daher :
                  ist 0 .
                  I Offline
                  I Offline
                  IceD112
                  @glasfaser ja, das verstehe ich auch nicht. ABer das obere hat ja scheinbar Inhalt mit 13.1 MB
                  HomoranH GlasfaserG 2 Antworten Letzte Antwort
                  • I IceD112
                    dann mach den umount und versuchs mit dem
                    • I IceD112
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @iced112
                      Ich sehe aber im beigestellte Log nichts davon das du es auch ausgewählt hast ...
                      oder habe ich es nicht gesehn
                        I Offline
                        I Offline
                        IceD112
                        schrieb am zuletzt editiert von IceD112
                        Kannst du mir bitte erklären wie ich das mache? 😲
                        Und was passiert da, damit ich das verstehe
                        • I IceD112
                          @glasfaser sagte in Backup Wiederherstellung nicht möglich:
                          @IceD112
                          Den dann mit :
                            @IceD112
                            Den dann mit :
                            I Offline
                            I Offline
                            IceD112
                            @homoran said in Backup Wiederherstellung nicht möglich:
                            Den Befehl in der ssh Console eingeben und Enter?
                            • I IceD112
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @iced112
                              Ja
                                @iced112
                                Ja
                                I Offline
                                I Offline
                                IceD112
                                @glasfaser
                                Ging immer noch nicht
                                2022-07-21 17:45:22.360 - info: host.ioBroker received SIGTERM
                                2022-07-21 17:45:22.362 - info: admin.0 (8135) terminating http server on port 8081
                                2022-07-21 17:45:22.366 - info: backitup.0 (8166) cleaned everything up...
                                2022-07-21 17:45:22.367 - info: host.ioBroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                2022-07-21 17:45:22.368 - info: host.ioBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2022-07-21 17:45:22.369 - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2022-07-21 17:45:22.380 - info: admin.0 (8135) Got terminate signal TERMINATE_YOURSELF
                                2022-07-21 17:45:22.382 - info: backitup.0 (8166) Got terminate signal TERMINATE_YOURSELF
                                2022-07-21 17:45:22.382 - info: discovery.0 (8150) Got terminate signal TERMINATE_YOURSELF
                                2022-07-21 17:45:22.387 - info: discovery.0 (8150) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2022-07-21 17:45:22.388 - info: host.ioBroker stopInstance system.adapter.admin.0 send kill signal
                                2022-07-21 17:45:22.387 - info: admin.0 (8135) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2022-07-21 17:45:22.389 - info: host.ioBroker stopInstance system.adapter.discovery.0 send kill signal
                                2022-07-21 17:45:22.389 - info: backitup.0 (8166) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                2022-07-21 17:45:22.390 - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
                                2022-07-21 17:45:22.955 - info: host.ioBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2022-07-21 17:45:22.978 - info: host.ioBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2022-07-21 17:45:23.023 - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                2022-07-21 17:45:23.024 - info: host.ioBroker All instances are stopped.
                                2022-07-21 17:45:23.215 - info: host.ioBroker terminated
                                2022-07-21 17:45:52.738 - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
                                2022-07-21 17:45:52.745 - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                2022-07-21 17:45:52.745 - info: host.ioBroker hostname: ioBroker, node: v16.16.0
                                2022-07-21 17:45:52.746 - info: host.ioBroker ip addresses: 192.168.178.64 2003:c9:df3d:ca00:6582:4118:74b2:83f4 fe80::b5b7:6e20:b2ab:8b78
                                2022-07-21 17:45:53.265 - info: host.ioBroker connected to Objects and States
                                2022-07-21 17:45:53.287 - info: host.ioBroker added notifications configuration of host
                                2022-07-21 17:45:53.561 - info: host.ioBroker 3 instances found
                                2022-07-21 17:45:53.569 - info: host.ioBroker starting 3 instances
                                2022-07-21 17:45:53.666 - info: host.ioBroker instance system.adapter.admin.0 started with pid 8571
                                2022-07-21 17:45:55.460 - info: admin.0 (8571) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                                2022-07-21 17:45:55.510 - info: admin.0 (8571) requesting all states
                                2022-07-21 17:45:55.511 - info: admin.0 (8571) requesting all objects
                                2022-07-21 17:45:56.052 - info: admin.0 (8571) received all objects
                                2022-07-21 17:45:56.279 - info: admin.0 (8571) http server listening on port 8081
                                2022-07-21 17:45:56.280 - info: admin.0 (8571) Use link "http://localhost:8081" to configure.
                                2022-07-21 17:45:57.632 - info: host.ioBroker instance system.adapter.discovery.0 started with pid 8586
                                2022-07-21 17:45:59.262 - info: discovery.0 (8586) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
                                2022-07-21 17:46:01.626 - info: host.ioBroker instance system.adapter.backitup.0 started with pid 8601
                                2022-07-21 17:46:03.337 - info: backitup.0 (8601) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
                                2022-07-21 17:46:03.391 - error: backitup.0 (8601) [ERROR] [iobroker] host.ioBroker Cannot extract from file "/opt/iobroker/backups/iobroker_2022_06_27-02_40_20_backupiobroker.tar.gz": TAR_BAD_ARCHIVE: Unrecognized archive format
                                2022-07-21 17:46:03.426 - info: backitup.0 (8601) [iobroker] backup was activated at 02:40 every 1 day(s)
                                GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                • I IceD112
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  kannst du mal diese Datei öffnen
                                  ich vermute mal deine ganzen Backups sind SCHROTT
                                    I Offline
                                    I Offline
                                    IceD112
                                    @glasfaser said in Backup Wiederherstellung nicht möglich:
                                    auch über putty?
                                    • I IceD112
                                      Hallo
                                      Ich musste meinen ioB neu installieren und wollte ihn nach Neuinstallation auf dem PI wiederherstellen.
                                      Den BackitUp Adapter habe ich entsprechend Konfiguriert (NAS / Kopieren). Die Backups wurden täglich auf einen USB-Stick an ander FritzBox gesichert
                                      Beim Versuch der Wiederherstellung kann ich auch ein entsprechendes Backup auswählen
                                      aber beim Versuch es wiederherzustellen, kommt die Meldung
                                      im Protokoll wird das geschrieben:
                                      Kann mir wer behilflich sein?
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Du kannst doch direkt darauf zugreifen !!
                                      I 2 Antworten Letzte Antwort
                                        I Offline
                                        I Offline
                                        IceD112
                                        @glasfaser
                                        achso... moment
                                          I Offline
                                          I Offline
                                          IceD112
                                          @glasfaser der öffnet mir dann die PI Imager
