  4. [Synology Docker]Iobroker startet nicht (no database)
130 Beiträge 11 Kommentatoren 22.7k Aufrufe 9 Beobachtet
  • GlasfaserG Glasfaser
    @simka
    iobroker status
    SimKa
    schrieb am zuletzt editiert von SimKa
    @glasfaser said in [Synology Docker]Iobroker startet nicht (no database):
    @simka
    iobroker status
    root@iobroker:/opt/iobroker# iobroker status
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    • GlasfaserG Offline
      GlasfaserG Offline
      @simka
      kill 1057
      ausnahmsweise :
      iobroker start
        @simka
        kill 1057
        ausnahmsweise :
        iobroker start
        SimKa
        iobroker start
        root@iobroker:/opt/iobroker# kill 1057
        bash: kill: (1057) - No such process
        root@iobroker:/opt/iobroker# ps
          PID TTY          TIME CMD
          986 pts/1    00:00:00 bash
         2095 pts/1    00:00:00 ps
        root@iobroker:/opt/iobroker# iobroker start
        iobroker controller daemon already running. PID: 2135
        root@iobroker:/opt/iobroker# kill 2135
        Starting iobroker controller daemon...
        iobroker controller daemon started. PID: 2208
        iobroker.2022-07-04 (12).log
          GlasfaserG Offline
          @simka
          Da stimmt was nicht es werden Zwei Controller gestartet !!
          einmal 4.0.21 und dann 4.0.23
          2022-07-04 19:57:00.141  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
          2022-07-04 19:57:00.159  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-07-04 19:57:00.161  - info: host.iobroker hostname: iobroker, node: v16.15.1
          2022-07-04 19:57:00.164  - info: host.iobroker ip addresses: 172.17.0.2
          2022-07-04 19:57:30.237  - error: host.iobroker No connection to databases possible, restart
          2022-07-04 19:57:30.260  - info: host.iobroker iobroker _restart
          2022-07-04 19:57:37.079  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
          2022-07-04 19:57:37.094  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
          2022-07-04 19:57:37.096  - info: host.iobroker hostname: iobroker, node: v16.15.1
          2022-07-04 19:57:37.097  - info: host.iobroker ip addresses: 172.17.0.2
            @simka
            SimKa
            @simka
            Vielleicht durch den js-controller Befehl gekommen. Gibt es einen uninstall Befehl oder soll ich eine neue Docker Instanz bauen und den Ordner mounten?
            • S SimKa
              @simka
              GlasfaserG Offline
              GlasfaserG Offline
              @simka sagte in [Synology Docker]Iobroker startet nicht (no database):
              Jipp , mach das .
              du hast da was quer installiert !
                Jipp , mach das .
                SimKa
                Jipp , mach das .
                Erledigt, leider immer noch nicht :-/
                iobroker.2022-07-04 (13).log
                • S SimKa
                  Jipp , mach das .
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @simka
                  Wie geht das einmal Node 16 dann 14
                  2022-07-04 21:21:03.074  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
                  2022-07-04 21:21:03.086  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2022-07-04 21:21:03.088  - info: host.iobroker hostname: iobroker, node: v16.15.1
                  2022-07-04 21:21:03.089  - info: host.iobroker ip addresses: 172.17.0.2
                  2022-07-04 21:26:04.283  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
                  2022-07-04 21:26:04.300  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2022-07-04 21:26:04.302  - info: host.iobroker hostname: iobroker, node: v14.19.3
                  2022-07-04 21:26:04.304  - info: host.iobroker ip addresses: 172.17.0.2
                    @simka
                    SimKa
                    @simka
                    Weg geht das einmal Node 16 dann 14
                    Is das im in einer Datei hinterlegt?
                    • S SimKa
                      @simka
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @simka
                      Hast du kein Backup über Backitup !?
                        @simka
                        SimKa
                        @simka
                        Dock, habe es über das Webinterface eingespielt und anschließend die gleichen Probleme bekommen
                        • S SimKa
                          iobroker.2022-07-04 (9).log Hallo zusammen,
                          mich hat es leider auch getroffen. Iobroker lässt sich nicht mehr starten. Log im Anhang
                          Ich habe verschiedene Befehle wie z.B.
                          iobroker fix
                          oder
                          curl -fsL https://iobroker.net/fix.sh | bash -
                          und anschließend
                          sudo -u iobroker -H npm install iobroker.js-controller
                          Wobei dann dieser Fehler kam
                          root@iobroker:/opt/iobroker# sudo -u iobroker -H npm install iobroker.js-controller
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          (################⠂⠂) ⠼ idealTree:inflate:node_modules/@samverschueren/stream-to-observable/node_modules/any-observable: sill inflate node_modules/@samverschueren/stream-to-observable/node_modul
                          npm ERR! code 24
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR! command failed
                          npm ERR! command sh -c node iobroker.js setup first
                          npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                          npm ERR!     /opt/iobroker/.npm/_logs/2022-07-04T17_55_42_289Z-debug-0.log
                          Das /opt/iobroker/.npm/_logs/2022-07-04T17_55_42_289Z-debug-0.log im Anhang.
                          Die Lockfiles habe ich auch bereits gelöscht.
                          Ich benutzte iobroker in einem Docker auf einer Synology mit folgenden Verionen
                          root@iobroker:/opt/iobroker# npm -v
                          8.11.0
                          und
                          root@iobroker:/opt/iobroker# node -v
                          v16.15.1
                          Das curiose ist, dass ich eine weitere Docker Instanz gestartet habe, bei der ich den Wizard durch gegangen bin und nachdem ich das Backup eingespielt habe, ebenfalls nicht mehr startete
                          Ich hoffe, dass ich alle benötigten Informationen, für eine Fehlerdiagnose, zusammen habe ansonsten liefere ich diese noch nach.
                          Vielen Dank schonmal im vorraus.
                          LG
                          2022-07-04T18_06_06_635Z-debug-0.log
                          andreA Offline
                          andreA Offline
                          andre
                          Was hat dich getroffen? Hab noch nicht gehört dass der iobroker einfach so über die Klippe springt. Was hat dich denn in diese Lage gebracht. Updates? Was genau hast du gemacht?
                          (Sorry falls ich das im Thread überlesen haben sollte)
                          MfG,
                          Andre
                          • andreA andre
                            MfG,
                            Andre
                            SimKa
                            @andre said in [Synology Docker]Iobroker startet nicht (no database):
                            MfG,
                            Andre
                            Wenn ich das wüsste. Ich habe kein Update von der Synology gemacht, kein Update des Dockers aber ich meine, ich hätte ein update von iobroker über das Webinterface gemacht.
                            andreA 1 Antwort Letzte Antwort
                            • S SimKa
                              iobroker fix
                              oder
                              und anschließend
                              npm ERR! code 24
                              8.11.0
                              und
                              v16.15.1
                              LG
                              GlasfaserG Offline
                              GlasfaserG Offline
                              v16.15.1
                              War das schon im Container oder hast du ein Update von 14 auf 16 gemacht !?
                                v16.15.1
                                SimKa
                                v16.15.1
                                Ich hab nur den Container erstellt, den Ordner gemountet und gestartet. Während der Container startete, sind einige Sachen installiert worden. Manuell habe ich nichts installiert.
                                • S SimKa
                                  @simka
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Ich frage deshalb weil der jetzige Container wieder 14 hat und die oben im Start-Thread 16 hattest
                                  Laut deinem neusten Log
                                  S 2 Antworten Letzte Antwort
                                    SimKa
                                    Hab ne neue Instanz gestartet in einem leeren Ordner. Anscheinend ist die 14er standardmäßig installiert. iobroker.2022-07-04 (14).log
                                      SimKa
                                      @glasfaser
                                      Ich hab noch mal über das Webinterface das Backup eingespielt.
                                      iobroker.2022-07-04 (16).log
                                        SimKa
                                        Nach einem Neustart bleibts zumindest bei v14 aber wieder ein Fehler
                                        2022-07-04 22:16:45.676  - info: host.iobroker iobroker.js-controller version 4.0.21 js-controller starting
                                        2022-07-04 22:16:45.689  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        2022-07-04 22:16:45.691  - info: host.iobroker hostname: iobroker, node: v14.19.3
                                        2022-07-04 22:16:45.692  - info: host.iobroker ip addresses: 172.17.0.2
                                        2022-07-04 22:16:47.534  - info: host.iobroker connected to Objects and States
                                        2022-07-04 22:16:47.603  - info: host.iobroker Node.js version has changed from unknown to 14.19.3
                                        2022-07-04 22:16:47.635  - info: host.iobroker added notifications configuration of host
                                        2022-07-04 22:16:48.203  - warn: host.iobroker Error while trying to update capabilities after detecting new Node.js version: Command failed: sudo setcap cap_net_bind_service,cap_net_raw+epi /usr/bin/node
                                        Failed to set capabilities on file `/usr/bin/node' (Operation not supported)
                                        The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
                                        2022-07-04 22:16:48.338  - info: host.iobroker Delete host system.host.iobroker-default
                                        2022-07-04 22:16:48.452  - info: host.iobroker 28 instances found
                                        2022-07-04 22:16:48.490  - warn: host.iobroker does not start any instances on this host
                                        iobroker.2022-07-04 (19).log
                                        • S SimKa
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          iobroker host this
                                          Verstehe trozdem nicht , wo das wieder herkommt bei dir
                                          Du erstellt doch einen neuen Container mit ioBroker , dann spielst du es mit dem Backitup Adapter wieder ein .
                                          Weil .... deine gezeigten Log´s zeigen nichts davon an !
