  4. Sonoff NSPanel
    6.8k
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 881.3k Aufrufe 80 Beobachtet
    Much2k 0
    #855
    Hallo! Versuche schon seit Einiger Zeit das NSPanle aufzusetzen. Leider scheitere ich immer daran, dass er mir keine Datenpunkte ausgibt. Menüs Funktnieren soweit. Nur wenn ein Datenpunkt ist, schreibt er immer deletet. Hatte jemand schon dieses Phanomen. Vielen Dank
    javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: getObject(id=0_userdata.0.example_state, enumName=undefined) => {"_id":"0_userdata.0.example_state","type":"state","common":{"name":"Example state","role":"indicator","def":false,"type":"string"},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1656781800747}
    19:38:17.325	info	javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: setForeignState(id=mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend, state={"val":"pageType~cardEntities","ack":false,"ts":1656783497325,"q":0,"from":"system.adapter.javascript.0","lc":1656783497325,"c":"script.js.System.NSPANEL.NSPanel_1"})
    19:38:17.325	info	javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: pageType~cardEntities
    19:38:17.326	info	javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: setForeignState(id=mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend, state={"val":"entityUpd~NSPanel Service~1|0~delete~~~~~~button~navigate.NSPanel_Infos~~65535~NSPanel Infos~PRESS~button~navigate.NSPanel_Firmware_Updates~~65535~Manuelle-Updates~PRESS~button~navigate.NSPanel_Einstellungen~~65535~Einstellungen~PRESS","ack":false,"ts":1656783497326,"q":0,"from":"system.adapter.javascript.0","lc":1656783497326,"c":"script.js.System.NSPANEL.NSPanel_1"})
    19:38:17.326	info	javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: entityUpd~NSPanel Service~1|0~delete~~~~~~button~navigate.NSPanel_Infos~~65535~NSPanel Infos~PRESS~button~navigate.NSPanel_Firmware_Updates~~65535~Manuelle-Updates~PRESS~button~navigate.NSPanel_Einstellungen~~65535~Einstellungen~PRESS
    19:38:17.327	info	javascript.0 (31690) script.js.System.NSPANEL.NSPanel_1: event - buttonPress2 - screensaver - bExit - 1
    • M Much2k 0
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #856
      @much2k-0 sagte in Sonoff NSPanel:
      Wenn der Alias nicht existiert, dann wird das "pageItem" gelöscht. Sieht aus wie der Beispiel-Info-Dialog. Da fehlt dann noch der Alias für die Auto-Updates, vermute ich mal. Dürfte vom Typ socket (Steckdose) sein.
      Ansonsten solltest du nicht nur die Tasmota-Konsole, sondern auch den Teil, der das aufruft. Macht es für die meisten einfacher nachzuvollziehen, was denn passieren soll.
      • ArmilarA Armilar
        Much2k 0
        schrieb am zuletzt editiert von Much2k 0
        #857
        @armilar said in Sonoff NSPanel:
        Er existiert aber: Z.B
        //Subpages 2 (+ Info)
        var Service: PageEntities =
            "type": "cardEntities",
            "heading": "NSPanel Service",
            "useColor": true,
            "subPage": false,
            "parent": undefined,
            "items": [
                <PageItem>{ id: "^alias.0.NSPanel_1.NSPanel_AutoUpdate", name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
                <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
                <PageItem>{ navigate: true, id: "NSPanel_Firmware_Updates", icon: "update", onColor: White, name: "Manuelle-Updates"},
                <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Einstellungen"}
        Langsam verzweifle ich an der Aufgabe. Auch wenn ich den Datenpunkt direkt auf einen Status lege, Ist es das geliche Problem. Habe auch an den Alias gedacht dass ich diesen nicht Vertshe
        ArmilarA 2 Antworten Letzte Antwort
        • M Much2k 0
              "useColor": true,
              "subPage": false,
              "items": [
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #858
          Nimm mal das Zeichen "^" vor alias... weg. Das gehört da definitiv nicht hin.
          ArmilarA M 2 Antworten Letzte Antwort
          • ArmilarA Armilar
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #859
            @armilar sagte in Sonoff NSPanel:
            Nimm mal das Zeichen "^" vor alias... weg. Das gehört da definitiv nicht hin. Falls es das nicht war, dann zeige mal deinen Alias
            • ArmilarA Armilar
              Much2k 0
              #860
              @armilar Ok das gehört hier nicht hin, war ein Kopierfehler vom Probieren.
              • M Much2k 0
                    "useColor": true,
                    "subPage": false,
                    "items": [
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #861
                @much2k-0
                Datenpunkte bringen dich hier nicht weiter. Muss ein Alias sein, der dann auf einen Datenpunkt zugreift.
                Zeige mal den Alias aus dem Geräte-Manager-"Adapter"
                • ArmilarA Armilar
                  @much2k-0
                  Much2k 0
                  #862
                  @armilar Ich habe die Alias in den Objekten händisch angelegt, da im Gerätemanger diese nicht so anlegbar sind wie sie im Script vorhanden sind.
                  • M Much2k 0
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #863
                    Ja, wenn er dann händisch funktioniert und einen .SET hat, dann sollte es ja gehen, oder?
                    Der Alias Steckdose oder Licht ist so ziemlich der einfachste Alias und funktioniert eigentlich immer im Gerätemanager
                    Auf Geräte (Adapter muss natürlich auch installiert sein)
                    Das "+" drücken
                    Namen vergeben und Steckdose auswählen und Erstellen drücken
                    Datenpunkt auswählen
                    Speichern und fertig
                    • M Much2k 0
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #864
                      @much2k-0
                      Geht natürlich auch über den Alias-Manager (ebenfalls optionaler Adapter)
                      sieht dann so aus
                      Habe die Erfahrung gemacht, dass die "händisch" angelegten Aliase in der Regel nicht viel taugen, wenn man nicht weiß, welche Alias-Datenpunkte benötigt werden.
                      • ArmilarA Armilar
                        @much2k-0
                        sieht dann so aus
                        Much2k 0
                        #865
                        @armilar Hallo! Ich glaube langsam Kapiere ich es wie es Funktioniert. Vielen Dank für die Unterstützung. Die Ersten Datenpunkte funktionieren :-)
                        • H Online
                          H Online
                          holgerwolf
                          #866
                          Kann man eigentlich beim Nutzen von Pages und Subpages bei dem Icon zum Navigieren auf Subpages auch mit Datenpunkten arbeiten?
                          Ich würde für Fenster/Tür Statis gerne eine Übersichtsseite haben, wo hinter einem Punkt immer der Sammelstatus eines Stockwerks angezeigt wird, man aber dahinter direkt auf die Subpage für das jeweilige Stockwerk kommt.
                          Hier das Beispiel aus dem Script:
                          Bei dieser Sprungmarke sehe ich nicht, ob und wie ich noch einen Alias-Datenpunkt hinzufügen kann.
                          H 1 Antwort Letzte Antwort
                          • ravenst0neR Offline
                            ravenst0neR Offline
                            ravenst0ne
                            #867
                            gibt es eine Möglichkeit ein Relay des NSPanels zum Schalten der Heizung zu verwenden? Die Default-Sonoff-SW hatte das Feature dabei.
                            Klar könnte ich das alles in iobroker manuell erstellen, aber bei einfachem Algorythmus (unter/über Threashold ein/aus) würde das Relay im Zweifel durchgehend toggeln, weshalb ich an einer einfacheren Lösung interresiert wäre. Vielleicht hat jemand schon damit Erfahung?
                            • ravenst0neR ravenst0ne
                              BananaJoeB Online
                              BananaJoeB Online
                              BananaJoe
                              #868
                              @ravenst0ne sagte in Sonoff NSPanel:
                              Da läuft ja Tasmota drunter - ja über Rules müsste das gehen:
                              https://tasmota.github.io/docs/Rules/
                              Damit könnte man z.B. Temperatur und Relais verbinden. Ob das sinnvoll, ist etwas anderes, ich vermute auf dem Panel würde man diese Regel nicht sehen
                              ravenst0neR 1 Antwort Letzte Antwort
                              • BananaJoeB BananaJoe
                                ravenst0neR Offline
                                ravenst0neR Offline
                                ravenst0ne
                                #869
                                @bananajoe said in Sonoff NSPanel:
                                Hi, du hast Recht, da gibt es sogar ein extra Beispiel dafür: https://tasmota.github.io/docs/Rules/#simple-thermostat-example
                                Ich würde diese Logik dann allerdings direkt im iobroker implementieren, und dann wäre ich wieder bei einer eigenen Lösung und hab meine Zweifel, dass das Thermostat nicht dauerhaft toggelt, wenn ich einen Fixwert anstelle eines erlaubten Temperaturbereichs einstelle
                                  BananaJoeB Online
                                  BananaJoeB Online
                                  BananaJoe
                                  #870
                                  @ravenst0ne also, je nachdem wie du das Panel in iobroker eingebunden hast ... wenn es über MQTT ist könntest du die Rules auch per MQTT senden, ändern, aktivieren und deaktivieren.
                                  Und du hats ja die Werte von Temperatur und Relaisstatus.
                                  Sprich du könntest es auch das Panel machen lassen und es in ioBroker überwachen / deaktivieren / aktivieren.
                                  Der Vorteil könnte sein das es dann auch funktioniert wenn iobroker mal gerade nicht verfügbar ist (WLAN ausgefallen, Server kaputt).
                                  So, nun muss ich meine Bewegungsmelder-Schaltung nach dieser hier Idee umbauen ...
                                  • H holgerwolf
                                    H Online
                                    H Online
                                    holgerwolf
                                    schrieb am zuletzt editiert von holgerwolf
                                    #871
                                    Ich hab das jetzt mit zwei Icon Reihen realisiert (zum Glück haben wir nur drei Stockwerke ;-)
                                    Oben der Status, unten der Link zur Subpage:
                                    Über den Link geht es dann zur Subpage mit den Einzelstatis:
                                    • T TT-Tom
                                      @Armilar
                                      Hallo morgen bekomme ich mein Panel. Ich habe hier schon eine Weile mitgelesen und wollte nur noch einmal sicher gehen, welche nun die aktuelle Anleitung ist. es gibt hier im Thread eine und ich habe diese gefunden nspanel.pky.eu
                                      Gruß Tom
                                      TT-Tom
                                      #872
                                      @Armilar
                                      So Panel läuft jetzt, es hat etwas gedauert mit dem MQTT.
                                      Danke nochmal für die gute Anleitung. gibt es eine Beschreibung zu der QRCode Seite?
                                      EDIT: habe grade gesehen das meine tasmota temp 70°C hat, ist das normal oder beim Zusammenbau etwas nicht beachtet?
                                      Gruß Tom
                                      Gruß Tom
                                      Public Transport
                                      NSPanel Adapter Wiki
                                      • T TT-Tom
                                        @Armilar
                                        Gruß Tom
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #873
                                        @tt-tom sagte in Sonoff NSPanel:
                                        @Armilar
                                        Gruß Tom
                                        cardQR:
                                        https://forum.iobroker.net/post/808242
                                        Das eingebaute Thermometer taugt nicht die Bohne. Habe ein Panel mit ca. 60°C und eines um den Gefrierpunkt ;-) . Und das im gleichen Raum...
                                        Ich greife einfach einen Datenpunkt eines Raumsensors (in meinem Fall Zigbee) ab und visualisiere den.
                                        • ArmilarA Armilar
                                          @Armilar
                                          Gruß Tom
                                          cardQR:
                                          TT-Tom
                                          #874
                                          ich habe ja zwei punkte
                                          Gruß Tom
                                          Public Transport
                                          O ArmilarA 2 Antworten Letzte Antwort
