  4. Admin 6.0 - neu als Beta
352 Beiträge 54 Kommentatoren 92.7k Aufrufe 45 Beobachtet
  • ? Offline
    #203
    Would you like to upgrade iot from @1.11.7 to @1.11.8 now? [(y)es, (n)o]: Y
    Update iot from @1.11.7 to @1.11.8
    host.iobroker-1 Adapter "system.adapter.iot.0" is stopped.
    NPM version: 8.11.0
    Installing iobroker.iot@1.11.8... (System call)
    removed 19 packages, and changed 3 packages in 8s
    145 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.iot.0"
    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.6ab12a0e.chunk.css static/css/2.6ab12a0e.chunk.css text/css
    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.6ab12a0e.chunk.css.map static/css/2.6ab12a0e.chunk.css.map application/json
    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.36970f4f.chunk.js static/js/2.36970f4f.chunk.js application/javascript
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.36970f4f.chunk.js.LICENSE.txt static/js/2.36970f4f.chunk.js.LICENSE.txt text/plain
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.36970f4f.chunk.js.map static/js/2.36970f4f.chunk.js.map application/json
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.005db1c0.chunk.js static/js/main.005db1c0.chunk.js application/javascript
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.005db1c0.chunk.js.map static/js/main.005db1c0.chunk.js.map application/json
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.67121c15.js static/js/runtime-main.67121c15.js application/javascript
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.67121c15.js.map static/js/runtime-main.67121c15.js.map application/json
    host.iobroker-1 Adapter "system.adapter.iot.0" is started
    tobias@iobroker-1:/opt/iobroker$
      NPM version: 8.11.0
      #204
      @brainbug
      iobroker update -i
      • ? Offline
        #205
        In der UI gehen anscheinend keine Updates mehr, ich wollte heute Abend einen Adapter per Github Url updaten auch das ging nicht.
        tobias@iobroker-1:/opt/iobroker$ iobroker update -i
        Used repository: test1
        Adapter    "admin"        : 6.1.5    , installed 6.1.5
        Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "cameras"      : 0.1.8    , installed 0.1.8
        Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
        Adapter    "cloud"        : 4.1.2    , installed 4.1.2
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "fb-checkpresence": 1.1.17, installed 1.1.17
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.1.4    , installed 2.1.4
        Adapter    "ical"         : 1.13.0   , installed 1.13.0
        Adapter    "iot"          : 1.11.8   , installed 1.11.8
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "lg-thinq"     : 0.0.7    , installed 0.0.7
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mqtt"         : 4.0.6    , installed 4.0.6
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
        Adapter    "pushover"     : 2.1.0    , installed 2.1.0
        Adapter    "sayit"        : 1.12.6   , installed 1.12.6
        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 6.1.7    , installed 6.1.7
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "trashschedule": 2.0.3    , installed 2.0.3
        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "web"          : 5.2.3    , installed 5.2.3
        Adapter    "ws"           : 2.1.2    , installed 2.1.2
        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          GlasfaserG Offline
          GlasfaserG Offline
          #206
          @brainbug
          hast du mal ein
          sudo reboot
          mal gemacht , was ist dann !?
            #207
            @brainbug
            Kann ich bestätigen, CLI funktioniert, GUI klemmt.
            But who needs a GUI anyway??? :-)
            Mach ein Issue auf.
            • ? Offline
              #208
              Ja hatte probiert bevor ich mich hier gemeldet habe und dann habe ich die Sicherung von gestern zurückgespielt. Dann Admin 6.1.5 und ab da geht dann kein update im Browser.
              • crunchipC Offline
                crunchipC Offline
                #209
                @brainbug sagte in Admin 6.0 - neu als Beta:
                kann ich bestätigen, hab ebenfalls gerade den admin erfolgreich und dann den iot versucht
                  @brainbug
                  Mach ein Issue auf.
                  #210
                  @thomas-braun sagte in Admin 6.0 - neu als Beta:
                  @brainbug
                  Mach ein Issue auf.
                  Ich wäre dir dankbar wenn du es bitte machen könntest. Und danke für die Rückmeldung dass es nicht nur bei mir ist.
                    @brainbug
                    Mach ein Issue auf.
                    #211
                    Du bist doch der Beta-Tester mit dem Issue. Dann mach auch das entsprechende.
                      @brainbug
                      Mach ein Issue auf.
                      crunchipC Offline
                      crunchipC Offline
                      #212
                      @brainbug hab schon eins erstellt
                      • ? Offline
                        #213
                        Und sorry wenn ich nicht gleich alles Informationen geliefert habe die nötig waren. Ich war gerade etwas im Stress mit den vielen Antworten. Dazu noch Familien Stress ( Handy kaputt )...
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #214
                          @crunchip sagte in Admin 6.0 - neu als Beta:
                          Das hier ist das von crunchip angelegte issue: https://github.com/ioBroker/ioBroker.admin/issues/1557
                          • A Alfi84
                            @thomas-braun said in Admin 6.0 - neu als Beta:
                            iobroker update deconz --debug
                            pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
                            Used repository: deconz
                            Error: unknown repository is active - "deconz". Known: stable, latest
                            #215
                            @alfi84
                            Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
                            iob repo list
                            sagt?
                            [Edit:] Und ich habe Blödsinn geschrieben...
                            iobroker upgrade deconz --debug
                            muss das heißen.
                            A 2 Antworten Letzte Antwort
                            • ? Offline
                              #216
                              Bevor ich einen neuen Beitrag starte, nicht dass es einen Zusammenhang mit dem Admin gibt:
                              Ich bekomme in der vis diese Fehlermeldung, sehe aber sonst nichts im Log :(
                              Noch jemand das gleiche Problem mit dem aktuellen Admin?
                              FeuersturmF apollon77A 2 Antworten Letzte Antwort
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #217
                                Hi, du meinst den Vis Editor oder?
                                Ich habe Admin 6.1.5 und VIS 1.4.15 installiert und bekomme keine Fehlermeldung.
                                Das sind die Versionen der anderen Adapter. Ich weiß nicht ob hier der web, socketio oder ws Adapter noch eine Rolle spielen. Kannst ja mal die Versionen abgleichen.
                                proxmox@ioBrokerTestsystem:~$ iob list adapters
                                system.adapter.admin                   : admin          - v6.1.5
                                system.adapter.backitup                : backitup       - v2.4.9
                                system.adapter.benchmark               : benchmark      - v1.0.0
                                system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
                                system.adapter.daswetter               : daswetter      - v3.1.2
                                system.adapter.devices                 : devices        - v1.0.12
                                system.adapter.discovery               : discovery      - v3.0.5
                                system.adapter.dwd                     : dwd            - v2.8.3
                                system.adapter.fritzbox                : fritzbox       - v0.5.0
                                system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.4-0
                                system.adapter.history                 : history        - v2.1.4
                                system.adapter.hmip                    : hmip           - v1.15.4
                                system.adapter.hue                     : hue            - v3.7.0
                                system.adapter.ical                    : ical           - v1.13.0
                                system.adapter.icons-material-png      : icons-material-png - v0.1.0
                                system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                                system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                                system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                                system.adapter.influxdb                : influxdb       - v3.1.5
                                system.adapter.info                    : info           - v1.9.19
                                system.adapter.javascript              : javascript     - v5.7.0
                                system.adapter.mqtt                    : mqtt           - v4.0.6
                                system.adapter.nina                    : nina           - v0.0.25
                                system.adapter.owfs                    : owfs           - v0.7.0
                                system.adapter.proxmox                 : proxmox        - v1.3.4
                                system.adapter.radar                   : radar          - v1.1.3
                                system.adapter.rainbird                : rainbird       - v0.2.3
                                system.adapter.samsung-community       : samsung-community - v0.5.0
                                system.adapter.sayit                   : sayit          - v1.12.6
                                system.adapter.scenes                  : scenes         - v2.3.9
                                system.adapter.simple-api              : simple-api     - v2.7.0
                                system.adapter.smartmeter              : smartmeter     - v3.3.4
                                system.adapter.socketio                : socketio       - v6.1.7
                                system.adapter.spotify-premium         : spotify-premium - v1.2.2
                                system.adapter.sql                     : sql            - v2.1.3
                                system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                                system.adapter.telegram                : telegram       - v1.13.0
                                system.adapter.tr-064                  : tr-064         - v4.2.16
                                system.adapter.trashschedule           : trashschedule  - v2.0.3
                                system.adapter.unifi                   : unifi          - v0.6.1
                                system.adapter.valloxmv                : valloxmv       - v1.1.3
                                system.adapter.vis                     : vis            - v1.4.15
                                system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                                system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
                                system.adapter.vis-history             : vis-history    - v1.0.0
                                system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                                system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                                system.adapter.vis-map                 : vis-map        - v1.0.4
                                system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                                system.adapter.vis-metro               : vis-metro      - v1.2.0
                                system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                                system.adapter.web                     : web            - v5.2.3
                                system.adapter.web-speedy              : web-speedy     - v0.2.0
                                system.adapter.worx                    : worx           - v1.6.5
                                system.adapter.ws                      : ws             - v2.1.2
                                  #218
                                  @brainbug In die Browser Konsole schauen was da steht ... aber bitte eigenes Issue!
                                  • apollon77A apollon77
                                    arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #219
                                    • arteckA arteck
                                      #220
                                      @arteck Packs ins Issue bitte im GitHub
                                      • FeuersturmF Feuersturm
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        #221
                                        @feuersturm sagte in Admin 6.0 - neu als Beta:
                                        Mit der neuen Admin Version 6.1.6 wurde das issue gefixt und man kann wieder Adapter über die GUI aktualisieren.
                                        Admin Update auf 6.1.6 hab ich über die Konsole durchgeführt.
                                          Snigga
                                          #222
                                          Habt ihr auch das Problem, wenn Ihr mit der Version 6.1.6 mehrere Adapter auf einmal updaten möchtest, dass euer Browser abschmiert? Einzel Update funktioniert ja jetzt wieder.
                                          ChaotC FeuersturmF apollon77A 4 Antworten Letzte Antwort
