  4. Admin 6.0 - neu als Beta
352 Beiträge 54 Kommentatoren 92.7k Aufrufe 45 Beobachtet
    In der UI gehen anscheinend keine Updates mehr, ich wollte heute Abend einen Adapter per Github Url updaten auch das ging nicht.
    tobias@iobroker-1:/opt/iobroker$ iobroker update -i
    Used repository: test1
    Adapter    "admin"        : 6.1.5    , installed 6.1.5
    Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "cameras"      : 0.1.8    , installed 0.1.8
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "cloud"        : 4.1.2    , installed 4.1.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "fb-checkpresence": 1.1.17, installed 1.1.17
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.1.4    , installed 2.1.4
    Adapter    "ical"         : 1.13.0   , installed 1.13.0
    Adapter    "iot"          : 1.11.8   , installed 1.11.8
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lg-thinq"     : 0.0.7    , installed 0.0.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mqtt"         : 4.0.6    , installed 4.0.6
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "sayit"        : 1.12.6   , installed 1.12.6
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 6.1.7    , installed 6.1.7
    Adapter    "telegram"     : 1.13.0   , installed 1.13.0
    Adapter    "text2command" : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    Adapter    "web"          : 5.2.3    , installed 5.2.3
    Adapter    "ws"           : 2.1.2    , installed 2.1.2
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    #207
    @brainbug
    Kann ich bestätigen, CLI funktioniert, GUI klemmt.
    But who needs a GUI anyway??? :-)
    Mach ein Issue auf.
    • ? Offline
      #208
      Ja hatte probiert bevor ich mich hier gemeldet habe und dann habe ich die Sicherung von gestern zurückgespielt. Dann Admin 6.1.5 und ab da geht dann kein update im Browser.
      • crunchipC Offline
        crunchipC Offline
        #209
        @brainbug sagte in Admin 6.0 - neu als Beta:
        kann ich bestätigen, hab ebenfalls gerade den admin erfolgreich und dann den iot versucht
          @brainbug
          Mach ein Issue auf.
          #210
          @thomas-braun sagte in Admin 6.0 - neu als Beta:
          @brainbug
          Mach ein Issue auf.
          Ich wäre dir dankbar wenn du es bitte machen könntest. Und danke für die Rückmeldung dass es nicht nur bei mir ist.
            @brainbug
            Mach ein Issue auf.
            #211
            Du bist doch der Beta-Tester mit dem Issue. Dann mach auch das entsprechende.
              @brainbug
              Mach ein Issue auf.
              crunchipC Offline
              crunchipC Offline
              #212
              @brainbug hab schon eins erstellt
              • ? Offline
                #213
                Und sorry wenn ich nicht gleich alles Informationen geliefert habe die nötig waren. Ich war gerade etwas im Stress mit den vielen Antworten. Dazu noch Familien Stress ( Handy kaputt )...
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  #214
                  @crunchip sagte in Admin 6.0 - neu als Beta:
                  Das hier ist das von crunchip angelegte issue: https://github.com/ioBroker/ioBroker.admin/issues/1557
                  • A Alfi84
                    @thomas-braun said in Admin 6.0 - neu als Beta:
                    iobroker update deconz --debug
                    pi@raspberrypi4-iob:/opt/iobroker $ iobroker update deconz --debug
                    Used repository: deconz
                    Error: unknown repository is active - "deconz". Known: stable, latest
                    #215
                    @alfi84
                    Du hast dir das (warum auch immer) ein Repository namens 'deconz' angelegt.
                    iob repo list
                    sagt?
                    [Edit:] Und ich habe Blödsinn geschrieben...
                    iobroker upgrade deconz --debug
                    muss das heißen.
                    A 2 Antworten Letzte Antwort
                    • ? Offline
                      #216
                      Bevor ich einen neuen Beitrag starte, nicht dass es einen Zusammenhang mit dem Admin gibt:
                      Ich bekomme in der vis diese Fehlermeldung, sehe aber sonst nichts im Log :(
                      Noch jemand das gleiche Problem mit dem aktuellen Admin?
                      FeuersturmF apollon77A 2 Antworten Letzte Antwort
                        FeuersturmF Offline
                        FeuersturmF Offline
                        Feuersturm
                        #217
                        Hi, du meinst den Vis Editor oder?
                        Ich habe Admin 6.1.5 und VIS 1.4.15 installiert und bekomme keine Fehlermeldung.
                        Das sind die Versionen der anderen Adapter. Ich weiß nicht ob hier der web, socketio oder ws Adapter noch eine Rolle spielen. Kannst ja mal die Versionen abgleichen.
                        proxmox@ioBrokerTestsystem:~$ iob list adapters
                        system.adapter.admin                   : admin          - v6.1.5
                        system.adapter.backitup                : backitup       - v2.4.9
                        system.adapter.benchmark               : benchmark      - v1.0.0
                        system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
                        system.adapter.daswetter               : daswetter      - v3.1.2
                        system.adapter.devices                 : devices        - v1.0.12
                        system.adapter.discovery               : discovery      - v3.0.5
                        system.adapter.dwd                     : dwd            - v2.8.3
                        system.adapter.fritzbox                : fritzbox       - v0.5.0
                        system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.4-0
                        system.adapter.history                 : history        - v2.1.4
                        system.adapter.hmip                    : hmip           - v1.15.4
                        system.adapter.hue                     : hue            - v3.7.0
                        system.adapter.ical                    : ical           - v1.13.0
                        system.adapter.icons-material-png      : icons-material-png - v0.1.0
                        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
                        system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                        system.adapter.influxdb                : influxdb       - v3.1.5
                        system.adapter.info                    : info           - v1.9.19
                        system.adapter.javascript              : javascript     - v5.7.0
                        system.adapter.mqtt                    : mqtt           - v4.0.6
                        system.adapter.nina                    : nina           - v0.0.25
                        system.adapter.owfs                    : owfs           - v0.7.0
                        system.adapter.proxmox                 : proxmox        - v1.3.4
                        system.adapter.radar                   : radar          - v1.1.3
                        system.adapter.rainbird                : rainbird       - v0.2.3
                        system.adapter.samsung-community       : samsung-community - v0.5.0
                        system.adapter.sayit                   : sayit          - v1.12.6
                        system.adapter.scenes                  : scenes         - v2.3.9
                        system.adapter.simple-api              : simple-api     - v2.7.0
                        system.adapter.smartmeter              : smartmeter     - v3.3.4
                        system.adapter.socketio                : socketio       - v6.1.7
                        system.adapter.spotify-premium         : spotify-premium - v1.2.2
                        system.adapter.sql                     : sql            - v2.1.3
                        system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
                        system.adapter.telegram                : telegram       - v1.13.0
                        system.adapter.tr-064                  : tr-064         - v4.2.16
                        system.adapter.trashschedule           : trashschedule  - v2.0.3
                        system.adapter.unifi                   : unifi          - v0.6.1
                        system.adapter.valloxmv                : valloxmv       - v1.1.3
                        system.adapter.vis                     : vis            - v1.4.15
                        system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                        system.adapter.vis-google-fonts        : vis-google-fonts - v1.0.3
                        system.adapter.vis-history             : vis-history    - v1.0.0
                        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                        system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                        system.adapter.vis-map                 : vis-map        - v1.0.4
                        system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                        system.adapter.vis-metro               : vis-metro      - v1.2.0
                        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                        system.adapter.web                     : web            - v5.2.3
                        system.adapter.web-speedy              : web-speedy     - v0.2.0
                        system.adapter.worx                    : worx           - v1.6.5
                        system.adapter.ws                      : ws             - v2.1.2
                          #218
                          @brainbug In die Browser Konsole schauen was da steht ... aber bitte eigenes Issue!
                          • apollon77A apollon77
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #219
                            • arteckA arteck
                              #220
                              @arteck Packs ins Issue bitte im GitHub
                              • FeuersturmF Feuersturm
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #221
                                @feuersturm sagte in Admin 6.0 - neu als Beta:
                                Mit der neuen Admin Version 6.1.6 wurde das issue gefixt und man kann wieder Adapter über die GUI aktualisieren.
                                Admin Update auf 6.1.6 hab ich über die Konsole durchgeführt.
                                  Snigga
                                  #222
                                  Habt ihr auch das Problem, wenn Ihr mit der Version 6.1.6 mehrere Adapter auf einmal updaten möchtest, dass euer Browser abschmiert? Einzel Update funktioniert ja jetzt wieder.
                                  ChaotC FeuersturmF apollon77A 4 Antworten Letzte Antwort
                                  • S Snigga
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #223
                                    @snigga Ja, gerade bei mir auch passiert
                                    • S Snigga
                                      FeuersturmF Offline
                                      FeuersturmF Offline
                                      Feuersturm
                                      #224
                                      @snigga bitte ein issue anlegen mit entsprechenden log aus der Browser Konsole :-)
                                        Snigga
                                        #225
                                        @feuersturm said in Admin 6.0 - neu als Beta:
                                        Mist jetzt bin ich schon wieder up to date. Wenn ich wieder ein paar Updates habe werde ich es melden.
                                        • S Snigga
                                          FeuersturmF Offline
                                          FeuersturmF Offline
                                          Feuersturm
                                          #226
                                          @snigga Du kannst doch einfach über den Expertenmodus 2-3 Adapter downgraden und dann kannst du das Verhalten reproduzieren.
