  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.7k Aufrufe 16 Beobachtet
    Ich hatte ebenfalls dieses Problem jedoch keine Fehlermeldung.
    Ich habe die packet-lock.json gelöscht und nach zweimaligem npm prune konnte ich den modbus Adapter updaten.
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    Hab brav eure Tipps hier befolgt, leider hängt bei mir npm prune bei adaptern die direkt von github installiert sind. Jemand eine Idee wie ich das lösen kann?
    npm info using npm@8.11.0
    npm info using node@v16.15.1
    npm timing npm:load:whichnode Completed in 0ms
    npm timing config:load:defaults Completed in 1ms
    npm timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
    npm timing config:load:builtin Completed in 1ms
    npm timing config:load:cli Completed in 1ms
    npm timing config:load:env Completed in 1ms
    npm timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
    npm timing config:load:project Completed in 3ms
    npm timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
    npm timing config:load:user Completed in 0ms
    npm timing config:load:file:/usr/etc/npmrc Completed in 0ms
    npm timing config:load:global Completed in 1ms
    npm timing config:load:validate Completed in 0ms
    npm timing config:load:credentials Completed in 0ms
    npm timing config:load:setEnvs Completed in 1ms
    npm timing config:load Completed in 9ms
    npm timing npm:load:configload Completed in 9ms
    npm timing npm:load:mkdirpcache Completed in 3ms
    npm timing npm:load:mkdirplogs Completed in 0ms
    npm timing npm:load:setTitle Completed in 1ms
    npm timing config:load:flatten Completed in 1ms
    npm timing npm:load:display Completed in 5ms
    npm timing npm:load:logFile Completed in 4ms
    npm timing npm:load:timers Completed in 0ms
    npm timing npm:load:configScope Completed in 1ms
    npm timing npm:load Completed in 23ms
    npm timing arborist:ctor Completed in 0ms
    npm timing idealTree:init Completed in 875ms
    npm timing idealTree:userRequests Completed in 0ms
    npm http fetch GET 200 https://codeload.github.com/foxthefox/ioBroker.musiccast/tar.gz/9320d5a2ccc584c280c56a51a1846c355c25a669 345ms (cache revalidated)
    npm http fetch GET 200 https://codeload.github.com/Scrounger/ioBroker.slideshow/tar.gz/21eebd86e31602b53d9ba90183d514994d28d51d 226ms (cache revalidated)
    [..................] / idealTree:iobroker: http fetch GET 200 https://codeload.github.com/Scrounger/ioBroker.slideshow/tar.gz/21eebd86e31602b53d9ba90183d514994d28d51d
    • ScroungerS Scrounger
      @scrounger sagte in Kein Update mehr möglich mit Node.js 16:
      musiccast
      slideshow
      Die gibt es ja beide im Beta-Zweig. Ich würde die vielleicht zunächst mal dort auf's Gleis setzen und dann wenn das alles lüppt bei Bedarf wieder aus dem git angeln.
      • ScroungerS Offline
        ScroungerS Offline
        Scrounger
        habs deinstalliert und versucht aus beta zu installieren, geht leider nicht:
        @ioBroker:/opt/iobroker# iobroker install iobroker.slideshow
        NPM version: 8.11.0
        Installing iobroker.slideshow@0.1.4... (System call)
        host.ioBroker Cannot install iobroker.slideshow@0.1.4: 217
        • Thomas BraunT Online
          @scrounger
          Macht man ja auch nicht als root.
          ScroungerS 1 Antwort Letzte Antwort
            @scrounger
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            Find ich gut das du darauf immer hinweist, ist aber ein proxmox lxc.
            Hab jetzt den Adapter gelöscht inkl. Verzeichnis und jetzt lief npm prune durch, warum auch immer...
            Updates klappen jetzt wieder 👍
              Und das soll jetzt genau was begründen?
              Auch da kann man mit usern arbeiten.
                Meister MopperM Offline
                Meister Mopper
                Da bin ich auch mit einem normalen user unterwegs. Das geht schon.
                Proxmox und HA ...
                • O Offline
                  O Offline
                  oxident
                  Also bei mir bringt das npm prune leider nicht den gewünschten Erfolg:
                  user@iobroker:/opt/iobroker$ node -v
                  v16.15.1
                  user@iobroker:/opt/iobroker$ npm -v
                  8.11.0
                  user@iobroker:/opt/iobroker$ npm prune
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder
                  npm ERR! dest /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/.xmlbuilder-UsIYEbox
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder' -> '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/.xmlbuilder-UsIYEbox'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T14_39_45_795Z-debug-0.log
                  Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                  • O oxident
                    v16.15.1
                    8.11.0
                    npm ERR! errno -39
                    Meister Mopper
                    @oxident
                    Hast Du es auch zweimal versucht?
                    Proxmox und HA ...
                    O 1 Antwort Letzte Antwort
                    • O oxident
                      v16.15.1
                      8.11.0
                      npm ERR! errno -39
                      @oxident sagte in Kein Update mehr möglich mit Node.js 16:
                      Mach das doch mal.
                        @oxident
                        O Offline
                        O Offline
                        oxident
                        @meister-mopper Jepp, gleiche Meldung.
                        @thomas-braun Da habe ich noch etwas Bammel vor. Dann wohl iobroker vorher stoppen, oder?
                        • O oxident
                          Ist keine doofe Idee. Zumindest den Adapter dazu würde ich stoppen.
                            lobomauL Offline
                            lobomauL Offline
                            lobomau
                            schrieb am zuletzt editiert von lobomau
                            Bei mir ist auch eine Datei, die ich umbenennen soll.
                            root@ioBrokerCT:/opt/iobroker# npm prune
                            npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                            npm ERR! dest /opt/iobroker/node_modules/.iobroker.esphome-tdyaRFqJ
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.esphome' -> '/opt/iobroker/node_modules/.iobroker.esphome-tdyaRFqJ'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T17_21_28_426Z-debug-0.log
                            npm ERR! errno -39
                            Hab ich gemacht. Nun soll die nächste umbenannt werden:
                            npm ERR! path /opt/iobroker/node_modules/syno
                            npm ERR! dest /opt/iobroker/node_modules/.syno-xocGQcRi
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/syno' -> '/opt/iobroker/node_modules/.syno-xocGQcRi'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T17_38_35_578Z-debug-0.log
                            Wo landen Datein, wenn man einen Punkt davor setzt? Im Home-Verzeichnis?
                            Edit.: da kommt jedes Mal eine neue Datei. Da bin ich morgen nicht fertig mit. Entweder gehe ich auf npm 6 oder node 14 zurück. Node 16 habe ich nun über 2 Wochen gut am Laufen. Nur keine Updates oder Downgrades mehr möglich :-(
                            Host: NUC8i3 mit Proxmox:
                            • Slave: Pi4
                            Thomas BraunT O 2 Antworten Letzte Antwort
                            • lobomauL lobomau
                              npm ERR! errno -39
                              npm ERR! errno -39
                              npm ERR! errno -39
                              @lobomau sagte in Kein Update mehr möglich mit Node.js 16:
                              Die bleiben im Pfad stehen, werden aber 'versteckt' und nur mit besonderen Optionen wieder angezeigt. Übrigens bist du gerade dabei dir die Rechte an den Verzeichnissen zu zerballern. root login... Lasst den MIST sein!
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                @thomas-braun ja, ich fahre ein Backup rein. Wer weiß was das Ändern der Dateien für einen Einfluss hat.
                                • Slave: Pi4
                                • lobomauL lobomau
                                  Mit root-Rechten? Das hat den Einfluss, dass andere user da nicht mehr drauf zugreifen dürfen.
                                  • lobomauL lobomau
                                    npm ERR! errno -39
                                    npm ERR! errno -39
                                    npm ERR! errno -39
                                    O Offline
                                    O Offline
                                    oxident
                                    @lobomau Danke fürs Testen. Hatte auch befürchtet, dass jedes Mal neue Verzeichnisse kommen... Werde wohl auch wieder downgraden.
                                    • O oxident
                                      Irgendwann wirst du auf höhere nodejs-Versionen wechseln müssen, weil Adpater diese vorraussetzen werden. Du sitzt die Thematik also nur aus, das Thema wird sich aber nicht 'von alleine' lösen.
                                      Alternative könnte sein: Backup per Backitup ziehen, iobroker komplett neuinstallieren (inkl. node16), Backup einspielen.
                                      Könnte evtl. auch funktionieren.
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        @thomas-braun ok, ich mache mal ein neues System. Ist debian 11.3 irgendwie sicherer geworden?
                                        Ich muss jedes Mal mein Passwort vergeben. Unter root wäre mir das nicht passiert ;-)
                                        Changing npm registry to https://registry.npmjs.org
                                        [sudo] password for lobomau:
                                        Installed acl
                                        Installed build-essential
                                        Installed gcc-c++
                                        Installed make
                                        Installed libavahi-compat-libdnssd-dev
                                        Installed libudev-dev
                                        Installed libpam0g-dev
                                        Installed pkg-config
                                        Installed git
                                        Installed unzip
                                        Installed libcairo2-dev
                                        Installed libpango1.0-dev
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          Installed acl
                                          Installed gcc-c++
                                          Installed make
                                          Installed git
                                          Installed unzip
                                          Da ich nicht sehe was du da genau treibst:
                                          Vermutlich hast du dir das nachhaltig durch das herumgerutsche als root versaubeutelt.
