  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.7k Aufrufe 16 Beobachtet
  • ChaotC Chaot
    @thomas-braun sagte in Kein Update mehr möglich mit Node.js 16:
    npm prune
    So, in Verbindung mit dem Löschen der Datei package-lock.json und dem Befehl npm prune kam jetzt folgendes:
    haus@ioBroker:/opt/iobroker$ npm prune
    npm WARN ERESOLVE overriding peer dependency
    npm WARN While resolving: svg-inline-react@1.0.3
    npm WARN Found: react@17.0.2
    npm WARN node_modules/react
    npm WARN   peer react@">=16.6.0" from react-transition-group@4.4.2
    npm WARN   node_modules/react-transition-group
    npm WARN     react-transition-group@"^4.0.0" from @material-ui/pickers@3.3.10
    npm WARN     node_modules/@material-ui/pickers
    npm WARN     1 more (@material-ui/core)
    npm WARN   7 more (rifm, @material-ui/pickers, @material-ui/core, ...)
    npm WARN
    npm WARN Could not resolve dependency:
    npm WARN peer react@"^0.14.0 || ^15.0.0" from svg-inline-react@1.0.3
    npm WARN node_modules/svg-inline-react
    npm WARN   svg-inline-react@"^1.0.2" from anyproxy@4.1.0
    npm WARN   node_modules/anyproxy
    npm WARN
    npm WARN Conflicting peer dependency: react@15.7.0
    npm WARN skipping integrity check for git dependency ssh://git@github.com/xXBJXx/ioBroker.wallpanel.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/foxthefox/ioBroker.fritzdect.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/BenAhrdt/ioBroker.drag-indicator.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/nVuln/homebridge-lg-thinq.git
    added 28 packages, removed 700 packages, and changed 12 packages in 2m
    151 packages are looking for funding
      run `npm fund` for details
    haus@ioBroker:/opt/iobroker$ npm ls | grep ERR
    Alle Adapter laufen und es scheint kein weiterer Fehler aufzutauchen. Ich hoffe mal das System jetzt halbwegs grade gezogen ist.
    @chaot sagte in Kein Update mehr möglich mit Node.js 16:
    Sind Aktionen mit Adaptern möglich? Neuinstallationen?
      ChaotC Offline
      ChaotC Offline
      Chaot
      @thomas-braun Neuinstallationen habe ich noch nicht probiert, aber Admin Adapter und MQTT Adapter haben gerade ein Update bekommen das problemlos durchgelaufen ist.
      • O Offline
        O Offline
        oxident
        Selbes Problem bei mir, jedoch ohne Fehler/Warnungen. Versuche jetzt auch mal, die package-lock.json zu löschen und dann npm prune laufen zu lassen.
        • O oxident
          Meister MopperM Offline
          Meister Mopper
          Ich hatte ebenfalls dieses Problem jedoch keine Fehlermeldung.
          Ich habe die packet-lock.json gelöscht und nach zweimaligem npm prune konnte ich den modbus Adapter updaten.
          Proxmox und HA ...
          ScroungerS 1 Antwort Letzte Antwort
            ScroungerS Offline
            ScroungerS Offline
            Scrounger
            Hab brav eure Tipps hier befolgt, leider hängt bei mir npm prune bei adaptern die direkt von github installiert sind. Jemand eine Idee wie ich das lösen kann?
            npm info using npm@8.11.0
            npm info using node@v16.15.1
            npm timing npm:load:whichnode Completed in 0ms
            npm timing config:load:defaults Completed in 1ms
            npm timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 1ms
            npm timing config:load:builtin Completed in 1ms
            npm timing config:load:cli Completed in 1ms
            npm timing config:load:env Completed in 1ms
            npm timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
            npm timing config:load:project Completed in 3ms
            npm timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
            npm timing config:load:user Completed in 0ms
            npm timing config:load:file:/usr/etc/npmrc Completed in 0ms
            npm timing config:load:global Completed in 1ms
            npm timing config:load:validate Completed in 0ms
            npm timing config:load:credentials Completed in 0ms
            npm timing config:load:setEnvs Completed in 1ms
            npm timing config:load Completed in 9ms
            npm timing npm:load:configload Completed in 9ms
            npm timing npm:load:mkdirpcache Completed in 3ms
            npm timing npm:load:mkdirplogs Completed in 0ms
            npm timing npm:load:setTitle Completed in 1ms
            npm timing config:load:flatten Completed in 1ms
            npm timing npm:load:display Completed in 5ms
            npm timing npm:load:logFile Completed in 4ms
            npm timing npm:load:timers Completed in 0ms
            npm timing npm:load:configScope Completed in 1ms
            npm timing npm:load Completed in 23ms
            npm timing arborist:ctor Completed in 0ms
            npm timing idealTree:init Completed in 875ms
            npm timing idealTree:userRequests Completed in 0ms
            npm http fetch GET 200 https://codeload.github.com/foxthefox/ioBroker.musiccast/tar.gz/9320d5a2ccc584c280c56a51a1846c355c25a669 345ms (cache revalidated)
            npm http fetch GET 200 https://codeload.github.com/Scrounger/ioBroker.slideshow/tar.gz/21eebd86e31602b53d9ba90183d514994d28d51d 226ms (cache revalidated)
            [..................] / idealTree:iobroker: http fetch GET 200 https://codeload.github.com/Scrounger/ioBroker.slideshow/tar.gz/21eebd86e31602b53d9ba90183d514994d28d51d
            • ScroungerS Scrounger
              @scrounger sagte in Kein Update mehr möglich mit Node.js 16:
              musiccast
              slideshow
              Die gibt es ja beide im Beta-Zweig. Ich würde die vielleicht zunächst mal dort auf's Gleis setzen und dann wenn das alles lüppt bei Bedarf wieder aus dem git angeln.
              • ScroungerS Offline
                ScroungerS Offline
                Scrounger
                habs deinstalliert und versucht aus beta zu installieren, geht leider nicht:
                @ioBroker:/opt/iobroker# iobroker install iobroker.slideshow
                NPM version: 8.11.0
                Installing iobroker.slideshow@0.1.4... (System call)
                host.ioBroker Cannot install iobroker.slideshow@0.1.4: 217
                • Thomas BraunT Online
                  @scrounger
                  Macht man ja auch nicht als root.
                    @scrounger
                    ScroungerS Offline
                    ScroungerS Offline
                    Scrounger
                    Find ich gut das du darauf immer hinweist, ist aber ein proxmox lxc.
                    Hab jetzt den Adapter gelöscht inkl. Verzeichnis und jetzt lief npm prune durch, warum auch immer...
                    Updates klappen jetzt wieder 👍
                      Und das soll jetzt genau was begründen?
                      Auch da kann man mit usern arbeiten.
                        Meister Mopper
                        Da bin ich auch mit einem normalen user unterwegs. Das geht schon.
                        Proxmox und HA ...
                        • O Offline
                          O Offline
                          oxident
                          Also bei mir bringt das npm prune leider nicht den gewünschten Erfolg:
                          user@iobroker:/opt/iobroker$ node -v
                          v16.15.1
                          user@iobroker:/opt/iobroker$ npm -v
                          8.11.0
                          user@iobroker:/opt/iobroker$ npm prune
                          npm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder
                          npm ERR! dest /opt/iobroker/node_modules/homematic-xmlrpc/node_modules/.xmlbuilder-UsIYEbox
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder' -> '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/.xmlbuilder-UsIYEbox'
                          npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T14_39_45_795Z-debug-0.log
                          Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                          • O oxident
                            v16.15.1
                            8.11.0
                            npm ERR! errno -39
                            Meister Mopper
                            @oxident
                            Hast Du es auch zweimal versucht?
                            Proxmox und HA ...
                            O 1 Antwort Letzte Antwort
                            • O oxident
                              v16.15.1
                              8.11.0
                              npm ERR! errno -39
                              @oxident sagte in Kein Update mehr möglich mit Node.js 16:
                              Mach das doch mal.
                                @oxident
                                O Offline
                                O Offline
                                oxident
                                @meister-mopper Jepp, gleiche Meldung.
                                @thomas-braun Da habe ich noch etwas Bammel vor. Dann wohl iobroker vorher stoppen, oder?
                                • O oxident
                                  Ist keine doofe Idee. Zumindest den Adapter dazu würde ich stoppen.
                                    lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    schrieb am zuletzt editiert von lobomau
                                    Bei mir ist auch eine Datei, die ich umbenennen soll.
                                    root@ioBrokerCT:/opt/iobroker# npm prune
                                    npm ERR! path /opt/iobroker/node_modules/iobroker.esphome
                                    npm ERR! dest /opt/iobroker/node_modules/.iobroker.esphome-tdyaRFqJ
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.esphome' -> '/opt/iobroker/node_modules/.iobroker.esphome-tdyaRFqJ'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T17_21_28_426Z-debug-0.log
                                    npm ERR! errno -39
                                    Hab ich gemacht. Nun soll die nächste umbenannt werden:
                                    npm ERR! path /opt/iobroker/node_modules/syno
                                    npm ERR! dest /opt/iobroker/node_modules/.syno-xocGQcRi
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/syno' -> '/opt/iobroker/node_modules/.syno-xocGQcRi'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-06-20T17_38_35_578Z-debug-0.log
                                    Wo landen Datein, wenn man einen Punkt davor setzt? Im Home-Verzeichnis?
                                    Edit.: da kommt jedes Mal eine neue Datei. Da bin ich morgen nicht fertig mit. Entweder gehe ich auf npm 6 oder node 14 zurück. Node 16 habe ich nun über 2 Wochen gut am Laufen. Nur keine Updates oder Downgrades mehr möglich :-(
                                    Host: NUC8i3 mit Proxmox:
                                    • Slave: Pi4
                                    Thomas BraunT O 2 Antworten Letzte Antwort
                                    • lobomauL lobomau
                                      npm ERR! errno -39
                                      npm ERR! errno -39
                                      npm ERR! errno -39
                                      @lobomau sagte in Kein Update mehr möglich mit Node.js 16:
                                      Die bleiben im Pfad stehen, werden aber 'versteckt' und nur mit besonderen Optionen wieder angezeigt. Übrigens bist du gerade dabei dir die Rechte an den Verzeichnissen zu zerballern. root login... Lasst den MIST sein!
                                        lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        @thomas-braun ja, ich fahre ein Backup rein. Wer weiß was das Ändern der Dateien für einen Einfluss hat.
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          Mit root-Rechten? Das hat den Einfluss, dass andere user da nicht mehr drauf zugreifen dürfen.
