  4. [Neuer Adapter] Life360
    6.4k
adapterlife360geopositionpräsenzmelder
708 Beiträge 85 Kommentatoren 273.9k Aufrufe 70 Beobachtet
  • BananaJoeB BananaJoe
    @fuxsism ständig oder nur zwischendurch mal? Letzteres ist - leider - normal.
    Fuxsism
    #358
    @bananajoe
    schwer zu sagen... also weniger oft als ständig aber öfters als zwischendurch :-)
    So ca. alle halbe stunde...
    BananaJoeB MiGollerM 2 Antworten Letzte Antwort
    • F Fuxsism
      @bananajoe
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      #359
      @fuxsism ich meine das sieht bei mir nicht anders aus.
      Ok, ich habe mal nachgesehen:
      2022-03-08 02:33:26.755  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 03:09:26.764  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 03:57:27.231  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 06:01:31.150  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 06:05:41.145  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 09:09:26.993  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 09:37:27.027  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 10:05:27.389  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 11:01:27.080  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 13:17:27.081  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 19:41:27.456  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      2022-03-08 20:25:27.459  - error: life360.0 (2734657) Connection established but failed to authenticate. Check your credentials!
      Mal öfter hintereinander, mal eine Weile nichts
      • F Fuxsism
        @bananajoe
        MiGollerM Offline
        MiGollerM Offline
        MiGoller
        #360
        @fuxsism Ja, teilweise lässt die API es temporär eine Anmeldung bzw. Erneuerung der Anmeldesession nicht zu. Der Adapter versucht schon, Verbindungsfehler abzufangen, aber Anmeldefehler zeigt er als Fehler an. Das könnte ich mal in eine Warnung ändern, bis z.B. die Anmeldung 3x nacheinander, also direkt nacheinander, nicht funktioniert hat.
        Allerdings muss ich auch gestehen, dass es mit der API nicht besser wird. Ich hatte das mal zufällig überprüft: Wenn der Adapter den Fehler wirft, dann kann ich auch in der App praktisch nicht eine andere Person orten oder Standorte aktualisieren.
        Wäre schön, wenn die API etwas stabiler werden würde. Nur da mache ich mir so gar keine Hoffnungen; ich bin schon froh, dass ich als Open-Source Entwickler noch nicht abgemahnt worden bin, da der Adapter auf eine nicht offengelegte API zugreifen muss, um die Aufgabe zu erfüllen.
        ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
        • U Offline
          U Offline
          UncleB
          #361
          Mahlzeit zusammen.
          Hat jetz weniger mit dem Adapter zu tun, liegt wohl mehr an der App oder am Handy aber Life360 aktualisiert meinen Standort nicht, hab der App alle Berechtigungen erlaubt. Aber es tut sich nix..
          Kann es sein das ich das einzigste Mitglied bin?
          Hab nur einen Kreis und ich bin das einzigste Mitglied, oder hat jemand sonst noch ne Idee?
          MiGollerM 1 Antwort Letzte Antwort
          • U UncleB
            Mahlzeit zusammen.
            MiGollerM Offline
            MiGollerM Offline
            MiGoller
            #362
            @uncleb Hey, sorry, dass ich Dir erst jetzt antworten kann. Nur um einem Missverständnis vorzubeugen: Meinst Du, dass der Life360 (-Adapter) den Standort nicht aktualisiert? In meinen Tests war das auch mit einem einzigen Mitglied in einem Kreis möglich.
            Prüfe mal bitte, dass Du in den Life360-Adaptereinstellungen Deiner Instanz unter "Integration" auch die "Standortverfolgung" aktiviert hast. Nur bei aktivierter Standortverfolgung meldet der Adapter die Geolokation der Mitglieder als Koordinaten; andernfalls werden die Standorte nur in Bezug auf die Kreise ausgewertet, aber nicht als Datenpunkt festgehalten.
            • MiGollerM MiGoller
              K_o_bold
              #363
              Bin ich momentan der einzige mit Problemen ?
              Adapter ist gelb und schießt im Sekundentakt errors
              Palm_ManiacP 1 Antwort Letzte Antwort
              • K K_o_bold
                Palm_ManiacP Offline
                Palm_Maniac
                schrieb am zuletzt editiert von Palm_Maniac
                #364
                @k_o_bold Nein, bei mir seit heute auch so. Hab den Adapter erstmal abgeschaltet, da er mir das Log zuspammt. Los ging es, ich meine es zumindest, erst nach den ganzen Adapter-Updates, unter anderem auf Admin V6.0.1
                K G 2 Antworten Letzte Antwort
                • Palm_ManiacP Palm_Maniac
                  K_o_bold
                  #365
                  @palm_maniac ,
                  Ok. Ich habe nichts verändert. Scheint wohl ein Problem bei Life360 zu sein
                    guergen
                    #366
                    @palm_maniac Ich bin noch nicht bei Admin V6, geht dennoch nicht
                    • Palm_ManiacP Offline
                      Palm_Maniac
                      #367
                      Ok, dann hat es doch nix mit den Updates zu tun und ich brauche nicht rum zu testen. Danke für die Info. :)
                        tomtaz
                        #368
                        Nein, bin leider auch betroffen. die Life360 Website selbst ist erreichbar, erhalte allerdings auch Zig Einträge seit etwa 15:40 die folgenden Log-Einträge:
                        2022-06-08 15:40:00.017  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:00.359  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:00.694  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:01.039  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:01.375  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:01.730  - error: life360.0 (21011) Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:01.736  - error: life360.0 (21011) Failed to connect or to login for 6 times. Aborting ...
                        2022-06-08 15:40:01.740  - error: life360.0 (21011) Error: Error: Connection established but failed to authenticate. Check your credentials!
                        2022-06-08 15:40:01.742  - warn: life360.0 (21011) No data received from Life360 cloud services!
                        Verändert wurde nichts. Ich werd den Adapter mal abschalten um das Log klein zu halten :-)
                        • T tomtaz
                          MiGollerM Offline
                          MiGollerM Offline
                          MiGoller
                          #369
                          Hallo zusammen. Sieht so aus, als würden alle Anmeldung an der Life360 API in der Art und Weise, wie der Adapter diese verarbeitet, fehlschlagen. Ich kann das Verhalten auch mit Kommandozeilen-Tools nachstellen.
                          Ich bitte um Geduld, da ich erst herausfinden muss, was sich an der API geändert hat. Es tut mir leid, aber abhängig von den Änderungen, die Life360 vorgenommen haben könnte, könnte es ein wenig dauern, bis der Adapter wieder funktioniert. Bis dahin müssen wir wohl leider auf die Funktionalität verzichten.
                          Auf Github wird der Fehler als Issue #59 geführt: https://github.com/MiGoller/ioBroker.life360/issues/59
                            MiGollerM Offline
                            MiGollerM Offline
                            MiGoller
                            #370
                            Jetzt kann ich mich auch in der Mobile App auf meinem Smartphone nicht mehr anmelden: Benutzername oder Kennwort seien falsch; sind sie nicht, aber ok. Der Versuch, das Kennwort zurückzusetzen, scheitert allerdings mit einem Fehler 503 Service unavailable.
                            Habt Ihr das auch, oder habe ich grad meinen Account zerschossen?
                            T C 2 Antworten Letzte Antwort
                              tomtaz
                              #371
                              @migoller Hatte ich tatsächlich gestern auch. Als ich mir dann ein neues passwort angelegt habe, hat er zwar sehr lange gebraucht mich in der Mobile App anzumelden. Aber nach 2 Minuten war ich dann angemeldet.
                                chemieka
                                #372
                                @migoller
                                Hatte auch mal zum Test mein Passwort zurückgesetzt. Im App läuft alles normal. Der Adapter läuft leider nicht. Hoffe du kannst den Fehler finden.
                                • C chemieka
                                  @migoller
                                  MiGollerM Offline
                                  MiGollerM Offline
                                  MiGoller
                                  #373
                                  Ich habe neue Erkenntnisse:
                                  1. Falls sich jemand in der Mobile App nicht mit der E-Mail-Adresse anmelden kann, möge es bitte mit der Handynummer versuchen. Bei mir hat es nachstellbar geklappt, auch wenn ich mehrere Versuche benötigt habe. Anschließend konnte ich mich abmelden und wieder mit der E-Mail-Adresse anmelden.
                                  2. Die Life360 API ist umgezogen; es gibt nicht nur neue Endpunkte, auch müssen min. für den Login anderen Aufrufe getätigt werden.
                                  Ich bin dran, aber das kann noch ein wenig dauern, bis der Adapter wieder funktioniert. Geduldet Euch bitte, ich arbeite dran, wie es meine Zeit zulässt.
                                  T MiGollerM 2 Antworten Letzte Antwort
                                    tomtaz
                                    #374
                                    @migoller said in [Neuer Adapter] Life360:
                                    1. Die Life360 API ist umgezogen; es gibt nicht nur neue Endpunkte, auch müssen min. für den Login anderen Aufrufe getätigt werden.
                                    Vielen Dank für deinen Einsatz!
                                      MiGollerM Offline
                                      MiGollerM Offline
                                      MiGoller
                                      #375
                                      Hallo zusammen. Die ersten Tests sahen gut aus. Die Daten kann ich nun wieder per Life360 API abfragen. Die notwendigen Änderungen pflege ich in den Adapter ein und stelle Euch den so schnell wie möglich zum TESTEN zur Verfügung.
                                      Sobald der Adapter auf Github zum Testen verfügbar ist, werde ich Euch hier eine kurze Info geben.
                                        MiGollerM Offline
                                        MiGollerM Offline
                                        MiGoller
                                        #376
                                        Guten Abend zusammen.
                                        Ihr findet die Version 0.2.18 auf GitHub https://github.com/MiGoller/ioBroker.life360 oder als npm-Paket zur Installation bzw. zum Update. Die Installation bzw. das Update können durchaus ein paar Minuten dauern, also seid bitte geduldig. Das Thema schaue ich mir später noch an. Jetzt geht es mir erst einmal darum, dass Ihr den Adapter wieder nutzen könnt.
                                        Falls noch nicht geschehen, stoppt bitte die Lifer360 Adapter Instanz(en), bevor Ihr die neue Version des Adapters über GitHub oder per npm installiert. Nach der Installation bzw. dem Update des Adapters gebt bitte noch einmal Eure Life360 Anmeldedaten in den Einstellungen der Instanz(en) des Adapters neu ein, auch wenn sich diese nicht geändert haben sollten.
                                        Bei mir läuft der Adapter in der Version 0.2.18 nun auf verschiedenen Installationen mit unterschiedlichen Life360 Accounts.
                                        Viel Glück.
                                          Viel Glück.
                                          BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          #377
                                          @migoller 👍 besten Dank für die Mühe!
