  3. Off Topic
  4. Proxmox
  5. Proxmox spinnt - brauche Hilfe - auch mit Unifi
Geplant Angeheftet Gesperrt Verschoben Proxmox
90 Beiträge 5 Kommentatoren 16.0k Aufrufe 2 Beobachtet
    Könnte gut was hardwareseitiges sein.
    dmesg -T
    spuckt was aus?
    @thomas-braun Teil 2:
    [Mon Apr 25 12:46:59 2022] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
    [Mon Apr 25 12:46:59 2022] NET: Registered protocol family 2
    [Mon Apr 25 12:46:59 2022] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [Mon Apr 25 12:46:59 2022] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [Mon Apr 25 12:46:59 2022] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [Mon Apr 25 12:46:59 2022] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
    [Mon Apr 25 12:46:59 2022] TCP: Hash tables configured (established 65536 bind 65536)
    [Mon Apr 25 12:46:59 2022] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
    [Mon Apr 25 12:46:59 2022] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [Mon Apr 25 12:46:59 2022] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [Mon Apr 25 12:46:59 2022] NET: Registered protocol family 1
    [Mon Apr 25 12:46:59 2022] NET: Registered protocol family 44
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: BAR 14: assigned [mem 0x81500000-0x816fffff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: BAR 15: assigned [mem 0x81700000-0x818fffff 64bit pref]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: BAR 13: assigned [io  0x1000-0x1fff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0: PCI bridge to [bus 01]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0:   bridge window [mem 0x81500000-0x816fffff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.0:   bridge window [mem 0x81700000-0x818fffff 64bit pref]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.1: PCI bridge to [bus 02]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.1:   bridge window [mem 0x81300000-0x813fffff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.2: PCI bridge to [bus 03]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.2:   bridge window [io  0xe000-0xefff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:1c.2:   bridge window [mem 0x81200000-0x812fffff]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000fffff window]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:00: resource 9 [mem 0x80000000-0xdfffffff window]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:01: resource 1 [mem 0x81500000-0x816fffff]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:01: resource 2 [mem 0x81700000-0x818fffff 64bit pref]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:02: resource 1 [mem 0x81300000-0x813fffff]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:03: resource 0 [io  0xe000-0xefff]
    [Mon Apr 25 12:46:59 2022] pci_bus 0000:03: resource 1 [mem 0x81200000-0x812fffff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
    [Mon Apr 25 12:46:59 2022] pci 0000:00:14.0: quirk_usb_early_handoff+0x0/0x6f0 took 13783 usecs
    [Mon Apr 25 12:46:59 2022] PCI: CLS 64 bytes, default 64
    [Mon Apr 25 12:46:59 2022] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
    [Mon Apr 25 12:46:59 2022] software IO TLB: mapped [mem 0x0000000072c02000-0x0000000076c02000] (64MB)
    [Mon Apr 25 12:46:59 2022] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
    [Mon Apr 25 12:46:59 2022] clocksource: Switched to clocksource tsc
    [Mon Apr 25 12:46:59 2022] Trying to unpack rootfs image as initramfs...
    [Mon Apr 25 12:46:59 2022] platform rtc_cmos: registered platform RTC device (no PNP device found)
    [Mon Apr 25 12:46:59 2022] Initialise system trusted keyrings
    [Mon Apr 25 12:46:59 2022] Key type blacklist registered
    [Mon Apr 25 12:46:59 2022] workingset: timestamp_bits=36 max_order=21 bucket_order=0
    [Mon Apr 25 12:46:59 2022] zbud: loaded
    [Mon Apr 25 12:46:59 2022] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [Mon Apr 25 12:46:59 2022] fuse: init (API version 7.34)
    [Mon Apr 25 12:46:59 2022] integrity: Platform Keyring initialized
    [Mon Apr 25 12:46:59 2022] Key type asymmetric registered
    [Mon Apr 25 12:46:59 2022] Asymmetric key parser 'x509' registered
    [Mon Apr 25 12:46:59 2022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [Mon Apr 25 12:46:59 2022] io scheduler mq-deadline registered
    [Mon Apr 25 12:46:59 2022] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [Mon Apr 25 12:46:59 2022] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
    [Mon Apr 25 12:46:59 2022] ACPI: button: Lid Switch [LID0]
    [Mon Apr 25 12:46:59 2022] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
    [Mon Apr 25 12:46:59 2022] ACPI: button: Sleep Button [SLPB]
    [Mon Apr 25 12:46:59 2022] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
    [Mon Apr 25 12:46:59 2022] ACPI: button: Power Button [PWRF]
    [Mon Apr 25 12:46:59 2022] thermal LNXTHERM:00: registered as thermal_zone0
    [Mon Apr 25 12:46:59 2022] ACPI: thermal: Thermal Zone [TZ01] (46 C)
    [Mon Apr 25 12:46:59 2022] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
    [Mon Apr 25 12:46:59 2022] Linux agpgart interface v0.103
    [Mon Apr 25 12:46:59 2022] loop: module loaded
    [Mon Apr 25 12:46:59 2022] libphy: Fixed MDIO Bus: probed
    [Mon Apr 25 12:46:59 2022] tun: Universal TUN/TAP device driver, 1.6
    [Mon Apr 25 12:46:59 2022] PPP generic driver version 2.4.2
    [Mon Apr 25 12:46:59 2022] i8042: PNP: No PS/2 controller found.
    [Mon Apr 25 12:46:59 2022] mousedev: PS/2 mouse device common for all mice
    [Mon Apr 25 12:46:59 2022] rtc_cmos rtc_cmos: RTC can wake from S4
    [Mon Apr 25 12:46:59 2022] rtc_cmos rtc_cmos: registered as rtc0
    [Mon Apr 25 12:46:59 2022] rtc_cmos rtc_cmos: setting system clock to 2022-04-25T10:47:00 UTC (1650883620)
    [Mon Apr 25 12:46:59 2022] rtc_cmos rtc_cmos: alarms up to one day, y3k, 114 bytes nvram
    [Mon Apr 25 12:46:59 2022] i2c /dev entries driver
    [Mon Apr 25 12:46:59 2022] device-mapper: uevent: version 1.0.3
    [Mon Apr 25 12:46:59 2022] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Probing EISA bus 0
    [Mon Apr 25 12:46:59 2022] platform eisa.0: EISA: Cannot allocate resource for mainboard
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 1
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 2
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 3
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 4
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 5
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 6
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 7
    [Mon Apr 25 12:46:59 2022] platform eisa.0: Cannot allocate resource for EISA slot 8
    [Mon Apr 25 12:46:59 2022] platform eisa.0: EISA: Detected 0 cards
    [Mon Apr 25 12:46:59 2022] intel_pstate: Intel P-state driver initializing
    [Mon Apr 25 12:46:59 2022] ledtrig-cpu: registered to indicate activity on CPUs
    [Mon Apr 25 12:46:59 2022] EFI Variables Facility v0.08 2004-May-17
    [Mon Apr 25 12:46:59 2022] drop_monitor: Initializing network drop monitor service
    [Mon Apr 25 12:46:59 2022] NET: Registered protocol family 10
    [Mon Apr 25 12:47:00 2022] Freeing initrd memory: 58140K
    [Mon Apr 25 12:47:00 2022] Segment Routing with IPv6
    [Mon Apr 25 12:47:00 2022] NET: Registered protocol family 17
    [Mon Apr 25 12:47:00 2022] Bridge firewalling registered
    [Mon Apr 25 12:47:00 2022] Key type dns_resolver registered
    [Mon Apr 25 12:47:00 2022] microcode: sig=0x406c3, pf=0x1, revision=0x363
    [Mon Apr 25 12:47:00 2022] microcode: Microcode Update Driver: v2.2.
    [Mon Apr 25 12:47:00 2022] IPI shorthand broadcast: enabled
    [Mon Apr 25 12:47:00 2022] sched_clock: Marking stable (1897251462, 1951325)->(1923301175, -24098388)
    [Mon Apr 25 12:47:00 2022] registered taskstats version 1
    [Mon Apr 25 12:47:00 2022] Loading compiled-in X.509 certificates
    [Mon Apr 25 12:47:00 2022] zswap: loaded using pool lzo/zbud
    [Mon Apr 25 12:47:00 2022] Key type ._fscrypt registered
    [Mon Apr 25 12:47:00 2022] Key type .fscrypt registered
    [Mon Apr 25 12:47:00 2022] Key type fscrypt-provisioning registered
    [Mon Apr 25 12:47:00 2022] Key type encrypted registered
    [Mon Apr 25 12:47:00 2022] AppArmor: AppArmor sha1 policy hashing enabled
    [Mon Apr 25 12:47:00 2022] integrity: Loading X.509 certificate: UEFI:db
    [Mon Apr 25 12:47:00 2022] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
    [Mon Apr 25 12:47:00 2022] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
    [Mon Apr 25 12:47:00 2022] ima: No TPM chip found, activating TPM-bypass!
    [Mon Apr 25 12:47:00 2022] Loading compiled-in module X.509 certificates
    [Mon Apr 25 12:47:00 2022] Loaded X.509 cert 'Build time autogenerated kernel key: da6277a2f83d64c41e13b2887fc2e2072c1de73b'
    [Mon Apr 25 12:47:00 2022] ima: Allocated hash algorithm: sha1
    [Mon Apr 25 12:47:00 2022] ima: No architecture policies found
    [Mon Apr 25 12:47:00 2022] evm: Initialising EVM extended attributes:
    [Mon Apr 25 12:47:00 2022] evm: security.selinux
    [Mon Apr 25 12:47:00 2022] evm: security.SMACK64
    [Mon Apr 25 12:47:00 2022] evm: security.SMACK64EXEC
    [Mon Apr 25 12:47:00 2022] evm: security.SMACK64TRANSMUTE
    [Mon Apr 25 12:47:00 2022] evm: security.SMACK64MMAP
    [Mon Apr 25 12:47:00 2022] evm: security.apparmor
    [Mon Apr 25 12:47:00 2022] evm: security.ima
    [Mon Apr 25 12:47:00 2022] evm: security.capability
    [Mon Apr 25 12:47:00 2022] evm: HMAC attrs: 0x1
    [Mon Apr 25 12:47:00 2022] PM:   Magic number: 2:163:781
    [Mon Apr 25 12:47:00 2022] dma_heap system: hash matches
    [Mon Apr 25 12:47:00 2022] RAS: Correctable Errors collector initialized.
    [Mon Apr 25 12:47:00 2022] Freeing unused decrypted memory: 2036K
    [Mon Apr 25 12:47:00 2022] Freeing unused kernel image (initmem) memory: 2848K
    [Mon Apr 25 12:47:00 2022] Write protecting the kernel read-only data: 28672k
    [Mon Apr 25 12:47:00 2022] Freeing unused kernel image (text/rodata gap) memory: 2036K
    [Mon Apr 25 12:47:00 2022] Freeing unused kernel image (rodata/data gap) memory: 224K
    [Mon Apr 25 12:47:01 2022] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [Mon Apr 25 12:47:01 2022] x86/mm: Checking user space page tables
    [Mon Apr 25 12:47:01 2022] Run /init as init process
    [Mon Apr 25 12:47:01 2022]   with arguments:
    [Mon Apr 25 12:47:01 2022]     /init
    [Mon Apr 25 12:47:01 2022]   with environment:
    [Mon Apr 25 12:47:01 2022]     HOME=/
    [Mon Apr 25 12:47:01 2022]     TERM=linux
    [Mon Apr 25 12:47:01 2022]     BOOT_IMAGE=/boot/vmlinuz-5.13.19-2-pve
    [Mon Apr 25 12:47:01 2022] sdhci: Secure Digital Host Controller Interface driver
    [Mon Apr 25 12:47:01 2022] sdhci: Copyright(c) Pierre Ossman
    [Mon Apr 25 12:47:01 2022] sdhci-pci 0000:00:12.0: SDHCI controller found [8086:2296] (rev 21)
    [Mon Apr 25 12:47:01 2022] ahci 0000:00:13.0: version 3.0
    [Mon Apr 25 12:47:01 2022] xhci_hcd 0000:00:14.0: xHCI Host Controller
    [Mon Apr 25 12:47:01 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
    [Mon Apr 25 12:47:01 2022] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081509810
    [Mon Apr 25 12:47:01 2022] ahci 0000:00:13.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
    [Mon Apr 25 12:47:01 2022] ahci 0000:00:13.0: flags: 64bit ncq ilck pm led clo only pio slum part deso sadm sds apst
    [Mon Apr 25 12:47:01 2022] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
    [Mon Apr 25 12:47:01 2022] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
    [Mon Apr 25 12:47:01 2022] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
    [Mon Apr 25 12:47:01 2022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mon Apr 25 12:47:01 2022] usb usb1: Product: xHCI Host Controller
    [Mon Apr 25 12:47:01 2022] usb usb1: Manufacturer: Linux 5.13.19-2-pve xhci-hcd
    [Mon Apr 25 12:47:01 2022] usb usb1: SerialNumber: 0000:00:14.0
    [Mon Apr 25 12:47:01 2022] scsi host0: ahci
    [Mon Apr 25 12:47:01 2022] hub 1-0:1.0: USB hub found
    [Mon Apr 25 12:47:01 2022] hub 1-0:1.0: 7 ports detected
    [Mon Apr 25 12:47:01 2022] scsi host1: ahci
    [Mon Apr 25 12:47:01 2022] ata1: SATA max UDMA/133 abar m2048@0x8141b000 port 0x8141b100 irq 118
    [Mon Apr 25 12:47:01 2022] ata2: SATA max UDMA/133 abar m2048@0x8141b000 port 0x8141b180 irq 118
    [Mon Apr 25 12:47:01 2022] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
    [Mon Apr 25 12:47:01 2022] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mon Apr 25 12:47:01 2022] usb usb2: Product: xHCI Host Controller
    [Mon Apr 25 12:47:01 2022] usb usb2: Manufacturer: Linux 5.13.19-2-pve xhci-hcd
    [Mon Apr 25 12:47:01 2022] usb usb2: SerialNumber: 0000:00:14.0
    [Mon Apr 25 12:47:01 2022] hub 2-0:1.0: USB hub found
    [Mon Apr 25 12:47:01 2022] hub 2-0:1.0: 6 ports detected
    [Mon Apr 25 12:47:01 2022] mmc0: SDHCI controller on PCI [0000:00:12.0] using ADMA
    [Mon Apr 25 12:47:01 2022] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
    [Mon Apr 25 12:47:01 2022] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
    [Mon Apr 25 12:47:01 2022] i2c i2c-2: 1/1 memory slots populated (from DMI)
    [Mon Apr 25 12:47:01 2022] i2c i2c-2: Successfully instantiated SPD at 0x50
    [Mon Apr 25 12:47:01 2022] libphy: r8169: probed
    [Mon Apr 25 12:47:01 2022] r8169 0000:03:00.0 eth0: RTL8168h/8111h, f4:4d:30:67:f0:71, XID 541, IRQ 121
    [Mon Apr 25 12:47:01 2022] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
    [Mon Apr 25 12:47:01 2022] r8169 0000:03:00.0 enp3s0: renamed from eth0
    [Mon Apr 25 12:47:01 2022] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
    [Mon Apr 25 12:47:01 2022] ata1.00: ATA-9: ADATA SP550, O1230C, max UDMA/133
    [Mon Apr 25 12:47:01 2022] ata1.00: 468862128 sectors, multi 2: LBA48 NCQ (depth 32), AA
    [Mon Apr 25 12:47:01 2022] ata1.00: configured for UDMA/133
    [Mon Apr 25 12:47:01 2022] ahci 0000:00:13.0: port does not support device sleep
    [Mon Apr 25 12:47:01 2022] scsi 0:0:0:0: Direct-Access     ATA      ADATA SP550      0C   PQ: 0 ANSI: 5
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: [sda] Write Protect is off
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [Mon Apr 25 12:47:01 2022] ata2: SATA link down (SStatus 4 SControl 300)
    [Mon Apr 25 12:47:01 2022] usb 1-4: new full-speed USB device number 2 using xhci_hcd
    [Mon Apr 25 12:47:01 2022]  sda: sda1 sda2 sda3
    [Mon Apr 25 12:47:01 2022] sd 0:0:0:0: [sda] Attached SCSI disk
    [Mon Apr 25 12:47:02 2022] usb 1-4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
    [Mon Apr 25 12:47:02 2022] usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    [Mon Apr 25 12:47:02 2022] usb 1-4: Product: USB2.0-Serial
    [Mon Apr 25 12:47:02 2022] usb 1-5: new high-speed USB device number 3 using xhci_hcd
    [Mon Apr 25 12:47:02 2022] usb 1-5: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
    [Mon Apr 25 12:47:02 2022] usb 1-5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Mon Apr 25 12:47:02 2022] usb 1-5: Product: USB2.0 Hub
    [Mon Apr 25 12:47:02 2022] hub 1-5:1.0: USB hub found
    [Mon Apr 25 12:47:02 2022] hub 1-5:1.0: 4 ports detected
    [Mon Apr 25 12:47:02 2022] usb 1-5.1: new full-speed USB device number 4 using xhci_hcd
    [Mon Apr 25 12:47:02 2022] usb 1-5.1: New USB device found, idVendor=8087, idProduct=0a2a, bcdDevice= 0.01
    [Mon Apr 25 12:47:02 2022] usb 1-5.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Mon Apr 25 12:47:04 2022] fbcon: Taking over console
    [Mon Apr 25 12:47:04 2022] raid6: sse2x4   gen() 91147 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: sse2x4   xor() 18442 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: sse2x2   gen() 89689 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: sse2x2   xor() 50301 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: sse2x1   gen() 68081 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: sse2x1   xor() 36061 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: using algorithm sse2x4 gen() 4028 MB/s
    [Mon Apr 25 12:47:04 2022] raid6: .... xor() 18442 MB/s, rmw enabled
    [Mon Apr 25 12:47:04 2022] raid6: using ssse3x2 recovery algorithm
    [Mon Apr 25 12:47:04 2022] xor: measuring software checksum speed
    [Mon Apr 25 12:47:04 2022]    prefetch64-sse  :  9281 MB/sec
    [Mon Apr 25 12:47:04 2022]    generic_sse     :  8256 MB/sec
    [Mon Apr 25 12:47:04 2022] xor: using function: prefetch64-sse (9281 MB/sec)
    [Mon Apr 25 12:47:04 2022] Btrfs loaded, crc32c=crc32c-intel, zoned=yes
    [Mon Apr 25 12:47:05 2022] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Inserted module 'autofs4'
    [Mon Apr 25 12:47:05 2022] systemd[1]: systemd 247.3-6 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [Mon Apr 25 12:47:05 2022] systemd[1]: Detected architecture x86-64.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Set hostname to <pve-neu>.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Queued start job for default target Graphical Interface.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Created slice system-getty.slice.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Created slice system-modprobe.slice.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Created slice system-postfix.slice.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Created slice User and Session Slice.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target ceph target allowing to start/stop all ceph-fuse@.service instances at once.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target ceph target allowing to start/stop all ceph*@.service instances at once.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target Local Encrypted Volumes.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target Paths.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target Slices.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Reached target System Time Set.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on Device-mapper event daemon FIFOs.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on LVM2 poll daemon socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on RPCbind Server Activation Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on Syslog Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on fsck to fsckd communication Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on Journal Audit Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on Journal Socket (/dev/log).
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on Journal Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on udev Control Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Listening on udev Kernel Socket.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting Huge Pages File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting POSIX Message Queue File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting RPC Pipe File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting Kernel Debug File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting Kernel Trace File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Set the console keyboard layout...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Load Kernel Module configfs...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Load Kernel Module drm...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Load Kernel Module fuse...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Journal Service...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Load Kernel Modules...
    [Mon Apr 25 12:47:05 2022] RPC: Registered named UNIX socket transport module.
    [Mon Apr 25 12:47:05 2022] RPC: Registered udp transport module.
    [Mon Apr 25 12:47:05 2022] RPC: Registered tcp transport module.
    [Mon Apr 25 12:47:05 2022] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Remount Root and Kernel File Systems...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Coldplug All udev Devices...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted Huge Pages File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted POSIX Message Queue File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted RPC Pipe File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted Kernel Debug File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted Kernel Trace File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Set the console keyboard layout.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Create list of static device nodes for the current kernel.
    [Mon Apr 25 12:47:05 2022] systemd[1]: modprobe@configfs.service: Succeeded.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Load Kernel Module configfs.
    [Mon Apr 25 12:47:05 2022] systemd[1]: modprobe@fuse.service: Succeeded.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Load Kernel Module fuse.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting FUSE Control File System...
    [Mon Apr 25 12:47:05 2022] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounting Kernel Configuration File System...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted FUSE Control File System.
    [Mon Apr 25 12:47:05 2022] Loading iSCSI transport class v2.0-870.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Mounted Kernel Configuration File System.
    [Mon Apr 25 12:47:05 2022] systemd[1]: modprobe@drm.service: Succeeded.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Load Kernel Module drm.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Remount Root and Kernel File Systems.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Load/Save Random Seed...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Create System Users...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Started Device-mapper event daemon.
    [Mon Apr 25 12:47:05 2022] iscsi: registered transport (tcp)
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Load/Save Random Seed.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Condition check resulted in First Boot Complete being skipped.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Create System Users.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Create Static Device Nodes in /dev...
    [Mon Apr 25 12:47:05 2022] systemd[1]: Finished Create Static Device Nodes in /dev.
    [Mon Apr 25 12:47:05 2022] iscsi: registered transport (iser)
    [Mon Apr 25 12:47:05 2022] systemd[1]: Starting Rule-based Manager for Device Events and Files...
    [Mon Apr 25 12:47:05 2022] spl: loading out-of-tree module taints kernel.
    [Mon Apr 25 12:47:05 2022] znvpair: module license 'CDDL' taints kernel.
    [Mon Apr 25 12:47:05 2022] Disabling lock debugging due to kernel taint
    [Mon Apr 25 12:47:05 2022] systemd[1]: Started Rule-based Manager for Device Events and Files.
    [Mon Apr 25 12:47:05 2022] systemd[1]: Started Journal Service.
    [Mon Apr 25 12:47:06 2022] systemd-journald[356]: Received client request to flush runtime journal.
    [Mon Apr 25 12:47:06 2022] systemd-journald[356]: File /var/log/journal/3937d254195d412fa4115cb56f0e1ee7/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [Mon Apr 25 12:47:06 2022] ZFS: Loaded module v2.1.1-pve1, ZFS pool version 5000, ZFS filesystem version 5
    [Mon Apr 25 12:47:06 2022] dw_dmac_pci 0000:00:18.0: DesignWare DMA Controller, 8 channels
    [Mon Apr 25 12:47:06 2022] Registered IR keymap rc-rc6-mce
    [Mon Apr 25 12:47:06 2022] Bluetooth: Core ver 2.22
    [Mon Apr 25 12:47:06 2022] NET: Registered protocol family 31
    [Mon Apr 25 12:47:06 2022] Bluetooth: HCI device and connection manager initialized
    [Mon Apr 25 12:47:06 2022] Bluetooth: HCI socket layer initialized
    [Mon Apr 25 12:47:06 2022] Bluetooth: L2CAP socket layer initialized
    [Mon Apr 25 12:47:06 2022] Bluetooth: SCO socket layer initialized
    [Mon Apr 25 12:47:06 2022] input: PC Speaker as /devices/platform/pcspkr/input/input4
    [Mon Apr 25 12:47:06 2022] IR RC6 protocol handler initialized
    [Mon Apr 25 12:47:06 2022] usbcore: registered new interface driver usbserial_generic
    [Mon Apr 25 12:47:06 2022] usbserial: USB Serial support registered for generic
    [Mon Apr 25 12:47:06 2022] usbcore: registered new interface driver ch341
    [Mon Apr 25 12:47:06 2022] usbserial: USB Serial support registered for ch341-uart
    [Mon Apr 25 12:47:06 2022] ch341 1-4:1.0: ch341-uart converter detected
    [Mon Apr 25 12:47:06 2022] usb 1-4: ch341-uart converter now attached to ttyUSB0
    [Mon Apr 25 12:47:06 2022] at24 2-0050: supply vcc not found, using dummy regulator
    [Mon Apr 25 12:47:06 2022] at24 2-0050: 256 byte spd EEPROM, read-only
    [Mon Apr 25 12:47:06 2022] rc rc0: ITE8713 CIR transceiver as /devices/pnp0/00:02/rc/rc0
    [Mon Apr 25 12:47:06 2022] cryptd: max_cpu_qlen set to 1000
    [Mon Apr 25 12:47:06 2022] rc rc0: lirc_dev: driver ite-cir registered at minor = 0, raw IR receiver, raw IR transmitter
      Teil 3:
      [Mon Apr 25 12:47:06 2022] input: ITE8713 CIR transceiver as /devices/pnp0/00:02/rc/rc0/input3
      [Mon Apr 25 12:47:06 2022] SSE version of gcm_enc/dec engaged.
      [Mon Apr 25 12:47:06 2022] pstore: Using crash dump compression: deflate
      [Mon Apr 25 12:47:06 2022] pstore: Registered efi as persistent store backend
      [Mon Apr 25 12:47:06 2022] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [Mon Apr 25 12:47:06 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [Mon Apr 25 12:47:06 2022] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [Mon Apr 25 12:47:06 2022] cfg80211: failed to load regulatory.db
      [Mon Apr 25 12:47:06 2022] usbcore: registered new interface driver btusb
      [Mon Apr 25 12:47:06 2022] Bluetooth: hci0: read Intel version: 370810011003110e00
      [Mon Apr 25 12:47:06 2022] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq failed with error -2
      [Mon Apr 25 12:47:06 2022] Bluetooth: hci0: failed to open Intel firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq (-2)
      [Mon Apr 25 12:47:06 2022] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.bseq failed with error -2
      [Mon Apr 25 12:47:06 2022] Bluetooth: hci0: failed to open default fw file: intel/ibt-hw-37.8.bseq
      [Mon Apr 25 12:47:06 2022] i915 0000:00:02.0: vgaarb: deactivate vga console
      [Mon Apr 25 12:47:06 2022] Intel(R) Wireless WiFi driver for Linux
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: Found debug configuration: 0
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: loaded firmware version 29.4063824552.0 7265D-29.ucode op_mode iwlmvm
      [Mon Apr 25 12:47:06 2022] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
      [Mon Apr 25 12:47:06 2022] intel_rapl_common: Found RAPL domain package
      [Mon Apr 25 12:47:06 2022] intel_rapl_common: Found RAPL domain core
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3165, REV=0x210
      [Mon Apr 25 12:47:06 2022] Adding 7340028k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:7340028k SSFS
      [Mon Apr 25 12:47:06 2022] thermal thermal_zone1: failed to read out thermal zone (-61)
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: Allocated 0x00400000 bytes for firmware monitor.
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0: base HW address: 98:54:1b:19:00:af
      [Mon Apr 25 12:47:06 2022] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
      [Mon Apr 25 12:47:06 2022] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
      [Mon Apr 25 12:47:06 2022] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
      [Mon Apr 25 12:47:06 2022] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
      [Mon Apr 25 12:47:06 2022] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
      [Mon Apr 25 12:47:06 2022] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
      [Mon Apr 25 12:47:06 2022] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC283: line_outs=2 (0x1b/0x21/0x0/0x0/0x0) type:hp
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x1e/0x0
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:    inputs:
      [Mon Apr 25 12:47:06 2022] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
      [Mon Apr 25 12:47:07 2022] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
      [Mon Apr 25 12:47:07 2022] input: HDA Intel PCH Headphone Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
      [Mon Apr 25 12:47:07 2022] input: HDA Intel PCH Front Headphone Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
      [Mon Apr 25 12:47:07 2022] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.020:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=576 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.024:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/chronyd" pid=573 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.028:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=574 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.036:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=581 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.036:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=581 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.044:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=580 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.044:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=580 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.044:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=580 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.056:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=577 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] audit: type=1400 audit(1650883628.056:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=577 comm="apparmor_parser"
      [Mon Apr 25 12:47:07 2022] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
      [Mon Apr 25 12:47:07 2022] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
      [Mon Apr 25 12:47:08 2022] vmbr0: port 1(enp3s0) entered blocking state
      [Mon Apr 25 12:47:08 2022] vmbr0: port 1(enp3s0) entered disabled state
      [Mon Apr 25 12:47:08 2022] device enp3s0 entered promiscuous mode
      [Mon Apr 25 12:47:08 2022] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
      [Mon Apr 25 12:47:08 2022] r8169 0000:03:00.0 enp3s0: Link is Down
      [Mon Apr 25 12:47:08 2022] vmbr0: port 1(enp3s0) entered forwarding state
      [Mon Apr 25 12:47:09 2022] vmbr0: port 1(enp3s0) entered disabled state
      [Mon Apr 25 12:47:11 2022] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
      [Mon Apr 25 12:47:11 2022] vmbr0: port 1(enp3s0) entered blocking state
      [Mon Apr 25 12:47:11 2022] vmbr0: port 1(enp3s0) entered forwarding state
      [Mon Apr 25 12:47:11 2022] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
      [Mon Apr 25 12:47:12 2022] bpfilter: Loaded bpfilter_umh pid 906
      [Mon Apr 25 12:47:12 2022] Started bpfilter
      [Mon Apr 25 12:47:27 2022] device tap100i0 entered promiscuous mode
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 1(fwln100i0) entered blocking state
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 1(fwln100i0) entered disabled state
      [Mon Apr 25 12:47:27 2022] device fwln100i0 entered promiscuous mode
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 1(fwln100i0) entered forwarding state
      [Mon Apr 25 12:47:27 2022] vmbr0: port 2(fwpr100p0) entered blocking state
      [Mon Apr 25 12:47:27 2022] vmbr0: port 2(fwpr100p0) entered disabled state
      [Mon Apr 25 12:47:27 2022] device fwpr100p0 entered promiscuous mode
      [Mon Apr 25 12:47:27 2022] vmbr0: port 2(fwpr100p0) entered forwarding state
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 2(tap100i0) entered blocking state
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 2(tap100i0) entered disabled state
      [Mon Apr 25 12:47:27 2022] fwbr100i0: port 2(tap100i0) entered forwarding state
      [Mon Apr 25 12:47:27 2022] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
      [Mon Apr 25 12:47:27 2022] ch341 1-4:1.0: device disconnected
      [Mon Apr 25 12:47:33 2022] device tap101i0 entered promiscuous mode
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 1(fwln101i0) entered blocking state
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 1(fwln101i0) entered disabled state
      [Mon Apr 25 12:47:33 2022] device fwln101i0 entered promiscuous mode
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 1(fwln101i0) entered forwarding state
      [Mon Apr 25 12:47:33 2022] vmbr0: port 3(fwpr101p0) entered blocking state
      [Mon Apr 25 12:47:33 2022] vmbr0: port 3(fwpr101p0) entered disabled state
      [Mon Apr 25 12:47:33 2022] device fwpr101p0 entered promiscuous mode
      [Mon Apr 25 12:47:33 2022] vmbr0: port 3(fwpr101p0) entered forwarding state
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 2(tap101i0) entered blocking state
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 2(tap101i0) entered disabled state
      [Mon Apr 25 12:47:33 2022] fwbr101i0: port 2(tap101i0) entered forwarding state
      [Mon Apr 25 12:47:42 2022] usb 1-4: reset full-speed USB device number 2 using xhci_hcd
      [Mon Apr 25 12:47:49 2022] device-mapper: thin: 253:4: reached low water mark for data device: sending event.
      [Mon Apr 25 12:47:49 2022] device-mapper: thin: 253:4: switching pool to out-of-data-space (queue IO) mode
      [Mon Apr 25 12:48:50 2022] device-mapper: thin: 253:4: switching pool to out-of-data-space (error IO) mode
      JLegJ 1 Antwort Letzte Antwort
        Ich würde mich über eine schnelle Hilfe von einem Proxmox kundigen freuen.
        Punkt 12:00 ist mein ioBroker verstummt als ich gerade einen View öffnen wollte.
        Nach etwas Suchen stellte ich fest, dass die VM einen I/O Error anzeigte.
        Neustart/Shutdown oder ähnliches hat nicht geklappt.
        Also todesmutig Hauptschalter am NUC betätigt.
        PVE fuhr wieder hoch, beide VMs auch.
        Nach kurzer Zeit hing dann diesmal die UNIFI-VM, ebenfalls mit I/O Error.
        Ich kann jetzt diese VM weder rebooten noch stoppen.
        und während ich tippe ist jetzt auch die ioBroker VM wieder down
        Dort steht jetzt im log:
        TASK ERROR: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
        Ich habe da kein Desktop
        für jede Hilfe dankbar.
        Natürlich muss ich morgeen für ein paar Tage weg und habe "eigentlich" keine Zeit
        crunchipC
        crunchipC
        Developer Global Moderator Most Active Forum Testing
        @homoran sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
        Per shell auch nicht?
        qm unlock 123
        qm stop 123
        • JLegJ
          JLegJ
          JLeg
          @homoran worauf laufen denn die beiden VMs? Also z.B LVM-Volumes, LVM-Thin etc? Nodeseitig evtl. Snapshots aktiv? Die Meldung "I/O-Error" innerhalb einer VM oder LXC kenne ich eigentlich nur vom Fall, dass z.B. ein LV bzw. Snapshot "vollgelaufen" ist... (zumindest wenn man defekte Platten ausschliessen kann)
          HomoranH crunchipC 2 Antworten Letzte Antwort
            Teil 3:
            JLegJ
            JLegJ
            JLeg
            schau' mal, was
            lsblk
            sagt - da kannst du sehen, zu was "253:4" gehört...
            • JLegJ JLeg
              @jleg
              Ich habe es mir mal ganz einfach gemacht:
              @crunchip
              wie du siehst komme ich nur noch auf das PVE
              dort in der PVE-Shell ausführen?
              • JLegJ JLeg
                crunchipC
                crunchipC
                @jleg wäre dann der Hinweis
                • JLegJ JLeg
                  schau' mal, was
                  lsblk
                  @jleg sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                  ich sicher nicht :-)
                  root@pve-neu:~# lsblk
                  NAME                         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
                  sda                            8:0    0 223.6G  0 disk
                  ├─sda1                         8:1    0  1007K  0 part
                  ├─sda2                         8:2    0   512M  0 part /boot/efi
                  └─sda3                         8:3    0 223.1G  0 part
                    ├─pve-swap                 253:0    0     7G  0 lvm  [SWAP]
                    ├─pve-root                 253:1    0  55.8G  0 lvm  /
                    ├─pve-data_tmeta           253:2    0   1.4G  0 lvm
                    │ └─pve-data-tpool         253:4    0 141.4G  0 lvm
                    │   ├─pve-data             253:5    0 141.4G  1 lvm
                    │   ├─pve-vm--100--disk--0 253:6    0   140G  0 lvm
                    │   └─pve-vm--101--disk--0 253:7    0    32G  0 lvm
                    └─pve-data_tdata           253:3    0 141.4G  0 lvm
                    @jleg
                    @crunchip
                    crunchipC
                    crunchipC
                    @homoran ja
                      JLegJ
                      JLegJ
                      JLeg
                      schrieb am zuletzt editiert von JLeg
                      @homoran jo, sind thin pools - und der 253:4 ist voll - was sagt denn
                      vgdisplay -v pve
                        @homoran ja
                        @crunchip sieht nicht gut aus:
                        • JLegJ JLeg
                          vgdisplay -v pve
                          @jleg
                          root@pve-neu:~# vgdisplay -v pve
                            --- Volume group ---
                            VG Name               pve
                            System ID
                            Format                lvm2
                            Metadata Areas        1
                            Metadata Sequence No  15
                            VG Access             read/write
                            VG Status             resizable
                            MAX LV                0
                            Cur LV                5
                            Open LV               3
                            Max PV                0
                            Cur PV                1
                            Act PV                1
                            VG Size               <223.07 GiB
                            PE Size               4.00 MiB
                            Total PE              57105
                            Alloc PE / Size       53010 / 207.07 GiB
                            Free  PE / Size       4095 / <16.00 GiB
                            VG UUID               QxE0vt-KnKS-Z92t-L53i-YOyT-4PEr-9THeBz
                            --- Logical volume ---
                            LV Path                /dev/pve/swap
                            LV Name                swap
                            VG Name                pve
                            LV UUID                u0kopG-fi9N-sqEn-YgpO-u82L-mAQp-RHpd38
                            LV Write Access        read/write
                            LV Creation host, time proxmox, 2021-12-13 15:30:10 +0100
                            LV Status              available
                            # open                 2
                            LV Size                7.00 GiB
                            Current LE             1792
                            Segments               1
                            Allocation             inherit
                            Read ahead sectors     auto
                            - currently set to     256
                            Block device           253:0
                            LV Path                /dev/pve/root
                            LV Name                root
                            VG Name                pve
                            LV UUID                k8bNxN-ss4P-V1vf-Zeqm-reIp-9cRj-B2AnfY
                            LV Status              available
                            # open                 1
                            LV Size                55.75 GiB
                            Current LE             14272
                            Segments               1
                            Allocation             inherit
                            Block device           253:1
                            LV Name                data
                            VG Name                pve
                            LV UUID                AP1yuy-r0H8-jsq0-rvy9-DBnu-K0TB-5Qkt0M
                            LV Write Access        read/write (activated read only)
                            LV Creation host, time proxmox, 2021-12-13 15:30:15 +0100
                            LV Pool metadata       data_tmeta
                            LV Pool data           data_tdata
                            LV Status              available
                            # open                 0
                            LV Size                <141.43 GiB
                            Allocated pool data    100.00%
                            Allocated metadata     5.40%
                            Current LE             36206
                            Segments               1
                            Allocation             inherit
                            Block device           253:5
                            LV Path                /dev/pve/vm-100-disk-0
                            LV Name                vm-100-disk-0
                            VG Name                pve
                            LV UUID                yVqmMo-lQFx-zeIW-VpEB-aC52-FQR9-dbjNZI
                            LV Creation host, time pve-neu, 2021-12-13 17:44:06 +0100
                            LV Pool name           data
                            LV Status              available
                            # open                 1
                            LV Size                140.00 GiB
                            Mapped size            95.47%
                            Current LE             35840
                            Segments               1
                            Allocation             inherit
                            Block device           253:6
                            LV Path                /dev/pve/vm-101-disk-0
                            LV Name                vm-101-disk-0
                            VG Name                pve
                            LV UUID                RZsqpX-CwHp-Obe9-nQYE-78F3-Jva5-lYRlRY
                            LV Creation host, time pve-neu, 2021-12-13 18:05:41 +0100
                            LV Pool name           data
                            LV Status              available
                            # open                 0
                            LV Size                32.00 GiB
                            Mapped size            24.30%
                            Current LE             8192
                            Segments               1
                            Allocation             inherit
                            Block device           253:7
                            --- Physical volumes ---
                            PV Name               /dev/sda3
                            PV UUID               AY1yhR-LBud-ZdQO-hN5N-n05P-Yrhd-zjt1Ii
                            PV Status             allocatable
                            Total PE / Free PE    57105 / 4095
                            crunchipC
                            crunchipC
                            @homoran ist doch gestoppt
                              @crunchip jepp gerade eben
                              und jetzt auch die ander
                                @crunchip jetzt habe ich auch beide wieder starten können....
                                101 hängt schon wieder
                                  @jleg
                                    VG Name               pve
                                    System ID
                                    Format                lvm2
                                    Metadata Areas        1
                                    VG Status             resizable
                                    MAX LV                0
                                    Cur LV                5
                                    Open LV               3
                                    Max PV                0
                                    Cur PV                1
                                    Act PV                1
                                    VG Size               <223.07 GiB
                                    PE Size               4.00 MiB
                                    Total PE              57105
                                    LV Name                swap
                                    VG Name                pve
                                    LV Status              available
                                    # open                 2
                                    LV Size                7.00 GiB
                                    Current LE             1792
                                    Segments               1
                                    Allocation             inherit
                                    Block device           253:0
                                    LV Name                root
                                    VG Name                pve
                                    LV Status              available
                                    # open                 1
                                    LV Size                55.75 GiB
                                    Current LE             14272
                                    Segments               1
                                    Allocation             inherit
                                    Block device           253:1
                                    LV Name                data
                                    VG Name                pve
                                    LV Status              available
                                    # open                 0
                                    LV Size                <141.43 GiB
                                    Current LE             36206
                                    Segments               1
                                    Allocation             inherit
                                    Block device           253:5
                                    VG Name                pve
                                    LV Pool name           data
                                    LV Status              available
                                    # open                 1
                                    LV Size                140.00 GiB
                                    Mapped size            95.47%
                                    Current LE             35840
                                    Segments               1
                                    Allocation             inherit
                                    Block device           253:6
                                    VG Name                pve
                                    LV Pool name           data
                                    LV Status              available
                                    # open                 0
                                    LV Size                32.00 GiB
                                    Mapped size            24.30%
                                    Current LE             8192
                                    Segments               1
                                    Allocation             inherit
                                    Block device           253:7
                                    PV Name               /dev/sda3
                                  JLegJ
                                  JLegJ
                                  JLeg
                                  @homoran tja, dein lvm-thin-metadata-Storage ist vollgelaufen. Gründe für sowas gibt's einige, wenn du keine Snapshots benutzt, sind's vielleicht zu kleine Chunk-Sizes (beim Einrichten gewählt) oder so...
                                  Schnellste Abhilfe wäre, das tmeta-LV zu vergrössern - blöderweise ist deine Volumegroup (pve) aber auch schon bis fast zum Anschlag ausgereizt (ich würde da immer bissel Luft lassen), du hast nur noch 6GB zur Verfügung. Das könnte aber schonmal helfen, zumindest für ein paar Wochen oder so..
                                  Hier steht der Aufruf zum Vergrössern: https://pve.proxmox.com/wiki/LVM2#Resize_metadata_pool
                                    crunchipC
                                    crunchipC
                                    @homoran mein handy hängt die ganze Zeit, kann nicht scrollen in dem Thread.
                                    Aber wenn ich es richtig sehe ist deine VM 140Gb?
                                    Und dein LVM ebenfalls
                                    • HomoranH
                                      Danke euch beiden - keine Panik - die habe ich.
                                      @crunchip sagte in Proxmox spinnt - brauche Hilfe - auch mit Unifi:
                                      passt wahrscheinlich zu
                                      und ich nutze keine Snapshots
                                      Habe schon den nächsten NUC vorbereitet gehabt, der 5PPYH sollte nur den Neuaufbau des i3 überbrücken.
                                      und wie das so ist dauert ein Provisorium zu lange
                                      • JLegJ JLeg
                                        wenn ich wüsste wovon du redest :-) würde ich das wohl auch
                                        reicht :-)
                                        DANKE
                                        sehe ich mir an
                                        • JLegJ JLeg
                                          Könntest du so nett sein und das für mich übersetzen?
                                          lvresize --poolmetadatasize +<size[M,G]> <VG>/<LVThin_pool>
                                          84.2k
