Test Adapter wireless-mbus v0.13.x
@lvogt 2022-04-10 16:26:07.921 -
Habe den Adapter auf debug gestellt und bekomme das folgende.
[32minfo[39m: wireless-mbus.0 (8517) Got terminate signal TERMINATE_YOURSELF
2022-04-10 16:26:07.925 - [32minfo[39m: wireless-mbus.0 (8517) terminating
2022-04-10 16:26:07.927 - [32minfo[39m: wireless-mbus.0 (8517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-04-10 16:26:08.497 - [32minfo[39m: host.iobrokerserver instance system.adapter.wireless-mbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2022-04-10 16:26:11.038 - [32minfo[39m: host.iobrokerserver instance system.adapter.wireless-mbus.0 started with pid 9481
2022-04-10 16:26:12.370 - [34mdebug[39m: wireless-mbus.0 (9481) Redis Objects: Use Redis connection: 127.0.0.1:9001
2022-04-10 16:26:12.442 - [34mdebug[39m: wireless-mbus.0 (9481) Objects client ready ... initialize now
2022-04-10 16:26:12.445 - [34mdebug[39m: wireless-mbus.0 (9481) Objects create System PubSub Client
2022-04-10 16:26:12.446 - [34mdebug[39m: wireless-mbus.0 (9481) Objects create User PubSub Client
2022-04-10 16:26:12.531 - [34mdebug[39m: wireless-mbus.0 (9481) Objects client initialize lua scripts
2022-04-10 16:26:12.538 - [34mdebug[39m: wireless-mbus.0 (9481) Objects connected to redis: 127.0.0.1:9001
2022-04-10 16:26:12.577 - [34mdebug[39m: wireless-mbus.0 (9481) Redis States: Use Redis connection: 127.0.0.1:9000
2022-04-10 16:26:12.595 - [34mdebug[39m: wireless-mbus.0 (9481) States create System PubSub Client
2022-04-10 16:26:12.597 - [34mdebug[39m: wireless-mbus.0 (9481) States create User PubSub Client
2022-04-10 16:26:12.647 - [34mdebug[39m: wireless-mbus.0 (9481) States connected to redis: 127.0.0.1:9000
2022-04-10 16:26:12.973 - [33mwarn[39m: wireless-mbus.0 (9481) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
2022-04-10 16:26:12.975 - [33mwarn[39m: wireless-mbus.0 (9481) This object will not be created in future versions. Please report this to the developer.
2022-04-10 16:26:12.989 - [32minfo[39m: wireless-mbus.0 (9481) starting. Version 0.7.6 (non-npm: Apollon77/ioBroker.wireless-mbus#9054a4b6bf7ce4bf92f0804e60323dbece905460) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.21
2022-04-10 16:26:13.079 - [34mdebug[39m: wireless-mbus.0 (9481) Created device of type: IMST iM871A
2022-04-10 16:26:13.102 - [34mdebug[39m: wireless-mbus.0 (9481) IMST: Receiver mode set to CA mode
2022-04-10 16:26:13.104 - [34mdebug[39m: wireless-mbus.0 (9481) connected set to true
2022-04-10 16:26:13.105 - [34mdebug[39m: wireless-mbus.0 (9481) connected set to trueWenn ich in das Feld "wireless-mbus.0.info.rawdata" gehe sieht das so aus
Ist also der Wert true / false.
Das Gerät ist eine Zenner Wasseruhr
Damit ich es nicht falsch einsortiere: Bei dir ging es nur um den "VIFExt 0x13" Fehler, ja?
Falls ja, dann wäre natürlich auch Logauszug bei dem der Fehler auftaucht nötig...
Das Handbuch des verlinkten Zählers gibt natürlich keine exakte Telegrammcodierung an, behauptet aber dem OMS 4.0.2 Standard zu folgen. Die VIF Extension ist aber definitiv nicht Teil des Standards - evtl. aber nur eine "Zenner interne" Zusatzinformation. Dem Handbuch nach scheint es aber sowieso nur mit Vormonatswerten zusammen zu hängen und ist damit für dich vermutlich sowieso uninteressant...2022-04-10 16:26:12.989 - [32minfo[39m: wireless-mbus.0 (9481) starting. Version 0.7.6 (non-npm: Apollon77/ioBroker.wireless-mbus#9054a4b6bf7ce4bf92f0804e60323dbece905460) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.21
Kurzer Hinweis: Wie auch immer du dazu kommst: Du hast den Adapter weder aus dem "unstable / beta" Repository installiert, noch aus meinem Github Repository, sondern aus einem (nicht mehr aktuellen) Fork von Apollon. Wenn du die aktuelle Version hättest - wäre zB auch der (unwichtige) Hinweis auf den
rawdataState nicht mehr da gewesen... -
rawdataState nicht mehr da gewesen...@lvogt ...woher ich den hatte von appollo kann ich nicht mehr sagen, ist aber auf deinen nun upgedatet. Jetzt habe ich die unrealistischen daten auch weg. Das 4-8 ist jetzt 1,828 m², das könnte der Vormonat sein. Da der erst 20 tage eingebaut ist, wird der 5-8 in einem Weilchen kommen
Echt super Adapter.
Blöde Frage. Ich nutze jetzt den C1 Modus bei der Abfrage.
Das muss ich ja im Adapter einstellen.
Wenn ich jetzt weitere Geräte kaufen die auf T1 senden, bedeutet dass das ich einen weitere Instanz installieren muss, also wireless-mbus.1.
Kann der dann auf den gleichen USB Stick zugreifen, oder benötige ich 2 Sticks?
Echt super Adapter.
@hkf8770 said in Test Adapter wireless-mbus v0.7.x:
Kann der dann auf den gleichen USB Stick zugreifen, oder benötige ich 2 Sticks?Wenn du zwei Instanzen erzeugst braucht auch jede einen echten Stick, den sie anspricht.
Der AMBER Stick hat einen Mode der gleichzeitig C und T empfängt - aber im reinen C-Mode hatte ich auch schon mal öfter das Problem dass der Stick(!) irgendwann crasht und vom Strom bzw. USB getrennt werden muss (ob das Problem auch den gemischten Mode betrifft erinnere ich mich nicht mehr...)
Als Kompromis könnte man überlegen ob man den Tag über mal ne Weile im C Mode und dann wieder ne Weile im T Mode lauscht. Aber das kann der Adapter selber nicht - könnte man aber "von außen" über ein kleines Script einbauen. Man müsste halt nur den Mode in der Config setzen und ioBroker würde den Adapter dann ja sowieso neustarten.
Ok, ich gebe auf mit meiner ArduinoUno TI-CC1101 combo.
Ich kann mir mein Problem nur mit der nicht unterstützten Hardware erklären. Mit wmbusmeter gehts, mit dem Adapter eben nicht.
Ist es erlaubt das mir jemand eine Kaufempfehlung gibt für einen CUL Stick der die Anforderungen erfüllt, und wo er ihn gekauft hat?
MfG
Patrick -
MfG
Patrick@marsmännchen
Du könntest noch ein paar Infos con wbusmeters posten, vl können wir dann weiter helfen.
Also zb die Konfiguration und mal einen Aufruf auf mit Ausgabe von wbusmeters wenn auch Daten ankommen.
Ob das wirklich hilft weiß ich natürlich nicht... -
@marsmännchen
Ob das wirklich hilft weiß ich natürlich nicht...Vielen Dank für die Hilfe, ich hab das schon abgebrochen, und wmbusmeters deinstalliert. Ich warte jetzt erst mal auf :
"eQ3 INNOGY RWE SmartHome USB Empfangseinheit Stromzähler Empfangs Einheit iM871A"
Wenn's damit nicht geht bau ich mir einen Durchflussmesser in die Leitung der in die Wago PFC200 geht. Damit geht's dann sicher. Die Konstellation vom Smartmeter Adapter - Landis+Gyr E450 - Hichi USB Lesekopf hat auch nie funktioniert, musste dann auch auf Eigenbau umsteigen.
Aber mal abwarten ob das mit dem iM871A was bringt.
Danke trotzdem:
Danke trotzdem:
@marsmännchen said in Test Adapter wireless-mbus v0.7.x:
"eQ3 INNOGY RWE SmartHome USB Empfangseinheit Stromzähler Empfangs Einheit iM871A"Also da hatten wir wohl die gleiche Idee. Leider hat der Stick von RWE eine andere USB PID (87ED) als der originale iMST iM871A. Und damit wird er (zumindest bei mir) leider nicht erkannt. Hab auch die originale Firmware von iMST drüber geflasht - hat aber auch nicht geholfen. Wenn du damit weiterkommst, sag bitte mal Bescheid :-)
Bin drauf und dran mir einen DVB-T Stick in Verbindung mit rtl-wmbus zuzulegen. Da lassen sich sogar alle Modi (C, T und S) gleichzeitig abfragen. @Ivogt: Wäre es möglich den rtl-wmbus auch in deinem Adapter unterstützten?
@gizmodlx
Na toll
Das wird ja immer besser!
ICH HASSE FUNK!! -
@gizmodlx
Ich habe mit einem solchen Stick damals deb Adapter getestet. Das geht also schon.
Ich weiß leider nicht mehr genau was man tun musste. Ich glaube man muss udev händisch mitteilen welchen (standard) Treiber das Gerät verwenden soll. Lässt sich bestimmt auch in eine udev Regel gießen...rtl-wmbus ließe sich schon einbauen. Ist aber halt ein ziemlicher CPU Fresser...
@gizmodlx
@lvogt said in Test Adapter wireless-mbus v0.7.x:
@gizmodlx
Ich weiß leider nicht mehr genau was man tun musste. Ich glaube man muss udev händisch mitteilen welchen (standard) Treiber das Gerät verwenden soll. Lässt sich bestimmt auch in eine udev Regel gießen...Hmm...da muss ich mich erst mal selbst schlau machen. Sagt mir alles so leider wenig.
wmbusmeters spricht den rtl-wmbus wohl direkt über dessen Kommandozeile an. Das wäre echt klasse, wenn das dein Adapter auch unterstützen würde. Für die CPU-Auslastung gibt es wohl auch mehrere Ansätze, diese zu begrenzen: https://github.com/weetmuts/wmbusmeters/issues/290
So, da bin ich wieder mit meinem tollen iM871A.
Angesteckt, dann lsusb:Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 10c4:87ed Silicon Labs IMST USB-Stick for Smart Meter Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubDanach ls -l /dev/ttyS*:
crw-rw---- 1 root dialout 4, 64 15. Apr 17:43 /dev/ttyS0Der Stick lässt sich auch im Adapter auswählen:
Und trotzdem:
wireless-mbus.0 2022-04-15 17:50:49.238 error IMST: Error setting wMBus mode: T wireless-mbus.0 2022-04-15 17:50:49.237 error IMST: Error setting link mode 3 wireless-mbus.0 2022-04-15 17:50:49.235 error IMST: Message response timeout wireless-mbus.0 2022-04-15 17:50:46.279 debug connected set to true wireless-mbus.0 2022-04-15 17:50:46.239 debug connected set to true wireless-mbus.0 2022-04-15 17:50:46.226 debug Created device of type: IMST iM871AUnd das bei allen Baudraten.
Hat jemand eine Idee dazu?
MfG
Patrick -
@marsmännchen Falscher Port. Was bringt dich dazu von ttyS0 auszugehen ? Das musste ein ttyUSBx Port werden.
Aber wie gesagt muss man evtl erst dem Kernel mitteilen welcher Treiber verwendet werden soll.
Stick entfernen - kurz warten - Stick einstecken - die letzten ~30 Zeilen der Ausgabe von
dmesgposten. Dann kann ich dir vielleicht helfen -
Und trotzdem:
MfG
Patrick@marsmännchen sagte in Test Adapter wireless-mbus v0.7.x:
Sind die user denn auch Mitglied bei 'dialout'?
groups sudo -u iobroker groupsPrinzipiell würde ich auch den device link aus /dev/serial/by-id nehmen.
ls -l /dev/serial/by-id/anschauen.
dmesgposten. Dann kann ich dir vielleicht helfen@lvogt said in Test Adapter wireless-mbus v0.7.x:
dmesgposten. Dann kann ich dir vielleicht helfenDa ich den gleichen Stick habe, hänge ich mich mal hier mit ran :-)
Hier die "dmesg" Infos zum Stick:[17564.196443] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[17564.334432] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=87ed, bcdDevice= 1.00
[17564.334463] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[17564.334484] usb 1-1.4: Product: IMST USB-Stick for Smart Meter
[17564.334502] usb 1-1.4: Manufacturer: Silicon Labs
[17564.334520] usb 1-1.4: SerialNumber: 0xxxxxx3 (->verfälscht) -
[17564.334520] usb 1-1.4: SerialNumber: 0xxxxxx3 (->verfälscht)@gizmodlx Was ist denn konkret dein Problem?
Unter welchem Device Link findet sich der Stick denn?
Siehels -l /dev/serial/by-idGruppenzugehörigkeiten i.O.?
@thomas-braun said in Test Adapter wireless-mbus v0.7.x:
Nun ich würde den Stick gerne ebenfalls in Verbindung mit dem Adapter nutzen. Es ist ein Stick von RWE, der den gleichen Chip (iMST iM871A) hat, aber eine andere ProductID (87ED). Und ich bin etwas "lost" wie ich diesen Stick nun mit Treibern versorgen kann.
Siehels -l /dev/serial/by-idda erhalte ich nur folgende Fehlermeldung:
ls: Zugriff auf '/dev/serial/by-id' nicht möglich: Datei oder Verzeichnis nicht gefundenGruppenzugehörigkeiten i.O.?
Kannst du das etwas ausführlicher erklären?
sudo -u iobroker groups iobroker tty dialout audio video bluetooth gpio i2c -
sudo -u iobroker groups iobroker tty dialout audio video bluetooth gpio i2c@gizmodlx sagte in Test Adapter wireless-mbus v0.7.x:
Die Treiber sind im Linux-Kernel enthalten. Die Erkennung erfolgt i. d. R. über die ProductID bei USB-Geräten. Kann sein, das dein Stick da etwas exotisch ist. Wenn du Glück hast kann man die Erkennung aber etwas 'zurecht biegen'. Das ist aber wohl eher was für einen eigenen Thread.
sudo -u iobroker groups iobroker tty dialout audio video bluetooth gpio i2cBei mir exakt das gleiche wie bei @gizmodlx . Gleiche Ausgaben in der Konsole.
lsusb -t -
lsusb -t[694216.283345] usb 1-1.3: USB disconnect, device number 5 [694222.324999] device eth0 entered promiscuous mode [694228.253947] device eth0 left promiscuous mode [694252.331385] device eth0 entered promiscuous mode [694257.892408] usb 1-1.1: new full-speed USB device number 6 using xhci_hcd [694258.000219] usb 1-1.1: New USB device found, idVendor=10c4, idProduct=87ed, bcdDevice= 1.00 [694258.000239] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [694258.000253] usb 1-1.1: Product: IMST USB-Stick for Smart Meter [694258.000266] usb 1-1.1: Manufacturer: Silicon Labs [694258.000278] usb 1-1.1: SerialNumber: 005FD795 [694258.243526] device eth0 left promiscuous mode [694282.322992] device eth0 entered promiscuous modelsusb -t /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M |__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=, 12M
