  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 200.3k Aufrufe 58 Beobachtet
  • H hardy_01
    Bei mir hat sich beim Update irgendwas aufgehangen. Seit dem ist der broker nicht mehr erreichbar
    pi@raspberrypi-iob:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @4.0.21
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
     Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
     States 127.0.0.1:38688 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
     Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
     Objects 127.0.0.1:53902 Error from InMemDB: Error: scan NOT SUPPORTED
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    ReplyError: Error scan NOT SUPPORTED
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:95:5) {
      command: {
        args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T16_38_52_007Z-debug.log
    host.raspberrypi-iob Cannot install iobroker.js-controller@4.0.21: 1
    iobroker update bringt
    pi@raspberrypi-iob:/opt/iobroker $ iobroker update
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Jemand eine Idee wo ich ansetzen kann?
    #340
    @hardy_01 naja Du kommst von der 3.1 ... Da steht oben das Du idealerweise zuerst die 3.2 installieren solltest bzw ja bei DIr wäre der direkte weg via npm der sinnvolle. Siehe letzter Post
    H 1 Antwort Letzte Antwort
    • apollon77A apollon77
      hardy_01
      #341
      @apollon77
      Habe ich probiert, bekomme leider immer noch einen Fehler (Berechtigung).
      pi@raspberrypi-iob:~ $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN checkPermissions Missing write access to /home/pi
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /home/pi
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/home/pi'
      npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/home/pi'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_06_59_453Z-debug.log
      • H hardy_01
        @apollon77
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        #342
        @hardy_01
        Du stehst im falschen Verzeichnis...
        cd /opt/iobroker
        Und dann die direkte Installation wie schon versucht.
          @hardy_01
          cd /opt/iobroker
          hardy_01
          #343
          Herzlichen Dank an alle, hat funktioniert 😊
          • J Offline
            Jack01
            schrieb am zuletzt editiert von Jack01
            #344
            Moin,
            heute habe ich mal allen Mut gefasst und auf die aktuelle Version upgedatet.
            Es sieht so aus, als ob alles funktioniert hat.
            Es allerdings ein paar Meldungen, die von dem Beispiel im ersten Thread abweichen
            pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
            Update js-controller from @3.3.22 to @4.0.21
            In file included from ../src/unix_dgram.cc:5:
            ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
            ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                 , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
            ../src/unix_dgram.cc: At global scope:
            Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
            Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
            Server Objects 127.0.0.1:41112 Error from InMemDB: Error: Unknown LUA script load
            Server Objects 127.0.0.1:41112 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
            Muss ich hier noch etwas unternehmen oder ist das so OK?
            Hans-Jürgen
            Nachtrag:
            meine Datenbanken sehen jetzt so aus:
            pi@raspberrypi:/opt/iobroker $ iob status
            Objects type: jsonl
            States  type: redis
            Proxmox LXC
            Node.js: V22.22.2
            NPM: 10.9.7
            JS-controller: 7.0.7
            • J Jack01
              Moin,
              Hans-Jürgen
              Nachtrag:
              Objects type: jsonl
              States  type: redis
              #345
              @jack01
              Schaut okay aus.
              • L Offline
                lacknelu
                schrieb am zuletzt editiert von lacknelu
                #346
                Hallo!
                Habe heute versucht auf den js-controller 4.0.x upzugraden - leider bin ich gescheitert ... Habe mich durch die infos im thread garbeitet und auch einiges ausprobiert, jedoch haben alle Lösungen nicht funktioniert bzw. immer wieder zu demselben Problem / Error geführt:
                pi@PI4IOBroker:/opt/iobroker $ iobroker upgrade self
                NPM version: 7.24.2
                 Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                 States 127.0.0.1:43884 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                 Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                 Objects 127.0.0.1:56176 Error from InMemDB: Error: scan NOT SUPPORTED
                npm ERR! code 1
                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! command failed
                npm ERR! command sh -c node iobroker.js setup first
                npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                npm ERR!         throw e;
                npm ERR!         ^
                npm ERR!
                npm ERR! ReplyError: Error scan NOT SUPPORTED
                npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                npm ERR! Emitted 'error' event on ScanStream instance at:
                npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:95:5) {
                npm ERR!   command: {
                npm ERR!     name: 'scan',
                npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                npm ERR!   }
                npm ERR! }
                npm ERR!     /home/iobroker/.npm/_logs/2022-04-01T21_26_30_838Z-debug.log
                Starting node restart.js
                Die zuletzt probierte Prozedur war folgende:
                iobroker update
                iobroker stop
                iobroker upgrade
                iobroker fix
                iobroker start
                Hat jemand eine idee woran es liegen könnte? Leider kann ich mit den Error Log auf keinen grünen Zweig kommen :-(
                Der Log beinhaltet folgendes:
                0 verbose cli [
                0 verbose cli   '/usr/local/bin/node',
                0 verbose cli   '/usr/local/bin/npm',
                0 verbose cli   'install',
                0 verbose cli   'iobroker.js-controller@4.0.21',
                0 verbose cli   '--loglevel',
                0 verbose cli   'error',
                0 verbose cli   '--unsafe-perm',
                0 verbose cli   '--prefix',
                0 verbose cli   '/opt/iobroker'
                0 verbose cli ]
                1 info using npm@7.24.2
                2 info using node@v14.19.1
                3 timing npm:load:whichnode Completed in 1ms
                4 timing config:load:defaults Completed in 5ms
                5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 4ms
                6 timing config:load:builtin Completed in 4ms
                7 timing config:load:cli Completed in 8ms
                8 timing config:load:env Completed in 0ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                10 timing config:load:project Completed in 2ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                12 timing config:load:user Completed in 1ms
                13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 0ms
                14 timing config:load:global Completed in 0ms
                15 timing config:load:validate Completed in 1ms
                16 timing config:load:credentials Completed in 3ms
                17 timing config:load:setEnvs Completed in 3ms
                18 timing config:load Completed in 28ms
                19 timing npm:load:configload Completed in 28ms
                20 timing npm:load:setTitle Completed in 0ms
                21 timing npm:load:setupLog Completed in 2ms
                22 timing config:load:flatten Completed in 9ms
                23 timing npm:load:cleanupLog Completed in 6ms
                24 timing npm:load:configScope Completed in 0ms
                25 timing npm:load:projectScope Completed in 1ms
                26 timing npm:load Completed in 47ms
                27 timing arborist:ctor Completed in 2ms
                28 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.zwave2
                29 timing idealTree:init Completed in 6038ms
                30 timing idealTree:userRequests Completed in 24ms
                31 silly idealTree buildDeps
                32 silly fetch manifest iobroker.js-controller@4.0.21
                33 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 7421ms (cache revalidated)
                34 silly placeDep ROOT iobroker.js-controller@4.0.21 REPLACE for: iobroker.inst@2.0.3 want: 4.0.21
                35 silly fetch manifest @alcalzone/esbuild-register@^2.5.1-1
                36 silly fetch manifest @iobroker/db-objects-file@4.0.21
                37 silly fetch manifest @iobroker/db-objects-jsonl@4.0.21
                38 silly fetch manifest @iobroker/db-objects-redis@4.0.21
                39 silly fetch manifest @iobroker/db-states-file@4.0.21
                40 silly fetch manifest @iobroker/db-states-jsonl@4.0.21
                41 silly fetch manifest @iobroker/db-states-redis@4.0.21
                42 silly fetch manifest @iobroker/js-controller-adapter@4.0.21
                43 silly fetch manifest @iobroker/js-controller-cli@4.0.21
                44 silly fetch manifest @iobroker/js-controller-common@4.0.21
                45 silly fetch manifest @iobroker/js-controller-common-db@4.0.21
                46 silly fetch manifest @iobroker/plugin-base@~1.2.1
                47 silly fetch manifest @iobroker/plugin-sentry@~1.2.0
                48 silly fetch manifest axios@^0.24.0
                Vielen Dank für eure Hilfe.
                LG Lukas
                Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                • crunchipC Offline
                  crunchipC Offline
                  #347
                  @lacknelu denke du müsstest erst mal dein node und npm richtig installieren
                  wenn das erledigt ist und dennoch kein upgrade funktioniert, dann im ersten Thread den Abschnitt "Bei Fehlern:" nochmal lesen
                  • L lacknelu
                    Hallo!
                    NPM version: 7.24.2
                    npm ERR! code 1
                    npm ERR!         throw e;
                    npm ERR!         ^
                    npm ERR!
                    npm ERR!   command: {
                    npm ERR!   }
                    npm ERR! }
                    iobroker update
                    iobroker stop
                    iobroker upgrade
                    iobroker fix
                    iobroker start
                    0 verbose cli [
                    0 verbose cli ]
                    LG Lukas
                    #348
                    @lacknelu
                    Ja, nodeJS und das Drumherum ist komplett schief.
                    Das zuerst in Ordnung bringen. Siehe in meiner Signatur.
                    • L lacknelu
                      Hallo!
                      NPM version: 7.24.2
                      npm ERR! code 1
                      npm ERR!         throw e;
                      npm ERR!         ^
                      npm ERR!
                      npm ERR!   command: {
                      npm ERR!   }
                      npm ERR! }
                      iobroker update
                      iobroker stop
                      iobroker upgrade
                      iobroker fix
                      iobroker start
                      0 verbose cli [
                      0 verbose cli ]
                      LG Lukas
                      #349
                      @lacknelu naja, du springst von der 3.1 über 3.2 und 3.3 zur 4.0 ... das ist ein "weiterer Weg" ... lies mal oben im ersten Post ... Mach einen "npm" install des 4er controller wie oben angegeben dann geht es auch
                      PS: Hättest auch einfach mal ein paar Posts nach oben scrollen können, da gabs schon einen zweiten User mit genau dem gleichen problem :-(
                        Aiouh
                        #350
                        Mein Update ist absolut problemlos gelaufen, wieder einmal prima Arbeit von den Verantwortlichen. DANKE dafür.
                        Eine Frage habe ich aber noch - Ich bekomme seit dem Update die Meldung
                        influxdb.0 2022-04-02 17:38:44.229	warn	No connection to DB
                        Das ist erst einmal nicht tragisch, da ich eigentlich nur noch die influxdb.1 benutze. Die influxdb.0 zeigt auf eine externe db die es seit kurzem nicht mehr gibt und nicht mehr genutzt wird. Bisher hatte ich dazu keine Fehlermeldungen bekommen, erst nach dem Update.
                        Meine Frage ist nun wie ich herausbekommen kann ob ich doch noch Objekte mit der alten influxdb.0 verknüpft habe.
                        Würde ich Fehlermeldungen bekommen wenn dem so wäre? Dann lege ich mich dazu gleich wieder ganz beruhigt hin.
                        apollon77A E 2 Antworten Letzte Antwort
                        • A Aiouh
                          #351
                          @aiouh sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                          Wie meinst Du das?
                          • A Aiouh
                            Einstein67
                            schrieb am zuletzt editiert von Einstein67
                            #352
                            @aiouh said in js-controller 4.0.x jetzt für alle User im STABLE!:
                            Einfach die Objekte öffnen und dann rechts oben bei Einstellungen "influxdb.0" auswählen.
                            Dann werden nur mehr Objekte angezeigt, die nach influxdb.0 speichern.
                            • L Offline
                              lacknelu
                              #353
                              @apollon77, @Thomas Braun, @crunchip
                              Danke für eure Unterstützung. Bin noch einmal alles durchgegangen und habe Node richtig gestellt. Zwischenzeitlich ist dann nichts mehr gegangen weil ich einfach leider viel zu wenig über die Thematik verstehe 😞
                              IOBroker läuft mittlerweile wieder und ich upgrade mich sukzessive in Richtung 4.X
                              Danke & LG
                              Lukas
                                Wie meinst Du das?
                                Aiouh
                                #354
                                @apollon77
                                Wie meine ich das: Ich habe in den Anfängen meines ioBroker bei einigen Objekten die influxdb.0 als history DB verwendet.
                                Ich habe dann auf die lokale influxdb.1 umgestellt und "glaube" auch, dass ich alle Objekte umgestellt habe, ich bin mir aber eben leider nicht sicher.
                                Bevor ich nun irgendwann eine Überraschung erlebe dass die history Daten eines Objekts fehlen dachte ich mir es wäre gut wenn ich, ohne jedes Objekt einzeln zu öffnen, irgendwie eine Übersicht ziehen könnte welches Objekt welcher influxdb zugeordnet ist.
                                Ich hoffe das war klarer ausgedrückt.
                                • A Aiouh
                                  @apollon77
                                  #355
                                  @aiouh Jupp danke. @Einstein67 hatte doch ja wohl dann richtig verstanden :-)
                                  • F Offline
                                    flubb
                                    #356
                                    habe noch eine etwas ältere Installation am laufen (js-controller 2.x) und würde diese gern updaten. Wie empfohlen würde ich das gerne über einen Zwischenstopp bei der 3.3 machen und dann erstmal Node.js updaten.
                                    Leider scheitere ich jedoch bei der Installation vom js-controller 3.3:
                                    pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@3.3
                                    npm ERR! code ENOTSUP
                                    npm ERR! notsup Unsupported engine for winston@3.7.2: wanted: {"node":">= 12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
                                    npm ERR! notsup Not compatible with your version of node/npm: winston@3.7.2
                                    npm ERR! notsup Required: {"node":">= 12.0.0"}
                                    npm ERR! notsup Actual:   {"npm":"6.13.4","node":"10.18.1"}
                                    npm ERR!     /home/pi/.npm/_logs/2022-04-07T18_31_35_248Z-debug.log
                                    Dachte der js-controller 3.3 ist noch mit Node.js 10 kompatibel? Der Versuch auf den js.controller 3.2 upzudaten führt zum gleichen Problem. Hat jmd. einen Tipp für mich?
                                    • F flubb
                                      #357
                                      @flubb
                                      Installier doch zunächst eine aktuelle nodeJS-Version?
                                      Ich würde gleich auf node14 gehen.
                                      • F flubb
                                        #358
                                        @flubb alternativ geh über die 3.2 vom Controller.
                                          Sonnenkind
                                          #359
                                          Hallo in die Runde,
                                          ich hätte mal folgende Frage, wollte jetzt auch updaten, dabei kommt bei der Abfrage von Node und Node js immer die gleiche Version 14.19.1 wie in derInfo angezeigt, aber gleichzeitig sagt er da mein Host ist noch a3376e83-d290-40af-a6a4-4d23d030e639-image.png
                                          das verstehe ich nicht ganz , bin abernoch immer kein Linux Profi eventuell würde mir jemand einen Tip geben können?
                                          Danke schon mal ?Ach es läuft eigentlich alles soweit, lediglich der matt leget keine Objekte an aber das nur nebenbei muss auch damit nix zu tun haben.Danke auf jeden Fall und einen schönen Sonntag noch
