  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 200.3k Aufrufe 58 Beobachtet
  • apollon77A apollon77
    @crunchip das du vllt nen Bug gefunden hast. GitHub issue bitte
    hardy_01
    schrieb am zuletzt editiert von hardy_01
    #337
    Bei mir hat sich beim Update irgendwas aufgehangen. Seit dem ist der broker nicht mehr erreichbar
    pi@raspberrypi-iob:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @4.0.21
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../../nan/nan.h:56,
                     from ../src/unix_dgram.cc:5:
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
     Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
     States 127.0.0.1:38688 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
     Objects 127.0.0.1:53902 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
     Objects 127.0.0.1:53902 Error from InMemDB: Error: scan NOT SUPPORTED
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    ReplyError: Error scan NOT SUPPORTED
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:95:5) {
      command: {
        args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T16_38_52_007Z-debug.log
    host.raspberrypi-iob Cannot install iobroker.js-controller@4.0.21: 1
    iobroker update bringt
    pi@raspberrypi-iob:/opt/iobroker $ iobroker update
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Jemand eine Idee wo ich ansetzen kann?
    H apollon77A 2 Antworten Letzte Antwort
    • H hardy_01
              throw e;
        command: {
      npm ERR! errno 1
      npm ERR!
        throw err;
        requireStack: []
      hardy_01
      #338
      @hardy_01 said in js-controller 4.0.x jetzt für alle User im STABLE!:
              throw e;
        command: {
      npm ERR! errno 1
      npm ERR!
        throw err;
        requireStack: []
      pi@raspberrypi-iob:/opt/iobroker $ iobroker start
      pi@raspberrypi-iob:/opt/iobroker $ iobroker fix
      library: loaded
      Library version=2022-02-10
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      • H hardy_01
                throw e;
          command: {
        npm ERR! errno 1
        npm ERR!
          throw err;
          requireStack: []
        library: loaded
        crunchipC Offline
        crunchipC Offline
        #339
        @hardy_01
        Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen.
        • H hardy_01
                  throw e;
            command: {
          npm ERR! errno 1
          npm ERR!
            throw err;
            requireStack: []
          #340
          @hardy_01 naja Du kommst von der 3.1 ... Da steht oben das Du idealerweise zuerst die 3.2 installieren solltest bzw ja bei DIr wäre der direkte weg via npm der sinnvolle. Siehe letzter Post
          H 1 Antwort Letzte Antwort
            hardy_01
            #341
            @apollon77
            Habe ich probiert, bekomme leider immer noch einen Fehler (Berechtigung).
            pi@raspberrypi-iob:~ $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN checkPermissions Missing write access to /home/pi
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm WARN pi No description
            npm WARN pi No repository field.
            npm WARN pi No README data
            npm WARN pi No license field.
            npm ERR! code EACCES
            npm ERR! syscall access
            npm ERR! path /home/pi
            npm ERR! errno -13
            npm ERR! Error: EACCES: permission denied, access '/home/pi'
            npm ERR!  [Error: EACCES: permission denied, access '/home/pi'] {
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'access',
            npm ERR!   path: '/home/pi'
            npm ERR! }
            npm ERR!
            npm ERR! The operation was rejected by your operating system.
            npm ERR! It is likely you do not have the permissions to access this file as the current user
            npm ERR!
            npm ERR! If you believe this might be a permissions issue, please double-check the
            npm ERR! permissions of the file and its containing directories, or try running
            npm ERR! the command again as root/Administrator.
            npm ERR!     /home/iobroker/.npm/_logs/2022-03-29T20_06_59_453Z-debug.log
            • H hardy_01
              @apollon77
              npm ERR! errno -13
              npm ERR! }
              npm ERR!
              npm ERR!
              #342
              @hardy_01
              Du stehst im falschen Verzeichnis...
              cd /opt/iobroker
              Und dann die direkte Installation wie schon versucht.
                @hardy_01
                cd /opt/iobroker
                hardy_01
                #343
                Herzlichen Dank an alle, hat funktioniert 😊
                • J Offline
                  Jack01
                  schrieb am zuletzt editiert von Jack01
                  #344
                  Moin,
                  heute habe ich mal allen Mut gefasst und auf die aktuelle Version upgedatet.
                  Es sieht so aus, als ob alles funktioniert hat.
                  Es allerdings ein paar Meldungen, die von dem Beispiel im ersten Thread abweichen
                  pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
                  Update js-controller from @3.3.22 to @4.0.21
                  In file included from ../src/unix_dgram.cc:5:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  ../src/unix_dgram.cc: At global scope:
                  Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                  Server Objects 127.0.0.1:41112 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                  Server Objects 127.0.0.1:41112 Error from InMemDB: Error: Unknown LUA script load
                  Server Objects 127.0.0.1:41112 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                  Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                  Muss ich hier noch etwas unternehmen oder ist das so OK?
                  Hans-Jürgen
                  Nachtrag:
                  meine Datenbanken sehen jetzt so aus:
                  pi@raspberrypi:/opt/iobroker $ iob status
                  Objects type: jsonl
                  States  type: redis
                  Proxmox LXC
                  Node.js: V22.22.2
                  NPM: 10.9.7
                  JS-controller: 7.0.7
                  • J Jack01
                    Moin,
                    Hans-Jürgen
                    Nachtrag:
                    Objects type: jsonl
                    States  type: redis
                    #345
                    @jack01
                    Schaut okay aus.
                    • L Offline
                      lacknelu
                      schrieb am zuletzt editiert von lacknelu
                      #346
                      Hallo!
                      Habe heute versucht auf den js-controller 4.0.x upzugraden - leider bin ich gescheitert ... Habe mich durch die infos im thread garbeitet und auch einiges ausprobiert, jedoch haben alle Lösungen nicht funktioniert bzw. immer wieder zu demselben Problem / Error geführt:
                      pi@PI4IOBroker:/opt/iobroker $ iobroker upgrade self
                      NPM version: 7.24.2
                       Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                       States 127.0.0.1:43884 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                       Objects 127.0.0.1:56176 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                       Objects 127.0.0.1:56176 Error from InMemDB: Error: scan NOT SUPPORTED
                      npm ERR! code 1
                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! command failed
                      npm ERR! command sh -c node iobroker.js setup first
                      npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                      npm ERR!         throw e;
                      npm ERR!         ^
                      npm ERR!
                      npm ERR! ReplyError: Error scan NOT SUPPORTED
                      npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                      npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                      npm ERR! Emitted 'error' event on ScanStream instance at:
                      npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                      npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                      npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                      npm ERR!     at processTicksAndRejections (internal/process/task_queues.js:95:5) {
                      npm ERR!   command: {
                      npm ERR!     name: 'scan',
                      npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
                      npm ERR!   }
                      npm ERR! }
                      npm ERR!     /home/iobroker/.npm/_logs/2022-04-01T21_26_30_838Z-debug.log
                      Starting node restart.js
                      Die zuletzt probierte Prozedur war folgende:
                      iobroker update
                      iobroker stop
                      iobroker upgrade
                      iobroker fix
                      iobroker start
                      Hat jemand eine idee woran es liegen könnte? Leider kann ich mit den Error Log auf keinen grünen Zweig kommen :-(
                      Der Log beinhaltet folgendes:
                      0 verbose cli [
                      0 verbose cli   '/usr/local/bin/node',
                      0 verbose cli   '/usr/local/bin/npm',
                      0 verbose cli   'install',
                      0 verbose cli   'iobroker.js-controller@4.0.21',
                      0 verbose cli   '--loglevel',
                      0 verbose cli   'error',
                      0 verbose cli   '--unsafe-perm',
                      0 verbose cli   '--prefix',
                      0 verbose cli   '/opt/iobroker'
                      0 verbose cli ]
                      1 info using npm@7.24.2
                      2 info using node@v14.19.1
                      3 timing npm:load:whichnode Completed in 1ms
                      4 timing config:load:defaults Completed in 5ms
                      5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 4ms
                      6 timing config:load:builtin Completed in 4ms
                      7 timing config:load:cli Completed in 8ms
                      8 timing config:load:env Completed in 0ms
                      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
                      10 timing config:load:project Completed in 2ms
                      11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                      12 timing config:load:user Completed in 1ms
                      13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 0ms
                      14 timing config:load:global Completed in 0ms
                      15 timing config:load:validate Completed in 1ms
                      16 timing config:load:credentials Completed in 3ms
                      17 timing config:load:setEnvs Completed in 3ms
                      18 timing config:load Completed in 28ms
                      19 timing npm:load:configload Completed in 28ms
                      20 timing npm:load:setTitle Completed in 0ms
                      21 timing npm:load:setupLog Completed in 2ms
                      22 timing config:load:flatten Completed in 9ms
                      23 timing npm:load:cleanupLog Completed in 6ms
                      24 timing npm:load:configScope Completed in 0ms
                      25 timing npm:load:projectScope Completed in 1ms
                      26 timing npm:load Completed in 47ms
                      27 timing arborist:ctor Completed in 2ms
                      28 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.zwave2
                      29 timing idealTree:init Completed in 6038ms
                      30 timing idealTree:userRequests Completed in 24ms
                      31 silly idealTree buildDeps
                      32 silly fetch manifest iobroker.js-controller@4.0.21
                      33 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 7421ms (cache revalidated)
                      34 silly placeDep ROOT iobroker.js-controller@4.0.21 REPLACE for: iobroker.inst@2.0.3 want: 4.0.21
                      35 silly fetch manifest @alcalzone/esbuild-register@^2.5.1-1
                      36 silly fetch manifest @iobroker/db-objects-file@4.0.21
                      37 silly fetch manifest @iobroker/db-objects-jsonl@4.0.21
                      38 silly fetch manifest @iobroker/db-objects-redis@4.0.21
                      39 silly fetch manifest @iobroker/db-states-file@4.0.21
                      40 silly fetch manifest @iobroker/db-states-jsonl@4.0.21
                      41 silly fetch manifest @iobroker/db-states-redis@4.0.21
                      42 silly fetch manifest @iobroker/js-controller-adapter@4.0.21
                      43 silly fetch manifest @iobroker/js-controller-cli@4.0.21
                      44 silly fetch manifest @iobroker/js-controller-common@4.0.21
                      45 silly fetch manifest @iobroker/js-controller-common-db@4.0.21
                      46 silly fetch manifest @iobroker/plugin-base@~1.2.1
                      47 silly fetch manifest @iobroker/plugin-sentry@~1.2.0
                      48 silly fetch manifest axios@^0.24.0
                      Vielen Dank für eure Hilfe.
                      LG Lukas
                      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                      • crunchipC Offline
                        crunchipC Offline
                        #347
                        @lacknelu denke du müsstest erst mal dein node und npm richtig installieren
                        wenn das erledigt ist und dennoch kein upgrade funktioniert, dann im ersten Thread den Abschnitt "Bei Fehlern:" nochmal lesen
                        • L lacknelu
                          Hallo!
                          NPM version: 7.24.2
                          npm ERR! code 1
                          npm ERR!         throw e;
                          npm ERR!         ^
                          npm ERR!
                          npm ERR!   command: {
                          npm ERR!   }
                          npm ERR! }
                          iobroker update
                          iobroker stop
                          iobroker upgrade
                          iobroker fix
                          iobroker start
                          0 verbose cli [
                          0 verbose cli ]
                          LG Lukas
                          #348
                          @lacknelu
                          Ja, nodeJS und das Drumherum ist komplett schief.
                          Das zuerst in Ordnung bringen. Siehe in meiner Signatur.
                          • L lacknelu
                            Hallo!
                            NPM version: 7.24.2
                            npm ERR! code 1
                            npm ERR!         throw e;
                            npm ERR!         ^
                            npm ERR!
                            npm ERR!   command: {
                            npm ERR!   }
                            npm ERR! }
                            iobroker update
                            iobroker stop
                            iobroker upgrade
                            iobroker fix
                            iobroker start
                            0 verbose cli [
                            0 verbose cli ]
                            LG Lukas
                            #349
                            @lacknelu naja, du springst von der 3.1 über 3.2 und 3.3 zur 4.0 ... das ist ein "weiterer Weg" ... lies mal oben im ersten Post ... Mach einen "npm" install des 4er controller wie oben angegeben dann geht es auch
                            PS: Hättest auch einfach mal ein paar Posts nach oben scrollen können, da gabs schon einen zweiten User mit genau dem gleichen problem :-(
                              Aiouh
                              #350
                              Mein Update ist absolut problemlos gelaufen, wieder einmal prima Arbeit von den Verantwortlichen. DANKE dafür.
                              Eine Frage habe ich aber noch - Ich bekomme seit dem Update die Meldung
                              influxdb.0 2022-04-02 17:38:44.229	warn	No connection to DB
                              Das ist erst einmal nicht tragisch, da ich eigentlich nur noch die influxdb.1 benutze. Die influxdb.0 zeigt auf eine externe db die es seit kurzem nicht mehr gibt und nicht mehr genutzt wird. Bisher hatte ich dazu keine Fehlermeldungen bekommen, erst nach dem Update.
                              Meine Frage ist nun wie ich herausbekommen kann ob ich doch noch Objekte mit der alten influxdb.0 verknüpft habe.
                              Würde ich Fehlermeldungen bekommen wenn dem so wäre? Dann lege ich mich dazu gleich wieder ganz beruhigt hin.
                              apollon77A E 2 Antworten Letzte Antwort
                              • A Aiouh
                                #351
                                @aiouh sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                Wie meinst Du das?
                                • A Aiouh
                                  Einstein67
                                  schrieb am zuletzt editiert von Einstein67
                                  #352
                                  @aiouh said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                  Einfach die Objekte öffnen und dann rechts oben bei Einstellungen "influxdb.0" auswählen.
                                  Dann werden nur mehr Objekte angezeigt, die nach influxdb.0 speichern.
                                  • L Offline
                                    lacknelu
                                    #353
                                    @apollon77, @Thomas Braun, @crunchip
                                    Danke für eure Unterstützung. Bin noch einmal alles durchgegangen und habe Node richtig gestellt. Zwischenzeitlich ist dann nichts mehr gegangen weil ich einfach leider viel zu wenig über die Thematik verstehe 😞
                                    IOBroker läuft mittlerweile wieder und ich upgrade mich sukzessive in Richtung 4.X
                                    Danke & LG
                                    Lukas
                                      Wie meinst Du das?
                                      Aiouh
                                      #354
                                      @apollon77
                                      Wie meine ich das: Ich habe in den Anfängen meines ioBroker bei einigen Objekten die influxdb.0 als history DB verwendet.
                                      Ich habe dann auf die lokale influxdb.1 umgestellt und "glaube" auch, dass ich alle Objekte umgestellt habe, ich bin mir aber eben leider nicht sicher.
                                      Bevor ich nun irgendwann eine Überraschung erlebe dass die history Daten eines Objekts fehlen dachte ich mir es wäre gut wenn ich, ohne jedes Objekt einzeln zu öffnen, irgendwie eine Übersicht ziehen könnte welches Objekt welcher influxdb zugeordnet ist.
                                      Ich hoffe das war klarer ausgedrückt.
                                      • A Aiouh
                                        @apollon77
                                        #355
                                        @aiouh Jupp danke. @Einstein67 hatte doch ja wohl dann richtig verstanden :-)
                                        • F Offline
                                          flubb
                                          #356
                                          habe noch eine etwas ältere Installation am laufen (js-controller 2.x) und würde diese gern updaten. Wie empfohlen würde ich das gerne über einen Zwischenstopp bei der 3.3 machen und dann erstmal Node.js updaten.
                                          Leider scheitere ich jedoch bei der Installation vom js-controller 3.3:
                                          pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@3.3
                                          npm ERR! code ENOTSUP
                                          npm ERR! notsup Unsupported engine for winston@3.7.2: wanted: {"node":">= 12.0.0"} (current: {"node":"10.18.1","npm":"6.13.4"})
                                          npm ERR! notsup Not compatible with your version of node/npm: winston@3.7.2
                                          npm ERR! notsup Required: {"node":">= 12.0.0"}
                                          npm ERR! notsup Actual:   {"npm":"6.13.4","node":"10.18.1"}
                                          npm ERR!     /home/pi/.npm/_logs/2022-04-07T18_31_35_248Z-debug.log
                                          Dachte der js-controller 3.3 ist noch mit Node.js 10 kompatibel? Der Versuch auf den js.controller 3.2 upzudaten führt zum gleichen Problem. Hat jmd. einen Tipp für mich?
