TESTER: Neuer Adapter Webuntis
Hi!
Ich schaffe es leider in beide meiner Schulen meiner Kinder mich nicht einzuloggen mit dem Adapter, Hier das Log:
Wer eine Idee?host.raspberrypi 2022-03-30 12:42:27.830 error instance system.adapter.webuntis.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND) webuntis.0 2022-03-30 12:42:27.116 warn Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason webuntis.0 2022-03-30 12:42:27.056 error adapter disabled host.raspberrypi 2022-03-30 12:41:57.638 info "system.adapter.webuntis.0" disabled host.raspberrypi 2022-03-30 12:41:54.661 info Restart adapter system.adapter.webuntis.0 because enabled host.raspberrypi 2022-03-30 12:41:54.660 error instance system.adapter.webuntis.0 terminated with code 6 (UNCAUGHT_EXCEPTION) webuntis.0 2022-03-30 12:41:53.981 warn Terminated (UNCAUGHT_EXCEPTION): Without reason webuntis.0 2022-03-30 12:41:53.980 info terminating webuntis.0 2022-03-30 12:41:53.968 error Server didn't returned any result. webuntis.0 2022-03-30 12:41:53.967 error Error: Server didn't returned any result. at WebUntis._request (/opt/iobroker/node_modules/webuntis/index.js:643:42) at processTicksAndRejections (internal/process/task_queues.js:97:5) at async WebUntis.getOwnTimetableForToday (/opt/iobroker/node_modules/webuntis/index.js:300:16) webuntis.0 2022-03-30 12:41:53.966 error unhandled promise rejection: Server didn't returned any result. webuntis.0 2022-03-30 12:41:53.965 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). webuntis.0 2022-03-30 12:41:53.629 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.webuntis, node: v12.22.6, js-controller: 4.0.21 host.raspberrypi 2022-03-30 12:41:51.171 info instance system.adapter.webuntis.0 started with pid 6637 host.raspberrypi 2022-03-30 12:41:50.811 info "system.adapter.webuntis.0" enabled host.raspberrypi 2022-03-30 12:41:29.084 info "system.adapter.webuntis.0" disabled host.raspberrypi 2022-03-30 12:41:25.704 info Restart adapter system.adapter.webuntis.0 because enabled host.raspberrypi 2022-03-30 12:41:25.703 error instance system.adapter.webuntis.0 terminated with code 6 (UNCAUGHT_EXCEPTION) webuntis.0 2022-03-30 12:41:24.980 warn Terminated (UNCAUGHT_EXCEPTION): Without reason webuntis.0 2022-03-30 12:41:24.979 info terminating webuntis.0 2022-03-30 12:41:24.965 error Server didn't returned any result. webuntis.0 2022-03-30 12:41:24.965 error Error: Server didn't returned any result. at WebUntis._request (/opt/iobroker/node_modules/webuntis/index.js:643:42) at processTicksAndRejections (internal/process/task_queues.js:97:5) at async WebUntis.getOwnTimetableForToday (/opt/iobroker/node_modules/webuntis/index.js:300:16) webuntis.0 2022-03-30 12:41:24.964 error unhandled promise rejection: Server didn't returned any result. webuntis.0 2022-03-30 12:41:24.963 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). webuntis.0 2022-03-30 12:41:24.485 info -
Hallo zusammen und erstmal vielen Dank für den Adapter
Im zweiten Anlauf hat es nun geklappt und ich wollte kurz schildern welches Problem ich hatte. Vielleicht hilft es ja.
Warum es nun geht kann ich auch nur vermuten.Adapter-Version 0.3.2
- Also ich habe 2 Kinder an der selben Schule > ergo 2 Webuntis Zugänge
- Basic-URL und Schul-Secret "ermittelt" und Zugangsdaten für erstes Kind in Instanz hinterlegt
- Anmeldung schlug fehl wegen "Error: Failed to login. {"jsonrpc":"2.0","id":"Awesome","error":{"message":"bad credentials","code":-8504}}"
- alles geprüft > Daten passen
- zweites Kind eingetragen > funktionierte sofort
- Unterschied zwischen Kind1 und Kind2 ist nur, dass bei Kind1 ein Underline im Nutzernamen steht, also abc_abc und bei Kind2 nicht!
Kann es da Probleme mit "_" geben? Hat das schonmal jemand anderes Probleme damit?
Hi!
Also, ich habe mich ein wenig beschäftigt und mein erstes Kind "funktioniert" und der Stundenplan ist fertig (siehe Bild)
Habe nun eine 2. Instanz für meine Tochter installiert, hier komme ich aber nicht rein:
Irgendwer eine Idee?
Liebe Grüße
Jürgen -
Hi!
Liebe Grüße
Jürgen -
@jwedenig habe nie 2 Instanzen getestet. Check mal ob die erste mit den Daten der 2. läuft. Dann wäre der Account funktional.
@newan
Hi!Nein, der Zugang meiner Tochter funktioniert auch mit der ersten Instanz nicht!
@jwedenig versuch mal das 2. Kind in der instanz 0 einzutragen, ob das geht.
Ich hatte ja weiter oben beschrieben, dass ich bei Kind1 mit dem "_" im Probleme hatte.
Danach habe ich in der gleichen Instanz die Benutzerdaten gegen die von Kind2 getauscht und das ging sofort.
Jetzt habe ich nochmal versucht wieder auf Kind1 (pure Neugier) zu wechseln und siehe da nun ging auch Kind1. Vorher habe ich die Instanz gestoppt und den ganzen Objektbaum gelöscht, um sauber zu starten.
Keine Ahnung warum, aber es lag definitiv nicht an nem falschen Passwort oder so, die hole ich mir direkt aus meinem Passwort-Manager.
@Newan ich kann Dir gern noch die Anmeldedaten zusenden, aber mittlerweile geht das ja mit dem "_" im Anmeldenamen von Kind1.
@friesenjung
Hi!Ja, wie schon gesagt funktioniert der Zugang meiner Tochter bei keiner Instanz, und "_" gibt es auch nicht im Benutzernamen
@newan
Ich habe einen "-" im Schulnamen, könnte das das Problem sein?
Wenn ich statt dem "-" ein Leerzeichen schreibe, habe ich grünen Hacken genau umgekehrt, sprich Verbunden mit Host und Lebenszeichen sind grün, aber Verbunden mit Gerät oder Dienst hat ein rotes Kreuz! -
@newan
Hi danke für diesen Adapter. Ich würde mich freuen wenn man den Stundenplan für die komplette aktuelle Woche (Mo-So) abrufen kann. Da ich in die Abendschule gehe und leider jeden Tag unter der Woche Schule habe. Es aber meistens schon 4 Tage vorher bekannt ist wenn ein Unterricht entfällt oder online stattfindet.
Des weiteren ist mir bei der Instalation noch ein Fehler in der Doku aufgefallen der nicht ganz schlüssig ist.
@larrysansan sagte in TESTER: Neuer Adapter Webuntis:
...Des weiteren ist mir bei der Instalation noch ein Fehler in der Doku aufgefallen der nicht ganz schlüssig ist.
Das passt schon so.
Wenn im Schoolsecret ein "-" steht wird dies 1:1 so übernommen.
Sollte ein "+" im Schoolsecret stehen sollte muss das "+" durch ein Leerzeichen " " ersetzt werden. -
Das passt schon so.
Sollte ein "+" im Schoolsecret stehen sollte muss das "+" durch ein Leerzeichen " " ersetzt werden.Hallo zusammen,
hat es schon jemand hinbekommen eine ganze Woche darzustellen?
Was bei mir auch noch nicht funktioniert ist die Anzeige des jeweiligen Wochentags oberhalb der Untis Tabelle. Wie habt ihr das umgesetzt?
Ansonsten: Coole Idee das so darzustellen. Ich benutze das mit einem Samsung Tablett mit FullyBrowser.Andreas
Hallo Newan,
vielen Dank für Deinen Adapter. Ich habe nun auch WebUntis-Zugangsdaten und sie direkt im Adapter eingetragen. Das sieht soweit auch gut aus:
Wenn ich speichere und schließe, bin ich jedoch etwas irritiert:
In den Objekten wird zwar etwas angezeigt, aber so recht bin ich mir nicht sicher ob das so richtig und vollständig ist:
Also, der Eintrag erscheint wirklich auf der "Heute"-Seite_
Wie komme ich denn nun an den Stundenplan und seine Änderungen?
Vielen Dank
Martin
@wowbagger Nein ganze Woche geht nicht, hatte bisher die Anforderung nicht. Wenn da bedarf besteht, bitte Request auf github
Hallo Newan,
Vielen Dank
Martin
@martin-72 Sieht nach einem Fehler im Log etc aus, am besten mal log prüfen oder hier posten
