  4. Test Adapter wireless-mbus v0.13.x
mbuswirelesswm-buswmbus
597 Beiträge 70 Kommentatoren 301.2k Aufrufe 55 Beobachtet
  • G gerald123
    @michi_pi
    Ich habe genau die gleichen Einstellungen auf meinem Testsystem eingestellt, leider bekomme ich keine Verbindung zum Wasserzähler.
    Im Log ist nach dem Starten folgendes und dann kommt nichts mehr:
    2022-03-01 17:14:12.865 - info: host.raspberrypi "system.adapter.wireless-mbus.0" enabled
    2022-03-01 17:14:12.967 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 started with pid 3008
    2022-03-01 17:14:16.102 - warn: wireless-mbus.0 (3008) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
    2022-03-01 17:14:16.110 - warn: wireless-mbus.0 (3008) This object will not be created in future versions. Please report this to the developer.
    2022-03-01 17:14:16.145 - info: wireless-mbus.0 (3008) starting. Version 0.7.7 (non-npm: lvogt/ioBroker.wireless-mbus#32679a612e4f3c02184035bd12d7fcaad4840ff1) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.15
    2022-03-01 17:18:56.607 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
    2022-03-01 17:18:56.607 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277506 ms: Scavenge 229.5 (231.8) -> 228.6 (231.8) MB, 11.5 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.608 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277660 ms: Scavenge 229.4 (231.8) -> 228.6 (232.0) MB, 14.3 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.611 - error: host.raspberrypi Caught by controller[0]: [3008:0x4a1cd40] 277800 ms: Scavenge 229.4 (232.0) -> 228.7 (232.0) MB, 4.3 / 0.0 ms (average mu = 0.183, current mu = 0.146) task
    2022-03-01 17:18:56.612 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
    2022-03-01 17:18:56.613 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    2022-03-01 17:18:56.614 - warn: host.raspberrypi instance system.adapter.wireless-mbus.0 terminated due to SIGABRT
    2022-03-01 17:18:56.614 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 terminated with code NaN ()
    2022-03-01 17:18:56.615 - info: host.raspberrypi Restart adapter system.adapter.wireless-mbus.0 because enabled
    2022-03-01 17:19:26.671 - info: host.raspberrypi instance system.adapter.wireless-mbus.0 started with pid 3042
    2022-03-01 17:19:29.393 - warn: wireless-mbus.0 (3042) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
    2022-03-01 17:19:29.402 - warn: wireless-mbus.0 (3042) This object will not be created in future versions. Please report this to the developer.
    2022-03-01 17:19:29.432 - info: wireless-mbus.0 (3042) starting. Version 0.7.7 (non-npm: lvogt/ioBroker.wireless-mbus#32679a612e4f3c02184035bd12d7fcaad4840ff1) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.15
    L
    L
    lvogt
    #216
    in letzter Zeit hatte ich nicht so viel Zeit. Ich versuche mal eine Runde Antwort zu verteilen:
    @gerald123 said in Test Adapter wireless-mbus v0.7.x:
    Da sieht für mich auch nach irgendeinem grundsätzlichen Hardware oder ioBroker Problem aus. Da kann ich glaube ich nicht weiterhelfen. Aber ein Pi 3B+ sollte auf jeden Fall reichen...
    @hkf8770 said in Test Adapter wireless-mbus v0.7.x:
    Bekomme gerade den folgenden Fehler.
    Meien datenpunkte habe ich, sprich die Verbindung Gerät über IM871A-USB zu meinem Rasberry steht. Hat einer eine Idee?
    Das heißt, dass der Adapter nicht "alle Details" des Telegramms auswerten konnte. Evtl. ist das auch nicht wirklich wichtig. Könnte aber auch tatsächlich zu falschen Werten führen. Kommt darauf was der Hersteller da in einem (vermutlich nicht standard-konformen) VIFE verpackt hat.
    Wenn du mir mal mit Hilfe des Debug-Logs einen Auszug der auch das ganze Telegramm enthält zukommen lässt kann ich evtl. versuchen daran was zu machen. Natürlich alles ohne Garantie.
    Dass die Fehlermeldung kontinuierlich im Log auftaucht ist natürlich nicht so gut. Da muss ich mal grundsätzlich noch etwas dran drehen wie geloggt wird.
    @martybr said in Test Adapter wireless-mbus v0.7.x:
    Nun habe ich Wasser Nord (Berliner Umland) angeschrieben mit der Bitte, mir den AES Key mitzuteilen. Das war leider erfolglos.
    Ob der HYDRUS 2 (mit AES Key) was brauchbares liefert weiß ich nicht genau (mein Tipp wäre, ja), aber ich kann mich nur nochmal wiederholen, ohne AES Key geht gar nichts.
    @damian-kazimierczak said in Test Adapter wireless-mbus v0.7.x:
    Was denkst du über M-BUS S?
    Das ist ein (Kabel)M-Bus Master. Was hat das mit WM-Bus und insbesondere mit diesem Adapter zu tun?
    G 1 Antwort Letzte Antwort
    • hg6806H
      hg6806H
      hg6806
      schrieb am zuletzt editiert von hg6806
      #217
      So, ich hatte das mal mit den nanoCUL und iPerl Sensus gestartet, leider bekomme ich keine Daten.
      Ich habe das wmbusmeter Zeug gestoppt, der Stick wurde von dem Adapter auch erkannt.
      AES Schlüssel ist eingegeben. Baudrate 9600 gesetzt
      Hier die Log Ausgabe:
      wireless-mbus.0	2022-03-19 08:44:51.683	info	(16651) starting. Version 0.7.7 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.0, js-controller: 4.0.18
      wireless-mbus.0	2022-03-19 08:44:51.647	warn	(16651) This object will not be created in future versions. Please report this to the developer.
      wireless-mbus.0	2022-03-19 08:44:51.642	warn	(16651) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
      Hat jemand eine Idee?
      L 1 Antwort Letzte Antwort
      • hg6806H hg6806
        L
        L
        lvogt
        #218
        @hg6806
        Ich denke die Kommunikation zum Stick klappt nicht. Stell das Logging für den Adapter mal auf Debug. Dann gibts vermutlich mehr Hinweise
        • L lvogt
          G
          G
          gerald123
          #219
          @lvogt
          Hab jetzt nochmals alles neu aufgesetzt, leider immer mit dem gleichen Ergebnis .
          Werde dann hier noch weiter mitlesen, vielleicht gibt es ja noch Infos wo es bei mir scheitert.
          Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
          L hg6806H 2 Antworten Letzte Antwort
          • G gerald123
            @lvogt
            L
            L
            lvogt
            #220
            @gerald123
            Nur mal zur Sicherheit: Dein Logauszug war auf debug Level? Falls nicht, bitte mal noch prüfen ob es damit ein paar mehr Ausgaben gibt.
            • G gerald123
              @lvogt
              hg6806H
              hg6806H
              hg6806
              #221
              @gerald123
              Hier das Log im Debug Modus. Sieht meiner Meinung nach auch unauffällig aus.
              wireless-mbus.0	2022-03-21 20:04:02.241	debug	(15755) connected set to true
              wireless-mbus.0	2022-03-21 20:04:02.193	debug	(15755) connected set to true
              wireless-mbus.0	2022-03-21 20:04:02.163	debug	(15755) CUL: Receiver set to T-MODE and data reporting with RSSI
              wireless-mbus.0	2022-03-21 20:04:02.107	debug	(15755) Created device of type: CUL (untested)
              wireless-mbus.0	2022-03-21 20:04:01.984	info	(15755) starting. Version 0.7.7 in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.1, js-controller: 4.0.21
              wireless-mbus.0	2022-03-21 20:04:01.970	warn	(15755) This object will not be created in future versions. Please report this to the developer.
              wireless-mbus.0	2022-03-21 20:04:01.968	warn	(15755) Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
              wireless-mbus.0	2022-03-21 20:04:01.215	debug	(15755) States connected to redis: 127.0.0.1:9000
              wireless-mbus.0	2022-03-21 20:04:01.108	debug	(15755) States create User PubSub Client
              wireless-mbus.0	2022-03-21 20:04:01.106	debug	(15755) States create System PubSub Client
              wireless-mbus.0	2022-03-21 20:04:01.041	debug	(15755) Redis States: Use Redis connection: 127.0.0.1:9000
              wireless-mbus.0	2022-03-21 20:04:00.960	debug	(15755) Objects connected to redis: 127.0.0.1:9001
              wireless-mbus.0	2022-03-21 20:04:00.935	debug	(15755) Objects client initialize lua scripts
              wireless-mbus.0	2022-03-21 20:04:00.756	debug	(15755) Objects create User PubSub Client
              wireless-mbus.0	2022-03-21 20:04:00.754	debug	(15755) Objects create System PubSub Client
              wireless-mbus.0	2022-03-21 20:04:00.740	debug	(15755) Objects client ready ... initialize now
              wireless-mbus.0	2022-03-21 20:04:00.598	debug	(15755) Redis Objects: Use Redis connection: 127.0.0.1:9001
              • hg6806H hg6806
                @gerald123
                L
                L
                lvogt
                #222
                @hg6806
                Sieht in der Tat unauffällig aus. Und die Kommunikation zum Stick scheint auch ok zu sein. Dann wäre halt die Anschlussfrage: Du bist sicher, dass auch irgendwas in deinem "Testzeitraum" empfangen werden müsste?
                hg6806H 1 Antwort Letzte Antwort
                • L lvogt
                  @hg6806
                  hg6806H
                  hg6806H
                  hg6806
                  #223
                  @lvogt
                  Eigentlich ja, denn ich hatte es einige Stunden am Laufen.
                  Mit wmbusmeters hatte ich grob alle 1-3 Stunden etwas empfangen.
                  Es ist doch so, sobald etwas empfangen wird, wird ein Datenpunkt neben "wireless-mbus.0.info" erstellt, oder?
                  Das ist bis jetzt noch nicht erfolgt.
                  • L
                    L
                    lvogt
                    #224
                    @hg6806 Ja da sollte dann ein "Device" im Objektbaum auftauchen - oder eine Logausgabe falls es Probleme gibt.
                    Mein letzter Rateversuch: Sendet das Gerät auf das du wartest vl nicht im T Mode sondern im S Mode?
                    • L lvogt
                      hg6806H
                      hg6806H
                      hg6806
                      #225
                      @lvogt
                      Ja, ich warte immer auf Übertragung und kann auch mal S Mode versuchen.
                      Nochmal die Frage ob es bei @kiste01 nun läuft?
                      • H
                        H
                        HKF8770
                        #226
                        @hkf8770
                        O.K., hab da folgende Informationen und auch den Fehler im debug log
                        Freddy
                        • H
                          H
                          HKF8770
                          #227
                          Hab auch den Fehler dass rawdata string sein sollte, aber die Daten boolen sind. Aber wie gesagt Der wichtige Wert der Wasseruhr kommt rein. Ist eher zur Info für die Entwickler
                          In io sieht das wie folgt aus
                          Also gar net so schlecht :-)
                          Freddy
                          • H HKF8770
                            @hkf8770
                            L
                            L
                            lvogt
                            schrieb am zuletzt editiert von lvogt
                            #228
                            Ich habe vorhin v0.7.8 veröffentlicht. Hauptsächliche Änderung ist, dass die Warnung über den Defaultwert des States beim Adapterstart nun verschwunden sein sollte und das kritische Probleme bei der Kommunikation mit dem "USB Stick" nun auch als ERROR geloggt werden sollten.
                            ⚠ Kurze Warnung: Dadurch musste ich natürlich in den entsprechenden Klassen für die Kommunikation mit den USB Sticks kleine Änderungen machen. Diese Klassen haben aber leider null Testabdeckung... Also falls mit der neuen Version plötzlich "gar nichts" mehr gehen sollte, bitte melden!
                            @hkf8770
                            Der entscheidenden Teil fehlt aber leider in deinem Screenshot(!). Die Rohdaten des Telegramms sind unvollständig da dein Screenshot da abgeschnitten ist. Logauszüge immer besser auch als Text posten. Das sollte die eigentlich weniger Arbeit machen wenn du dir den Screenshot sparst und "der Empfänger" muss nicht anfangen (fehleranfällig!) von Hand was abzutippen...
                            Alternativ würde vl. das genaue Modell des Wasserzählers vl. auch schon helfen - zumindest falls der Hersteller nett genug ist was zu den verwendenten Telegrammen im Handbuch zu schreiben.
                            M H 2 Antworten Letzte Antwort
                            • S
                              S
                              Simps
                              #229
                              ich würde mir gerne einen Stick zulegen, aber alles ist ausverkauft. Hat jemand einen Tipp?
                              Ich habe Heizkostenverteiler an den Heizkörpern, manche haben keine AES Verschlüsselung (Qundis) auf dem OMS Kanal. Was denkt ihr, kann ich davon ausgehen, dass zB der Nano-Cul da funktioniert?
                              Aber ich sehe gerade, selbst der scheint ausverkauft zu sein? 🤔 😢
                              Danke Euch für die erste Hilfe. Super Threat 👍
                              • hg6806H hg6806
                                @lvogt
                                K
                                K
                                kiste01
                                schrieb am zuletzt editiert von kiste01
                                #230
                                @hg6806 sagte in Test Adapter wireless-mbus v0.7.x:
                                @lvogt
                                Update: Hat sich geklärt. Mehrere Neustarts und ein kurzes Entfernen des Sticks haben Wunder bewirkt.
                                Das letzte Adapterupdate hat irgendwas verändert, so dass ich den Adapter nicht mehr grün bekomme, davor lief es top. Da ich zeitgleich aber auch sonst das System (iob auf 4.0.21 und node.js auf 14.19.1) aktualisiert habe, kann ich das nicht voneinander trennen.
                                Aktuell steht das im log
                                wireless-mbus.0
                                2022-03-28 18:04:19.841	debug	connected set to false
                                wireless-mbus.0
                                2022-03-28 18:04:19.803	debug	connected set to false
                                wireless-mbus.0
                                2022-03-28 18:04:19.800	debug	connected set to false
                                wireless-mbus.0
                                2022-03-28 18:04:19.786	error	Serialport error: Port is not open
                                wireless-mbus.0
                                2022-03-28 18:04:19.784	error	Serialport error: Error Resource temporarily unavailable Cannot lock port
                                wireless-mbus.0
                                2022-03-28 18:04:19.775	debug	Created device of type: CUL (untested)
                                wireless-mbus.0
                                2022-03-28 18:04:19.691	info	starting. Version 0.7.7 (non-npm: lvogt/ioBroker.wireless-mbus#32679a612e4f3c02184035bd12d7fcaad4840ff1) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v14.19.1, js-controller: 4.0.21
                                wireless-mbus.0
                                2022-03-28 18:04:19.673	warn	This object will not be created in future versions. Please report this to the developer.
                                wireless-mbus.0
                                2022-03-28 18:04:19.671	warn	Object wireless-mbus.0.info.rawdata is invalid: Default value has to be type "string" but received type "boolean"
                                • L lvogt
                                  @hkf8770
                                  M
                                  M
                                  Michi_Pi
                                  #231
                                  @lvogt bei mir funktioniert nach wie vor der Adapter mit dem neuen Update.
                                  • S
                                    S
                                    Simps
                                    schrieb am zuletzt editiert von Simps
                                    #232
                                    Servus @lvogt
                                    Du suchst ja Tester für CUL, ich hab einen Mini-Cul, die Firmware ist upgedatet auf WMBUs-fähig.
                                    Über Github installiere ich Deinen Adapter, aber er taucht nicht unter den Adaptern auf, er legt aber zwei Objekt-Verzeichnisse an (wmbus/admin, aber keine Ziffer). Beim Installieren kommt (Debug-Fenster). Die Script Depency WARN ist sicher die Lösung, finde durch googlen nichts, was mir hilft, ist es die NPM Version?
                                    url https://github.com/lvogt/ioBroker.wireless-mbus --host pii --debug
                                    install lvogt/ioBroker.wireless-mbus#ece83640b64ef90971e96e03b229f236dd2d2b0a
                                    NPM version: 6.14.16Installing lvogt/ioBroker.wireless-mbus#ece83640b64ef90971e96e03b229f236dd2d2b0a... (System call)
                                    iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                    iobroker npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    + iobroker.wireless-mbus@0.7.8added 2 packages from 2 contributors in 11.038s
                                    46 packages are looking for funding run `npm fund` for details
                                    upload [2] wireless-mbus.admin /opt/iobroker/node_modules/iobroker.wireless-mbus/admin/index_m.html index_m.html text/html
                                    iobroker upload [1] wireless-mbus.admin /opt/iobroker/node_modules/iobroker.wireless-mbus/admin/wireless-mbus.png wireless-mbus.png image/png
                                    iobroker upload [0] wireless-mbus.admin /opt/iobroker/node_modules/iobroker.wireless-mbus/admin/words.js words.js application/javascript
                                    iobroker exit 0
                                    npm fund hat kein nennenswertes Ergebnis.
                                    Javascript version ist 5.2.21
                                    NPM ist 6.14.16
                                    Alla Adapter sind upgedated (via stable repository).
                                    ABER: Wenn ich nicht den Link aus Github installiere, sondern den WMBUS Adapter 0.7.8 aus dem beta Repository (ist das denn deiner?) bekomme ich im System einen funktionierenden Adapter, ausserdem auch irgendwelche Daten (siehe Screenshot), aber keine Objekte ausm funk. Es müssten aber ein paar funken.
                                    Danke fürs Helfen :-)
                                    Stefan
                                    • L
                                      L
                                      lvogt
                                      #233
                                      @simps
                                      Vorweg: Der wireless-mbus Adapter ist natürlich genau der selbe.
                                      Die Warnung kommt glaube ich von serialport und ist kein Problem sofern ich das gerade richtig im Kopf habe.
                                      Ich vermute mal du hast nur den Adapter installiert aber keine Instanz erzeugt. Du musst jetzt halt im Adapter "Tab" noch eine Instanz anlegen...
                                      Edit: Das was du zeigst sind ja die technischen "Interna" wie sie für jeden Adapter existieren.
                                      Wenn ich irgendwie helfen können soll brauche ich min. ein Debug Log. Und "es m üssten aber ein paar funken" klingt schon nach der Ursache. Wie sicher bist du dir dass was funkt und in welchem Intervall? Und vl auch verschlüsselt?
                                      • L lvogt
                                        @simps
                                        S
                                        S
                                        Simps
                                        #234
                                        @lvogt vielen Dank!
                                        Anbei ein Debug-Log, ist das ausreichend? Derzeit hängt er in folgender Schleife fest
                                        wireless-mbus.0
                                        10401	2022-04-04 08:36:08.180	info	starting. Version 0.7.8 (non-npm: lvogt/ioBroker.wireless-mbus#ece83640b64ef90971e96e03b229f236dd2d2b0a) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.22.11, js-controller: 4.0.21
                                        host.pii
                                        2022-04-04 08:36:06.752	info	instance system.adapter.wireless-mbus.0 started with pid 10401
                                        host.pii
                                        2022-04-04 08:35:36.646	info	Restart adapter system.adapter.wireless-mbus.0 because enabled
                                        host.pii
                                        2022-04-04 08:35:36.645	info	instance system.adapter.wireless-mbus.0 terminated with code NaN ()
                                        host.pii
                                        2022-04-04 08:35:36.645	warn	instance system.adapter.wireless-mbus.0 terminated due to SIGABRT
                                        host.pii
                                        2022-04-04 08:35:36.641	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                        wireless-mbus.0
                                        10027	2022-04-04 08:24:50.165	info	starting. Version 0.7.8 (non-npm: lvogt/ioBroker.wireless-mbus#ece83640b64ef90971e96e03b229f236dd2d2b0a) in /opt/iobroker/node_modules/iobroker.wireless-mbus, node: v12.22.11, js-controller: 4.0.21
                                        host.pii
                                        2022-04-04 08:24:48.732	info	instance system.adapter.wireless-mbus.0 started with pid 10027
                                        host.pii
                                        2022-04-04 08:24:18.631	info	Restart adapter system.adapter.wireless-mbus.0 because enabled
                                        host.pii
                                        2022-04-04 08:24:18.631	info	instance system.adapter.wireless-mbus.0 terminated with code NaN ()
                                        host.pii
                                        2022-04-04 08:24:18.630	warn	instance system.adapter.wireless-mbus.0 terminated due to SIGABRT
                                        host.pii
                                        2022-04-04 08:24:18.630	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                        "Adapter aus der Beta installiert" führt natürlich dann zu einer Instanz. Nur der Github-Link nicht. Die technischen Interna hatte ich gescreenshottet, weil ich mir nicht sicher war, ob das helfen könnte.
                                        Derzeit läuft er auf /dev/ttyAMA0 wenn ich den Port wechsle auf /dev/ttyUSB0 kommt:
                                        wireless-mbus.0
                                        10849	2022-04-04 08:47:42.147	error	CUL: Error setting wMBus mode: Timeout waiting for response
                                        wireless-mbus.0
                                        10849	2022-04-04 08:47:42.144	error	CUL: Message response timeout
                                        Das bedeutet, das er auf dem ttyUSB0 nicht ansprechbar ist oder?
                                        Und es "funkt" auf jeden Fall :-) Ich habe hier Test-Heizkostenverteiler verschiedener Marken als Testgeräte, auf der richtigen Frequenz und im richtigen OMS WMBUS Format, einige sind AES verschlüsselt, andere nicht, aber keiner kommt an in den Objekten.
                                        Was denkst Du? Und Danke nochmal!
                                        • S Simps
                                          @lvogt vielen Dank!
                                          wireless-mbus.0
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          wireless-mbus.0
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          L
                                          L
                                          lvogt
                                          #235
                                          @simps said in Test Adapter wireless-mbus v0.7.x:
                                          Eigentlich nicht. Da ist ja nicht mal drin dass der Adapter ein korrekte Antwort vom CUL nach dem Setzen des T- oder S-Modes bekommen hat. Aber: (s.u.)
                                          wireless-mbus.0
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          wireless-mbus.0
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          host.pii
                                          Wenn das wirklich eine Schleife ist, sollte es dich nicht wundern wenn der Adapter nichts empfängt, da er offensichtlich ununterbrochen neu gestartet wird. Die Fehlermeldung deutet auf ein Memoryleak hin, aber ich weiß nicht wirklich woher das kommen soll. Insbesondere da ja offensichtlich die meisten keine Probleme mit überfülltem Speicher haben. (Und es ja scheinbar quasi direkt nach dem Adapter Start bereits auftritt.) Weiter oben im Thread hatte jemand anderes schon dasselbe oder wenigstens ein ähnliches Problem was bisher nicht gelöst ist.
                                          Wenn du etwas experimentieren willst kannst du mal versuchen andere Adapter / Skripte zu stoppen und gucken ob es hilft.
                                          Wie ich geschrieben habe, ist der Unterschied dass ioBroker nicht automatisch eine Instanz anlegt wenn du den Adapter aus dem Git Repository installierst, das müsstest du halt "manuell" machen. Ist aber ja auch egal, der du am Ende sowieso mit dem selben Stand wie aus dem "beta Repository" raus kommst.
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          Im Grunde ja. Welches der richtige Port musst du schon selber wissen / rausfinden. (Zb. in dmesg nach dem Verbinden des CULs gucken...) Auf Dauer würde ich dir aber empfehlen, einen Symlink durch udev anlegen zu lassen, damit du nicht auf die ttyUSB Nummerierung vertrauen musst. Wenn du mehr als ein Serialdevice hast, kann die sich (am RPi) nämlich je nach Neustart ändern. (Dazu gibt's keine Anleitung von mir - aber mehr als genug quer durchs Internet verteilt...)
                                          Mal geraten: /dev/ttyAMA0 klingt (in meiner Erinnerung) für den Raspi eher unplausibel - ist je nach Config glaube ich ein Debug Port. Evtl. kommen da Berge von anderen Daten/Müll an. Der Adapter sammelt alles auf (weil er darauf wartet ein vollständiges Telegramm oder eine Antwort auf einen Befehl zu bekommen und schreibt ruckzuck den RAM voll. Vor dem Hintergrund sollte ich mal noch ein Limit für den Puffer einbauen, das ist bisher nämlich noch nicht der Fall...
                                          Wenn ich da richtig gereaten hätte, dann gäbe es kein Problem außer dass du den korrekten Port auswählen musst...
                                          Das ist schon mal gut - aber natürlich musst du trotzdem darauf warten dass die Geräte auch tatsächlich was versenden. Gerade Heizkostenverteiler sind nicht gerade die Geräte die am häufigsten Senden... (kenne aber natürlich deine konkreten Geräte und deren Konfiguration aber nicht.)
                                          M S 2 Antworten Letzte Antwort
                                          84.1k
