  4. Update Javascript auf 5.2.21 - Fehler im Log
53 Beiträge 6 Kommentatoren 10.8k Aufrufe 4 Beobachtet
  • NamrennerN Namrenner
    @apollon77
    D:\Iobroker\SmartHome>iobroker update
    D:\Iobroker\SmartHome>node node_modules/iobroker.js-controller/iobroker.js update
    Used repository: stable
    Adapter    "admin"        : 5.3.1    , installed 5.3.1
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.3.3    , installed 2.3.3
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.10.5   , installed 1.10.5
    Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
    Adapter    "info"         : 1.9.8    , installed 1.9.18
    Adapter    "iot"          : 1.8.24   , installed 1.8.24
    Adapter    "javascript"   : 5.2.21   , installed 5.2.13 [Updatable]
    Controller "js-controller": 4.0.15   , installed 4.0.15
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "modbus"       : 3.4.17   , installed 3.4.17
    Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
    Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
    Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
    Adapter    "node-red"     : 2.4.2    , installed 2.4.2
    Adapter    "parser"       : 1.0.7    , installed 1.0.7
    Adapter    "ping"         : 1.5.0    , installed 1.5.0
    Adapter    "scenes"       : 2.3.8    , installed 2.3.8
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
    Adapter    "smartmeter"   : 3.2.1    , installed 3.2.1
    Adapter    "socketio"     : 3.1.5    , installed 3.1.5
    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
    Adapter    "telegram"     : 1.11.1   , installed 1.11.1
    Adapter    "text2command" : 2.1.1    , installed 2.1.1
    Adapter    "vis"          : 1.4.5    , installed 1.4.5
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
    Adapter    "vis-inventwo" : 3.2.8    , installed 3.2.8
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 3.4.16   , installed 3.4.16
    Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y
    Update javascript from @5.2.13 to @5.2.21
    NPM version: 6.14.16
    Installing iobroker.javascript@5.2.21... (System call)
    host.TV Cannot install iobroker.javascript@5.2.21: 4294963214
    apollon77A
    apollon77A
    @namrenner naja dann machen wir mal
    „iobroker upgrade javascript --debug“
    Was sagt die Ausgabe? Und mal versuchen wenn iobroker komplett gestoppt ist.
    Ps: und nochmal die Frage: hast du Vis-icontwo als Adapter installiert????
    NamrennerN 1 Antwort Letzte Antwort
    • apollon77A apollon77
      NamrennerN
      NamrennerN
      Namrenner
      schrieb am zuletzt editiert von Namrenner
      @apollon77
      Vis-icontwo denke nicht, in der Liste habe es nicht, sehe Nachricht davor, dort sind alle Adapter aufgelistet, danke.
      host.TV Adapter "system.adapter.javascript.0" is stopped.
      npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm WARN rollback Rolling back iobroker.javascript@5.2.21 failed (this is probably harmless): EBUSY: resource busy or locked, rmdir 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript'
      npm ERR! code EBUSY
      npm ERR! syscall rename
      npm ERR! path D:\Iobroker\SmartHome\node_modules\iobroker.javascript
      npm ERR! dest D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE
      npm ERR! errno -4082
      npm ERR! EBUSY: resource busy or locked, rename 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript' -> 'D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE'
      npm ERR!     C:\Users\Hans\AppData\Roaming\npm-cache\_logs\2022-02-26T13_36_10_444Z-debug.log
        @apollon77
        npm ERR! code EBUSY
        apollon77A
        apollon77A
        @namrenner ebusy ist mal wieder so ne Windows Nummer. Bitte alles beenden und dann das Update machen. Scheinbar lockt Windows irgendwelche files die das Update Bzw npm dann nicht austauschen kann.
        Wir stoppen zwar auf Windows seit Controller 4 immer die Instanzen des Adapters was das Update bekommt aber manchmal scheint das bei Windows nicht zu reichen :-(
          NamrennerN
          NamrennerN
          Namrenner
          @apollon77 hatte iobroker gestoppt, habe nun ein restart in Windows gemacht, nun ging es, danke
            apollon77A
            apollon77A
            @namrenner Gmrpf ... keine Ahnung was Windows da treibt :-(
            • Basti97B
              Basti97B
              Basti97
              Nach dem Update auf die JavaScript Version 5.2.21 kommt bei mir folgende Fehlermeldung wenn ich den Adapter starte. Im laufenden Betrieb kommt die Meldung aber nicht mehr.
              Ist diese Meldung wichtig oder eher unwichtig?
              Node.js
                  v16.13.2 (Es gibt eine neuere Version: v16.14.0 - Empfohlene Version v14.19.0)
              NPM
                  8.1.2
              JSController 3.3.22
              2022-03-03 16:47:07.423 - error: javascript.0 (1423151) npm
              2022-03-03 16:47:07.426 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.428 - error: javascript.0 (1423151) WARN
              2022-03-03 16:47:07.430 - error: javascript.0 (1423151) deprecated har-validator@5.1.5: this library is no longer supported
              2022-03-03 16:47:07.502 - error: javascript.0 (1423151) npm
              2022-03-03 16:47:07.505 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.506 - error: javascript.0 (1423151) WARN
              2022-03-03 16:47:07.509 - error: javascript.0 (1423151) deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
              2022-03-03 16:47:07.554 - error: javascript.0 (1423151) npm
              2022-03-03 16:47:07.557 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.560 - error: javascript.0 (1423151) WARN
              2022-03-03 16:47:07.562 - error: javascript.0 (1423151) deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
              2022-03-03 16:47:07.601 - error: javascript.0 (1423151) npm
              2022-03-03 16:47:07.603 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.605 - error: javascript.0 (1423151) WARN
              2022-03-03 16:47:07.607 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.609 - error: javascript.0 (1423151) deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              2022-03-03 16:47:07.648 - error: javascript.0 (1423151) npm
              2022-03-03 16:47:07.651 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.652 - error: javascript.0 (1423151) WARN
              2022-03-03 16:47:07.654 - error: javascript.0 (1423151)
              2022-03-03 16:47:07.656 - error: javascript.0 (1423151) deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
              Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              • Basti97B Basti97
                Node.js
                NPM
                    8.1.2
                JSController 3.3.22
                Thomas BraunT
                Thomas BraunT
                Most Active Developer
                @basti97
                Nicht so wichtig.
                Du könntest aber beim Adapter ein Issue eröffnen und fragen, ob die Dependencies aktualisiert werden können.
                Basti97B 1 Antwort Letzte Antwort
                • Basti97B Basti97
                  Node.js
                  NPM
                      8.1.2
                  JSController 3.3.22
                  apollon77A
                  apollon77A
                  @basti97 Naja der JavaScript Adapter installiert beim Start die Pakete die du dort konfiguriert hast ... und das sind potentielle Ausgaben davon .. also von daher ...
                    @basti97
                    Nicht so wichtig.
                    Basti97B
                    Basti97B
                    Basti97
                    @thomas-braun @apollon77 Danke also kann ich das vernachlässigen und brauche mir keine sorgen machen. Ich werde demnächst ein issuses aufmachen. Wenn ein anderer die Fehlermeldung hat das er weiß das alles ok ist. Muss ich das bei dem Javascript Adapter bei github stellen?
                    • Basti97B Basti97
                      apollon77A
                      apollon77A
                      @basti97 Ein Issue wegen was willst du auf machen?
                      • Basti97B
                        Basti97B
                        Basti97
                        Bei mir ist leider der Javascript Adapter von meinen Slave kaputt gegangen. Ich glaube ich muss die SD Karte mal wechseln.
                        Welche Pakete muss ich nun nachinstallieren und wie?
                        host.Media04
                        	2022-03-04 18:48:34.078	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.Media04
                        	2022-03-04 18:48:34.077	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                        host.Media04
                        	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                        host.Media04
                        	2022-03-04 18:48:34.077	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                        host.Media04
                        	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                        host.Media04
                        	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                        host.Media04
                        	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                        host.Media04
                        	2022-03-04 18:48:34.073	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                        host.Media04
                        	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                        host.Media04
                        	2022-03-04 18:48:34.073	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                        host.Media04
                        	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                        host.Media04
                        	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                        host.Media04
                        	2022-03-04 18:48:34.070	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                        host.Media04
                        	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                        host.Media04
                        	2022-03-04 18:48:34.069	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                        host.Media04
                        	2022-03-04 18:48:34.068	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                        host.Media04
                        	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                        host.Media04
                        	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                        host.Media04
                        	2022-03-04 18:48:34.066	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                        host.Media04
                        	2022-03-04 18:48:34.065	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                        host.Media04
                        	2022-03-04 18:48:34.064	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                        host.Media04
                        	2022-03-04 18:48:34.063	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                        host.Media04
                        	2022-03-04 18:48:34.062	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                        host.Media04
                        	2022-03-04 18:48:34.061	error	Caught by controller[0]:
                          Basti97B
                          Basti97B
                          Basti97
                          @apollon77 said in Update Javascript auf 5.2.21 - Fehler im Log:
                          Das der Fehler behoben wird. :)
                          • Basti97B Basti97
                            apollon77A
                            apollon77A
                            @basti97 welcher Fehler? Wenn npm das als error loggt landet es als error im log. Ist „as designed”
                            • Basti97B Basti97
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              apollon77A
                              apollon77A
                              @basti97 Puhh. Kommt das auch wenn alle Skripte dort gestoppt sind? Sonst reinstalliere mal den JavaScript Adapter selbst.
                              Basti97B 2 Antworten Letzte Antwort
                                Basti97B
                                Basti97B
                                Basti97
                                schrieb am zuletzt editiert von Basti97
                                @apollon77 Der Adapter lässt sich gar nicht erst starten die Meldung kommt sobald ich ihn starten möchte. Bei den Java Adapter steht als Verbrauch 0MB
                                Ich glaube ich muss bei meinem Slave doch langsam die SD wechseln.
                                  Basti97B
                                  Basti97B
                                  Basti97
                                  @apollon77 noch vergessen das kommt noch zuvor
                                  Das ist das komplette Log
                                  host.Media04
                                  	2022-03-04 23:53:43.832	info	Restart adapter system.adapter.javascript.1 because enabled
                                  host.Media04
                                  	2022-03-04 23:53:43.832	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.Media04
                                  	2022-03-04 23:53:43.831	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                                  host.Media04
                                  	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                  host.Media04
                                  	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                  host.Media04
                                  	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                  host.Media04
                                  	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                  host.Media04
                                  	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                  host.Media04
                                  	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                                  host.Media04
                                  	2022-03-04 23:53:43.829	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                  host.Media04
                                  	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                  host.Media04
                                  	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                  host.Media04
                                  	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                  host.Media04
                                  	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                  host.Media04
                                  	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                  host.Media04
                                  	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                                  host.Media04
                                  	2022-03-04 23:53:43.827	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                  host.Media04
                                  	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                  host.Media04
                                  	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                  host.Media04
                                  	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                  host.Media04
                                  	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                  host.Media04
                                  	2022-03-04 23:53:43.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                                  host.Media04
                                  	2022-03-04 23:53:43.825	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                                  host.Media04
                                  	2022-03-04 23:53:43.825	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                                  host.Media04
                                  	2022-03-04 23:53:43.824	error	Caught by controller[0]:
                                  host.Media04
                                  	2022-03-04 23:53:43.821	error	Caught by controller[0]: return getR�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&return splitChildren(node.getChildren(), function (_a) {
                                  host.Media04
                                  	2022-03-04 23:53:43.820	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:139366
                                  • Basti97B Basti97
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    host.Media04
                                    apollon77A
                                    apollon77A
                                    @basti97 ja Adapter s add m besten löschen und neu installieren und vorher as Karte tauschen
                                      Basti97B
                                      Basti97B
                                      Basti97
                                      @apollon77 Danke werde ich morgen mal machen.
                                        Basti97B
                                        Basti97B
                                        Basti97
                                        @apollon77
                                        Ich habe auf dem Slave nun das hier eingegeben.
                                        pi@Media04:~ $ iobroker del javascript.1
                                        Delete adapter "javascript.1"
                                        host.Media04 Counted 1 instances of javascript.1
                                        host.Media04 Counted 2 channels of javascript.1
                                        host.Media04 Counted 6 states of javascript.1
                                        host.Media04 Counted 14 states of system.adapter.javascript.1
                                        host.Media04 Counted 4 states (system.adapter.javascript.1.*) from states
                                        host.Media04 Deleting 23 object(s).
                                        host.Media04 Deleting 4 state(s).
                                        pi@Media04:~ $ iobroker install javascript.1
                                        adapter "javascript" already installed. Use "upgrade" to upgrade to a newer version.
                                        Und danach über den Reiter Adapter nochmal neuinstalliert. Beim starten des Adapters kommt wieder diese Fehlermeldung.
                                        host.Media04
                                        	2022-03-06 12:24:11.686	info	Restart adapter system.adapter.javascript.1 because enabled
                                        host.Media04
                                        	2022-03-06 12:24:11.685	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.Media04
                                        	2022-03-06 12:24:11.684	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                                        host.Media04
                                        	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                        host.Media04
                                        	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                        host.Media04
                                        	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                        host.Media04
                                        	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                        host.Media04
                                        	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                                        host.Media04
                                        	2022-03-06 12:24:11.680	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                        host.Media04
                                        	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                        host.Media04
                                        	2022-03-06 12:24:11.680	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                        host.Media04
                                        	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                        host.Media04
                                        	2022-03-06 12:24:11.678	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                        host.Media04
                                        	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                        host.Media04
                                        	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                        host.Media04
                                        	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                                        host.Media04
                                        	2022-03-06 12:24:11.676	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                        host.Media04
                                        	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                        host.Media04
                                        	2022-03-06 12:24:11.676	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                        host.Media04
                                        	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                        host.Media04
                                        	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                                        host.Media04
                                        	2022-03-06 12:24:11.673	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                                        host.Media04
                                        	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                        host.Media04
                                        	2022-03-06 12:24:11.673	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                                        host.Media04
                                        	2022-03-06 12:24:11.672	error	Caught by controller[0]:
                                        Aber trotzdem funktioniert es nicht.
                                        • Basti97B Basti97
                                          @apollon77
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          host.Media04
                                          apollon77A
                                          apollon77A
                                          @basti97 Naja du must wenn javascript komplett entfernen nicht nur instanz 1 ... Die Skripte werden an sich nicht gelöscht, also iob del javascript (vorher backup sicherheitshalber)
                                          Alternativ kannst du vorher ein ´cd /opt/iobrokerundnpm i iobroker.javasscript` versuchen obs hilft
                                          33.2k
                                          84.3k
