<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update Javascript auf 5.2.21 - Fehler im Log]]></title><description><![CDATA[<table class="table table-bordered table-striped">
<thead>
<tr>
<th>Systemdata</th>
<th>Bitte Ausfüllen</th>
</tr>
</thead>
<tbody>
<tr>
<td>Hardwaresystem:</td>
<td>Syno/Docker</td>
</tr>
</tbody>
</table>
<p dir="auto"><img src="/assets/uploads/files/1645022603356-8986e2f6-a504-413f-b5b4-486e0acb06b8-image.png" alt="8986e2f6-a504-413f-b5b4-486e0acb06b8-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Habe heute JS aktualisiert von 5.2.13 auf 5.2.21 und habe folgende Fehler im Protokoll, aus denen ich aber (für mich) kein ToDo ableiten kann. Grundsätzlich scheint aber erstmal alles zu funktionieren.</p>
<pre><code>javascript.0	2022-02-16 15:31:49.636	info	(24753) received all objects
javascript.0	2022-02-16 15:31:48.813	info	(24753) received all states
javascript.0	2022-02-16 15:31:45.905	info	(24753) requesting all objects
javascript.0	2022-02-16 15:31:45.904	info	(24753) requesting all states
javascript.0	2022-02-16 15:31:45.820	info	(24753) found 0 vulnerabilities
javascript.0	2022-02-16 15:31:45.819	info	run `npm fund` for details
javascript.0	2022-02-16 15:31:45.819	info	8 packages are looking for funding
javascript.0	2022-02-16 15:31:45.819	info	(24753)
javascript.0	2022-02-16 15:31:45.680	info	added 9 packages from 11 contributors and audited 78 packages in 12.587s
javascript.0	2022-02-16 15:31:45.680	info	(24753) + node-ssh@12.0.3
javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 install: `node-gyp rebuild`
javascript.0	2022-02-16 15:31:45.676	error	(24753) WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 (node_modules/cpu-features):
javascript.0	2022-02-16 15:31:45.675	error	(24753) npm
javascript.0	2022-02-16 15:31:45.362	info	(24753) Succeeded in building optional crypto binding
javascript.0	2022-02-16 15:31:45.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
javascript.0	2022-02-16 15:31:45.188	info	(24753) COPY Release/sshcrypto.node
javascript.0	2022-02-16 15:31:44.559	info	(24753) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~
javascript.0	2022-02-16 15:31:41.390	error	2003 | NODE_MODULE(sshcrypto, init)
javascript.0	2022-02-16 15:31:41.390	error	../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’
javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~
javascript.0	2022-02-16 15:31:41.390	error	770 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
javascript.0	2022-02-16 15:31:41.390	error	736 | (node::addon_register_func) (regfunc), \
javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local&lt;v8::
javascript.0	2022-02-16 15:31:41.390	error	(24753) In file included from ../src/binding.cc:6:
javascript.0	2022-02-16 15:31:38.461	info	(24753) CXX(target) Release/obj.target/sshcrypto/src/binding.o
javascript.0	2022-02-16 15:31:38.460	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
javascript.0	2022-02-16 15:31:37.370	info	&gt; node install.js
javascript.0	2022-02-16 15:31:37.370	info	&gt; ssh2@1.6.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
javascript.0	2022-02-16 15:31:37.370	info	(24753)
javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! not ok
javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node-gyp -v v5.1.0
javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node -v v12.22.7
javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
javascript.0	2022-02-16 15:31:37.347	error	(24753) gyp ERR! System Linux 4.4.59+
javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.emit (events.js:314:20)
javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack Error: `make` failed with exit code: 2
javascript.0	2022-02-16 15:31:37.345	error	(24753) gyp ERR! build error
javascript.0	2022-02-16 15:31:37.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
javascript.0	2022-02-16 15:31:37.342	error	(24753) make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127
javascript.0	2022-02-16 15:31:37.341	error	(24753) /bin/sh: 1: cmake: not found
javascript.0	2022-02-16 15:31:37.334	info	(24753) ACTION Configuring dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile
javascript.0	2022-02-16 15:31:37.333	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
host.iobroker	2022-02-16 15:31:36.358	info	iobroker exit 0
javascript.0	2022-02-16 15:31:36.037	info	&gt; node-gyp rebuild
javascript.0	2022-02-16 15:31:36.037	info	&gt; cpu-features@0.0.2 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
javascript.0	2022-02-16 15:31:36.037	info	(24753)
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/52576/update-javascript-auf-5-2-21-fehler-im-log</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 04:47:22 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/52576.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Feb 2022 14:46:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 19:32:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> Ok dann lieber immer nachfragen bevor man was falsches macht. Aber so lange man ein Backup hat was man im Notfall einspielen könnte. Wenn es dann nicht mehr funktioniert. Aber nicht so schlimm wenn man wie hier gute Hilfe bekommt. :)<br />
Ausfälle sind zwar ärgerlich und zeitaufwändig aber wenn es dann funktioniert ist man glücklicher.</p>
]]></description><link>https://forum.iobroker.net/post/773068</link><guid isPermaLink="true">https://forum.iobroker.net/post/773068</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 19:32:59 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 19:29:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Danke gut zu wissen. :)</p>
]]></description><link>https://forum.iobroker.net/post/773064</link><guid isPermaLink="true">https://forum.iobroker.net/post/773064</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 19:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 18:13:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> ja und nein. Als pauschale Nummer nicht ganz so geeignet. Kommt immer darauf an</p>
]]></description><link>https://forum.iobroker.net/post/773020</link><guid isPermaLink="true">https://forum.iobroker.net/post/773020</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Sun, 06 Mar 2022 18:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 18:04:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a></p>
<p dir="auto">Eigentlich vermeidet man den Einsatz von npm auf direktem Weg.<br />
Besser:</p>
<pre><code>iobroker install ADAPTERNAME
</code></pre>
]]></description><link>https://forum.iobroker.net/post/773012</link><guid isPermaLink="true">https://forum.iobroker.net/post/773012</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 06 Mar 2022 18:04:44 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 18:01:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> Ja der Adapter funktioniert wieder. Wenn man die Lösung weiß ist es einfach. Ich habe mir gleich den Lösungsweg gespeichert. :)</p>
<p dir="auto">Würde der Befehl <em>npm i iobroker.javascript</em>  auch funktionieren wenn ein anderer Adapter kaputt wäre. Natürlich müsste ich dann javascript ersetzen.</p>
]]></description><link>https://forum.iobroker.net/post/773010</link><guid isPermaLink="true">https://forum.iobroker.net/post/773010</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 18:01:59 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 17:56:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> uund hats was gebracht?</p>
]]></description><link>https://forum.iobroker.net/post/773005</link><guid isPermaLink="true">https://forum.iobroker.net/post/773005</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Sun, 06 Mar 2022 17:56:37 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 17:52:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/772957">Update Javascript auf 5.2.21 - Fehler im Log</a>:</p>
<blockquote>
<p dir="auto">npm i iobroker.javascript</p>
</blockquote>
<p dir="auto">Super vielen Dank das hat funktoniert ich bin glücklich.<br />
Das kam im übrigen.</p>
<pre><code>pi@Media04:/opt/iobroker $ npm i iobroker.javascript
npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
&gt; iobroker.javascript@5.3.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
&gt; node ./install/installTypings.js
Installing NodeJS typings...
latest @types: 17, installed node: 14
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
+ iobroker.javascript@5.3.1
added 3 packages from 3 contributors, removed 3 packages and updated 6 packages in 377.051s
90 packages are looking for funding
</code></pre>
]]></description><link>https://forum.iobroker.net/post/773003</link><guid isPermaLink="true">https://forum.iobroker.net/post/773003</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 17:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 16:18:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a></p>
<p dir="auto">Da ist ein s zu viel.</p>
<pre><code>npm i iobroker.javascript
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772957</link><guid isPermaLink="true">https://forum.iobroker.net/post/772957</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 06 Mar 2022 16:18:09 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 16:14:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Das kommt raus</p>
<pre><code>pi@Media04:/opt/iobroker $  npm i iobroker.javasscript
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.javasscript - N        ot found
npm ERR! 404
npm ERR! 404  'iobroker.javasscript@latest' is not in the npm registry.
npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR!     /home/iobroker/.npm/_logs/2022-03-06T16_02_24_230Z-debug.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772952</link><guid isPermaLink="true">https://forum.iobroker.net/post/772952</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 16:14:39 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:40:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> sagte in <a href="/post/772908">Update Javascript auf 5.2.21 - Fehler im Log</a>:</p>
<blockquote>
<p dir="auto">cd /opt/iobrokerundnpm i iobroker.javasscript</p>
</blockquote>
<p dir="auto">Das soll so lauten:</p>
<pre><code>cd /opt/iobroker/
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772909</link><guid isPermaLink="true">https://forum.iobroker.net/post/772909</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:40:29 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:38:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> sollte ich das ausführen? Weil irgendwie ging es nicht.</p>
<pre><code>pi@Media04:~ $ cd /opt/iobrokerundnpm i iobroker.javasscript
-bash: cd: Zu viele Argumente.
pi@Media04:~ $ cd /opt/iobroker undnpm i iobroker.javasscript
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772908</link><guid isPermaLink="true">https://forum.iobroker.net/post/772908</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:38:34 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:35:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a></p>
<pre><code>    Plattform: linux
    Betriebssystem: linux
    Architektur: arm
    CPUs: 4
    Geschwindigkeit: 600 MHz
    Modell: ARMv7 Processor rev 4 (v7l)
    RAM: 922.8 MB
    System-Betriebszeit: 1 T. 22:21:40
    Node.js: v14.19.0
    NPM: 6.14.16
    Datenträgergröße: 14.5 GB
    freier Festplattenspeicher: 4.9 GB
    Adapter-Anzahl: 400
    Betriebszeit: 04:10:41
    Aktive Instanzen: 4
    Pfad: /opt/iobroker/
    JS Controller: 3.3.2
</code></pre>
<p dir="auto">Javascript Adapter hat die Version 5.2.21<br />
Brauchst du noch mehr infos?</p>
]]></description><link>https://forum.iobroker.net/post/772905</link><guid isPermaLink="true">https://forum.iobroker.net/post/772905</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:35:27 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:17:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> dann mach lieber das mit npm install ... zu dem  "no connection to db": Welcher controller? Welche db?</p>
]]></description><link>https://forum.iobroker.net/post/772881</link><guid isPermaLink="true">https://forum.iobroker.net/post/772881</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:17:19 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:15:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> ok also führe ich auf den Slave mal das hier aus?<br />
bleiben die andere Instanzen unberührt oder soll ich den Master herunterfahren.</p>
<pre><code>cd /opt/iobrokerundnpm i iobroker.javasscript
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772878</link><guid isPermaLink="true">https://forum.iobroker.net/post/772878</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:13:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> sagte in <a href="/post/772870">Update Javascript auf 5.2.21 - Fehler im Log</a>:</p>
<blockquote>
<p dir="auto">Oder soll ich das mal als sudo probieren.</p>
</blockquote>
<p dir="auto">Nein, iobroker nie mit sudo beackern.</p>
]]></description><link>https://forum.iobroker.net/post/772873</link><guid isPermaLink="true">https://forum.iobroker.net/post/772873</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:13:54 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 15:12:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> Ich habe aber auf meinem Master noch zwei Javascript Instanzen laufen. Nicht das sie mit gelöscht werden.<br />
Wenn ich den Master herunterfahre und das <em>iobroker del javascript</em> ausführe kommt das hier.<br />
<pre><code>pi@Media04:~ $ iobroker del javascript
No connection to databases possible ...
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772870</link><guid isPermaLink="true">https://forum.iobroker.net/post/772870</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 15:12:56 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 12:00:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> Naja du must wenn javascript komplett entfernen nicht nur instanz 1 ... Die Skripte werden an sich nicht gelöscht, also <code>iob del javascript</code> (vorher backup sicherheitshalber)</p>
<p dir="auto">Alternativ kannst du vorher ein ´cd /opt/iobroker<code>und</code>npm i iobroker.javasscript` versuchen obs hilft</p>
]]></description><link>https://forum.iobroker.net/post/772799</link><guid isPermaLink="true">https://forum.iobroker.net/post/772799</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Sun, 06 Mar 2022 12:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Sun, 06 Mar 2022 11:27:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a><br />
Ich habe auf dem Slave nun das hier eingegeben.</p>
<pre><code>pi@Media04:~ $ iobroker del javascript.1
Delete adapter "javascript.1"
host.Media04 Counted 1 instances of javascript.1
host.Media04 Counted 2 channels of javascript.1
host.Media04 Counted 6 states of javascript.1
host.Media04 Counted 14 states of system.adapter.javascript.1
host.Media04 Counted 4 states (system.adapter.javascript.1.*) from states
host.Media04 Deleting 23 object(s).
host.Media04 Deleting 4 state(s).
pi@Media04:~ $ iobroker install javascript.1
adapter "javascript" already installed. Use "upgrade" to upgrade to a newer version.
</code></pre>
<p dir="auto">Und danach über den Reiter Adapter nochmal neuinstalliert. Beim starten des Adapters kommt wieder diese Fehlermeldung.</p>
<pre><code>host.Media04
	2022-03-06 12:24:11.686	info	Restart adapter system.adapter.javascript.1 because enabled
host.Media04
	2022-03-06 12:24:11.685	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.Media04
	2022-03-06 12:24:11.684	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
host.Media04
	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
host.Media04
	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
host.Media04
	2022-03-06 12:24:11.680	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
host.Media04
	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
host.Media04
	2022-03-06 12:24:11.680	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
host.Media04
	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-06 12:24:11.678	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
host.Media04
	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
host.Media04
	2022-03-06 12:24:11.676	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
host.Media04
	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-06 12:24:11.676	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
host.Media04
	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
host.Media04
	2022-03-06 12:24:11.673	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
host.Media04
	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-06 12:24:11.673	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
host.Media04
	2022-03-06 12:24:11.672	error	Caught by controller[0]:
</code></pre>
<p dir="auto">Aber trotzdem funktioniert es nicht.</p>
<p dir="auto"><img src="/assets/uploads/files/1646565984950-0a36b3af-2af2-49cc-aaa5-35f20549da66-grafik.png" alt="0a36b3af-2af2-49cc-aaa5-35f20549da66-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/772794</link><guid isPermaLink="true">https://forum.iobroker.net/post/772794</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Sun, 06 Mar 2022 11:27:08 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 23:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> Danke werde ich morgen mal machen.</p>
]]></description><link>https://forum.iobroker.net/post/772264</link><guid isPermaLink="true">https://forum.iobroker.net/post/772264</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Fri, 04 Mar 2022 23:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 23:14:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> ja Adapter s add m besten löschen und neu installieren und vorher as Karte tauschen</p>
]]></description><link>https://forum.iobroker.net/post/772261</link><guid isPermaLink="true">https://forum.iobroker.net/post/772261</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 04 Mar 2022 23:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 22:54:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> noch vergessen das kommt noch zuvor</p>
<p dir="auto">Das ist das komplette Log</p>
	2022-03-04 23:53:43.832	info	Restart adapter system.adapter.javascript.1 because enabled
host.Media04
	2022-03-04 23:53:43.832	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
host.Media04
	2022-03-04 23:53:43.831	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
host.Media04
	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
host.Media04
	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
host.Media04
	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
host.Media04
	2022-03-04 23:53:43.829	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
host.Media04
	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
host.Media04
	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
host.Media04
	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
host.Media04
	2022-03-04 23:53:43.827	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
host.Media04
	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
host.Media04
	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
host.Media04
	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
host.Media04
	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
host.Media04
	2022-03-04 23:53:43.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
host.Media04
	2022-03-04 23:53:43.825	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
host.Media04
	2022-03-04 23:53:43.825	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
host.Media04
	2022-03-04 23:53:43.824	error	Caught by controller[0]:
host.Media04
	2022-03-04 23:53:43.821	error	Caught by controller[0]: return getR�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;�'�&amp;�&amp;return splitChildren(node.getChildren(), function (_a) {
host.Media04
	2022-03-04 23:53:43.820	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:139366
</code></pre>
]]></description><link>https://forum.iobroker.net/post/772256</link><guid isPermaLink="true">https://forum.iobroker.net/post/772256</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Fri, 04 Mar 2022 22:54:34 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 22:51:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> Der Adapter lässt sich gar nicht erst starten die Meldung kommt sobald ich ihn starten möchte. Bei den Java Adapter steht als Verbrauch 0MB<br />
Ich glaube ich muss bei meinem Slave doch langsam die SD wechseln.</p>
]]></description><link>https://forum.iobroker.net/post/772255</link><guid isPermaLink="true">https://forum.iobroker.net/post/772255</guid><dc:creator><![CDATA[Basti97]]></dc:creator><pubDate>Fri, 04 Mar 2022 22:51:22 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 22:11:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> Puhh. Kommt das auch wenn alle Skripte dort gestoppt sind? Sonst reinstalliere mal den JavaScript Adapter selbst.</p>
]]></description><link>https://forum.iobroker.net/post/772245</link><guid isPermaLink="true">https://forum.iobroker.net/post/772245</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 04 Mar 2022 22:11:35 GMT</pubDate></item><item><title><![CDATA[Reply to Update Javascript auf 5.2.21 - Fehler im Log on Fri, 04 Mar 2022 22:09:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/basti97" aria-label="Profile: basti97">@<bdi>basti97</bdi></a> welcher Fehler? Wenn npm das als error loggt landet es als error im log. Ist „as designed”</p>
]]></description><link>https://forum.iobroker.net/post/772243</link><guid isPermaLink="true">https://forum.iobroker.net/post/772243</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 04 Mar 2022 22:09:37 GMT</pubDate></item></channel></rss>
