  4. Update Javascript auf 5.2.21 - Fehler im Log
53 Beiträge 6 Kommentatoren 10.8k Aufrufe 4 Beobachtet
  • Basti97B Basti97
    Nach dem Update auf die JavaScript Version 5.2.21 kommt bei mir folgende Fehlermeldung wenn ich den Adapter starte. Im laufenden Betrieb kommt die Meldung aber nicht mehr.
    Ist diese Meldung wichtig oder eher unwichtig?
    Node.js
        v16.13.2 (Es gibt eine neuere Version: v16.14.0 - Empfohlene Version v14.19.0)
    NPM
        8.1.2
    JSController 3.3.22
    2022-03-03 16:47:07.423 - error: javascript.0 (1423151) npm
    2022-03-03 16:47:07.426 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.428 - error: javascript.0 (1423151) WARN
    2022-03-03 16:47:07.430 - error: javascript.0 (1423151) deprecated har-validator@5.1.5: this library is no longer supported
    2022-03-03 16:47:07.502 - error: javascript.0 (1423151) npm
    2022-03-03 16:47:07.505 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.506 - error: javascript.0 (1423151) WARN
    2022-03-03 16:47:07.509 - error: javascript.0 (1423151) deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    2022-03-03 16:47:07.554 - error: javascript.0 (1423151) npm
    2022-03-03 16:47:07.557 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.560 - error: javascript.0 (1423151) WARN
    2022-03-03 16:47:07.562 - error: javascript.0 (1423151) deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    2022-03-03 16:47:07.601 - error: javascript.0 (1423151) npm
    2022-03-03 16:47:07.603 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.605 - error: javascript.0 (1423151) WARN
    2022-03-03 16:47:07.607 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.609 - error: javascript.0 (1423151) deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    2022-03-03 16:47:07.648 - error: javascript.0 (1423151) npm
    2022-03-03 16:47:07.651 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.652 - error: javascript.0 (1423151) WARN
    2022-03-03 16:47:07.654 - error: javascript.0 (1423151)
    2022-03-03 16:47:07.656 - error: javascript.0 (1423151) deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @basti97
    Nicht so wichtig.
    Du könntest aber beim Adapter ein Issue eröffnen und fragen, ob die Dependencies aktualisiert werden können.
    Basti97B 1 Antwort Letzte Antwort
    • Basti97B Basti97
      Node.js
      NPM
          8.1.2
      JSController 3.3.22
      apollon77A
      apollon77A
      @basti97 Naja der JavaScript Adapter installiert beim Start die Pakete die du dort konfiguriert hast ... und das sind potentielle Ausgaben davon .. also von daher ...
        @basti97
        Nicht so wichtig.
        Basti97B
        Basti97B
        Basti97
        @thomas-braun @apollon77 Danke also kann ich das vernachlässigen und brauche mir keine sorgen machen. Ich werde demnächst ein issuses aufmachen. Wenn ein anderer die Fehlermeldung hat das er weiß das alles ok ist. Muss ich das bei dem Javascript Adapter bei github stellen?
        Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
        • Basti97B Basti97
          apollon77A
          apollon77A
          @basti97 Ein Issue wegen was willst du auf machen?
          • Basti97B
            Basti97B
            Basti97
            Bei mir ist leider der Javascript Adapter von meinen Slave kaputt gegangen. Ich glaube ich muss die SD Karte mal wechseln.
            Welche Pakete muss ich nun nachinstallieren und wie?
            host.Media04
            	2022-03-04 18:48:34.078	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.Media04
            	2022-03-04 18:48:34.077	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
            host.Media04
            	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
            host.Media04
            	2022-03-04 18:48:34.077	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
            host.Media04
            	2022-03-04 18:48:34.076	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
            host.Media04
            	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
            host.Media04
            	2022-03-04 18:48:34.074	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
            host.Media04
            	2022-03-04 18:48:34.073	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
            host.Media04
            	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
            host.Media04
            	2022-03-04 18:48:34.073	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
            host.Media04
            	2022-03-04 18:48:34.072	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
            host.Media04
            	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
            host.Media04
            	2022-03-04 18:48:34.070	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
            host.Media04
            	2022-03-04 18:48:34.071	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
            host.Media04
            	2022-03-04 18:48:34.069	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
            host.Media04
            	2022-03-04 18:48:34.068	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
            host.Media04
            	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
            host.Media04
            	2022-03-04 18:48:34.067	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
            host.Media04
            	2022-03-04 18:48:34.066	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
            host.Media04
            	2022-03-04 18:48:34.065	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
            host.Media04
            	2022-03-04 18:48:34.064	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
            host.Media04
            	2022-03-04 18:48:34.063	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
            host.Media04
            	2022-03-04 18:48:34.062	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
            host.Media04
            	2022-03-04 18:48:34.061	error	Caught by controller[0]:
            • apollon77A apollon77
              Basti97B
              Basti97B
              Basti97
              @apollon77 said in Update Javascript auf 5.2.21 - Fehler im Log:
              Das der Fehler behoben wird. :)
              • Basti97B Basti97
                apollon77A
                apollon77A
                @basti97 welcher Fehler? Wenn npm das als error loggt landet es als error im log. Ist „as designed”
                • Basti97B Basti97
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  host.Media04
                  apollon77A
                  apollon77A
                  @basti97 Puhh. Kommt das auch wenn alle Skripte dort gestoppt sind? Sonst reinstalliere mal den JavaScript Adapter selbst.
                  Basti97B 2 Antworten Letzte Antwort
                    Basti97B
                    Basti97B
                    Basti97
                    schrieb am zuletzt editiert von Basti97
                    @apollon77 Der Adapter lässt sich gar nicht erst starten die Meldung kommt sobald ich ihn starten möchte. Bei den Java Adapter steht als Verbrauch 0MB
                    Ich glaube ich muss bei meinem Slave doch langsam die SD wechseln.
                      Basti97B
                      Basti97B
                      Basti97
                      @apollon77 noch vergessen das kommt noch zuvor
                      Das ist das komplette Log
                      host.Media04
                      	2022-03-04 23:53:43.832	info	Restart adapter system.adapter.javascript.1 because enabled
                      host.Media04
                      	2022-03-04 23:53:43.832	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.Media04
                      	2022-03-04 23:53:43.831	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                      host.Media04
                      	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                      host.Media04
                      	2022-03-04 23:53:43.831	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-04 23:53:43.830	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                      host.Media04
                      	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                      host.Media04
                      	2022-03-04 23:53:43.829	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                      host.Media04
                      	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                      host.Media04
                      	2022-03-04 23:53:43.829	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-04 23:53:43.828	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                      host.Media04
                      	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                      host.Media04
                      	2022-03-04 23:53:43.827	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                      host.Media04
                      	2022-03-04 23:53:43.827	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                      host.Media04
                      	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                      host.Media04
                      	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                      host.Media04
                      	2022-03-04 23:53:43.826	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                      host.Media04
                      	2022-03-04 23:53:43.825	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                      host.Media04
                      	2022-03-04 23:53:43.825	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                      host.Media04
                      	2022-03-04 23:53:43.825	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                      host.Media04
                      	2022-03-04 23:53:43.824	error	Caught by controller[0]:
                      host.Media04
                      	2022-03-04 23:53:43.821	error	Caught by controller[0]: return getR�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&�'�&�&return splitChildren(node.getChildren(), function (_a) {
                      host.Media04
                      	2022-03-04 23:53:43.820	error	Caught by controller[0]: /opt/iobroker/node_modules/typescript/lib/typescript.js:139366
                      • Basti97B Basti97
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        host.Media04
                        apollon77A
                        apollon77A
                        @basti97 ja Adapter s add m besten löschen und neu installieren und vorher as Karte tauschen
                          Basti97B
                          Basti97B
                          Basti97
                          @apollon77 Danke werde ich morgen mal machen.
                            Basti97B
                            Basti97B
                            Basti97
                            @apollon77
                            Ich habe auf dem Slave nun das hier eingegeben.
                            pi@Media04:~ $ iobroker del javascript.1
                            Delete adapter "javascript.1"
                            host.Media04 Counted 1 instances of javascript.1
                            host.Media04 Counted 2 channels of javascript.1
                            host.Media04 Counted 6 states of javascript.1
                            host.Media04 Counted 14 states of system.adapter.javascript.1
                            host.Media04 Counted 4 states (system.adapter.javascript.1.*) from states
                            host.Media04 Deleting 23 object(s).
                            host.Media04 Deleting 4 state(s).
                            pi@Media04:~ $ iobroker install javascript.1
                            adapter "javascript" already installed. Use "upgrade" to upgrade to a newer version.
                            Und danach über den Reiter Adapter nochmal neuinstalliert. Beim starten des Adapters kommt wieder diese Fehlermeldung.
                            host.Media04
                            	2022-03-06 12:24:11.686	info	Restart adapter system.adapter.javascript.1 because enabled
                            host.Media04
                            	2022-03-06 12:24:11.685	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.Media04
                            	2022-03-06 12:24:11.684	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
                            host.Media04
                            	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                            host.Media04
                            	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                            host.Media04
                            	2022-03-06 12:24:11.683	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                            host.Media04
                            	2022-03-06 12:24:11.682	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                            host.Media04
                            	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:73:5)
                            host.Media04
                            	2022-03-06 12:24:11.680	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                            host.Media04
                            	2022-03-06 12:24:11.681	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                            host.Media04
                            	2022-03-06 12:24:11.680	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                            host.Media04
                            	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                            host.Media04
                            	2022-03-06 12:24:11.678	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                            host.Media04
                            	2022-03-06 12:24:11.679	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                            host.Media04
                            	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                            host.Media04
                            	2022-03-06 12:24:11.677	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:5:12)
                            host.Media04
                            	2022-03-06 12:24:11.676	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                            host.Media04
                            	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                            host.Media04
                            	2022-03-06 12:24:11.676	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                            host.Media04
                            	2022-03-06 12:24:11.675	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                            host.Media04
                            	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1049:27)
                            host.Media04
                            	2022-03-06 12:24:11.673	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:1001:16)
                            host.Media04
                            	2022-03-06 12:24:11.674	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                            host.Media04
                            	2022-03-06 12:24:11.673	error	Caught by controller[0]: SyntaxError: Invalid or unexpected token
                            host.Media04
                            	2022-03-06 12:24:11.672	error	Caught by controller[0]:
                            Aber trotzdem funktioniert es nicht.
                            • Basti97B Basti97
                              @apollon77
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              host.Media04
                              apollon77A
                              apollon77A
                              @basti97 Naja du must wenn javascript komplett entfernen nicht nur instanz 1 ... Die Skripte werden an sich nicht gelöscht, also iob del javascript (vorher backup sicherheitshalber)
                              Alternativ kannst du vorher ein ´cd /opt/iobrokerundnpm i iobroker.javasscript` versuchen obs hilft
                                Basti97B
                                Basti97B
                                Basti97
                                @apollon77 Ich habe aber auf meinem Master noch zwei Javascript Instanzen laufen. Nicht das sie mit gelöscht werden.
                                Wenn ich den Master herunterfahre und das iobroker del javascript ausführe kommt das hier.
                                Oder soll ich das mal als sudo probieren.
                                No connection to databases possible ...
                                Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                • Basti97B Basti97
                                  Thomas BraunT
                                  Thomas BraunT
                                  @basti97 sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                                  Nein, iobroker nie mit sudo beackern.
                                    Basti97B
                                    Basti97B
                                    Basti97
                                    @thomas-braun ok also führe ich auf den Slave mal das hier aus?
                                    bleiben die andere Instanzen unberührt oder soll ich den Master herunterfahren.
                                    • Basti97B Basti97
                                      apollon77A
                                      apollon77A
                                      @basti97 dann mach lieber das mit npm install ... zu dem "no connection to db": Welcher controller? Welche db?
                                        Basti97B
                                        Basti97B
                                        Basti97
                                        @apollon77
                                            Plattform: linux
                                            Betriebssystem: linux
                                            Architektur: arm
                                            CPUs: 4
                                            Geschwindigkeit: 600 MHz
                                            Modell: ARMv7 Processor rev 4 (v7l)
                                            RAM: 922.8 MB
                                            System-Betriebszeit: 1 T. 22:21:40
                                            Node.js: v14.19.0
                                            NPM: 6.14.16
                                            Datenträgergröße: 14.5 GB
                                            freier Festplattenspeicher: 4.9 GB
                                            Adapter-Anzahl: 400
                                            Betriebszeit: 04:10:41
                                            Aktive Instanzen: 4
                                            Pfad: /opt/iobroker/
                                            JS Controller: 3.3.2
                                        Javascript Adapter hat die Version 5.2.21
                                        Brauchst du noch mehr infos?
                                          Basti97B
                                          Basti97B
                                          Basti97
                                          @apollon77 sollte ich das ausführen? Weil irgendwie ging es nicht.
                                          pi@Media04:~ $ cd /opt/iobrokerundnpm i iobroker.javasscript
                                          -bash: cd: Zu viele Argumente.
                                          pi@Media04:~ $ cd /opt/iobroker undnpm i iobroker.javasscript
                                          33.2k
                                          84.3k
