  4. Update Javascript auf 5.2.21 - Fehler im Log
    apollon77A
53 Beiträge 6 Kommentatoren 8.4k Aufrufe 4 Beobachtet
  • Samson71S
    Samson71S
    Samson71
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Syno/Docker
    Habe heute JS aktualisiert von 5.2.13 auf 5.2.21 und habe folgende Fehler im Protokoll, aus denen ich aber (für mich) kein ToDo ableiten kann. Grundsätzlich scheint aber erstmal alles zu funktionieren.
    javascript.0	2022-02-16 15:31:49.636	info	(24753) received all objects
    javascript.0	2022-02-16 15:31:48.813	info	(24753) received all states
    javascript.0	2022-02-16 15:31:45.905	info	(24753) requesting all objects
    javascript.0	2022-02-16 15:31:45.904	info	(24753) requesting all states
    javascript.0	2022-02-16 15:31:45.820	info	(24753) found 0 vulnerabilities
    javascript.0	2022-02-16 15:31:45.819	info	run `npm fund` for details
    javascript.0	2022-02-16 15:31:45.819	info	8 packages are looking for funding
    javascript.0	2022-02-16 15:31:45.819	info	(24753)
    javascript.0	2022-02-16 15:31:45.680	info	added 9 packages from 11 contributors and audited 78 packages in 12.587s
    javascript.0	2022-02-16 15:31:45.680	info	(24753) + node-ssh@12.0.3
    javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 install: `node-gyp rebuild`
    javascript.0	2022-02-16 15:31:45.676	error	(24753) WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 (node_modules/cpu-features):
    javascript.0	2022-02-16 15:31:45.675	error	(24753) npm
    javascript.0	2022-02-16 15:31:45.362	info	(24753) Succeeded in building optional crypto binding
    javascript.0	2022-02-16 15:31:45.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
    javascript.0	2022-02-16 15:31:45.188	info	(24753) COPY Release/sshcrypto.node
    javascript.0	2022-02-16 15:31:44.559	info	(24753) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
    javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~
    javascript.0	2022-02-16 15:31:41.390	error	2003 | NODE_MODULE(sshcrypto, init)
    javascript.0	2022-02-16 15:31:41.390	error	../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’
    javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~
    javascript.0	2022-02-16 15:31:41.390	error	770 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
    javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    javascript.0	2022-02-16 15:31:41.390	error	736 | (node::addon_register_func) (regfunc), \
    javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::
    javascript.0	2022-02-16 15:31:41.390	error	(24753) In file included from ../src/binding.cc:6:
    javascript.0	2022-02-16 15:31:38.461	info	(24753) CXX(target) Release/obj.target/sshcrypto/src/binding.o
    javascript.0	2022-02-16 15:31:38.460	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
    javascript.0	2022-02-16 15:31:37.370	info	> node install.js
    javascript.0	2022-02-16 15:31:37.370	info	> ssh2@1.6.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
    javascript.0	2022-02-16 15:31:37.370	info	(24753)
    javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! not ok
    javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node-gyp -v v5.1.0
    javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node -v v12.22.7
    javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
    javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    javascript.0	2022-02-16 15:31:37.347	error	(24753) gyp ERR! System Linux 4.4.59+
    javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.emit (events.js:314:20)
    javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack Error: `make` failed with exit code: 2
    javascript.0	2022-02-16 15:31:37.345	error	(24753) gyp ERR! build error
    javascript.0	2022-02-16 15:31:37.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
    javascript.0	2022-02-16 15:31:37.342	error	(24753) make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127
    javascript.0	2022-02-16 15:31:37.341	error	(24753) /bin/sh: 1: cmake: not found
    javascript.0	2022-02-16 15:31:37.334	info	(24753) ACTION Configuring dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile
    javascript.0	2022-02-16 15:31:37.333	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
    host.iobroker	2022-02-16 15:31:36.358	info	iobroker exit 0
    javascript.0	2022-02-16 15:31:36.037	info	> node-gyp rebuild
    javascript.0	2022-02-16 15:31:36.037	info	> cpu-features@0.0.2 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
    javascript.0	2022-02-16 15:31:36.037	info	(24753)
    Markus
    Bitte beachten:
    • Thomas BraunT
      Thomas BraunT
      @samson71
      cmake: not found
      cmake nachinstallieren.
        @samson71
        cmake: not found
        Samson71S
        Samson71S
        Samson71
        Danke für die schnelle Rückmeldung. Dann muss ich mir das unter Docker mal näher ansehen. Habe ich ehrlich gesagt (noch) keinen Plan wie.
        Markus
        Bitte beachten:
        • Samson71S Samson71
          Thomas BraunT
          Thomas BraunT
          @samson71
          In nativen Debian-Umgebungen halt wie üblich:
          sudo apt update
          sudo apt install cmake
          Ob das eingedost anders gemacht werden muss hab ich keine Ahnung von.
          • NamrennerN
            NamrennerN
            Namrenner
            bekomme leider diesen Fehler:
            D:\Iobroker\SmartHome>npm install "cmake"
            > cmake@0.0.4 install D:\Iobroker\SmartHome\node_modules\cmake
            > make
            Der Befehl "make" ist entweder falsch geschrieben oder
            konnte nicht gefunden werden.
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! cmake@0.0.4 install: `make`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the cmake@0.0.4 install script.
            Thomas BraunT apollon77A 2 Antworten Letzte Antwort
            • NamrennerN Namrenner
              > make
              npm ERR! errno 1
              npm ERR!
              Thomas BraunT
              Thomas BraunT
              @namrenner
              Windows...
              Hab ich keine Aktien drin. Vielleicht gibt es cmake nicht dafür.
              NamrennerN 1 Antwort Letzte Antwort
                @namrenner
                Windows...
                NamrennerN
                NamrennerN
                Namrenner
                @thomas-braun ok, wir bekomme ich den Update v5.2.21 drauf, andere Updates gehen, nur dieser nicht?
                liv-in-skyL Thomas BraunT 2 Antworten Letzte Antwort
                  liv-in-skyL
                  liv-in-skyL
                  @namrenner
                  EDIT: war falsch - kann ihn auch nicht installieren
                    Thomas BraunT
                    Thomas BraunT
                    @namrenner sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                    Mit welchen Meldungen?
                    NamrennerN liv-in-skyL 2 Antworten Letzte Antwort
                      NamrennerN
                      NamrennerN
                      Namrenner
                      @thomas-braun ```
                      $ iobroker upgrade javascript@5.2.21
                      Update javascript from @5.2.13 to @5.2.21
                      host.TV Adapter "system.adapter.javascript.0" is stopped.
                      NPM version: 6.14.16
                      Installing iobroker.javascript@5.2.21... (System call)
                      host.TV Cannot install iobroker.javascript@5.2.21: 4294963214
                      ERROR: Process exited with code 25
                        liv-in-skyL
                        liv-in-skyL
                        @thomas-braun bei mir:
                        host.iobroker59
                        2022-02-26 11:11:00.509	error	iobroker (node:27388) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                        host.iobroker59
                        2022-02-26 11:11:00.505	error	iobroker (node:27388) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                        danach werden instanzen neugestartet
                        • liv-in-skyL liv-in-sky
                          host.iobroker59
                          host.iobroker59
                          apollon77A
                          apollon77A
                          @liv-in-sky wie im Anderen thread. Gesagt. Mongodb lib ist buggy in alter Version und ab nodejs 14 wird das angemeckert. FAQ vom Controller 4 thread sagt was zu tun ist.
                          Aber nur wegen der Meldung sollte nichts neu starten. Die Meldungen nerven nur ;-)
                            @thomas-braun ```
                            apollon77A
                            apollon77A
                            @namrenner Windows oder Linux? Bitte mal das Upgrade Kommando an der Shell ausführen. Ich tippe das dann Fehlermeldungen kommen mit permissions.
                            Also wenn Linux dann „iob fix“ nutzen. Bei Windows bitte mal iobroker komplett beenden und update manuell machen. Auch schauen ob visentwo als Adapter installiert ist und latest updaten. Der hatte es kaputtes drin was auf Windows komische permission Effekte hatte
                              > make
                              npm ERR! errno 1
                              npm ERR!
                              apollon77A
                              apollon77A
                              @namrenner gute Frage. Ja das liegt übrigens an der ssh2 Library die du bestimmt manuell als JavaScript Adapter Modul dabei hast.
                              Am Ende ggf mal hier durcharbeiten?? https://github.com/mscdex/cpu-features/issues/3
                              • liv-in-skyL
                                liv-in-skyL
                                @apollon77 sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                                Warning: Accessing non-existent property '...' of module exports inside circular dependency
                                danke - habe ich gemacht
                                • javascript update läuft durch, wird aber nicht upgedatet - version in adapter tab:
                                Update javascript from @5.2.18 to @5.2.21
                                NPM version: 6.14.16Installing iobroker.javascript@5.2.21... (System call)
                                upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.02a8da94.js static/js/runtime-main.02a8da94.js application/javascript
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                Process exited with code 0
                                am ende steht wieder:
                                  apollon77A
                                  apollon77A
                                  @liv-in-sky Reloade mal ... Es gab mal Refresh issues im Admin ... vllt ist da nich so eins? Also wenn Admin 5.3.1 dann bitte github issue im admin anlegen
                                  • apollon77A apollon77
                                    NamrennerN
                                    NamrennerN
                                    Namrenner
                                    @apollon77
                                    D:\Iobroker\SmartHome>iobroker update
                                    D:\Iobroker\SmartHome>node node_modules/iobroker.js-controller/iobroker.js update
                                    Used repository: stable
                                    Adapter    "admin"        : 5.3.1    , installed 5.3.1
                                    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                    Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                                    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                    Adapter    "countdown"    : 1.2.5    , installed 1.2.5
                                    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                                    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                                    Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                    Adapter    "history"      : 1.10.5   , installed 1.10.5
                                    Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                                    Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
                                    Adapter    "info"         : 1.9.8    , installed 1.9.18
                                    Adapter    "iot"          : 1.8.24   , installed 1.8.24
                                    Adapter    "javascript"   : 5.2.21   , installed 5.2.13 [Updatable]
                                    Controller "js-controller": 4.0.15   , installed 4.0.15
                                    Adapter    "material"     : 1.1.2    , installed 1.1.2
                                    Adapter    "modbus"       : 3.4.17   , installed 3.4.17
                                    Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
                                    Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
                                    Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
                                    Adapter    "node-red"     : 2.4.2    , installed 2.4.2
                                    Adapter    "parser"       : 1.0.7    , installed 1.0.7
                                    Adapter    "ping"         : 1.5.0    , installed 1.5.0
                                    Adapter    "scenes"       : 2.3.8    , installed 2.3.8
                                    Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                                    Adapter    "smartmeter"   : 3.2.1    , installed 3.2.1
                                    Adapter    "socketio"     : 3.1.5    , installed 3.1.5
                                    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                                    Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                                    Adapter    "text2command" : 2.1.1    , installed 2.1.1
                                    Adapter    "vis"          : 1.4.5    , installed 1.4.5
                                    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                    Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                                    Adapter    "vis-inventwo" : 3.2.8    , installed 3.2.8
                                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                    Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "web"          : 3.4.16   , installed 3.4.16
                                    Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y
                                      @apollon77
                                      apollon77A
                                      apollon77A
                                      @namrenner naja dann machen wir mal
                                      „iobroker upgrade javascript --debug“
                                      Was sagt die Ausgabe? Und mal versuchen wenn iobroker komplett gestoppt ist.
                                      Ps: und nochmal die Frage: hast du Vis-icontwo als Adapter installiert????
                                        NamrennerN
                                        NamrennerN
                                        Namrenner
                                        schrieb am zuletzt editiert von Namrenner
                                        @apollon77
                                        Vis-icontwo denke nicht, in der Liste habe es nicht, sehe Nachricht davor, dort sind alle Adapter aufgelistet, danke.
                                        npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                        npm WARN rollback Rolling back iobroker.javascript@5.2.21 failed (this is probably harmless): EBUSY: resource busy or locked, rmdir 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript'
                                        npm ERR! code EBUSY
                                        npm ERR! syscall rename
                                        npm ERR! path D:\Iobroker\SmartHome\node_modules\iobroker.javascript
                                        npm ERR! dest D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE
                                        npm ERR! errno -4082
                                        npm ERR! EBUSY: resource busy or locked, rename 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript' -> 'D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE'
                                        npm ERR!     C:\Users\Hans\AppData\Roaming\npm-cache\_logs\2022-02-26T13_36_10_444Z-debug.log
                                          @apollon77
                                          npm ERR! code EBUSY
                                          apollon77A
                                          apollon77A
                                          @namrenner ebusy ist mal wieder so ne Windows Nummer. Bitte alles beenden und dann das Update machen. Scheinbar lockt Windows irgendwelche files die das Update Bzw npm dann nicht austauschen kann.
                                          Wir stoppen zwar auf Windows seit Controller 4 immer die Instanzen des Adapters was das Update bekommt aber manchmal scheint das bei Windows nicht zu reichen :-(
                                          83.9k
