  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • apollon77A apollon77
    @diginix Ok, wäre cool wenn du nochmal reinschauen kannst bei Zeit
    DiginixD Offline
    DiginixD Offline
    Diginix
    #291
    @apollon77
    Das wird dir nicht helfen:
    2022-02-11 12:29:25.448 - info: simple-api.0 (350760) https server listening on port 8285
    2022-02-11 12:29:33.454 - info: text2command.0 (350816) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.0, js-controller: 4.0.8
    2022-02-11 12:29:44.963 - error: web.0 (350832) [LE] {"code":"E_FAIL_DRY_CHALLENGE","context":"cert_renewal","subject":"***","altnames":["***"]}
    2022-02-11 12:29:57.275 - error: web.0 (350832) [LE] {"code":"E_FAIL_DRY_CHALLENGE","context":"cert_renewal","subject":"***","altnames":["***"]}
    2022-02-11 12:30:23.546 - warn: javascript.0 (349701) getState "system.adapter.modbus.0.connected" not found (3)
    2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.<anonymous> (script.js.0.System.Checks_and_Restarts:449:67)
    2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
    2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2022-02-11 12:30:23.549 - warn: javascript.0 (349701)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5902:56)
    2022-02-11 12:30:23.549 - warn: javascript.0 (349701)     at processImmediate (internal/timers.js:464:21)
    2022-02-11 12:30:23.640 - warn: javascript.0 (349701) getState "system.adapter.shelly.0.connected" not found (3)
    2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.<anonymous> (script.js.0.System.Checks_and_Restarts:376:67)
    2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
    2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2022-02-11 12:30:23.642 - warn: javascript.0 (349701)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5902:56)
    2022-02-11 12:30:23.642 - warn: javascript.0 (349701)     at processImmediate (internal/timers.js:464:21)
    2022-02-11 12:30:25.672 - warn: host.iobroker Your system has only 96 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:30:25.678 - warn: host.iobroker Your system has only 96 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:30:26.481 - warn: host.iobroker Your system has only 89 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:30:26.520 - warn: host.iobroker Your system has only 88 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:30:34.119 - error: text2command.0 (350816) States database error: read ECONNRESET
    2022-02-11 12:30:34.133 - error: simple-api.0 (350760) Objects database error: read ECONNRESET
    2022-02-11 12:30:34.134 - error: radar2.0 (350696) States database error: read ECONNRESET
    2022-02-11 12:30:34.154 - error: parser.0 (350642) States database error: read ECONNRESET
    2022-02-11 12:30:34.161 - error: lupusec.0 (350587) States database error: read ECONNRESET
    2022-02-11 12:30:34.171 - error: info.0 (350074) States database error: read ECONNRESET
    2022-02-11 12:30:34.177 - error: backitup.0 (350000) States database error: read ECONNRESET
    2022-02-11 12:30:34.191 - error: shelly.0 (349917) States database error: read ECONNRESET
    2022-02-11 12:30:34.193 - error: shelly.0 (349917) Objects database error: read ECONNRESET
    2022-02-11 12:30:34.205 - error: modbus.0 (349812) Objects database error: read ECONNRESET
    2022-02-11 12:30:34.213 - error: alexa2.0 (349750) States database error: read ECONNRESET
    2022-02-11 12:30:34.222 - error: javascript.0 (349701) States database error: read ECONNRESET
    2022-02-11 12:30:34.247 - error: mqtt.0 (349829) Objects database error: read ECONNRESET
    2022-02-11 12:30:34.264 - info: javascript.0 (349701) Stop script script.js.0.Devices.Bring
    2022-02-11 12:30:34.262 - info: backitup.0 (350000) cleaned everything up...
    2022-02-11 12:30:34.270 - info: simple-api.0 (350760) terminating https server on port 8285
    2022-02-11 12:30:34.277 - info: admin.0 (349653) terminating https server on port 8081
    2022-02-11 12:30:34.273 - error: mihome-vacuum.0 (349797) Socket Close
    2022-02-11 12:30:34.305 - error: ping.0 (349885) Objects database error: read ECONNRESET
    2022-02-11 12:30:34.197 - error: sonoff.0 (349940) States database error: read ECONNRESET
    2022-02-11 12:30:34.325 - warn: influxdb.0 (349733) Store data for 1025 points and 0 conflicts
    2022-02-11 12:30:34.346 - info: iot.1 (350554) Connection changed: disconnect
    2022-02-11 12:30:34.347 - info: iot.1 (350554) Connection lost
    Die JS getState Fehler hatte ich sonst auch. Das direkt danach die RAM Meldungen kommen ist schon komisch. In der CLI mit free -m war es meine ich auch nicht so knapp. Der Loglevel vom Controller ist allerdings auch warn. K.a. ob mit info mehr gekommen wäre. Da er nun nach Reboot vorerst unauffällig läuft und auch ein Adapter Update gerade schon problemlos klappte, würde ich es unter "blöder Zufall" abstempeln.
    ..:: So long! Tom ::..
    • DiginixD Diginix
      @apollon77
      #292
      @diginix Schau mal ins /var/log/syslog ... ich tippe eher das dir der OOM Killer den controller abgeschossen hat ... wegen RAM issues, weil das wäre die Erklärung das alle adapter die DB COnnection verlieren
        DiginixD Offline
        DiginixD Offline
        Diginix
        #293
        @apollon77 Jup, sieht so aus:
        Feb 11 12:29:17 iobroker kernel: [177211.018669] debugfs: File 'le_min_key_size' in directory 'hci0' already present!
        Feb 11 12:29:17 iobroker kernel: [177211.019665] debugfs: File 'le_max_key_size' in directory 'hci0' already present!
        Feb 11 12:29:17 iobroker kernel: [177211.195576] device ens18 entered promiscuous mode
        Feb 11 12:29:17 iobroker kernel: [177211.240654] device ens18 left promiscuous mode
        Feb 11 12:29:24 iobroker kernel: [177217.687482] device ens18 entered promiscuous mode
        Feb 11 12:29:24 iobroker kernel: [177217.889378] debugfs: File 'le_min_key_size' in directory 'hci0' already present!
        Feb 11 12:29:24 iobroker kernel: [177217.890173] debugfs: File 'le_max_key_size' in directory 'hci0' already present!
        Feb 11 12:29:25 iobroker kernel: [177218.944360] device ens18 left promiscuous mode
        Feb 11 12:29:27 iobroker bash[349628]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
        Feb 11 12:29:27 iobroker bash[349628]: Send diag info: {"uuid":"40ef6245-7146-4f16-3646-632acb8f00bd","language":"de","country":"Germany","hosts":[{"version":"4.0.8","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.0","arch":"x64","docker":false,"adapters":{"admin":{"version":"5.3.0","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.2.4","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.9","platform":"Javascript/Node.js"},"discovery":{"version":"2.7.5","platform":"Javascript/Node.js"},"dwd":{"version":"2.7.7","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"fb-checkpresence":{"version":"1.1.13","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.10.5","platform":"Javascript/Node.js"},"ical":{"version":"1.11.6","platform":"Javascript/Node.js"},"info":{"version":"1.9.17","platform":"Javascript/Node.js"},"iot":{"version":"1.9.5","platform":"Javascript/Node.js"},"jarvis":{"version":"2.2.5","platform":"Javascript/Node.js"},"javascript":{"version":"5.2.21","platform":"Javascript/Node.js"},"lupusec":{"version":"1.3.6","platform":"Javascript/Node.js"},"mihome":{"version":"1.3.7","platform":"javascript/Node.js"},"mihome-vacuum":{"version":"3.3.4","platform":"Javascript/Node.js"},"modbus":{"version":"3.4.17","platform":"Javascript/Node.js"},"mqtt":{"version":"2.4.1","platform":"Javascript/Node.js"},"node-red":{"version":"1.7.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.1.1","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"ping":{"version":"1.5.2","platform":"Javascript/Node.js"},"plenticore":{"version":"2.2.1","platform":"Javascript/Node.js"},"radar":{"version":"1.2.1","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"shelly":{"version":"5.1.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.2","platform":"Javascript/Node.js"},"socketio":{"version":"3.1.4","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.7","platform":"Javascript/Node.js"},"statistics":{"version":"1.0.10","platform":"Javascript/Node.js"},"telegram":{"version":"1.11.1","platform":"Javascript/Node.js"},"text2command":{"version":"2.1.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"ubuntu":{"version":"0.1.3","platform":"javascript/Node.js"},"upnp":{"version":"0.3.9","platform":"Javascript/Node.js"},"web":{"version":"4.1.1","platform":"Javascript/Node.js"},"yeelight":{"version":"0.0.1","platform":"Javascript/Node.js"},"yeelight-2":{"version":"1.1.2","platform":"Javascript/Node.js"},"proxmox":{"version":"1.3.4","platform":"Javascript/Node.js"},"influxdb":{"version":"2.4.0","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"netatmo-crawler":{"version":"0.7.1","platform":"Javascript/Node.js"},"bydbatt":{"version":"1.0.7","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.1.1","platform":"javascript/Node.js"},"bring":{"version":"1.7.13","platform":"Javascript/Node.js"},"pvforecast":{"version":"0.1.8","platform":"Javascript/Node.js"},"alias-manager":{"version":"1.2.4","platform":"Javascript/Node.js"},"ws":{"version":"1.1.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":49,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":4122136576,"ostype":"Linux"}
        Feb 11 12:30:33 iobroker kernel: [177287.231054] io.email.0 invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
        Feb 11 12:30:33 iobroker kernel: [177287.231059] CPU: 3 PID: 349670 Comm: io.email.0 Not tainted 5.4.0-99-generic #112-Ubuntu
        Feb 11 12:30:33 iobroker kernel: [177287.231060] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org 04/01/2014
        Feb 11 12:30:33 iobroker kernel: [177287.231061] Call Trace:
        Feb 11 12:30:33 iobroker kernel: [177287.231068]  dump_stack+0x6d/0x8b
        Feb 11 12:30:33 iobroker kernel: [177287.231071]  dump_header+0x4f/0x1eb
        Feb 11 12:30:33 iobroker kernel: [177287.231073]  oom_kill_process.cold+0xb/0x10
        Feb 11 12:30:33 iobroker kernel: [177287.231076]  out_of_memory+0x1cf/0x4d0
        Feb 11 12:30:33 iobroker kernel: [177287.231080]  __alloc_pages_slowpath+0xd5e/0xe50
        Feb 11 12:30:33 iobroker kernel: [177287.231084]  __alloc_pages_nodemask+0x2d0/0x320
        Feb 11 12:30:33 iobroker kernel: [177287.231086]  alloc_pages_current+0x87/0xe0
        Feb 11 12:30:33 iobroker kernel: [177287.231089]  __page_cache_alloc+0x72/0x90
        Feb 11 12:30:33 iobroker kernel: [177287.231091]  pagecache_get_page+0xbf/0x300
        Feb 11 12:30:33 iobroker kernel: [177287.231094]  filemap_fault+0x6b2/0xa50
        Feb 11 12:30:33 iobroker kernel: [177287.231096]  ? unlock_page_memcg+0x12/0x20
        Feb 11 12:30:33 iobroker kernel: [177287.231098]  ? page_add_file_rmap+0xff/0x1a0
        Feb 11 12:30:33 iobroker kernel: [177287.231100]  ? __switch_to_asm+0x34/0x70
        Feb 11 12:30:33 iobroker kernel: [177287.231103]  ? xas_load+0xd/0x80
        Feb 11 12:30:33 iobroker kernel: [177287.231105]  ? xas_find+0x17f/0x1c0
        Feb 11 12:30:33 iobroker kernel: [177287.231107]  ? filemap_map_pages+0x24c/0x380
        Feb 11 12:30:33 iobroker kernel: [177287.231111]  ext4_filemap_fault+0x32/0x50
        Feb 11 12:30:33 iobroker kernel: [177287.231113]  __do_fault+0x3c/0x130
        Feb 11 12:30:33 iobroker kernel: [177287.231114]  do_fault+0x24b/0x640
        Feb 11 12:30:33 iobroker kernel: [177287.231116]  ? __switch_to_asm+0x34/0x70
        Feb 11 12:30:33 iobroker kernel: [177287.231118]  __handle_mm_fault+0x4c5/0x7a0
        Feb 11 12:30:33 iobroker kernel: [177287.231120]  handle_mm_fault+0xca/0x200
        Feb 11 12:30:33 iobroker kernel: [177287.231123]  do_user_addr_fault+0x1f9/0x450
        Feb 11 12:30:33 iobroker kernel: [177287.231126]  __do_page_fault+0x58/0x90
        Feb 11 12:30:33 iobroker kernel: [177287.231127]  do_page_fault+0x2c/0xe0
        Feb 11 12:30:33 iobroker kernel: [177287.231130]  do_async_page_fault+0x39/0x70
        Feb 11 12:30:33 iobroker kernel: [177287.231132]  async_page_fault+0x34/0x40
        Feb 11 12:30:33 iobroker kernel: [177287.231134] RIP: 0033:0xbe9e10
        Feb 11 12:30:33 iobroker kernel: [177287.231140] Code: Bad RIP value.
        Feb 11 12:30:33 iobroker kernel: [177287.231141] RSP: 002b:00007ffcbd32bba8 EFLAGS: 00010297
        Feb 11 12:30:33 iobroker kernel: [177287.231143] RAX: 0000000005753b10 RBX: 00007ffcbd32bcd0 RCX: 000000000593fe20
        Feb 11 12:30:33 iobroker kernel: [177287.231144] RDX: 00000000056bb1c0 RSI: 1baffed00baffedf RDI: 000000000569ec00
        Feb 11 12:30:33 iobroker kernel: [177287.231145] RBP: 00007ffcbd32bc40 R08: 000000000579cb00 R09: 0000000000000000
        Feb 11 12:30:33 iobroker kernel: [177287.231146] R10: 00000e60520d84c1 R11: 000000000002b48a R12: 000000000579cb08
        Feb 11 12:30:33 iobroker kernel: [177287.231147] R13: 0000000005753b10 R14: 000000000579cb08 R15: 0000000000000000
        Feb 11 12:30:33 iobroker kernel: [177287.231149] Mem-Info:
        Feb 11 12:30:33 iobroker kernel: [177287.231154] active_anon:908320 inactive_anon:45 isolated_anon:0
        Feb 11 12:30:33 iobroker kernel: [177287.231154]  active_file:330 inactive_file:274 isolated_file:1
        Feb 11 12:30:33 iobroker kernel: [177287.231154]  unevictable:4618 dirty:0 writeback:0 unstable:0
        Feb 11 12:30:33 iobroker kernel: [177287.231154]  slab_reclaimable:10429 slab_unreclaimable:23100
        Feb 11 12:30:33 iobroker kernel: [177287.231154]  mapped:2534 shmem:288 pagetables:12484 bounce:0
        Feb 11 12:30:33 iobroker kernel: [177287.231154]  free:21604 free_pcp:1153 free_cma:0
        Feb 11 12:30:33 iobroker kernel: [177287.231157] Node 0 active_anon:3633280kB inactive_anon:180kB active_file:1320kB inactive_file:1096kB unevictable:18472kB isolated(anon):0kB isolated(file):4kB mapped:10136kB dirty:0kB writeback:0kB shmem:1152kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
        Feb 11 12:30:33 iobroker kernel: [177287.231158] Node 0 DMA free:15568kB min:272kB low:340kB high:408kB active_anon:332kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15908kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
        Feb 11 12:30:33 iobroker kernel: [177287.231162] lowmem_reserve[]: 0 2875 3827 3827 3827
        Feb 11 12:30:33 iobroker kernel: [177287.231164] Node 0 DMA32 free:54240kB min:50560kB low:63200kB high:75840kB active_anon:2819480kB inactive_anon:48kB active_file:244kB inactive_file:764kB unevictable:0kB writepending:0kB present:3129176kB managed:3034304kB mlocked:0kB kernel_stack:6432kB pagetables:43536kB bounce:0kB free_pcp:1324kB local_pcp:428kB free_cma:0kB
        Feb 11 12:30:33 iobroker kernel: [177287.231167] lowmem_reserve[]: 0 0 952 952 952
        Feb 11 12:30:33 iobroker kernel: [177287.231170] Node 0 Normal free:16608kB min:16748kB low:20932kB high:25116kB active_anon:813468kB inactive_anon:132kB active_file:1632kB inactive_file:1272kB unevictable:18472kB writepending:0kB present:1048576kB managed:975312kB mlocked:18472kB kernel_stack:3312kB pagetables:6400kB bounce:0kB free_pcp:3288kB local_pcp:688kB free_cma:0kB
        Feb 11 12:30:33 iobroker kernel: [177287.231173] lowmem_reserve[]: 0 0 0 0 0
        Feb 11 12:30:33 iobroker kernel: [177287.231174] Node 0 DMA: 2*4kB (UM) 1*8kB (U) 2*16kB (UM) 1*32kB (M) 2*64kB (U) 2*128kB (UM) 1*256kB (U) 1*512kB (M) 2*1024kB (UM) 0*2048kB 3*4096kB (ME) = 15568kB
        Feb 11 12:30:33 iobroker kernel: [177287.231183] Node 0 DMA32: 3006*4kB (UE) 1977*8kB (UE) 439*16kB (UME) 15*32kB (UME) 222*64kB (UME) 35*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 54032kB
        Feb 11 12:30:33 iobroker kernel: [177287.231190] Node 0 Normal: 393*4kB (UME) 379*8kB (UMEH) 274*16kB (UME) 165*32kB (UMEH) 22*64kB (UME) 1*128kB (M) 1*256kB (M) 2*512kB (ME) 0*1024kB 0*2048kB 0*4096kB = 17084kB
        Feb 11 12:30:33 iobroker kernel: [177287.231199] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
        Feb 11 12:30:33 iobroker kernel: [177287.231200] 2868 total pagecache pages
        Feb 11 12:30:33 iobroker kernel: [177287.231201] 0 pages in swap cache
        Feb 11 12:30:33 iobroker kernel: [177287.231202] Swap cache stats: add 0, delete 0, find 0/0
        Feb 11 12:30:33 iobroker kernel: [177287.231203] Free swap  = 0kB
        Feb 11 12:30:33 iobroker kernel: [177287.231203] Total swap = 0kB
        Feb 11 12:30:33 iobroker kernel: [177287.231204] 1048436 pages RAM
        Feb 11 12:30:33 iobroker kernel: [177287.231205] 0 pages HighMem/MovableOnly
        Feb 11 12:30:33 iobroker kernel: [177287.231206] 42055 pages reserved
        Feb 11 12:30:33 iobroker kernel: [177287.231206] 0 pages cma reserved
        Feb 11 12:30:33 iobroker kernel: [177287.231207] 0 pages hwpoisoned
        Feb 11 12:30:33 iobroker kernel: [177287.231208] Tasks state (memory values in pages):
        Feb 11 12:30:33 iobroker kernel: [177287.231209] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
        Feb 11 12:30:33 iobroker kernel: [177287.231217] [    377]     0   377    22370     1062   188416        0          -250 systemd-journal
        Feb 11 12:30:33 iobroker kernel: [177287.231220] [    412]     0   412     5347      798    65536        0         -1000 systemd-udevd
        Feb 11 12:30:33 iobroker kernel: [177287.231223] [    587]     0   587    70036     4487    94208        0         -1000 multipathd
        Feb 11 12:30:33 iobroker kernel: [177287.231226] [    642]   112   642     1776      675    49152        0             0 rpcbind
        Feb 11 12:30:33 iobroker kernel: [177287.231233] [    643]   102   643    22558      449    81920        0             0 systemd-timesyn
        Feb 11 12:30:33 iobroker kernel: [177287.231255] [    683]   100   683     6653      833    77824        0             0 systemd-network
        Feb 11 12:30:33 iobroker kernel: [177287.231257] [    685]   101   685     6340     1676    86016        0             0 systemd-resolve
        Feb 11 12:30:33 iobroker kernel: [177287.231259] [    698]     0   698    58895      533    94208        0             0 accounts-daemon
        Feb 11 12:30:33 iobroker kernel: [177287.231261] [    701]     0   701     2134      597    61440        0             0 bluetoothd
        Feb 11 12:30:33 iobroker kernel: [177287.231263] [    704]     0   704     1392      545    53248        0             0 cron
        Feb 11 12:30:33 iobroker kernel: [177287.231265] [    705]   103   705     1995      886    53248        0          -900 dbus-daemon
        Feb 11 12:30:33 iobroker kernel: [177287.231267] [    713]     0   713    20474      275    57344        0             0 irqbalance
        Feb 11 12:30:33 iobroker kernel: [177287.231269] [    715]     0   715     6656     2731    90112        0             0 networkd-dispat
        Feb 11 12:30:33 iobroker kernel: [177287.231271] [    716]     0   716     1638      482    53248        0             0 qemu-ga
        Feb 11 12:30:33 iobroker kernel: [177287.231280] [    717]   104   717    56087      671    86016        0             0 rsyslogd
        Feb 11 12:30:33 iobroker kernel: [177287.231282] [    726]     0   726     4183      441    77824        0             0 systemd-logind
        Feb 11 12:30:33 iobroker kernel: [177287.231284] [    729]     0   729    98138      477   126976        0             0 udisksd
        Feb 11 12:30:33 iobroker kernel: [177287.231286] [    732]     0   732      948      496    49152        0             0 atd
        Feb 11 12:30:33 iobroker kernel: [177287.231288] [    752]     0   752     3044      939    61440        0         -1000 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231290] [    756]     0   756      715      381    40960        0             0 agetty
        Feb 11 12:30:33 iobroker kernel: [177287.231292] [    761]     0   761    26287     2670    98304        0             0 unattended-upgr
        Feb 11 12:30:33 iobroker kernel: [177287.231294] [    779]     0   779    58179      269    86016        0             0 polkitd
        Feb 11 12:30:33 iobroker kernel: [177287.231297] [  66929]     0 66929    62068      537   110592        0             0 upowerd
        Feb 11 12:30:33 iobroker kernel: [177287.231300] [ 301951]   107 301951     1695      170    49152        0             0 uuidd
        Feb 11 12:30:33 iobroker kernel: [177287.231302] [ 307461]     0 307461     3482      997    73728        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231304] [ 307476]  1000 307476     4601      751    77824        0             0 systemd
        Feb 11 12:30:33 iobroker kernel: [177287.231306] [ 307478]  1000 307478    42513     1180    94208        0             0 (sd-pam)
        Feb 11 12:30:33 iobroker kernel: [177287.231309] [ 307602]  1000 307602     3516      834    73728        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231311] [ 307603]  1000 307603     1465      469    45056        0             0 bash
        Feb 11 12:30:33 iobroker kernel: [177287.231313] [ 325101]     0 325101     3481     1021    61440        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231316] [ 325227]  1000 325227     3686      658    65536        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231318] [ 325228]  1000 325228     1465      543    57344        0             0 bash
        Feb 11 12:30:33 iobroker kernel: [177287.231320] [ 325300]     0 325300     3481      995    69632        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231322] [ 325388]  1000 325388     3666     1065    73728        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231325] [ 325389]  1000 325389     1465      537    45056        0             0 bash
        Feb 11 12:30:33 iobroker kernel: [177287.231327] [ 326632]     0 326632   273772     3983   274432        0          -900 snapd
        Feb 11 12:30:33 iobroker kernel: [177287.231331] [ 347969]     0 347969     3482     1019    69632        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231333] [ 348049]  1000 348049     3516      371    69632        0             0 sshd
        Feb 11 12:30:33 iobroker kernel: [177287.231335] [ 348050]  1000 348050     1412      455    57344        0             0 bash
        Feb 11 12:30:33 iobroker kernel: [177287.231337] [ 348051]  1000 348051     1766      855    49152        0             0 bash
        Feb 11 12:30:33 iobroker kernel: [177287.231341] [ 349628]  1000 349628   719124   504915 11972608        0             0 iobroker.js-con
        Feb 11 12:30:33 iobroker kernel: [177287.231343] [ 349653]  1000 349653   248458    25632  3637248        0             0 io.admin.0
        Feb 11 12:30:33 iobroker kernel: [177287.231345] [ 349670]  1000 349670   163964     5908  2166784        0             0 io.email.0
        Feb 11 12:30:33 iobroker kernel: [177287.231347] [ 349685]  1000 349685   166034     8233  2289664        0             0 io.history.0
        Feb 11 12:30:33 iobroker kernel: [177287.231349] [ 349701]  1000 349701   240738    51933  5328896        0             0 io.javascript.0
        Feb 11 12:30:33 iobroker kernel: [177287.231351] [ 349733]  1000 349733   167132     9510  2416640        0             0 io.influxdb.0
        Feb 11 12:30:33 iobroker kernel: [177287.231354] [ 349750]  1000 349750   231765     8390  2318336        0             0 io.alexa2.0
        Feb 11 12:30:33 iobroker kernel: [177287.231356] [ 349765]  1000 349765   230870     7512  2277376        0             0 io.alexa2.1
        Feb 11 12:30:33 iobroker kernel: [177287.231358] [ 349797]  1000 349797   249672     8721  2490368        0             0 io.mihome-vacuu
        Feb 11 12:30:33 iobroker kernel: [177287.231360] [ 349812]  1000 349812   164790     7037  2244608        0             0 io.modbus.0
        Feb 11 12:30:33 iobroker kernel: [177287.231362] [ 349829]  1000 349829   166898     9440  2424832        0             0 io.mqtt.0
        Feb 11 12:30:33 iobroker kernel: [177287.231364] [ 349853]  1000 349853   199167     8390  2420736        0             0 io.telegram.0
        Feb 11 12:30:33 iobroker kernel: [177287.231366] [ 349864]  1000 349864   164607     6105  2232320        0             0 io.onkyo.0
        Feb 11 12:30:33 iobroker kernel: [177287.231369] [ 349885]  1000 349885   164270     5960  2215936        0             0 io.ping.0
        Feb 11 12:30:33 iobroker kernel: [177287.231371] [ 349917]  1000 349917   168422    11006  2613248        0             0 io.shelly.0
        Feb 11 12:30:33 iobroker kernel: [177287.231373] [ 349940]  1000 349940   166501     9081  2437120        0             0 io.sonoff.0
        Feb 11 12:30:33 iobroker kernel: [177287.231375] [ 349962]  1000 349962   167503     9592  2555904        0             0 io.tr-064.0
        Feb 11 12:30:33 iobroker kernel: [177287.231378] [ 350000]  1000 350000   198527     7985  2367488        0             0 io.backitup.0
        Feb 11 12:30:33 iobroker kernel: [177287.231380] [ 350074]  1000 350074   182336     7976  2269184        0             0 io.info.0
        Feb 11 12:30:33 iobroker kernel: [177287.231382] [ 350423]  1000 350423   185016    11027  2510848        0             0 io.iot.0
        Feb 11 12:30:33 iobroker kernel: [177287.231385] [ 350554]  1000 350554   184976    10749  2510848        0             0 io.iot.1
        Feb 11 12:30:33 iobroker kernel: [177287.231387] [ 350569]  1000 350569   166005     8031  2322432        0             0 io.jarvis.0
        Feb 11 12:30:33 iobroker kernel: [177287.231389] [ 350587]  1000 350587   166827     9192  2416640        0             0 io.lupusec.0
        Feb 11 12:30:33 iobroker kernel: [177287.231391] [ 350609]  1000 350609   164286     6415  2183168        0             0 io.mihome.0
        Feb 11 12:30:33 iobroker kernel: [177287.231393] [ 350642]  1000 350642   230371     6984  2240512        0             0 io.parser.0
        Feb 11 12:30:33 iobroker kernel: [177287.231395] [ 350664]  1000 350664   231818     8917  2383872        0             0 io.plenticore.0
        Feb 11 12:30:33 iobroker kernel: [177287.231397] [ 350696]  1000 350696   165269     7497  2338816        0             0 io.radar2.0
        Feb 11 12:30:33 iobroker kernel: [177287.231400] [ 350743]  1000 350743   163666     5564  2154496        0             0 io.samsung.0
        Feb 11 12:30:33 iobroker kernel: [177287.231402] [ 350760]  1000 350760   213447     6102  2183168        0             0 io.simple-api.0
        Feb 11 12:30:33 iobroker kernel: [177287.231404] [ 350790]  1000 350790   165242     7184  2224128        0             0 io.statistics.0
        Feb 11 12:30:33 iobroker kernel: [177287.231406] [ 350816]  1000 350816   164186     6277  2146304        0             0 io.text2command
        Feb 11 12:30:33 iobroker kernel: [177287.231408] [ 350832]  1000 350832   216115     9031  2433024        0             0 io.web.0
        Feb 11 12:30:33 iobroker kernel: [177287.231410] [ 350849]  1000 350849   199043    33057  3997696        0             0 io.web.1
        Feb 11 12:30:33 iobroker kernel: [177287.231412] [ 350952]  1000 350952   159855     8667  1552384        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231414] [ 350953]  1000 350953      652      120    40960        0             0 sh
        Feb 11 12:30:33 iobroker kernel: [177287.231416] [ 350960]  1000 350960   146023     4089   708608        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231418] [ 350968]  1000 350968   164931    10230  2269184        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231420] [ 350975]  1000 350975   159409     8362  1515520        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231423] [ 350986]  1000 350986   150789     6666  1433600        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231425] [ 350994]  1000 350994   147637     4797   933888        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231427] [ 351005]  1000 351005   145698     3279   630784        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231429] [ 351006]  1000 351006   145492     2567   589824        0             0 node
        Feb 11 12:30:33 iobroker kernel: [177287.231431] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/iobroker.service,task=iobroker.js-con,pid=349628,uid=1000
        Feb 11 12:30:33 iobroker kernel: [177287.231477] Out of memory: Killed process 349628 (iobroker.js-con) total-vm:2876496kB, anon-rss:2018188kB, file-rss:1472kB, shmem-rss:0kB, UID:1000 pgtables:11692kB oom_score_adj:0
        Feb 11 12:30:34 iobroker kernel: [177287.408367] oom_reaper: reaped process 349628 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
        Feb 11 12:30:34 iobroker systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
        Feb 11 12:31:04 iobroker systemd[1]: iobroker.service: Failed with result 'signal'.
        Feb 11 12:31:04 iobroker systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
        Feb 11 12:31:04 iobroker systemd[1]: Stopped ioBroker Server.
        Feb 11 12:31:04 iobroker systemd[1]: Started ioBroker Server.
        Feb 11 12:31:06 iobroker bash[351060]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
        • DiginixD Diginix
          #294
          @diginix Ok, 40 node Prozesse/Adapterinstanzen .. Hut ab :-) Scheinbar wird da irgendwas mit deinen 3 GB knapp :-)
          @AlCalzone schaut mal ob wir noch was bezüglich der Datenbank Initialisierung optimieren können
            DiginixD Offline
            DiginixD Offline
            Diginix
            #295
            @apollon77 Nene da stimmte was temporär nicht. Die iob VM hat 4 von 16 GB. Der ganze Server mit allen VM/LXC läuft nie über 45% RAM. Die iob VM im Monatsmittel hängt bei 3,5 von den zugewiesenen 4 GB rum. Noch nie hatte ich eine Warnung bei >80% der VM. Klar kann ich der VM mal mehr geben, wird dann sicher auch verwendet, aber war bisher nie nötig und nach reboot ja auch nicht mehr. Auch frühere iob restarts mit file und JSONL kamen nicht an die Grenzen.
            Irgendwas ist da vorhin beim Update von 4.0.7 mächtig schief gegangen.
            • simatecS Offline
              simatecS Offline
              simatec
              #296
              Ab sofort steht die Beta 2.3.0 des Backitup Adapter zur Verfügung.
              Hier gab es für den js-controller einige größere Änderungen beim iobroker-restore.
              Es wäre super, wenn hier die Tester des js-controllers dies mit testen und bei Fehlern bitte melden könnten.
              Voraussetzung für einen Test des Restores ist js-controller größer 4.0.6, da alle Anpassungen in kleineren 4er Versionen noch nicht enthalten sind.
              Auch Versionen von js-controller 3.3.x werden weiter unterstützt.
              Alle Änderungen findet Ihr im Backitup Thread.
              https://forum.iobroker.net/post/760337
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • simatecS simatec
                amg_666A Offline
                amg_666A Offline
                amg_666
                #297
                @simatec
                ich hab den aktuellen js-controller drauf (4.0.8) und backitup 2.3.0 grade installiert.
                intel nuc mit proxmox debian als Master und einen abgesetzten pi3b (auch mit 4.0.8)
                Das lief alles fehlerfrei durch, aber ich habe ein backup manuell angestartet (über Adminoberfläche) und das "hängt", keine Ahnung was da "undefined" ist.
                Started iobroker ...
                [DEBUG] [iobroker] - host.iobroker 17009 states saved
                [DEBUG] [iobroker] - host.iobroker 19191 objects saved
                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_02_11-14_06_44_backupiobroker.tar.gz
                [DEBUG] [iobroker] - done
                [DEBUG] [historyDB] - compress from historyDB started ...
                [ERROR] [historyDB] - Backitup cannot found source "undefined" for compress!
                • amg_666A amg_666
                  @simatec
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #298
                  @amg_666 Bitte poste das im backitup Thread sonst werden hier die Themen vermischt.
                  Es geht hier nur um den Restore des iobrokers in Verbindung mit dem js-controller 4
                  • wendy2702W Offline
                    wendy2702W Offline
                    #299
                    @apollon77 Keine Ahnung ob es am JS 4.0.7 liegt aber ich habe ja vorhin einen Slave neu installiert und da ist ja dann der Discovery Adapter bei. Den wollte ich jetzt wieder löschen vom Master aus.
                    Im Log:
                    2022-02-11 15:50:07.082  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-02-11 15:50:09.570  - info: host.iobroker iobroker del discovery.0
                    2022-02-11 15:50:10.934  - info: host.iobroker iobroker Delete instance "discovery.0"
                    2022-02-11 15:50:11.216  - info: host.iobroker iobroker host.iobroker Counted 5 states of discovery.0
                    2022-02-11 15:50:11.280  - info: host.iobroker iobroker host.iobroker Counted 15 states of system.adapter.discovery.0
                    2022-02-11 15:50:11.319  - info: host.iobroker iobroker host.iobroker Counted 5 states (io.discovery.0.*) from states
                    2022-02-11 15:50:11.338  - info: linux-control.0 (28537) getting data from VIS-OG (192.168.178.215:22)
                    2022-02-11 15:50:11.435  - info: host.iobroker iobroker host.iobroker Counted 15 states (system.adapter.discovery.0.*) from states
                    2022-02-11 15:50:13.091  - info: host.iobroker iobroker host.iobroker Counted 1 objects of discovery.0
                    2022-02-11 15:50:13.091  - info: host.iobroker iobroker host.iobroker Deleting 21 object(s).
                    2022-02-11 15:50:13.241  - info: host.iobroker iobroker host.iobroker Deleting 20 state(s).
                    2022-02-11 15:50:14.378  - info: host.iobroker iobroker exit 0
                    In den Objekten:
                    Im Admin:
                    Jetzt mal versucht wenn ich auf den Slave Filter wobei ich dann in einen loop laufe:
                    Wenn ich das bestätige:
                    Kommt das:
                    Wenn ich dann hier auf Schließen klicke kommt wieder das:
                    Den Hinweis das er nicht deinstalliert werden kann weil Nettools ihn benötigt gab es beim ersten mal nicht.
                    JS Problem, Adapter oder Admin?
                    • wendy2702W wendy2702
                      Im Log:
                      In den Objekten:
                      Im Admin:
                      Kommt das:
                      #300
                      @wendy2702 Lies mal den Changelog zur 4.0.8... Da wurde genau das gefixt ... also wenn es darum geht einen discovery auf nem anderen Host zu löschen.
                      Die Meldung mit "nettools braucht ihn" sollte an sich immer kommen... bzw hier die gilt ggf das "Host spezifisch"
                      EDIT: @foxriver76 hat schon festgestellt das da noch was nicht korrekt ist ... fix kommt in die 4.0.9
                        die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
                        jobe451
                        #301
                        @apollon77
                        Also bei mir kommt dieser NPM nicht-gefunden-package.json Fehler immer noch, mit ws 4.0.8
                        • J jobe451
                          @apollon77
                          jobe451
                          #302
                          @jobe451 Update: Das Problem ist offenbar vielmehr, dass ich den ws selber nicht ugedated kriege auf 4.0.8... Was kann man da machen? Wie kann man den update erzwingen?
                          • J jobe451
                            #303
                            @jobe451 Du hast recht ... dann installiere es via cd /opt/iobroker und npm i iobroker.js-controller@4.0.8 --production
                              @e-i-k-e Danke, Hast nen Bug gefunden. Wird in der 4.0.8 gefixt
                              e-i-k-e
                              #304
                              @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                              Mit 4.0.8 kann ich nun die Adapter löschen.
                              Danke!
                              • crunchipC Abwesend
                                crunchipC Abwesend
                                #305
                                habe jetzt gerade das update von 4.0.5 auf 4.0.8 gemacht
                                was ich aber nun nicht verstehe, was ist damit gemeint?
                                The following notifications happened during sync:
                                - Ignoring Directory "userdata.0" because officially not created as meta object. Please remove directory!
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #306
                                  @crunchip 0_userdata.0 vs userdata.0
                                  Videotutorials & mehr
                                  • foxriver76F foxriver76
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #307
                                    @foxriver76 ok und wo sollte ich userdata.0 finden
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #308
                                      @crunchip Entweder in deinen Objekten oder vllt auch hier: /opt/iobroker/iobroker-data/files/userdata.0
                                      • DiginixD Diginix
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #309
                                        @diginix ich hab schon nach userdata suchen lassen, findet aber nichts
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          #310
                                          @crunchip der Ordner heißt meiner Meinung nach falsch.. hast du ihn selbst erstellt? Auf meinem System heißt er korrekt 0_userdata.0
                                          crunchipC DiginixD 2 Antworten Letzte Antwort
