  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • DiginixD Diginix
    @apollon77 4.0.8 will bei mir gerade nicht durchstarten:
    2022-02-11 12:21:17.624 - erro: host.iobroker Your system has only 49 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:17.628 - erro: host.iobroker In future versions, the adapter might not be started!
    2022-02-11 12:21:17.740 - warn: host.iobroker Your system has only 84 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:17.741 - warn: host.iobroker Your system has only 84 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:18.133 - warn: host.iobroker Your system has only 74 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:18.140 - warn: host.iobroker Your system has only 73 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:18.155 - warn: host.iobroker Your system has only 72 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:18.159 - warn: host.iobroker Your system has only 72 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    2022-02-11 12:21:18.212 - warn: host.iobroker Your system has only 71 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
    Danach loopt er mit allen Instanzen. Die RAM Meldungen kommen aber nicht mehr. Also das war nur beim ersten Start von 4.0.8.
    Selbst wenn ich iob stop mache und kein Prozess mehr läuft, startet 4.0.8 nicht durch und endet in irgend einem Loop der fast alle Instanzen gestartet bekommt, aber dann doch abschmiert und sich selbst wieder beendet.
    iobroker@iobroker:/opt/iobroker/log$ iob list instances
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Habe nun ein Downgrad auf 4.0.7 gemacht.
    #282
    @diginix Versuch mal reboot. Also die Log Meldungen sagen nur das dein RAM gerade knapp wird - sonst nix.
    Das andere (mit dem "lock" der DB) ist der echte Grund das es nicht startet
    • apollon77A apollon77
      @dskrt iobroker set admin.0 --ssl false
      dskrt
      #283
      @apollon77 said in js-controller 4.0 jetzt im BETA/LATEST!:
      Danke,habe aber dann diese Meldung
      Adapter "admin.0" has no setting "ssl".
      No parameters set.
      • D dskrt
        No parameters set.
        #284
        @dskrt sorry type ... secure anstelle ssl
          DiginixD Offline
          DiginixD Offline
          Diginix
          #285
          @apollon77 Hab den Post noch mal editiert. Downgrade auf 4.0.7 hat leider auch nicht geholfen.
          Uncaught Rejection: Error: Connection is closed.
              at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
              at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
              at Object.onceWrapper (events.js:520:26)
              at Socket.emit (events.js:400:28)
              at TCP.<anonymous> (net.js:686:12)
          Es sind immer fast alle Instanzen grün, vllt noch 4-5 nicht gestartet und dann werden wieder alle rot.
          Danach kann ich direkt iob stop in der CLI machen
          Ich mach nochmal ein Update und danach ein reboot.
          ..:: So long! Tom ::..
          apollon77A 2 Antworten Letzte Antwort
            dskrt
            #286
            @apollon77 Super ! Vielen, vielen Dank
            • DiginixD Diginix
              #287
              @diginix Da muss @AlCalzone was zu sagen wo der lock herkommen könnte ... ich kapiers nicht schau nochmal das sichergestellt ist das keine iobroker prozesse mehr laufen
              • DiginixD Diginix
                #288
                @diginix sagte in js-controller 4.0 jetzt im BETA/LATEST!:
                Ok, was sagt dann der iobroker log? (Zu dem Zeitpunkt wo alles rot wird)
                  DiginixD Offline
                  DiginixD Offline
                  Diginix
                  #289
                  @apollon77 Muss ich in Ruhe nochmal filtern. Ist zu voll mit Fehlern von Adaptern die seit 4.x gemeldet werden.
                  Reboot hat tatsächlich geholfen. 4.0.8 läuft nun mit allen Instanzen.
                  Alte iob Prozesse gab es nie vor dem iob start.
                  • DiginixD Diginix
                    #290
                    @diginix Ok, wäre cool wenn du nochmal reinschauen kannst bei Zeit
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #291
                      @apollon77
                      Das wird dir nicht helfen:
                      2022-02-11 12:29:25.448 - info: simple-api.0 (350760) https server listening on port 8285
                      2022-02-11 12:29:33.454 - info: text2command.0 (350816) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.0, js-controller: 4.0.8
                      2022-02-11 12:29:44.963 - error: web.0 (350832) [LE] {"code":"E_FAIL_DRY_CHALLENGE","context":"cert_renewal","subject":"***","altnames":["***"]}
                      2022-02-11 12:29:57.275 - error: web.0 (350832) [LE] {"code":"E_FAIL_DRY_CHALLENGE","context":"cert_renewal","subject":"***","altnames":["***"]}
                      2022-02-11 12:30:23.546 - warn: javascript.0 (349701) getState "system.adapter.modbus.0.connected" not found (3)
                      2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.<anonymous> (script.js.0.System.Checks_and_Restarts:449:67)
                      2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
                      2022-02-11 12:30:23.548 - warn: javascript.0 (349701)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
                      2022-02-11 12:30:23.549 - warn: javascript.0 (349701)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5902:56)
                      2022-02-11 12:30:23.549 - warn: javascript.0 (349701)     at processImmediate (internal/timers.js:464:21)
                      2022-02-11 12:30:23.640 - warn: javascript.0 (349701) getState "system.adapter.shelly.0.connected" not found (3)
                      2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.<anonymous> (script.js.0.System.Checks_and_Restarts:376:67)
                      2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
                      2022-02-11 12:30:23.641 - warn: javascript.0 (349701)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
                      2022-02-11 12:30:23.642 - warn: javascript.0 (349701)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5902:56)
                      2022-02-11 12:30:23.642 - warn: javascript.0 (349701)     at processImmediate (internal/timers.js:464:21)
                      2022-02-11 12:30:25.672 - warn: host.iobroker Your system has only 96 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                      2022-02-11 12:30:25.678 - warn: host.iobroker Your system has only 96 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                      2022-02-11 12:30:26.481 - warn: host.iobroker Your system has only 89 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                      2022-02-11 12:30:26.520 - warn: host.iobroker Your system has only 88 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
                      2022-02-11 12:30:34.119 - error: text2command.0 (350816) States database error: read ECONNRESET
                      2022-02-11 12:30:34.133 - error: simple-api.0 (350760) Objects database error: read ECONNRESET
                      2022-02-11 12:30:34.134 - error: radar2.0 (350696) States database error: read ECONNRESET
                      2022-02-11 12:30:34.154 - error: parser.0 (350642) States database error: read ECONNRESET
                      2022-02-11 12:30:34.161 - error: lupusec.0 (350587) States database error: read ECONNRESET
                      2022-02-11 12:30:34.171 - error: info.0 (350074) States database error: read ECONNRESET
                      2022-02-11 12:30:34.177 - error: backitup.0 (350000) States database error: read ECONNRESET
                      2022-02-11 12:30:34.191 - error: shelly.0 (349917) States database error: read ECONNRESET
                      2022-02-11 12:30:34.193 - error: shelly.0 (349917) Objects database error: read ECONNRESET
                      2022-02-11 12:30:34.205 - error: modbus.0 (349812) Objects database error: read ECONNRESET
                      2022-02-11 12:30:34.213 - error: alexa2.0 (349750) States database error: read ECONNRESET
                      2022-02-11 12:30:34.222 - error: javascript.0 (349701) States database error: read ECONNRESET
                      2022-02-11 12:30:34.247 - error: mqtt.0 (349829) Objects database error: read ECONNRESET
                      2022-02-11 12:30:34.264 - info: javascript.0 (349701) Stop script script.js.0.Devices.Bring
                      2022-02-11 12:30:34.262 - info: backitup.0 (350000) cleaned everything up...
                      2022-02-11 12:30:34.270 - info: simple-api.0 (350760) terminating https server on port 8285
                      2022-02-11 12:30:34.277 - info: admin.0 (349653) terminating https server on port 8081
                      2022-02-11 12:30:34.273 - error: mihome-vacuum.0 (349797) Socket Close
                      2022-02-11 12:30:34.305 - error: ping.0 (349885) Objects database error: read ECONNRESET
                      2022-02-11 12:30:34.197 - error: sonoff.0 (349940) States database error: read ECONNRESET
                      2022-02-11 12:30:34.325 - warn: influxdb.0 (349733) Store data for 1025 points and 0 conflicts
                      2022-02-11 12:30:34.346 - info: iot.1 (350554) Connection changed: disconnect
                      2022-02-11 12:30:34.347 - info: iot.1 (350554) Connection lost
                      Die JS getState Fehler hatte ich sonst auch. Das direkt danach die RAM Meldungen kommen ist schon komisch. In der CLI mit free -m war es meine ich auch nicht so knapp. Der Loglevel vom Controller ist allerdings auch warn. K.a. ob mit info mehr gekommen wäre. Da er nun nach Reboot vorerst unauffällig läuft und auch ein Adapter Update gerade schon problemlos klappte, würde ich es unter "blöder Zufall" abstempeln.
                      • DiginixD Diginix
                        @apollon77
                        #292
                        @diginix Schau mal ins /var/log/syslog ... ich tippe eher das dir der OOM Killer den controller abgeschossen hat ... wegen RAM issues, weil das wäre die Erklärung das alle adapter die DB COnnection verlieren
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #293
                          @apollon77 Jup, sieht so aus:
                          Feb 11 12:29:17 iobroker kernel: [177211.018669] debugfs: File 'le_min_key_size' in directory 'hci0' already present!
                          Feb 11 12:29:17 iobroker kernel: [177211.019665] debugfs: File 'le_max_key_size' in directory 'hci0' already present!
                          Feb 11 12:29:17 iobroker kernel: [177211.195576] device ens18 entered promiscuous mode
                          Feb 11 12:29:17 iobroker kernel: [177211.240654] device ens18 left promiscuous mode
                          Feb 11 12:29:24 iobroker kernel: [177217.687482] device ens18 entered promiscuous mode
                          Feb 11 12:29:24 iobroker kernel: [177217.889378] debugfs: File 'le_min_key_size' in directory 'hci0' already present!
                          Feb 11 12:29:24 iobroker kernel: [177217.890173] debugfs: File 'le_max_key_size' in directory 'hci0' already present!
                          Feb 11 12:29:25 iobroker kernel: [177218.944360] device ens18 left promiscuous mode
                          Feb 11 12:29:27 iobroker bash[349628]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                          Feb 11 12:29:27 iobroker bash[349628]: Send diag info: {"uuid":"40ef6245-7146-4f16-3646-632acb8f00bd","language":"de","country":"Germany","hosts":[{"version":"4.0.8","platform":"Javascript/Node.js","type":"linux"}],"node":"v14.19.0","arch":"x64","docker":false,"adapters":{"admin":{"version":"5.3.0","platform":"Javascript/Node.js"},"alexa2":{"version":"3.12.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.2.4","platform":"Javascript/Node.js"},"daswetter":{"version":"3.0.9","platform":"Javascript/Node.js"},"discovery":{"version":"2.7.5","platform":"Javascript/Node.js"},"dwd":{"version":"2.7.7","platform":"Javascript/Node.js"},"email":{"version":"1.0.10","platform":"Javascript/Node.js"},"fb-checkpresence":{"version":"1.1.13","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.js"},"flot":{"version":"1.10.7","platform":"javascript/Node.js"},"history":{"version":"1.10.5","platform":"Javascript/Node.js"},"ical":{"version":"1.11.6","platform":"Javascript/Node.js"},"info":{"version":"1.9.17","platform":"Javascript/Node.js"},"iot":{"version":"1.9.5","platform":"Javascript/Node.js"},"jarvis":{"version":"2.2.5","platform":"Javascript/Node.js"},"javascript":{"version":"5.2.21","platform":"Javascript/Node.js"},"lupusec":{"version":"1.3.6","platform":"Javascript/Node.js"},"mihome":{"version":"1.3.7","platform":"javascript/Node.js"},"mihome-vacuum":{"version":"3.3.4","platform":"Javascript/Node.js"},"modbus":{"version":"3.4.17","platform":"Javascript/Node.js"},"mqtt":{"version":"2.4.1","platform":"Javascript/Node.js"},"node-red":{"version":"1.7.1","platform":"Javascript/Node.js"},"onkyo":{"version":"2.1.1","platform":"Javascript/Node.js"},"parser":{"version":"1.0.7","platform":"Javascript/Node.js"},"ping":{"version":"1.5.2","platform":"Javascript/Node.js"},"plenticore":{"version":"2.2.1","platform":"Javascript/Node.js"},"radar":{"version":"1.2.1","platform":"Javascript/Node.js"},"radar2":{"version":"2.0.3","platform":"Javascript/Node.js"},"samsung":{"version":"0.2.9","platform":"Javascript/Node.js"},"shelly":{"version":"5.1.2","platform":"Javascript/Node.js"},"simple-api":{"version":"2.6.2","platform":"Javascript/Node.js"},"socketio":{"version":"3.1.4","platform":"Javascript/Node.js"},"sonoff":{"version":"2.4.7","platform":"Javascript/Node.js"},"statistics":{"version":"1.0.10","platform":"Javascript/Node.js"},"telegram":{"version":"1.11.1","platform":"Javascript/Node.js"},"text2command":{"version":"2.1.1","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.15","platform":"Javascript/Node.js"},"ubuntu":{"version":"0.1.3","platform":"javascript/Node.js"},"upnp":{"version":"0.3.9","platform":"Javascript/Node.js"},"web":{"version":"4.1.1","platform":"Javascript/Node.js"},"yeelight":{"version":"0.0.1","platform":"Javascript/Node.js"},"yeelight-2":{"version":"1.1.2","platform":"Javascript/Node.js"},"proxmox":{"version":"1.3.4","platform":"Javascript/Node.js"},"influxdb":{"version":"2.4.0","platform":"Javascript/Node.js"},"frontier_silicon":{"version":"0.0.10","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"netatmo-crawler":{"version":"0.7.1","platform":"Javascript/Node.js"},"bydbatt":{"version":"1.0.7","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"2.1.1","platform":"javascript/Node.js"},"bring":{"version":"1.7.13","platform":"Javascript/Node.js"},"pvforecast":{"version":"0.1.8","platform":"Javascript/Node.js"},"alias-manager":{"version":"1.2.4","platform":"Javascript/Node.js"},"ws":{"version":"1.1.1","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":49,"noCompactInstances":0,"model":"Common KVM processor","cpus":4,"mem":4122136576,"ostype":"Linux"}
                          Feb 11 12:30:33 iobroker kernel: [177287.231054] io.email.0 invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
                          Feb 11 12:30:33 iobroker kernel: [177287.231059] CPU: 3 PID: 349670 Comm: io.email.0 Not tainted 5.4.0-99-generic #112-Ubuntu
                          Feb 11 12:30:33 iobroker kernel: [177287.231060] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org 04/01/2014
                          Feb 11 12:30:33 iobroker kernel: [177287.231061] Call Trace:
                          Feb 11 12:30:33 iobroker kernel: [177287.231068]  dump_stack+0x6d/0x8b
                          Feb 11 12:30:33 iobroker kernel: [177287.231071]  dump_header+0x4f/0x1eb
                          Feb 11 12:30:33 iobroker kernel: [177287.231073]  oom_kill_process.cold+0xb/0x10
                          Feb 11 12:30:33 iobroker kernel: [177287.231076]  out_of_memory+0x1cf/0x4d0
                          Feb 11 12:30:33 iobroker kernel: [177287.231080]  __alloc_pages_slowpath+0xd5e/0xe50
                          Feb 11 12:30:33 iobroker kernel: [177287.231084]  __alloc_pages_nodemask+0x2d0/0x320
                          Feb 11 12:30:33 iobroker kernel: [177287.231086]  alloc_pages_current+0x87/0xe0
                          Feb 11 12:30:33 iobroker kernel: [177287.231089]  __page_cache_alloc+0x72/0x90
                          Feb 11 12:30:33 iobroker kernel: [177287.231091]  pagecache_get_page+0xbf/0x300
                          Feb 11 12:30:33 iobroker kernel: [177287.231094]  filemap_fault+0x6b2/0xa50
                          Feb 11 12:30:33 iobroker kernel: [177287.231096]  ? unlock_page_memcg+0x12/0x20
                          Feb 11 12:30:33 iobroker kernel: [177287.231098]  ? page_add_file_rmap+0xff/0x1a0
                          Feb 11 12:30:33 iobroker kernel: [177287.231100]  ? __switch_to_asm+0x34/0x70
                          Feb 11 12:30:33 iobroker kernel: [177287.231103]  ? xas_load+0xd/0x80
                          Feb 11 12:30:33 iobroker kernel: [177287.231105]  ? xas_find+0x17f/0x1c0
                          Feb 11 12:30:33 iobroker kernel: [177287.231107]  ? filemap_map_pages+0x24c/0x380
                          Feb 11 12:30:33 iobroker kernel: [177287.231111]  ext4_filemap_fault+0x32/0x50
                          Feb 11 12:30:33 iobroker kernel: [177287.231113]  __do_fault+0x3c/0x130
                          Feb 11 12:30:33 iobroker kernel: [177287.231114]  do_fault+0x24b/0x640
                          Feb 11 12:30:33 iobroker kernel: [177287.231116]  ? __switch_to_asm+0x34/0x70
                          Feb 11 12:30:33 iobroker kernel: [177287.231118]  __handle_mm_fault+0x4c5/0x7a0
                          Feb 11 12:30:33 iobroker kernel: [177287.231120]  handle_mm_fault+0xca/0x200
                          Feb 11 12:30:33 iobroker kernel: [177287.231123]  do_user_addr_fault+0x1f9/0x450
                          Feb 11 12:30:33 iobroker kernel: [177287.231126]  __do_page_fault+0x58/0x90
                          Feb 11 12:30:33 iobroker kernel: [177287.231127]  do_page_fault+0x2c/0xe0
                          Feb 11 12:30:33 iobroker kernel: [177287.231130]  do_async_page_fault+0x39/0x70
                          Feb 11 12:30:33 iobroker kernel: [177287.231132]  async_page_fault+0x34/0x40
                          Feb 11 12:30:33 iobroker kernel: [177287.231134] RIP: 0033:0xbe9e10
                          Feb 11 12:30:33 iobroker kernel: [177287.231140] Code: Bad RIP value.
                          Feb 11 12:30:33 iobroker kernel: [177287.231141] RSP: 002b:00007ffcbd32bba8 EFLAGS: 00010297
                          Feb 11 12:30:33 iobroker kernel: [177287.231143] RAX: 0000000005753b10 RBX: 00007ffcbd32bcd0 RCX: 000000000593fe20
                          Feb 11 12:30:33 iobroker kernel: [177287.231144] RDX: 00000000056bb1c0 RSI: 1baffed00baffedf RDI: 000000000569ec00
                          Feb 11 12:30:33 iobroker kernel: [177287.231145] RBP: 00007ffcbd32bc40 R08: 000000000579cb00 R09: 0000000000000000
                          Feb 11 12:30:33 iobroker kernel: [177287.231146] R10: 00000e60520d84c1 R11: 000000000002b48a R12: 000000000579cb08
                          Feb 11 12:30:33 iobroker kernel: [177287.231147] R13: 0000000005753b10 R14: 000000000579cb08 R15: 0000000000000000
                          Feb 11 12:30:33 iobroker kernel: [177287.231149] Mem-Info:
                          Feb 11 12:30:33 iobroker kernel: [177287.231154] active_anon:908320 inactive_anon:45 isolated_anon:0
                          Feb 11 12:30:33 iobroker kernel: [177287.231154]  active_file:330 inactive_file:274 isolated_file:1
                          Feb 11 12:30:33 iobroker kernel: [177287.231154]  unevictable:4618 dirty:0 writeback:0 unstable:0
                          Feb 11 12:30:33 iobroker kernel: [177287.231154]  slab_reclaimable:10429 slab_unreclaimable:23100
                          Feb 11 12:30:33 iobroker kernel: [177287.231154]  mapped:2534 shmem:288 pagetables:12484 bounce:0
                          Feb 11 12:30:33 iobroker kernel: [177287.231154]  free:21604 free_pcp:1153 free_cma:0
                          Feb 11 12:30:33 iobroker kernel: [177287.231157] Node 0 active_anon:3633280kB inactive_anon:180kB active_file:1320kB inactive_file:1096kB unevictable:18472kB isolated(anon):0kB isolated(file):4kB mapped:10136kB dirty:0kB writeback:0kB shmem:1152kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 0kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
                          Feb 11 12:30:33 iobroker kernel: [177287.231158] Node 0 DMA free:15568kB min:272kB low:340kB high:408kB active_anon:332kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15908kB mlocked:0kB kernel_stack:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231162] lowmem_reserve[]: 0 2875 3827 3827 3827
                          Feb 11 12:30:33 iobroker kernel: [177287.231164] Node 0 DMA32 free:54240kB min:50560kB low:63200kB high:75840kB active_anon:2819480kB inactive_anon:48kB active_file:244kB inactive_file:764kB unevictable:0kB writepending:0kB present:3129176kB managed:3034304kB mlocked:0kB kernel_stack:6432kB pagetables:43536kB bounce:0kB free_pcp:1324kB local_pcp:428kB free_cma:0kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231167] lowmem_reserve[]: 0 0 952 952 952
                          Feb 11 12:30:33 iobroker kernel: [177287.231170] Node 0 Normal free:16608kB min:16748kB low:20932kB high:25116kB active_anon:813468kB inactive_anon:132kB active_file:1632kB inactive_file:1272kB unevictable:18472kB writepending:0kB present:1048576kB managed:975312kB mlocked:18472kB kernel_stack:3312kB pagetables:6400kB bounce:0kB free_pcp:3288kB local_pcp:688kB free_cma:0kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231173] lowmem_reserve[]: 0 0 0 0 0
                          Feb 11 12:30:33 iobroker kernel: [177287.231174] Node 0 DMA: 2*4kB (UM) 1*8kB (U) 2*16kB (UM) 1*32kB (M) 2*64kB (U) 2*128kB (UM) 1*256kB (U) 1*512kB (M) 2*1024kB (UM) 0*2048kB 3*4096kB (ME) = 15568kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231183] Node 0 DMA32: 3006*4kB (UE) 1977*8kB (UE) 439*16kB (UME) 15*32kB (UME) 222*64kB (UME) 35*128kB (UM) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 54032kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231190] Node 0 Normal: 393*4kB (UME) 379*8kB (UMEH) 274*16kB (UME) 165*32kB (UMEH) 22*64kB (UME) 1*128kB (M) 1*256kB (M) 2*512kB (ME) 0*1024kB 0*2048kB 0*4096kB = 17084kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231199] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231200] 2868 total pagecache pages
                          Feb 11 12:30:33 iobroker kernel: [177287.231201] 0 pages in swap cache
                          Feb 11 12:30:33 iobroker kernel: [177287.231202] Swap cache stats: add 0, delete 0, find 0/0
                          Feb 11 12:30:33 iobroker kernel: [177287.231203] Free swap  = 0kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231203] Total swap = 0kB
                          Feb 11 12:30:33 iobroker kernel: [177287.231204] 1048436 pages RAM
                          Feb 11 12:30:33 iobroker kernel: [177287.231205] 0 pages HighMem/MovableOnly
                          Feb 11 12:30:33 iobroker kernel: [177287.231206] 42055 pages reserved
                          Feb 11 12:30:33 iobroker kernel: [177287.231206] 0 pages cma reserved
                          Feb 11 12:30:33 iobroker kernel: [177287.231207] 0 pages hwpoisoned
                          Feb 11 12:30:33 iobroker kernel: [177287.231208] Tasks state (memory values in pages):
                          Feb 11 12:30:33 iobroker kernel: [177287.231209] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
                          Feb 11 12:30:33 iobroker kernel: [177287.231217] [    377]     0   377    22370     1062   188416        0          -250 systemd-journal
                          Feb 11 12:30:33 iobroker kernel: [177287.231220] [    412]     0   412     5347      798    65536        0         -1000 systemd-udevd
                          Feb 11 12:30:33 iobroker kernel: [177287.231223] [    587]     0   587    70036     4487    94208        0         -1000 multipathd
                          Feb 11 12:30:33 iobroker kernel: [177287.231226] [    642]   112   642     1776      675    49152        0             0 rpcbind
                          Feb 11 12:30:33 iobroker kernel: [177287.231233] [    643]   102   643    22558      449    81920        0             0 systemd-timesyn
                          Feb 11 12:30:33 iobroker kernel: [177287.231255] [    683]   100   683     6653      833    77824        0             0 systemd-network
                          Feb 11 12:30:33 iobroker kernel: [177287.231257] [    685]   101   685     6340     1676    86016        0             0 systemd-resolve
                          Feb 11 12:30:33 iobroker kernel: [177287.231259] [    698]     0   698    58895      533    94208        0             0 accounts-daemon
                          Feb 11 12:30:33 iobroker kernel: [177287.231261] [    701]     0   701     2134      597    61440        0             0 bluetoothd
                          Feb 11 12:30:33 iobroker kernel: [177287.231263] [    704]     0   704     1392      545    53248        0             0 cron
                          Feb 11 12:30:33 iobroker kernel: [177287.231265] [    705]   103   705     1995      886    53248        0          -900 dbus-daemon
                          Feb 11 12:30:33 iobroker kernel: [177287.231267] [    713]     0   713    20474      275    57344        0             0 irqbalance
                          Feb 11 12:30:33 iobroker kernel: [177287.231269] [    715]     0   715     6656     2731    90112        0             0 networkd-dispat
                          Feb 11 12:30:33 iobroker kernel: [177287.231271] [    716]     0   716     1638      482    53248        0             0 qemu-ga
                          Feb 11 12:30:33 iobroker kernel: [177287.231280] [    717]   104   717    56087      671    86016        0             0 rsyslogd
                          Feb 11 12:30:33 iobroker kernel: [177287.231282] [    726]     0   726     4183      441    77824        0             0 systemd-logind
                          Feb 11 12:30:33 iobroker kernel: [177287.231284] [    729]     0   729    98138      477   126976        0             0 udisksd
                          Feb 11 12:30:33 iobroker kernel: [177287.231286] [    732]     0   732      948      496    49152        0             0 atd
                          Feb 11 12:30:33 iobroker kernel: [177287.231288] [    752]     0   752     3044      939    61440        0         -1000 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231290] [    756]     0   756      715      381    40960        0             0 agetty
                          Feb 11 12:30:33 iobroker kernel: [177287.231292] [    761]     0   761    26287     2670    98304        0             0 unattended-upgr
                          Feb 11 12:30:33 iobroker kernel: [177287.231294] [    779]     0   779    58179      269    86016        0             0 polkitd
                          Feb 11 12:30:33 iobroker kernel: [177287.231297] [  66929]     0 66929    62068      537   110592        0             0 upowerd
                          Feb 11 12:30:33 iobroker kernel: [177287.231300] [ 301951]   107 301951     1695      170    49152        0             0 uuidd
                          Feb 11 12:30:33 iobroker kernel: [177287.231302] [ 307461]     0 307461     3482      997    73728        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231304] [ 307476]  1000 307476     4601      751    77824        0             0 systemd
                          Feb 11 12:30:33 iobroker kernel: [177287.231306] [ 307478]  1000 307478    42513     1180    94208        0             0 (sd-pam)
                          Feb 11 12:30:33 iobroker kernel: [177287.231309] [ 307602]  1000 307602     3516      834    73728        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231311] [ 307603]  1000 307603     1465      469    45056        0             0 bash
                          Feb 11 12:30:33 iobroker kernel: [177287.231313] [ 325101]     0 325101     3481     1021    61440        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231316] [ 325227]  1000 325227     3686      658    65536        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231318] [ 325228]  1000 325228     1465      543    57344        0             0 bash
                          Feb 11 12:30:33 iobroker kernel: [177287.231320] [ 325300]     0 325300     3481      995    69632        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231322] [ 325388]  1000 325388     3666     1065    73728        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231325] [ 325389]  1000 325389     1465      537    45056        0             0 bash
                          Feb 11 12:30:33 iobroker kernel: [177287.231327] [ 326632]     0 326632   273772     3983   274432        0          -900 snapd
                          Feb 11 12:30:33 iobroker kernel: [177287.231331] [ 347969]     0 347969     3482     1019    69632        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231333] [ 348049]  1000 348049     3516      371    69632        0             0 sshd
                          Feb 11 12:30:33 iobroker kernel: [177287.231335] [ 348050]  1000 348050     1412      455    57344        0             0 bash
                          Feb 11 12:30:33 iobroker kernel: [177287.231337] [ 348051]  1000 348051     1766      855    49152        0             0 bash
                          Feb 11 12:30:33 iobroker kernel: [177287.231341] [ 349628]  1000 349628   719124   504915 11972608        0             0 iobroker.js-con
                          Feb 11 12:30:33 iobroker kernel: [177287.231343] [ 349653]  1000 349653   248458    25632  3637248        0             0 io.admin.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231345] [ 349670]  1000 349670   163964     5908  2166784        0             0 io.email.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231347] [ 349685]  1000 349685   166034     8233  2289664        0             0 io.history.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231349] [ 349701]  1000 349701   240738    51933  5328896        0             0 io.javascript.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231351] [ 349733]  1000 349733   167132     9510  2416640        0             0 io.influxdb.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231354] [ 349750]  1000 349750   231765     8390  2318336        0             0 io.alexa2.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231356] [ 349765]  1000 349765   230870     7512  2277376        0             0 io.alexa2.1
                          Feb 11 12:30:33 iobroker kernel: [177287.231358] [ 349797]  1000 349797   249672     8721  2490368        0             0 io.mihome-vacuu
                          Feb 11 12:30:33 iobroker kernel: [177287.231360] [ 349812]  1000 349812   164790     7037  2244608        0             0 io.modbus.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231362] [ 349829]  1000 349829   166898     9440  2424832        0             0 io.mqtt.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231364] [ 349853]  1000 349853   199167     8390  2420736        0             0 io.telegram.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231366] [ 349864]  1000 349864   164607     6105  2232320        0             0 io.onkyo.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231369] [ 349885]  1000 349885   164270     5960  2215936        0             0 io.ping.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231371] [ 349917]  1000 349917   168422    11006  2613248        0             0 io.shelly.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231373] [ 349940]  1000 349940   166501     9081  2437120        0             0 io.sonoff.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231375] [ 349962]  1000 349962   167503     9592  2555904        0             0 io.tr-064.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231378] [ 350000]  1000 350000   198527     7985  2367488        0             0 io.backitup.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231380] [ 350074]  1000 350074   182336     7976  2269184        0             0 io.info.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231382] [ 350423]  1000 350423   185016    11027  2510848        0             0 io.iot.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231385] [ 350554]  1000 350554   184976    10749  2510848        0             0 io.iot.1
                          Feb 11 12:30:33 iobroker kernel: [177287.231387] [ 350569]  1000 350569   166005     8031  2322432        0             0 io.jarvis.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231389] [ 350587]  1000 350587   166827     9192  2416640        0             0 io.lupusec.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231391] [ 350609]  1000 350609   164286     6415  2183168        0             0 io.mihome.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231393] [ 350642]  1000 350642   230371     6984  2240512        0             0 io.parser.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231395] [ 350664]  1000 350664   231818     8917  2383872        0             0 io.plenticore.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231397] [ 350696]  1000 350696   165269     7497  2338816        0             0 io.radar2.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231400] [ 350743]  1000 350743   163666     5564  2154496        0             0 io.samsung.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231402] [ 350760]  1000 350760   213447     6102  2183168        0             0 io.simple-api.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231404] [ 350790]  1000 350790   165242     7184  2224128        0             0 io.statistics.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231406] [ 350816]  1000 350816   164186     6277  2146304        0             0 io.text2command
                          Feb 11 12:30:33 iobroker kernel: [177287.231408] [ 350832]  1000 350832   216115     9031  2433024        0             0 io.web.0
                          Feb 11 12:30:33 iobroker kernel: [177287.231410] [ 350849]  1000 350849   199043    33057  3997696        0             0 io.web.1
                          Feb 11 12:30:33 iobroker kernel: [177287.231412] [ 350952]  1000 350952   159855     8667  1552384        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231414] [ 350953]  1000 350953      652      120    40960        0             0 sh
                          Feb 11 12:30:33 iobroker kernel: [177287.231416] [ 350960]  1000 350960   146023     4089   708608        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231418] [ 350968]  1000 350968   164931    10230  2269184        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231420] [ 350975]  1000 350975   159409     8362  1515520        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231423] [ 350986]  1000 350986   150789     6666  1433600        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231425] [ 350994]  1000 350994   147637     4797   933888        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231427] [ 351005]  1000 351005   145698     3279   630784        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231429] [ 351006]  1000 351006   145492     2567   589824        0             0 node
                          Feb 11 12:30:33 iobroker kernel: [177287.231431] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/iobroker.service,task=iobroker.js-con,pid=349628,uid=1000
                          Feb 11 12:30:33 iobroker kernel: [177287.231477] Out of memory: Killed process 349628 (iobroker.js-con) total-vm:2876496kB, anon-rss:2018188kB, file-rss:1472kB, shmem-rss:0kB, UID:1000 pgtables:11692kB oom_score_adj:0
                          Feb 11 12:30:34 iobroker kernel: [177287.408367] oom_reaper: reaped process 349628 (iobroker.js-con), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
                          Feb 11 12:30:34 iobroker systemd[1]: iobroker.service: Main process exited, code=killed, status=9/KILL
                          Feb 11 12:31:04 iobroker systemd[1]: iobroker.service: Failed with result 'signal'.
                          Feb 11 12:31:04 iobroker systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 1.
                          Feb 11 12:31:04 iobroker systemd[1]: Stopped ioBroker Server.
                          Feb 11 12:31:04 iobroker systemd[1]: Started ioBroker Server.
                          Feb 11 12:31:06 iobroker bash[351060]: ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
                          • DiginixD Diginix
                            #294
                            @diginix Ok, 40 node Prozesse/Adapterinstanzen .. Hut ab :-) Scheinbar wird da irgendwas mit deinen 3 GB knapp :-)
                            @AlCalzone schaut mal ob wir noch was bezüglich der Datenbank Initialisierung optimieren können
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #295
                              @apollon77 Nene da stimmte was temporär nicht. Die iob VM hat 4 von 16 GB. Der ganze Server mit allen VM/LXC läuft nie über 45% RAM. Die iob VM im Monatsmittel hängt bei 3,5 von den zugewiesenen 4 GB rum. Noch nie hatte ich eine Warnung bei >80% der VM. Klar kann ich der VM mal mehr geben, wird dann sicher auch verwendet, aber war bisher nie nötig und nach reboot ja auch nicht mehr. Auch frühere iob restarts mit file und JSONL kamen nicht an die Grenzen.
                              Irgendwas ist da vorhin beim Update von 4.0.7 mächtig schief gegangen.
                              • simatecS Offline
                                simatecS Offline
                                simatec
                                #296
                                Ab sofort steht die Beta 2.3.0 des Backitup Adapter zur Verfügung.
                                Hier gab es für den js-controller einige größere Änderungen beim iobroker-restore.
                                Es wäre super, wenn hier die Tester des js-controllers dies mit testen und bei Fehlern bitte melden könnten.
                                Voraussetzung für einen Test des Restores ist js-controller größer 4.0.6, da alle Anpassungen in kleineren 4er Versionen noch nicht enthalten sind.
                                Auch Versionen von js-controller 3.3.x werden weiter unterstützt.
                                Alle Änderungen findet Ihr im Backitup Thread.
                                https://forum.iobroker.net/post/760337
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                • simatecS simatec
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  #297
                                  @simatec
                                  ich hab den aktuellen js-controller drauf (4.0.8) und backitup 2.3.0 grade installiert.
                                  intel nuc mit proxmox debian als Master und einen abgesetzten pi3b (auch mit 4.0.8)
                                  Das lief alles fehlerfrei durch, aber ich habe ein backup manuell angestartet (über Adminoberfläche) und das "hängt", keine Ahnung was da "undefined" ist.
                                  Started iobroker ...
                                  [DEBUG] [iobroker] - host.iobroker 17009 states saved
                                  [DEBUG] [iobroker] - host.iobroker 19191 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_02_11-14_06_44_backupiobroker.tar.gz
                                  [DEBUG] [iobroker] - done
                                  [DEBUG] [historyDB] - compress from historyDB started ...
                                  [ERROR] [historyDB] - Backitup cannot found source "undefined" for compress!
                                  • amg_666A amg_666
                                    @simatec
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #298
                                    @amg_666 Bitte poste das im backitup Thread sonst werden hier die Themen vermischt.
                                    Es geht hier nur um den Restore des iobrokers in Verbindung mit dem js-controller 4
                                    • wendy2702W Offline
                                      wendy2702W Offline
                                      #299
                                      @apollon77 Keine Ahnung ob es am JS 4.0.7 liegt aber ich habe ja vorhin einen Slave neu installiert und da ist ja dann der Discovery Adapter bei. Den wollte ich jetzt wieder löschen vom Master aus.
                                      Im Log:
                                      2022-02-11 15:50:07.082  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2022-02-11 15:50:09.570  - info: host.iobroker iobroker del discovery.0
                                      2022-02-11 15:50:10.934  - info: host.iobroker iobroker Delete instance "discovery.0"
                                      2022-02-11 15:50:11.216  - info: host.iobroker iobroker host.iobroker Counted 5 states of discovery.0
                                      2022-02-11 15:50:11.280  - info: host.iobroker iobroker host.iobroker Counted 15 states of system.adapter.discovery.0
                                      2022-02-11 15:50:11.319  - info: host.iobroker iobroker host.iobroker Counted 5 states (io.discovery.0.*) from states
                                      2022-02-11 15:50:11.338  - info: linux-control.0 (28537) getting data from VIS-OG (192.168.178.215:22)
                                      2022-02-11 15:50:11.435  - info: host.iobroker iobroker host.iobroker Counted 15 states (system.adapter.discovery.0.*) from states
                                      2022-02-11 15:50:13.091  - info: host.iobroker iobroker host.iobroker Counted 1 objects of discovery.0
                                      2022-02-11 15:50:13.091  - info: host.iobroker iobroker host.iobroker Deleting 21 object(s).
                                      2022-02-11 15:50:13.241  - info: host.iobroker iobroker host.iobroker Deleting 20 state(s).
                                      2022-02-11 15:50:14.378  - info: host.iobroker iobroker exit 0
                                      In den Objekten:
                                      Im Admin:
                                      Jetzt mal versucht wenn ich auf den Slave Filter wobei ich dann in einen loop laufe:
                                      Wenn ich das bestätige:
                                      Kommt das:
                                      Wenn ich dann hier auf Schließen klicke kommt wieder das:
                                      Den Hinweis das er nicht deinstalliert werden kann weil Nettools ihn benötigt gab es beim ersten mal nicht.
                                      JS Problem, Adapter oder Admin?
                                      • wendy2702W wendy2702
                                        Im Log:
                                        In den Objekten:
                                        Im Admin:
                                        Kommt das:
                                        #300
                                        @wendy2702 Lies mal den Changelog zur 4.0.8... Da wurde genau das gefixt ... also wenn es darum geht einen discovery auf nem anderen Host zu löschen.
                                        Die Meldung mit "nettools braucht ihn" sollte an sich immer kommen... bzw hier die gilt ggf das "Host spezifisch"
                                        EDIT: @foxriver76 hat schon festgestellt das da noch was nicht korrekt ist ... fix kommt in die 4.0.9
                                          die NPM package.json nicht gefunden Fehler werden in der kommenden 4.0.6 behoben sein
                                          jobe451
                                          #301
                                          @apollon77
                                          Also bei mir kommt dieser NPM nicht-gefunden-package.json Fehler immer noch, mit ws 4.0.8
