js-controller 4.0 jetzt im BETA/LATEST!
Bei mir sind folgende fehler gekommen. Danach liefen fast keine Adapter alle Lese/Schreib Probleme wohl...
iob fix hilft nichtroot@iobroker:/# iob upgrade self Update js-controller from @3.3.22 to @4.0.4 NPM version: 6.14.10 npm install iobroker.js-controller@4.0.4 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call) In file included from ../src/unix_dgram.cc:5: ../../nan/nan.h: In function 'void Nan::AsyncQueueWorker(Nan::AsyncWorker*)': ../../nan/nan.h:2298:62: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ In file included from ../../nan/nan.h:54, from ../src/unix_dgram.cc:5: ../src/unix_dgram.cc: At global scope: /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/14.15.4/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X' NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~Im log auch bisschen was:
host.iobroker 2022-02-08 10:01:30.519 error instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker 2022-02-08 10:01:30.519 error Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:81:21) host.iobroker 2022-02-08 10:01:30.519 error Caught by controller[0]: at doListen (net.js:1503:7) host.iobroker 2022-02-08 10:01:30.519 error Caught by controller[0]: at listenInCluster (net.js:1366:12) host.iobroker 2022-02-08 10:01:30.519 error Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1301:21) host.iobroker 2022-02-08 10:01:30.519 error Caught by controller[0]: Error: listen EADDRNOTAVAIL: address not available 192.168.2.200:2001@chrisxy sagte in js-controller 4.0 jetzt im BETA/LATEST!:
Da scheint irgendetwas anderes auf Port 2001 zu Hören, und daher kann der Adapter nicht starten ... Stelle sicher das da nicht noch Zombie Prozesse laufen
@homecineplexx hatte ich auch
@apollon77 bin soeben auf v4, habe allerdings danach ein paar Adapter Update's angestoßen, die Meldung kommt bei jedem Adapter update2022-02-08 09:44:29.782 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created) 2022-02-08 09:44:29.818 - error: host.IoBroker iobroker (node:8633) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:8633) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency 2022-02-08 09:45:52.304 - info: shelly.0 (653) Got terminate signal TERMINATE_YOURSELF 2022-02-08 09:45:52.305 - info: shelly.0 (653) Closing Adapter 2022-02-08 09:46:12.167 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created) 2022-02-08 09:46:12.171 - error: host.IoBroker iobroker (node:9498) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:9498) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency 2022-02-08 09:46:12.774 - info: shuttercontrol.0 (1872) Adapter is disabled => stop 2022-02-08 09:46:12.783 - info: shuttercontrol.0 (1872) cleaned everything up... 2022-02-08 09:58:07.286 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)(node:14307) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:14307) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency 2022-02-08 09:58:07.293 - error: host.IoBroker iobroker (node:14307) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency 2022-02-08 09:59:24.076 - info: trashschedule.0 (2332) Got terminate signal TERMINATE_YOURSELF 2022-02-08 09:59:24.078 - info: trashschedule.0 (2332) cleaned everything up... 2022-02-08 10:01:14.838 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created) 2022-02-08 10:01:14.853 - error: host.IoBroker iobroker (node:15596) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:15596) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency 2022-02-08 10:02:40.396 - info: jarvis.0 (1316) Got terminate signal TERMINATE_YOURSELF 2022-02-08 10:02:40.423 - info: jarvis.0 (1316) Adapter stopped und unloaded.Nachtrag:
habe das nun eine Weile beobachtet, an der Performance hat sich nicht groß was verändert, da ich sowieso schon jsonl verwende, jedoch sehe ich nun einen erhöhten Ram Verbrauch, ob das vom Controller Update kommt oder den 4 Adapter Updates geschuldet ist, keine Ahnung.@crunchip sagte in js-controller 4.0 jetzt im BETA/LATEST!:
Kannst Das ggf nochmal versuchen nachzustellen und dazu das kommando anstelle über "iob upgrade name" mal mittels ´node --trace-warnings /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js upgrade name` machen ... dann sollten mehr infos kommen ...
Kann sein aber das mach ich so schon seit Jahren. Früher war das doch oft so?
fix habe ich natürlich schon Probiert.Werde ich wohl ein Backup zurückspielen müssen komisch .. bisher gab es nie Probleme alles sauber durch.
Naja, npm macht hier inzwischen auch einige Dinge sehr anders ... also "vor einigen Jahren" war auch da einiges anders. Inzwischen verhält sich mit aktuelleren npm Versionen hier einiges anders bzw manchmal wie ne Diva
@e-s Danke da habe ich keine Fehler bekommen. Jedoch bei iobroker Start kommt auch die Migrations meldung. Aber mein iobroker Menü links ist auch leer. Zigbee usw. alles fehlt. Einige Adapter werden auch nicht mehr grün
Fhem, Zigbee ... ich lass iobroker mal etwas Zeitiobroker status sagt auch nicht mehr redis
iobroker is running on this host.Objects type: file
States type: fileScheinbar beim Update mein Redis verloren gegangen. Bekomm es auch nicht hin iob fix usw.. immer Zugriffs Probleme
Connecting to previous DB "file"... Creating backup ... This can take some time ... please be patient! host.iobroker 19727 states saved host.iobroker 22369 objects saved Backup created: /opt/iobroker/backups/2022_02_08-12_52_25_backupiobroker-migration.tar.gz updating conf/iobroker.json Uncaught Rejection: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak' at Object.openSync (fs.js:476:3) at Object.writeFileSync (fs.js:1467:35) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24 This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason: Error: EACCES: permission denied, open '/iobroker-data/iobroker.json.bak' at Object.openSync (fs.js:476:3) at Object.writeFileSync (fs.js:1467:35) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:521:24 root@iobroker:/dev# iob status iobroker is not running on this host. Objects type: file States type: file@chrisxy Ääähmm ... was Hast Du genau hier getan? Das ist ist ein Migration-Prozess ... so mir scheint es als ob du aktiv über "iob setup custom" eine Migration zu "file" gemacht hast und dabei gab es einen Permission Fehler.
Um es jetzt zu fixen:
1.)iob fixum die Rechtefehler zu fixen
2.) Wenn DU zurück zum letzten Redis Stand willst editiere die /opt/iobroker/iobroker-data/iobroker.json und ändere bei objects und states jeweils den Typ in "redis" da wo jetzt scheinbar "file" steht.Danach sollte erstmal alles wieder laufen
Hallo hier meine Erkenntnisse des Tests. Ob die alle durch den js-controller verursacht sind weiß ich nicht. sind aber auch keine Kriitischen Fehler:
Ausganslage:
Getestet wird in einem docker-container auf Basis buanet/iobroker:latest in einem macvlan. volumes wurden nicht in einen Ordner herausgeführtdocker-compose-file
Testablauf
Nach Erzeugen des Containers wurden das repo auf latest gesetzt. Hier ist mir aufgefallen, das beim Speichern des Konfigurationsdialog eine Fehlermeldung auftrat "DB cannot be read " oder so ähnlich. Der Dialog konnte nicht geschlossen werden, sondern man musste erneut die http-adresse des iobrokers eingeben.Fehler/Problem1: Beim Speichern des Konfigurationsdialog konnte der Dialog nicht geschlossen werden.
im Anschluss habe ich alle Adapter aktualisiert
Danach Update von js-controller
Fehler/Problem2: Bei den Hinweisen gibt es einen Fehler im adapterfixer. Es fehlt ein leerzeichen zwischen bash und -curl -sL https://iobroker.net/fix.sh | bash-upgrade lief soweit gut, bis auf die oben bereits benannten Probleme (angezeigte Fehlermeldungen, Fixer muss durchgeführt werden, sonst Fehlermeldung "operation not permittet"
Im Anschluss dann noch Update des Admin-Adapters
Beim installieren von Adaptern traten 2 Probleme auf.
Der Adapter hat eine Abhängigkeit zu vis, vis eine Abhängigkeit zu web. Beide wurden auch installiert, nur am Ende brach die Installation des eigentlichen Adapters mit Fehlermeldung ab (meldung landete nicht im log)Fehler/Problem3:
Bei Installation von Adaptern mit Abhängigkeiten zu vis/web wird der eigentliche Adapter nicht installiert.Ein erneuter Aufruf der Installation endete dann mit der folgenden Fehlermeldung
iobroker adapter "rssfeed" cannot be installed: Cannot read property 'startsWith' of undefined iobroker adapter "tvprogram" cannot be installed: Cannot read property 'startsWith' of undefinedFehler/Problem4:
Innerhalb einer gewissen zeit nach Umstellung und Start von iobroker können keine Adapter installiert werden. Das sollte über eine Meldung dem Nutzer signalisiert werden.Nach einer gewissen Zeit, klappte dann die erneute Installation der Adapter
@oliverio Zu Fehler 1: Ich verstehe nicht was Du meinst. Hast Du da mehr Infos? Screenshot? Whatever?
zu Fehler 3: Unbekannt, bitte GitHub issue anlegen. Und am besten mehr logs bitte und so. Ich kann DAS nicht niachstellen, aber sehe ein anderes issue wenn ich tvprogram installiere und weder web noch vis habe
Zu Fehler 4: Keine Ahnung was du meinst? Was sagt das system am anfang? Die Installation sollte an sich davon unabhängig sein ...Mehr details und Logs bitte
Also ich kann nach dem Update keine adapter mehr updaten, das Update selbst ist ohne Probleme durchgelaufen bis auf die erwarteten Fehler.
@apollon77 Gibt eig keine Fehlermeldung das Update läuft durch, verschwindet aber nicht, auch nicht nach einen kompletten reload der seite, wenn ich dann per Snaphsot zurück gehe auf 3.3.22 funktioniert es wieder
@m0rph sagte in js-controller 4.0 jetzt im BETA/LATEST!:
Zuviel GUI im Spiel. Im LogFile auf der Kommandozeile kommt was?
Schau mitiobroker logs --watchdanach.
Ich glaube ich muss ein screenToGif machen.
@apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
da erscheint nur kurz eine Meldung. Im Server-Log ist nichts zu sehen. Browser-Log muss ich nochmal schauen.
ok, werde neu aufsetzen und dann ein komplettes log bereitstellen
@thomas-braun Ich bekomme bei jeden versuch diese Warnung geloggt
2022-02-08 18:04:41.756 error iobroker Assuming that correct version is installed. 2022-02-08 18:04:41.754 error iobroker Could not check npm version: This directory tree does not contain a package.jsonMOD EDIT: LOG in Code Tags gesetzt
iobroker Could not check npm version: This directory tree does not contain a package.jsonHabe ich noch nie gesehen, die Meldung. In welchem Verzeichnis springst du denn da rum?
nodeJS / npm richtig installiert?
sudo ln -s /usr/bin/node /usr/bin/nodejs which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
sudo ln -s /usr/bin/node /usr/bin/nodejs which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs@thomas-braun sagte in js-controller 4.0 jetzt im BETA/LATEST!:
Hab die Befehle mal ausgeführt hat nichts gebracht, der link zur nodejs war schon vorhanden, npm -v funktioniert auch normal
hat nichts gebracht
Das soll auch 'nichts bringen', das soll nur den Helfern zeigen womit du da unterwegs bist. Ausgaben in CodeTags hier ins Forum posten.
hat nichts gebracht
/usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.0 v14.19.0 6.14.16 root /root OK:1 http://security.ubuntu.com/ubuntu xenial-security InRelease OK:2 http://de.archive.ubuntu.com/ubuntu xenial InRelease OK:3 http://de.archive.ubuntu.com/ubuntu xenial-updates InRelease OK:4 https://deb.nodesource.com/node_14.x xenial InRelease OK:5 http://de.archive.ubuntu.com/ubuntu xenial-backports InRelease OK:6 https://esm.ubuntu.com/infra/ubuntu xenial-infra-security InRelease OK:7 https://esm.ubuntu.com/infra/ubuntu xenial-infra-updates InRelease Ign:8 https://download.webmin.com/download/repository sarge InRelease OK:9 https://download.webmin.com/download/repository sarge Release Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Alle Pakete sind aktuell. nodejs: Installiert: 14.19.0-1nodesource1 Installationskandidat: 14.19.0-1nodesource1 Versionstabelle: *** 14.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_14.x xenial/main amd64 Packages 100 /var/lib/dpkg/status 4.2.6~dfsg-1ubuntu4.2 500 500 http://de.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages 4.2.6~dfsg-1ubuntu4 500 500 http://de.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages -
/usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.19.0 v14.19.0 6.14.16 root /root OK:1 http://security.ubuntu.com/ubuntu xenial-security InRelease OK:2 http://de.archive.ubuntu.com/ubuntu xenial InRelease OK:3 http://de.archive.ubuntu.com/ubuntu xenial-updates InRelease OK:4 https://deb.nodesource.com/node_14.x xenial InRelease OK:5 http://de.archive.ubuntu.com/ubuntu xenial-backports InRelease OK:6 https://esm.ubuntu.com/infra/ubuntu xenial-infra-security InRelease OK:7 https://esm.ubuntu.com/infra/ubuntu xenial-infra-updates InRelease Ign:8 https://download.webmin.com/download/repository sarge InRelease OK:9 https://download.webmin.com/download/repository sarge Release Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Alle Pakete sind aktuell. nodejs: Installiert: 14.19.0-1nodesource1 Installationskandidat: 14.19.0-1nodesource1 Versionstabelle: *** 14.19.0-1nodesource1 500 500 https://deb.nodesource.com/node_14.x xenial/main amd64 Packages 100 /var/lib/dpkg/status 4.2.6~dfsg-1ubuntu4.2 500 500 http://de.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 Packages 500 http://security.ubuntu.com/ubuntu xenial-security/universe amd64 Packages 4.2.6~dfsg-1ubuntu4 500 500 http://de.archive.ubuntu.com/ubuntu xenial/universe amd64 PackagesUbuntu xenial ist Steinzeit. Und nur noch im Wachkoma künstlich am Leben gehalten.
Und als root agiert man (gerade auf einem Ubuntu) nicht. -
Und als root agiert man (gerade auf einem Ubuntu) nicht.@thomas-braun Mag sein, was hat das jetzt genau mit dem Problem zu tun !?
@m0rph
Warum sollte es nicht mit dem Problem zu tun haben? -
@m0rph
Warum sollte es nicht mit dem Problem zu tun haben?@thomas-braun Bin kein Entwickler, ich weis nur das es mit der alten version funktioniert, aber egal ich werde es einfach lassen, und bei Zeiten OS updaten, ich hoffe ja das es mit einen aktuellen ubuntu funktioniert
Kann ich später, wenn ich zu hause bin.
Die Meldungen, kamen übrigens auch schon beim controller update selbst
