  4. [gelöst] Unbekannte Ursache für Raspi Komplettabsturz alle..
    6.1k
65 Beiträge 6 Kommentatoren 6.8k Aufrufe 4 Beobachtet
  • wendy2702W wendy2702
    @tklein
    /var/log
    tklein
    @wendy2702 thx, welches genau aus dem Verzeichtnis, das sind einige drin
    • T tklein
      wendy2702W Offline
      wendy2702W Offline
      @tklein syslog.
      Wenn du weißt wann genau der letzte „Absturz“ war kannst du dir das vom Datum her passende File ansehen
      • T tklein
        @wendy2702 hier der output von dmesg
        pi@raspberrypi-iob:~ $ dmesg
        [    0.000000] Booting Linux on physical CPU 0x0
        [    0.000000] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1421 SMP Thu May 27 14:00:13 BST 2021
        [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [    0.000000] Zone ranges:
        [    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        [    0.000000]   Normal   empty
        [    0.000000]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
        [    0.000000] Movable zone start for each node
        [    0.000000] Early memory node ranges
        [    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
        [    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
        [    0.000000] On node 0 totalpages: 1012480
        [    0.000000]   DMA zone: 2304 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
        [    0.000000] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        [    0.000000] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010176
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [    0.000000] Kernel parameter elevator= does not have any effect anymore.
                       Please use sysfs to set IO scheduler for individual devices.
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [    0.000000] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
        [    0.000000] Memory: 3653916K/4049920K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3263488K highmem)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 33942 entries in 67 pages
        [    0.000000] ftrace: allocated 67 pages with 3 groups
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000]  Rude variant of Tasks RCU enabled.
        [    0.000000]  Tracing variant of Tasks RCU enabled.
        [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
        [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [    0.000027] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [    0.000087] bcm2835: system timer (irq = 25)
        [    0.000734] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [    0.000752] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [    0.000770] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [    0.000785] Switching to timer-based delay loop, resolution 18ns
        [    0.001034] Console: colour dummy device 80x30
        [    0.001100] printk: console [tty1] enabled
        [    0.001154] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [    0.001187] pid_max: default: 32768 minimum: 301
        [    0.001356] LSM: Security Framework initializing
        [    0.001540] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.001567] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.003117] Disabling memory control group subsystem
        [    0.003236] CPU: Testing write buffer coherency: ok
        [    0.003694] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.004898] Setting up static identity map for 0x200000 - 0x20003c
        [    0.005095] rcu: Hierarchical SRCU implementation.
        [    0.006018] smp: Bringing up secondary CPUs ...
        [    0.007221] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.008585] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [    0.009875] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [    0.010032] smp: Brought up 1 node, 4 CPUs
        [    0.010052] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [    0.010068] CPU: All CPU(s) started in HYP mode.
        [    0.010082] CPU: Virtualization extensions available.
        [    0.010969] devtmpfs: initialized
        [    0.024966] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [    0.025199] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.025231] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [    0.032217] pinctrl core: initialized pinctrl subsystem
        [    0.033277] NET: Registered protocol family 16
        [    0.037333] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.038090] audit: initializing netlink subsys (disabled)
        [    0.038379] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
        [    0.038938] thermal_sys: Registered thermal governor 'step_wise'
        [    0.039702] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.039720] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.040107] Serial: AMBA PL011 UART driver
        [    0.071947] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [    0.091121] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-05-27T14:02:15, variant start
        [    0.101134] raspberrypi-firmware soc:firmware: Firmware hash is 7d9a298cda813f747b51fe17e1e417e7bf5ca94d
        [    0.146205] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [    0.150322] vgaarb: loaded
        [    0.150770] SCSI subsystem initialized
        [    0.150981] usbcore: registered new interface driver usbfs
        [    0.151053] usbcore: registered new interface driver hub
        [    0.151127] usbcore: registered new device driver usb
        [    0.151834] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [    0.153784] clocksource: Switched to clocksource arch_sys_counter
        [    1.152262] VFS: Disk quotas dquot_6.6.0
        [    1.152363] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    1.152528] FS-Cache: Loaded
        [    1.152738] CacheFiles: Loaded
        [    1.163134] NET: Registered protocol family 2
        [    1.164038] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    1.164090] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [    1.164232] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    1.164303] TCP: Hash tables configured (established 8192 bind 8192)
        [    1.164460] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.164496] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    1.164768] NET: Registered protocol family 1
        [    1.165467] RPC: Registered named UNIX socket transport module.
        [    1.165482] RPC: Registered udp transport module.
        [    1.165497] RPC: Registered tcp transport module.
        [    1.165511] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    1.165535] PCI: CLS 0 bytes, default 64
        [    1.168484] Initialise system trusted keyrings
        [    1.168706] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        [    1.177270] zbud: loaded
        [    1.179165] FS-Cache: Netfs 'nfs' registered for caching
        [    1.179944] NFS: Registering the id_resolver key type
        [    1.179984] Key type id_resolver registered
        [    1.179999] Key type id_legacy registered
        [    1.180146] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    1.181172] Key type asymmetric registered
        [    1.181189] Asymmetric key parser 'x509' registered
        [    1.181381] bounce: pool size: 64 pages
        [    1.181425] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [    1.181636] io scheduler mq-deadline registered
        [    1.181653] io scheduler kyber registered
        [    1.186067] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [    1.186098] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [    1.186178] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [    1.186266] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [    1.245889] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [    1.246255] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [    1.246276] pci_bus 0000:00: root bus resource [bus 00-ff]
        [    1.246297] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [    1.246385] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [    1.246629] pci 0000:00:00.0: PME# supported from D0 D3hot
        [    1.250143] PCI: bus0: Fast back to back transfers disabled
        [    1.250481] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [    1.250609] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [    1.251044] pci 0000:01:00.0: PME# supported from D0 D3cold
        [    1.254541] PCI: bus1: Fast back to back transfers disabled
        [    1.254604] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [    1.254628] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [    1.254712] pci 0000:00:00.0: PCI bridge to [bus 01]
        [    1.254738] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [    1.255159] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [    1.255384] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
        [    1.263693] iproc-rng200 fe104000.rng: hwrng registered
        [    1.264038] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [    1.264896] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [    1.277105] brd: module loaded
        [    1.289372] loop: module loaded
        [    1.291018] Loading iSCSI transport class v2.0-870.
        [    1.293428] libphy: Fixed MDIO Bus: probed
        [    1.295145] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [    1.313832] libphy: bcmgenet MII bus: probed
        [    1.403935] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [    1.405093] usbcore: registered new interface driver r8152
        [    1.405162] usbcore: registered new interface driver lan78xx
        [    1.405223] usbcore: registered new interface driver smsc95xx
        [    1.407653] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
        [    1.407815] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.407851] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [    1.411209] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
        [    1.412541] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [    1.412560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.412577] usb usb1: Product: xHCI Host Controller
        [    1.412594] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [    1.412610] usb usb1: SerialNumber: 0000:01:00.0
        [    1.413339] hub 1-0:1.0: USB hub found
        [    1.413437] hub 1-0:1.0: 1 port detected
        [    1.414147] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.414175] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [    1.414201] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [    1.414750] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        [    1.414769] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.414786] usb usb2: Product: xHCI Host Controller
        [    1.414803] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [    1.414820] usb usb2: SerialNumber: 0000:01:00.0
        [    1.415541] hub 2-0:1.0: USB hub found
        [    1.415635] hub 2-0:1.0: 4 ports detected
        [    1.417333] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    1.417636] dwc_otg: FIQ enabled
        [    1.417651] dwc_otg: NAK holdoff enabled
        [    1.417665] dwc_otg: FIQ split-transaction FSM enabled
        [    1.417683] Module dwc_common_port init
        [    1.418134] usbcore: registered new interface driver uas
        [    1.418239] usbcore: registered new interface driver usb-storage
        [    1.418432] mousedev: PS/2 mouse device common for all mice
        [    1.420076] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    1.423530] sdhci: Secure Digital Host Controller Interface driver
        [    1.423545] sdhci: Copyright(c) Pierre Ossman
        [    1.424275] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [    1.424877] sdhci-pltfm: SDHCI platform and OF driver helper
        [    1.429013] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.429354] hid: raw HID events driver (C) Jiri Kosina
        [    1.429546] usbcore: registered new interface driver usbhid
        [    1.429560] usbhid: USB HID core driver
        [    1.435297] Initializing XFRM netlink socket
        [    1.435339] NET: Registered protocol family 17
        [    1.435459] Key type dns_resolver registered
        [    1.435895] Registering SWP/SWPB emulation handler
        [    1.436076] registered taskstats version 1
        [    1.436103] Loading compiled-in X.509 certificates
        [    1.436943] Key type ._fscrypt registered
        [    1.436960] Key type .fscrypt registered
        [    1.436975] Key type fscrypt-provisioning registered
        [    1.448529] uart-pl011 fe201000.serial: there is not valid maps for state default
        [    1.448842] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [    1.448917] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        [    1.455674] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [    1.456712] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [    1.456729] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [    1.487010] of_cfs_init
        [    1.487272] of_cfs_init: OK
        [    1.494580] mmc1: Controller never released inhibit bit(s).
        [    1.519085] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [    1.520775] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.522516] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.526082] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [    1.527789] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.535040] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [    1.535718] Waiting for root device PARTUUID=74cbdb6a-02...
        [    1.572035] random: fast init done
        [    1.595963] mmc1: new high speed SDIO card at address 0001
        [    1.773827] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [    1.956632] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [    1.956651] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    1.956669] usb 1-1: Product: USB2.0 Hub
        [    1.958424] hub 1-1:1.0: USB hub found
        [    1.958737] hub 1-1:1.0: 4 ports detected
        [    2.104183] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [    2.135817] usb 2-2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 4.14
        [    2.135836] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.135853] usb 2-2: Product: USB to ATA/ATAPI Bridge
        [    2.135870] usb 2-2: Manufacturer: JMicron
        [    2.135886] usb 2-2: SerialNumber: 0123456789ABCDEF
        [    2.159842] scsi host0: uas
        [    2.161315] scsi 0:0:0:0: Direct-Access     JMicron  Generic          0414 PQ: 0 ANSI: 6
        [    2.164230] sd 0:0:0:0: [sda] 468862128 512-byte logical blocks: (240 GB/224 GiB)
        [    2.164327] sd 0:0:0:0: [sda] 4096-byte physical blocks
        [    2.164590] sd 0:0:0:0: [sda] Write Protect is off
        [    2.164610] sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08
        [    2.165088] sd 0:0:0:0: [sda] Disabling FUA
        [    2.165109] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
        [    2.165907] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
        [    2.166902]  sda: sda1 sda2
        [    2.170791] sd 0:0:0:0: [sda] Attached SCSI disk
        [    2.199302] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [    2.199321] EXT4-fs (sda2): write access will be enabled during recovery
        [    2.283875] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
        [    2.710888] EXT4-fs (sda2): orphan cleanup on readonly fs
        [    2.718697] EXT4-fs (sda2): 6 orphan inodes deleted
        [    2.718715] EXT4-fs (sda2): recovery complete
        [    2.725881] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [    2.725967] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [    2.726445] devtmpfs: mounted
        [    2.735364] Freeing unused kernel memory: 2048K
        [    2.737870] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
        [    2.737890] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    2.737908] usb 1-1.3: Product: FT232R USB UART
        [    2.737925] usb 1-1.3: Manufacturer: FTDI
        [    2.737942] usb 1-1.3: SerialNumber: A94ZVX1D
        [    2.774142] Run /sbin/init as init process
        [    2.774158]   with arguments:
        [    2.774172]     /sbin/init
        [    2.774187]     splash
        [    2.774201]   with environment:
        [    2.774215]     HOME=/
        [    2.774229]     TERM=linux
        [    2.883894] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
        [    2.969124] systemd[1]: System time before build time, advancing clock.
        [    3.022908] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
        [    3.022930] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [    3.022947] usb 1-1.4: Product: ConBee II
        [    3.022964] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
        [    3.022981] usb 1-1.4: SerialNumber: DE2219042
        [    3.036563] NET: Registered protocol family 10
        [    3.037948] Segment Routing with IPv6
        [    3.082441] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    3.083459] systemd[1]: Detected architecture arm.
        [    3.157076] systemd[1]: Set hostname to <raspberrypi-iob>.
        [    3.790645] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.800839] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.804457] systemd[1]: Created slice system-getty.slice.
        [    3.804742] random: systemd: uninitialized urandom read (16 bytes read)
        [    3.805419] systemd[1]: Listening on Syslog Socket.
        [    3.805870] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [    3.808296] systemd[1]: Listening on udev Kernel Socket.
        [    3.809332] systemd[1]: Listening on Journal Audit Socket.
        [    3.810168] systemd[1]: Listening on Journal Socket.
        [    3.810802] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
        [    3.951918] i2c /dev entries driver
        [    4.634583] EXT4-fs (sda2): re-mounted. Opts: (null)
        [    4.725196] systemd-journald[111]: Received request to flush runtime journal from PID 1
        [    5.331062] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [    5.343634] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [    5.350592] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [    5.368860] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [    5.409376] mc: Linux media interface: v0.10
        [    5.454741] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.456891] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    5.456916] [vc_sm_connected_init]: start
        [    5.490889] videodev: Linux video capture interface: v2.00
        [    5.496872] [vc_sm_connected_init]: installed successfully
        [    5.515879] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.540496] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.548338] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.569698] bcm2835_audio bcm2835_audio: card created with 8 channels
        [    5.571113] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.582220] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [    5.582887] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [    5.583360] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [    5.583732] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [    5.583839] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [    5.583864] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [    5.583888] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [    5.583925] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [    5.584153] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [    5.592378] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    5.638293] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    5.663166] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    5.663233] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    5.670651] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    5.670696] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    5.683174] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    5.683219] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    5.787038] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [    5.805152] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    5.854154] brcmfmac: F1 signature read @0x18000000=0x15264345
        [    5.869706] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    5.870882] usbcore: registered new interface driver brcmfmac
        [    5.879093] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        [    5.879234] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [    5.879984] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [    5.881154] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        [    5.999843] random: crng init done
        [    5.999864] random: 7 urandom warning(s) missed due to ratelimiting
        [    6.006317] usbcore: registered new interface driver usbserial_generic
        [    6.006453] usbserial: USB Serial support registered for generic
        [    6.050977] usbcore: registered new interface driver ftdi_sio
        [    6.051078] usbserial: USB Serial support registered for FTDI USB Serial Device
        [    6.051366] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
        [    6.051561] usb 1-1.3: Detected FT232RL
        [    6.070231] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
        [    6.139136] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
        [    6.141973] usbcore: registered new interface driver cdc_acm
        [    6.142030] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
        [    6.147380] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    6.156548] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [    6.219863] sd 0:0:0:0: Attached scsi generic sg0 type 0
        [    8.493344] 8021q: 802.1Q VLAN Support v1.8
        [    8.567345] uart-pl011 fe201000.serial: no DMA platform data
        [    8.914117] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
        [    8.956410] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
        [   31.833823] vcc-sd: disabling
        [   39.533816] sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD IN
        [   39.533833] sd 0:0:0:0: [sda] tag#27 CDB: opcode=0x28 28 00 00 d0 f0 c8 00 00 08 00
        [   39.534080] sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD IN
        [   39.534094] sd 0:0:0:0: [sda] tag#26 CDB: opcode=0x28 28 00 00 4b 02 78 00 00 08 00
        [   39.534415] sd 0:0:0:0: [sda] tag#23 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
        [   39.534428] sd 0:0:0:0: [sda] tag#23 CDB: opcode=0x28 28 00 00 91 ad 50 00 01 00 00
        [   39.535270] sd 0:0:0:0: [sda] tag#22 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
        [   39.535283] sd 0:0:0:0: [sda] tag#22 CDB: opcode=0x28 28 00 00 91 a2 00 00 00 08 00
        [   39.535627] sd 0:0:0:0: [sda] tag#20 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD IN
        [   39.535640] sd 0:0:0:0: [sda] tag#20 CDB: opcode=0x28 28 00 00 09 38 c8 00 00 08 00
        [   39.535934] sd 0:0:0:0: [sda] tag#15 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
        [   39.535947] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 01 79 c4 00 00 00 20 00
        [   39.536142] sd 0:0:0:0: [sda] tag#14 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD IN
        [   39.536154] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x28 28 00 00 2c 84 78 00 00 40 00
        [   39.536515] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD IN
        [   39.536528] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 09 24 b0 00 00 08 00
        [   39.536699] sd 0:0:0:0: [sda] tag#12 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD IN
        [   39.536712] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x28 28 00 00 0f ec 88 00 00 20 00
        [   39.536906] sd 0:0:0:0: [sda] tag#11 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
        [   39.536918] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 00 3b c2 00 00 00 98 00
        [   39.537470] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
        [   39.537482] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 00 bd 66 38 00 00 98 00
        [   39.538070] sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
        [   39.538083] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 01 70 01 e0 00 00 80 00
        [   39.538613] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD IN
        [   39.538626] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x28 28 00 00 22 d1 e8 00 00 08 00
        [   40.053817] sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD IN
        [   40.053835] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 00 48 6d 08 00 01 00 00
        [   40.223812] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD IN
        [   40.223829] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x28 28 00 00 2c 84 b8 00 00 18 00
        [   42.733813] sd 0:0:0:0: [sda] tag#21 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
        [   42.733830] sd 0:0:0:0: [sda] tag#21 CDB: opcode=0x2a 2a 00 00 09 ad 10 00 00 08 00
        [   42.734234] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
        [   42.734249] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x2a 2a 00 00 0c 27 a0 00 00 08 00
        [   42.734800] sd 0:0:0:0: [sda] tag#18 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD IN
        [   42.734813] sd 0:0:0:0: [sda] tag#18 CDB: opcode=0x28 28 00 00 08 26 f0 00 00 08 00
        [   63.853815] sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD IN
        [   63.853833] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x28 28 00 00 88 21 00 00 01 08 00
        [   63.913855] scsi host0: uas_eh_device_reset_handler start
        [   64.074917] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [   64.109652] scsi host0: uas_eh_device_reset_handler success
        [   64.751428] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [   64.752122] bcmgenet fd580000.ethernet eth0: Link is Down
        [   68.874040] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
        [   68.874082] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   71.933831] sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 8 inflight: CMD IN
        [   71.933850] sd 0:0:0:0: [sda] tag#8 CDB: opcode=0x85 85 08 2e 00 00 00 01 00 00 00 00 00 00 00 ec 00
        [   95.213829] sd 0:0:0:0: [sda] tag#15 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD IN
        [   95.213848] sd 0:0:0:0: [sda] tag#15 CDB: opcode=0x28 28 00 00 26 77 50 00 00 08 00
        [   95.214107] sd 0:0:0:0: [sda] tag#14 uas_eh_abort_handler 0 uas-tag 7 inflight: CMD OUT
        [   95.214121] sd 0:0:0:0: [sda] tag#14 CDB: opcode=0x2a 2a 00 00 d2 a0 08 00 00 08 00
        [   95.214571] sd 0:0:0:0: [sda] tag#11 uas_eh_abort_handler 0 uas-tag 6 inflight: CMD IN
        [   95.214584] sd 0:0:0:0: [sda] tag#11 CDB: opcode=0x28 28 00 00 a9 20 00 00 00 20 00
        [   95.215072] sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD IN
        [   95.215085] sd 0:0:0:0: [sda] tag#10 CDB: opcode=0x28 28 00 00 bd 58 70 00 00 18 00
        [   95.215367] sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD IN
        [   95.215380] sd 0:0:0:0: [sda] tag#7 CDB: opcode=0x28 28 00 01 70 3f e0 00 01 00 00
        [   95.216187] sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
        [   95.216200] sd 0:0:0:0: [sda] tag#6 CDB: opcode=0x28 28 00 00 67 79 e0 00 00 20 00
        [   95.216596] sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
        [   95.216609] sd 0:0:0:0: [sda] tag#5 CDB: opcode=0x28 28 00 00 3f 77 c0 00 00 10 00
        [   95.216887] sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD IN
        [   95.216900] sd 0:0:0:0: [sda] tag#4 CDB: opcode=0x28 28 00 00 01 b9 93 00 00 01 00
        [   98.973811] sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD IN
        [   98.973826] sd 0:0:0:0: [sda] tag#9 CDB: opcode=0x28 28 00 00 09 ae 68 00 00 08 00
        [   99.943823] sd 0:0:0:0: [sda] tag#13 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD IN
        [   99.943843] sd 0:0:0:0: [sda] tag#13 CDB: opcode=0x28 28 00 00 42 ec 00 00 00 20 00
        [   99.944105] sd 0:0:0:0: [sda] tag#12 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
        [   99.944120] sd 0:0:0:0: [sda] tag#12 CDB: opcode=0x2a 2a 00 00 38 23 68 00 01 18 00
        [   99.993888] scsi host0: uas_eh_device_reset_handler start
        [  100.144871] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [  100.179627] scsi host0: uas_eh_device_reset_handler success
        [  101.852047] broken atomic modeset userspace detected, disabling atomic
        [  102.744888] broken atomic modeset userspace detected, disabling atomic
        [  103.715089] broken atomic modeset userspace detected, disabling atomic
        [  104.388428] broken atomic modeset userspace detected, disabling atomic
        [  105.466259] broken atomic modeset userspace detected, disabling atomic
        [  106.146534] broken atomic modeset userspace detected, disabling atomic
        [  107.161775] broken atomic modeset userspace detected, disabling atomic
        [  107.788820] broken atomic modeset userspace detected, disabling atomic
        [  108.879844] broken atomic modeset userspace detected, disabling atomic
        [  109.548492] broken atomic modeset userspace detected, disabling atomic
        [  110.611677] broken atomic modeset userspace detected, disabling atomic
        [  111.219193] broken atomic modeset userspace detected, disabling atomic
        [  315.263777] Bluetooth: Core ver 2.22
        [  315.263865] NET: Registered protocol family 31
        [  315.263872] Bluetooth: HCI device and connection manager initialized
        [  315.264334] Bluetooth: HCI socket layer initialized
        [  315.264347] Bluetooth: L2CAP socket layer initialized
        [  315.264370] Bluetooth: SCO socket layer initialized
        [ 3247.875812] sd 0:0:0:0: [sda] tag#19 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD IN
        [ 3247.875832] sd 0:0:0:0: [sda] tag#19 CDB: opcode=0x28 28 00 01 ed f8 00 00 04 00 00
        [ 3247.877022] sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
        [ 3247.877037] sd 0:0:0:0: [sda] tag#16 CDB: opcode=0x28 28 00 01 ed fc 00 00 04 00 00
        [ 3247.895796] sd 0:0:0:0: [sda] tag#17 uas_eh_abort_handler 0 uas-tag 3 inflight: CMD OUT
        [ 3247.895813] sd 0:0:0:0: [sda] tag#17 CDB: opcode=0x2a 2a 00 14 4c e6 40 00 00 08 00
        [ 3250.435795] sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 4 inflight: CMD OUT
        [ 3250.435814] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x2a 2a 00 00 3a 02 a8 00 00 68 00
        [ 3252.915808] sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 5 inflight: CMD OUT
        [ 3252.915824] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x2a 2a 00 14 96 1d 70 00 00 80 00
        [ 3252.955798] scsi host0: uas_eh_device_reset_handler start
        [ 3253.107038] usb 2-2: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [ 3253.141502] scsi host0: uas_eh_device_reset_handler success
        Das sagt mir als relativer Linux-Laie nicht wirklich viel.
        @tklein
        Den Desktop schon mal ausknipsen.
        Das Dateisystem auf sda / der SSD hat 'nen Schuß.
          @tklein syslog.
          tklein
          @wendy2702 said in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
          ordner/log von influx db ist z.b leer
            @tklein
            tklein
            @thomas-braun said in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
            danke für den Hinweis. Woran erkennt man das? Wie kann ich den Desktop ausstellen? Gehe eh nur per SSH drauf
            • T tklein
              wendy2702W Offline
              wendy2702W Offline
              @tklein sagte in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
              Du musst in die syslog files schauen.
              Aber Thomas hat ja schon geschrieben wo der Hund begraben liegt.
              Am besten Backup machen und neu aufsetzen würde ich machen
              • T tklein
                Desktop: An der Meldung zu Atomic Mode Setting
                SSD: An den Meldungen zu orphaned inodes und den anderen /dev/SDA bezogenen Meldungen.
                  tklein
                  @thomas-braun gibt es eine Möglichkeit, dass wieder ohne Neuinstallation hinzubekommen? Ich würde da Tage dransitzen mit iobroker, fhem, grafana, influx etc.
                  • T tklein
                    @tklein
                    Backup?
                    Ich würde es allerdings komplett Neuaufsetzen, beim OS angefangen und dann gleich eine Version ohne Desktop hernehmen.
                      @tklein
                      Backup?
                      tklein
                      @tklein
                      Backup?
                      ich als Laie benötige meist für die Installation ewig lange. Muss mich an Tutorials etc entlanghangeln. Dann sind einige veraltet etc.
                      • T tklein
                        @tklein
                        Backup?
                        für ioBroker:
                        • aktuelles RaspberrypiOS lite aufspielen (über piImager mit den entsprechenden Parametern)
                        • curl -sLf https://iobroker.net/install.sh | bash - ausführen
                        • fertig
                          für ioBroker:
                          • fertig
                          tklein
                          @homoran said in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
                          da fängt es schon an. kann ich das auf die ssd spielen oder muss ich erst von sd booten?
                          • T tklein
                            die ist doch hin?
                            Aber ich weiß nicht wie das jetzt läuft. Bei pi2/3 konnte man es direkt auf die SSD spielen
                              die ist doch hin?
                              tklein
                              die ist doch hin?
                              die platte ist gerade 3-4 wochen alt. dachte, dass es mit einer neuinstallation alles tutti wäre.
                              Pi ist ein 4er mit 4GB
                              • T tklein
                                die ist doch hin?
                                wenn die Probleme an defekten Zellen liegen, ist das eben nicht tutti
                                T Dr. BakteriusD 2 Antworten Letzte Antwort
                                  tklein
                                  wie kann ich das rausfinden? Würde das nach Neuinstallation testen wollen, bevor ich mir die arbeit mache.
                                  Alternativ könnte ich das Image sichern und auf eine neue SSD Platte aufspielen, oder?
                                  • T tklein
                                    welches Image?
                                    wenn du jetzt die defekte Platte klonen willst hast du die Fehler mit geklont
                                      welches Image?
                                      tklein
                                      schrieb am zuletzt editiert von tklein
                                      achso mist. hätte die jetzt geclont
                                        Dr. BakteriusD Online
                                        Dr. Bakterius
                                        @tklein, @homoran sagte in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
                                        Was sagt denn S.M.A.R.T.? Beschädigtes Dateisystem kann ja auch daran liegen, dass der Pi mal hart vom Strom genommen wurde.
                                          tklein
                                          @dr-bakterius said in Unbekannte Ursache für Raspi Komplettabsturz alle 2-3 Tage:
                                          ja öfters, wenn er dead war.
                                          pi@raspberrypi-iob:/var/log/influxdb $ sudo smartctl --info /dev/sda1
                                          smartctl 6.6 2017-11-05 r4594 [armv7l-linux-5.10.17-v7l+] (local build)
                                          Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
                                          === START OF INFORMATION SECTION ===
                                          Vendor:               JMicron
                                          Product:              Generic
                                          Revision:             0414
                                          Compliance:           SPC-4
                                          User Capacity:        240,057,409,536 bytes [240 GB]
                                          Logical block size:   512 bytes
                                          LU is resource provisioned, LBPRZ=0
                                          Logical Unit id:      0x3001234567891234
                                          Serial number:        0123456789ABCDEF
                                          Device type:          disk
                                          Local Time is:        Sat Jan 15 12:48:35 2022 CET
                                          SMART support is:     Unavailable - device lacks SMART capability.
                                          keine Ahnung, ob ich es ausführen kann
                                          Ergebnis:
                                          pi@raspberrypi-iob:/var/log/influxdb $ sudo smartctl -t long /dev/sda1
                                          Long (extended) offline self test failed [device not ready]
                                          pi@raspberrypi-iob:/var/log/influxdb $ sudo smartctl -t short /dev/sda1
                                          Short offline self test failed [device not ready]
                                          Es ist diese Platte:
                                          https://www.amazon.de/gp/product/B07G3YNLJB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
                                          UPDATE:
                                          Kurzcheck ergab das:
                                          pi@raspberrypi-iob:/var/log/influxdb $ sudo smartctl -H /dev/sda1
                                          === START OF READ SMART DATA SECTION ===
                                          SMART Health Status: OK
                                          Der lange läuft noch
                                          Thomas BraunT H 2 Antworten Letzte Antwort
