  4. Viessmann-Adapter
Viessmann-Adapter
viesmann
523 Beiträge 50 Kommentatoren 213.2k Aufrufe 19 Beobachtet
  • P Offline
    Pep
    #87
    @blauholsten:
    @Pep:
    JSON Konverter wird natürlich genutzt.
    Als Beispiel:
      "vito": {
        "devices": {
          "device": [
              "-ID": "2098",
              "-name": "V200KW2",
              "-protocol": "KW2"
              "-ID": "2053",
              "-name": "GWG_VBEM",
              "-protocol": "GWG"
        "commands": {
          "command": [
              "-name": "getTempA",
              "-protocmd": "getaddr",
              "addr": "0800",
              "len": "2",
              "unit": "UT",
              "error": "05 05",
              "description": "Ermittle die Aussentemeratur in Grad C",
              "device": {
                "-ID": "2053",
                "addr": "6F",
                "unit": "UT1",
                "len": "1"
              "-name": "getTempWWist",
              "addr": "0804",
              "len": "2",
              "unit": "UT",
              "error": "05 05",
              "description": "Ermittle die Warmwassertemperatur in Grad C",
              "device": {
                "-ID": "2053",
                "addr": "42",
                "unit": "UT1U",
                "len": "1"
              "-name": "getTempWWsoll",
              "addr": "6300",
              "len": "1",
              "unit": "ST",
              "description": "Ermittle die Warmwassersolltemperatur in Grad C",
              "device": {
                "-ID": "2053",
                "addr": "5C",
                "unit": "UT1",
                "len": "1"
    Dieser Import führt zu einem Fehler :( `
    Bitte lösche unter device das nicht verwendete Gerät.
    Z.b.
              "-ID": "2053",
              "-protocol": "GWG"
    OK Super. damit bin ich jetzt einen Schritt wieder weiter gekommen.
    Im Log taucht jetzt folgendes auf:
    viessmann.0	2017-02-19 19:11:18.760	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
    viessmann.0	2017-02-19 19:11:17.717	warn	vctrld>
    viessmann.0	2017-02-19 19:11:17.717	warn	Vctrld send ERROR: vctrld>ERR: command unknown
    viessmann.0	2017-02-19 19:11:17.613	info	starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.viessmann, node: v0.10.22
    host.raspberrypi	2017-02-19 19:11:15.500	info	instance system.adapter.viessmann.0 started with pid 4303
    host.raspberrypi	2017-02-19 19:11:13.114	info	instance system.adapter.viessmann.0 terminated with code 0 (OK)
    viessmann.0	2017-02-19 19:11:12.999	info	terminating
    host.raspberrypi	2017-02-19 19:11:12.974	info	stopInstance system.adapter.viessmann.0 killing pid 7725
    viessmann.0	2017-02-19 19:11:12.980	info	cleaned everything up...
    host.raspberrypi	2017-02-19 19:11:12.973	info	object change system.adapter.viessmann.0
    Ein telnet und ein vclient funktionieren aber:
    root@raspberrypi:~# telnet 192.168.178.10 3002
    Trying 192.168.178.10...
    Connected to 192.168.178.10.
    Escape character is '^]'.
    vctrld>quit
    good bye!
    Connection closed by foreign host.
    root@raspberrypi:~# vclient -h 127.0.0.1:3002 -c getTempWWist
    getTempWWist:
    70.599998 Grad Celsius
    root@raspberrypi:~#
    Was läuft da noch falsch :-/
    Ps.: Danke für die Hilfe bis jetzt - echt super von euch.
    • blauholstenB Offline
      blauholsten
      #88
      Wie sieht deine Konfiseite (Reiter Abfragewerte) nach dem einlesen der JSON aus? Bitte Screenshoot
      - Alarm Adapter
      • P Offline
        Pep
        #89
        @blauholsten:
        Wie sieht deine Konfiseite (Reiter Abfragewerte) nach dem einlesen der JSON aus? Bitte Screenshoot `
        Und im Log steht es wie folgt
        viessmann.0	2017-02-19 06:16:17.772	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:16:17.691	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:16:17.584	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:16:17.467	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:16:16.962	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.961	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.960	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.958	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.957	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.955	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.953	warn	Malfunction connection
        viessmann.0	2017-02-19 06:16:16.951	warn	Malfunction connection
        viessmann.0	2017-02-19 06:15:07.576	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:15:07.381	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
        viessmann.0	2017-02-19 06:15:06.931	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.931	warn	Vctrld send ERROR: ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.930	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.930	warn	Vctrld send ERROR: ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.929	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.929	warn	Vctrld send ERROR: ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.927	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.927	warn	Vctrld send ERROR: ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.892	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.892	warn	Vctrld send ERROR: vctrld>ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.891	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.891	warn	Vctrld send ERROR: vctrld>ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.890	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.890	warn	Vctrld send ERROR: vctrld>ERR: command unknown
        viessmann.0	2017-02-19 06:15:06.889	warn	vctrld>
        viessmann.0	2017-02-19 06:15:06.889	warn	Vctrld send ERROR: vctrld>ERR: command unknown
        viessmann.0	2017-02-19 06:13:57.092	warn	No states found for {"type":"state","common":{"name":"","desc":"Testabfrage, Adresse eingeben"},"native":{},"_id":"viessmann.0.get."}
          blauholsten
          #90
          Kannst du bitte noch ein Screenshot von den angelegten Objekten machen? (Im Admin Reiter Objekte)
          - Alarm Adapter
          • P Offline
            Pep
            #91
            @blauholsten:
            Kannst du bitte noch ein Screenshot von den angelegten Objekten machen? (Im Admin Reiter Objekte) `
            klar. Jetzt sehe ich da sogar Werte:
            Im Log finde ich aber immer noch die Einträge. Egal - laut History läuft es aber.
            Würde also erstmal sagen, dass alles (ausser die Logs) läuft :-D
              blauholsten
              #92
              Hast zwar Werte, aber so haut das nicht hin.
              Ich weiß momentan noch nicht mit dem anzufangen.
              Könntest du die Instanz in den debug Modus stellen, und dann die Ausgabe posten.
              Edit:
              Bitte lösche folgendes aus deiner Vito.
              <command name="get" protocmd="gettestaddr"></command>
              <description>Testabfrage, Adresse eingeben</description>
               <device id="2053"><addr>dummy</addr>
              <len>1</len></device>
              Falls du das brauchst, nenne es um. Get sollte nicht alleine stehen. Ich werde das in der nächsten Version abfangen.
              __****Nochmals EDIT:
              bitte installiere den Adapter nochmal (ich habe keine neue Version gemacht), das Kommando aus deiner Vito wird sollte jetzt ignoriert werden.****__
              - Alarm Adapter
                dtp
                #93
                Vielleicht läuft auch einfach nur noch irgendwo eine weitere Instanz von vctrld>. In dem Fall funktioniert die Abfrage der weiteren Instanz nämlich nicht. Auch der vclient würde dann geblockt werden.
                Nur so eine Idee.
                Bei mir läuft die 0.2.5 soweit übrigens einwandfrei.
                Gruß,
                Thorsten
                  dtp
                  #94
                  Hab da noch mal eine kleine Frage.
                  Ich möchte gerne die Systemzeit meiner VScotHO1 per ioBroker setzen (das Ding geht leider nach einigen Wochen immer gerne etwas nach).
                  Hier im https://openv.wikispaces.com/share/view/66158564?replyId=78334294 habe ich dazu folgendes gelesen:
                  ` > Ich habe eine Vitodens 200-W WB2C und das setzen der Zeit in der Heizung habe ich über ein Shellscript realisiert mit folgendem Inhalt:
                  export Startzeit=date "+20 %g %m %d 0%u %H %M %S"
                  export file=/var/log/vitoSetTime
                  echo getSystemTime >$file
                  echo unit off >>$file
                  echo setSystemTime $Startzeit >>$file
                  echo unit on >>$file
                  #echo setSystemTime >>$file
                  #tail $file
                  /usr/local/bin/vclient -h localhost:3002 -f $file
                  /usr/local/bin/vclient -h localhost:3002 'getSystemTime'
                  …Vorher muss die Einheit deaktiviert werden (unit off) und die Systemzeit im 2er Häppchen übertragen werden (wie es im Post bei getSystemTime zu sehen ist). Zwischen Datum und Uhrzeit ist der Wochentag als Zahl. Diese wird beim setzen der Zeit nicht berücksichtigt, da die Heizung das vermutlich selbst umrechnet. Zum Schluss habe ich noch eine Kontrollausgabe eingebaut. Die Datei kann über einen CronJob z.B. 1x am Tag ausgeführt werden. `
                  Das würde ich nun gerne auch über ein Javascript in Verbindung mit dem Viessmann-Adapter und vis umsetzen. Hat jemand eine Idee?
                  Das http://forum.iobroker.net/viewtopic.php?f=21&t=4199&p=40139 für die Heizung, das Warmwasser und die Zirkulationspumpe über einen entsprechenden vis-View habe ich mittlerweile ganz passabel gelöst bekommen. Allerdings ist das zugehörige Javascript noch nicht optimal. Aber dazu an anderer Stelle mehr.
                  Gruß,
                  Thorsten
                    dtp
                    #95
                    Der Adapter läuft soweit sehr gut bei mir.
                    Etwas irritierend ist jedoch, dass nach einem Neustart des Adapters oftmals zunächst die Datenpunkte mit den Werten falscher Adressen befüllt werden. Nach dem erneuten Auslesen der Adressen stimmt's dann aber. Ob das an vctrld oder am Optolink-Adapter liegt? Keine Ahnung. Ist ja auch nicht so tragisch, weil es - wie gesagt - nach dem zweiten Durchlauf wieder in Ordnung ist.
                    Was ich mir noch wünschen würde für den Adapter:
                    1. Ein weiterer Reiter mit einer vctrld-Konsole, so dass man dort direkt Befehle zum Testen eingeben kann. Im Moment muss man den Adapter immer erst anhalten, um in einer per PuTTY oder dergleichen geöffneten vctrld-Konsole Kommandos ausführen zu können. Zwei parallel geöffnete vctrld-Konsolen mag die Viessmann-Heizung offensichtlich nicht.
                    2. Bei manchen Setz-Befehlen (z.B. setSystemTime) ist ein vorheriges Ausschalten der Einheiten-Umwandlung mit dem Befehl "unit off" notwendig. Danach muss die Einheiten-Umwandlung mit "unit on" wieder eingeschaltet werden. Ich fände es toll, wenn man im Adapter für jeden get- und set-Befehl einen kleinen Schalter "unit on|off" setzen könnte. Steht der Schalter auf on, muss nichts weiter unternommen werden. Steht er auf off, wird vor dem eigentlichen get- bzw. set-Befehl zunächst die Einheiten-Umwandlung aus- und danach wieder eingeschaltet.
                    Ich weiß aber nicht, ob das mit vctrld funktioniert. Ich hatte damit so meine Probleme. Beim direkten Aufruf per vclient funktioniert es.
                    3. Schön fände ich auch, wenn man in der vctrld-Konsole (siehe Punkt 1) per Schalter den debug-Modus ein- und ausschalten könnte.
                    Leider bin ich, was die Adapter-Programmierung und Javascript angeht, ein ziemliches Greenhorn. Daher kann ich nur Wünsche äußern. 8-)
                    Bis dann,
                    Thorsten
                    • E Offline
                      elektrofreak
                      #96
                      ich bekomme den Adapter nicht mehr installiert, beim Installieren über die ioBroker Console kommt die Meldung:
                      $ ./iobroker add viessmann
                      ERROR: host.RBpi_Haupt Unknown packetName viessmann
                      ERROR: process exited with code 5
                      Auf der npm Website "https://www.npmjs.com/package/iobroker.viessmann" steht das das Modul nicht existiert.
                      jemand einen Vorschlag woran das liegt.
                      • HomoranH Offline
                        HomoranH Offline
                        #97
                        @elektrofreak:
                        jemand einen Vorschlag woran das liegt. `
                        ich weiß nicht ob der Adapter schon in npm gepusht ist.
                        du kannst ihn wahrscheinlich über github installieren:
                        https://github.com/misanorot/iobroker.viessmann
                        • E Offline
                          elektrofreak
                          #98
                          Hallo
                          das habe ich versucht, habe die Daten Runtergeladen und in den Ordner "/opt/iobroker/node_modules" kopiert.
                          Der Adapter erscheid danach auch bei den Adaptern, doch er lässt sich nicht installieren.
                          ~~![](</s><URL url=)http://up.picr.de/28586016zm.jpg" />
                          ~~![](</s><URL url=)http://up.picr.de/28586017xc.jpg" />
                          Habe das erst letzte Woche auf einem anderen Raspberry Pi gemacht da hat es direkt geklappt nur jetzt nicht mehr.~~~~
                          • HomoranH Offline
                            HomoranH Offline
                            #99
                            Hast du es mal über das octocat icon und dann "beliebig" versucht?
                            http://www.iobroker.net/?page_id=5379&l … stallieren
                            Dort den Pfad zum github-repo von misanorot eingeben
                            • E Offline
                              elektrofreak
                              #100
                              Hi Rainer,
                              Danke das war jetzt echt einfach, hat auf Anhieb funktioniert, diese Methode kannte ich noch nicht.
                              • ldittmarL Offline
                                ldittmarL Offline
                                ldittmar
                                #101
                                Wie weit ist der Adapter eigentlich? Kann er schon in die Liste aufgenommen werden? Wenn ja dann bitte im npm publizieren und kurz bescheid geben ;)
                                Grüße,
                                ldittmar
                                  dtp
                                  #102
                                  Der Adapter funktioniert bei mir seit Wochen ohne Auffälligkeiten. Hier und da ist evtl. noch etwas Feinschliff nötig. Aber das ist ja bei den meisten ioBroker-Adaptern der Fall. ;) Gibt daher eigentlich keinen Grund, ihn nicht in die ioBroker-Liste aufzunehmen.
                                  Gruß,
                                  Thorsten
                                  • P Offline
                                    Pep
                                    #103
                                    Also bei mir läuft der Adapter auch super. Habe eine VITOTRONIC 200 KW2
                                    Hat jemand für mich da einen Tipp, wie ich den Ölverbrauch bestimmen kann?
                                    Den Wert
                                    <command name="getOelverbrauch" protocmd="getaddr"></command>
                                    <addr>7574</addr>
                                    <len>4</len>
                                    <unit>OV</unit>
                                    <description>Ermittle angezeigten Oelverbrauch</description>
                                    habe ich drin - da bekomme ich aber immer den gleichen Wert (26083.73) zurück. Kann man eventuell irgendwas berechnen (aus den Brennerstarts usw.)?
                                      blauholsten
                                      #104
                                      @Pep:
                                      Den Wert
                                      <addr>7574</addr>
                                      <len>4</len>
                                      <unit>OV</unit>
                                      habe ich drin - da bekomme ich aber immer den gleichen Wert (26083.73) zurück. Kann man eventuell irgendwas berechnen (aus den Brennerstarts usw.)? `
                                      Muss erst in deiner Steuerung freigeschalten werden.
                                      Schau in die Serviceanleitung.
                                      - Alarm Adapter
                                      • bahnuhrB Online
                                        bahnuhrB Online
                                        bahnuhr
                                        #105
                                        Guten Tag,
                                        Voraussetzung für den Adapter ist wohl dieses "vcontrold".
                                        Nach dem Link der weiter vorne eingestellt wurde, verweist dieser auf eine Linux Version.
                                        Gibt es dazu auch eine Windows-Variante ?
                                        Oder genauer:
                                        Setzt der Adapter eine vcontrold Linux Variante voraus?
                                        Oder bekomme ich dies mit meinem Windows Rechner auch gebacken.
                                        mfg
                                        Danke.
                                          blauholsten
                                          #106
                                          @bahnuhr:
                                          Guten Tag,
                                          Oder genauer:
                                          mfg `
                                          Hey,
                                          https://openv.wikispaces.com/vcontrold
                                          wenn ich das dort richtig verstehe, gibt es ein daemon für Windows
                                          - Alarm Adapter
