Test Adapter pegelalarm 1.2.x
@simatec sagte in Test Adapter pegelalarm 1.2.x:
1.2.2 (2021-09-02)
jetzt kommt
pegelalarm.0 2021-09-02 15:28:26.386 info State value to set for "pegelalarm.0.stations.pramerdorf.state.unknown" has to be type "boolean" but received type "string" pegelalarm.0 2021-09-02 15:28:22.518 info State value to set for "pegelalarm.0.stations.schrding.state.unknown" has to be type "boolean" but received type "string" pegelalarm.1 2021-09-02 15:28:29.881 info State value to set for "pegelalarm.1.stations.schrding-neuhaus_kw.state.unknown" has to be type "boolean" but received type "string" pegelalarm.1 2021-09-02 15:28:26.385 info State value to set for "pegelalarm.1.stations.passau_marienbrücke.state.unknown" has to be type "boolean" but received type "string" pegelalarm.1 2021-09-02 15:28:22.531 info State value to set for "pegelalarm.1.stations.passau_ingling.state.unknown" has to be type "boolean" but received type "string"@negalein sagte in Test Adapter pegelalarm 1.2.x:
unknown
Mist übersehen ... Warte ich pushe nochmal eine Version
Ab sofort steht die Version 1.2.3 auf Github und in Kürze auch im latest zur Verfügung.
Changelog
1.2.3 (2021-09-02)
- (simatec) Bugfix States
Changelog
1.2.3 (2021-09-02)
@simatec said in Test Adapter pegelalarm 1.2.x:
Changelog
1.2.3 (2021-09-02)
Ist gefixt. Super, vielen Dank!
Sorry, dass ich nicht geantwortet hatte, grad zurück aus Urlaub. -
mit 1.2.4 tritt wieder das Problem auf, dass er plötzlich die Daten nicht mehr abholt.
Im Debug steht auch nur das
host.ioBroker 2021-12-01 12:55:39.437 error instance system.adapter.pegelalarm.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING) pegelalarm.1 2021-12-01 12:55:38.856 error pegelalarm.1 already running host.ioBroker 2021-12-01 12:55:30.781 error instance system.adapter.pegelalarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) pegelalarm.0 2021-12-01 12:55:30.208 error pegelalarm.0 already running -
@negalein Sehr komisch ... gab nur Update der Deps.
Ich schaue die Tage nochmal, wo er genau den Adapter nicht beendet. mein Testsystem läuft und läuft und läuft ... -
ich lass den Debug jetzt mal dauernd an. Vielleicht findet sich dann was.
Ab sofort steht auf Github und in kürze auch im latest die Version 1.2.5 zur Verfügung.
Changelog
1.2.5 (2021-12-08)
- (simatec) Bugfix Adapter stop after request error
- (simatec) Dependencies updated
- (simatec) test and release updated
Super das hilft mir weiter
Servus
Am 25. 5. um ca. 14:xx Uhr war es mit Schaerding wieder soweit.
@negalein Danke dir für den Log ... Er hat mir ein wenig geholfen ...
Hoffe ich konnte damit den Fehler ausfindig machen.
Kannst du nochmal von Github testen?
https://github.com/simatec/ioBroker.pegelalarm.git -
Servus
Gab es mit der aktuellen Git Version noch einmal Ausfälle?
gerade gecheckt.
derzeit keine Ausfälle :) -
@sigi234 Sind nur kleine Änderungen und Anpassungen an Admin 5
Ok, läuft bei mir unter Admin 5.0.11 einwandfrei.
@sigi234 Guten Tag sigi,
ich wollte mal höflich nachfragen, ob Du mir diese Tabelle zur Verfügung stellen könntest, denn ich finde die super.
Dann würde ich noch gerne wissen, wie Du das gemacht hast, das Du mehr als 5 Stationen hinzugefügt hast.
@damrak2022 sagte in Test Adapter pegelalarm 1.2.x:
https://forum.iobroker.net/topic/28717/vis-von-sigi234?page=1
musst eine zusätzliche Instanz machen.
